[PATCH] arm: mvebu: turris_omnia: Fix SYS_RSTOUT_* macro names
This is A385 register.
Signed-off-by: Pali Rohár pali@kernel.org --- board/CZ.NIC/turris_omnia/turris_omnia.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/board/CZ.NIC/turris_omnia/turris_omnia.c b/board/CZ.NIC/turris_omnia/turris_omnia.c index 97292456f148..6132c8f94369 100644 --- a/board/CZ.NIC/turris_omnia/turris_omnia.c +++ b/board/CZ.NIC/turris_omnia/turris_omnia.c @@ -43,8 +43,8 @@ DECLARE_GLOBAL_DATA_PTR; #define OMNIA_I2C_EEPROM_CHIP_LEN 2 #define OMNIA_I2C_EEPROM_MAGIC 0x0341a034
-#define SYS_RSTOUT_MASK MVEBU_REGISTER(0x18260) -#define SYS_RSTOUT_MASK_WD BIT(10) +#define A385_SYS_RSTOUT_MASK MVEBU_REGISTER(0x18260) +#define A385_SYS_RSTOUT_MASK_WD BIT(10)
#define A385_WDT_GLOBAL_CTRL MVEBU_REGISTER(0x20300) #define A385_WDT_GLOBAL_RATIO_MASK GENMASK(18, 16) @@ -187,7 +187,7 @@ static void enable_a385_watchdog(unsigned int timeout_minutes) setbits_32(A385_WD_RSTOUT_UNMASK, A385_WD_RSTOUT_UNMASK_GLOBAL);
/* Unmask reset for watchdog */ - clrbits_32(SYS_RSTOUT_MASK, SYS_RSTOUT_MASK_WD); + clrbits_32(A385_SYS_RSTOUT_MASK, A385_SYS_RSTOUT_MASK_WD); }
static bool disable_mcu_watchdog(void)
Thanks, Stefan
Viele Grüße, Stefan Roese
Applied to u-boot-marvell/master
Thanks, Stefan
Pali Rohár
Stefan Roese
