[U-Boot] init FEC @ MPC5200
Ben,
after cloning the latest u-boot git I can see that you've added this inside the mvBC-P board setup :
int board_eth_init(bd_t *bis) { cpu_eth_init(bis); /* Built in FEC comes first */ return pci_eth_init(bis); }
Are you aware that there's no PHY connected and the ETH-Pins are used otherwise ?
CONFIG_MPC5xxx_FEC is _not_ defined.
Can you tell me where "cpu_eth_init(bis)" is actually pointing to ?
regards, André
MATRIX VISION GmbH, Talstraße 16, DE-71570 Oppenweiler - Registergericht: Amtsgericht Stuttgart, HRB 271090 Geschäftsführer: Gerhard Thullner, Werner Armingeon, Uwe Furtner
Andre Schwarz wrote:
Ben,
Since CONFIG_MPC5xxx_FEC isn't defined, the default weak cpu_eth_init() function in net/eth.c should get called, which does essentially nothing. I assumed that since you #undef'd the FEC controller in your board header file (instead of leaving it out completely), that it was perhaps optional, and so kept the call to cpu_eth_init() as shown above.
Are you seeing a problem with this?
regards, André
regards, Ben
Ben,
ok - missed that.
no - just wanted to know.
Thanks for the hint, André
regards, André
regards, Ben
Andre Schwarz
André Schwarz
Ben Warren
