[U-Boot] Please pull u-boot-marvell master
Hi Tom,
this series contains the last bits of pending kirkwood/mvebu patches that I'm aware of. The changes from Gerald are minimal and I've merged Stefan's series which have reached v3 on the list.
The following changes since commit 7f641d53bbb3a426a3bfb132d8346153e86a9d08:
Merge branch 'master' of git://git.denx.de/u-boot-ubi (2015-02-04 13:30:00 -0500)
git://git.denx.de/u-boot-marvell.git
for you to fetch changes up to 68102b81e8fb699087ec5757a75676c6c65af3fd:
arm: mvebu: maxbcm: Fix compilation warning and add Spansion SPI NOR support (2015-02-06 17:25:08 +0100)
---------------------------------------------------------------- DrEagle (3): kirkwood: sheevaplug: fix style kirkwood: sheevaplug: fix multiple defines kirkwood: sheevaplug: add FDT support
Stefan Roese (11): arm: armada-xp: Change built target to include the SPL binary as bin_hdr arm: mvebu: Placeholder bin_hdr file can now be removed arm: maxbcm: Enable SPL to include DDR training code into U-Boot arm: db-mv784mp-gp: Enable SPL to include DDR training code into U-Boot Makefile: Add another kwb build target used on Marvell Armada-XP (AXP) tools: kwbimage: Support u-boot.img padding to CONFIG_SYS_SPI_U_BOOT_OFFS scripts/Makefile.spl: Add MVEBU DDR code to SPL arm: armada-xp: Add SPL support used to include the DDR training code arm: mvebu: Add Serdes PHY config code arm: mvebu: drivers/ddr: Add DDR3 driver with training code from Marvell bin_hdr arm: mvebu: maxbcm: Fix compilation warning and add Spansion SPI NOR support
Makefile | 6 + arch/arm/Kconfig | 2 + arch/arm/cpu/armv7/armada-xp/Makefile | 2 + arch/arm/cpu/armv7/armada-xp/lowlevel_spl.S | 62 + arch/arm/cpu/armv7/armada-xp/spl.c | 38 + arch/arm/include/asm/arch-armada-xp/config.h | 4 + arch/arm/include/asm/arch-armada-xp/cpu.h | 16 + arch/arm/mvebu-common/Makefile | 2 + arch/arm/mvebu-common/serdes/Makefile | 6 + arch/arm/mvebu-common/serdes/board_env_spec.h | 262 ++++ arch/arm/mvebu-common/serdes/high_speed_env_lib.c | 1572 +++++++++++++++++++ arch/arm/mvebu-common/serdes/high_speed_env_spec.c | 185 +++ arch/arm/mvebu-common/serdes/high_speed_env_spec.h | 87 ++ arch/arm/mvebu-common/u-boot-spl.lds | 57 + board/Marvell/db-mv784mp-gp/binary.0 | 17 - board/Marvell/db-mv784mp-gp/kwbimage.cfg | 2 +- board/maxbcm/binary.0 | 17 - board/maxbcm/kwbimage.cfg | 2 +- board/maxbcm/maxbcm.c | 85 +- configs/db-mv784mp-gp_defconfig | 5 +- configs/maxbcm_defconfig | 5 +- drivers/ddr/mvebu/Makefile | 14 + drivers/ddr/mvebu/ddr3_axp.h | 510 +++++++ drivers/ddr/mvebu/ddr3_axp_config.h | 146 ++ drivers/ddr/mvebu/ddr3_axp_mc_static.h | 284 ++++ drivers/ddr/mvebu/ddr3_axp_training_static.h | 770 ++++++++++ drivers/ddr/mvebu/ddr3_axp_vars.h | 226 +++ drivers/ddr/mvebu/ddr3_dfs.c | 1552 +++++++++++++++++++ drivers/ddr/mvebu/ddr3_dqs.c | 1374 +++++++++++++++++ drivers/ddr/mvebu/ddr3_hw_training.c | 1115 ++++++++++++++ drivers/ddr/mvebu/ddr3_hw_training.h | 392 +++++ drivers/ddr/mvebu/ddr3_init.c | 1219 +++++++++++++++ drivers/ddr/mvebu/ddr3_init.h | 143 ++ drivers/ddr/mvebu/ddr3_patterns_64bit.h | 924 ++++++++++++ drivers/ddr/mvebu/ddr3_pbs.c | 1592 ++++++++++++++++++++ drivers/ddr/mvebu/ddr3_read_leveling.c | 1214 +++++++++++++++ drivers/ddr/mvebu/ddr3_sdram.c | 669 ++++++++ drivers/ddr/mvebu/ddr3_spd.c | 1300 ++++++++++++++++ drivers/ddr/mvebu/ddr3_write_leveling.c | 1366 +++++++++++++++++ drivers/ddr/mvebu/xor.c | 436 ++++++ drivers/ddr/mvebu/xor.h | 70 + drivers/ddr/mvebu/xor_regs.h | 103 ++ include/configs/db-mv784mp-gp.h | 49 + include/configs/maxbcm.h | 49 + include/configs/sheevaplug.h | 7 +- scripts/Makefile.spl | 1 + tools/kwbimage.c | 11 + 47 files changed, 17925 insertions(+), 45 deletions(-) create mode 100644 arch/arm/cpu/armv7/armada-xp/lowlevel_spl.S create mode 100644 arch/arm/cpu/armv7/armada-xp/spl.c create mode 100644 arch/arm/mvebu-common/serdes/Makefile create mode 100644 arch/arm/mvebu-common/serdes/board_env_spec.h create mode 100644 arch/arm/mvebu-common/serdes/high_speed_env_lib.c create mode 100644 arch/arm/mvebu-common/serdes/high_speed_env_spec.c create mode 100644 arch/arm/mvebu-common/serdes/high_speed_env_spec.h create mode 100644 arch/arm/mvebu-common/u-boot-spl.lds delete mode 100644 board/Marvell/db-mv784mp-gp/binary.0 delete mode 100644 board/maxbcm/binary.0 create mode 100644 drivers/ddr/mvebu/Makefile create mode 100644 drivers/ddr/mvebu/ddr3_axp.h create mode 100644 drivers/ddr/mvebu/ddr3_axp_config.h create mode 100644 drivers/ddr/mvebu/ddr3_axp_mc_static.h create mode 100644 drivers/ddr/mvebu/ddr3_axp_training_static.h create mode 100644 drivers/ddr/mvebu/ddr3_axp_vars.h create mode 100644 drivers/ddr/mvebu/ddr3_dfs.c create mode 100644 drivers/ddr/mvebu/ddr3_dqs.c create mode 100644 drivers/ddr/mvebu/ddr3_hw_training.c create mode 100644 drivers/ddr/mvebu/ddr3_hw_training.h create mode 100644 drivers/ddr/mvebu/ddr3_init.c create mode 100644 drivers/ddr/mvebu/ddr3_init.h create mode 100644 drivers/ddr/mvebu/ddr3_patterns_64bit.h create mode 100644 drivers/ddr/mvebu/ddr3_pbs.c create mode 100644 drivers/ddr/mvebu/ddr3_read_leveling.c create mode 100644 drivers/ddr/mvebu/ddr3_sdram.c create mode 100644 drivers/ddr/mvebu/ddr3_spd.c create mode 100644 drivers/ddr/mvebu/ddr3_write_leveling.c create mode 100644 drivers/ddr/mvebu/xor.c create mode 100644 drivers/ddr/mvebu/xor.h create mode 100644 drivers/ddr/mvebu/xor_regs.h
Regards, Luka
On Fri, Feb 06, 2015 at 04:35:54PM +0000, Luka Perkov wrote:
Hi Tom,
Luka Perkov
