[PATCH 0/3] rockchip: Add Xunlong Orange Pi 5 and 5 Plus boards
This series add support for Xunlong Orange Pi 5 and 5 Plus boards.
First patch add support for the SPI NOR Flash used on the two boards. Second patch add support for the Xunlong Orange Pi 5 RK3588S board. Third patch add support for the Xunlong Orange Pi 5 Plus RK3588 board.
This series depends on the following series for a clean apply: - rockchip: rk3588: Sync pcie and usb3 nodes from linux [1] - board: rockchip: add FriendlyElec NanoPC-T6 rk3588 board [2]
[1] https://patchwork.ozlabs.org/cover/1850311/ [2] https://patchwork.ozlabs.org/patch/1847842/
Jonas Karlman (2): board: rockchip: Add Xunlong Orange Pi 5 board: rockchip: Add Xunlong Orange Pi 5 Plus
Ricardo Pardini (1): mtd: spi-nor: Add support for XMC XM25QU128C
arch/arm/dts/Makefile | 2 + .../dts/rk3588-orangepi-5-plus-u-boot.dtsi | 27 + arch/arm/dts/rk3588-orangepi-5-plus.dts | 848 ++++++++++++++++++ arch/arm/dts/rk3588s-orangepi-5-u-boot.dtsi | 22 + arch/arm/dts/rk3588s-orangepi-5.dts | 662 ++++++++++++++ board/rockchip/evb_rk3588/MAINTAINERS | 14 + configs/orangepi-5-plus-rk3588_defconfig | 105 +++ configs/orangepi-5-rk3588s_defconfig | 102 +++ doc/board/rockchip/rockchip.rst | 2 + drivers/mtd/spi/spi-nor-ids.c | 1 + 10 files changed, 1785 insertions(+) create mode 100644 arch/arm/dts/rk3588-orangepi-5-plus-u-boot.dtsi create mode 100644 arch/arm/dts/rk3588-orangepi-5-plus.dts create mode 100644 arch/arm/dts/rk3588s-orangepi-5-u-boot.dtsi create mode 100644 arch/arm/dts/rk3588s-orangepi-5.dts create mode 100644 configs/orangepi-5-plus-rk3588_defconfig create mode 100644 configs/orangepi-5-rk3588s_defconfig
Add support for XMC XM25QU128C (128M-bit) Serial Flash memory. Used on the Xunlong Orange Pi 3B, 5 and 5 Plus boards.
Datasheet: https://www.xmcwh.com/uploads/806/XM25QU128C_Ver2.0.pdf
Signed-off-by: Ricardo Pardini ricardo@pardini.net [jonas@kwiboo.se: update commit message] Signed-off-by: Jonas Karlman jonas@kwiboo.se --- drivers/mtd/spi/spi-nor-ids.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/mtd/spi/spi-nor-ids.c b/drivers/mtd/spi/spi-nor-ids.c index 5c35171ffd55..392db5c99e84 100644 --- a/drivers/mtd/spi/spi-nor-ids.c +++ b/drivers/mtd/spi/spi-nor-ids.c @@ -536,6 +536,7 @@ const struct flash_info spi_nor_ids[] = { { INFO("XM25QH64A", 0x207017, 0, 64 * 1024, 128, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("XM25QH64C", 0x204017, 0, 64 * 1024, 128, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("XM25QH128A", 0x207018, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("XM25QU128C", 0x204118, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, #endif #ifdef CONFIG_SPI_FLASH_XTX /* XTX Technology Limited */
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- { INFO("XM25QU128C", 0x204118, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, #endif #ifdef CONFIG_SPI_FLASH_XTX /* XTX Technology Limited */
Xunlong Orange Pi 5 is a single-board computer based on the Rockchip RK3588S SoC. The board provides abundant interfaces, HDMI output, GPIO interface, M.2 PCIe2.0, Type-C, Gigabit LAN port, 2*USB2.0, 1*USB3.0, etc.
Features tested on a Orange Pi 5 4GB v1.2: - SD-card boot - SPI Flash boot - PCIe/NVMe - USB 2.0 host - Ethernet
Device tree is imported from linux v6.7-rockchip-dts64-1 tag.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- Cc: Muhammed Efe Cetin efectn@6tel.net --- arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3588s-orangepi-5-u-boot.dtsi | 22 + arch/arm/dts/rk3588s-orangepi-5.dts | 662 ++++++++++++++++++++ board/rockchip/evb_rk3588/MAINTAINERS | 7 + configs/orangepi-5-rk3588s_defconfig | 102 +++ doc/board/rockchip/rockchip.rst | 1 + 6 files changed, 795 insertions(+) create mode 100644 arch/arm/dts/rk3588s-orangepi-5-u-boot.dtsi create mode 100644 arch/arm/dts/rk3588s-orangepi-5.dts create mode 100644 configs/orangepi-5-rk3588s_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 490709359553..fd99bb76fa6b 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -192,6 +192,7 @@ dtb-$(CONFIG_ROCKCHIP_RK3588) += \ rk3588-edgeble-neu6b-io.dtb \ rk3588-evb1-v10.dtb \ rk3588-nanopc-t6.dtb \ + rk3588s-orangepi-5.dtb \ rk3588s-rock-5a.dtb \ rk3588-rock-5b.dtb
diff --git a/arch/arm/dts/rk3588s-orangepi-5-u-boot.dtsi b/arch/arm/dts/rk3588s-orangepi-5-u-boot.dtsi new file mode 100644 index 000000000000..888d1b9c12d7 --- /dev/null +++ b/arch/arm/dts/rk3588s-orangepi-5-u-boot.dtsi @@ -0,0 +1,22 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +#include "rk3588s-u-boot.dtsi" + +/ { + chosen { + u-boot,spl-boot-order = "same-as-spl", &sdmmc; + }; +}; + +&fspim0_pins { + bootph-all; +}; + +&sfc { + bootph-pre-ram; + u-boot,spl-sfc-no-dma; + + flash@0 { + bootph-pre-ram; + }; +}; diff --git a/arch/arm/dts/rk3588s-orangepi-5.dts b/arch/arm/dts/rk3588s-orangepi-5.dts new file mode 100644 index 000000000000..8f399c4317bd --- /dev/null +++ b/arch/arm/dts/rk3588s-orangepi-5.dts @@ -0,0 +1,662 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +/dts-v1/; + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/leds/common.h> +#include <dt-bindings/input/input.h> +#include <dt-bindings/pinctrl/rockchip.h> +#include "rk3588s.dtsi" + +/ { + model = "Xunlong Orange Pi 5"; + compatible = "xunlong,orangepi-5", "rockchip,rk3588s"; + + aliases { + mmc0 = &sdmmc; + serial2 = &uart2; + }; + + chosen { + stdout-path = "serial2:1500000n8"; + }; + + adc-keys { + compatible = "adc-keys"; + io-channels = <&saradc 1>; + io-channel-names = "buttons"; + keyup-threshold-microvolt = <1800000>; + poll-interval = <100>; + + button-recovery { + label = "Recovery"; + linux,code = <KEY_VENDOR>; + press-threshold-microvolt = <1800>; + }; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 =<&leds_gpio>; + + led-1 { + gpios = <&gpio1 RK_PA2 GPIO_ACTIVE_HIGH>; + label = "status_led"; + linux,default-trigger = "heartbeat"; + }; + }; + + vbus_typec: vbus-typec-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio3 RK_PC0 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&typec5v_pwren>; + regulator-name = "vbus_typec"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc5v0_sys>; + }; + + vcc5v0_sys: vcc5v0-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + vcc_3v3_sd_s0: vcc-3v3-sd-s0-regulator { + compatible = "regulator-fixed"; + enable-active-low; + gpios = <&gpio4 RK_PB5 GPIO_ACTIVE_LOW>; + regulator-name = "vcc_3v3_sd_s0"; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc_3v3_s3>; + }; + + vcc3v3_pcie20: vcc3v3-pcie20-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpios = <&gpio0 RK_PC5 GPIO_ACTIVE_HIGH>; + regulator-name = "vcc3v3_pcie20"; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + startup-delay-us = <50000>; + vin-supply = <&vcc5v0_sys>; + }; +}; + +&combphy0_ps { + status = "okay"; +}; + +&combphy2_psu { + status = "okay"; +}; + +&cpu_b0 { + cpu-supply = <&vdd_cpu_big0_s0>; +}; + +&cpu_b1 { + cpu-supply = <&vdd_cpu_big0_s0>; +}; + +&cpu_b2 { + cpu-supply = <&vdd_cpu_big1_s0>; +}; + +&cpu_b3 { + cpu-supply = <&vdd_cpu_big1_s0>; +}; + +&cpu_l0 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&cpu_l1 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&cpu_l2 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&cpu_l3 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&gmac1 { + clock_in_out = "output"; + phy-handle = <&rgmii_phy1>; + phy-mode = "rgmii-rxid"; + pinctrl-0 = <&gmac1_miim + &gmac1_tx_bus2 + &gmac1_rx_bus2 + &gmac1_rgmii_clk + &gmac1_rgmii_bus>; + pinctrl-names = "default"; + tx_delay = <0x42>; + status = "okay"; +}; + +&i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c0m2_xfer>; + status = "okay"; + + vdd_cpu_big0_s0: regulator@42 { + compatible = "rockchip,rk8602"; + reg = <0x42>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu_big0_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <1050000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_big1_s0: regulator@43 { + compatible = "rockchip,rk8603", "rockchip,rk8602"; + reg = <0x43>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu_big1_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <1050000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; +}; + +&i2c2 { + status = "okay"; + + vdd_npu_s0: regulator@42 { + compatible = "rockchip,rk8602"; + reg = <0x42>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_npu_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; +}; + +&i2c6 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c6m3_xfer>; + status = "okay"; + + hym8563: rtc@51 { + compatible = "haoyu,hym8563"; + reg = <0x51>; + #clock-cells = <0>; + clock-output-names = "hym8563"; + pinctrl-names = "default"; + pinctrl-0 = <&hym8563_int>; + interrupt-parent = <&gpio0>; + interrupts = <RK_PB0 IRQ_TYPE_LEVEL_LOW>; + wakeup-source; + }; +}; + +&mdio1 { + rgmii_phy1: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0x1>; + reset-assert-us = <20000>; + reset-deassert-us = <100000>; + reset-gpios = <&gpio3 RK_PB2 GPIO_ACTIVE_LOW>; + }; +}; + +&pcie2x1l2 { + reset-gpios = <&gpio3 RK_PD1 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&vcc3v3_pcie20>; + status = "okay"; +}; + +&pinctrl { + gpio-func { + leds_gpio: leds-gpio { + rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + hym8563 { + hym8563_int: hym8563-int { + rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb-typec { + usbc0_int: usbc0-int { + rockchip,pins = <0 RK_PD3 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + typec5v_pwren: typec5v-pwren { + rockchip,pins = <3 RK_PC0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&saradc { + vref-supply = <&avcc_1v8_s0>; + status = "okay"; +}; + +&sdmmc { + bus-width = <4>; + cap-sd-highspeed; + disable-wp; + max-frequency = <150000000>; + no-mmc; + no-sdio; + sd-uhs-sdr104; + vmmc-supply = <&vcc_3v3_sd_s0>; + vqmmc-supply = <&vccio_sd_s0>; + status = "okay"; +}; + +&sfc { + pinctrl-names = "default"; + pinctrl-0 = <&fspim0_pins>; + status = "okay"; + + flash@0 { + compatible = "jedec,spi-nor"; + reg = <0x0>; + spi-max-frequency = <100000000>; + spi-rx-bus-width = <4>; + spi-tx-bus-width = <1>; + }; +}; + +&spi2 { + status = "okay"; + assigned-clocks = <&cru CLK_SPI2>; + assigned-clock-rates = <200000000>; + num-cs = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&spi2m2_cs0 &spi2m2_pins>; + + pmic@0 { + compatible = "rockchip,rk806"; + reg = <0x0>; + interrupt-parent = <&gpio0>; + interrupts = <7 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_pins>, <&rk806_dvs1_null>, + <&rk806_dvs2_null>, <&rk806_dvs3_null>; + spi-max-frequency = <1000000>; + + vcc1-supply = <&vcc5v0_sys>; + vcc2-supply = <&vcc5v0_sys>; + vcc3-supply = <&vcc5v0_sys>; + vcc4-supply = <&vcc5v0_sys>; + vcc5-supply = <&vcc5v0_sys>; + vcc6-supply = <&vcc5v0_sys>; + vcc7-supply = <&vcc5v0_sys>; + vcc8-supply = <&vcc5v0_sys>; + vcc9-supply = <&vcc5v0_sys>; + vcc10-supply = <&vcc5v0_sys>; + vcc11-supply = <&vcc_2v0_pldo_s3>; + vcc12-supply = <&vcc5v0_sys>; + vcc13-supply = <&vcc_1v1_nldo_s3>; + vcc14-supply = <&vcc_1v1_nldo_s3>; + vcca-supply = <&vcc5v0_sys>; + + gpio-controller; + #gpio-cells = <2>; + + rk806_dvs1_null: dvs1-null-pins { + pins = "gpio_pwrctrl2"; + function = "pin_fun0"; + }; + + rk806_dvs2_null: dvs2-null-pins { + pins = "gpio_pwrctrl2"; + function = "pin_fun0"; + }; + + rk806_dvs3_null: dvs3-null-pins { + pins = "gpio_pwrctrl3"; + function = "pin_fun0"; + }; + + regulators { + vdd_gpu_s0: dcdc-reg1 { + regulator-name = "vdd_gpu_s0"; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <12500>; + regulator-enable-ramp-delay = <400>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_lit_s0: dcdc-reg2 { + regulator-name = "vdd_cpu_lit_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_log_s0: dcdc-reg3 { + regulator-name = "vdd_log_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <675000>; + regulator-max-microvolt = <750000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <750000>; + }; + }; + + vdd_vdenc_s0: dcdc-reg4 { + regulator-name = "vdd_vdenc_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_ddr_s0: dcdc-reg5 { + regulator-name = "vdd_ddr_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <675000>; + regulator-max-microvolt = <900000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <850000>; + }; + }; + + vcc_1v1_nldo_s3: vdd2_ddr_s3: dcdc-reg6 { + regulator-name = "vdd2_ddr_s3"; + regulator-always-on; + regulator-boot-on; + regulator-max-microvolt = <1100000>; + regulator-min-microvolt = <1100000>; + + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_2v0_pldo_s3: dcdc-reg7 { + regulator-name = "vdd_2v0_pldo_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <2000000>; + regulator-max-microvolt = <2000000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <2000000>; + }; + }; + + vcc_3v3_s3: dcdc-reg8 { + regulator-name = "vcc_3v3_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vddq_ddr_s0: dcdc-reg9 { + regulator-name = "vddq_ddr_s0"; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v8_s3: dcdc-reg10 { + regulator-name = "vcc_1v8_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + avcc_1v8_s0: pldo-reg1 { + regulator-name = "avcc_1v8_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v8_s0: pldo-reg2 { + regulator-name = "vcc_1v8_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + avdd_1v2_s0: pldo-reg3 { + regulator-name = "avdd_1v2_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_3v3_s0: pldo-reg4 { + regulator-name = "vcc_3v3_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vccio_sd_s0: pldo-reg5 { + regulator-name = "vccio_sd_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + pldo6_s3: pldo-reg6 { + regulator-name = "pldo6_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vdd_0v75_s3: nldo-reg1 { + regulator-name = "vdd_0v75_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <750000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <750000>; + }; + }; + + vdd_ddr_pll_s0: nldo-reg2 { + regulator-name = "vdd_ddr_pll_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <850000>; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <850000>; + }; + }; + + avdd_0v75_s0: nldo-reg3 { + regulator-name = "avdd_0v75_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <750000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_0v85_s0: nldo-reg4 { + regulator-name = "vdd_0v85_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <850000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_0v75_s0: nldo-reg5 { + regulator-name = "vdd_0v75_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <750000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; + }; +}; + +&tsadc { + status = "okay"; +}; + +&u2phy2 { + status = "okay"; +}; + +&u2phy2_host { + status = "okay"; +}; + +&u2phy3 { + status = "okay"; +}; + +&u2phy3_host { + status = "okay"; +}; + +&uart2 { + pinctrl-0 = <&uart2m0_xfer>; + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +}; diff --git a/board/rockchip/evb_rk3588/MAINTAINERS b/board/rockchip/evb_rk3588/MAINTAINERS index 6b2c257a1705..c75f47254066 100644 --- a/board/rockchip/evb_rk3588/MAINTAINERS +++ b/board/rockchip/evb_rk3588/MAINTAINERS @@ -6,3 +6,10 @@ F: include/configs/evb_rk3588.h F: configs/evb-rk3588_defconfig F: arch/arm/dts/rk3588-evb1-v10.dts F: arch/arm/dts/rk3588-evb1-v10-u-boot.dtsi + +ORANGEPI-5-RK3588 +M: Jonas Karlman jonas@kwiboo.se +S: Maintained +F: configs/orangepi-5-rk3588s_defconfig +F: arch/arm/dts/rk3588s-orangepi-5.dts +F: arch/arm/dts/rk3588s-orangepi-5-u-boot.dtsi diff --git a/configs/orangepi-5-rk3588s_defconfig b/configs/orangepi-5-rk3588s_defconfig new file mode 100644 index 000000000000..feb45a53853b --- /dev/null +++ b/configs/orangepi-5-rk3588s_defconfig @@ -0,0 +1,102 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_TEXT_BASE=0x00a00000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc00000 +CONFIG_SF_DEFAULT_SPEED=24000000 +CONFIG_SF_DEFAULT_MODE=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="rk3588s-orangepi-5" +CONFIG_ROCKCHIP_RK3588=y +CONFIG_SPL_ROCKCHIP_COMMON_BOARD=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_STACK_R_ADDR=0x600000 +CONFIG_TARGET_EVB_RK3588=y +CONFIG_SPL_STACK=0x400000 +CONFIG_DEBUG_UART_BASE=0xFEB50000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI=y +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_PCI=y +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3588s-orangepi-5.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x4000000 +CONFIG_SPL_BSS_MAX_SIZE=0x4000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x60000 +CONFIG_SPL_ATF=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_AHCI_PCI=y +CONFIG_DWC_AHCI=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_SF_DEFAULT_BUS=5 +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_XMC=y +CONFIG_PHY_MOTORCOMM=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y +CONFIG_NVME_PCI=y +CONFIG_PCIE_DW_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y +CONFIG_PHY_ROCKCHIP_USBDP=y +CONFIG_SPL_PINCTRL=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_SPL_RAM=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_ROCKCHIP_SFC=y +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_DM_USB_GADGET=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_ERRNO_STR=y diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index f8f0e66a9cde..a4b69b345d91 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -118,6 +118,7 @@ List of mainline supported Rockchip boards: - FriendlyElec NanoPC-T6 (nanopc-t6-rk3588) - Radxa ROCK 5A (rock5a-rk3588s) - Radxa ROCK 5B (rock5b-rk3588) + - Xunlong Orange Pi 5 (orangepi-5-rk3588s)
* rv1108 - Rockchip Evb-rv1108 (evb-rv1108)
- SD-card boot
- SPI Flash boot
- PCIe/NVMe
- USB 2.0 host
- Ethernet
Thanks, - Kever
- rk3588s-orangepi-5.dtb \ rk3588s-rock-5a.dtb \ rk3588-rock-5b.dtb
- chosen {
+&fspim0_pins {
- bootph-all;
+&sfc {
- bootph-pre-ram;
- u-boot,spl-sfc-no-dma;
- flash@0 {
bootph-pre-ram;
+/dts-v1/;
- model = "Xunlong Orange Pi 5";
- compatible = "xunlong,orangepi-5", "rockchip,rk3588s";
- aliases {
mmc0 = &sdmmc;
serial2 = &uart2;
- chosen {
- adc-keys {
button-recovery {
label = "Recovery";
- leds {
led-1 {
- vbus_typec: vbus-typec-regulator {
enable-active-high;
- vcc5v0_sys: vcc5v0-sys-regulator {
regulator-boot-on;
- vcc_3v3_sd_s0: vcc-3v3-sd-s0-regulator {
enable-active-low;
regulator-boot-on;
- vcc3v3_pcie20: vcc3v3-pcie20-regulator {
enable-active-high;
regulator-boot-on;
+&combphy0_ps {
- status = "okay";
+&combphy2_psu {
- status = "okay";
+&cpu_b0 {
- cpu-supply = <&vdd_cpu_big0_s0>;
+&cpu_b1 {
+&cpu_b2 {
- cpu-supply = <&vdd_cpu_big1_s0>;
+&cpu_b3 {
+&cpu_l0 {
- cpu-supply = <&vdd_cpu_lit_s0>;
+&cpu_l1 {
+&cpu_l2 {
+&cpu_l3 {
+&gmac1 {
- clock_in_out = "output";
- phy-handle = <&rgmii_phy1>;
- phy-mode = "rgmii-rxid";
- pinctrl-0 = <&gmac1_miim
&gmac1_tx_bus2
&gmac1_rx_bus2
&gmac1_rgmii_clk
&gmac1_rgmii_bus>;
- pinctrl-names = "default";
- tx_delay = <0x42>;
- status = "okay";
+&i2c0 {
- pinctrl-0 = <&i2c0m2_xfer>;
- status = "okay";
- vdd_cpu_big0_s0: regulator@42 {
reg = <0x42>;
regulator-boot-on;
- vdd_cpu_big1_s0: regulator@43 {
reg = <0x43>;
regulator-boot-on;
+&i2c2 {
- status = "okay";
- vdd_npu_s0: regulator@42 {
reg = <0x42>;
regulator-boot-on;
+&i2c6 {
- pinctrl-0 = <&i2c6m3_xfer>;
- status = "okay";
- hym8563: rtc@51 {
reg = <0x51>;
#clock-cells = <0>;
wakeup-source;
+&mdio1 {
- rgmii_phy1: ethernet-phy@1 {
reg = <0x1>;
+&pcie2x1l2 {
- reset-gpios = <&gpio3 RK_PD1 GPIO_ACTIVE_HIGH>;
- vpcie3v3-supply = <&vcc3v3_pcie20>;
- status = "okay";
+&pinctrl {
- gpio-func {
- hym8563 {
- usb-typec {
+&saradc {
- vref-supply = <&avcc_1v8_s0>;
- status = "okay";
+&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- max-frequency = <150000000>;
- no-mmc;
- no-sdio;
- sd-uhs-sdr104;
- vmmc-supply = <&vcc_3v3_sd_s0>;
- vqmmc-supply = <&vccio_sd_s0>;
- status = "okay";
+&sfc {
- pinctrl-0 = <&fspim0_pins>;
- status = "okay";
- flash@0 {
reg = <0x0>;
+&spi2 {
- status = "okay";
- assigned-clocks = <&cru CLK_SPI2>;
- assigned-clock-rates = <200000000>;
- num-cs = <1>;
- pinctrl-0 = <&spi2m2_cs0 &spi2m2_pins>;
- pmic@0 {
reg = <0x0>;
gpio-controller;
#gpio-cells = <2>;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
+&tsadc {
- status = "okay";
+&u2phy2 {
- status = "okay";
+&u2phy2_host {
- status = "okay";
+&u2phy3 {
- status = "okay";
+&u2phy3_host {
- status = "okay";
+&uart2 {
- pinctrl-0 = <&uart2m0_xfer>;
- status = "okay";
+&usb_host0_ehci {
- status = "okay";
+&usb_host0_ohci {
- status = "okay";
+&usb_host1_ehci {
- status = "okay";
+&usb_host1_ohci {
- status = "okay";
- rv1108
Xunlong Orange Pi 5 Plus is a single-board computer based on the Rockchip RK3588 SoC. The board provides abundant interfaces, including two HDMI output ports, one HDMI input port, two 2.5G Ethernet ports, M.2 M-Key slot, M.2 E-Key slot, two USB 3.0, two USB 2.0, and two Type-C.
Features tested on a Orange Pi 5 Plus 4GB v1.2: - SD-card boot - eMMC boot - SPI Flash boot - PCIe/NVMe - USB 2.0 host - Ethernet
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- Cc: Ondrej Jirman megi@xff.cz --- arch/arm/dts/Makefile | 1 + .../dts/rk3588-orangepi-5-plus-u-boot.dtsi | 27 + arch/arm/dts/rk3588-orangepi-5-plus.dts | 848 ++++++++++++++++++ board/rockchip/evb_rk3588/MAINTAINERS | 7 + configs/orangepi-5-plus-rk3588_defconfig | 105 +++ doc/board/rockchip/rockchip.rst | 1 + 6 files changed, 989 insertions(+) create mode 100644 arch/arm/dts/rk3588-orangepi-5-plus-u-boot.dtsi create mode 100644 arch/arm/dts/rk3588-orangepi-5-plus.dts create mode 100644 configs/orangepi-5-plus-rk3588_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index fd99bb76fa6b..c1a760592df5 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -193,6 +193,7 @@ dtb-$(CONFIG_ROCKCHIP_RK3588) += \ rk3588-evb1-v10.dtb \ rk3588-nanopc-t6.dtb \ rk3588s-orangepi-5.dtb \ + rk3588-orangepi-5-plus.dtb \ rk3588s-rock-5a.dtb \ rk3588-rock-5b.dtb
diff --git a/arch/arm/dts/rk3588-orangepi-5-plus-u-boot.dtsi b/arch/arm/dts/rk3588-orangepi-5-plus-u-boot.dtsi new file mode 100644 index 000000000000..b0f5c667197c --- /dev/null +++ b/arch/arm/dts/rk3588-orangepi-5-plus-u-boot.dtsi @@ -0,0 +1,27 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +#include "rk3588-u-boot.dtsi" + +/ { + chosen { + u-boot,spl-boot-order = "same-as-spl", &sdmmc, &sdhci; + }; +}; + +&fspim1_pins { + bootph-all; +}; + +&sdhci { + cap-mmc-highspeed; + mmc-hs200-1_8v; +}; + +&sfc { + bootph-pre-ram; + u-boot,spl-sfc-no-dma; + + flash@0 { + bootph-pre-ram; + }; +}; diff --git a/arch/arm/dts/rk3588-orangepi-5-plus.dts b/arch/arm/dts/rk3588-orangepi-5-plus.dts new file mode 100644 index 000000000000..298c183d6f4f --- /dev/null +++ b/arch/arm/dts/rk3588-orangepi-5-plus.dts @@ -0,0 +1,848 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2023 Ondřej Jirman megi@xff.cz + */ + +/dts-v1/; + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/leds/common.h> +#include <dt-bindings/input/input.h> +#include <dt-bindings/pinctrl/rockchip.h> +#include <dt-bindings/usb/pd.h> +#include "rk3588.dtsi" + +/ { + model = "Xunlong Orange Pi 5 Plus"; + compatible = "xunlong,orangepi-5-plus", "rockchip,rk3588"; + + aliases { + mmc0 = &sdhci; + mmc1 = &sdmmc; + serial2 = &uart2; + }; + + chosen { + stdout-path = "serial2:1500000n8"; + }; + + adc-keys-0 { + compatible = "adc-keys"; + io-channels = <&saradc 0>; + io-channel-names = "buttons"; + keyup-threshold-microvolt = <1800000>; + poll-interval = <100>; + + button-maskrom { + label = "Mask Rom"; + linux,code = <KEY_SETUP>; + press-threshold-microvolt = <2000>; + }; + }; + + adc-keys-1 { + compatible = "adc-keys"; + io-channels = <&saradc 1>; + io-channel-names = "buttons"; + keyup-threshold-microvolt = <1800000>; + poll-interval = <100>; + + button-recovery { + label = "Recovery"; + linux,code = <KEY_VENDOR>; + press-threshold-microvolt = <2000>; + }; + }; + + speaker_amp: speaker-audio-amplifier { + compatible = "simple-audio-amplifier"; + enable-gpios = <&gpio3 RK_PC0 GPIO_ACTIVE_HIGH>; + sound-name-prefix = "Speaker Amp"; + }; + + headphone_amp: headphones-audio-amplifier { + compatible = "simple-audio-amplifier"; + enable-gpios = <&gpio3 RK_PA7 GPIO_ACTIVE_HIGH>; + sound-name-prefix = "Headphones Amp"; + }; + + ir-receiver { + compatible = "gpio-ir-receiver"; + gpios = <&gpio4 RK_PB3 GPIO_ACTIVE_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&ir_receiver_pin>; + }; + + gpio-leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&blue_led_pin>; + + led { + color = <LED_COLOR_ID_BLUE>; + function = LED_FUNCTION_INDICATOR; + function-enumerator = <1>; + gpios = <&gpio3 RK_PA6 GPIO_ACTIVE_HIGH>; + }; + }; + + fan: pwm-fan { + compatible = "pwm-fan"; + cooling-levels = <0 70 75 80 100>; + fan-supply = <&vcc5v0_sys>; + pwms = <&pwm3 0 50000 0>; + #cooling-cells = <2>; + }; + + pwm-leds { + compatible = "pwm-leds"; + + led { + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_INDICATOR; + function-enumerator = <2>; + max-brightness = <255>; + pwms = <&pwm2 0 25000 0>; + }; + }; + + sound { + compatible = "simple-audio-card"; + pinctrl-names = "default"; + pinctrl-0 = <&hp_detect>; + simple-audio-card,name = "Analog"; + simple-audio-card,aux-devs = <&speaker_amp>, <&headphone_amp>; + simple-audio-card,format = "i2s"; + simple-audio-card,mclk-fs = <256>; + simple-audio-card,hp-det-gpio = <&gpio1 RK_PD3 GPIO_ACTIVE_LOW>; + simple-audio-card,bitclock-master = <&daicpu>; + simple-audio-card,frame-master = <&daicpu>; + /*TODO: SARADC_IN3 is used as MIC detection / key input */ + + simple-audio-card,widgets = + "Microphone", "Onboard Microphone", + "Microphone", "Microphone Jack", + "Speaker", "Speaker", + "Headphone", "Headphones"; + + simple-audio-card,routing = + "Headphones", "LOUT1", + "Headphones", "ROUT1", + "Speaker", "LOUT2", + "Speaker", "ROUT2", + + "Headphones", "Headphones Amp OUTL", + "Headphones", "Headphones Amp OUTR", + "Headphones Amp INL", "LOUT1", + "Headphones Amp INR", "ROUT1", + + "Speaker", "Speaker Amp OUTL", + "Speaker", "Speaker Amp OUTR", + "Speaker Amp INL", "LOUT2", + "Speaker Amp INR", "ROUT2", + + /* single ended signal to LINPUT1 */ + "LINPUT1", "Microphone Jack", + "RINPUT1", "Microphone Jack", + /* differential signal */ + "LINPUT2", "Onboard Microphone", + "RINPUT2", "Onboard Microphone"; + + daicpu: simple-audio-card,cpu { + sound-dai = <&i2s0_8ch>; + system-clock-frequency = <12288000>; + }; + + daicodec: simple-audio-card,codec { + sound-dai = <&es8388>; + system-clock-frequency = <12288000>; + }; + }; + + vcc3v3_pcie30: vcc3v3-pcie30-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpios = <&gpio2 RK_PB6 GPIO_ACTIVE_HIGH>; + regulator-name = "vcc3v3_pcie30"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + startup-delay-us = <5000>; + vin-supply = <&vcc5v0_sys>; + }; + + vcc3v3_pcie_eth: vcc3v3-pcie-eth-regulator { + compatible = "regulator-fixed"; + gpios = <&gpio3 RK_PB4 GPIO_ACTIVE_LOW>; + regulator-name = "vcc3v3_pcie_eth"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + startup-delay-us = <50000>; + vin-supply = <&vcc5v0_sys>; + }; + + vcc3v3_wf: vcc3v3-wf-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpios = <&gpio2 RK_PC5 GPIO_ACTIVE_HIGH>; + regulator-name = "vcc3v3_wf"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + startup-delay-us = <50000>; + vin-supply = <&vcc5v0_sys>; + }; + + vcc5v0_sys: vcc5v0-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + vcc5v0_usb20: vcc5v0-usb20-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc5v0_usb20_en>; + regulator-name = "vcc5v0_usb20"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc5v0_sys>; + }; +}; + +&combphy0_ps { + status = "okay"; +}; + +&combphy1_ps { + status = "okay"; +}; + +&combphy2_psu { + status = "okay"; +}; + +&cpu_b0 { + cpu-supply = <&vdd_cpu_big0_s0>; +}; + +&cpu_b1 { + cpu-supply = <&vdd_cpu_big0_s0>; +}; + +&cpu_b2 { + cpu-supply = <&vdd_cpu_big1_s0>; +}; + +&cpu_b3 { + cpu-supply = <&vdd_cpu_big1_s0>; +}; + +&cpu_l0 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&cpu_l1 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&cpu_l2 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&cpu_l3 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c0m2_xfer>; + status = "okay"; + + vdd_cpu_big0_s0: regulator@42 { + compatible = "rockchip,rk8602"; + reg = <0x42>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu_big0_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <1050000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_big1_s0: regulator@43 { + compatible = "rockchip,rk8603", "rockchip,rk8602"; + reg = <0x43>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu_big1_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <1050000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; +}; + +&i2c6 { + clock-frequency = <400000>; + status = "okay"; + + hym8563: rtc@51 { + compatible = "haoyu,hym8563"; + reg = <0x51>; + interrupt-parent = <&gpio0>; + interrupts = <RK_PB0 IRQ_TYPE_LEVEL_LOW>; + #clock-cells = <0>; + clock-output-names = "hym8563"; + pinctrl-names = "default"; + pinctrl-0 = <&hym8563_int>; + wakeup-source; + }; +}; + +&i2c7 { + status = "okay"; + + /* PLDO2 vcca 1.8V, BUCK8 gated by PLDO2 being enabled */ + es8388: audio-codec@11 { + compatible = "everest,es8388"; + reg = <0x11>; + clocks = <&cru I2S0_8CH_MCLKOUT>; + clock-names = "mclk"; + AVDD-supply = <&vcc_1v8_s0>; + DVDD-supply = <&vcc_1v8_s0>; + HPVDD-supply = <&vcc_3v3_s0>; + PVDD-supply = <&vcc_3v3_s0>; + assigned-clocks = <&cru I2S0_8CH_MCLKOUT>; + assigned-clock-rates = <12288000>; + #sound-dai-cells = <0>; + }; +}; + +&i2s0_8ch { + pinctrl-names = "default"; + pinctrl-0 = <&i2s0_lrck + &i2s0_mclk + &i2s0_sclk + &i2s0_sdi0 + &i2s0_sdo0>; + status = "okay"; +}; + +&i2s2_2ch { + pinctrl-names = "default"; + pinctrl-0 = <&i2s2m0_lrck + &i2s2m0_sclk + &i2s2m0_sdi + &i2s2m0_sdo>; + status = "okay"; +}; + +/* phy1 - M.KEY socket */ +&pcie2x1l0 { + reset-gpios = <&gpio4 RK_PA5 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&vcc3v3_wf>; + status = "okay"; +}; + +/* phy2 - right ethernet port */ +&pcie2x1l1 { + reset-gpios = <&gpio3 RK_PB3 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&vcc3v3_pcie_eth>; + status = "okay"; +}; + +/* phy0 - left ethernet port */ +&pcie2x1l2 { + reset-gpios = <&gpio4 RK_PA2 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&vcc3v3_pcie_eth>; + status = "okay"; +}; + +&pcie30phy { + status = "okay"; +}; + +&pcie3x4 { + reset-gpios = <&gpio4 RK_PB6 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&vcc3v3_pcie30>; + status = "okay"; +}; + +&pinctrl { + hym8563 { + hym8563_int: hym8563-int { + rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + leds { + blue_led_pin: blue-led { + rockchip,pins = <3 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + ir-receiver { + ir_receiver_pin: ir-receiver-pin { + rockchip,pins = <4 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + sound { + hp_detect: hp-detect { + rockchip,pins = <1 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb { + vcc5v0_usb20_en: vcc5v0-usb20-en { + rockchip,pins = <3 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&pwm2 { + pinctrl-0 = <&pwm2m1_pins>; + pinctrl-names = "default"; + status = "okay"; +}; + +&pwm3 { + pinctrl-0 = <&pwm3m1_pins>; + status = "okay"; +}; + +&saradc { + vref-supply = <&vcc_1v8_s0>; + status = "okay"; +}; + +&sdhci { + bus-width = <8>; + no-sdio; + no-sd; + non-removable; + max-frequency = <200000000>; + mmc-hs400-1_8v; + mmc-hs400-enhanced-strobe; + status = "okay"; +}; + +&sdmmc { + bus-width = <4>; + cap-sd-highspeed; + cd-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_LOW>; + disable-wp; + max-frequency = <150000000>; + no-sdio; + no-mmc; + sd-uhs-sdr104; + vmmc-supply = <&vcc_3v3_s3>; + vqmmc-supply = <&vccio_sd_s0>; + status = "okay"; +}; + +&sfc { + pinctrl-names = "default"; + pinctrl-0 = <&fspim1_pins>; + status = "okay"; + + spi_flash: flash@0 { + compatible = "jedec,spi-nor"; + reg = <0x0>; + spi-max-frequency = <100000000>; + spi-rx-bus-width = <4>; + spi-tx-bus-width = <1>; + }; +}; + +&spi2 { + assigned-clocks = <&cru CLK_SPI2>; + assigned-clock-rates = <200000000>; + num-cs = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&spi2m2_cs0 &spi2m2_pins>; + status = "okay"; + + pmic@0 { + compatible = "rockchip,rk806"; + reg = <0x0>; + interrupt-parent = <&gpio0>; + interrupts = <7 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_pins>, <&rk806_dvs1_null>, + <&rk806_dvs2_null>, <&rk806_dvs3_null>; + spi-max-frequency = <1000000>; + + vcc1-supply = <&vcc5v0_sys>; + vcc2-supply = <&vcc5v0_sys>; + vcc3-supply = <&vcc5v0_sys>; + vcc4-supply = <&vcc5v0_sys>; + vcc5-supply = <&vcc5v0_sys>; + vcc6-supply = <&vcc5v0_sys>; + vcc7-supply = <&vcc5v0_sys>; + vcc8-supply = <&vcc5v0_sys>; + vcc9-supply = <&vcc5v0_sys>; + vcc10-supply = <&vcc5v0_sys>; + vcc11-supply = <&vcc_2v0_pldo_s3>; + vcc12-supply = <&vcc5v0_sys>; + vcc13-supply = <&vdd2_ddr_s3>; + vcc14-supply = <&vdd2_ddr_s3>; + vcca-supply = <&vcc5v0_sys>; + + gpio-controller; + #gpio-cells = <2>; + + rk806_dvs1_null: dvs1-null-pins { + pins = "gpio_pwrctrl2"; + function = "pin_fun0"; + }; + + rk806_dvs2_null: dvs2-null-pins { + pins = "gpio_pwrctrl2"; + function = "pin_fun0"; + }; + + rk806_dvs3_null: dvs3-null-pins { + pins = "gpio_pwrctrl3"; + function = "pin_fun0"; + }; + + regulators { + vdd_gpu_s0: dcdc-reg1 { + regulator-name = "vdd_gpu_s0"; + regulator-boot-on; + regulator-enable-ramp-delay = <400>; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_lit_s0: dcdc-reg2 { + regulator-name = "vdd_cpu_lit_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_log_s0: dcdc-reg3 { + regulator-name = "vdd_log_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <675000>; + regulator-max-microvolt = <825000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <750000>; + }; + }; + + vdd_vdenc_s0: dcdc-reg4 { + regulator-name = "vdd_vdenc_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <825000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_ddr_s0: dcdc-reg5 { + regulator-name = "vdd_ddr_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <675000>; + regulator-max-microvolt = <900000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <850000>; + }; + }; + + vdd2_ddr_s3: dcdc-reg6 { + regulator-name = "vdd2_ddr_s3"; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_2v0_pldo_s3: dcdc-reg7 { + regulator-name = "vdd_2v0_pldo_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <2000000>; + regulator-max-microvolt = <2000000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <2000000>; + }; + }; + + vcc_3v3_s3: dcdc-reg8 { + regulator-name = "vcc_3v3_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vddq_ddr_s0: dcdc-reg9 { + regulator-name = "vddq_ddr_s0"; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v8_s3: dcdc-reg10 { + regulator-name = "vcc_1v8_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + avcc_1v8_s0: pldo-reg1 { + regulator-name = "avcc_1v8_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + /* shorted to avcc_1v8_s0 on the board */ + vcc_1v8_s0: pldo-reg2 { + regulator-name = "vcc_1v8_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + avdd_1v2_s0: pldo-reg3 { + regulator-name = "avdd_1v2_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_3v3_s0: pldo-reg4 { + regulator-name = "vcc_3v3_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vccio_sd_s0: pldo-reg5 { + regulator-name = "vccio_sd_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + pldo6_s3: pldo-reg6 { + regulator-name = "pldo6_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vdd_0v75_s3: nldo-reg1 { + regulator-name = "vdd_0v75_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <750000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <750000>; + }; + }; + + vdd_ddr_pll_s0: nldo-reg2 { + regulator-name = "vdd_ddr_pll_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <850000>; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <850000>; + }; + }; + + avdd_0v75_s0: nldo-reg3 { + regulator-name = "avdd_0v75_s0"; + regulator-always-on; + regulator-boot-on; + /* + * The schematic mentions that actual setting + * should be 0.8375V. RK3588 datasheet specifies + * maximum as 0.825V. So we set datasheet max + * here. + */ + regulator-min-microvolt = <825000>; + regulator-max-microvolt = <825000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_0v85_s0: nldo-reg4 { + regulator-name = "vdd_0v85_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <850000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_0v75_s0: nldo-reg5 { + regulator-name = "vdd_0v75_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <750000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; + }; +}; + +&tsadc { + status = "okay"; +}; + +&u2phy2 { + status = "okay"; +}; + +&u2phy3 { + status = "okay"; +}; + +&u2phy2_host { + phy-supply = <&vcc5v0_usb20>; + status = "okay"; +}; + +&u2phy3_host { + phy-supply = <&vcc5v0_usb20>; + status = "okay"; +}; + +&uart2 { + pinctrl-0 = <&uart2m0_xfer>; + status = "okay"; +}; + +&uart9 { + pinctrl-0 = <&uart9m0_xfer>; + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +}; diff --git a/board/rockchip/evb_rk3588/MAINTAINERS b/board/rockchip/evb_rk3588/MAINTAINERS index c75f47254066..2bd44bc58728 100644 --- a/board/rockchip/evb_rk3588/MAINTAINERS +++ b/board/rockchip/evb_rk3588/MAINTAINERS @@ -13,3 +13,10 @@ S: Maintained F: configs/orangepi-5-rk3588s_defconfig F: arch/arm/dts/rk3588s-orangepi-5.dts F: arch/arm/dts/rk3588s-orangepi-5-u-boot.dtsi + +ORANGEPI-5-PLUS-RK3588 +M: Jonas Karlman jonas@kwiboo.se +S: Maintained +F: configs/orangepi-5-plus-rk3588_defconfig +F: arch/arm/dts/rk3588-orangepi-5-plus.dts +F: arch/arm/dts/rk3588-orangepi-5-plus-u-boot.dtsi diff --git a/configs/orangepi-5-plus-rk3588_defconfig b/configs/orangepi-5-plus-rk3588_defconfig new file mode 100644 index 000000000000..04736996217e --- /dev/null +++ b/configs/orangepi-5-plus-rk3588_defconfig @@ -0,0 +1,105 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SYS_HAS_NONCACHED_MEMORY=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_TEXT_BASE=0x00a00000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc00000 +CONFIG_SF_DEFAULT_SPEED=24000000 +CONFIG_SF_DEFAULT_MODE=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="rk3588-orangepi-5-plus" +CONFIG_ROCKCHIP_RK3588=y +CONFIG_SPL_ROCKCHIP_COMMON_BOARD=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_STACK_R_ADDR=0x600000 +CONFIG_TARGET_EVB_RK3588=y +CONFIG_SPL_STACK=0x400000 +CONFIG_DEBUG_UART_BASE=0xFEB50000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI=y +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_PCI=y +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3588-orangepi-5-plus.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x4000000 +CONFIG_SPL_BSS_MAX_SIZE=0x4000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x60000 +CONFIG_SPL_ATF=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_AHCI_PCI=y +CONFIG_DWC_AHCI=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_SF_DEFAULT_BUS=5 +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_XMC=y +CONFIG_PHYLIB=y +CONFIG_RTL8169=y +CONFIG_NVME_PCI=y +CONFIG_PCIE_DW_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y +CONFIG_PHY_ROCKCHIP_USBDP=y +CONFIG_SPL_PINCTRL=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_SPL_RAM=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_ROCKCHIP_SFC=y +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_DM_USB_GADGET=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_ERRNO_STR=y diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index a4b69b345d91..ffbebd0bb3da 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -119,6 +119,7 @@ List of mainline supported Rockchip boards: - Radxa ROCK 5A (rock5a-rk3588s) - Radxa ROCK 5B (rock5b-rk3588) - Xunlong Orange Pi 5 (orangepi-5-rk3588s) + - Xunlong Orange Pi 5 Plus (orangepi-5-plus-rk3588)
- SD-card boot
- eMMC boot
- SPI Flash boot
- PCIe/NVMe
- USB 2.0 host
- Ethernet
Thanks, - Kever
- rk3588-orangepi-5-plus.dtb \ rk3588s-rock-5a.dtb \ rk3588-rock-5b.dtb
- chosen {
+&fspim1_pins {
- bootph-all;
+&sdhci {
- cap-mmc-highspeed;
- mmc-hs200-1_8v;
+&sfc {
- bootph-pre-ram;
- flash@0 {
bootph-pre-ram;
- Copyright (c) 2023 Ondřej Jirman megi@xff.cz
+/dts-v1/;
- model = "Xunlong Orange Pi 5 Plus";
- compatible = "xunlong,orangepi-5-plus", "rockchip,rk3588";
- aliases {
mmc0 = &sdhci;
mmc1 = &sdmmc;
serial2 = &uart2;
- chosen {
- adc-keys-0 {
button-maskrom {
label = "Mask Rom";
- adc-keys-1 {
button-recovery {
label = "Recovery";
- speaker_amp: speaker-audio-amplifier {
- headphone_amp: headphones-audio-amplifier {
- ir-receiver {
- gpio-leds {
led {
- fan: pwm-fan {
- pwm-leds {
led {
- sound {
"Speaker", "LOUT2",
"Speaker", "ROUT2",
- vcc3v3_pcie30: vcc3v3-pcie30-regulator {
enable-active-high;
- vcc3v3_pcie_eth: vcc3v3-pcie-eth-regulator {
- vcc3v3_wf: vcc3v3-wf-regulator {
enable-active-high;
regulator-boot-on;
- vcc5v0_usb20: vcc5v0-usb20-regulator {
enable-active-high;
+&combphy0_ps {
- status = "okay";
+&combphy1_ps {
- status = "okay";
+&combphy2_psu {
- status = "okay";
+&cpu_b0 {
+&cpu_b1 {
+&cpu_b2 {
+&cpu_b3 {
+&cpu_l0 {
+&cpu_l1 {
+&cpu_l2 {
+&cpu_l3 {
+&i2c0 {
- status = "okay";
reg = <0x42>;
regulator-boot-on;
reg = <0x43>;
regulator-boot-on;
+&i2c6 {
- clock-frequency = <400000>;
- status = "okay";
- hym8563: rtc@51 {
reg = <0x51>;
#clock-cells = <0>;
wakeup-source;
+&i2c7 {
- status = "okay";
- /* PLDO2 vcca 1.8V, BUCK8 gated by PLDO2 being enabled */
- es8388: audio-codec@11 {
reg = <0x11>;
+&i2s0_8ch {
- pinctrl-0 = <&i2s0_lrck
&i2s0_mclk
&i2s0_sclk
&i2s0_sdi0
&i2s0_sdo0>;
- status = "okay";
+&i2s2_2ch {
- pinctrl-0 = <&i2s2m0_lrck
&i2s2m0_sclk
&i2s2m0_sdi
&i2s2m0_sdo>;
- status = "okay";
- reset-gpios = <&gpio4 RK_PA5 GPIO_ACTIVE_HIGH>;
- vpcie3v3-supply = <&vcc3v3_wf>;
- status = "okay";
- reset-gpios = <&gpio3 RK_PB3 GPIO_ACTIVE_HIGH>;
- vpcie3v3-supply = <&vcc3v3_pcie_eth>;
- status = "okay";
- reset-gpios = <&gpio4 RK_PA2 GPIO_ACTIVE_HIGH>;
- status = "okay";
+&pcie30phy {
- status = "okay";
+&pcie3x4 {
- reset-gpios = <&gpio4 RK_PB6 GPIO_ACTIVE_HIGH>;
- vpcie3v3-supply = <&vcc3v3_pcie30>;
- status = "okay";
+&pinctrl {
- hym8563 {
- leds {
- ir-receiver {
- sound {
- usb {
+&pwm2 {
- pinctrl-0 = <&pwm2m1_pins>;
- status = "okay";
+&pwm3 {
- pinctrl-0 = <&pwm3m1_pins>;
- status = "okay";
+&saradc {
- vref-supply = <&vcc_1v8_s0>;
- status = "okay";
+&sdhci {
- bus-width = <8>;
- no-sdio;
- no-sd;
- non-removable;
- max-frequency = <200000000>;
- mmc-hs400-1_8v;
- mmc-hs400-enhanced-strobe;
- status = "okay";
+&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- cd-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_LOW>;
- disable-wp;
- no-sdio;
- no-mmc;
- sd-uhs-sdr104;
- vmmc-supply = <&vcc_3v3_s3>;
- status = "okay";
+&sfc {
- pinctrl-0 = <&fspim1_pins>;
- status = "okay";
- spi_flash: flash@0 {
reg = <0x0>;
+&spi2 {
- num-cs = <1>;
- status = "okay";
- pmic@0 {
reg = <0x0>;
gpio-controller;
#gpio-cells = <2>;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
* here.
regulator-boot-on;
regulator-boot-on;
+&tsadc {
- status = "okay";
+&u2phy2 {
- status = "okay";
+&u2phy3 {
- status = "okay";
+&u2phy2_host {
- phy-supply = <&vcc5v0_usb20>;
- status = "okay";
+&u2phy3_host {
- status = "okay";
+&uart2 {
- status = "okay";
+&uart9 {
- pinctrl-0 = <&uart9m0_xfer>;
- status = "okay";
+&usb_host0_ehci {
- status = "okay";
+&usb_host0_ohci {
- status = "okay";
+&usb_host1_ehci {
- status = "okay";
+&usb_host1_ohci {
- status = "okay";
- rv1108
Jonas Karlman
Kever Yang
