[U-Boot-Users] [PATCH] 85xx io out functions need sync after write.
This fixes the mc146818 rtc_read/write functions for 85xx.
Signed-off-by: Ed Swarthout Ed.Swarthout@freescale.com ---
cpu/mpc85xx/start.S | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/cpu/mpc85xx/start.S b/cpu/mpc85xx/start.S index 2c98c2a..5d65190 100644 --- a/cpu/mpc85xx/start.S +++ b/cpu/mpc85xx/start.S @@ -701,6 +701,7 @@ in8: .globl out8 out8: stb r4,0x0000(r3) + sync blr
/*------------------------------------------------------------------------------- */ @@ -710,6 +711,7 @@ out8: .globl out16 out16: sth r4,0x0000(r3) + sync blr
/*------------------------------------------------------------------------------- */ @@ -719,6 +721,7 @@ out16: .globl out16r out16r: sthbrx r4,r0,r3 + sync blr
/*------------------------------------------------------------------------------- */ @@ -728,6 +731,7 @@ out16r: .globl out32 out32: stw r4,0x0000(r3) + sync blr
/*------------------------------------------------------------------------------- */ @@ -737,6 +741,7 @@ out32: .globl out32r out32r: stwbrx r4,r0,r3 + sync blr
applied, thanks
Andy
- sync
Another way would be to use the out_be32() and friends functions defined in asm-ppc/io.h. They already have the sync/barrier included and are recommened for accessing peripheral devices.
Best regards, Stefan
--- a/cpu/mpc85xx/start.S out8: stb r4,0x0000(r3)
- sync
Agreed, but grep finds 132 calls to out[813] in driver and rtc files.
I only noticed the missing sync's when debugging a failing "date" command that uses rtc/mc145818.
-Ed
In message B52955765C54604CB1A62A9967F22C73026F7696@az33exm20.fsl.freescale.net you wrote:
As Stefan already pointed out on #u-boot, this is just an indication that this is a pretty common error.
participants (5)
Andy Fleming
Ed Swarthout
Stefan Roese
Swarthout Edward L-SWARTHOU
