[PATCH v5 00/25] Add support for MediaTek MT7621 SoC - v5
This series will add support for MediaTek MT7621 SoC with two reference boards and related drivers.
The MediaTek MT7621 is a network processor integrating a dual-core dual-threaded MIPS 1004Kc processor running at a normal frequency of 880MHz. This chip can be found in many wireless routers.
This series add all basic drivers which are useful in u-boot, like usb, sdxc, ethernet, spi, nand and serial.
Currently this patch series only supports building the ram-bootable image as it needs the preloader from MediaTek SDK.
Thanks, Weijie
v5 changes: - Adjust mt7621.dtsi, clkctrl node moved to sysc, pinctrl default states moved to board dts files - Modify clk driver due to its node changed in mt7621.dtsi - Minor fixes
v4 changes: - Add full support for booting from flash
v3 changes: - Rewrite clk driver to follow definitions from upstream kernel - Implement noncached_alloc() for MIPS platform - Update register remap for mtk-eth driver needed by mt7621
v2 changes: - Add a kconfig for max supported ram size - Remove network configs from default config file - Add config file for mt7621-rfb boards
Weijie Gao (25): mips: add asm/mipsmtregs.h for MIPS multi-threading mips: add more definitions for asm/cm.h mips: add __image_copy_len for SPL linker script mips: add support for noncached_alloc() mips: mtmips: add support for MediaTek MT7621 SoC mips: mtmips: add two reference boards for mt7621 doc: mediatek: add documentation for mt7621 reference boards clk: mtmips: add clock driver for MediaTek MT7621 SoC reset: mtmips: add reset controller support for MediaTek MT7621 SoC pinctrl: mtmips: add support for MediaTek MT7621 SoC usb: xhci-mtk: add support for MediaTek MT7621 SoC phy: mtk-tphy: add support for MediaTek MT7621 SoC spi: add support for MediaTek MT7621 SoC gpio: add support for MediaTek MT7621 SoC watchdog: add support for MediaTek MT7621 SoC mmc: mediatek: add support for MediaTek MT7621 SoC net: mediatek: remap iobase address net: mediatek: use regmap api to modify ethsys registers net: mediatek: add support for MediaTek MT7621 SoC nand: raw: add support for MediaTek MT7621 SoC spl: allow using nand base without standard nand driver spl: spl_legacy: fix the use of SPL_COPY_PAYLOAD_ONLY spl: nand: support loading legacy image with payload compressed tools: mtk_image: add support for MT7621 NAND images MAINTAINERS: update maintainer for MediaTek MIPS platform
MAINTAINERS | 8 + arch/mips/cpu/u-boot-spl.lds | 3 + arch/mips/dts/Makefile | 2 + arch/mips/dts/mediatek,mt7621-nand-rfb.dts | 67 + arch/mips/dts/mediatek,mt7621-rfb.dts | 82 ++ arch/mips/dts/mt7621-u-boot.dtsi | 111 ++ arch/mips/dts/mt7621.dtsi | 349 +++++ arch/mips/include/asm/cm.h | 67 + arch/mips/include/asm/mipsmtregs.h | 142 ++ arch/mips/include/asm/system.h | 20 + arch/mips/lib/cache.c | 43 + arch/mips/mach-mtmips/Kconfig | 49 +- arch/mips/mach-mtmips/Makefile | 4 + arch/mips/mach-mtmips/cpu.c | 2 +- arch/mips/mach-mtmips/mt7621/Kconfig | 115 ++ arch/mips/mach-mtmips/mt7621/Makefile | 14 + arch/mips/mach-mtmips/mt7621/init.c | 229 +++ arch/mips/mach-mtmips/mt7621/mt7621.h | 229 +++ arch/mips/mach-mtmips/mt7621/serial.c | 23 + arch/mips/mach-mtmips/mt7621/spl/Makefile | 9 + arch/mips/mach-mtmips/mt7621/spl/cps.c | 152 ++ arch/mips/mach-mtmips/mt7621/spl/dram.c | 155 +++ arch/mips/mach-mtmips/mt7621/spl/dram.h | 39 + arch/mips/mach-mtmips/mt7621/spl/launch.c | 100 ++ arch/mips/mach-mtmips/mt7621/spl/launch.h | 52 + arch/mips/mach-mtmips/mt7621/spl/launch_ll.S | 357 +++++ arch/mips/mach-mtmips/mt7621/spl/serial.c | 24 + arch/mips/mach-mtmips/mt7621/spl/spl.c | 95 ++ arch/mips/mach-mtmips/mt7621/spl/start.S | 226 +++ arch/mips/mach-mtmips/mt7621/sram_init.S | 22 + arch/mips/mach-mtmips/mt7621/tpl/Makefile | 4 + arch/mips/mach-mtmips/mt7621/tpl/start.S | 161 +++ arch/mips/mach-mtmips/mt7621/tpl/tpl.c | 146 ++ board/mediatek/mt7621/MAINTAINERS | 8 + board/mediatek/mt7621/Makefile | 3 + board/mediatek/mt7621/board.c | 6 + common/spl/Kconfig | 2 +- common/spl/spl_legacy.c | 21 +- common/spl/spl_nand.c | 27 + configs/mt7621_nand_rfb_defconfig | 83 ++ configs/mt7621_rfb_defconfig | 82 ++ doc/board/mediatek/mt7621.rst | 48 + drivers/clk/mtmips/Makefile | 1 + drivers/clk/mtmips/clk-mt7621.c | 294 ++++ drivers/gpio/Kconfig | 2 +- drivers/mmc/mtk-sd.c | 13 + drivers/mtd/nand/raw/Kconfig | 17 +- drivers/mtd/nand/raw/Makefile | 2 + drivers/mtd/nand/raw/mt7621_nand.c | 1224 +++++++++++++++++ drivers/mtd/nand/raw/mt7621_nand.h | 29 + drivers/mtd/nand/raw/mt7621_nand_spl.c | 237 ++++ drivers/net/mtk_eth.c | 45 +- drivers/phy/Kconfig | 2 +- drivers/pinctrl/mtmips/Kconfig | 9 + drivers/pinctrl/mtmips/Makefile | 1 + drivers/pinctrl/mtmips/pinctrl-mt7621.c | 306 +++++ .../pinctrl/mtmips/pinctrl-mtmips-common.c | 4 +- .../pinctrl/mtmips/pinctrl-mtmips-common.h | 12 + drivers/spi/Kconfig | 2 +- drivers/usb/host/Kconfig | 2 +- drivers/watchdog/Kconfig | 2 +- include/configs/mt7621.h | 67 + include/dt-bindings/clock/mt7621-clk.h | 46 + include/dt-bindings/reset/mt7621-reset.h | 38 + tools/mtk_image.c | 182 +++ tools/mtk_image.h | 24 + 66 files changed, 5906 insertions(+), 36 deletions(-) create mode 100644 arch/mips/dts/mediatek,mt7621-nand-rfb.dts create mode 100644 arch/mips/dts/mediatek,mt7621-rfb.dts create mode 100644 arch/mips/dts/mt7621-u-boot.dtsi create mode 100644 arch/mips/dts/mt7621.dtsi create mode 100644 arch/mips/include/asm/mipsmtregs.h create mode 100644 arch/mips/mach-mtmips/mt7621/Kconfig create mode 100644 arch/mips/mach-mtmips/mt7621/Makefile create mode 100644 arch/mips/mach-mtmips/mt7621/init.c create mode 100644 arch/mips/mach-mtmips/mt7621/mt7621.h create mode 100644 arch/mips/mach-mtmips/mt7621/serial.c create mode 100644 arch/mips/mach-mtmips/mt7621/spl/Makefile create mode 100644 arch/mips/mach-mtmips/mt7621/spl/cps.c create mode 100644 arch/mips/mach-mtmips/mt7621/spl/dram.c create mode 100644 arch/mips/mach-mtmips/mt7621/spl/dram.h create mode 100644 arch/mips/mach-mtmips/mt7621/spl/launch.c create mode 100644 arch/mips/mach-mtmips/mt7621/spl/launch.h create mode 100644 arch/mips/mach-mtmips/mt7621/spl/launch_ll.S create mode 100644 arch/mips/mach-mtmips/mt7621/spl/serial.c create mode 100644 arch/mips/mach-mtmips/mt7621/spl/spl.c create mode 100644 arch/mips/mach-mtmips/mt7621/spl/start.S create mode 100644 arch/mips/mach-mtmips/mt7621/sram_init.S create mode 100644 arch/mips/mach-mtmips/mt7621/tpl/Makefile create mode 100644 arch/mips/mach-mtmips/mt7621/tpl/start.S create mode 100644 arch/mips/mach-mtmips/mt7621/tpl/tpl.c create mode 100644 board/mediatek/mt7621/MAINTAINERS create mode 100644 board/mediatek/mt7621/Makefile create mode 100644 board/mediatek/mt7621/board.c create mode 100644 configs/mt7621_nand_rfb_defconfig create mode 100644 configs/mt7621_rfb_defconfig create mode 100644 doc/board/mediatek/mt7621.rst create mode 100644 drivers/clk/mtmips/clk-mt7621.c create mode 100644 drivers/mtd/nand/raw/mt7621_nand.c create mode 100644 drivers/mtd/nand/raw/mt7621_nand.h create mode 100644 drivers/mtd/nand/raw/mt7621_nand_spl.c create mode 100644 drivers/pinctrl/mtmips/pinctrl-mt7621.c create mode 100644 include/configs/mt7621.h create mode 100644 include/dt-bindings/clock/mt7621-clk.h create mode 100644 include/dt-bindings/reset/mt7621-reset.h
To be compatible with old u-boot used by lots of MT7621 devices, the u-boot needs to boot-up MT7621's all cores, and all VPES of each core.
This patch adds asm/mipsmtregs.h from linux kernel which is need for boot-up VPEs.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v5 changes: none v4 changes: new --- arch/mips/include/asm/mipsmtregs.h | 142 +++++++++++++++++++++++++++++ 1 file changed, 142 insertions(+) create mode 100644 arch/mips/include/asm/mipsmtregs.h
diff --git a/arch/mips/include/asm/mipsmtregs.h b/arch/mips/include/asm/mipsmtregs.h new file mode 100644 index 0000000000..ba82e2bd97 --- /dev/null +++ b/arch/mips/include/asm/mipsmtregs.h @@ -0,0 +1,142 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * MT regs definitions, follows on from mipsregs.h + * Copyright (C) 2004 - 2005 MIPS Technologies, Inc. All rights reserved. + * Elizabeth Clarke et. al. + * + */ +#ifndef _ASM_MIPSMTREGS_H +#define _ASM_MIPSMTREGS_H + +#include <asm/mipsregs.h> + +/* + * Macros for use in assembly language code + */ + +#define CP0_MVPCONTROL $0, 1 +#define CP0_MVPCONF0 $0, 2 +#define CP0_MVPCONF1 $0, 3 +#define CP0_VPECONTROL $1, 1 +#define CP0_VPECONF0 $1, 2 +#define CP0_VPECONF1 $1, 3 +#define CP0_YQMASK $1, 4 +#define CP0_VPESCHEDULE $1, 5 +#define CP0_VPESCHEFBK $1, 6 +#define CP0_TCSTATUS $2, 1 +#define CP0_TCBIND $2, 2 +#define CP0_TCRESTART $2, 3 +#define CP0_TCHALT $2, 4 +#define CP0_TCCONTEXT $2, 5 +#define CP0_TCSCHEDULE $2, 6 +#define CP0_TCSCHEFBK $2, 7 +#define CP0_SRSCONF0 $6, 1 +#define CP0_SRSCONF1 $6, 2 +#define CP0_SRSCONF2 $6, 3 +#define CP0_SRSCONF3 $6, 4 +#define CP0_SRSCONF4 $6, 5 + +/* MVPControl fields */ +#define MVPCONTROL_EVP (_ULCAST_(1)) + +#define MVPCONTROL_VPC_SHIFT 1 +#define MVPCONTROL_VPC (_ULCAST_(1) << MVPCONTROL_VPC_SHIFT) + +#define MVPCONTROL_STLB_SHIFT 2 +#define MVPCONTROL_STLB (_ULCAST_(1) << MVPCONTROL_STLB_SHIFT) + +/* MVPConf0 fields */ +#define MVPCONF0_PTC_SHIFT 0 +#define MVPCONF0_PTC (_ULCAST_(0xff)) +#define MVPCONF0_PVPE_SHIFT 10 +#define MVPCONF0_PVPE (_ULCAST_(0xf) << MVPCONF0_PVPE_SHIFT) +#define MVPCONF0_TCA_SHIFT 15 +#define MVPCONF0_TCA (_ULCAST_(1) << MVPCONF0_TCA_SHIFT) +#define MVPCONF0_PTLBE_SHIFT 16 +#define MVPCONF0_PTLBE (_ULCAST_(0x3ff) << MVPCONF0_PTLBE_SHIFT) +#define MVPCONF0_TLBS_SHIFT 29 +#define MVPCONF0_TLBS (_ULCAST_(1) << MVPCONF0_TLBS_SHIFT) +#define MVPCONF0_M_SHIFT 31 +#define MVPCONF0_M (_ULCAST_(0x1) << MVPCONF0_M_SHIFT) + +/* config3 fields */ +#define CONFIG3_MT_SHIFT 2 +#define CONFIG3_MT (_ULCAST_(1) << CONFIG3_MT_SHIFT) + +/* VPEControl fields (per VPE) */ +#define VPECONTROL_TARGTC (_ULCAST_(0xff)) + +#define VPECONTROL_TE_SHIFT 15 +#define VPECONTROL_TE (_ULCAST_(1) << VPECONTROL_TE_SHIFT) +#define VPECONTROL_EXCPT_SHIFT 16 +#define VPECONTROL_EXCPT (_ULCAST_(0x7) << VPECONTROL_EXCPT_SHIFT) + +/* Thread Exception Codes for EXCPT field */ +#define THREX_TU 0 +#define THREX_TO 1 +#define THREX_IYQ 2 +#define THREX_GSX 3 +#define THREX_YSCH 4 +#define THREX_GSSCH 5 + +#define VPECONTROL_GSI_SHIFT 20 +#define VPECONTROL_GSI (_ULCAST_(1) << VPECONTROL_GSI_SHIFT) +#define VPECONTROL_YSI_SHIFT 21 +#define VPECONTROL_YSI (_ULCAST_(1) << VPECONTROL_YSI_SHIFT) + +/* VPEConf0 fields (per VPE) */ +#define VPECONF0_VPA_SHIFT 0 +#define VPECONF0_VPA (_ULCAST_(1) << VPECONF0_VPA_SHIFT) +#define VPECONF0_MVP_SHIFT 1 +#define VPECONF0_MVP (_ULCAST_(1) << VPECONF0_MVP_SHIFT) +#define VPECONF0_XTC_SHIFT 21 +#define VPECONF0_XTC (_ULCAST_(0xff) << VPECONF0_XTC_SHIFT) + +/* VPEConf1 fields (per VPE) */ +#define VPECONF1_NCP1_SHIFT 0 +#define VPECONF1_NCP1 (_ULCAST_(0xff) << VPECONF1_NCP1_SHIFT) +#define VPECONF1_NCP2_SHIFT 10 +#define VPECONF1_NCP2 (_ULCAST_(0xff) << VPECONF1_NCP2_SHIFT) +#define VPECONF1_NCX_SHIFT 20 +#define VPECONF1_NCX (_ULCAST_(0xff) << VPECONF1_NCX_SHIFT) + +/* TCStatus fields (per TC) */ +#define TCSTATUS_TASID (_ULCAST_(0xff)) +#define TCSTATUS_IXMT_SHIFT 10 +#define TCSTATUS_IXMT (_ULCAST_(1) << TCSTATUS_IXMT_SHIFT) +#define TCSTATUS_TKSU_SHIFT 11 +#define TCSTATUS_TKSU (_ULCAST_(3) << TCSTATUS_TKSU_SHIFT) +#define TCSTATUS_A_SHIFT 13 +#define TCSTATUS_A (_ULCAST_(1) << TCSTATUS_A_SHIFT) +#define TCSTATUS_DA_SHIFT 15 +#define TCSTATUS_DA (_ULCAST_(1) << TCSTATUS_DA_SHIFT) +#define TCSTATUS_DT_SHIFT 20 +#define TCSTATUS_DT (_ULCAST_(1) << TCSTATUS_DT_SHIFT) +#define TCSTATUS_TDS_SHIFT 21 +#define TCSTATUS_TDS (_ULCAST_(1) << TCSTATUS_TDS_SHIFT) +#define TCSTATUS_TSST_SHIFT 22 +#define TCSTATUS_TSST (_ULCAST_(1) << TCSTATUS_TSST_SHIFT) +#define TCSTATUS_RNST_SHIFT 23 +#define TCSTATUS_RNST (_ULCAST_(3) << TCSTATUS_RNST_SHIFT) +/* Codes for RNST */ +#define TC_RUNNING 0 +#define TC_WAITING 1 +#define TC_YIELDING 2 +#define TC_GATED 3 + +#define TCSTATUS_TMX_SHIFT 27 +#define TCSTATUS_TMX (_ULCAST_(1) << TCSTATUS_TMX_SHIFT) +/* TCStatus TCU bits can use same definitions/offsets as CU bits in Status */ + +/* TCBind */ +#define TCBIND_CURVPE_SHIFT 0 +#define TCBIND_CURVPE (_ULCAST_(0xf)) + +#define TCBIND_CURTC_SHIFT 21 + +#define TCBIND_CURTC (_ULCAST_(0xff) << TCBIND_CURTC_SHIFT) + +/* TCHalt */ +#define TCHALT_H (_ULCAST_(1)) + +#endif
Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
This patch add more definitions needed for MT7621 initialization. MT7621 needs to initialize GIC/CPC and other related parts.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v5 changes: none v4 changes: new --- arch/mips/include/asm/cm.h | 67 ++++++++++++++++++++++++++++++++++++++ 1 file changed, 67 insertions(+)
diff --git a/arch/mips/include/asm/cm.h b/arch/mips/include/asm/cm.h index 99ddbccd80..5cc8c09621 100644 --- a/arch/mips/include/asm/cm.h +++ b/arch/mips/include/asm/cm.h @@ -8,9 +8,23 @@ #define __MIPS_ASM_CM_H__
/* Global Control Register (GCR) offsets */ +#define GCR_CONFIG 0x0000 #define GCR_BASE 0x0008 #define GCR_BASE_UPPER 0x000c +#define GCR_CONTROL 0x0010 +#define GCR_ACCESS 0x0020 #define GCR_REV 0x0030 +#define GCR_GIC_BASE 0x0080 +#define GCR_CPC_BASE 0x0088 +#define GCR_REG0_BASE 0x0090 +#define GCR_REG0_MASK 0x0098 +#define GCR_REG1_BASE 0x00a0 +#define GCR_REG1_MASK 0x00a8 +#define GCR_REG2_BASE 0x00b0 +#define GCR_REG2_MASK 0x00b8 +#define GCR_REG3_BASE 0x00c0 +#define GCR_REG3_MASK 0x00c8 +#define GCR_CPC_STATUS 0x00f0 #define GCR_L2_CONFIG 0x0130 #define GCR_L2_TAG_ADDR 0x0600 #define GCR_L2_TAG_ADDR_UPPER 0x0604 @@ -19,10 +33,59 @@ #define GCR_L2_DATA 0x0610 #define GCR_L2_DATA_UPPER 0x0614 #define GCR_Cx_COHERENCE 0x2008 +#define GCR_Cx_OTHER 0x2018 +#define GCR_Cx_ID 0x2028 +#define GCR_CO_COHERENCE 0x4008 + +/* GCR_CONFIG fields */ +#define GCR_CONFIG_NUM_CLUSTERS_SHIFT 23 +#define GCR_CONFIG_NUM_CLUSTERS (0x7f << 23) +#define GCR_CONFIG_NUMIOCU_SHIFT 8 +#define GCR_CONFIG_NUMIOCU (0xff << 8) +#define GCR_CONFIG_PCORES_SHIFT 0 +#define GCR_CONFIG_PCORES (0xff << 0) + +/* GCR_BASE fields */ +#define GCR_BASE_SHIFT 15 +#define CCA_DEFAULT_OVR_SHIFT 5 +#define CCA_DEFAULT_OVR_MASK (0x7 << 5) +#define CCA_DEFAULT_OVREN (0x1 << 4) +#define CM_DEFAULT_TARGET_SHIFT 0 +#define CM_DEFAULT_TARGET_MASK (0x3 << 0) + +/* GCR_CONTROL fields */ +#define GCR_CONTROL_SYNCCTL (0x1 << 16)
/* GCR_REV CM versions */ #define GCR_REV_CM3 0x0800
+/* GCR_GIC_BASE fields */ +#define GCR_GIC_BASE_ADDRMASK_SHIFT 7 +#define GCR_GIC_BASE_ADDRMASK (0x1ffffff << 7) +#define GCR_GIC_EN (0x1 << 0) + +/* GCR_CPC_BASE fields */ +#define GCR_CPC_BASE_ADDRMASK_SHIFT 15 +#define GCR_CPC_BASE_ADDRMASK (0x1ffff << 15) +#define GCR_CPC_EN (0x1 << 0) + +/* GCR_REGn_MASK fields */ +#define GCR_REGn_MASK_ADDRMASK_SHIFT 16 +#define GCR_REGn_MASK_ADDRMASK (0xffff << 16) +#define GCR_REGn_MASK_CCAOVR_SHIFT 5 +#define GCR_REGn_MASK_CCAOVR (0x7 << 5) +#define GCR_REGn_MASK_CCAOVREN (1 << 4) +#define GCR_REGn_MASK_DROPL2 (1 << 2) +#define GCR_REGn_MASK_CMTGT_SHIFT 0 +#define GCR_REGn_MASK_CMTGT (0x3 << 0) +#define GCR_REGn_MASK_CMTGT_DISABLED 0x0 +#define GCR_REGn_MASK_CMTGT_MEM 0x1 +#define GCR_REGn_MASK_CMTGT_IOCU0 0x2 +#define GCR_REGn_MASK_CMTGT_IOCU1 0x3 + +/* GCR_CPC_STATUS fields */ +#define GCR_CPC_EX (0x1 << 0) + /* GCR_L2_CONFIG fields */ #define GCR_L2_CONFIG_ASSOC_SHIFT 0 #define GCR_L2_CONFIG_ASSOC_BITS 8 @@ -36,6 +99,10 @@ #define GCR_Cx_COHERENCE_DOM_EN (0xff << 0) #define GCR_Cx_COHERENCE_EN (0x1 << 0)
+/* GCR_Cx_OTHER fields */ +#define GCR_Cx_OTHER_CORENUM_SHIFT 16 +#define GCR_Cx_OTHER_CORENUM (0xffff << 16) + #ifndef __ASSEMBLY__
#include <asm/io.h>
This patch adds __image_copy_len needed by TPL of MT7621 SoC. The __image_copy_len represents the binary blob size of both SPL/TPL binaries. To achieve this, __text_start/end are added for calculation.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v5 changes: none v4 changes: new --- arch/mips/cpu/u-boot-spl.lds | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/mips/cpu/u-boot-spl.lds b/arch/mips/cpu/u-boot-spl.lds index 28ea4f2a48..f88754ab56 100644 --- a/arch/mips/cpu/u-boot-spl.lds +++ b/arch/mips/cpu/u-boot-spl.lds @@ -13,7 +13,9 @@ SECTIONS
. = ALIGN(4); .text : { + __text_start = .; *(.text*) + __text_end = .; } > .spl_mem
. = ALIGN(4); @@ -36,6 +38,7 @@ SECTIONS
. = ALIGN(4); __image_copy_end = .; + __image_copy_len = __image_copy_end - __text_start;
_image_binary_end = .;
This patch adds support for noncached_alloc() which was only supported by ARM platform.
Unlike the ARM platform, MMU is not used in u-boot for MIPS. Instead, KSEG is provided to access uncached memory. So most code of this patch is copied from cache.c of ARM platform, with only two differences: 1. MMU is untouched in noncached_set_region() 2. Address returned by noncached_alloc() is converted using KSEG1ADDR()
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v5 changes: change KSEG1ADDR to CKSEG1ADDR v4 changes: new --- arch/mips/include/asm/system.h | 20 ++++++++++++++++ arch/mips/lib/cache.c | 43 ++++++++++++++++++++++++++++++++++ 2 files changed, 63 insertions(+)
diff --git a/arch/mips/include/asm/system.h b/arch/mips/include/asm/system.h index 79e638844b..89a2ac209f 100644 --- a/arch/mips/include/asm/system.h +++ b/arch/mips/include/asm/system.h @@ -282,4 +282,24 @@ static inline void instruction_hazard_barrier(void) : "=&r"(tmp)); }
+#ifdef CONFIG_SYS_NONCACHED_MEMORY +/* 1MB granularity */ +#define MMU_SECTION_SHIFT 20 +#define MMU_SECTION_SIZE (1 << MMU_SECTION_SHIFT) + +/** + * noncached_init() - Initialize non-cached memory region + * + * Initialize non-cached memory area. This memory region will be typically + * located right below the malloc() area and be accessed from KSEG1. + * + * It is called during the generic post-relocation init sequence. + * + * Return: 0 if OK + */ +int noncached_init(void); + +phys_addr_t noncached_alloc(size_t size, size_t align); +#endif /* CONFIG_SYS_NONCACHED_MEMORY */ + #endif /* _ASM_SYSTEM_H */ diff --git a/arch/mips/lib/cache.c b/arch/mips/lib/cache.c index ec652f0fba..40ee2de935 100644 --- a/arch/mips/lib/cache.c +++ b/arch/mips/lib/cache.c @@ -6,6 +6,7 @@
#include <common.h> #include <cpu_func.h> +#include <malloc.h> #include <asm/cache.h> #include <asm/cacheops.h> #include <asm/cm.h> @@ -197,3 +198,45 @@ void dcache_disable(void) /* ensure the pipeline doesn't contain now-invalid instructions */ instruction_hazard_barrier(); } + +#ifdef CONFIG_SYS_NONCACHED_MEMORY +static unsigned long noncached_start; +static unsigned long noncached_end; +static unsigned long noncached_next; + +void noncached_set_region(void) +{ +} + +int noncached_init(void) +{ + phys_addr_t start, end; + size_t size; + + /* If this calculation changes, update board_f.c:reserve_noncached() */ + end = ALIGN(mem_malloc_start, MMU_SECTION_SIZE) - MMU_SECTION_SIZE; + size = ALIGN(CONFIG_SYS_NONCACHED_MEMORY, MMU_SECTION_SIZE); + start = end - size; + + debug("mapping memory %pa-%pa non-cached\n", &start, &end); + + noncached_start = start; + noncached_end = end; + noncached_next = start; + + return 0; +} + +phys_addr_t noncached_alloc(size_t size, size_t align) +{ + phys_addr_t next = ALIGN(noncached_next, align); + + if (next >= noncached_end || (noncached_end - next) < size) + return 0; + + debug("allocated %zu bytes of uncached memory @%pa\n", size, &next); + noncached_next = next + size; + + return CKSEG1ADDR(next); +} +#endif /* CONFIG_SYS_NONCACHED_MEMORY */
- MMU is untouched in noncached_set_region()
- Address returned by noncached_alloc() is converted using KSEG1ADDR()
This patch adds support for MediaTek MT7621 SoC. All files are dedicated for u-boot.
The default build target is u-boot-mt7621.bin.
The specification of this chip: https://www.mediatek.com/products/homenetworking/mt7621
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v5 changes: Fix dram binary blob loading procedure Adjust mt7621.dtsi, clkctrl moved under sysc, pinctrl default states removed v4 changes: Add full support for booting from flash (SPL/TPL support) Boot all cores/VPEs Use binman to generate final binary Use binman to embed external binary blob v3 changes: Update clock name for mt7621.dtsi due to clk driver changed v2 changes: Add a kconfig for max supported ram size Remove network configs from default config file --- arch/mips/dts/mt7621-u-boot.dtsi | 111 ++++++ arch/mips/dts/mt7621.dtsi | 349 ++++++++++++++++++ arch/mips/mach-mtmips/Kconfig | 49 ++- arch/mips/mach-mtmips/Makefile | 4 + arch/mips/mach-mtmips/cpu.c | 2 +- arch/mips/mach-mtmips/mt7621/Kconfig | 95 +++++ arch/mips/mach-mtmips/mt7621/Makefile | 14 + arch/mips/mach-mtmips/mt7621/init.c | 229 ++++++++++++ arch/mips/mach-mtmips/mt7621/mt7621.h | 229 ++++++++++++ arch/mips/mach-mtmips/mt7621/serial.c | 23 ++ arch/mips/mach-mtmips/mt7621/spl/Makefile | 9 + arch/mips/mach-mtmips/mt7621/spl/cps.c | 152 ++++++++ arch/mips/mach-mtmips/mt7621/spl/dram.c | 155 ++++++++ arch/mips/mach-mtmips/mt7621/spl/dram.h | 39 ++ arch/mips/mach-mtmips/mt7621/spl/launch.c | 100 ++++++ arch/mips/mach-mtmips/mt7621/spl/launch.h | 52 +++ arch/mips/mach-mtmips/mt7621/spl/launch_ll.S | 357 +++++++++++++++++++ arch/mips/mach-mtmips/mt7621/spl/serial.c | 24 ++ arch/mips/mach-mtmips/mt7621/spl/spl.c | 95 +++++ arch/mips/mach-mtmips/mt7621/spl/start.S | 226 ++++++++++++ arch/mips/mach-mtmips/mt7621/sram_init.S | 22 ++ arch/mips/mach-mtmips/mt7621/tpl/Makefile | 4 + arch/mips/mach-mtmips/mt7621/tpl/start.S | 161 +++++++++ arch/mips/mach-mtmips/mt7621/tpl/tpl.c | 146 ++++++++ include/configs/mt7621.h | 67 ++++ 25 files changed, 2708 insertions(+), 6 deletions(-) create mode 100644 arch/mips/dts/mt7621-u-boot.dtsi create mode 100644 arch/mips/dts/mt7621.dtsi create mode 100644 arch/mips/mach-mtmips/mt7621/Kconfig create mode 100644 arch/mips/mach-mtmips/mt7621/Makefile create mode 100644 arch/mips/mach-mtmips/mt7621/init.c create mode 100644 arch/mips/mach-mtmips/mt7621/mt7621.h create mode 100644 arch/mips/mach-mtmips/mt7621/serial.c create mode 100644 arch/mips/mach-mtmips/mt7621/spl/Makefile create mode 100644 arch/mips/mach-mtmips/mt7621/spl/cps.c create mode 100644 arch/mips/mach-mtmips/mt7621/spl/dram.c create mode 100644 arch/mips/mach-mtmips/mt7621/spl/dram.h create mode 100644 arch/mips/mach-mtmips/mt7621/spl/launch.c create mode 100644 arch/mips/mach-mtmips/mt7621/spl/launch.h create mode 100644 arch/mips/mach-mtmips/mt7621/spl/launch_ll.S create mode 100644 arch/mips/mach-mtmips/mt7621/spl/serial.c create mode 100644 arch/mips/mach-mtmips/mt7621/spl/spl.c create mode 100644 arch/mips/mach-mtmips/mt7621/spl/start.S create mode 100644 arch/mips/mach-mtmips/mt7621/sram_init.S create mode 100644 arch/mips/mach-mtmips/mt7621/tpl/Makefile create mode 100644 arch/mips/mach-mtmips/mt7621/tpl/start.S create mode 100644 arch/mips/mach-mtmips/mt7621/tpl/tpl.c create mode 100644 include/configs/mt7621.h
diff --git a/arch/mips/dts/mt7621-u-boot.dtsi b/arch/mips/dts/mt7621-u-boot.dtsi new file mode 100644 index 0000000000..c5a8aa357f --- /dev/null +++ b/arch/mips/dts/mt7621-u-boot.dtsi @@ -0,0 +1,111 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 MediaTek Inc. All rights reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <linux/stringify.h> + +/ { + binman: binman { + multiple-images; + }; +}; + +&sysc { + u-boot,dm-pre-reloc; +}; + +&reboot { + u-boot,dm-pre-reloc; +}; + +&clkctrl { + u-boot,dm-pre-reloc; +}; + +&rstctrl { + u-boot,dm-pre-reloc; +}; + +&pinctrl { + u-boot,dm-pre-reloc; +}; + +&uart0 { + u-boot,dm-pre-reloc; +}; + +&uart1 { + u-boot,dm-pre-reloc; +}; + +&uart2 { + u-boot,dm-pre-reloc; +}; + +&binman { + u-boot-spl-ddr { + align = <4>; + align-size = <4>; + filename = "u-boot-spl-ddr.bin"; + pad-byte = <0xff>; + + u-boot-spl { + align-end = <4>; + filename = "u-boot-spl.bin"; + }; + + stage_bin { + filename = "mt7621_stage_sram.bin"; + type = "blob-ext"; + }; + }; + + spl-img { + filename = "u-boot-spl-ddr.img"; + + mkimage { +#ifdef CONFIG_MT7621_BOOT_FROM_NAND + args = "-T", "mtk_image", "-n", "mt7621=1", + "-a", __stringify(CONFIG_SPL_TEXT_BASE), + "-e", __stringify(CONFIG_SPL_TEXT_BASE); +#else + args = "-A", "mips", "-T", "standalone", "-O", "u-boot", + "-C", "none", "-n", "MT7621 U-Boot SPL", + "-a", __stringify(CONFIG_SPL_TEXT_BASE), + "-e", __stringify(CONFIG_SPL_TEXT_BASE); +#endif + + blob { + filename = "u-boot-spl-ddr.bin"; + }; + }; + }; + + mt7621-uboot { + filename = "u-boot-mt7621.bin"; + pad-byte = <0xff>; + +#ifndef CONFIG_MT7621_BOOT_FROM_NAND + u-boot-tpl { + align-end = <4>; + filename = "u-boot-tpl.bin"; + }; +#endif + + spl { +#ifdef CONFIG_MT7621_BOOT_FROM_NAND + align-end = <0x1000>; +#endif + filename = "u-boot-spl-ddr.img"; + type = "blob"; + }; + + u-boot { + filename = "u-boot-lzma.img"; + type = "blob"; + }; + }; +}; diff --git a/arch/mips/dts/mt7621.dtsi b/arch/mips/dts/mt7621.dtsi new file mode 100644 index 0000000000..0f057dfe1b --- /dev/null +++ b/arch/mips/dts/mt7621.dtsi @@ -0,0 +1,349 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 MediaTek Inc. All rights reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <dt-bindings/clock/mt7621-clk.h> +#include <dt-bindings/reset/mt7621-reset.h> +#include <dt-bindings/phy/phy.h> + +/ { + #address-cells = <1>; + #size-cells = <1>; + compatible = "mediatek,mt7621-soc"; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + device_type = "cpu"; + compatible = "mips,mips1004Kc"; + reg = <0>; + }; + + cpu@1 { + device_type = "cpu"; + compatible = "mips,mips1004Kc"; + reg = <1>; + }; + }; + + clk48m: clk48m@0 { + compatible = "fixed-clock"; + + clock-frequency = <48000000>; + + #clock-cells = <0>; + }; + + clk50m: clk50m@0 { + compatible = "fixed-clock"; + + clock-frequency = <50000000>; + + #clock-cells = <0>; + }; + + sysc: sysctrl@1e000000 { + compatible = "mediatek,mt7621-sysc", "syscon"; + reg = <0x1e000000 0x100>; + + clkctrl: clock-controller@1e000030 { + compatible = "mediatek,mt7621-clk"; + mediatek,memc = <&memc>; + + #clock-cells = <1>; + }; + }; + + rstctrl: reset-controller@1e000034 { + compatible = "mediatek,mtmips-reset"; + reg = <0x1e000034 0x4>; + #reset-cells = <1>; + }; + + reboot: resetctl-reboot { + compatible = "resetctl-reboot"; + + resets = <&rstctrl RST_SYS>; + reset-names = "sysreset"; + }; + + memc: memctrl@1e005000 { + compatible = "mediatek,mt7621-memc", "syscon"; + reg = <0x1e005000 0x1000>; + }; + + pinctrl: pinctrl@1e000060 { + compatible = "mediatek,mt7621-pinctrl"; + reg = <0x1e000048 0x30>; + + pinctrl-names = "default"; + pinctrl-0 = <&state_default>; + + state_default: pin_state { + }; + + uart1_pins: uart1_pins { + groups = "uart1"; + function = "uart"; + }; + + uart2_pins: uart2_pins { + groups = "uart2"; + function = "uart"; + }; + + uart3_pins: uart3_pins { + groups = "uart3"; + function = "uart"; + }; + + sdxc_pins: sdxc_pins { + groups = "sdxc"; + function = "sdxc"; + }; + + spi_pins: spi_pins { + groups = "spi"; + function = "spi"; + }; + + eth_pins: eth_pins { + mdio_pins { + groups = "mdio"; + function = "mdio"; + }; + + rgmii1_pins { + groups = "rgmii1"; + function = "rgmii"; + }; + + esw_pins { + groups = "esw int"; + function = "esw int"; + }; + + mdio_pconf { + groups = "mdio"; + drive-strength = <2>; + }; + }; + }; + + watchdog: watchdog@1e000100 { + compatible = "mediatek,mt7621-wdt"; + reg = <0x1e000100 0x40>; + + resets = <&rstctrl RST_TIMER>; + reset-names = "wdt"; + + status = "disabled"; + }; + + gpio: gpio@1e000600 { + #address-cells = <1>; + #size-cells = <0>; + + compatible = "mtk,mt7621-gpio"; + reg = <0x1e000600 0x100>; + + resets = <&rstctrl RST_PIO>; + reset-names = "pio"; + + gpio0: bank@0 { + reg = <0>; + compatible = "mtk,mt7621-gpio-bank"; + gpio-controller; + #gpio-cells = <2>; + }; + + gpio1: bank@1 { + reg = <1>; + compatible = "mtk,mt7621-gpio-bank"; + gpio-controller; + #gpio-cells = <2>; + }; + + gpio2: bank@2 { + reg = <2>; + compatible = "mtk,mt7621-gpio-bank"; + gpio-controller; + #gpio-cells = <2>; + }; + }; + + spi: spi@1e000b00 { + compatible = "ralink,mt7621-spi"; + reg = <0x1e000b00 0x40>; + + status = "disabled"; + + pinctrl-names = "default"; + pinctrl-0 = <&spi_pins>; + + resets = <&rstctrl RST_SPI>; + reset-names = "spi"; + + clocks = <&clkctrl MT7621_CLK_SPI>; + + #address-cells = <1>; + #size-cells = <0>; + }; + + uart0: uart1@1e000c00 { + compatible = "mediatek,hsuart", "ns16550a"; + reg = <0x1e000c00 0x100>; + + pinctrl-names = "default"; + pinctrl-0 = <&uart1_pins>; + + clocks = <&clkctrl MT7621_CLK_UART1>; + + resets = <&rstctrl RST_UART1>; + + reg-shift = <2>; + }; + + uart1: uart2@1e000d00 { + compatible = "mediatek,hsuart", "ns16550a"; + reg = <0x1e000d00 0x100>; + + pinctrl-names = "default"; + pinctrl-0 = <&uart2_pins>; + + clocks = <&clkctrl MT7621_CLK_UART2>; + + resets = <&rstctrl RST_UART2>; + + reg-shift = <2>; + + status = "disabled"; + }; + + uart2: uart3@1e000e00 { + compatible = "mediatek,hsuart", "ns16550a"; + reg = <0x1e000e00 0x100>; + + pinctrl-names = "default"; + pinctrl-0 = <&uart3_pins>; + + clocks = <&clkctrl MT7621_CLK_UART3>; + + resets = <&rstctrl RST_UART3>; + + reg-shift = <2>; + + status = "disabled"; + }; + + eth: eth@1e100000 { + compatible = "mediatek,mt7621-eth"; + reg = <0x1e100000 0x20000>; + mediatek,ethsys = <&sysc>; + + pinctrl-names = "default"; + pinctrl-0 = <ð_pins>; + + resets = <&rstctrl RST_FE>, <&rstctrl RST_GMAC>, <&rstctrl RST_MCM>; + reset-names = "fe", "gmac", "mcm"; + + clocks = <&clkctrl MT7621_CLK_GDMA>, + <&clkctrl MT7621_CLK_ETH>; + clock-names = "gmac", "fe"; + + #address-cells = <1>; + #size-cells = <0>; + + mediatek,gmac-id = <0>; + phy-mode = "rgmii"; + mediatek,switch = "mt7530"; + mediatek,mcm; + + fixed-link { + speed = <1000>; + full-duplex; + }; + }; + + mmc: mmc@1e130000 { + compatible = "mediatek,mt7621-mmc"; + reg = <0x1e130000 0x4000>; + + status = "disabled"; + + bus-width = <4>; + builtin-cd = <1>; + r_smpl = <1>; + + pinctrl-names = "default"; + pinctrl-0 = <&sdxc_pins>; + + clocks = <&clk50m>, <&clkctrl MT7621_CLK_SHXC>; + clock-names = "source", "hclk"; + + resets = <&rstctrl RST_SDXC>; + }; + + ssusb: usb@1e1c0000 { + compatible = "mediatek,mt7621-xhci", "mediatek,mtk-xhci"; + reg = <0x1e1c0000 0x1000>, <0x1e1d0700 0x100>; + reg-names = "mac", "ippc"; + + clocks = <&clk48m>, <&clk48m>; + clock-names = "sys_ck", "ref_ck"; + + phys = <&u2port0 PHY_TYPE_USB2>, + <&u3port0 PHY_TYPE_USB3>, + <&u2port1 PHY_TYPE_USB2>; + + status = "disabled"; + }; + + u3phy: usb-phy@1e1d0000 { + compatible = "mediatek,mt7621-u3phy", + "mediatek,generic-tphy-v1"; + reg = <0x1e1d0000 0x700>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + status = "disabled"; + + u2port0: usb-phy@1e1d0800 { + reg = <0x1e1d0800 0x0100>; + #phy-cells = <1>; + clocks = <&clk48m>; + clock-names = "ref"; + }; + + u3port0: usb-phy@1e1d0900 { + reg = <0x1e1d0900 0x0100>; + #phy-cells = <1>; + }; + + u2port1: usb-phy@1e1d1000 { + reg = <0x1e1d1000 0x0100>; + #phy-cells = <1>; + clocks = <&clk48m>; + clock-names = "ref"; + }; + }; + + i2c: i2c@1e000900 { + compatible = "i2c-gpio"; + + status = "disabled"; + + i2c-gpio,delay-us = <3>; + + gpios = <&gpio0 3 1>, /* PIN3 as SDA */ + <&gpio0 4 1>; /* PIN4 as CLK */ + + #address-cells = <1>; + #size-cells = <0>; + }; +}; diff --git a/arch/mips/mach-mtmips/Kconfig b/arch/mips/mach-mtmips/Kconfig index 151b004603..d46be503a2 100644 --- a/arch/mips/mach-mtmips/Kconfig +++ b/arch/mips/mach-mtmips/Kconfig @@ -9,6 +9,7 @@ config SYS_MALLOC_F_LEN
config SYS_SOC default "mt7620" if SOC_MT7620 + default "mt7621" if SOC_MT7621 default "mt7628" if SOC_MT7628
config SYS_DCACHE_SIZE @@ -18,25 +19,45 @@ config SYS_DCACHE_LINE_SIZE default 32
config SYS_ICACHE_SIZE - default 65536 + default 65536 if SOC_MT7620 || SOC_MT7628 + default 32768 if SOC_MT7621
config SYS_ICACHE_LINE_SIZE default 32
+config SYS_SCACHE_LINE_SIZE + default 32 if SOC_MT7621 + config SYS_TEXT_BASE - default 0x9c000000 if !SPL - default 0x80200000 if SPL + default 0x9c000000 if !SPL && !SOC_MT7621 + default 0x80200000 if SPL || SOC_MT7621
config SPL_TEXT_BASE - default 0x9c000000 + default 0x9c000000 if !SOC_MT7621 + default 0x80100000 if SOC_MT7621 + +config SPL_SIZE_LIMIT + default 0x30000 if SOC_MT7621 + +config TPL_TEXT_BASE + default 0xbfc00000 if SOC_MT7621 + +config TPL_MAX_SIZE + default 4096 if SOC_MT7621
config SPL_PAYLOAD default "u-boot-lzma.img" if SPL_LZMA
config BUILD_TARGET - default "u-boot-with-spl.bin" if SPL + default "u-boot-with-spl.bin" if SPL && !SOC_MT7621 + default "u-boot-lzma.img" if SOC_MT7621 default "u-boot.bin"
+config MAX_MEM_SIZE + int + default 256 if SOC_MT7620 || SOC_MT7628 + default 512 if SOC_MT7621 + choice prompt "MediaTek MIPS SoC select"
@@ -55,6 +76,23 @@ config SOC_MT7620 help This supports MediaTek MT7620.
+config SOC_MT7621 + bool "MT7621" + select MIPS_CM + select MIPS_L2_CACHE + select SYS_CACHE_SHIFT_5 + select SYS_MIPS_CACHE_INIT_RAM_LOAD + select PINCTRL_MT7621 + select MTK_SERIAL + select REGMAP + select SYSCON + select BINMAN + select SUPPORT_TPL + select SPL_LOADER_SUPPORT if SPL + select SPL_INIT_STACK_WITHOUT_MALLOC_F if SPL + help + This supports MediaTek MT7621. + config SOC_MT7628 bool "MT7628" select SYS_CACHE_SHIFT_5 @@ -80,6 +118,7 @@ config SOC_MT7628 endchoice
source "arch/mips/mach-mtmips/mt7620/Kconfig" +source "arch/mips/mach-mtmips/mt7621/Kconfig" source "arch/mips/mach-mtmips/mt7628/Kconfig"
endmenu diff --git a/arch/mips/mach-mtmips/Makefile b/arch/mips/mach-mtmips/Makefile index 4909b47ef2..19f1e07033 100644 --- a/arch/mips/mach-mtmips/Makefile +++ b/arch/mips/mach-mtmips/Makefile @@ -1,9 +1,13 @@ # SPDX-License-Identifier: GPL-2.0+
obj-y += cpu.o + +ifneq ($(CONFIG_SOC_MT7621),y) obj-y += ddr_init.o obj-y += ddr_cal.o obj-$(CONFIG_SPL_BUILD) += spl.o +endif
obj-$(CONFIG_SOC_MT7620) += mt7620/ +obj-$(CONFIG_SOC_MT7621) += mt7621/ obj-$(CONFIG_SOC_MT7628) += mt7628/ diff --git a/arch/mips/mach-mtmips/cpu.c b/arch/mips/mach-mtmips/cpu.c index a4b5cff61d..f1e9022738 100644 --- a/arch/mips/mach-mtmips/cpu.c +++ b/arch/mips/mach-mtmips/cpu.c @@ -16,7 +16,7 @@ DECLARE_GLOBAL_DATA_PTR;
int dram_init(void) { - gd->ram_size = get_ram_size((void *)KSEG1, SZ_256M); + gd->ram_size = get_ram_size((void *)KSEG1, CONFIG_MAX_MEM_SIZE << 20);
return 0; } diff --git a/arch/mips/mach-mtmips/mt7621/Kconfig b/arch/mips/mach-mtmips/mt7621/Kconfig new file mode 100644 index 0000000000..37d512c68f --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/Kconfig @@ -0,0 +1,95 @@ + +if SOC_MT7621 + +menu "CPU & DDR configuration" + +config MT7621_CPU_FREQ + int "CPU Frequency (MHz)" + range 400 1200 + default 880 + +choice + prompt "DRAM Frequency" + default MT7621_DRAM_FREQ_1200 + +config MT7621_DRAM_FREQ_400 + bool "400MHz" + +config MT7621_DRAM_FREQ_800 + bool "800MHz" + +config MT7621_DRAM_FREQ_1066 + bool "1066MHz" + +config MT7621_DRAM_FREQ_1200 + bool "1200MHz" + +endchoice + +choice + prompt "DDR2 timing parameters" + default MT7621_DRAM_DDR2_1024M + +config MT7621_DRAM_DDR2_512M + bool "64MB" + +config MT7621_DRAM_DDR2_1024M + bool "128MB" + +config MT7621_DRAM_DDR2_512M_W9751G6KB_A02_1066MHZ + bool "W9751G6KB_A02 @ 1066MHz (64MB)" + +config MT7621_DRAM_DDR2_1024M_W971GG6KB25_800MHZ + bool "W971GG6KB25 @ 800MHz (128MB)" + +config MT7621_DRAM_DDR2_1024M_W971GG6KB18_1066MHZ + bool "W971GG6KB18 @ 1066MHz (128MB)" + +endchoice + +choice + prompt "DDR3 timing parameters" + default MT7621_DRAM_DDR3_2048M + +config MT7621_DRAM_DDR3_1024M + bool "128MB" + +config MT7621_DRAM_DDR3_1024M_KGD + bool "128MB KGD (MT7621DA)" + +config MT7621_DRAM_DDR3_2048M + bool "256MB" + +config MT7621_DRAM_DDR3_4096M + bool "512MB" + +endchoice + +endmenu + +config DEBUG_UART_BOARD_INIT + default y + +config MT7621_BOOT_FROM_NAND + bool "Boot from NAND" + help + Select this if u-boot will boot from NAND flash. When booting from + NAND, SPL will be loaded by bootrom directly and no TPL is needed. + +choice + prompt "Board select" + +endchoice + +config SYS_CONFIG_NAME + string "Board configuration name" + default "mt7621" if BOARD_MT7621_RFB || BOARD_MT7621_NAND_RFB + +config SYS_BOARD + string "Board name" + default "mt7621" if BOARD_MT7621_RFB || BOARD_MT7621_NAND_RFB + +config SYS_VENDOR + default "mediatek" if BOARD_MT7621_RFB || BOARD_MT7621_NAND_RFB + +endif diff --git a/arch/mips/mach-mtmips/mt7621/Makefile b/arch/mips/mach-mtmips/mt7621/Makefile new file mode 100644 index 0000000000..bf1b0bb688 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/Makefile @@ -0,0 +1,14 @@ +# SPDX-License-Identifier: GPL-2.0 + +obj-y += init.o +obj-y += serial.o + +ifeq ($(CONFIG_SPL_BUILD),y) +ifeq ($(CONFIG_TPL_BUILD),y) +obj-y += tpl/ +else +obj-y += spl/ +endif + +obj-y += sram_init.o +endif diff --git a/arch/mips/mach-mtmips/mt7621/init.c b/arch/mips/mach-mtmips/mt7621/init.c new file mode 100644 index 0000000000..ec63712bc1 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/init.c @@ -0,0 +1,229 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 MediaTek Inc. All rights reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <clk.h> +#include <dm.h> +#include <dm/uclass.h> +#include <dt-bindings/clock/mt7621-clk.h> +#include <asm/global_data.h> +#include <linux/io.h> +#include "mt7621.h" + +DECLARE_GLOBAL_DATA_PTR; + +static const char *const boot_mode[(CHIP_MODE_M >> CHIP_MODE_S) + 1] = { + [1] = "NAND 2K+64", + [2] = "SPI-NOR 3-Byte Addr", + [3] = "SPI-NOR 4-Byte Addr", + [10] = "NAND 2K+128", + [11] = "NAND 4K+128", + [12] = "NAND 4K+256", +}; + +int print_cpuinfo(void) +{ + void __iomem *sysc = ioremap_nocache(SYSCTL_BASE, SYSCTL_SIZE); + u32 val, ver, eco, pkg, core, dram, chipmode; + u32 cpu_clk, ddr_clk, bus_clk, xtal_clk; + struct udevice *clkdev; + const char *bootdev; + struct clk clk; + int ret; + + val = readl(sysc + SYSCTL_CHIP_REV_ID_REG); + ver = (val & VER_ID_M) >> VER_ID_S; + eco = (val & ECO_ID_M) >> ECO_ID_S; + pkg = !!(val & PKG_ID); + core = !!(val & CPU_ID); + + val = readl(sysc + SYSCTL_SYSCFG0_REG); + dram = val & DRAM_TYPE; + chipmode = (val & CHIP_MODE_M) >> CHIP_MODE_S; + + bootdev = boot_mode[chipmode]; + if (!bootdev) + bootdev = "Unsupported boot mode"; + + printf("CPU: MediaTek MT7621%c ver %u, eco %u\n", + core ? (pkg ? 'A' : 'N') : 'S', ver, eco); + + printf("Boot: DDR%u, %s\n", dram ? 2 : 3, bootdev); + + ret = uclass_get_device_by_driver(UCLASS_CLK, DM_DRIVER_GET(mt7621_clk), + &clkdev); + if (ret) + return ret; + + clk.dev = clkdev; + + clk.id = MT7621_CLK_CPU; + cpu_clk = clk_get_rate(&clk); + + clk.id = MT7621_CLK_BUS; + bus_clk = clk_get_rate(&clk); + + clk.id = MT7621_CLK_DDR; + ddr_clk = clk_get_rate(&clk); + + clk.id = MT7621_CLK_XTAL; + xtal_clk = clk_get_rate(&clk); + + /* Set final timer frequency */ + if (cpu_clk) + gd->arch.timer_freq = cpu_clk / 2; + + printf("Clock: CPU: %uMHz, DDR: %uMT/s, Bus: %uMHz, XTAL: %uMHz\n", + cpu_clk / 1000000, ddr_clk / 500000, bus_clk / 1000000, + xtal_clk / 1000000); + + return 0; +} + +unsigned long get_xtal_mhz(void) +{ + void __iomem *sysc = (void *)KSEG1ADDR(SYSCTL_BASE); + u32 bs, xtal_sel; + + bs = readl(sysc + SYSCTL_SYSCFG0_REG); + xtal_sel = (bs & XTAL_MODE_SEL_M) >> XTAL_MODE_SEL_S; + + if (xtal_sel <= 2) + return 20; + else if (xtal_sel <= 5) + return 40; + else + return 25; +} + +static void xhci_config_40mhz(void __iomem *usbh) +{ + writel((0x20 << SSUSB_MAC3_SYS_CK_GATE_MASK_TIME_S) | + (0x20 << SSUSB_MAC2_SYS_CK_GATE_MASK_TIME_S) | + (2 << SSUSB_MAC3_SYS_CK_GATE_MODE_S) | + (2 << SSUSB_MAC2_SYS_CK_GATE_MODE_S) | 0x10, + usbh + SSUSB_MAC_CK_CTRL_REG); + + writel((2 << SSUSB_PLL_PREDIV_PE1D_S) | (1 << SSUSB_PLL_PREDIV_U3_S) | + (4 << SSUSB_PLL_FBKDI_S), usbh + DA_SSUSB_U3PHYA_10_REG); + + writel((0x18 << SSUSB_PLL_FBKDIV_PE2H_S) | + (0x18 << SSUSB_PLL_FBKDIV_PE1D_S) | + (0x18 << SSUSB_PLL_FBKDIV_PE1H_S) | + (0x1e << SSUSB_PLL_FBKDIV_U3_S), + usbh + DA_SSUSB_PLL_FBKDIV_REG); + + writel((0x1e400000 << SSUSB_PLL_PCW_NCPO_U3_S), + usbh + DA_SSUSB_PLL_PCW_NCPO_REG); + + writel((0x25 << SSUSB_PLL_SSC_DELTA1_PE1H_S) | + (0x73 << SSUSB_PLL_SSC_DELTA1_U3_S), + usbh + DA_SSUSB_PLL_SSC_DELTA1_REG); + + writel((0x71 << SSUSB_PLL_SSC_DELTA_U3_S) | + (0x4a << SSUSB_PLL_SSC_DELTA1_PE2D_S), + usbh + DA_SSUSB_U3PHYA_21_REG); + + writel((0x140 << SSUSB_PLL_SSC_PRD_S), usbh + SSUSB_U3PHYA_9_REG); + + writel((0x11c00000 << SSUSB_SYSPLL_PCW_NCPO_S), + usbh + SSUSB_U3PHYA_3_REG); + + writel((4 << SSUSB_PCIE_CLKDRV_AMP_S) | (1 << SSUSB_SYSPLL_FBSEL_S) | + (1 << SSUSB_SYSPLL_PREDIV_S), usbh + SSUSB_U3PHYA_1_REG); + + writel((0x12 << SSUSB_SYSPLL_FBDIV_S) | SSUSB_SYSPLL_VCO_DIV_SEL | + SSUSB_SYSPLL_FPEN | SSUSB_SYSPLL_MONCK_EN | SSUSB_SYSPLL_VOD_EN, + usbh + SSUSB_U3PHYA_2_REG); + + writel(SSUSB_EQ_CURSEL | (8 << SSUSB_RX_DAC_MUX_S) | + (1 << SSUSB_PCIE_SIGDET_VTH_S) | (1 << SSUSB_PCIE_SIGDET_LPF_S), + usbh + SSUSB_U3PHYA_11_REG); + + writel((0x1ff << SSUSB_RING_OSC_CNTEND_S) | + (0x7f << SSUSB_XTAL_OSC_CNTEND_S) | SSUSB_RING_BYPASS_DET, + usbh + SSUSB_B2_ROSC_0_REG); + + writel((3 << SSUSB_RING_OSC_FRC_RECAL_S) | SSUSB_RING_OSC_FRC_SEL, + usbh + SSUSB_B2_ROSC_1_REG); +} + +static void xhci_config_25mhz(void __iomem *usbh) +{ + writel((0x20 << SSUSB_MAC3_SYS_CK_GATE_MASK_TIME_S) | + (0x20 << SSUSB_MAC2_SYS_CK_GATE_MASK_TIME_S) | + (2 << SSUSB_MAC3_SYS_CK_GATE_MODE_S) | + (2 << SSUSB_MAC2_SYS_CK_GATE_MODE_S) | 0x10, + usbh + SSUSB_MAC_CK_CTRL_REG); + + writel((2 << SSUSB_PLL_PREDIV_PE1D_S) | (4 << SSUSB_PLL_FBKDI_S), + usbh + DA_SSUSB_U3PHYA_10_REG); + + writel((0x18 << SSUSB_PLL_FBKDIV_PE2H_S) | + (0x18 << SSUSB_PLL_FBKDIV_PE1D_S) | + (0x18 << SSUSB_PLL_FBKDIV_PE1H_S) | + (0x19 << SSUSB_PLL_FBKDIV_U3_S), + usbh + DA_SSUSB_PLL_FBKDIV_REG); + + writel((0x18000000 << SSUSB_PLL_PCW_NCPO_U3_S), + usbh + DA_SSUSB_PLL_PCW_NCPO_REG); + + writel((0x25 << SSUSB_PLL_SSC_DELTA1_PE1H_S) | + (0x4a << SSUSB_PLL_SSC_DELTA1_U3_S), + usbh + DA_SSUSB_PLL_SSC_DELTA1_REG); + + writel((0x48 << SSUSB_PLL_SSC_DELTA_U3_S) | + (0x4a << SSUSB_PLL_SSC_DELTA1_PE2D_S), + usbh + DA_SSUSB_U3PHYA_21_REG); + + writel((0x190 << SSUSB_PLL_SSC_PRD_S), usbh + SSUSB_U3PHYA_9_REG); + + writel((0xe000000 << SSUSB_SYSPLL_PCW_NCPO_S), + usbh + SSUSB_U3PHYA_3_REG); + + writel((4 << SSUSB_PCIE_CLKDRV_AMP_S) | (1 << SSUSB_SYSPLL_FBSEL_S), + usbh + SSUSB_U3PHYA_1_REG); + + writel((0xf << SSUSB_SYSPLL_FBDIV_S) | SSUSB_SYSPLL_VCO_DIV_SEL | + SSUSB_SYSPLL_FPEN | SSUSB_SYSPLL_MONCK_EN | SSUSB_SYSPLL_VOD_EN, + usbh + SSUSB_U3PHYA_2_REG); + + writel(SSUSB_EQ_CURSEL | (8 << SSUSB_RX_DAC_MUX_S) | + (1 << SSUSB_PCIE_SIGDET_VTH_S) | (1 << SSUSB_PCIE_SIGDET_LPF_S), + usbh + SSUSB_U3PHYA_11_REG); + + writel((0x1ff << SSUSB_RING_OSC_CNTEND_S) | + (0x7f << SSUSB_XTAL_OSC_CNTEND_S) | SSUSB_RING_BYPASS_DET, + usbh + SSUSB_B2_ROSC_0_REG); + + writel((3 << SSUSB_RING_OSC_FRC_RECAL_S) | SSUSB_RING_OSC_FRC_SEL, + usbh + SSUSB_B2_ROSC_1_REG); +} + +void lowlevel_init(void) +{ + void __iomem *usbh = ioremap_nocache(SSUSB_BASE, SSUSB_SIZE); + u32 xtal = get_xtal_mhz(); + + /* Setup USB xHCI */ + if (xtal == 40) + xhci_config_40mhz(usbh); + else if (xtal == 25) + xhci_config_25mhz(usbh); +} + +ulong notrace get_tbclk(void) +{ + return gd->arch.timer_freq; +} + +void _machine_restart(void) +{ + void __iomem *sysc = ioremap_nocache(SYSCTL_BASE, SYSCTL_SIZE); + + while (1) + writel(SYS_RST, sysc + SYSCTL_RSTCTL_REG); +} diff --git a/arch/mips/mach-mtmips/mt7621/mt7621.h b/arch/mips/mach-mtmips/mt7621/mt7621.h new file mode 100644 index 0000000000..916cc993b4 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/mt7621.h @@ -0,0 +1,229 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2022 MediaTek Inc. All rights reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#ifndef _MT7621_H_ +#define _MT7621_H_ + +#define SYSCTL_BASE 0x1e000000 +#define SYSCTL_SIZE 0x100 +#define TIMER_BASE 0x1e000100 +#define TIMER_SIZE 0x100 +#define RBUS_BASE 0x1e000400 +#define RBUS_SIZE 0x100 +#define GPIO_BASE 0x1e000600 +#define GPIO_SIZE 0x100 +#define DMA_CFG_ARB_BASE 0x1e000800 +#define DMA_CFG_ARB_SIZE 0x100 +#define SPI_BASE 0x1e000b00 +#define SPI_SIZE 0x100 +#define UART1_BASE 0x1e000c00 +#define UART1_SIZE 0x100 +#define UART2_BASE 0x1e000d00 +#define UART2_SIZE 0x100 +#define UART3_BASE 0x1e000e00 +#define UART3_SIZE 0x100 +#define NFI_BASE 0x1e003000 +#define NFI_SIZE 0x800 +#define NFI_ECC_BASE 0x1e003800 +#define NFI_ECC_SIZE 0x800 +#define DRAMC_BASE 0x1e005000 +#define DRAMC_SIZE 0x1000 +#define FE_BASE 0x1e100000 +#define FE_SIZE 0xe000 +#define GMAC_BASE 0x1e110000 +#define GMAC_SIZE 0x8000 +#define SSUSB_BASE 0x1e1c0000 +#define SSUSB_SIZE 0x40000 + + /* GIC Base Address */ +#define MIPS_GIC_BASE 0x1fbc0000 + + /* CPC Base Address */ +#define MIPS_CPC_BASE 0x1fbf0000 + + /* Flash Memory-mapped Base Address */ +#define FLASH_MMAP_BASE 0x1fc00000 +#define TPL_INFO_OFFSET 0x40 +#define TPL_INFO_MAGIC 0x31323637 /* Magic "7621" */ + +/* SRAM */ +#define FE_SRAM_BASE1 0x8000 +#define FE_SRAM_BASE2 0xa000 + +/* SYSCTL_BASE */ +#define SYSCTL_CHIP_REV_ID_REG 0x0c +#define CPU_ID 0x20000 +#define PKG_ID 0x10000 +#define VER_ID_S 8 +#define VER_ID_M 0xf00 +#define ECO_ID_S 0 +#define ECO_ID_M 0x0f + +#define SYSCTL_SYSCFG0_REG 0x10 +#define XTAL_MODE_SEL_S 6 +#define XTAL_MODE_SEL_M 0x1c0 +#define DRAM_TYPE 0x10 +#define CHIP_MODE_S 0 +#define CHIP_MODE_M 0x0f + +#define BOOT_SRAM_BASE_REG 0x20 + +#define SYSCTL_CLKCFG0_REG 0x2c +#define CPU_CLK_SEL_S 30 +#define CPU_CLK_SEL_M 0xc0000000 +#define MPLL_CFG_SEL_S 23 +#define MPLL_CFG_SEL_M 0x800000 + +#define SYSCTL_RSTCTL_REG 0x34 +#define MCM_RST 0x04 +#define SYS_RST 0x01 + +#define SYSCTL_CUR_CLK_STS_REG 0x44 +#define CUR_CPU_FDIV_S 8 +#define CUR_CPU_FDIV_M 0x1f00 +#define CUR_CPU_FFRAC_S 0 +#define CUR_CPU_FFRAC_M 0x1f + +#define SYSCTL_GPIOMODE_REG 0x60 +#define UART2_MODE_S 5 +#define UART2_MODE_M 0x60 +#define UART3_MODE_S 3 +#define UART3_MODE_M 0x18 +#define UART1_MODE 0x02 + +/* RBUS_BASE */ +#define RBUS_DYN_CFG0_REG 0x0010 +#define CPU_FDIV_S 8 +#define CPU_FDIV_M 0x1f00 +#define CPU_FFRAC_S 0 +#define CPU_FFRAC_M 0x1f + +/* DMA_CFG_ARB_BASE */ +#define DMA_ROUTE_REG 0x000c + +/* SPI_BASE */ +#define SPI_SPACE_REG 0x003c +#define FS_SLAVE_SEL_S 12 +#define FS_SLAVE_SEL_M 0x70000 +#define FS_CLK_SEL_S 0 +#define FS_CLK_SEL_M 0xfff + +/* FE_BASE */ +#define FE_RST_GLO_REG 0x0004 +#define FE_PSE_RAM 0x04 +#define FE_PSE_MEM_EN 0x02 +#define FE_PSE_RESET 0x01 + +/* SSUSB_BASE */ +#define SSUSB_MAC_CK_CTRL_REG 0x10784 +#define SSUSB_MAC3_SYS_CK_GATE_MASK_TIME_S 16 +#define SSUSB_MAC3_SYS_CK_GATE_MASK_TIME_M 0xff0000 +#define SSUSB_MAC2_SYS_CK_GATE_MASK_TIME_S 8 +#define SSUSB_MAC2_SYS_CK_GATE_MASK_TIME_M 0xff00 +#define SSUSB_MAC3_SYS_CK_GATE_MODE_S 2 +#define SSUSB_MAC3_SYS_CK_GATE_MODE_M 0x0c +#define SSUSB_MAC2_SYS_CK_GATE_MODE_S 0 +#define SSUSB_MAC2_SYS_CK_GATE_MODE_M 0x03 + +#define SSUSB_B2_ROSC_0_REG 0x10a40 +#define SSUSB_RING_OSC_CNTEND_S 23 +#define SSUSB_RING_OSC_CNTEND_M 0xff800000 +#define SSUSB_XTAL_OSC_CNTEND_S 16 +#define SSUSB_XTAL_OSC_CNTEND_M 0x7f0000 +#define SSUSB_RING_BYPASS_DET 0x01 + +#define SSUSB_B2_ROSC_1_REG 0x10a44 +#define SSUSB_RING_OSC_FRC_RECAL_S 17 +#define SSUSB_RING_OSC_FRC_RECAL_M 0x60000 +#define SSUSB_RING_OSC_FRC_SEL 0x01 + +#define SSUSB_U3PHYA_1_REG 0x10b04 +#define SSUSB_PCIE_CLKDRV_AMP_S 27 +#define SSUSB_PCIE_CLKDRV_AMP_M 0x38000000 +#define SSUSB_SYSPLL_FBSEL_S 2 +#define SSUSB_SYSPLL_FBSEL_M 0x0c +#define SSUSB_SYSPLL_PREDIV_S 0 +#define SSUSB_SYSPLL_PREDIV_M 0x03 + +#define SSUSB_U3PHYA_2_REG 0x10b08 +#define SSUSB_SYSPLL_FBDIV_S 24 +#define SSUSB_SYSPLL_FBDIV_M 0x7f000000 +#define SSUSB_SYSPLL_VCO_DIV_SEL 0x200000 +#define SSUSB_SYSPLL_FPEN 0x2000 +#define SSUSB_SYSPLL_MONCK_EN 0x1000 +#define SSUSB_SYSPLL_VOD_EN 0x200 + +#define SSUSB_U3PHYA_3_REG 0x10b10 +#define SSUSB_SYSPLL_PCW_NCPO_S 1 +#define SSUSB_SYSPLL_PCW_NCPO_M 0xfffffffe + +#define SSUSB_U3PHYA_9_REG 0x10b24 +#define SSUSB_PLL_SSC_PRD_S 0 +#define SSUSB_PLL_SSC_PRD_M 0xffff + +#define SSUSB_U3PHYA_11_REG 0x10b2c +#define SSUSB_EQ_CURSEL 0x1000000 +#define SSUSB_RX_DAC_MUX_S 19 +#define SSUSB_RX_DAC_MUX_M 0xf80000 +#define SSUSB_PCIE_SIGDET_VTH_S 5 +#define SSUSB_PCIE_SIGDET_VTH_M 0x60 +#define SSUSB_PCIE_SIGDET_LPF_S 3 +#define SSUSB_PCIE_SIGDET_LPF_M 0x18 + +#define DA_SSUSB_PLL_FBKDIV_REG 0x10c1c +#define SSUSB_PLL_FBKDIV_PE2H_S 24 +#define SSUSB_PLL_FBKDIV_PE2H_M 0x7f000000 +#define SSUSB_PLL_FBKDIV_PE1D_S 16 +#define SSUSB_PLL_FBKDIV_PE1D_M 0x7f0000 +#define SSUSB_PLL_FBKDIV_PE1H_S 8 +#define SSUSB_PLL_FBKDIV_PE1H_M 0x7f00 +#define SSUSB_PLL_FBKDIV_U3_S 0 +#define SSUSB_PLL_FBKDIV_U3_M 0x7f + +#define DA_SSUSB_U3PHYA_10_REG 0x10c20 +#define SSUSB_PLL_PREDIV_PE1D_S 18 +#define SSUSB_PLL_PREDIV_PE1D_M 0xc0000 +#define SSUSB_PLL_PREDIV_U3_S 8 +#define SSUSB_PLL_PREDIV_U3_M 0x300 +#define SSUSB_PLL_FBKDI_S 0 +#define SSUSB_PLL_FBKDI_M 0x07 + +#define DA_SSUSB_PLL_PCW_NCPO_REG 0x10c24 +#define SSUSB_PLL_PCW_NCPO_U3_S 0 +#define SSUSB_PLL_PCW_NCPO_U3_M 0x7fffffff + +#define DA_SSUSB_PLL_SSC_DELTA1_REG 0x10c38 +#define SSUSB_PLL_SSC_DELTA1_PE1H_S 16 +#define SSUSB_PLL_SSC_DELTA1_PE1H_M 0xffff0000 +#define SSUSB_PLL_SSC_DELTA1_U3_S 0 +#define SSUSB_PLL_SSC_DELTA1_U3_M 0xffff + +#define DA_SSUSB_U3PHYA_21_REG 0x10c40 +#define SSUSB_PLL_SSC_DELTA_U3_S 16 +#define SSUSB_PLL_SSC_DELTA_U3_M 0xffff0000 +#define SSUSB_PLL_SSC_DELTA1_PE2D_S 0 +#define SSUSB_PLL_SSC_DELTA1_PE2D_M 0xffff + +/* MT7621 specific CM values */ + +/* GCR_REGx_BASE */ +#define GCR_REG0_BASE_VALUE 0x1c000000 +#define GCR_REG1_BASE_VALUE 0x60000000 +#define GCR_REG2_BASE_VALUE 0x1c000000 +#define GCR_REG3_BASE_VALUE 0x1c000000 + +/* GCR_REGx_MASK */ +#define GCR_REG0_MASK_VALUE 0x0000fc00 /* 64M Bus */ +#define GCR_REG1_MASK_VALUE 0x0000f000 /* 256M PCI Mem */ +#define GCR_REG2_MASK_VALUE 0x0000fc00 /* unused */ +#define GCR_REG3_MASK_VALUE 0x0000fc00 /* unused */ + +#ifndef __ASSEMBLY__ +unsigned long get_xtal_mhz(void); +#endif + +#endif /* _MT7621_H_ */ diff --git a/arch/mips/mach-mtmips/mt7621/serial.c b/arch/mips/mach-mtmips/mt7621/serial.c new file mode 100644 index 0000000000..0ccc71dc75 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/serial.c @@ -0,0 +1,23 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 MediaTek Inc. All rights reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <asm/io.h> +#include <asm/addrspace.h> +#include "mt7621.h" + +void board_debug_uart_init(void) +{ + void __iomem *base = ioremap_nocache(SYSCTL_BASE, SYSCTL_SIZE); + +#if CONFIG_DEBUG_UART_BASE == 0xbe000c00 /* KSEG1ADDR(UART1_BASE) */ + clrbits_32(base + SYSCTL_GPIOMODE_REG, UART1_MODE); +#elif CONFIG_DEBUG_UART_BASE == 0xbe000d00 /* KSEG1ADDR(UART2_BASE) */ + clrbits_32(base + SYSCTL_GPIOMODE_REG, UART2_MODE_M); +#elif CONFIG_DEBUG_UART_BASE == 0xbe000e00 /* KSEG1ADDR(UART3_BASE) */ + clrbits_32(base + SYSCTL_GPIOMODE_REG, UART3_MODE_M); +#endif +} diff --git a/arch/mips/mach-mtmips/mt7621/spl/Makefile b/arch/mips/mach-mtmips/mt7621/spl/Makefile new file mode 100644 index 0000000000..ebe54e79b9 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/spl/Makefile @@ -0,0 +1,9 @@ + +extra-y += start.o + +obj-y += spl.o +obj-y += cps.o +obj-y += dram.o +obj-y += serial.o +obj-y += launch.o +obj-y += launch_ll.o diff --git a/arch/mips/mach-mtmips/mt7621/spl/cps.c b/arch/mips/mach-mtmips/mt7621/spl/cps.c new file mode 100644 index 0000000000..61f319f45f --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/spl/cps.c @@ -0,0 +1,152 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 MediaTek Inc. All rights reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <asm/io.h> +#include <asm/addrspace.h> +#include <asm/mipsregs.h> +#include <asm/cm.h> +#include "../mt7621.h" + +/* GIC Shared Register Bases */ +#define GIC_SH_POL_BASE 0x100 +#define GIC_SH_TRIG_BASE 0x180 +#define GIC_SH_RMASK_BASE 0x300 +#define GIC_SH_SMASK_BASE 0x380 +#define GIC_SH_MASK_BASE 0x400 +#define GIC_SH_PEND_BASE 0x480 +#define GIC_SH_MAP_PIN_BASE 0x500 +#define GIC_SH_MAP_VPE_BASE 0x2000 + +/* GIC Registers */ +#define GIC_SH_POL31_0 (GIC_SH_POL_BASE + 0x00) +#define GIC_SH_POL63_32 (GIC_SH_POL_BASE + 0x04) + +#define GIC_SH_TRIG31_0 (GIC_SH_TRIG_BASE + 0x00) +#define GIC_SH_TRIG63_32 (GIC_SH_TRIG_BASE + 0x04) + +#define GIC_SH_RMASK31_0 (GIC_SH_RMASK_BASE + 0x00) +#define GIC_SH_RMASK63_32 (GIC_SH_RMASK_BASE + 0x04) + +#define GIC_SH_SMASK31_0 (GIC_SH_SMASK_BASE + 0x00) +#define GIC_SH_SMASK63_32 (GIC_SH_SMASK_BASE + 0x04) + +#define GIC_SH_MAP_PIN(n) (GIC_SH_MAP_PIN_BASE + (n) * 4) + +#define GIC_SH_MAP_VPE(n, v) (GIC_SH_MAP_VPE_BASE + (n) * 0x20 + ((v) / 32) * 4) +#define GIC_SH_MAP_VPE31_0(n) GIC_SH_MAP_VPE(n, 0) + +/* GIC_SH_MAP_PIN fields */ +#define GIC_MAP_TO_PIN BIT(31) +#define GIC_MAP_TO_NMI BIT(30) +#define GIC_MAP GENMASK(5, 0) +#define GIC_MAP_SHIFT 0 + +static void cm_init(void __iomem *cm_base) +{ + u32 num_cores; + + num_cores = ((readl(cm_base + GCR_CONFIG) & GCR_CONFIG_PCORES) >> + GCR_CONFIG_PCORES_SHIFT) + 1; + + writel((1 << num_cores) - 1, cm_base + GCR_ACCESS); + + writel(GCR_REG0_BASE_VALUE, cm_base + GCR_REG0_BASE); + writel(GCR_REG1_BASE_VALUE, cm_base + GCR_REG1_BASE); + writel(GCR_REG2_BASE_VALUE, cm_base + GCR_REG2_BASE); + writel(GCR_REG3_BASE_VALUE, cm_base + GCR_REG3_BASE); + + clrsetbits_32(cm_base + GCR_REG0_MASK, + GCR_REGn_MASK_ADDRMASK | GCR_REGn_MASK_CMTGT, + (GCR_REG0_MASK_VALUE << GCR_REGn_MASK_ADDRMASK_SHIFT) | + GCR_REGn_MASK_CMTGT_IOCU0); + + clrsetbits_32(cm_base + GCR_REG1_MASK, + GCR_REGn_MASK_ADDRMASK | GCR_REGn_MASK_CMTGT, + (GCR_REG1_MASK_VALUE << GCR_REGn_MASK_ADDRMASK_SHIFT) | + GCR_REGn_MASK_CMTGT_IOCU0); + + clrsetbits_32(cm_base + GCR_REG2_MASK, + GCR_REGn_MASK_ADDRMASK | GCR_REGn_MASK_CMTGT, + (GCR_REG2_MASK_VALUE << GCR_REGn_MASK_ADDRMASK_SHIFT) | + GCR_REGn_MASK_CMTGT_IOCU0); + + clrsetbits_32(cm_base + GCR_REG3_MASK, + GCR_REGn_MASK_ADDRMASK | GCR_REGn_MASK_CMTGT, + (GCR_REG3_MASK_VALUE << GCR_REGn_MASK_ADDRMASK_SHIFT) | + GCR_REGn_MASK_CMTGT_IOCU0); + + clrbits_32(cm_base + GCR_BASE, CM_DEFAULT_TARGET_MASK); + setbits_32(cm_base + GCR_CONTROL, GCR_CONTROL_SYNCCTL); +} + +static void gic_init(void) +{ + void __iomem *gic_base = (void *)KSEG1ADDR(MIPS_GIC_BASE); + int i; + + /* Interrupt 0..5: Level Trigger, Active High */ + writel(0, gic_base + GIC_SH_TRIG31_0); + writel(0x3f, gic_base + GIC_SH_RMASK31_0); + writel(0x3f, gic_base + GIC_SH_POL31_0); + writel(0x3f, gic_base + GIC_SH_SMASK31_0); + + /* Interrupt 56..63: Edge Trigger, Rising Edge */ + /* Hardcoded to set up the last 8 external interrupts for IPI. */ + writel(0xff000000, gic_base + GIC_SH_TRIG63_32); + writel(0xff000000, gic_base + GIC_SH_RMASK63_32); + writel(0xff000000, gic_base + GIC_SH_POL63_32); + writel(0xff000000, gic_base + GIC_SH_SMASK63_32); + + /* Map interrupt source to particular hardware interrupt pin */ + /* source {0,1,2,3,4,5} -> pin {0,0,4,3,0,5} */ + writel(GIC_MAP_TO_PIN | 0, gic_base + GIC_SH_MAP_PIN(0)); + writel(GIC_MAP_TO_PIN | 0, gic_base + GIC_SH_MAP_PIN(1)); + writel(GIC_MAP_TO_PIN | 4, gic_base + GIC_SH_MAP_PIN(2)); + writel(GIC_MAP_TO_PIN | 3, gic_base + GIC_SH_MAP_PIN(3)); + writel(GIC_MAP_TO_PIN | 0, gic_base + GIC_SH_MAP_PIN(4)); + writel(GIC_MAP_TO_PIN | 5, gic_base + GIC_SH_MAP_PIN(5)); + + /* source 56~59 -> pin 1, 60~63 -> pin 2 */ + writel(GIC_MAP_TO_PIN | 1, gic_base + GIC_SH_MAP_PIN(56)); + writel(GIC_MAP_TO_PIN | 1, gic_base + GIC_SH_MAP_PIN(57)); + writel(GIC_MAP_TO_PIN | 1, gic_base + GIC_SH_MAP_PIN(58)); + writel(GIC_MAP_TO_PIN | 1, gic_base + GIC_SH_MAP_PIN(59)); + writel(GIC_MAP_TO_PIN | 2, gic_base + GIC_SH_MAP_PIN(60)); + writel(GIC_MAP_TO_PIN | 2, gic_base + GIC_SH_MAP_PIN(61)); + writel(GIC_MAP_TO_PIN | 2, gic_base + GIC_SH_MAP_PIN(62)); + writel(GIC_MAP_TO_PIN | 2, gic_base + GIC_SH_MAP_PIN(63)); + + /* Interrupt map to VPE (bit mask) */ + for (i = 0; i < 32; i++) + writel(BIT(0), gic_base + GIC_SH_MAP_VPE31_0(i)); + + /* + * Direct GIC_int 56..63 to vpe 0..3 + * MIPS Linux convention that last 16 interrupts implemented be set + * aside for IPI signaling. + * The actual interrupts are tied low and software sends interrupts + * via GIC_SH_WEDGE writes. + */ + for (i = 0; i < 4; i++) { + writel(BIT(i), gic_base + GIC_SH_MAP_VPE31_0(i + 56)); + writel(BIT(i), gic_base + GIC_SH_MAP_VPE31_0(i + 60)); + } +} + +void mt7621_cps_init(void) +{ + void __iomem *cm_base = (void *)KSEG1ADDR(CONFIG_MIPS_CM_BASE); + + /* Enable GIC */ + writel(MIPS_GIC_BASE | GCR_GIC_EN, cm_base + GCR_GIC_BASE); + + /* Enable CPC */ + writel(MIPS_CPC_BASE | GCR_CPC_EN, cm_base + GCR_CPC_BASE); + + gic_init(); + cm_init(cm_base); +} diff --git a/arch/mips/mach-mtmips/mt7621/spl/dram.c b/arch/mips/mach-mtmips/mt7621/spl/dram.c new file mode 100644 index 0000000000..827c4a71e9 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/spl/dram.c @@ -0,0 +1,155 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 MediaTek Inc. All rights reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <asm/io.h> +#include <asm/sections.h> +#include <asm/byteorder.h> +#include <asm/addrspace.h> +#include <linux/string.h> +#include "../mt7621.h" +#include "dram.h" + +static const u32 ddr2_act[DDR_PARAM_SIZE] = { +#if defined(CONFIG_MT7621_DRAM_DDR2_512M) + 0xAA00AA00, 0xAA00AA00, 0x00000007, 0x22174441, + 0x00000000, 0xF0748661, 0x40001273, 0x9F0A0481, + 0x0304692F, 0x15602842, 0x00008888, 0x88888888, + 0x00000000, 0x00000000, 0x00000000, 0x07100000, + 0x00001B63, 0x00002000, 0x00004000, 0x00006000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, +#elif defined(CONFIG_MT7621_DRAM_DDR2_512M_W9751G6KB_A02_1066MHZ) + 0xAA00AA00, 0xAA00AA00, 0x00000007, 0x33484584, + 0x00000000, 0xF07486A1, 0x50001273, 0x9F010481, + 0x0304693F, 0x15602842, 0x00008888, 0x88888888, + 0x00000000, 0x00000000, 0x00000010, 0x07100000, + 0x00001F73, 0x00002000, 0x00004000, 0x00006000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, +#elif defined(CONFIG_MT7621_DRAM_DDR2_1024M_W971GG6KB25_800MHZ) + 0xAA00AA00, 0xAA00AA00, 0x00000007, 0x22174430, + 0x01000000, 0xF0748661, 0x40001273, 0x9F0F0481, + 0x0304692F, 0x15602842, 0x00008888, 0x88888888, + 0x00000000, 0x00000000, 0x00000000, 0x07100000, + 0x00001B63, 0x00002000, 0x00004000, 0x00006000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, +#elif defined(CONFIG_MT7621_DRAM_DDR2_1024M_W971GG6KB18_1066MHZ) + 0xAA00AA00, 0xAA00AA00, 0x00000007, 0x33484584, + 0x01000000, 0xF07486A1, 0x50001273, 0x9F070481, + 0x0304693F, 0x15602842, 0x00008888, 0x88888888, + 0x00000000, 0x00000000, 0x00000010, 0x07100000, + 0x00001F73, 0x00002000, 0x00004000, 0x00006000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, +#else /* CONFIG_MT7621_DRAM_DDR2_1024M */ + 0xAA00AA00, 0xAA00AA00, 0x00000007, 0x22174441, + 0x01000000, 0xF0748661, 0x40001273, 0x9F0F0481, + 0x0304692F, 0x15602842, 0x00008888, 0x88888888, + 0x00000000, 0x00000000, 0x00000000, 0x07100000, + 0x00001B63, 0x00002000, 0x00004000, 0x00006000, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, +#endif +}; + +static const u32 ddr3_act[DDR_PARAM_SIZE] = { +#if defined(CONFIG_MT7621_DRAM_DDR3_1024M) + 0xAA00AA00, 0xAA00AA00, 0x00000007, 0x44694683, + 0x01000000, 0xF07486A1, 0xC287221D, 0x9F060481, + 0x03046948, 0x15602842, 0x00008888, 0x88888888, + 0x00000000, 0x00000000, 0x00000210, 0x07100000, + 0x00001B61, 0x00002040, 0x00004010, 0x00006000, + 0x0C000000, 0x07070000, 0x00000000, 0x00000000, +#elif defined(CONFIG_MT7621_DRAM_DDR3_4096M) + 0xAA00AA00, 0xAA00AA00, 0x00000007, 0x44694683, + 0x01000000, 0xF07486A1, 0xC287221D, 0x9F0F0481, + 0x03046948, 0x15602842, 0x00008888, 0x88888888, + 0x00000000, 0x00000000, 0x00000240, 0x07100000, + 0x00001B61, 0x00002040, 0x00004010, 0x00006000, + 0x0C000000, 0x07070000, 0x00000000, 0x00000000, +#elif defined(CONFIG_MT7621_DRAM_DDR3_1024M_KGD) + 0xFF00FF00, 0xFF00FF00, 0x00000007, 0x44694683, + 0x01000000, 0xF07406A1, 0xC287221D, 0x9F060481, + 0x03046923, 0x152f2842, 0x00008888, 0x88888888, + 0x00000000, 0x00000000, 0x00000210, 0x07100000, + 0x00001B61, 0x00002040, 0x00004010, 0x00006000, + 0x0C000000, 0x07070000, 0x000C0000, 0x00000000, +#else /* CONFIG_MT7621_DRAM_DDR3_2048M */ + 0xAA00AA00, 0xAA00AA00, 0x00000007, 0x44694673, + 0x01000000, 0xF07486A1, 0xC287221D, 0x9F050481, + 0x03046948, 0x15602842, 0x00008888, 0x88888888, + 0x00000000, 0x00000000, 0x00000220, 0x07100000, + 0x00001B61, 0x00002040, 0x00004010, 0x00006000, + 0x0C000000, 0x07070000, 0x00000000, 0x00000000, +#endif +}; + +#if defined(CONFIG_MT7621_DRAM_FREQ_400) +#define DDR_FREQ_PARAM 0x41000000 +#elif defined(CONFIG_MT7621_DRAM_FREQ_1066) +#define DDR_FREQ_PARAM 0x21000000 +#elif defined(CONFIG_MT7621_DRAM_FREQ_1200) +#define DDR_FREQ_PARAM 0x11000000 +#else /* CONFIG_MT7621_DRAM_FREQ_800 */ +#define DDR_FREQ_PARAM 0x31000000 +#endif + +#define RG_MEPL_FBDIV_S 4 +#define RG_MEPL_FBDIV_M 0x7f + +static inline void word_copy(u32 *dest, const u32 *src, u32 count) +{ + u32 i; + + for (i = 0; i < count; i++) + dest[i] = src[i]; +} + +static u32 calc_cpu_pll_val(void) +{ + u32 div, baseval, fb; + + div = get_xtal_mhz(); + + if (div == 40) { + div /= 2; + baseval = 0xc0005802; + } else { + baseval = 0xc0004802; + } + + fb = CONFIG_MT7621_CPU_FREQ / div - 1; + if (fb > RG_MEPL_FBDIV_M) + fb = RG_MEPL_FBDIV_M; + + return baseval | (fb << RG_MEPL_FBDIV_S); +} + +void prepare_stage_bin(void) +{ + u32 stage_size; + + const struct stage_header *stock_stage_bin = + (const struct stage_header *)__image_copy_end; + + struct stage_header *new_stage_bin = + (struct stage_header *)STAGE_LOAD_ADDR; + + if (be32_to_cpu(stock_stage_bin->ep) != STAGE_LOAD_ADDR) { + /* Possible wrong binary blob. Hang here */ + for (;;) + ; + } + + stage_size = be32_to_cpu(stock_stage_bin->stage_size); + + word_copy((u32 *)new_stage_bin, (const u32 *)stock_stage_bin, + (stage_size + sizeof(u32) - 1) / sizeof(u32)); + + word_copy(new_stage_bin->ddr2_act, ddr2_act, DDR_PARAM_SIZE); + word_copy(new_stage_bin->ddr3_act, ddr3_act, DDR_PARAM_SIZE); + + new_stage_bin->cpu_pll_cfg = calc_cpu_pll_val(); + new_stage_bin->ddr_pll_cfg = DDR_FREQ_PARAM; + new_stage_bin->baudrate = CONFIG_BAUDRATE; +} diff --git a/arch/mips/mach-mtmips/mt7621/spl/dram.h b/arch/mips/mach-mtmips/mt7621/spl/dram.h new file mode 100644 index 0000000000..7322c58276 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/spl/dram.h @@ -0,0 +1,39 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2022 MediaTek Inc. All rights reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#ifndef _MT7621_DRAM_H_ +#define _MT7621_DRAM_H_ + +#define STAGE_LOAD_ADDR 0xBE108800 + +#ifndef __ASSEMBLY__ +#include <linux/types.h> + +#define DDR_PARAM_SIZE 24 + +struct stage_header { + u32 jump_insn[2]; + u32 ep; + u32 stage_size; + u32 has_stage2; + u32 next_ep; + u32 next_size; + u32 next_offset; + u32 cpu_pll_cfg; + u32 ddr_pll_cfg; + u32 reserved2[6]; + char build_tag[32]; + u32 ddr3_act[DDR_PARAM_SIZE]; + u32 padding1[2]; + u32 ddr2_act[DDR_PARAM_SIZE]; + u32 padding2[2]; + u32 baudrate; + u32 padding3; +}; +#endif + +#endif /* _MT7621_DRAM_H_ */ diff --git a/arch/mips/mach-mtmips/mt7621/spl/launch.c b/arch/mips/mach-mtmips/mt7621/spl/launch.c new file mode 100644 index 0000000000..37c20a5f56 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/spl/launch.c @@ -0,0 +1,100 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 MediaTek Inc. All rights reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <asm/io.h> +#include <asm/cm.h> +#include <asm/sections.h> +#include <asm/addrspace.h> +#include <asm/mipsmtregs.h> +#include <linux/sizes.h> +#include <time.h> +#include <cpu_func.h> +#include "launch.h" +#include "../mt7621.h" + +/* Cluster Power Controller (CPC) offsets */ +#define CPC_CL_OTHER 0x2010 +#define CPC_CO_CMD 0x4000 + +/* CPC_CL_OTHER fields */ +#define CPC_CL_OTHER_CORENUM_SHIFT 16 +#define CPC_CL_OTHER_CORENUM GENMASK(23, 16) + +/* CPC_CO_CMD */ +#define PWR_UP 3 + +#define NUM_CORES 2 +#define NUM_CPUS 4 +#define WAIT_CPUS_TIMEOUT 4000 + +static void copy_launch_wait_code(void) +{ + memset((void *)KSEG1, 0, SZ_4K); + + memcpy((void *)KSEG1ADDR(LAUNCH_WAITCODE), + &launch_wait_code_start, + &launch_wait_code_end - &launch_wait_code_start); + + invalidate_dcache_range(KSEG0, SZ_4K); +} + +static void bootup_secondary_core(void) +{ + void __iomem *cpcbase = (void __iomem *)KSEG1ADDR(MIPS_CPC_BASE); + int i; + + for (i = 1; i < NUM_CORES; i++) { + writel(i << CPC_CL_OTHER_CORENUM_SHIFT, cpcbase + CPC_CL_OTHER); + writel(PWR_UP, cpcbase + CPC_CO_CMD); + } +} + +void secondary_cpu_init(void) +{ + void __iomem *sysc = (void __iomem *)KSEG1ADDR(SYSCTL_BASE); + u32 i, dual_core = 0, cpuready = 1, cpumask = 0x03; + ulong wait_tick; + struct cpulaunch_t *c; + + /* Copy LAUNCH wait code used by other VPEs */ + copy_launch_wait_code(); + + dual_core = readl(sysc + SYSCTL_CHIP_REV_ID_REG) & CPU_ID; + + if (dual_core) { + /* Bootup secondary core for MT7621A */ + cpumask = 0x0f; + + /* Make BootROM/TPL redirect Core1's bootup flow to our entry point */ + writel((uintptr_t)&_start, sysc + BOOT_SRAM_BASE_REG); + + bootup_secondary_core(); + } + + /* Join the coherent domain */ + join_coherent_domain(dual_core ? 2 : 1); + + /* Bootup Core0/VPE1 */ + boot_vpe1(); + + /* Wait for all CPU ready */ + wait_tick = get_timer(0) + WAIT_CPUS_TIMEOUT; + + while (time_before(get_timer(0), wait_tick)) { + /* CPU0 is obviously ready */ + for (i = 1; i < NUM_CPUS; i++) { + c = (struct cpulaunch_t *)(KSEG0ADDR(CPULAUNCH) + + (i << LOG2CPULAUNCH)); + + if (c->flags & LAUNCH_FREADY) + cpuready |= BIT(i); + } + + if ((cpuready & cpumask) == cpumask) + break; + } +} diff --git a/arch/mips/mach-mtmips/mt7621/spl/launch.h b/arch/mips/mach-mtmips/mt7621/spl/launch.h new file mode 100644 index 0000000000..f34250d605 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/spl/launch.h @@ -0,0 +1,52 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2022 MediaTek Inc. All rights reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#ifndef _LAUNCH_H_ +#define _LAUNCH_H_ + +#ifndef __ASSEMBLY__ + +struct cpulaunch_t { + unsigned long pc; + unsigned long gp; + unsigned long sp; + unsigned long a0; + unsigned long _pad[3]; /* pad to cache line size to avoid thrashing */ + unsigned long flags; +}; + +extern char launch_wait_code_start; +extern char launch_wait_code_end; + +void join_coherent_domain(int ncores); +void boot_vpe1(void); + +#else + +#define LAUNCH_PC 0 +#define LAUNCH_GP 4 +#define LAUNCH_SP 8 +#define LAUNCH_A0 12 +#define LAUNCH_FLAGS 28 + +#endif + +#define LOG2CPULAUNCH 5 + +#define LAUNCH_FREADY 1 +#define LAUNCH_FGO 2 +#define LAUNCH_FGONE 4 + +#define LAUNCH_WAITCODE 0x00000d00 +#define SCRLAUNCH 0x00000e00 +#define CPULAUNCH 0x00000f00 +#define NCPULAUNCH 8 + +/* Polling period in count cycles for secondary CPU's */ +#define LAUNCHPERIOD 10000 + +#endif /* _LAUNCH_H_ */ diff --git a/arch/mips/mach-mtmips/mt7621/spl/launch_ll.S b/arch/mips/mach-mtmips/mt7621/spl/launch_ll.S new file mode 100644 index 0000000000..55a8fff9af --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/spl/launch_ll.S @@ -0,0 +1,357 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2022 MediaTek Inc. All rights reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <asm/cm.h> +#include <asm/asm.h> +#include <asm/regdef.h> +#include <asm/cacheops.h> +#include <asm/mipsregs.h> +#include <asm/addrspace.h> +#include <asm/mipsmtregs.h> +#include "launch.h" + + .macro cache_loop curr, end, line_sz, op +10: cache \op, 0(\curr) + PTR_ADDU \curr, \curr, \line_sz + bne \curr, \end, 10b + .endm + + .set mt + +/* + * Join the coherent domain + * a0 = number of cores + */ +LEAF(join_coherent_domain) + /* + * Enable coherence and allow interventions from all other cores. + * (Write access enabled via GCR_ACCESS by core 0.) + */ + li t1, 1 + sll t1, a0 + addiu t1, -1 + + li t0, KSEG1ADDR(CONFIG_MIPS_CM_BASE) + sw t1, GCR_Cx_COHERENCE(t0) + ehb + + move t2, zero + +_next_coherent_core: + sll t1, t2, GCR_Cx_OTHER_CORENUM_SHIFT + sw t1, GCR_Cx_OTHER(t0) + +_busy_wait_coherent_core: + lw t1, GCR_CO_COHERENCE(t0) + beqz t1, _busy_wait_coherent_core + nop + + addiu t2, 1 + bne t2, a0, _next_coherent_core + nop + + jr ra + nop + END(join_coherent_domain) + +/* + * All VPEs other than VPE0 will go here. + */ +LEAF(launch_vpe_entry) + mfc0 t0, CP0_EBASE + and t0, t0, MIPS_EBASE_CPUNUM + + /* per-VPE cpulaunch_t */ + li a0, KSEG0ADDR(CPULAUNCH) + sll t1, t0, LOG2CPULAUNCH + addu a0, t1 + + /* Set CPU online flag */ + li t0, LAUNCH_FREADY + sw t0, LAUNCH_FLAGS(a0) + + /* Enable count interrupt in mask, but do not enable interrupts */ + mfc0 t0, CP0_STATUS + ori t0, STATUSF_IP7 + mtc0 t0, CP0_STATUS + + /* VPEs executing in wait code do not need a stack */ + li t9, KSEG0ADDR(LAUNCH_WAITCODE) + jr t9 + nop + END(launch_vpe_entry) + +/* + * This function will not be executed in place. + * It will be copied into memory, and VPEs other than VPE0 will be + * started to run into this in-memory function. + */ +LEAF(launch_wait_code) + .globl launch_wait_code_start +launch_wait_code_start: + + move t0, a0 + +start_poll: + /* Poll CPU go flag */ + mtc0 zero, CP0_COUNT + li t1, LAUNCHPERIOD + mtc0 t1, CP0_COMPARE + +time_wait: + /* Software wait */ + mfc0 t2, CP0_COUNT + subu t2, t1 + bltz t2, time_wait + nop + + /* Check the launch flag */ + lw t3, LAUNCH_FLAGS(t0) + and t3, LAUNCH_FGO + beqz t3, start_poll + nop + + /* Reset the counter and interrupts to give naive clients a chance */ + mfc0 t1, CP0_STATUS + ins t1, zero, STATUSB_IP7, 1 + mtc0 t1, CP0_STATUS + + mfc0 t1, CP0_COUNT + subu t1, 1 + mtc0 t1, CP0_COMPARE + + /* Jump to kernel */ + lw t9, LAUNCH_PC(t0) + lw gp, LAUNCH_GP(t0) + lw sp, LAUNCH_SP(t0) + lw a0, LAUNCH_A0(t0) + move a1, zero + move a2, zero + move a3, zero + ori t3, LAUNCH_FGONE + sw t3, LAUNCH_FLAGS(t0) + + jr t9 + nop + + .globl launch_wait_code_end +launch_wait_code_end: + END(launch_wait_code) + +/* + * Core1 will go here. + */ +LEAF(launch_core_entry) + /* Disable caches */ + bal mips_cache_disable + nop + + /* Initialize L1 cache only */ + li a0, CONFIG_SYS_ICACHE_SIZE + li a1, CONFIG_SYS_ICACHE_LINE_SIZE + li a2, CONFIG_SYS_DCACHE_SIZE + li a3, CONFIG_SYS_DCACHE_LINE_SIZE + + mtc0 zero, CP0_TAGLO + mtc0 zero, CP0_TAGLO, 2 + ehb + + /* + * Initialize the I-cache first, + */ + li t0, KSEG0 + addu t1, t0, a0 + /* clear tag to invalidate */ + cache_loop t0, t1, a1, INDEX_STORE_TAG_I +#ifdef CONFIG_SYS_MIPS_CACHE_INIT_RAM_LOAD + /* fill once, so data field parity is correct */ + PTR_LI t0, KSEG0 + cache_loop t0, t1, a1, FILL + /* invalidate again - prudent but not strictly necessary */ + PTR_LI t0, KSEG0 + cache_loop t0, t1, a1, INDEX_STORE_TAG_I +#endif + + /* + * then initialize D-cache. + */ + PTR_LI t0, KSEG0 + PTR_ADDU t1, t0, a2 + /* clear all tags */ + cache_loop t0, t1, a3, INDEX_STORE_TAG_D +#ifdef CONFIG_SYS_MIPS_CACHE_INIT_RAM_LOAD + /* load from each line (in cached space) */ + PTR_LI t0, KSEG0 +2: LONG_L zero, 0(t0) + PTR_ADDU t0, a3 + bne t0, t1, 2b + /* clear all tags */ + PTR_LI t0, KSEG0 + cache_loop t0, t1, a3, INDEX_STORE_TAG_D +#endif + + /* Set Cache Mode */ + mfc0 t0, CP0_CONFIG + li t1, CONF_CM_CACHABLE_COW + ins t0, t1, 0, 3 + mtc0 t0, CP0_CONFIG + + /* Join the coherent domain */ + li a0, 2 + bal join_coherent_domain + nop + + /* Bootup Core0/VPE1 */ + bal boot_vpe1 + nop + + b launch_vpe_entry + nop + END(launch_core_entry) + +/* + * Bootup VPE1. + * This subroutine must be executed from VPE0 with VPECONF0[MVP] already set. + */ +LEAF(boot_vpe1) + mfc0 t0, CP0_MVPCONF0 + + /* a0 = number of TCs - 1 */ + ext a0, t0, MVPCONF0_PTC_SHIFT, 8 + beqz a0, _vpe1_init_done + nop + + /* a1 = number of VPEs - 1 */ + ext a1, t0, MVPCONF0_PVPE_SHIFT, 4 + beqz a1, _vpe1_init_done + nop + + /* a2 = current TC No. */ + move a2, zero + + /* Enter VPE Configuration State */ + mfc0 t0, CP0_MVPCONTROL + or t0, MVPCONTROL_VPC + mtc0 t0, CP0_MVPCONTROL + ehb + +_next_tc: + /* Set the TC number to be used on MTTR and MFTR instructions */ + mfc0 t0, CP0_VPECONTROL + ins t0, a2, 0, 8 + mtc0 t0, CP0_VPECONTROL + ehb + + /* TC0 is already bound */ + beqz a2, _next_vpe + nop + + /* Halt current TC */ + li t0, TCHALT_H + mttc0 t0, CP0_TCHALT + ehb + + /* If there is spare TC, bind it to the last VPE (VPE[a1]) */ + slt t1, a1, a2 + bnez t1, _vpe_bind_tc + move t1, a1 + + /* Set Exclusive TC for active TC */ + mftc0 t0, CP0_VPECONF0 + ins t0, a2, VPECONF0_XTC_SHIFT, 8 + mttc0 t0, CP0_VPECONF0 + + move t1, a2 +_vpe_bind_tc: + /* Bind TC to a VPE */ + mftc0 t0, CP0_TCBIND + ins t0, t1, TCBIND_CURVPE_SHIFT, 4 + mttc0 t0, CP0_TCBIND + + /* + * Set up CP0_TCSTATUS register: + * Disable Coprocessor Usable bits + * Disable MDMX/DSP ASE + * Clear Dirty TC + * not dynamically allocatable + * not allocated + * Kernel mode + * interrupt exempt + * ASID 0 + */ + li t0, TCSTATUS_IXMT + mttc0 t0, CP0_TCSTATUS + +_next_vpe: + slt t1, a1, a2 + bnez t1, _done_vpe # No more VPEs + nop + + /* Disable TC multi-threading */ + mftc0 t0, CP0_VPECONTROL + ins t0, zero, VPECONTROL_TE_SHIFT, 1 + mttc0 t0, CP0_VPECONTROL + + /* Skip following configuration for TC0 */ + beqz a2, _done_vpe + nop + + /* Deactivate VPE, set Master VPE */ + mftc0 t0, CP0_VPECONF0 + ins t0, zero, VPECONF0_VPA_SHIFT, 1 + or t0, VPECONF0_MVP + mttc0 t0, CP0_VPECONF0 + + mfc0 t0, CP0_STATUS + mttc0 t0, CP0_STATUS + + mttc0 zero, CP0_EPC + mttc0 zero, CP0_CAUSE + + mfc0 t0, CP0_CONFIG + mttc0 t0, CP0_CONFIG + + /* + * VPE1 of each core can execute cached as its L1 I$ has already + * been initialized. + * and the L2$ has been initialized or "disabled" via CCA override. + */ + PTR_LA t0, _start + mttc0 t0, CP0_TCRESTART + + /* Unset Interrupt Exempt, set Activate Thread */ + mftc0 t0, CP0_TCSTATUS + ins t0, zero, TCSTATUS_IXMT_SHIFT, 1 + ori t0, TCSTATUS_A + mttc0 t0, CP0_TCSTATUS + + /* Resume TC */ + mttc0 zero, CP0_TCHALT + + /* Activate VPE */ + mftc0 t0, CP0_VPECONF0 + ori t0, VPECONF0_VPA + mttc0 t0, CP0_VPECONF0 + +_done_vpe: + addu a2, 1 + sltu t0, a0, a2 + beqz t0, _next_tc + nop + + mfc0 t0, CP0_MVPCONTROL + /* Enable all activated VPE to execute */ + ori t0, MVPCONTROL_EVP + /* Exit VPE Configuration State */ + ins t0, zero, MVPCONTROL_VPC_SHIFT, 1 + mtc0 t0, CP0_MVPCONTROL + ehb + +_vpe1_init_done: + jr ra + nop + END(boot_vpe1) diff --git a/arch/mips/mach-mtmips/mt7621/spl/serial.c b/arch/mips/mach-mtmips/mt7621/spl/serial.c new file mode 100644 index 0000000000..5cf093a078 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/spl/serial.c @@ -0,0 +1,24 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 MediaTek Inc. All rights reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <asm/io.h> +#include "../mt7621.h" + +void mtmips_spl_serial_init(void) +{ +#ifdef CONFIG_SPL_SERIAL + void __iomem *base = ioremap_nocache(SYSCTL_BASE, SYSCTL_SIZE); + +#if CONFIG_CONS_INDEX == 1 + clrbits_32(base + SYSCTL_GPIOMODE_REG, UART1_MODE); +#elif CONFIG_CONS_INDEX == 2 + clrbits_32(base + SYSCTL_GPIOMODE_REG, UART2_MODE_M); +#elif CONFIG_CONS_INDEX == 3 + clrbits_32(base + SYSCTL_GPIOMODE_REG, UART3_MODE_M); +#endif /* CONFIG_CONS_INDEX */ +#endif /* CONFIG_SPL_SERIAL */ +} diff --git a/arch/mips/mach-mtmips/mt7621/spl/spl.c b/arch/mips/mach-mtmips/mt7621/spl/spl.c new file mode 100644 index 0000000000..71d01aa7f5 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/spl/spl.c @@ -0,0 +1,95 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 MediaTek Inc. All rights reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <spl.h> +#include <init.h> +#include <image.h> +#include <vsprintf.h> +#include <malloc.h> +#include <asm/io.h> +#include <asm/sections.h> +#include <asm/addrspace.h> +#include <asm/byteorder.h> +#include <asm/global_data.h> +#include <linux/sizes.h> +#include <mach/serial.h> +#include "../mt7621.h" +#include "dram.h" + +DECLARE_GLOBAL_DATA_PTR; + +struct tpl_info { + u32 magic; + u32 size; +}; + +void set_timer_freq_simple(void) +{ + u32 div = get_xtal_mhz(); + + /* Round down cpu freq */ + gd->arch.timer_freq = rounddown(CONFIG_MT7621_CPU_FREQ, div) * 500000; +} + +void __noreturn board_init_f(ulong dummy) +{ + spl_init(); + +#ifdef CONFIG_SPL_SERIAL + /* + * mtmips_spl_serial_init() is useful if debug uart is enabled, + * or DM based serial is not enabled. + */ + mtmips_spl_serial_init(); + preloader_console_init(); +#endif + + board_init_r(NULL, 0); +} + +void board_boot_order(u32 *spl_boot_list) +{ +#ifdef CONFIG_MT7621_BOOT_FROM_NAND + spl_boot_list[0] = BOOT_DEVICE_NAND; +#else + spl_boot_list[0] = BOOT_DEVICE_NOR; +#endif +} + +unsigned long spl_nor_get_uboot_base(void) +{ + const struct tpl_info *tpli; + const image_header_t *hdr; + u32 addr; + + addr = FLASH_MMAP_BASE + TPL_INFO_OFFSET; + tpli = (const struct tpl_info *)KSEG1ADDR(addr); + + if (tpli->magic == TPL_INFO_MAGIC) { + addr = FLASH_MMAP_BASE + tpli->size; + hdr = (const image_header_t *)KSEG1ADDR(addr); + + if (image_get_magic(hdr) == IH_MAGIC) { + addr += sizeof(*hdr) + image_get_size(hdr); + return KSEG1ADDR(addr); + } + } + + panic("Unable to locate SPL payload\n"); + return 0; +} + +uint32_t spl_nand_get_uboot_raw_page(void) +{ + const struct stage_header *sh = (const struct stage_header *)&_start; + u32 addr; + + addr = image_get_header_size() + be32_to_cpu(sh->stage_size); + addr = ALIGN(addr, SZ_4K); + + return addr; +} diff --git a/arch/mips/mach-mtmips/mt7621/spl/start.S b/arch/mips/mach-mtmips/mt7621/spl/start.S new file mode 100644 index 0000000000..3cad3567e7 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/spl/start.S @@ -0,0 +1,226 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2022 MediaTek Inc. All rights reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <asm-offsets.h> +#include <config.h> +#include <asm/asm.h> +#include <asm/regdef.h> +#include <asm/mipsregs.h> +#include <asm/cacheops.h> +#include <asm/addrspace.h> +#include <asm/mipsmtregs.h> +#include <asm/cm.h> +#include "../mt7621.h" +#include "dram.h" + +#ifndef CONFIG_SYS_INIT_SP_ADDR +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + \ + CONFIG_SYS_INIT_SP_OFFSET) +#endif + +#define SP_ADDR_TEMP 0xbe10dff0 + + .macro init_wr sel + MTC0 zero, CP0_WATCHLO,\sel + mtc0 t1, CP0_WATCHHI,\sel + .endm + + .macro setup_stack_gd + li t0, -16 + PTR_LI t1, CONFIG_SYS_INIT_SP_ADDR + and sp, t1, t0 # force 16 byte alignment + PTR_SUBU \ + sp, sp, GD_SIZE # reserve space for gd + and sp, sp, t0 # force 16 byte alignment + move k0, sp # save gd pointer +#if CONFIG_VAL(SYS_MALLOC_F_LEN) && \ + !CONFIG_IS_ENABLED(INIT_STACK_WITHOUT_MALLOC_F) + li t2, CONFIG_VAL(SYS_MALLOC_F_LEN) + PTR_SUBU \ + sp, sp, t2 # reserve space for early malloc + and sp, sp, t0 # force 16 byte alignment +#endif + move fp, sp + + /* Clear gd */ + move t0, k0 +1: + PTR_S zero, 0(t0) + PTR_ADDIU t0, PTRSIZE + blt t0, t1, 1b + nop + +#if CONFIG_VAL(SYS_MALLOC_F_LEN) && \ + !CONFIG_IS_ENABLED(INIT_STACK_WITHOUT_MALLOC_F) + PTR_S sp, GD_MALLOC_BASE(k0) # gd->malloc_base offset +#endif + .endm + + .set noreorder + +ENTRY(_start) + b 1f + mtc0 zero, CP0_COUNT + + /* Stage header required by BootROM */ + .org 0x8 + .word 0 # ep, filled by mkimage + .word 0 # stage_size, filled by mkimage + .word 0 # has_stage2 + .word 0 # next_ep + .word 0 # next_size + .word 0 # next_offset + +1: + /* Init CP0 Status */ + mfc0 t0, CP0_STATUS + and t0, ST0_IMPL + or t0, ST0_BEV | ST0_ERL + mtc0 t0, CP0_STATUS + ehb + + /* Clear Watch Status bits and disable watch exceptions */ + li t1, 0x7 # Clear I, R and W conditions + init_wr 0 + init_wr 1 + init_wr 2 + init_wr 3 + + /* Clear WP, IV and SW interrupts */ + mtc0 zero, CP0_CAUSE + + /* Clear timer interrupt (CP0_COUNT cleared on branch to 'reset') */ + mtc0 zero, CP0_COMPARE + + /* VPE1 goes to wait code directly */ + mfc0 t0, CP0_TCBIND + andi t0, TCBIND_CURVPE + bnez t0, launch_vpe_entry + nop + + /* Core1 goes to specific launch entry */ + PTR_LI t0, KSEG1ADDR(CONFIG_MIPS_CM_BASE) + lw t1, GCR_Cx_ID(t0) + bnez t1, launch_core_entry + nop + + /* MT7530 reset */ + li t0, KSEG1ADDR(SYSCTL_BASE) + lw t1, SYSCTL_RSTCTL_REG(t0) + ori t1, MCM_RST + sw t1, SYSCTL_RSTCTL_REG(t0) + + /* Disable DMA route for PSE SRAM set by BootROM */ + PTR_LI t0, KSEG1ADDR(DMA_CFG_ARB_BASE) + sw zero, DMA_ROUTE_REG(t0) + + /* Set CPU clock to 500MHz (Required if boot from NAND) */ + li t0, KSEG1ADDR(SYSCTL_BASE) + lw t1, SYSCTL_CLKCFG0_REG(t0) + ins t1, zero, 30, 2 # CPU_CLK_SEL + sw t1, SYSCTL_CLKCFG0_REG(t0) + + /* Set CPU clock divider to 1/1 */ + li t0, KSEG1ADDR(RBUS_BASE) + li t1, 0x101 + sw t1, RBUS_DYN_CFG0_REG(t0) + + /* (Re-)initialize the SRAM */ + bal mips_sram_init + nop + + /* Set up temporary stack */ + li sp, SP_ADDR_TEMP + + /* Setup full CPS */ + bal mips_cm_map + nop + + bal mt7621_cps_init + nop + + /* Prepare for CPU/DDR initialization binary blob */ + bal prepare_stage_bin + nop + + /* Call CPU/DDR initialization binary blob */ + li t9, STAGE_LOAD_ADDR + jalr t9 + nop + + /* Switch CPU PLL source */ + li t0, KSEG1ADDR(SYSCTL_BASE) + lw t1, SYSCTL_CLKCFG0_REG(t0) + li t2, 1 + ins t1, t2, CPU_CLK_SEL_S, 2 + sw t1, SYSCTL_CLKCFG0_REG(t0) + + /* + * Currently SPL is running on locked L2 cache (on KSEG0). + * To reset the entire cache, we have to writeback SPL to DRAM first. + * Cache flush won't work here. Use memcpy instead. + */ + + la a0, __text_start + move a1, a0 + la a2, __image_copy_end + sub a2, a2, a1 + li a3, 5 + ins a0, a3, 29, 3 # convert to KSEG1 + + bal memcpy + nop + + /* Disable caches */ + bal mips_cache_disable + nop + + /* Reset caches */ + bal mips_cache_reset + nop + + /* Disable SRAM */ + li t0, KSEG1ADDR(FE_BASE) + li t1, FE_PSE_RESET + sw t1, FE_RST_GLO_REG(t0) + + /* Clear the .bss section */ + la a0, __bss_start + la a1, __bss_end +1: sw zero, 0(a0) + addiu a0, 4 + ble a0, a1, 1b + nop + + /* Set up initial stack and global data */ + setup_stack_gd + +#if CONFIG_IS_ENABLED(INIT_STACK_WITHOUT_MALLOC_F) + /* Set malloc base */ + li t0, (CONFIG_SYS_INIT_SP_ADDR + 15) & (~15) + PTR_S t0, GD_MALLOC_BASE(k0) # gd->malloc_base offset +#endif + +#if defined(CONFIG_DEBUG_UART) && defined(CONFIG_SPL_SERIAL) + /* Earliest point to set up debug uart */ + bal debug_uart_init + nop +#endif + + /* Setup timer */ + bal set_timer_freq_simple + nop + + /* Bootup secondary CPUs */ + bal secondary_cpu_init + nop + + move a0, zero # a0 <-- boot_flags = 0 + bal board_init_f + move ra, zero + + END(_start) diff --git a/arch/mips/mach-mtmips/mt7621/sram_init.S b/arch/mips/mach-mtmips/mt7621/sram_init.S new file mode 100644 index 0000000000..74ddd6bcd7 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/sram_init.S @@ -0,0 +1,22 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 MediaTek Inc. All rights reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <asm/addrspace.h> +#include <asm/asm.h> +#include <asm/regdef.h> +#include "mt7621.h" + +LEAF(mips_sram_init) + li t0, KSEG1ADDR(FE_BASE) + li t1, FE_PSE_RESET + sw t1, FE_RST_GLO_REG(t0) + + li t1, (FE_PSE_RAM | FE_PSE_MEM_EN) + sw t1, FE_RST_GLO_REG(t0) + + jr ra + END(mips_sram_init) diff --git a/arch/mips/mach-mtmips/mt7621/tpl/Makefile b/arch/mips/mach-mtmips/mt7621/tpl/Makefile new file mode 100644 index 0000000000..471ad74249 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/tpl/Makefile @@ -0,0 +1,4 @@ + +extra-y += start.o + +obj-y += tpl.o diff --git a/arch/mips/mach-mtmips/mt7621/tpl/start.S b/arch/mips/mach-mtmips/mt7621/tpl/start.S new file mode 100644 index 0000000000..19b09f7251 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/tpl/start.S @@ -0,0 +1,161 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2022 MediaTek Inc. All rights reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <asm-offsets.h> +#include <config.h> +#include <asm/asm.h> +#include <asm/regdef.h> +#include <asm/addrspace.h> +#include <asm/mipsregs.h> +#include <asm/cm.h> +#include "../mt7621.h" + +#define SP_ADDR_TEMP 0xbe10dff0 + + .set noreorder + + .macro init_wr sel + MTC0 zero, CP0_WATCHLO,\sel + mtc0 t1, CP0_WATCHHI,\sel + .endm + + .macro uhi_mips_exception + move k0, t9 # preserve t9 in k0 + move k1, a0 # preserve a0 in k1 + li t9, 15 # UHI exception operation + li a0, 0 # Use hard register context + sdbbp 1 # Invoke UHI operation + .endm + +ENTRY(_start) + b reset + mtc0 zero, CP0_COUNT + + /* + * Store TPL size here. + * This will be used by SPL to locate u-boot payload. + */ + .org TPL_INFO_OFFSET + .word TPL_INFO_MAGIC + .word __image_copy_len + + /* Exception vector */ + .org 0x200 + /* TLB refill, 32 bit task */ + uhi_mips_exception + + .org 0x280 + /* XTLB refill, 64 bit task */ + uhi_mips_exception + + .org 0x300 + /* Cache error exception */ + uhi_mips_exception + + .org 0x380 + /* General exception */ + uhi_mips_exception + + .org 0x400 + /* Catch interrupt exceptions */ + uhi_mips_exception + + .org 0x480 + /* EJTAG debug exception */ +1: b 1b + nop + + .org 0x500 + +reset: + /* Set KSEG0 to Uncached */ + mfc0 t0, CP0_CONFIG + ins t0, zero, 0, 3 + ori t0, t0, CONF_CM_UNCACHED + mtc0 t0, CP0_CONFIG + ehb + + /* Check for CPU number */ + mfc0 t0, CP0_EBASE + and t0, t0, MIPS_EBASE_CPUNUM + beqz t0, 1f + nop + + /* Secondary core goes to specified SPL entry address */ + li t0, KSEG1ADDR(SYSCTL_BASE) + lw t0, BOOT_SRAM_BASE_REG(t0) + jr t0 + nop + + /* Init CP0 Status */ +1: mfc0 t0, CP0_STATUS + and t0, ST0_IMPL + or t0, ST0_BEV | ST0_ERL + mtc0 t0, CP0_STATUS + nop + + /* Clear Watch Status bits and disable watch exceptions */ + li t1, 0x7 # Clear I, R and W conditions + init_wr 0 + init_wr 1 + init_wr 2 + init_wr 3 + + /* Clear WP, IV and SW interrupts */ + mtc0 zero, CP0_CAUSE + + /* Clear timer interrupt (CP0_COUNT cleared on branch to 'reset') */ + mtc0 zero, CP0_COMPARE + + /* Setup basic CPS */ + bal mips_cm_map + nop + + li t0, KSEG1ADDR(CONFIG_MIPS_CM_BASE) + li t1, GCR_REG0_BASE_VALUE + sw t1, GCR_REG0_BASE(t0) + + li t1, ((GCR_REG0_MASK_VALUE << GCR_REGn_MASK_ADDRMASK_SHIFT) | \ + GCR_REGn_MASK_CMTGT_IOCU0) + sw t1, GCR_REG0_MASK(t0) + + lw t1, GCR_BASE(t0) + ins t1, zero, 0, 2 # CM_DEFAULT_TARGET + sw t1, GCR_BASE(t0) + + lw t1, GCR_CONTROL(t0) + li t2, GCR_CONTROL_SYNCCTL + or t1, t1, t2 + sw t1, GCR_CONTROL(t0) + + /* Increase SPI frequency */ + li t0, KSEG1ADDR(SPI_BASE) + li t1, 5 + sw t1, SPI_SPACE_REG(t0) + + /* Set CPU clock to 500MHz */ + li t0, KSEG1ADDR(SYSCTL_BASE) + lw t1, SYSCTL_CLKCFG0_REG(t0) + ins t1, zero, 30, 2 # CPU_CLK_SEL + sw t1, SYSCTL_CLKCFG0_REG(t0) + + /* Set CPU clock divider to 1/1 */ + li t0, KSEG1ADDR(RBUS_BASE) + li t1, 0x101 + sw t1, RBUS_DYN_CFG0_REG(t0) + + /* Initialize the SRAM */ + bal mips_sram_init + nop + + /* Set up initial stack */ + li sp, SP_ADDR_TEMP + + bal tpl_main + nop + + END(_start) diff --git a/arch/mips/mach-mtmips/mt7621/tpl/tpl.c b/arch/mips/mach-mtmips/mt7621/tpl/tpl.c new file mode 100644 index 0000000000..77bcf0ddf0 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/tpl/tpl.c @@ -0,0 +1,146 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 MediaTek Inc. All rights reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <image.h> +#include <asm/sections.h> +#include <asm/cacheops.h> +#include <asm/mipsregs.h> +#include <asm/cm.h> + +#define INDEX_STORE_DATA_SD 0x0f + +typedef void __noreturn (*image_entry_noargs_t)(void); + +static inline void ehb(void) +{ + __asm__ __volatile__ ("ehb"); +} + +/* + * Lock L2 cache and fill data + * Assume that data is 4-byte aligned and start_addr/size is 32-byte aligned + */ +static void fill_lock_l2cache(uintptr_t dataptr, ulong start_addr, ulong size) +{ + ulong slsize = CONFIG_SYS_DCACHE_LINE_SIZE; + ulong end_addr = start_addr + size; + const u32 *data = (u32 *)dataptr; + ulong i, addr; + u32 val; + + /* Clear WSC & SPR bit in ErrCtl */ + val = read_c0_ecc(); + val &= 0xcfffffff; + write_c0_ecc(val); + ehb(); + + for (addr = start_addr; addr < end_addr; addr += slsize) { + /* Set STagLo to lock cache line */ + write_c0_staglo((addr & 0x1ffff800) | 0xa0); + mips_cache(INDEX_STORE_TAG_SD, (void *)addr); + + /* Fill data */ + for (i = 0; i < slsize; i += 8) { + val = *data++; + __write_32bit_c0_register($28, 5, val); /* sdtaglo */ + val = *data++; + __write_32bit_c0_register($29, 5, val); /* sdtaghi */ + mips_cache(INDEX_STORE_DATA_SD, (void *)(addr + i)); + } + } +} + +/* A simple function to initialize MT7621's cache */ +static void mt7621_cache_init(void) +{ + void __iomem *cm_base = (void *)KSEG1ADDR(CONFIG_MIPS_CM_BASE); + ulong lsize = CONFIG_SYS_DCACHE_LINE_SIZE; + ulong addr; + u32 val; + + /* Enable CCA override. Set to uncached */ + val = readl(cm_base + GCR_BASE); + val &= ~CCA_DEFAULT_OVR_MASK; + val |= CCA_DEFAULT_OVREN | (2 << CCA_DEFAULT_OVR_SHIFT); + writel(val, cm_base + GCR_BASE); + + /* Initialize L1 I-Cache */ + write_c0_taglo(0); + write_c0_taghi(0); + + for (addr = 0; addr < CONFIG_SYS_ICACHE_SIZE; addr += lsize) + mips_cache(INDEX_STORE_TAG_I, (void *)addr); + + /* Initialize L1 D-Cache */ + write_c0_dtaglo(0); + __write_32bit_c0_register($29, 2, 0); /* dtaghi */ + + for (addr = 0; addr < CONFIG_SYS_DCACHE_SIZE; addr += lsize) + mips_cache(INDEX_STORE_TAG_D, (void *)addr); + + /* Initialize L2 Cache */ + write_c0_staglo(0); + __write_32bit_c0_register($29, 4, 0); /* staghi */ + + for (addr = 0; addr < (256 << 10); addr += lsize) + mips_cache(INDEX_STORE_TAG_SD, (void *)addr); + + /* Dsiable CCA override */ + val = readl(cm_base + GCR_BASE); + val &= ~(CCA_DEFAULT_OVR_MASK | CCA_DEFAULT_OVREN); + writel(val, cm_base + GCR_BASE); + + /* Set KSEG0 to non-coherent cached (important!) */ + val = read_c0_config(); + val &= ~CONF_CM_CMASK; + val |= CONF_CM_CACHABLE_NONCOHERENT; + write_c0_config(val); + ehb(); + + /* Again, invalidate L1 D-Cache */ + for (addr = 0; addr < CONFIG_SYS_DCACHE_SIZE; addr += lsize) + mips_cache(INDEX_WRITEBACK_INV_D, (void *)addr); + + /* Invalidate L1 I-Cache */ + for (addr = 0; addr < CONFIG_SYS_ICACHE_SIZE; addr += lsize) + mips_cache(INDEX_INVALIDATE_I, (void *)addr); + + /* Disable L2 cache bypass */ + val = read_c0_config2(); + val &= ~MIPS_CONF_IMPL; + write_c0_config2(val); + ehb(); +} + +void __noreturn tpl_main(void) +{ + const image_header_t *hdr = (const image_header_t *)__image_copy_end; + image_entry_noargs_t image_entry; + u32 loadaddr, size; + uintptr_t data; + + /* Initialize the cache first */ + mt7621_cache_init(); + + if (image_get_magic(hdr) != IH_MAGIC) + goto failed; + + loadaddr = image_get_load(hdr); + size = image_get_size(hdr); + image_entry = (image_entry_noargs_t)image_get_ep(hdr); + + /* Load TPL image to L2 cache */ + data = (uintptr_t)__image_copy_end + sizeof(struct image_header); + fill_lock_l2cache(data, loadaddr, size); + + /* Jump to SPL */ + image_entry(); + +failed: + for (;;) + ; +} diff --git a/include/configs/mt7621.h b/include/configs/mt7621.h new file mode 100644 index 0000000000..580d5fde0c --- /dev/null +++ b/include/configs/mt7621.h @@ -0,0 +1,67 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2022 MediaTek Inc. All rights reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#ifndef __CONFIG_MT7621_H +#define __CONFIG_MT7621_H + +#define CONFIG_SYS_HZ 1000 +#define CONFIG_SYS_MIPS_TIMER_FREQ 440000000 + +#define CONFIG_SYS_BOOTPARAMS_LEN 0x20000 + +#define CONFIG_SYS_SDRAM_BASE 0x80000000 + +#define CONFIG_VERY_BIG_RAM +#define CONFIG_MAX_MEM_MAPPED 0x1c000000 + +#define CONFIG_SYS_INIT_SP_OFFSET 0x800000 + +#define CONFIG_SYS_BOOTM_LEN 0x2000000 + +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_CBSIZE 1024 + +#define CONFIG_SYS_NONCACHED_MEMORY 0x100000 + +/* MMC */ +#define MMC_SUPPORTS_TUNING + +/* NAND */ +#define CONFIG_SYS_MAX_NAND_DEVICE 1 + +/* Serial SPL */ +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_SERIAL) +#define CONFIG_SYS_NS16550_MEM32 +#define CONFIG_SYS_NS16550_CLK 50000000 +#define CONFIG_SYS_NS16550_REG_SIZE -4 +#define CONFIG_SYS_NS16550_COM1 0xbe000c00 +#endif + +/* Serial common */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, \ + 230400, 460800, 921600 } + +/* SPL */ +#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE + +#ifdef CONFIG_TPL_BUILD +#define CONFIG_SPL_START_S_PATH "arch/mips/mach-mtmips/mt7621/tpl" +/* .bss will not be used by TPL */ +#define CONFIG_SPL_BSS_START_ADDR 0x80000000 +#define CONFIG_SPL_BSS_MAX_SIZE 0 +#else +#define CONFIG_SPL_START_S_PATH "arch/mips/mach-mtmips/mt7621/spl" +#define CONFIG_SPL_BSS_START_ADDR 0x80140000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 +#define CONFIG_SPL_MAX_SIZE 0x30000 +#endif + +/* Dummy value */ +#define CONFIG_SYS_UBOOT_BASE 0 +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0 + +#endif /* __CONFIG_MT7621_H */
On 16.05.22 04:42, Weijie Gao wrote:
This patch adds support for MediaTek MT7621 SoC. All files are dedicated for u-boot.
The default build target is u-boot-mt7621.bin.
The specification of this chip: https://www.mediatek.com/products/homenetworking/mt7621
Signed-off-by: Weijie Gao weijie.gao@mediatek.com
v5 changes: Fix dram binary blob loading procedure Adjust mt7621.dtsi, clkctrl moved under sysc, pinctrl default states removed v4 changes: Add full support for booting from flash (SPL/TPL support) Boot all cores/VPEs Use binman to generate final binary Use binman to embed external binary blob v3 changes: Update clock name for mt7621.dtsi due to clk driver changed v2 changes: Add a kconfig for max supported ram size Remove network configs from default config file
arch/mips/dts/mt7621-u-boot.dtsi | 111 ++++++ arch/mips/dts/mt7621.dtsi | 349 ++++++++++++++++++ arch/mips/mach-mtmips/Kconfig | 49 ++- arch/mips/mach-mtmips/Makefile | 4 + arch/mips/mach-mtmips/cpu.c | 2 +- arch/mips/mach-mtmips/mt7621/Kconfig | 95 +++++ arch/mips/mach-mtmips/mt7621/Makefile | 14 + arch/mips/mach-mtmips/mt7621/init.c | 229 ++++++++++++ arch/mips/mach-mtmips/mt7621/mt7621.h | 229 ++++++++++++ arch/mips/mach-mtmips/mt7621/serial.c | 23 ++ arch/mips/mach-mtmips/mt7621/spl/Makefile | 9 + arch/mips/mach-mtmips/mt7621/spl/cps.c | 152 ++++++++ arch/mips/mach-mtmips/mt7621/spl/dram.c | 155 ++++++++ arch/mips/mach-mtmips/mt7621/spl/dram.h | 39 ++ arch/mips/mach-mtmips/mt7621/spl/launch.c | 100 ++++++ arch/mips/mach-mtmips/mt7621/spl/launch.h | 52 +++ arch/mips/mach-mtmips/mt7621/spl/launch_ll.S | 357 +++++++++++++++++++ arch/mips/mach-mtmips/mt7621/spl/serial.c | 24 ++ arch/mips/mach-mtmips/mt7621/spl/spl.c | 95 +++++ arch/mips/mach-mtmips/mt7621/spl/start.S | 226 ++++++++++++ arch/mips/mach-mtmips/mt7621/sram_init.S | 22 ++ arch/mips/mach-mtmips/mt7621/tpl/Makefile | 4 + arch/mips/mach-mtmips/mt7621/tpl/start.S | 161 +++++++++ arch/mips/mach-mtmips/mt7621/tpl/tpl.c | 146 ++++++++ include/configs/mt7621.h | 67 ++++ 25 files changed, 2708 insertions(+), 6 deletions(-) create mode 100644 arch/mips/dts/mt7621-u-boot.dtsi create mode 100644 arch/mips/dts/mt7621.dtsi create mode 100644 arch/mips/mach-mtmips/mt7621/Kconfig create mode 100644 arch/mips/mach-mtmips/mt7621/Makefile create mode 100644 arch/mips/mach-mtmips/mt7621/init.c create mode 100644 arch/mips/mach-mtmips/mt7621/mt7621.h create mode 100644 arch/mips/mach-mtmips/mt7621/serial.c create mode 100644 arch/mips/mach-mtmips/mt7621/spl/Makefile create mode 100644 arch/mips/mach-mtmips/mt7621/spl/cps.c create mode 100644 arch/mips/mach-mtmips/mt7621/spl/dram.c create mode 100644 arch/mips/mach-mtmips/mt7621/spl/dram.h create mode 100644 arch/mips/mach-mtmips/mt7621/spl/launch.c create mode 100644 arch/mips/mach-mtmips/mt7621/spl/launch.h create mode 100644 arch/mips/mach-mtmips/mt7621/spl/launch_ll.S create mode 100644 arch/mips/mach-mtmips/mt7621/spl/serial.c create mode 100644 arch/mips/mach-mtmips/mt7621/spl/spl.c create mode 100644 arch/mips/mach-mtmips/mt7621/spl/start.S create mode 100644 arch/mips/mach-mtmips/mt7621/sram_init.S create mode 100644 arch/mips/mach-mtmips/mt7621/tpl/Makefile create mode 100644 arch/mips/mach-mtmips/mt7621/tpl/start.S create mode 100644 arch/mips/mach-mtmips/mt7621/tpl/tpl.c create mode 100644 include/configs/mt7621.h
Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
some nits below
diff --git a/arch/mips/dts/mt7621-u-boot.dtsi b/arch/mips/dts/mt7621-u-boot.dtsi new file mode 100644 index 0000000000..c5a8aa357f --- /dev/null +++ b/arch/mips/dts/mt7621-u-boot.dtsi @@ -0,0 +1,111 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
- Copyright (C) 2022 MediaTek Inc. All rights reserved.
- Author: Weijie Gao weijie.gao@mediatek.com
+#include <linux/stringify.h>
- binman: binman {
multiple-images;
+&sysc {
- u-boot,dm-pre-reloc;
+&reboot {
+&clkctrl {
+&rstctrl {
+&pinctrl {
+&uart0 {
+&uart1 {
+&uart2 {
+&binman {
- u-boot-spl-ddr {
align = <4>;
align-size = <4>;
filename = "u-boot-spl-ddr.bin";
pad-byte = <0xff>;
u-boot-spl {
align-end = <4>;
filename = "u-boot-spl.bin";
stage_bin {
filename = "mt7621_stage_sram.bin";
type = "blob-ext";
- spl-img {
filename = "u-boot-spl-ddr.img";
mkimage {
args = "-T", "mtk_image", "-n", "mt7621=1",
"-a", __stringify(CONFIG_SPL_TEXT_BASE),
"-e", __stringify(CONFIG_SPL_TEXT_BASE);
+#else
args = "-A", "mips", "-T", "standalone", "-O", "u-boot",
"-C", "none", "-n", "MT7621 U-Boot SPL",
blob {
- mt7621-uboot {
filename = "u-boot-mt7621.bin";
pad-byte = <0xff>;
+#ifndef CONFIG_MT7621_BOOT_FROM_NAND
u-boot-tpl {
align-end = <4>;
filename = "u-boot-tpl.bin";
spl {
align-end = <0x1000>;
type = "blob";
u-boot {
filename = "u-boot-lzma.img";
type = "blob";
+}; diff --git a/arch/mips/dts/mt7621.dtsi b/arch/mips/dts/mt7621.dtsi new file mode 100644 index 0000000000..0f057dfe1b --- /dev/null +++ b/arch/mips/dts/mt7621.dtsi @@ -0,0 +1,349 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+#include <dt-bindings/clock/mt7621-clk.h> +#include <dt-bindings/reset/mt7621-reset.h> +#include <dt-bindings/phy/phy.h>
- #address-cells = <1>;
- #size-cells = <1>;
- compatible = "mediatek,mt7621-soc";
- cpus {
#size-cells = <0>;
cpu@0 {
device_type = "cpu";
compatible = "mips,mips1004Kc";
reg = <0>;
cpu@1 {
reg = <1>;
- clk48m: clk48m@0 {
shouldn't a @XXX be always paired with a "reg = <XXX>" respectively shouldn't it be omitted without a "reg"?
compatible = "fixed-clock";
clock-frequency = <48000000>;
#clock-cells = <0>;
- clk50m: clk50m@0 {
clock-frequency = <50000000>;
#clock-cells = <0>;
- sysc: sysctrl@1e000000 {
compatible = "mediatek,mt7621-sysc", "syscon";
reg = <0x1e000000 0x100>;
clkctrl: clock-controller@1e000030 {
compatible = "mediatek,mt7621-clk";
mediatek,memc = <&memc>;
#clock-cells = <1>;
- rstctrl: reset-controller@1e000034 {
compatible = "mediatek,mtmips-reset";
reg = <0x1e000034 0x4>;
#reset-cells = <1>;
- reboot: resetctl-reboot {
compatible = "resetctl-reboot";
resets = <&rstctrl RST_SYS>;
reset-names = "sysreset";
- memc: memctrl@1e005000 {
compatible = "mediatek,mt7621-memc", "syscon";
reg = <0x1e005000 0x1000>;
- pinctrl: pinctrl@1e000060 {
compatible = "mediatek,mt7621-pinctrl";
reg = <0x1e000048 0x30>;
pinctrl-names = "default";
pinctrl-0 = <&state_default>;
state_default: pin_state {
uart1_pins: uart1_pins {
groups = "uart1";
function = "uart";
uart2_pins: uart2_pins {
groups = "uart2";
function = "uart";
uart3_pins: uart3_pins {
groups = "uart3";
function = "uart";
sdxc_pins: sdxc_pins {
groups = "sdxc";
function = "sdxc";
spi_pins: spi_pins {
groups = "spi";
function = "spi";
eth_pins: eth_pins {
mdio_pins {
groups = "mdio";
function = "mdio";
rgmii1_pins {
groups = "rgmii1";
function = "rgmii";
esw_pins {
groups = "esw int";
function = "esw int";
mdio_pconf {
groups = "mdio";
drive-strength = <2>;
- watchdog: watchdog@1e000100 {
compatible = "mediatek,mt7621-wdt";
reg = <0x1e000100 0x40>;
resets = <&rstctrl RST_TIMER>;
reset-names = "wdt";
status = "disabled";
- gpio: gpio@1e000600 {
#size-cells = <0>;
compatible = "mtk,mt7621-gpio";
reg = <0x1e000600 0x100>;
resets = <&rstctrl RST_PIO>;
reset-names = "pio";
gpio0: bank@0 {
reg = <0>;
compatible = "mtk,mt7621-gpio-bank";
gpio-controller;
#gpio-cells = <2>;
gpio1: bank@1 {
reg = <1>;
gpio-controller;
#gpio-cells = <2>;
gpio2: bank@2 {
reg = <2>;
gpio-controller;
#gpio-cells = <2>;
- spi: spi@1e000b00 {
compatible = "ralink,mt7621-spi";
reg = <0x1e000b00 0x40>;
pinctrl-0 = <&spi_pins>;
resets = <&rstctrl RST_SPI>;
reset-names = "spi";
clocks = <&clkctrl MT7621_CLK_SPI>;
#size-cells = <0>;
- uart0: uart1@1e000c00 {
compatible = "mediatek,hsuart", "ns16550a";
reg = <0x1e000c00 0x100>;
pinctrl-0 = <&uart1_pins>;
clocks = <&clkctrl MT7621_CLK_UART1>;
resets = <&rstctrl RST_UART1>;
reg-shift = <2>;
- uart1: uart2@1e000d00 {
reg = <0x1e000d00 0x100>;
pinctrl-0 = <&uart2_pins>;
clocks = <&clkctrl MT7621_CLK_UART2>;
resets = <&rstctrl RST_UART2>;
reg-shift = <2>;
- uart2: uart3@1e000e00 {
reg = <0x1e000e00 0x100>;
pinctrl-0 = <&uart3_pins>;
clocks = <&clkctrl MT7621_CLK_UART3>;
resets = <&rstctrl RST_UART3>;
reg-shift = <2>;
- eth: eth@1e100000 {
compatible = "mediatek,mt7621-eth";
reg = <0x1e100000 0x20000>;
mediatek,ethsys = <&sysc>;
pinctrl-0 = <ð_pins>;
resets = <&rstctrl RST_FE>, <&rstctrl RST_GMAC>, <&rstctrl RST_MCM>;
reset-names = "fe", "gmac", "mcm";
clocks = <&clkctrl MT7621_CLK_GDMA>,
<&clkctrl MT7621_CLK_ETH>;
clock-names = "gmac", "fe";
#size-cells = <0>;
mediatek,gmac-id = <0>;
phy-mode = "rgmii";
mediatek,switch = "mt7530";
mediatek,mcm;
fixed-link {
speed = <1000>;
full-duplex;
- mmc: mmc@1e130000 {
compatible = "mediatek,mt7621-mmc";
reg = <0x1e130000 0x4000>;
bus-width = <4>;
builtin-cd = <1>;
r_smpl = <1>;
pinctrl-0 = <&sdxc_pins>;
clocks = <&clk50m>, <&clkctrl MT7621_CLK_SHXC>;
clock-names = "source", "hclk";
resets = <&rstctrl RST_SDXC>;
- ssusb: usb@1e1c0000 {
compatible = "mediatek,mt7621-xhci", "mediatek,mtk-xhci";
reg = <0x1e1c0000 0x1000>, <0x1e1d0700 0x100>;
reg-names = "mac", "ippc";
clocks = <&clk48m>, <&clk48m>;
clock-names = "sys_ck", "ref_ck";
phys = <&u2port0 PHY_TYPE_USB2>,
<&u3port0 PHY_TYPE_USB3>,
<&u2port1 PHY_TYPE_USB2>;
- u3phy: usb-phy@1e1d0000 {
compatible = "mediatek,mt7621-u3phy",
"mediatek,generic-tphy-v1";
reg = <0x1e1d0000 0x700>;
#size-cells = <1>;
ranges;
u2port0: usb-phy@1e1d0800 {
reg = <0x1e1d0800 0x0100>;
#phy-cells = <1>;
clocks = <&clk48m>;
clock-names = "ref";
u3port0: usb-phy@1e1d0900 {
reg = <0x1e1d0900 0x0100>;
#phy-cells = <1>;
u2port1: usb-phy@1e1d1000 {
reg = <0x1e1d1000 0x0100>;
#phy-cells = <1>;
clocks = <&clk48m>;
- i2c: i2c@1e000900 {
compatible = "i2c-gpio";
i2c-gpio,delay-us = <3>;
gpios = <&gpio0 3 1>, /* PIN3 as SDA */
<&gpio0 4 1>; /* PIN4 as CLK */
#size-cells = <0>;
+}; diff --git a/arch/mips/mach-mtmips/Kconfig b/arch/mips/mach-mtmips/Kconfig index 151b004603..d46be503a2 100644 --- a/arch/mips/mach-mtmips/Kconfig +++ b/arch/mips/mach-mtmips/Kconfig @@ -9,6 +9,7 @@ config SYS_MALLOC_F_LEN
config SYS_SOC default "mt7620" if SOC_MT7620
default "mt7621" if SOC_MT7621 default "mt7628" if SOC_MT7628
config SYS_DCACHE_SIZE
@@ -18,25 +19,45 @@ config SYS_DCACHE_LINE_SIZE default 32
config SYS_ICACHE_SIZE
- default 65536
default 65536 if SOC_MT7620 || SOC_MT7628
default 32768 if SOC_MT7621
config SYS_ICACHE_LINE_SIZE default 32
+config SYS_SCACHE_LINE_SIZE
- default 32 if SOC_MT7621
- config SYS_TEXT_BASE
- default 0x9c000000 if !SPL
- default 0x80200000 if SPL
default 0x9c000000 if !SPL && !SOC_MT7621
default 0x80200000 if SPL || SOC_MT7621
config SPL_TEXT_BASE
- default 0x9c000000 if !SOC_MT7621
- default 0x80100000 if SOC_MT7621
+config SPL_SIZE_LIMIT
- default 0x30000 if SOC_MT7621
+config TPL_TEXT_BASE
- default 0xbfc00000 if SOC_MT7621
+config TPL_MAX_SIZE
default 4096 if SOC_MT7621
config SPL_PAYLOAD default "u-boot-lzma.img" if SPL_LZMA
config BUILD_TARGET
- default "u-boot-with-spl.bin" if SPL
- default "u-boot-with-spl.bin" if SPL && !SOC_MT7621
- default "u-boot-lzma.img" if SOC_MT7621 default "u-boot.bin"
+config MAX_MEM_SIZE
- int
- default 256 if SOC_MT7620 || SOC_MT7628
- default 512 if SOC_MT7621
- choice prompt "MediaTek MIPS SoC select"
@@ -55,6 +76,23 @@ config SOC_MT7620 help This supports MediaTek MT7620.
+config SOC_MT7621
- bool "MT7621"
- select MIPS_CM
- select MIPS_L2_CACHE
- select SYS_CACHE_SHIFT_5
- select SYS_MIPS_CACHE_INIT_RAM_LOAD
- select PINCTRL_MT7621
- select MTK_SERIAL
- select REGMAP
- select SYSCON
- select BINMAN
- select SUPPORT_TPL
- select SPL_LOADER_SUPPORT if SPL
- select SPL_INIT_STACK_WITHOUT_MALLOC_F if SPL
- help
This supports MediaTek MT7621.
- config SOC_MT7628 bool "MT7628" select SYS_CACHE_SHIFT_5
@@ -80,6 +118,7 @@ config SOC_MT7628 endchoice
source "arch/mips/mach-mtmips/mt7620/Kconfig" +source "arch/mips/mach-mtmips/mt7621/Kconfig" source "arch/mips/mach-mtmips/mt7628/Kconfig"
endmenu diff --git a/arch/mips/mach-mtmips/Makefile b/arch/mips/mach-mtmips/Makefile index 4909b47ef2..19f1e07033 100644 --- a/arch/mips/mach-mtmips/Makefile +++ b/arch/mips/mach-mtmips/Makefile @@ -1,9 +1,13 @@ # SPDX-License-Identifier: GPL-2.0+
obj-y += cpu.o
+ifneq ($(CONFIG_SOC_MT7621),y) obj-y += ddr_init.o obj-y += ddr_cal.o obj-$(CONFIG_SPL_BUILD) += spl.o +endif
obj-$(CONFIG_SOC_MT7620) += mt7620/ +obj-$(CONFIG_SOC_MT7621) += mt7621/ obj-$(CONFIG_SOC_MT7628) += mt7628/ diff --git a/arch/mips/mach-mtmips/cpu.c b/arch/mips/mach-mtmips/cpu.c index a4b5cff61d..f1e9022738 100644 --- a/arch/mips/mach-mtmips/cpu.c +++ b/arch/mips/mach-mtmips/cpu.c @@ -16,7 +16,7 @@ DECLARE_GLOBAL_DATA_PTR;
int dram_init(void) {
- gd->ram_size = get_ram_size((void *)KSEG1, SZ_256M);
gd->ram_size = get_ram_size((void *)KSEG1, CONFIG_MAX_MEM_SIZE << 20);
return 0; }
diff --git a/arch/mips/mach-mtmips/mt7621/Kconfig b/arch/mips/mach-mtmips/mt7621/Kconfig new file mode 100644 index 0000000000..37d512c68f --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/Kconfig @@ -0,0 +1,95 @@
+if SOC_MT7621
+menu "CPU & DDR configuration"
+config MT7621_CPU_FREQ
- int "CPU Frequency (MHz)"
- range 400 1200
- default 880
can you really select any frequency in that range like 123 MHz? Doesn't need it be in sync with the DRAM frequency?
+choice
- prompt "DRAM Frequency"
- default MT7621_DRAM_FREQ_1200
+config MT7621_DRAM_FREQ_400
- bool "400MHz"
+config MT7621_DRAM_FREQ_800
- bool "800MHz"
+config MT7621_DRAM_FREQ_1066
- bool "1066MHz"
+config MT7621_DRAM_FREQ_1200
- bool "1200MHz"
+endchoice
+choice
- prompt "DDR2 timing parameters"
- default MT7621_DRAM_DDR2_1024M
+config MT7621_DRAM_DDR2_512M
- bool "64MB"
+config MT7621_DRAM_DDR2_1024M
- bool "128MB"
+config MT7621_DRAM_DDR2_512M_W9751G6KB_A02_1066MHZ
- bool "W9751G6KB_A02 @ 1066MHz (64MB)"
+config MT7621_DRAM_DDR2_1024M_W971GG6KB25_800MHZ
- bool "W971GG6KB25 @ 800MHz (128MB)"
+config MT7621_DRAM_DDR2_1024M_W971GG6KB18_1066MHZ
- bool "W971GG6KB18 @ 1066MHz (128MB)"
+endchoice
+choice
- prompt "DDR3 timing parameters"
- default MT7621_DRAM_DDR3_2048M
+config MT7621_DRAM_DDR3_1024M
- bool "128MB"
+config MT7621_DRAM_DDR3_1024M_KGD
- bool "128MB KGD (MT7621DA)"
+config MT7621_DRAM_DDR3_2048M
- bool "256MB"
+config MT7621_DRAM_DDR3_4096M
- bool "512MB"
+endchoice
+endmenu
+config DEBUG_UART_BOARD_INIT
- default y
+config MT7621_BOOT_FROM_NAND
- bool "Boot from NAND"
- help
Select this if u-boot will boot from NAND flash. When booting from
NAND, SPL will be loaded by bootrom directly and no TPL is needed.
+choice
- prompt "Board select"
+endchoice
+config SYS_CONFIG_NAME
- string "Board configuration name"
- default "mt7621" if BOARD_MT7621_RFB || BOARD_MT7621_NAND_RFB
+config SYS_BOARD
- string "Board name"
+config SYS_VENDOR
- default "mediatek" if BOARD_MT7621_RFB || BOARD_MT7621_NAND_RFB
+endif diff --git a/arch/mips/mach-mtmips/mt7621/Makefile b/arch/mips/mach-mtmips/mt7621/Makefile new file mode 100644 index 0000000000..bf1b0bb688 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/Makefile @@ -0,0 +1,14 @@ +# SPDX-License-Identifier: GPL-2.0
+obj-y += init.o +obj-y += serial.o
+ifeq ($(CONFIG_SPL_BUILD),y) +ifeq ($(CONFIG_TPL_BUILD),y) +obj-y += tpl/ +else +obj-y += spl/ +endif
+obj-y += sram_init.o +endif diff --git a/arch/mips/mach-mtmips/mt7621/init.c b/arch/mips/mach-mtmips/mt7621/init.c new file mode 100644 index 0000000000..ec63712bc1 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/init.c @@ -0,0 +1,229 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+#include <clk.h> +#include <dm.h> +#include <dm/uclass.h> +#include <dt-bindings/clock/mt7621-clk.h> +#include <asm/global_data.h> +#include <linux/io.h> +#include "mt7621.h"
+static const char *const boot_mode[(CHIP_MODE_M >> CHIP_MODE_S) + 1] = {
- [1] = "NAND 2K+64",
- [2] = "SPI-NOR 3-Byte Addr",
- [3] = "SPI-NOR 4-Byte Addr",
- [10] = "NAND 2K+128",
- [11] = "NAND 4K+128",
- [12] = "NAND 4K+256",
+int print_cpuinfo(void) +{
- void __iomem *sysc = ioremap_nocache(SYSCTL_BASE, SYSCTL_SIZE);
- u32 val, ver, eco, pkg, core, dram, chipmode;
- u32 cpu_clk, ddr_clk, bus_clk, xtal_clk;
- struct udevice *clkdev;
- const char *bootdev;
- struct clk clk;
- int ret;
- val = readl(sysc + SYSCTL_CHIP_REV_ID_REG);
- ver = (val & VER_ID_M) >> VER_ID_S;
- eco = (val & ECO_ID_M) >> ECO_ID_S;
- pkg = !!(val & PKG_ID);
- core = !!(val & CPU_ID);
- val = readl(sysc + SYSCTL_SYSCFG0_REG);
- dram = val & DRAM_TYPE;
- chipmode = (val & CHIP_MODE_M) >> CHIP_MODE_S;
- bootdev = boot_mode[chipmode];
- if (!bootdev)
bootdev = "Unsupported boot mode";
- printf("CPU: MediaTek MT7621%c ver %u, eco %u\n",
core ? (pkg ? 'A' : 'N') : 'S', ver, eco);
- printf("Boot: DDR%u, %s\n", dram ? 2 : 3, bootdev);
- ret = uclass_get_device_by_driver(UCLASS_CLK, DM_DRIVER_GET(mt7621_clk),
&clkdev);
- if (ret)
return ret;
- clk.dev = clkdev;
- clk.id = MT7621_CLK_CPU;
- cpu_clk = clk_get_rate(&clk);
- clk.id = MT7621_CLK_BUS;
- bus_clk = clk_get_rate(&clk);
- clk.id = MT7621_CLK_DDR;
- ddr_clk = clk_get_rate(&clk);
- clk.id = MT7621_CLK_XTAL;
- xtal_clk = clk_get_rate(&clk);
- /* Set final timer frequency */
- if (cpu_clk)
gd->arch.timer_freq = cpu_clk / 2;
- printf("Clock: CPU: %uMHz, DDR: %uMT/s, Bus: %uMHz, XTAL: %uMHz\n",
cpu_clk / 1000000, ddr_clk / 500000, bus_clk / 1000000,
xtal_clk / 1000000);
+unsigned long get_xtal_mhz(void) +{
- void __iomem *sysc = (void *)KSEG1ADDR(SYSCTL_BASE);
- u32 bs, xtal_sel;
- bs = readl(sysc + SYSCTL_SYSCFG0_REG);
- xtal_sel = (bs & XTAL_MODE_SEL_M) >> XTAL_MODE_SEL_S;
- if (xtal_sel <= 2)
return 20;
- else if (xtal_sel <= 5)
return 40;
- else
return 25;
+static void xhci_config_40mhz(void __iomem *usbh) +{
- writel((0x20 << SSUSB_MAC3_SYS_CK_GATE_MASK_TIME_S) |
(0x20 << SSUSB_MAC2_SYS_CK_GATE_MASK_TIME_S) |
(2 << SSUSB_MAC3_SYS_CK_GATE_MODE_S) |
(2 << SSUSB_MAC2_SYS_CK_GATE_MODE_S) | 0x10,
usbh + SSUSB_MAC_CK_CTRL_REG);
- writel((2 << SSUSB_PLL_PREDIV_PE1D_S) | (1 << SSUSB_PLL_PREDIV_U3_S) |
(4 << SSUSB_PLL_FBKDI_S), usbh + DA_SSUSB_U3PHYA_10_REG);
- writel((0x18 << SSUSB_PLL_FBKDIV_PE2H_S) |
(0x18 << SSUSB_PLL_FBKDIV_PE1D_S) |
(0x18 << SSUSB_PLL_FBKDIV_PE1H_S) |
(0x1e << SSUSB_PLL_FBKDIV_U3_S),
usbh + DA_SSUSB_PLL_FBKDIV_REG);
- writel((0x1e400000 << SSUSB_PLL_PCW_NCPO_U3_S),
usbh + DA_SSUSB_PLL_PCW_NCPO_REG);
- writel((0x25 << SSUSB_PLL_SSC_DELTA1_PE1H_S) |
(0x73 << SSUSB_PLL_SSC_DELTA1_U3_S),
usbh + DA_SSUSB_PLL_SSC_DELTA1_REG);
- writel((0x71 << SSUSB_PLL_SSC_DELTA_U3_S) |
(0x4a << SSUSB_PLL_SSC_DELTA1_PE2D_S),
usbh + DA_SSUSB_U3PHYA_21_REG);
- writel((0x140 << SSUSB_PLL_SSC_PRD_S), usbh + SSUSB_U3PHYA_9_REG);
- writel((0x11c00000 << SSUSB_SYSPLL_PCW_NCPO_S),
usbh + SSUSB_U3PHYA_3_REG);
- writel((4 << SSUSB_PCIE_CLKDRV_AMP_S) | (1 << SSUSB_SYSPLL_FBSEL_S) |
(1 << SSUSB_SYSPLL_PREDIV_S), usbh + SSUSB_U3PHYA_1_REG);
- writel((0x12 << SSUSB_SYSPLL_FBDIV_S) | SSUSB_SYSPLL_VCO_DIV_SEL |
SSUSB_SYSPLL_FPEN | SSUSB_SYSPLL_MONCK_EN | SSUSB_SYSPLL_VOD_EN,
usbh + SSUSB_U3PHYA_2_REG);
- writel(SSUSB_EQ_CURSEL | (8 << SSUSB_RX_DAC_MUX_S) |
(1 << SSUSB_PCIE_SIGDET_VTH_S) | (1 << SSUSB_PCIE_SIGDET_LPF_S),
usbh + SSUSB_U3PHYA_11_REG);
- writel((0x1ff << SSUSB_RING_OSC_CNTEND_S) |
(0x7f << SSUSB_XTAL_OSC_CNTEND_S) | SSUSB_RING_BYPASS_DET,
usbh + SSUSB_B2_ROSC_0_REG);
- writel((3 << SSUSB_RING_OSC_FRC_RECAL_S) | SSUSB_RING_OSC_FRC_SEL,
usbh + SSUSB_B2_ROSC_1_REG);
+static void xhci_config_25mhz(void __iomem *usbh) +{
- writel((2 << SSUSB_PLL_PREDIV_PE1D_S) | (4 << SSUSB_PLL_FBKDI_S),
(0x19 << SSUSB_PLL_FBKDIV_U3_S),
- writel((0x18000000 << SSUSB_PLL_PCW_NCPO_U3_S),
(0x4a << SSUSB_PLL_SSC_DELTA1_U3_S),
- writel((0x48 << SSUSB_PLL_SSC_DELTA_U3_S) |
- writel((0x190 << SSUSB_PLL_SSC_PRD_S), usbh + SSUSB_U3PHYA_9_REG);
- writel((0xe000000 << SSUSB_SYSPLL_PCW_NCPO_S),
- writel((4 << SSUSB_PCIE_CLKDRV_AMP_S) | (1 << SSUSB_SYSPLL_FBSEL_S),
- writel((0xf << SSUSB_SYSPLL_FBDIV_S) | SSUSB_SYSPLL_VCO_DIV_SEL |
+void lowlevel_init(void) +{
- void __iomem *usbh = ioremap_nocache(SSUSB_BASE, SSUSB_SIZE);
- u32 xtal = get_xtal_mhz();
- /* Setup USB xHCI */
- if (xtal == 40)
xhci_config_40mhz(usbh);
- else if (xtal == 25)
xhci_config_25mhz(usbh);
+ulong notrace get_tbclk(void) +{
- return gd->arch.timer_freq;
+void _machine_restart(void) +{
- while (1)
writel(SYS_RST, sysc + SYSCTL_RSTCTL_REG);
+} diff --git a/arch/mips/mach-mtmips/mt7621/mt7621.h b/arch/mips/mach-mtmips/mt7621/mt7621.h new file mode 100644 index 0000000000..916cc993b4 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/mt7621.h @@ -0,0 +1,229 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/*
+#ifndef _MT7621_H_ +#define _MT7621_H_
+#define SYSCTL_BASE 0x1e000000 +#define SYSCTL_SIZE 0x100 +#define TIMER_BASE 0x1e000100 +#define TIMER_SIZE 0x100 +#define RBUS_BASE 0x1e000400 +#define RBUS_SIZE 0x100 +#define GPIO_BASE 0x1e000600 +#define GPIO_SIZE 0x100 +#define DMA_CFG_ARB_BASE 0x1e000800 +#define DMA_CFG_ARB_SIZE 0x100 +#define SPI_BASE 0x1e000b00 +#define SPI_SIZE 0x100 +#define UART1_BASE 0x1e000c00 +#define UART1_SIZE 0x100 +#define UART2_BASE 0x1e000d00 +#define UART2_SIZE 0x100 +#define UART3_BASE 0x1e000e00 +#define UART3_SIZE 0x100 +#define NFI_BASE 0x1e003000 +#define NFI_SIZE 0x800 +#define NFI_ECC_BASE 0x1e003800 +#define NFI_ECC_SIZE 0x800 +#define DRAMC_BASE 0x1e005000 +#define DRAMC_SIZE 0x1000 +#define FE_BASE 0x1e100000 +#define FE_SIZE 0xe000 +#define GMAC_BASE 0x1e110000 +#define GMAC_SIZE 0x8000 +#define SSUSB_BASE 0x1e1c0000 +#define SSUSB_SIZE 0x40000
- /* GIC Base Address */
+#define MIPS_GIC_BASE 0x1fbc0000
- /* CPC Base Address */
+#define MIPS_CPC_BASE 0x1fbf0000
- /* Flash Memory-mapped Base Address */
+#define FLASH_MMAP_BASE 0x1fc00000 +#define TPL_INFO_OFFSET 0x40 +#define TPL_INFO_MAGIC 0x31323637 /* Magic "7621" */
+/* SRAM */ +#define FE_SRAM_BASE1 0x8000 +#define FE_SRAM_BASE2 0xa000
+/* SYSCTL_BASE */ +#define SYSCTL_CHIP_REV_ID_REG 0x0c +#define CPU_ID 0x20000 +#define PKG_ID 0x10000 +#define VER_ID_S 8 +#define VER_ID_M 0xf00 +#define ECO_ID_S 0 +#define ECO_ID_M 0x0f
+#define SYSCTL_SYSCFG0_REG 0x10 +#define XTAL_MODE_SEL_S 6 +#define XTAL_MODE_SEL_M 0x1c0 +#define DRAM_TYPE 0x10 +#define CHIP_MODE_S 0 +#define CHIP_MODE_M 0x0f
+#define BOOT_SRAM_BASE_REG 0x20
+#define SYSCTL_CLKCFG0_REG 0x2c +#define CPU_CLK_SEL_S 30 +#define CPU_CLK_SEL_M 0xc0000000 +#define MPLL_CFG_SEL_S 23 +#define MPLL_CFG_SEL_M 0x800000
+#define SYSCTL_RSTCTL_REG 0x34 +#define MCM_RST 0x04 +#define SYS_RST 0x01
+#define SYSCTL_CUR_CLK_STS_REG 0x44 +#define CUR_CPU_FDIV_S 8 +#define CUR_CPU_FDIV_M 0x1f00 +#define CUR_CPU_FFRAC_S 0 +#define CUR_CPU_FFRAC_M 0x1f
+#define SYSCTL_GPIOMODE_REG 0x60 +#define UART2_MODE_S 5 +#define UART2_MODE_M 0x60 +#define UART3_MODE_S 3 +#define UART3_MODE_M 0x18 +#define UART1_MODE 0x02
+/* RBUS_BASE */ +#define RBUS_DYN_CFG0_REG 0x0010 +#define CPU_FDIV_S 8 +#define CPU_FDIV_M 0x1f00 +#define CPU_FFRAC_S 0 +#define CPU_FFRAC_M 0x1f
+/* DMA_CFG_ARB_BASE */ +#define DMA_ROUTE_REG 0x000c
+/* SPI_BASE */ +#define SPI_SPACE_REG 0x003c +#define FS_SLAVE_SEL_S 12 +#define FS_SLAVE_SEL_M 0x70000 +#define FS_CLK_SEL_S 0 +#define FS_CLK_SEL_M 0xfff
+/* FE_BASE */ +#define FE_RST_GLO_REG 0x0004 +#define FE_PSE_RAM 0x04 +#define FE_PSE_MEM_EN 0x02 +#define FE_PSE_RESET 0x01
+/* SSUSB_BASE */ +#define SSUSB_MAC_CK_CTRL_REG 0x10784 +#define SSUSB_MAC3_SYS_CK_GATE_MASK_TIME_S 16 +#define SSUSB_MAC3_SYS_CK_GATE_MASK_TIME_M 0xff0000 +#define SSUSB_MAC2_SYS_CK_GATE_MASK_TIME_S 8 +#define SSUSB_MAC2_SYS_CK_GATE_MASK_TIME_M 0xff00 +#define SSUSB_MAC3_SYS_CK_GATE_MODE_S 2 +#define SSUSB_MAC3_SYS_CK_GATE_MODE_M 0x0c +#define SSUSB_MAC2_SYS_CK_GATE_MODE_S 0 +#define SSUSB_MAC2_SYS_CK_GATE_MODE_M 0x03
+#define SSUSB_B2_ROSC_0_REG 0x10a40 +#define SSUSB_RING_OSC_CNTEND_S 23 +#define SSUSB_RING_OSC_CNTEND_M 0xff800000 +#define SSUSB_XTAL_OSC_CNTEND_S 16 +#define SSUSB_XTAL_OSC_CNTEND_M 0x7f0000 +#define SSUSB_RING_BYPASS_DET 0x01
+#define SSUSB_B2_ROSC_1_REG 0x10a44 +#define SSUSB_RING_OSC_FRC_RECAL_S 17 +#define SSUSB_RING_OSC_FRC_RECAL_M 0x60000 +#define SSUSB_RING_OSC_FRC_SEL 0x01
+#define SSUSB_U3PHYA_1_REG 0x10b04 +#define SSUSB_PCIE_CLKDRV_AMP_S 27 +#define SSUSB_PCIE_CLKDRV_AMP_M 0x38000000 +#define SSUSB_SYSPLL_FBSEL_S 2 +#define SSUSB_SYSPLL_FBSEL_M 0x0c +#define SSUSB_SYSPLL_PREDIV_S 0 +#define SSUSB_SYSPLL_PREDIV_M 0x03
+#define SSUSB_U3PHYA_2_REG 0x10b08 +#define SSUSB_SYSPLL_FBDIV_S 24 +#define SSUSB_SYSPLL_FBDIV_M 0x7f000000 +#define SSUSB_SYSPLL_VCO_DIV_SEL 0x200000 +#define SSUSB_SYSPLL_FPEN 0x2000 +#define SSUSB_SYSPLL_MONCK_EN 0x1000 +#define SSUSB_SYSPLL_VOD_EN 0x200
+#define SSUSB_U3PHYA_3_REG 0x10b10 +#define SSUSB_SYSPLL_PCW_NCPO_S 1 +#define SSUSB_SYSPLL_PCW_NCPO_M 0xfffffffe
+#define SSUSB_U3PHYA_9_REG 0x10b24 +#define SSUSB_PLL_SSC_PRD_S 0 +#define SSUSB_PLL_SSC_PRD_M 0xffff
+#define SSUSB_U3PHYA_11_REG 0x10b2c +#define SSUSB_EQ_CURSEL 0x1000000 +#define SSUSB_RX_DAC_MUX_S 19 +#define SSUSB_RX_DAC_MUX_M 0xf80000 +#define SSUSB_PCIE_SIGDET_VTH_S 5 +#define SSUSB_PCIE_SIGDET_VTH_M 0x60 +#define SSUSB_PCIE_SIGDET_LPF_S 3 +#define SSUSB_PCIE_SIGDET_LPF_M 0x18
+#define DA_SSUSB_PLL_FBKDIV_REG 0x10c1c +#define SSUSB_PLL_FBKDIV_PE2H_S 24 +#define SSUSB_PLL_FBKDIV_PE2H_M 0x7f000000 +#define SSUSB_PLL_FBKDIV_PE1D_S 16 +#define SSUSB_PLL_FBKDIV_PE1D_M 0x7f0000 +#define SSUSB_PLL_FBKDIV_PE1H_S 8 +#define SSUSB_PLL_FBKDIV_PE1H_M 0x7f00 +#define SSUSB_PLL_FBKDIV_U3_S 0 +#define SSUSB_PLL_FBKDIV_U3_M 0x7f
+#define DA_SSUSB_U3PHYA_10_REG 0x10c20 +#define SSUSB_PLL_PREDIV_PE1D_S 18 +#define SSUSB_PLL_PREDIV_PE1D_M 0xc0000 +#define SSUSB_PLL_PREDIV_U3_S 8 +#define SSUSB_PLL_PREDIV_U3_M 0x300 +#define SSUSB_PLL_FBKDI_S 0 +#define SSUSB_PLL_FBKDI_M 0x07
+#define DA_SSUSB_PLL_PCW_NCPO_REG 0x10c24 +#define SSUSB_PLL_PCW_NCPO_U3_S 0 +#define SSUSB_PLL_PCW_NCPO_U3_M 0x7fffffff
+#define DA_SSUSB_PLL_SSC_DELTA1_REG 0x10c38 +#define SSUSB_PLL_SSC_DELTA1_PE1H_S 16 +#define SSUSB_PLL_SSC_DELTA1_PE1H_M 0xffff0000 +#define SSUSB_PLL_SSC_DELTA1_U3_S 0 +#define SSUSB_PLL_SSC_DELTA1_U3_M 0xffff
+#define DA_SSUSB_U3PHYA_21_REG 0x10c40 +#define SSUSB_PLL_SSC_DELTA_U3_S 16 +#define SSUSB_PLL_SSC_DELTA_U3_M 0xffff0000 +#define SSUSB_PLL_SSC_DELTA1_PE2D_S 0 +#define SSUSB_PLL_SSC_DELTA1_PE2D_M 0xffff
+/* MT7621 specific CM values */
+/* GCR_REGx_BASE */ +#define GCR_REG0_BASE_VALUE 0x1c000000 +#define GCR_REG1_BASE_VALUE 0x60000000 +#define GCR_REG2_BASE_VALUE 0x1c000000 +#define GCR_REG3_BASE_VALUE 0x1c000000
+/* GCR_REGx_MASK */ +#define GCR_REG0_MASK_VALUE 0x0000fc00 /* 64M Bus */ +#define GCR_REG1_MASK_VALUE 0x0000f000 /* 256M PCI Mem */ +#define GCR_REG2_MASK_VALUE 0x0000fc00 /* unused */ +#define GCR_REG3_MASK_VALUE 0x0000fc00 /* unused */
+#ifndef __ASSEMBLY__ +unsigned long get_xtal_mhz(void); +#endif
+#endif /* _MT7621_H_ */ diff --git a/arch/mips/mach-mtmips/mt7621/serial.c b/arch/mips/mach-mtmips/mt7621/serial.c new file mode 100644 index 0000000000..0ccc71dc75 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/serial.c @@ -0,0 +1,23 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+#include <asm/io.h> +#include <asm/addrspace.h> +#include "mt7621.h"
+void board_debug_uart_init(void) +{
- void __iomem *base = ioremap_nocache(SYSCTL_BASE, SYSCTL_SIZE);
+#if CONFIG_DEBUG_UART_BASE == 0xbe000c00 /* KSEG1ADDR(UART1_BASE) */
- clrbits_32(base + SYSCTL_GPIOMODE_REG, UART1_MODE);
+#elif CONFIG_DEBUG_UART_BASE == 0xbe000d00 /* KSEG1ADDR(UART2_BASE) */
- clrbits_32(base + SYSCTL_GPIOMODE_REG, UART2_MODE_M);
+#elif CONFIG_DEBUG_UART_BASE == 0xbe000e00 /* KSEG1ADDR(UART3_BASE) */
- clrbits_32(base + SYSCTL_GPIOMODE_REG, UART3_MODE_M);
+#endif +} diff --git a/arch/mips/mach-mtmips/mt7621/spl/Makefile b/arch/mips/mach-mtmips/mt7621/spl/Makefile new file mode 100644 index 0000000000..ebe54e79b9 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/spl/Makefile @@ -0,0 +1,9 @@
+extra-y += start.o
+obj-y += spl.o +obj-y += cps.o +obj-y += dram.o +obj-y += serial.o +obj-y += launch.o +obj-y += launch_ll.o diff --git a/arch/mips/mach-mtmips/mt7621/spl/cps.c b/arch/mips/mach-mtmips/mt7621/spl/cps.c new file mode 100644 index 0000000000..61f319f45f --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/spl/cps.c @@ -0,0 +1,152 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+#include <asm/io.h> +#include <asm/addrspace.h> +#include <asm/mipsregs.h> +#include <asm/cm.h> +#include "../mt7621.h"
+/* GIC Shared Register Bases */ +#define GIC_SH_POL_BASE 0x100 +#define GIC_SH_TRIG_BASE 0x180 +#define GIC_SH_RMASK_BASE 0x300 +#define GIC_SH_SMASK_BASE 0x380 +#define GIC_SH_MASK_BASE 0x400 +#define GIC_SH_PEND_BASE 0x480 +#define GIC_SH_MAP_PIN_BASE 0x500 +#define GIC_SH_MAP_VPE_BASE 0x2000
+/* GIC Registers */ +#define GIC_SH_POL31_0 (GIC_SH_POL_BASE + 0x00) +#define GIC_SH_POL63_32 (GIC_SH_POL_BASE + 0x04)
+#define GIC_SH_TRIG31_0 (GIC_SH_TRIG_BASE + 0x00) +#define GIC_SH_TRIG63_32 (GIC_SH_TRIG_BASE + 0x04)
+#define GIC_SH_RMASK31_0 (GIC_SH_RMASK_BASE + 0x00) +#define GIC_SH_RMASK63_32 (GIC_SH_RMASK_BASE + 0x04)
+#define GIC_SH_SMASK31_0 (GIC_SH_SMASK_BASE + 0x00) +#define GIC_SH_SMASK63_32 (GIC_SH_SMASK_BASE + 0x04)
+#define GIC_SH_MAP_PIN(n) (GIC_SH_MAP_PIN_BASE + (n) * 4)
+#define GIC_SH_MAP_VPE(n, v) (GIC_SH_MAP_VPE_BASE + (n) * 0x20 + ((v) / 32) * 4) +#define GIC_SH_MAP_VPE31_0(n) GIC_SH_MAP_VPE(n, 0)
+/* GIC_SH_MAP_PIN fields */ +#define GIC_MAP_TO_PIN BIT(31) +#define GIC_MAP_TO_NMI BIT(30) +#define GIC_MAP GENMASK(5, 0) +#define GIC_MAP_SHIFT 0
+static void cm_init(void __iomem *cm_base) +{
- u32 num_cores;
- num_cores = ((readl(cm_base + GCR_CONFIG) & GCR_CONFIG_PCORES) >>
GCR_CONFIG_PCORES_SHIFT) + 1;
- writel((1 << num_cores) - 1, cm_base + GCR_ACCESS);
- writel(GCR_REG0_BASE_VALUE, cm_base + GCR_REG0_BASE);
- writel(GCR_REG1_BASE_VALUE, cm_base + GCR_REG1_BASE);
- writel(GCR_REG2_BASE_VALUE, cm_base + GCR_REG2_BASE);
- writel(GCR_REG3_BASE_VALUE, cm_base + GCR_REG3_BASE);
- clrsetbits_32(cm_base + GCR_REG0_MASK,
GCR_REGn_MASK_ADDRMASK | GCR_REGn_MASK_CMTGT,
GCR_REGn_MASK_CMTGT_IOCU0);
- clrsetbits_32(cm_base + GCR_REG1_MASK,
(GCR_REG1_MASK_VALUE << GCR_REGn_MASK_ADDRMASK_SHIFT) |
- clrsetbits_32(cm_base + GCR_REG2_MASK,
(GCR_REG2_MASK_VALUE << GCR_REGn_MASK_ADDRMASK_SHIFT) |
- clrsetbits_32(cm_base + GCR_REG3_MASK,
(GCR_REG3_MASK_VALUE << GCR_REGn_MASK_ADDRMASK_SHIFT) |
- clrbits_32(cm_base + GCR_BASE, CM_DEFAULT_TARGET_MASK);
- setbits_32(cm_base + GCR_CONTROL, GCR_CONTROL_SYNCCTL);
+static void gic_init(void) +{
- void __iomem *gic_base = (void *)KSEG1ADDR(MIPS_GIC_BASE);
- int i;
- /* Interrupt 0..5: Level Trigger, Active High */
- writel(0, gic_base + GIC_SH_TRIG31_0);
- writel(0x3f, gic_base + GIC_SH_RMASK31_0);
- writel(0x3f, gic_base + GIC_SH_POL31_0);
- writel(0x3f, gic_base + GIC_SH_SMASK31_0);
- /* Interrupt 56..63: Edge Trigger, Rising Edge */
- /* Hardcoded to set up the last 8 external interrupts for IPI. */
- writel(0xff000000, gic_base + GIC_SH_TRIG63_32);
- writel(0xff000000, gic_base + GIC_SH_RMASK63_32);
- writel(0xff000000, gic_base + GIC_SH_POL63_32);
- writel(0xff000000, gic_base + GIC_SH_SMASK63_32);
- /* Map interrupt source to particular hardware interrupt pin */
- /* source {0,1,2,3,4,5} -> pin {0,0,4,3,0,5} */
- writel(GIC_MAP_TO_PIN | 0, gic_base + GIC_SH_MAP_PIN(0));
- writel(GIC_MAP_TO_PIN | 0, gic_base + GIC_SH_MAP_PIN(1));
- writel(GIC_MAP_TO_PIN | 4, gic_base + GIC_SH_MAP_PIN(2));
- writel(GIC_MAP_TO_PIN | 3, gic_base + GIC_SH_MAP_PIN(3));
- writel(GIC_MAP_TO_PIN | 0, gic_base + GIC_SH_MAP_PIN(4));
- writel(GIC_MAP_TO_PIN | 5, gic_base + GIC_SH_MAP_PIN(5));
- /* source 56~59 -> pin 1, 60~63 -> pin 2 */
- writel(GIC_MAP_TO_PIN | 1, gic_base + GIC_SH_MAP_PIN(56));
- writel(GIC_MAP_TO_PIN | 1, gic_base + GIC_SH_MAP_PIN(57));
- writel(GIC_MAP_TO_PIN | 1, gic_base + GIC_SH_MAP_PIN(58));
- writel(GIC_MAP_TO_PIN | 1, gic_base + GIC_SH_MAP_PIN(59));
- writel(GIC_MAP_TO_PIN | 2, gic_base + GIC_SH_MAP_PIN(60));
- writel(GIC_MAP_TO_PIN | 2, gic_base + GIC_SH_MAP_PIN(61));
- writel(GIC_MAP_TO_PIN | 2, gic_base + GIC_SH_MAP_PIN(62));
- writel(GIC_MAP_TO_PIN | 2, gic_base + GIC_SH_MAP_PIN(63));
- /* Interrupt map to VPE (bit mask) */
- for (i = 0; i < 32; i++)
writel(BIT(0), gic_base + GIC_SH_MAP_VPE31_0(i));
* Direct GIC_int 56..63 to vpe 0..3
* MIPS Linux convention that last 16 interrupts implemented be set
* aside for IPI signaling.
* The actual interrupts are tied low and software sends interrupts
* via GIC_SH_WEDGE writes.
- for (i = 0; i < 4; i++) {
writel(BIT(i), gic_base + GIC_SH_MAP_VPE31_0(i + 56));
writel(BIT(i), gic_base + GIC_SH_MAP_VPE31_0(i + 60));
+void mt7621_cps_init(void) +{
- void __iomem *cm_base = (void *)KSEG1ADDR(CONFIG_MIPS_CM_BASE);
- /* Enable GIC */
- writel(MIPS_GIC_BASE | GCR_GIC_EN, cm_base + GCR_GIC_BASE);
- /* Enable CPC */
- writel(MIPS_CPC_BASE | GCR_CPC_EN, cm_base + GCR_CPC_BASE);
- gic_init();
- cm_init(cm_base);
+} diff --git a/arch/mips/mach-mtmips/mt7621/spl/dram.c b/arch/mips/mach-mtmips/mt7621/spl/dram.c new file mode 100644 index 0000000000..827c4a71e9 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/spl/dram.c @@ -0,0 +1,155 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+#include <asm/io.h> +#include <asm/sections.h> +#include <asm/byteorder.h> +#include <asm/addrspace.h> +#include <linux/string.h> +#include "../mt7621.h" +#include "dram.h"
+static const u32 ddr2_act[DDR_PARAM_SIZE] = { +#if defined(CONFIG_MT7621_DRAM_DDR2_512M)
- 0xAA00AA00, 0xAA00AA00, 0x00000007, 0x22174441,
- 0x00000000, 0xF0748661, 0x40001273, 0x9F0A0481,
- 0x0304692F, 0x15602842, 0x00008888, 0x88888888,
- 0x00000000, 0x00000000, 0x00000000, 0x07100000,
- 0x00001B63, 0x00002000, 0x00004000, 0x00006000,
- 0x00000000, 0x00000000, 0x00000000, 0x00000000,
+#elif defined(CONFIG_MT7621_DRAM_DDR2_512M_W9751G6KB_A02_1066MHZ)
- 0xAA00AA00, 0xAA00AA00, 0x00000007, 0x33484584,
- 0x00000000, 0xF07486A1, 0x50001273, 0x9F010481,
- 0x0304693F, 0x15602842, 0x00008888, 0x88888888,
- 0x00000000, 0x00000000, 0x00000010, 0x07100000,
- 0x00001F73, 0x00002000, 0x00004000, 0x00006000,
+#elif defined(CONFIG_MT7621_DRAM_DDR2_1024M_W971GG6KB25_800MHZ)
- 0xAA00AA00, 0xAA00AA00, 0x00000007, 0x22174430,
- 0x01000000, 0xF0748661, 0x40001273, 0x9F0F0481,
+#elif defined(CONFIG_MT7621_DRAM_DDR2_1024M_W971GG6KB18_1066MHZ)
- 0x01000000, 0xF07486A1, 0x50001273, 0x9F070481,
+#else /* CONFIG_MT7621_DRAM_DDR2_1024M */
+#endif +};
+static const u32 ddr3_act[DDR_PARAM_SIZE] = { +#if defined(CONFIG_MT7621_DRAM_DDR3_1024M)
- 0xAA00AA00, 0xAA00AA00, 0x00000007, 0x44694683,
- 0x01000000, 0xF07486A1, 0xC287221D, 0x9F060481,
- 0x03046948, 0x15602842, 0x00008888, 0x88888888,
- 0x00000000, 0x00000000, 0x00000210, 0x07100000,
- 0x00001B61, 0x00002040, 0x00004010, 0x00006000,
- 0x0C000000, 0x07070000, 0x00000000, 0x00000000,
+#elif defined(CONFIG_MT7621_DRAM_DDR3_4096M)
- 0x01000000, 0xF07486A1, 0xC287221D, 0x9F0F0481,
- 0x00000000, 0x00000000, 0x00000240, 0x07100000,
+#elif defined(CONFIG_MT7621_DRAM_DDR3_1024M_KGD)
- 0xFF00FF00, 0xFF00FF00, 0x00000007, 0x44694683,
- 0x01000000, 0xF07406A1, 0xC287221D, 0x9F060481,
- 0x03046923, 0x152f2842, 0x00008888, 0x88888888,
- 0x0C000000, 0x07070000, 0x000C0000, 0x00000000,
+#else /* CONFIG_MT7621_DRAM_DDR3_2048M */
- 0xAA00AA00, 0xAA00AA00, 0x00000007, 0x44694673,
- 0x01000000, 0xF07486A1, 0xC287221D, 0x9F050481,
- 0x00000000, 0x00000000, 0x00000220, 0x07100000,
+#endif +};
+#if defined(CONFIG_MT7621_DRAM_FREQ_400) +#define DDR_FREQ_PARAM 0x41000000 +#elif defined(CONFIG_MT7621_DRAM_FREQ_1066) +#define DDR_FREQ_PARAM 0x21000000 +#elif defined(CONFIG_MT7621_DRAM_FREQ_1200) +#define DDR_FREQ_PARAM 0x11000000 +#else /* CONFIG_MT7621_DRAM_FREQ_800 */ +#define DDR_FREQ_PARAM 0x31000000 +#endif
+#define RG_MEPL_FBDIV_S 4 +#define RG_MEPL_FBDIV_M 0x7f
+static inline void word_copy(u32 *dest, const u32 *src, u32 count) +{
- u32 i;
- for (i = 0; i < count; i++)
dest[i] = src[i];
+static u32 calc_cpu_pll_val(void) +{
- u32 div, baseval, fb;
- div = get_xtal_mhz();
- if (div == 40) {
div /= 2;
baseval = 0xc0005802;
- } else {
baseval = 0xc0004802;
- fb = CONFIG_MT7621_CPU_FREQ / div - 1;
- if (fb > RG_MEPL_FBDIV_M)
fb = RG_MEPL_FBDIV_M;
- return baseval | (fb << RG_MEPL_FBDIV_S);
+void prepare_stage_bin(void) +{
- u32 stage_size;
- const struct stage_header *stock_stage_bin =
(const struct stage_header *)__image_copy_end;
- struct stage_header *new_stage_bin =
(struct stage_header *)STAGE_LOAD_ADDR;
- if (be32_to_cpu(stock_stage_bin->ep) != STAGE_LOAD_ADDR) {
/* Possible wrong binary blob. Hang here */
for (;;)
perhaps a panic() with an according error message should be used?
- stage_size = be32_to_cpu(stock_stage_bin->stage_size);
- word_copy((u32 *)new_stage_bin, (const u32 *)stock_stage_bin,
(stage_size + sizeof(u32) - 1) / sizeof(u32));
- word_copy(new_stage_bin->ddr2_act, ddr2_act, DDR_PARAM_SIZE);
- word_copy(new_stage_bin->ddr3_act, ddr3_act, DDR_PARAM_SIZE);
- new_stage_bin->cpu_pll_cfg = calc_cpu_pll_val();
- new_stage_bin->ddr_pll_cfg = DDR_FREQ_PARAM;
- new_stage_bin->baudrate = CONFIG_BAUDRATE;
+} diff --git a/arch/mips/mach-mtmips/mt7621/spl/dram.h b/arch/mips/mach-mtmips/mt7621/spl/dram.h new file mode 100644 index 0000000000..7322c58276 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/spl/dram.h @@ -0,0 +1,39 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/*
+#ifndef _MT7621_DRAM_H_ +#define _MT7621_DRAM_H_
+#define STAGE_LOAD_ADDR 0xBE108800
+#ifndef __ASSEMBLY__ +#include <linux/types.h>
+#define DDR_PARAM_SIZE 24
+struct stage_header {
- u32 jump_insn[2];
- u32 ep;
- u32 stage_size;
- u32 has_stage2;
- u32 next_ep;
- u32 next_size;
- u32 next_offset;
- u32 cpu_pll_cfg;
- u32 ddr_pll_cfg;
- u32 reserved2[6];
- char build_tag[32];
- u32 ddr3_act[DDR_PARAM_SIZE];
- u32 padding1[2];
- u32 ddr2_act[DDR_PARAM_SIZE];
- u32 padding2[2];
- u32 baudrate;
- u32 padding3;
+}; +#endif
+#endif /* _MT7621_DRAM_H_ */ diff --git a/arch/mips/mach-mtmips/mt7621/spl/launch.c b/arch/mips/mach-mtmips/mt7621/spl/launch.c new file mode 100644 index 0000000000..37c20a5f56 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/spl/launch.c @@ -0,0 +1,100 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+#include <asm/io.h> +#include <asm/cm.h> +#include <asm/sections.h> +#include <asm/addrspace.h> +#include <asm/mipsmtregs.h> +#include <linux/sizes.h> +#include <time.h> +#include <cpu_func.h> +#include "launch.h" +#include "../mt7621.h"
+/* Cluster Power Controller (CPC) offsets */ +#define CPC_CL_OTHER 0x2010 +#define CPC_CO_CMD 0x4000
+/* CPC_CL_OTHER fields */ +#define CPC_CL_OTHER_CORENUM_SHIFT 16 +#define CPC_CL_OTHER_CORENUM GENMASK(23, 16)
+/* CPC_CO_CMD */ +#define PWR_UP 3
+#define NUM_CORES 2 +#define NUM_CPUS 4 +#define WAIT_CPUS_TIMEOUT 4000
+static void copy_launch_wait_code(void) +{
- memset((void *)KSEG1, 0, SZ_4K);
- memcpy((void *)KSEG1ADDR(LAUNCH_WAITCODE),
&launch_wait_code_start,
&launch_wait_code_end - &launch_wait_code_start);
- invalidate_dcache_range(KSEG0, SZ_4K);
+static void bootup_secondary_core(void) +{
- void __iomem *cpcbase = (void __iomem *)KSEG1ADDR(MIPS_CPC_BASE);
- int i;
- for (i = 1; i < NUM_CORES; i++) {
writel(i << CPC_CL_OTHER_CORENUM_SHIFT, cpcbase + CPC_CL_OTHER);
writel(PWR_UP, cpcbase + CPC_CO_CMD);
+void secondary_cpu_init(void) +{
- void __iomem *sysc = (void __iomem *)KSEG1ADDR(SYSCTL_BASE);
- u32 i, dual_core = 0, cpuready = 1, cpumask = 0x03;
- ulong wait_tick;
- struct cpulaunch_t *c;
- /* Copy LAUNCH wait code used by other VPEs */
- copy_launch_wait_code();
- dual_core = readl(sysc + SYSCTL_CHIP_REV_ID_REG) & CPU_ID;
- if (dual_core) {
/* Bootup secondary core for MT7621A */
cpumask = 0x0f;
/* Make BootROM/TPL redirect Core1's bootup flow to our entry point */
writel((uintptr_t)&_start, sysc + BOOT_SRAM_BASE_REG);
bootup_secondary_core();
- /* Join the coherent domain */
- join_coherent_domain(dual_core ? 2 : 1);
- /* Bootup Core0/VPE1 */
- boot_vpe1();
- /* Wait for all CPU ready */
- wait_tick = get_timer(0) + WAIT_CPUS_TIMEOUT;
- while (time_before(get_timer(0), wait_tick)) {
/* CPU0 is obviously ready */
for (i = 1; i < NUM_CPUS; i++) {
c = (struct cpulaunch_t *)(KSEG0ADDR(CPULAUNCH) +
(i << LOG2CPULAUNCH));
if (c->flags & LAUNCH_FREADY)
cpuready |= BIT(i);
if ((cpuready & cpumask) == cpumask)
break;
+} diff --git a/arch/mips/mach-mtmips/mt7621/spl/launch.h b/arch/mips/mach-mtmips/mt7621/spl/launch.h new file mode 100644 index 0000000000..f34250d605 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/spl/launch.h @@ -0,0 +1,52 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/*
+#ifndef _LAUNCH_H_ +#define _LAUNCH_H_
+struct cpulaunch_t {
- unsigned long pc;
- unsigned long gp;
- unsigned long sp;
- unsigned long a0;
- unsigned long _pad[3]; /* pad to cache line size to avoid thrashing */
- unsigned long flags;
+extern char launch_wait_code_start; +extern char launch_wait_code_end;
+void join_coherent_domain(int ncores); +void boot_vpe1(void);
+#else
+#define LAUNCH_PC 0 +#define LAUNCH_GP 4 +#define LAUNCH_SP 8 +#define LAUNCH_A0 12 +#define LAUNCH_FLAGS 28
+#define LOG2CPULAUNCH 5
+#define LAUNCH_FREADY 1 +#define LAUNCH_FGO 2 +#define LAUNCH_FGONE 4
+#define LAUNCH_WAITCODE 0x00000d00 +#define SCRLAUNCH 0x00000e00 +#define CPULAUNCH 0x00000f00 +#define NCPULAUNCH 8
+/* Polling period in count cycles for secondary CPU's */ +#define LAUNCHPERIOD 10000
+#endif /* _LAUNCH_H_ */ diff --git a/arch/mips/mach-mtmips/mt7621/spl/launch_ll.S b/arch/mips/mach-mtmips/mt7621/spl/launch_ll.S new file mode 100644 index 0000000000..55a8fff9af --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/spl/launch_ll.S @@ -0,0 +1,357 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/*
+#include <asm/cm.h> +#include <asm/asm.h> +#include <asm/regdef.h> +#include <asm/cacheops.h> +#include <asm/mipsregs.h> +#include <asm/addrspace.h> +#include <asm/mipsmtregs.h> +#include "launch.h"
- .macro cache_loop curr, end, line_sz, op
+10: cache \op, 0(\curr)
- PTR_ADDU \curr, \curr, \line_sz
- bne \curr, \end, 10b
- .endm
- .set mt
- Join the coherent domain
- a0 = number of cores
+LEAF(join_coherent_domain)
* Enable coherence and allow interventions from all other cores.
* (Write access enabled via GCR_ACCESS by core 0.)
- li t1, 1
- sll t1, a0
- addiu t1, -1
- li t0, KSEG1ADDR(CONFIG_MIPS_CM_BASE)
- sw t1, GCR_Cx_COHERENCE(t0)
- ehb
- move t2, zero
+_next_coherent_core:
- sll t1, t2, GCR_Cx_OTHER_CORENUM_SHIFT
- sw t1, GCR_Cx_OTHER(t0)
+_busy_wait_coherent_core:
- lw t1, GCR_CO_COHERENCE(t0)
- beqz t1, _busy_wait_coherent_core
nop
- addiu t2, 1
- bne t2, a0, _next_coherent_core
nop
- jr ra
nop
the nop's are actually redundant in normal reorder assembly mode and could be omitted. The assembler will add them automatically if there are no other instructions feasible for the delay slot
- END(join_coherent_domain)
- All VPEs other than VPE0 will go here.
+LEAF(launch_vpe_entry)
- mfc0 t0, CP0_EBASE
- and t0, t0, MIPS_EBASE_CPUNUM
- /* per-VPE cpulaunch_t */
- li a0, KSEG0ADDR(CPULAUNCH)
- sll t1, t0, LOG2CPULAUNCH
- addu a0, t1
- /* Set CPU online flag */
- li t0, LAUNCH_FREADY
- sw t0, LAUNCH_FLAGS(a0)
- /* Enable count interrupt in mask, but do not enable interrupts */
- mfc0 t0, CP0_STATUS
- ori t0, STATUSF_IP7
- mtc0 t0, CP0_STATUS
- /* VPEs executing in wait code do not need a stack */
- li t9, KSEG0ADDR(LAUNCH_WAITCODE)
- jr t9
nop
- END(launch_vpe_entry)
- This function will not be executed in place.
- It will be copied into memory, and VPEs other than VPE0 will be
- started to run into this in-memory function.
+LEAF(launch_wait_code)
- .globl launch_wait_code_start
+launch_wait_code_start:
- move t0, a0
+start_poll:
- /* Poll CPU go flag */
- mtc0 zero, CP0_COUNT
- li t1, LAUNCHPERIOD
- mtc0 t1, CP0_COMPARE
+time_wait:
- /* Software wait */
- mfc0 t2, CP0_COUNT
- subu t2, t1
- bltz t2, time_wait
nop
- /* Check the launch flag */
- lw t3, LAUNCH_FLAGS(t0)
- and t3, LAUNCH_FGO
- beqz t3, start_poll
nop
- /* Reset the counter and interrupts to give naive clients a chance */
- mfc0 t1, CP0_STATUS
- ins t1, zero, STATUSB_IP7, 1
- mtc0 t1, CP0_STATUS
- mfc0 t1, CP0_COUNT
- subu t1, 1
- /* Jump to kernel */
- lw t9, LAUNCH_PC(t0)
- lw gp, LAUNCH_GP(t0)
- lw sp, LAUNCH_SP(t0)
- lw a0, LAUNCH_A0(t0)
- move a1, zero
- move a2, zero
- move a3, zero
- ori t3, LAUNCH_FGONE
- sw t3, LAUNCH_FLAGS(t0)
- jr t9
nop
- .globl launch_wait_code_end
+launch_wait_code_end:
- END(launch_wait_code)
- Core1 will go here.
+LEAF(launch_core_entry)
- /* Disable caches */
- bal mips_cache_disable
nop
- /* Initialize L1 cache only */
- li a0, CONFIG_SYS_ICACHE_SIZE
- li a1, CONFIG_SYS_ICACHE_LINE_SIZE
- li a2, CONFIG_SYS_DCACHE_SIZE
- li a3, CONFIG_SYS_DCACHE_LINE_SIZE
- mtc0 zero, CP0_TAGLO
- mtc0 zero, CP0_TAGLO, 2
- ehb
* Initialize the I-cache first,
- li t0, KSEG0
- addu t1, t0, a0
- /* clear tag to invalidate */
- cache_loop t0, t1, a1, INDEX_STORE_TAG_I
+#ifdef CONFIG_SYS_MIPS_CACHE_INIT_RAM_LOAD
- /* fill once, so data field parity is correct */
- PTR_LI t0, KSEG0
- cache_loop t0, t1, a1, FILL
- /* invalidate again - prudent but not strictly necessary */
- PTR_LI t0, KSEG0
* then initialize D-cache.
- PTR_LI t0, KSEG0
- PTR_ADDU t1, t0, a2
- /* clear all tags */
- cache_loop t0, t1, a3, INDEX_STORE_TAG_D
- /* load from each line (in cached space) */
- PTR_LI t0, KSEG0
+2: LONG_L zero, 0(t0)
- PTR_ADDU t0, a3
bne t0, t1, 2b
- PTR_LI t0, KSEG0
- /* Set Cache Mode */
- mfc0 t0, CP0_CONFIG
- li t1, CONF_CM_CACHABLE_COW
- ins t0, t1, 0, 3
- mtc0 t0, CP0_CONFIG
- li a0, 2
- bal join_coherent_domain
nop
- bal boot_vpe1
nop
- b launch_vpe_entry
nop
- END(launch_core_entry)
- Bootup VPE1.
- This subroutine must be executed from VPE0 with VPECONF0[MVP] already set.
+LEAF(boot_vpe1)
- mfc0 t0, CP0_MVPCONF0
- /* a0 = number of TCs - 1 */
- ext a0, t0, MVPCONF0_PTC_SHIFT, 8
- beqz a0, _vpe1_init_done
nop
- /* a1 = number of VPEs - 1 */
- ext a1, t0, MVPCONF0_PVPE_SHIFT, 4
- beqz a1, _vpe1_init_done
nop
- /* a2 = current TC No. */
- move a2, zero
- /* Enter VPE Configuration State */
- mfc0 t0, CP0_MVPCONTROL
- or t0, MVPCONTROL_VPC
- mtc0 t0, CP0_MVPCONTROL
- ehb
+_next_tc:
- /* Set the TC number to be used on MTTR and MFTR instructions */
- mfc0 t0, CP0_VPECONTROL
- ins t0, a2, 0, 8
- mtc0 t0, CP0_VPECONTROL
- ehb
- /* TC0 is already bound */
- beqz a2, _next_vpe
nop
- /* Halt current TC */
- li t0, TCHALT_H
- mttc0 t0, CP0_TCHALT
- ehb
- /* If there is spare TC, bind it to the last VPE (VPE[a1]) */
- slt t1, a1, a2
- bnez t1, _vpe_bind_tc
move t1, a1
- /* Set Exclusive TC for active TC */
- mftc0 t0, CP0_VPECONF0
- ins t0, a2, VPECONF0_XTC_SHIFT, 8
- mttc0 t0, CP0_VPECONF0
- move t1, a2
+_vpe_bind_tc:
- /* Bind TC to a VPE */
- mftc0 t0, CP0_TCBIND
- ins t0, t1, TCBIND_CURVPE_SHIFT, 4
- mttc0 t0, CP0_TCBIND
* Set up CP0_TCSTATUS register:
* Disable Coprocessor Usable bits
* Disable MDMX/DSP ASE
* Clear Dirty TC
* not dynamically allocatable
* not allocated
* Kernel mode
* interrupt exempt
* ASID 0
- li t0, TCSTATUS_IXMT
- mttc0 t0, CP0_TCSTATUS
+_next_vpe:
- slt t1, a1, a2
- bnez t1, _done_vpe # No more VPEs
nop
- /* Disable TC multi-threading */
- mftc0 t0, CP0_VPECONTROL
- ins t0, zero, VPECONTROL_TE_SHIFT, 1
- mttc0 t0, CP0_VPECONTROL
- /* Skip following configuration for TC0 */
- beqz a2, _done_vpe
nop
- /* Deactivate VPE, set Master VPE */
- ins t0, zero, VPECONF0_VPA_SHIFT, 1
- or t0, VPECONF0_MVP
- mttc0 t0, CP0_STATUS
- mttc0 zero, CP0_EPC
- mttc0 zero, CP0_CAUSE
- mttc0 t0, CP0_CONFIG
* VPE1 of each core can execute cached as its L1 I$ has already
* been initialized.
* and the L2$ has been initialized or "disabled" via CCA override.
- PTR_LA t0, _start
- mttc0 t0, CP0_TCRESTART
- /* Unset Interrupt Exempt, set Activate Thread */
- mftc0 t0, CP0_TCSTATUS
- ins t0, zero, TCSTATUS_IXMT_SHIFT, 1
- ori t0, TCSTATUS_A
- /* Resume TC */
- mttc0 zero, CP0_TCHALT
- /* Activate VPE */
- ori t0, VPECONF0_VPA
+_done_vpe:
- addu a2, 1
- sltu t0, a0, a2
- beqz t0, _next_tc
nop
- /* Enable all activated VPE to execute */
- ori t0, MVPCONTROL_EVP
- /* Exit VPE Configuration State */
- ins t0, zero, MVPCONTROL_VPC_SHIFT, 1
- ehb
+_vpe1_init_done:
- jr ra
nop
- END(boot_vpe1)
diff --git a/arch/mips/mach-mtmips/mt7621/spl/serial.c b/arch/mips/mach-mtmips/mt7621/spl/serial.c new file mode 100644 index 0000000000..5cf093a078 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/spl/serial.c @@ -0,0 +1,24 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+#include <asm/io.h> +#include "../mt7621.h"
+void mtmips_spl_serial_init(void) +{ +#ifdef CONFIG_SPL_SERIAL
+#if CONFIG_CONS_INDEX == 1
+#elif CONFIG_CONS_INDEX == 2
+#elif CONFIG_CONS_INDEX == 3
+#endif /* CONFIG_CONS_INDEX */ +#endif /* CONFIG_SPL_SERIAL */ +} diff --git a/arch/mips/mach-mtmips/mt7621/spl/spl.c b/arch/mips/mach-mtmips/mt7621/spl/spl.c new file mode 100644 index 0000000000..71d01aa7f5 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/spl/spl.c @@ -0,0 +1,95 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+#include <spl.h> +#include <init.h> +#include <image.h> +#include <vsprintf.h> +#include <malloc.h> +#include <asm/io.h> +#include <asm/sections.h> +#include <asm/addrspace.h> +#include <asm/byteorder.h> +#include <asm/global_data.h> +#include <linux/sizes.h> +#include <mach/serial.h> +#include "../mt7621.h" +#include "dram.h"
+DECLARE_GLOBAL_DATA_PTR;
+struct tpl_info {
- u32 magic;
- u32 size;
+void set_timer_freq_simple(void) +{
- u32 div = get_xtal_mhz();
- /* Round down cpu freq */
- gd->arch.timer_freq = rounddown(CONFIG_MT7621_CPU_FREQ, div) * 500000;
+void __noreturn board_init_f(ulong dummy) +{
- spl_init();
* mtmips_spl_serial_init() is useful if debug uart is enabled,
* or DM based serial is not enabled.
- mtmips_spl_serial_init();
- preloader_console_init();
- board_init_r(NULL, 0);
+void board_boot_order(u32 *spl_boot_list) +{ +#ifdef CONFIG_MT7621_BOOT_FROM_NAND
- spl_boot_list[0] = BOOT_DEVICE_NAND;
+#else
- spl_boot_list[0] = BOOT_DEVICE_NOR;
+#endif +}
+unsigned long spl_nor_get_uboot_base(void) +{
- const struct tpl_info *tpli;
- const image_header_t *hdr;
- u32 addr;
- addr = FLASH_MMAP_BASE + TPL_INFO_OFFSET;
- tpli = (const struct tpl_info *)KSEG1ADDR(addr);
- if (tpli->magic == TPL_INFO_MAGIC) {
addr = FLASH_MMAP_BASE + tpli->size;
hdr = (const image_header_t *)KSEG1ADDR(addr);
if (image_get_magic(hdr) == IH_MAGIC) {
addr += sizeof(*hdr) + image_get_size(hdr);
return KSEG1ADDR(addr);
- panic("Unable to locate SPL payload\n");
+uint32_t spl_nand_get_uboot_raw_page(void) +{
- const struct stage_header *sh = (const struct stage_header *)&_start;
- u32 addr;
- addr = image_get_header_size() + be32_to_cpu(sh->stage_size);
- addr = ALIGN(addr, SZ_4K);
- return addr;
+} diff --git a/arch/mips/mach-mtmips/mt7621/spl/start.S b/arch/mips/mach-mtmips/mt7621/spl/start.S new file mode 100644 index 0000000000..3cad3567e7 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/spl/start.S @@ -0,0 +1,226 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/*
+#include <asm-offsets.h> +#include <config.h> +#include <asm/asm.h> +#include <asm/regdef.h> +#include <asm/mipsregs.h> +#include <asm/cacheops.h> +#include <asm/addrspace.h> +#include <asm/mipsmtregs.h> +#include <asm/cm.h> +#include "../mt7621.h" +#include "dram.h"
+#ifndef CONFIG_SYS_INIT_SP_ADDR +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + \
CONFIG_SYS_INIT_SP_OFFSET)
- .macro init_wr sel
- MTC0 zero, CP0_WATCHLO,\sel
- mtc0 t1, CP0_WATCHHI,\sel
- .endm
- .macro setup_stack_gd
- li t0, -16
- PTR_LI t1, CONFIG_SYS_INIT_SP_ADDR
- and sp, t1, t0 # force 16 byte alignment
- PTR_SUBU \
sp, sp, GD_SIZE # reserve space for gd
- and sp, sp, t0 # force 16 byte alignment
- move k0, sp # save gd pointer
+#if CONFIG_VAL(SYS_MALLOC_F_LEN) && \
- !CONFIG_IS_ENABLED(INIT_STACK_WITHOUT_MALLOC_F)
- li t2, CONFIG_VAL(SYS_MALLOC_F_LEN)
- PTR_SUBU \
sp, sp, t2 # reserve space for early malloc
- move fp, sp
- /* Clear gd */
- move t0, k0
+1:
- PTR_S zero, 0(t0)
- PTR_ADDIU t0, PTRSIZE
- blt t0, t1, 1b
nop
- PTR_S sp, GD_MALLOC_BASE(k0) # gd->malloc_base offset
- .endm
- .set noreorder
+ENTRY(_start)
- b 1f
- /* Stage header required by BootROM */
- .org 0x8
- .word 0 # ep, filled by mkimage
- .word 0 # stage_size, filled by mkimage
- .word 0 # has_stage2
- .word 0 # next_ep
- .word 0 # next_size
- .word 0 # next_offset
+1:
- /* Init CP0 Status */
- and t0, ST0_IMPL
- or t0, ST0_BEV | ST0_ERL
- ehb
- /* Clear Watch Status bits and disable watch exceptions */
- li t1, 0x7 # Clear I, R and W conditions
- init_wr 0
- init_wr 1
- init_wr 2
- init_wr 3
- /* Clear WP, IV and SW interrupts */
- mtc0 zero, CP0_CAUSE
- /* Clear timer interrupt (CP0_COUNT cleared on branch to 'reset') */
- mtc0 zero, CP0_COMPARE
- /* VPE1 goes to wait code directly */
- mfc0 t0, CP0_TCBIND
- andi t0, TCBIND_CURVPE
- bnez t0, launch_vpe_entry
nop
- /* Core1 goes to specific launch entry */
- PTR_LI t0, KSEG1ADDR(CONFIG_MIPS_CM_BASE)
- lw t1, GCR_Cx_ID(t0)
- bnez t1, launch_core_entry
nop
- /* MT7530 reset */
- li t0, KSEG1ADDR(SYSCTL_BASE)
- lw t1, SYSCTL_RSTCTL_REG(t0)
- ori t1, MCM_RST
- sw t1, SYSCTL_RSTCTL_REG(t0)
- /* Disable DMA route for PSE SRAM set by BootROM */
- PTR_LI t0, KSEG1ADDR(DMA_CFG_ARB_BASE)
- sw zero, DMA_ROUTE_REG(t0)
- /* Set CPU clock to 500MHz (Required if boot from NAND) */
- lw t1, SYSCTL_CLKCFG0_REG(t0)
- ins t1, zero, 30, 2 # CPU_CLK_SEL
- sw t1, SYSCTL_CLKCFG0_REG(t0)
- /* Set CPU clock divider to 1/1 */
- li t0, KSEG1ADDR(RBUS_BASE)
- li t1, 0x101
- sw t1, RBUS_DYN_CFG0_REG(t0)
- /* (Re-)initialize the SRAM */
- bal mips_sram_init
nop
- /* Set up temporary stack */
- li sp, SP_ADDR_TEMP
- /* Setup full CPS */
- bal mips_cm_map
nop
- bal mt7621_cps_init
nop
- /* Prepare for CPU/DDR initialization binary blob */
- bal prepare_stage_bin
nop
- /* Call CPU/DDR initialization binary blob */
- li t9, STAGE_LOAD_ADDR
- jalr t9
nop
- /* Switch CPU PLL source */
- li t2, 1
- ins t1, t2, CPU_CLK_SEL_S, 2
* Currently SPL is running on locked L2 cache (on KSEG0).
* To reset the entire cache, we have to writeback SPL to DRAM first.
* Cache flush won't work here. Use memcpy instead.
- la a0, __text_start
- move a1, a0
- la a2, __image_copy_end
- sub a2, a2, a1
- li a3, 5
- ins a0, a3, 29, 3 # convert to KSEG1
- bal memcpy
nop
nop
- /* Reset caches */
- bal mips_cache_reset
nop
- /* Disable SRAM */
- li t0, KSEG1ADDR(FE_BASE)
- li t1, FE_PSE_RESET
- sw t1, FE_RST_GLO_REG(t0)
- /* Clear the .bss section */
- la a0, __bss_start
- la a1, __bss_end
+1: sw zero, 0(a0)
- addiu a0, 4
- ble a0, a1, 1b
nop
- /* Set up initial stack and global data */
- setup_stack_gd
+#if CONFIG_IS_ENABLED(INIT_STACK_WITHOUT_MALLOC_F)
- /* Set malloc base */
- li t0, (CONFIG_SYS_INIT_SP_ADDR + 15) & (~15)
- PTR_S t0, GD_MALLOC_BASE(k0) # gd->malloc_base offset
+#if defined(CONFIG_DEBUG_UART) && defined(CONFIG_SPL_SERIAL)
- /* Earliest point to set up debug uart */
- bal debug_uart_init
nop
- /* Setup timer */
- bal set_timer_freq_simple
nop
- /* Bootup secondary CPUs */
- bal secondary_cpu_init
nop
- move a0, zero # a0 <-- boot_flags = 0
- bal board_init_f
move ra, zero
- END(_start)
diff --git a/arch/mips/mach-mtmips/mt7621/sram_init.S b/arch/mips/mach-mtmips/mt7621/sram_init.S new file mode 100644 index 0000000000..74ddd6bcd7 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/sram_init.S @@ -0,0 +1,22 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+#include <asm/addrspace.h> +#include <asm/asm.h> +#include <asm/regdef.h> +#include "mt7621.h"
+LEAF(mips_sram_init)
- li t1, (FE_PSE_RAM | FE_PSE_MEM_EN)
- jr ra
- END(mips_sram_init)
diff --git a/arch/mips/mach-mtmips/mt7621/tpl/Makefile b/arch/mips/mach-mtmips/mt7621/tpl/Makefile new file mode 100644 index 0000000000..471ad74249 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/tpl/Makefile @@ -0,0 +1,4 @@
+extra-y += start.o
+obj-y += tpl.o diff --git a/arch/mips/mach-mtmips/mt7621/tpl/start.S b/arch/mips/mach-mtmips/mt7621/tpl/start.S new file mode 100644 index 0000000000..19b09f7251 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/tpl/start.S @@ -0,0 +1,161 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/*
+#include <asm-offsets.h> +#include <config.h> +#include <asm/asm.h> +#include <asm/regdef.h> +#include <asm/addrspace.h> +#include <asm/mipsregs.h> +#include <asm/cm.h> +#include "../mt7621.h"
+#define SP_ADDR_TEMP 0xbe10dff0
- .set noreorder
- .endm
- .macro uhi_mips_exception
- move k0, t9 # preserve t9 in k0
- move k1, a0 # preserve a0 in k1
- li t9, 15 # UHI exception operation
- li a0, 0 # Use hard register context
- sdbbp 1 # Invoke UHI operation
- .endm
+ENTRY(_start)
- b reset
* Store TPL size here.
* This will be used by SPL to locate u-boot payload.
- .org TPL_INFO_OFFSET
- .word TPL_INFO_MAGIC
- .word __image_copy_len
- /* Exception vector */
- .org 0x200
- /* TLB refill, 32 bit task */
- uhi_mips_exception
- .org 0x280
- /* XTLB refill, 64 bit task */
- .org 0x300
- /* Cache error exception */
- .org 0x380
- /* General exception */
- .org 0x400
- /* Catch interrupt exceptions */
- .org 0x480
- /* EJTAG debug exception */
+1: b 1b
nop
- .org 0x500
+reset:
- /* Set KSEG0 to Uncached */
- ins t0, zero, 0, 3
- ori t0, t0, CONF_CM_UNCACHED
- ehb
- /* Check for CPU number */
- beqz t0, 1f
nop
- /* Secondary core goes to specified SPL entry address */
- lw t0, BOOT_SRAM_BASE_REG(t0)
- jr t0
nop
+1: mfc0 t0, CP0_STATUS
- and t0, ST0_IMPL
nop
- init_wr 0
- init_wr 1
- init_wr 2
- init_wr 3
- /* Setup basic CPS */
- bal mips_cm_map
nop
- li t1, GCR_REG0_BASE_VALUE
- sw t1, GCR_REG0_BASE(t0)
- li t1, ((GCR_REG0_MASK_VALUE << GCR_REGn_MASK_ADDRMASK_SHIFT) | \
- sw t1, GCR_REG0_MASK(t0)
- lw t1, GCR_BASE(t0)
- ins t1, zero, 0, 2 # CM_DEFAULT_TARGET
- sw t1, GCR_BASE(t0)
- lw t1, GCR_CONTROL(t0)
- li t2, GCR_CONTROL_SYNCCTL
- or t1, t1, t2
- sw t1, GCR_CONTROL(t0)
- /* Increase SPI frequency */
- li t0, KSEG1ADDR(SPI_BASE)
- li t1, 5
- sw t1, SPI_SPACE_REG(t0)
- /* Set CPU clock to 500MHz */
- li t1, 0x101
- /* Initialize the SRAM */
nop
- /* Set up initial stack */
- bal tpl_main
nop
- END(_start)
diff --git a/arch/mips/mach-mtmips/mt7621/tpl/tpl.c b/arch/mips/mach-mtmips/mt7621/tpl/tpl.c new file mode 100644 index 0000000000..77bcf0ddf0 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/tpl/tpl.c @@ -0,0 +1,146 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+#include <image.h> +#include <asm/sections.h> +#include <asm/cacheops.h> +#include <asm/mipsregs.h> +#include <asm/cm.h>
+#define INDEX_STORE_DATA_SD 0x0f
+typedef void __noreturn (*image_entry_noargs_t)(void);
+static inline void ehb(void) +{
- __asm__ __volatile__ ("ehb");
this is already available as execution_hazard_barrier() in arch/mips/include/asm/system.h. There is also sync() and instruction_hazard_barrier() if needed.
- Lock L2 cache and fill data
- Assume that data is 4-byte aligned and start_addr/size is 32-byte aligned
+static void fill_lock_l2cache(uintptr_t dataptr, ulong start_addr, ulong size) +{
- ulong slsize = CONFIG_SYS_DCACHE_LINE_SIZE;
- ulong end_addr = start_addr + size;
- const u32 *data = (u32 *)dataptr;
- ulong i, addr;
- u32 val;
- /* Clear WSC & SPR bit in ErrCtl */
- val = read_c0_ecc();
- val &= 0xcfffffff;
- write_c0_ecc(val);
- ehb();
- for (addr = start_addr; addr < end_addr; addr += slsize) {
/* Set STagLo to lock cache line */
write_c0_staglo((addr & 0x1ffff800) | 0xa0);
mips_cache(INDEX_STORE_TAG_SD, (void *)addr);
/* Fill data */
for (i = 0; i < slsize; i += 8) {
val = *data++;
__write_32bit_c0_register($28, 5, val); /* sdtaglo */
val = *data++;
__write_32bit_c0_register($29, 5, val); /* sdtaghi */
mips_cache(INDEX_STORE_DATA_SD, (void *)(addr + i));
+/* A simple function to initialize MT7621's cache */ +static void mt7621_cache_init(void) +{
- ulong lsize = CONFIG_SYS_DCACHE_LINE_SIZE;
- ulong addr;
- u32 val;
- /* Enable CCA override. Set to uncached */
- val = readl(cm_base + GCR_BASE);
- val &= ~CCA_DEFAULT_OVR_MASK;
- val |= CCA_DEFAULT_OVREN | (2 << CCA_DEFAULT_OVR_SHIFT);
- writel(val, cm_base + GCR_BASE);
- /* Initialize L1 I-Cache */
- write_c0_taglo(0);
- write_c0_taghi(0);
- for (addr = 0; addr < CONFIG_SYS_ICACHE_SIZE; addr += lsize)
mips_cache(INDEX_STORE_TAG_I, (void *)addr);
- /* Initialize L1 D-Cache */
- write_c0_dtaglo(0);
- __write_32bit_c0_register($29, 2, 0); /* dtaghi */
- for (addr = 0; addr < CONFIG_SYS_DCACHE_SIZE; addr += lsize)
mips_cache(INDEX_STORE_TAG_D, (void *)addr);
- /* Initialize L2 Cache */
- write_c0_staglo(0);
- __write_32bit_c0_register($29, 4, 0); /* staghi */
- for (addr = 0; addr < (256 << 10); addr += lsize)
- /* Dsiable CCA override */
- val &= ~(CCA_DEFAULT_OVR_MASK | CCA_DEFAULT_OVREN);
- /* Set KSEG0 to non-coherent cached (important!) */
- val = read_c0_config();
- val &= ~CONF_CM_CMASK;
- val |= CONF_CM_CACHABLE_NONCOHERENT;
- write_c0_config(val);
- ehb();
- /* Again, invalidate L1 D-Cache */
mips_cache(INDEX_WRITEBACK_INV_D, (void *)addr);
- /* Invalidate L1 I-Cache */
mips_cache(INDEX_INVALIDATE_I, (void *)addr);
- /* Disable L2 cache bypass */
- val = read_c0_config2();
- val &= ~MIPS_CONF_IMPL;
- write_c0_config2(val);
- ehb();
+void __noreturn tpl_main(void) +{
- const image_header_t *hdr = (const image_header_t *)__image_copy_end;
- image_entry_noargs_t image_entry;
- u32 loadaddr, size;
- uintptr_t data;
- /* Initialize the cache first */
- mt7621_cache_init();
- if (image_get_magic(hdr) != IH_MAGIC)
goto failed;
- loadaddr = image_get_load(hdr);
- size = image_get_size(hdr);
- image_entry = (image_entry_noargs_t)image_get_ep(hdr);
- /* Load TPL image to L2 cache */
- data = (uintptr_t)__image_copy_end + sizeof(struct image_header);
- fill_lock_l2cache(data, loadaddr, size);
- /* Jump to SPL */
- image_entry();
+failed:
- for (;;)
+} diff --git a/include/configs/mt7621.h b/include/configs/mt7621.h new file mode 100644 index 0000000000..580d5fde0c --- /dev/null +++ b/include/configs/mt7621.h @@ -0,0 +1,67 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/*
+#ifndef __CONFIG_MT7621_H +#define __CONFIG_MT7621_H
+#define CONFIG_SYS_HZ 1000 +#define CONFIG_SYS_MIPS_TIMER_FREQ 440000000
+#define CONFIG_SYS_BOOTPARAMS_LEN 0x20000
+#define CONFIG_SYS_SDRAM_BASE 0x80000000
+#define CONFIG_VERY_BIG_RAM +#define CONFIG_MAX_MEM_MAPPED 0x1c000000
+#define CONFIG_SYS_INIT_SP_OFFSET 0x800000
+#define CONFIG_SYS_BOOTM_LEN 0x2000000
+#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_CBSIZE 1024
+#define CONFIG_SYS_NONCACHED_MEMORY 0x100000
+/* MMC */ +#define MMC_SUPPORTS_TUNING
+/* NAND */ +#define CONFIG_SYS_MAX_NAND_DEVICE 1
+/* Serial SPL */ +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_SERIAL) +#define CONFIG_SYS_NS16550_MEM32 +#define CONFIG_SYS_NS16550_CLK 50000000 +#define CONFIG_SYS_NS16550_REG_SIZE -4 +#define CONFIG_SYS_NS16550_COM1 0xbe000c00 +#endif
+/* Serial common */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, \
230400, 460800, 921600 }
+/* SPL */ +#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE
+#ifdef CONFIG_TPL_BUILD +#define CONFIG_SPL_START_S_PATH "arch/mips/mach-mtmips/mt7621/tpl" +/* .bss will not be used by TPL */ +#define CONFIG_SPL_BSS_START_ADDR 0x80000000 +#define CONFIG_SPL_BSS_MAX_SIZE 0 +#else +#define CONFIG_SPL_START_S_PATH "arch/mips/mach-mtmips/mt7621/spl" +#define CONFIG_SPL_BSS_START_ADDR 0x80140000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 +#define CONFIG_SPL_MAX_SIZE 0x30000 +#endif
+/* Dummy value */ +#define CONFIG_SYS_UBOOT_BASE 0 +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0
+#endif /* __CONFIG_MT7621_H */
On Tue, 2022-05-17 at 23:39 +0200, Daniel Schwierzeck wrote:
On 16.05.22 04:42, Weijie Gao wrote:
This patch adds support for MediaTek MT7621 SoC. All files are dedicated for u-boot.
The default build target is u-boot-mt7621.bin.
The specification of this chip: https://www.mediatek.com/products/homenetworking/mt7621
Signed-off-by: Weijie Gao weijie.gao@mediatek.com
v5 changes: Fix dram binary blob loading procedure Adjust mt7621.dtsi, clkctrl moved under sysc, pinctrl default states removed v4 changes: Add full support for booting from flash (SPL/TPL support) Boot all cores/VPEs Use binman to generate final binary Use binman to embed external binary blob v3 changes: Update clock name for mt7621.dtsi due to clk driver changed v2 changes: Add a kconfig for max supported ram size Remove network configs from default config file
arch/mips/dts/mt7621-u-boot.dtsi | 111 ++++++ arch/mips/dts/mt7621.dtsi | 349 ++++++++++++++++++ arch/mips/mach-mtmips/Kconfig | 49 ++- arch/mips/mach-mtmips/Makefile | 4 + arch/mips/mach-mtmips/cpu.c | 2 +- arch/mips/mach-mtmips/mt7621/Kconfig | 95 +++++ arch/mips/mach-mtmips/mt7621/Makefile | 14 + arch/mips/mach-mtmips/mt7621/init.c | 229 ++++++++++++ arch/mips/mach-mtmips/mt7621/mt7621.h | 229 ++++++++++++ arch/mips/mach-mtmips/mt7621/serial.c | 23 ++ arch/mips/mach-mtmips/mt7621/spl/Makefile | 9 + arch/mips/mach-mtmips/mt7621/spl/cps.c | 152 ++++++++ arch/mips/mach-mtmips/mt7621/spl/dram.c | 155 ++++++++ arch/mips/mach-mtmips/mt7621/spl/dram.h | 39 ++ arch/mips/mach-mtmips/mt7621/spl/launch.c | 100 ++++++ arch/mips/mach-mtmips/mt7621/spl/launch.h | 52 +++ arch/mips/mach-mtmips/mt7621/spl/launch_ll.S | 357 +++++++++++++++++++ arch/mips/mach-mtmips/mt7621/spl/serial.c | 24 ++ arch/mips/mach-mtmips/mt7621/spl/spl.c | 95 +++++ arch/mips/mach-mtmips/mt7621/spl/start.S | 226 ++++++++++++ arch/mips/mach-mtmips/mt7621/sram_init.S | 22 ++ arch/mips/mach-mtmips/mt7621/tpl/Makefile | 4 + arch/mips/mach-mtmips/mt7621/tpl/start.S | 161 +++++++++ arch/mips/mach-mtmips/mt7621/tpl/tpl.c | 146 ++++++++ include/configs/mt7621.h | 67 ++++ 25 files changed, 2708 insertions(+), 6 deletions(-) create mode 100644 arch/mips/dts/mt7621-u-boot.dtsi create mode 100644 arch/mips/dts/mt7621.dtsi create mode 100644 arch/mips/mach-mtmips/mt7621/Kconfig create mode 100644 arch/mips/mach-mtmips/mt7621/Makefile create mode 100644 arch/mips/mach-mtmips/mt7621/init.c create mode 100644 arch/mips/mach-mtmips/mt7621/mt7621.h create mode 100644 arch/mips/mach-mtmips/mt7621/serial.c create mode 100644 arch/mips/mach-mtmips/mt7621/spl/Makefile create mode 100644 arch/mips/mach-mtmips/mt7621/spl/cps.c create mode 100644 arch/mips/mach-mtmips/mt7621/spl/dram.c create mode 100644 arch/mips/mach-mtmips/mt7621/spl/dram.h create mode 100644 arch/mips/mach-mtmips/mt7621/spl/launch.c create mode 100644 arch/mips/mach-mtmips/mt7621/spl/launch.h create mode 100644 arch/mips/mach-mtmips/mt7621/spl/launch_ll.S create mode 100644 arch/mips/mach-mtmips/mt7621/spl/serial.c create mode 100644 arch/mips/mach-mtmips/mt7621/spl/spl.c create mode 100644 arch/mips/mach-mtmips/mt7621/spl/start.S create mode 100644 arch/mips/mach-mtmips/mt7621/sram_init.S create mode 100644 arch/mips/mach-mtmips/mt7621/tpl/Makefile create mode 100644 arch/mips/mach-mtmips/mt7621/tpl/start.S create mode 100644 arch/mips/mach-mtmips/mt7621/tpl/tpl.c create mode 100644 include/configs/mt7621.h
Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
some nits below
diff --git a/arch/mips/dts/mt7621-u-boot.dtsi b/arch/mips/dts/mt7621-u-boot.dtsi new file mode 100644 index 0000000000..c5a8aa357f --- /dev/null +++ b/arch/mips/dts/mt7621-u-boot.dtsi @@ -0,0 +1,111 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
- Copyright (C) 2022 MediaTek Inc. All rights reserved.
- Author: Weijie Gao weijie.gao@mediatek.com
+#include <linux/stringify.h>
- binman: binman {
multiple-images;
+&sysc {
- u-boot,dm-pre-reloc;
+&reboot {
+&clkctrl {
+&rstctrl {
+&pinctrl {
+&uart0 {
+&uart1 {
+&uart2 {
+&binman {
- u-boot-spl-ddr {
align = <4>;
align-size = <4>;
filename = "u-boot-spl-ddr.bin";
pad-byte = <0xff>;
u-boot-spl {
align-end = <4>;
filename = "u-boot-spl.bin";
stage_bin {
filename = "mt7621_stage_sram.bin";
type = "blob-ext";
- spl-img {
filename = "u-boot-spl-ddr.img";
mkimage {
args = "-T", "mtk_image", "-n",
"mt7621=1",
"-a",
__stringify(CONFIG_SPL_TEXT_BASE),
"-e",
__stringify(CONFIG_SPL_TEXT_BASE); +#else
args = "-A", "mips", "-T", "standalone",
"-O", "u-boot",
"-C", "none", "-n", "MT7621 U-Boot
SPL",
"-a",
"-e",
__stringify(CONFIG_SPL_TEXT_BASE); +#endif
blob {
- mt7621-uboot {
filename = "u-boot-mt7621.bin";
pad-byte = <0xff>;
+#ifndef CONFIG_MT7621_BOOT_FROM_NAND
u-boot-tpl {
align-end = <4>;
filename = "u-boot-tpl.bin";
spl {
align-end = <0x1000>;
type = "blob";
u-boot {
filename = "u-boot-lzma.img";
type = "blob";
+}; diff --git a/arch/mips/dts/mt7621.dtsi b/arch/mips/dts/mt7621.dtsi new file mode 100644 index 0000000000..0f057dfe1b --- /dev/null +++ b/arch/mips/dts/mt7621.dtsi @@ -0,0 +1,349 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+#include <dt-bindings/clock/mt7621-clk.h> +#include <dt-bindings/reset/mt7621-reset.h> +#include <dt-bindings/phy/phy.h>
- #address-cells = <1>;
- #size-cells = <1>;
- compatible = "mediatek,mt7621-soc";
- cpus {
#size-cells = <0>;
cpu@0 {
device_type = "cpu";
compatible = "mips,mips1004Kc";
reg = <0>;
cpu@1 {
reg = <1>;
- clk48m: clk48m@0 {
shouldn't a @XXX be always paired with a "reg = <XXX>" respectively shouldn't it be omitted without a "reg"?
ah, that's right. I will use clk48m directly.
compatible = "fixed-clock";
clock-frequency = <48000000>;
#clock-cells = <0>;
- clk50m: clk50m@0 {
clock-frequency = <50000000>;
#clock-cells = <0>;
- sysc: sysctrl@1e000000 {
compatible = "mediatek,mt7621-sysc", "syscon";
reg = <0x1e000000 0x100>;
clkctrl: clock-controller@1e000030 {
compatible = "mediatek,mt7621-clk";
mediatek,memc = <&memc>;
#clock-cells = <1>;
- rstctrl: reset-controller@1e000034 {
compatible = "mediatek,mtmips-reset";
reg = <0x1e000034 0x4>;
#reset-cells = <1>;
- reboot: resetctl-reboot {
compatible = "resetctl-reboot";
resets = <&rstctrl RST_SYS>;
reset-names = "sysreset";
- memc: memctrl@1e005000 {
compatible = "mediatek,mt7621-memc", "syscon";
reg = <0x1e005000 0x1000>;
- pinctrl: pinctrl@1e000060 {
compatible = "mediatek,mt7621-pinctrl";
reg = <0x1e000048 0x30>;
pinctrl-names = "default";
pinctrl-0 = <&state_default>;
state_default: pin_state {
uart1_pins: uart1_pins {
groups = "uart1";
function = "uart";
uart2_pins: uart2_pins {
groups = "uart2";
function = "uart";
uart3_pins: uart3_pins {
groups = "uart3";
function = "uart";
sdxc_pins: sdxc_pins {
groups = "sdxc";
function = "sdxc";
spi_pins: spi_pins {
groups = "spi";
function = "spi";
eth_pins: eth_pins {
mdio_pins {
groups = "mdio";
function = "mdio";
rgmii1_pins {
groups = "rgmii1";
function = "rgmii";
esw_pins {
groups = "esw int";
function = "esw int";
mdio_pconf {
groups = "mdio";
drive-strength = <2>;
- watchdog: watchdog@1e000100 {
compatible = "mediatek,mt7621-wdt";
reg = <0x1e000100 0x40>;
resets = <&rstctrl RST_TIMER>;
reset-names = "wdt";
status = "disabled";
- gpio: gpio@1e000600 {
#size-cells = <0>;
compatible = "mtk,mt7621-gpio";
reg = <0x1e000600 0x100>;
resets = <&rstctrl RST_PIO>;
reset-names = "pio";
gpio0: bank@0 {
reg = <0>;
compatible = "mtk,mt7621-gpio-bank";
gpio-controller;
#gpio-cells = <2>;
gpio1: bank@1 {
reg = <1>;
gpio-controller;
#gpio-cells = <2>;
gpio2: bank@2 {
reg = <2>;
gpio-controller;
#gpio-cells = <2>;
- spi: spi@1e000b00 {
compatible = "ralink,mt7621-spi";
reg = <0x1e000b00 0x40>;
pinctrl-0 = <&spi_pins>;
resets = <&rstctrl RST_SPI>;
reset-names = "spi";
clocks = <&clkctrl MT7621_CLK_SPI>;
#size-cells = <0>;
- uart0: uart1@1e000c00 {
compatible = "mediatek,hsuart", "ns16550a";
reg = <0x1e000c00 0x100>;
pinctrl-0 = <&uart1_pins>;
clocks = <&clkctrl MT7621_CLK_UART1>;
resets = <&rstctrl RST_UART1>;
reg-shift = <2>;
- uart1: uart2@1e000d00 {
reg = <0x1e000d00 0x100>;
pinctrl-0 = <&uart2_pins>;
clocks = <&clkctrl MT7621_CLK_UART2>;
resets = <&rstctrl RST_UART2>;
reg-shift = <2>;
- uart2: uart3@1e000e00 {
reg = <0x1e000e00 0x100>;
pinctrl-0 = <&uart3_pins>;
clocks = <&clkctrl MT7621_CLK_UART3>;
resets = <&rstctrl RST_UART3>;
reg-shift = <2>;
- eth: eth@1e100000 {
compatible = "mediatek,mt7621-eth";
reg = <0x1e100000 0x20000>;
mediatek,ethsys = <&sysc>;
pinctrl-0 = <ð_pins>;
resets = <&rstctrl RST_FE>, <&rstctrl RST_GMAC>,
<&rstctrl RST_MCM>;
reset-names = "fe", "gmac", "mcm";
clocks = <&clkctrl MT7621_CLK_GDMA>,
<&clkctrl MT7621_CLK_ETH>;
clock-names = "gmac", "fe";
#size-cells = <0>;
mediatek,gmac-id = <0>;
phy-mode = "rgmii";
mediatek,switch = "mt7530";
mediatek,mcm;
fixed-link {
speed = <1000>;
full-duplex;
- mmc: mmc@1e130000 {
compatible = "mediatek,mt7621-mmc";
reg = <0x1e130000 0x4000>;
bus-width = <4>;
builtin-cd = <1>;
r_smpl = <1>;
pinctrl-0 = <&sdxc_pins>;
clocks = <&clk50m>, <&clkctrl MT7621_CLK_SHXC>;
clock-names = "source", "hclk";
resets = <&rstctrl RST_SDXC>;
- ssusb: usb@1e1c0000 {
compatible = "mediatek,mt7621-xhci",
"mediatek,mtk-xhci";
reg = <0x1e1c0000 0x1000>, <0x1e1d0700 0x100>;
reg-names = "mac", "ippc";
clocks = <&clk48m>, <&clk48m>;
clock-names = "sys_ck", "ref_ck";
phys = <&u2port0 PHY_TYPE_USB2>,
<&u3port0 PHY_TYPE_USB3>,
<&u2port1 PHY_TYPE_USB2>;
- u3phy: usb-phy@1e1d0000 {
compatible = "mediatek,mt7621-u3phy",
"mediatek,generic-tphy-v1";
reg = <0x1e1d0000 0x700>;
#size-cells = <1>;
ranges;
u2port0: usb-phy@1e1d0800 {
reg = <0x1e1d0800 0x0100>;
#phy-cells = <1>;
clocks = <&clk48m>;
clock-names = "ref";
u3port0: usb-phy@1e1d0900 {
reg = <0x1e1d0900 0x0100>;
#phy-cells = <1>;
u2port1: usb-phy@1e1d1000 {
reg = <0x1e1d1000 0x0100>;
#phy-cells = <1>;
clocks = <&clk48m>;
- i2c: i2c@1e000900 {
compatible = "i2c-gpio";
i2c-gpio,delay-us = <3>;
gpios = <&gpio0 3 1>, /* PIN3 as SDA */
<&gpio0 4 1>; /* PIN4 as CLK */
#size-cells = <0>;
+}; diff --git a/arch/mips/mach-mtmips/Kconfig b/arch/mips/mach- mtmips/Kconfig index 151b004603..d46be503a2 100644 --- a/arch/mips/mach-mtmips/Kconfig +++ b/arch/mips/mach-mtmips/Kconfig @@ -9,6 +9,7 @@ config SYS_MALLOC_F_LEN
config SYS_SOC default "mt7620" if SOC_MT7620
default "mt7621" if SOC_MT7621 default "mt7628" if SOC_MT7628
config SYS_DCACHE_SIZE
@@ -18,25 +19,45 @@ config SYS_DCACHE_LINE_SIZE default 32
config SYS_ICACHE_SIZE
- default 65536
default 65536 if SOC_MT7620 || SOC_MT7628
default 32768 if SOC_MT7621
config SYS_ICACHE_LINE_SIZE default 32
+config SYS_SCACHE_LINE_SIZE
- default 32 if SOC_MT7621
- config SYS_TEXT_BASE
- default 0x9c000000 if !SPL
- default 0x80200000 if SPL
default 0x9c000000 if !SPL && !SOC_MT7621
default 0x80200000 if SPL || SOC_MT7621
config SPL_TEXT_BASE
- default 0x9c000000 if !SOC_MT7621
- default 0x80100000 if SOC_MT7621
+config SPL_SIZE_LIMIT
- default 0x30000 if SOC_MT7621
+config TPL_TEXT_BASE
- default 0xbfc00000 if SOC_MT7621
+config TPL_MAX_SIZE
default 4096 if SOC_MT7621
config SPL_PAYLOAD default "u-boot-lzma.img" if SPL_LZMA
config BUILD_TARGET
- default "u-boot-with-spl.bin" if SPL
- default "u-boot-with-spl.bin" if SPL && !SOC_MT7621
- default "u-boot-lzma.img" if SOC_MT7621 default "u-boot.bin"
+config MAX_MEM_SIZE
- int
- default 256 if SOC_MT7620 || SOC_MT7628
- default 512 if SOC_MT7621
- choice prompt "MediaTek MIPS SoC select"
@@ -55,6 +76,23 @@ config SOC_MT7620 help This supports MediaTek MT7620.
+config SOC_MT7621
- bool "MT7621"
- select MIPS_CM
- select MIPS_L2_CACHE
- select SYS_CACHE_SHIFT_5
- select SYS_MIPS_CACHE_INIT_RAM_LOAD
- select PINCTRL_MT7621
- select MTK_SERIAL
- select REGMAP
- select SYSCON
- select BINMAN
- select SUPPORT_TPL
- select SPL_LOADER_SUPPORT if SPL
- select SPL_INIT_STACK_WITHOUT_MALLOC_F if SPL
- help
This supports MediaTek MT7621.
- config SOC_MT7628 bool "MT7628" select SYS_CACHE_SHIFT_5
@@ -80,6 +118,7 @@ config SOC_MT7628 endchoice
source "arch/mips/mach-mtmips/mt7620/Kconfig" +source "arch/mips/mach-mtmips/mt7621/Kconfig" source "arch/mips/mach-mtmips/mt7628/Kconfig"
endmenu diff --git a/arch/mips/mach-mtmips/Makefile b/arch/mips/mach- mtmips/Makefile index 4909b47ef2..19f1e07033 100644 --- a/arch/mips/mach-mtmips/Makefile +++ b/arch/mips/mach-mtmips/Makefile @@ -1,9 +1,13 @@ # SPDX-License-Identifier: GPL-2.0+
obj-y += cpu.o
+ifneq ($(CONFIG_SOC_MT7621),y) obj-y += ddr_init.o obj-y += ddr_cal.o obj-$(CONFIG_SPL_BUILD) += spl.o +endif
obj-$(CONFIG_SOC_MT7620) += mt7620/ +obj-$(CONFIG_SOC_MT7621) += mt7621/ obj-$(CONFIG_SOC_MT7628) += mt7628/ diff --git a/arch/mips/mach-mtmips/cpu.c b/arch/mips/mach- mtmips/cpu.c index a4b5cff61d..f1e9022738 100644 --- a/arch/mips/mach-mtmips/cpu.c +++ b/arch/mips/mach-mtmips/cpu.c @@ -16,7 +16,7 @@ DECLARE_GLOBAL_DATA_PTR;
int dram_init(void) {
- gd->ram_size = get_ram_size((void *)KSEG1, SZ_256M);
CONFIG_MAX_MEM_SIZE << 20);
return 0; } diff --git a/arch/mips/mach-mtmips/mt7621/Kconfig b/arch/mips/mach- mtmips/mt7621/Kconfig new file mode 100644 index 0000000000..37d512c68f --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/Kconfig @@ -0,0 +1,95 @@
+if SOC_MT7621
+menu "CPU & DDR configuration"
+config MT7621_CPU_FREQ
- int "CPU Frequency (MHz)"
- range 400 1200
- default 880
can you really select any frequency in that range like 123 MHz? Doesn't need it be in sync with the DRAM frequency?
The CPU PLL uses xtal clock as input. So the actual CPU frequency will be round down to a multiple of the xtal clock. Please refer to function calc_cpu_pll_val() in arch/mips/mach-mtmips/mt7621/spl/dram.c
+choice
- prompt "DRAM Frequency"
- default MT7621_DRAM_FREQ_1200
+config MT7621_DRAM_FREQ_400
- bool "400MHz"
+config MT7621_DRAM_FREQ_800
- bool "800MHz"
+config MT7621_DRAM_FREQ_1066
- bool "1066MHz"
+config MT7621_DRAM_FREQ_1200
- bool "1200MHz"
+endchoice
+choice
- prompt "DDR2 timing parameters"
- default MT7621_DRAM_DDR2_1024M
+config MT7621_DRAM_DDR2_512M
- bool "64MB"
+config MT7621_DRAM_DDR2_1024M
- bool "128MB"
+config MT7621_DRAM_DDR2_512M_W9751G6KB_A02_1066MHZ
- bool "W9751G6KB_A02 @ 1066MHz (64MB)"
+config MT7621_DRAM_DDR2_1024M_W971GG6KB25_800MHZ
- bool "W971GG6KB25 @ 800MHz (128MB)"
+config MT7621_DRAM_DDR2_1024M_W971GG6KB18_1066MHZ
- bool "W971GG6KB18 @ 1066MHz (128MB)"
+endchoice
+choice
- prompt "DDR3 timing parameters"
- default MT7621_DRAM_DDR3_2048M
+config MT7621_DRAM_DDR3_1024M
- bool "128MB"
+config MT7621_DRAM_DDR3_1024M_KGD
- bool "128MB KGD (MT7621DA)"
+config MT7621_DRAM_DDR3_2048M
- bool "256MB"
+config MT7621_DRAM_DDR3_4096M
- bool "512MB"
+endchoice
+endmenu
+config DEBUG_UART_BOARD_INIT
- default y
+config MT7621_BOOT_FROM_NAND
- bool "Boot from NAND"
- help
Select this if u-boot will boot from NAND flash. When
booting from
NAND, SPL will be loaded by bootrom directly and no TPL
is needed.
+choice
- prompt "Board select"
+endchoice
+config SYS_CONFIG_NAME
- string "Board configuration name"
- default "mt7621" if BOARD_MT7621_RFB ||
BOARD_MT7621_NAND_RFB
+config SYS_BOARD
- string "Board name"
+config SYS_VENDOR
- default "mediatek" if BOARD_MT7621_RFB ||
+endif diff --git a/arch/mips/mach-mtmips/mt7621/Makefile b/arch/mips/mach-mtmips/mt7621/Makefile new file mode 100644 index 0000000000..bf1b0bb688 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/Makefile @@ -0,0 +1,14 @@ +# SPDX-License-Identifier: GPL-2.0
+obj-y += init.o +obj-y += serial.o
+ifeq ($(CONFIG_SPL_BUILD),y) +ifeq ($(CONFIG_TPL_BUILD),y) +obj-y += tpl/ +else +obj-y += spl/ +endif
+obj-y += sram_init.o +endif diff --git a/arch/mips/mach-mtmips/mt7621/init.c b/arch/mips/mach- mtmips/mt7621/init.c new file mode 100644 index 0000000000..ec63712bc1 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/init.c @@ -0,0 +1,229 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+#include <clk.h> +#include <dm.h> +#include <dm/uclass.h> +#include <dt-bindings/clock/mt7621-clk.h> +#include <asm/global_data.h> +#include <linux/io.h> +#include "mt7621.h"
+static const char *const boot_mode[(CHIP_MODE_M >> CHIP_MODE_S) + 1] = {
- [1] = "NAND 2K+64",
- [2] = "SPI-NOR 3-Byte Addr",
- [3] = "SPI-NOR 4-Byte Addr",
- [10] = "NAND 2K+128",
- [11] = "NAND 4K+128",
- [12] = "NAND 4K+256",
+int print_cpuinfo(void) +{
- void __iomem *sysc = ioremap_nocache(SYSCTL_BASE,
SYSCTL_SIZE);
- u32 val, ver, eco, pkg, core, dram, chipmode;
- u32 cpu_clk, ddr_clk, bus_clk, xtal_clk;
- struct udevice *clkdev;
- const char *bootdev;
- struct clk clk;
- int ret;
- val = readl(sysc + SYSCTL_CHIP_REV_ID_REG);
- ver = (val & VER_ID_M) >> VER_ID_S;
- eco = (val & ECO_ID_M) >> ECO_ID_S;
- pkg = !!(val & PKG_ID);
- core = !!(val & CPU_ID);
- val = readl(sysc + SYSCTL_SYSCFG0_REG);
- dram = val & DRAM_TYPE;
- chipmode = (val & CHIP_MODE_M) >> CHIP_MODE_S;
- bootdev = boot_mode[chipmode];
- if (!bootdev)
bootdev = "Unsupported boot mode";
- printf("CPU: MediaTek MT7621%c ver %u, eco %u\n",
core ? (pkg ? 'A' : 'N') : 'S', ver, eco);
- printf("Boot: DDR%u, %s\n", dram ? 2 : 3, bootdev);
- ret = uclass_get_device_by_driver(UCLASS_CLK,
DM_DRIVER_GET(mt7621_clk),
&clkdev);
- if (ret)
return ret;
- clk.dev = clkdev;
- clk.id = MT7621_CLK_CPU;
- cpu_clk = clk_get_rate(&clk);
- clk.id = MT7621_CLK_BUS;
- bus_clk = clk_get_rate(&clk);
- clk.id = MT7621_CLK_DDR;
- ddr_clk = clk_get_rate(&clk);
- clk.id = MT7621_CLK_XTAL;
- xtal_clk = clk_get_rate(&clk);
- /* Set final timer frequency */
- if (cpu_clk)
gd->arch.timer_freq = cpu_clk / 2;
- printf("Clock: CPU: %uMHz, DDR: %uMT/s, Bus: %uMHz, XTAL:
%uMHz\n",
cpu_clk / 1000000, ddr_clk / 500000, bus_clk /
1000000,
xtal_clk / 1000000);
+unsigned long get_xtal_mhz(void) +{
- void __iomem *sysc = (void *)KSEG1ADDR(SYSCTL_BASE);
- u32 bs, xtal_sel;
- bs = readl(sysc + SYSCTL_SYSCFG0_REG);
- xtal_sel = (bs & XTAL_MODE_SEL_M) >> XTAL_MODE_SEL_S;
- if (xtal_sel <= 2)
return 20;
- else if (xtal_sel <= 5)
return 40;
- else
return 25;
+static void xhci_config_40mhz(void __iomem *usbh) +{
- writel((0x20 << SSUSB_MAC3_SYS_CK_GATE_MASK_TIME_S) |
(0x20 << SSUSB_MAC2_SYS_CK_GATE_MASK_TIME_S) |
(2 << SSUSB_MAC3_SYS_CK_GATE_MODE_S) |
(2 << SSUSB_MAC2_SYS_CK_GATE_MODE_S) | 0x10,
usbh + SSUSB_MAC_CK_CTRL_REG);
- writel((2 << SSUSB_PLL_PREDIV_PE1D_S) | (1 <<
SSUSB_PLL_PREDIV_U3_S) |
(4 << SSUSB_PLL_FBKDI_S), usbh +
DA_SSUSB_U3PHYA_10_REG);
- writel((0x18 << SSUSB_PLL_FBKDIV_PE2H_S) |
(0x18 << SSUSB_PLL_FBKDIV_PE1D_S) |
(0x18 << SSUSB_PLL_FBKDIV_PE1H_S) |
(0x1e << SSUSB_PLL_FBKDIV_U3_S),
usbh + DA_SSUSB_PLL_FBKDIV_REG);
- writel((0x1e400000 << SSUSB_PLL_PCW_NCPO_U3_S),
usbh + DA_SSUSB_PLL_PCW_NCPO_REG);
- writel((0x25 << SSUSB_PLL_SSC_DELTA1_PE1H_S) |
(0x73 << SSUSB_PLL_SSC_DELTA1_U3_S),
usbh + DA_SSUSB_PLL_SSC_DELTA1_REG);
- writel((0x71 << SSUSB_PLL_SSC_DELTA_U3_S) |
(0x4a << SSUSB_PLL_SSC_DELTA1_PE2D_S),
usbh + DA_SSUSB_U3PHYA_21_REG);
- writel((0x140 << SSUSB_PLL_SSC_PRD_S), usbh +
SSUSB_U3PHYA_9_REG);
- writel((0x11c00000 << SSUSB_SYSPLL_PCW_NCPO_S),
usbh + SSUSB_U3PHYA_3_REG);
- writel((4 << SSUSB_PCIE_CLKDRV_AMP_S) | (1 <<
SSUSB_SYSPLL_FBSEL_S) |
(1 << SSUSB_SYSPLL_PREDIV_S), usbh +
SSUSB_U3PHYA_1_REG);
- writel((0x12 << SSUSB_SYSPLL_FBDIV_S) |
SSUSB_SYSPLL_VCO_DIV_SEL |
SSUSB_SYSPLL_FPEN | SSUSB_SYSPLL_MONCK_EN |
SSUSB_SYSPLL_VOD_EN,
usbh + SSUSB_U3PHYA_2_REG);
- writel(SSUSB_EQ_CURSEL | (8 << SSUSB_RX_DAC_MUX_S) |
(1 << SSUSB_PCIE_SIGDET_VTH_S) | (1 <<
SSUSB_PCIE_SIGDET_LPF_S),
usbh + SSUSB_U3PHYA_11_REG);
- writel((0x1ff << SSUSB_RING_OSC_CNTEND_S) |
(0x7f << SSUSB_XTAL_OSC_CNTEND_S) |
SSUSB_RING_BYPASS_DET,
usbh + SSUSB_B2_ROSC_0_REG);
- writel((3 << SSUSB_RING_OSC_FRC_RECAL_S) |
SSUSB_RING_OSC_FRC_SEL,
usbh + SSUSB_B2_ROSC_1_REG);
+static void xhci_config_25mhz(void __iomem *usbh) +{
- writel((2 << SSUSB_PLL_PREDIV_PE1D_S) | (4 <<
SSUSB_PLL_FBKDI_S),
usbh + DA_SSUSB_U3PHYA_10_REG);
(0x19 << SSUSB_PLL_FBKDIV_U3_S),
- writel((0x18000000 << SSUSB_PLL_PCW_NCPO_U3_S),
(0x4a << SSUSB_PLL_SSC_DELTA1_U3_S),
- writel((0x48 << SSUSB_PLL_SSC_DELTA_U3_S) |
- writel((0x190 << SSUSB_PLL_SSC_PRD_S), usbh +
- writel((0xe000000 << SSUSB_SYSPLL_PCW_NCPO_S),
SSUSB_SYSPLL_FBSEL_S),
usbh + SSUSB_U3PHYA_1_REG);
- writel((0xf << SSUSB_SYSPLL_FBDIV_S) |
+void lowlevel_init(void) +{
- void __iomem *usbh = ioremap_nocache(SSUSB_BASE,
SSUSB_SIZE);
- u32 xtal = get_xtal_mhz();
- /* Setup USB xHCI */
- if (xtal == 40)
xhci_config_40mhz(usbh);
- else if (xtal == 25)
xhci_config_25mhz(usbh);
+ulong notrace get_tbclk(void) +{
- return gd->arch.timer_freq;
+void _machine_restart(void) +{
SYSCTL_SIZE);
- while (1)
writel(SYS_RST, sysc + SYSCTL_RSTCTL_REG);
+} diff --git a/arch/mips/mach-mtmips/mt7621/mt7621.h b/arch/mips/mach-mtmips/mt7621/mt7621.h new file mode 100644 index 0000000000..916cc993b4 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/mt7621.h @@ -0,0 +1,229 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/*
+#ifndef _MT7621_H_ +#define _MT7621_H_
+#define SYSCTL_BASE 0x1e000000 +#define SYSCTL_SIZE 0x100 +#define TIMER_BASE 0x1e000100 +#define TIMER_SIZE 0x100 +#define RBUS_BASE 0x1e000400 +#define RBUS_SIZE 0x100 +#define GPIO_BASE 0x1e000600 +#define GPIO_SIZE 0x100 +#define DMA_CFG_ARB_BASE 0x1e000800 +#define DMA_CFG_ARB_SIZE 0x100 +#define SPI_BASE 0x1e000b00 +#define SPI_SIZE 0x100 +#define UART1_BASE 0x1e000c00 +#define UART1_SIZE 0x100 +#define UART2_BASE 0x1e000d00 +#define UART2_SIZE 0x100 +#define UART3_BASE 0x1e000e00 +#define UART3_SIZE 0x100 +#define NFI_BASE 0x1e003000 +#define NFI_SIZE 0x800 +#define NFI_ECC_BASE 0x1e003800 +#define NFI_ECC_SIZE 0x800 +#define DRAMC_BASE 0x1e005000 +#define DRAMC_SIZE 0x1000 +#define FE_BASE 0x1e100000 +#define FE_SIZE 0xe000 +#define GMAC_BASE 0x1e110000 +#define GMAC_SIZE 0x8000 +#define SSUSB_BASE 0x1e1c0000 +#define SSUSB_SIZE 0x40000
- /* GIC Base Address */
+#define MIPS_GIC_BASE 0x1fbc0000
- /* CPC Base Address */
+#define MIPS_CPC_BASE 0x1fbf0000
- /* Flash Memory-mapped Base Address */
+#define FLASH_MMAP_BASE 0x1fc00000 +#define TPL_INFO_OFFSET 0x40 +#define TPL_INFO_MAGIC 0x31323637 /* Magic "7621" */
+/* SRAM */ +#define FE_SRAM_BASE1 0x8000 +#define FE_SRAM_BASE2 0xa000
+/* SYSCTL_BASE */ +#define SYSCTL_CHIP_REV_ID_REG 0x0c +#define CPU_ID 0x20000 +#define PKG_ID 0x10000 +#define VER_ID_S 8 +#define VER_ID_M 0xf00 +#define ECO_ID_S 0 +#define ECO_ID_M 0x0f
+#define SYSCTL_SYSCFG0_REG 0x10 +#define XTAL_MODE_SEL_S 6 +#define XTAL_MODE_SEL_M 0x1c0 +#define DRAM_TYPE 0x10 +#define CHIP_MODE_S 0 +#define CHIP_MODE_M 0x0f
+#define BOOT_SRAM_BASE_REG 0x20
+#define SYSCTL_CLKCFG0_REG 0x2c +#define CPU_CLK_SEL_S 30 +#define CPU_CLK_SEL_M 0xc0000000 +#define MPLL_CFG_SEL_S 23 +#define MPLL_CFG_SEL_M 0x800000
+#define SYSCTL_RSTCTL_REG 0x34 +#define MCM_RST 0x04 +#define SYS_RST 0x01
+#define SYSCTL_CUR_CLK_STS_REG 0x44 +#define CUR_CPU_FDIV_S 8 +#define CUR_CPU_FDIV_M 0x1f00 +#define CUR_CPU_FFRAC_S 0 +#define CUR_CPU_FFRAC_M 0x1f
+#define SYSCTL_GPIOMODE_REG 0x60 +#define UART2_MODE_S 5 +#define UART2_MODE_M 0x60 +#define UART3_MODE_S 3 +#define UART3_MODE_M 0x18 +#define UART1_MODE 0x02
+/* RBUS_BASE */ +#define RBUS_DYN_CFG0_REG 0x0010 +#define CPU_FDIV_S 8 +#define CPU_FDIV_M 0x1f00 +#define CPU_FFRAC_S 0 +#define CPU_FFRAC_M 0x1f
+/* DMA_CFG_ARB_BASE */ +#define DMA_ROUTE_REG 0x000c
+/* SPI_BASE */ +#define SPI_SPACE_REG 0x003c +#define FS_SLAVE_SEL_S 12 +#define FS_SLAVE_SEL_M 0x70000 +#define FS_CLK_SEL_S 0 +#define FS_CLK_SEL_M 0xfff
+/* FE_BASE */ +#define FE_RST_GLO_REG 0x0004 +#define FE_PSE_RAM 0x04 +#define FE_PSE_MEM_EN 0x02 +#define FE_PSE_RESET 0x01
+/* SSUSB_BASE */ +#define SSUSB_MAC_CK_CTRL_REG 0x10784 +#define SSUSB_MAC3_SYS_CK_GATE_MASK_TIME_S 16 +#define SSUSB_MAC3_SYS_CK_GATE_MASK_TIME_M 0xff0000 +#define SSUSB_MAC2_SYS_CK_GATE_MASK_TIME_S 8 +#define SSUSB_MAC2_SYS_CK_GATE_MASK_TIME_M 0xff00 +#define SSUSB_MAC3_SYS_CK_GATE_MODE_S 2 +#define SSUSB_MAC3_SYS_CK_GATE_MODE_M 0x0c +#define SSUSB_MAC2_SYS_CK_GATE_MODE_S 0 +#define SSUSB_MAC2_SYS_CK_GATE_MODE_M 0x03
+#define SSUSB_B2_ROSC_0_REG 0x10a40 +#define SSUSB_RING_OSC_CNTEND_S 23 +#define SSUSB_RING_OSC_CNTEND_M 0xff800000 +#define SSUSB_XTAL_OSC_CNTEND_S 16 +#define SSUSB_XTAL_OSC_CNTEND_M 0x7f0000 +#define SSUSB_RING_BYPASS_DET 0x01
+#define SSUSB_B2_ROSC_1_REG 0x10a44 +#define SSUSB_RING_OSC_FRC_RECAL_S 17 +#define SSUSB_RING_OSC_FRC_RECAL_M 0x60000 +#define SSUSB_RING_OSC_FRC_SEL 0x01
+#define SSUSB_U3PHYA_1_REG 0x10b04 +#define SSUSB_PCIE_CLKDRV_AMP_S 27 +#define SSUSB_PCIE_CLKDRV_AMP_M 0x38000000 +#define SSUSB_SYSPLL_FBSEL_S 2 +#define SSUSB_SYSPLL_FBSEL_M 0x0c +#define SSUSB_SYSPLL_PREDIV_S 0 +#define SSUSB_SYSPLL_PREDIV_M 0x03
+#define SSUSB_U3PHYA_2_REG 0x10b08 +#define SSUSB_SYSPLL_FBDIV_S 24 +#define SSUSB_SYSPLL_FBDIV_M 0x7f000000 +#define SSUSB_SYSPLL_VCO_DIV_SEL 0x200000 +#define SSUSB_SYSPLL_FPEN 0x2000 +#define SSUSB_SYSPLL_MONCK_EN 0x1000 +#define SSUSB_SYSPLL_VOD_EN 0x200
+#define SSUSB_U3PHYA_3_REG 0x10b10 +#define SSUSB_SYSPLL_PCW_NCPO_S 1 +#define SSUSB_SYSPLL_PCW_NCPO_M 0xfffffffe
+#define SSUSB_U3PHYA_9_REG 0x10b24 +#define SSUSB_PLL_SSC_PRD_S 0 +#define SSUSB_PLL_SSC_PRD_M 0xffff
+#define SSUSB_U3PHYA_11_REG 0x10b2c +#define SSUSB_EQ_CURSEL 0x1000000 +#define SSUSB_RX_DAC_MUX_S 19 +#define SSUSB_RX_DAC_MUX_M 0xf80000 +#define SSUSB_PCIE_SIGDET_VTH_S 5 +#define SSUSB_PCIE_SIGDET_VTH_M 0x60 +#define SSUSB_PCIE_SIGDET_LPF_S 3 +#define SSUSB_PCIE_SIGDET_LPF_M 0x18
+#define DA_SSUSB_PLL_FBKDIV_REG 0x10c1c +#define SSUSB_PLL_FBKDIV_PE2H_S 24 +#define SSUSB_PLL_FBKDIV_PE2H_M 0x7f000000 +#define SSUSB_PLL_FBKDIV_PE1D_S 16 +#define SSUSB_PLL_FBKDIV_PE1D_M 0x7f0000 +#define SSUSB_PLL_FBKDIV_PE1H_S 8 +#define SSUSB_PLL_FBKDIV_PE1H_M 0x7f00 +#define SSUSB_PLL_FBKDIV_U3_S 0 +#define SSUSB_PLL_FBKDIV_U3_M 0x7f
+#define DA_SSUSB_U3PHYA_10_REG 0x10c20 +#define SSUSB_PLL_PREDIV_PE1D_S 18 +#define SSUSB_PLL_PREDIV_PE1D_M 0xc0000 +#define SSUSB_PLL_PREDIV_U3_S 8 +#define SSUSB_PLL_PREDIV_U3_M 0x300 +#define SSUSB_PLL_FBKDI_S 0 +#define SSUSB_PLL_FBKDI_M 0x07
+#define DA_SSUSB_PLL_PCW_NCPO_REG 0x10c24 +#define SSUSB_PLL_PCW_NCPO_U3_S 0 +#define SSUSB_PLL_PCW_NCPO_U3_M 0x7fffffff
+#define DA_SSUSB_PLL_SSC_DELTA1_REG 0x10c38 +#define SSUSB_PLL_SSC_DELTA1_PE1H_S 16 +#define SSUSB_PLL_SSC_DELTA1_PE1H_M 0xffff0000 +#define SSUSB_PLL_SSC_DELTA1_U3_S 0 +#define SSUSB_PLL_SSC_DELTA1_U3_M 0xffff
+#define DA_SSUSB_U3PHYA_21_REG 0x10c40 +#define SSUSB_PLL_SSC_DELTA_U3_S 16 +#define SSUSB_PLL_SSC_DELTA_U3_M 0xffff0000 +#define SSUSB_PLL_SSC_DELTA1_PE2D_S 0 +#define SSUSB_PLL_SSC_DELTA1_PE2D_M 0xffff
+/* MT7621 specific CM values */
+/* GCR_REGx_BASE */ +#define GCR_REG0_BASE_VALUE 0x1c000000 +#define GCR_REG1_BASE_VALUE 0x60000000 +#define GCR_REG2_BASE_VALUE 0x1c000000 +#define GCR_REG3_BASE_VALUE 0x1c000000
+/* GCR_REGx_MASK */ +#define GCR_REG0_MASK_VALUE 0x0000fc00 /* 64M Bus */ +#define GCR_REG1_MASK_VALUE 0x0000f000 /* 256M PCI Mem */ +#define GCR_REG2_MASK_VALUE 0x0000fc00 /* unused */ +#define GCR_REG3_MASK_VALUE 0x0000fc00 /* unused */
+#ifndef __ASSEMBLY__ +unsigned long get_xtal_mhz(void); +#endif
+#endif /* _MT7621_H_ */ diff --git a/arch/mips/mach-mtmips/mt7621/serial.c b/arch/mips/mach-mtmips/mt7621/serial.c new file mode 100644 index 0000000000..0ccc71dc75 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/serial.c @@ -0,0 +1,23 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+#include <asm/io.h> +#include <asm/addrspace.h> +#include "mt7621.h"
+void board_debug_uart_init(void) +{
- void __iomem *base = ioremap_nocache(SYSCTL_BASE,
SYSCTL_SIZE);
+#if CONFIG_DEBUG_UART_BASE == 0xbe000c00 /* KSEG1ADDR(UART1_BASE) */
- clrbits_32(base + SYSCTL_GPIOMODE_REG, UART1_MODE);
+#elif CONFIG_DEBUG_UART_BASE == 0xbe000d00 /* KSEG1ADDR(UART2_BASE) */
- clrbits_32(base + SYSCTL_GPIOMODE_REG, UART2_MODE_M);
+#elif CONFIG_DEBUG_UART_BASE == 0xbe000e00 /* KSEG1ADDR(UART3_BASE) */
- clrbits_32(base + SYSCTL_GPIOMODE_REG, UART3_MODE_M);
+#endif +} diff --git a/arch/mips/mach-mtmips/mt7621/spl/Makefile b/arch/mips/mach-mtmips/mt7621/spl/Makefile new file mode 100644 index 0000000000..ebe54e79b9 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/spl/Makefile @@ -0,0 +1,9 @@
+extra-y += start.o
+obj-y += spl.o +obj-y += cps.o +obj-y += dram.o +obj-y += serial.o +obj-y += launch.o +obj-y += launch_ll.o diff --git a/arch/mips/mach-mtmips/mt7621/spl/cps.c b/arch/mips/mach-mtmips/mt7621/spl/cps.c new file mode 100644 index 0000000000..61f319f45f --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/spl/cps.c @@ -0,0 +1,152 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+#include <asm/io.h> +#include <asm/addrspace.h> +#include <asm/mipsregs.h> +#include <asm/cm.h> +#include "../mt7621.h"
+/* GIC Shared Register Bases */ +#define GIC_SH_POL_BASE 0x100 +#define GIC_SH_TRIG_BASE 0x180 +#define GIC_SH_RMASK_BASE 0x300 +#define GIC_SH_SMASK_BASE 0x380 +#define GIC_SH_MASK_BASE 0x400 +#define GIC_SH_PEND_BASE 0x480 +#define GIC_SH_MAP_PIN_BASE 0x500 +#define GIC_SH_MAP_VPE_BASE 0x2000
+/* GIC Registers */ +#define GIC_SH_POL31_0 (GIC_SH_POL_BASE + 0x00) +#define GIC_SH_POL63_32 (GIC_SH_POL_BASE + 0x04)
+#define GIC_SH_TRIG31_0 (GIC_SH_TRIG_BASE + 0x00) +#define GIC_SH_TRIG63_32 (GIC_SH_TRIG_BASE + 0x04)
+#define GIC_SH_RMASK31_0 (GIC_SH_RMASK_BASE + 0x00) +#define GIC_SH_RMASK63_32 (GIC_SH_RMASK_BASE + 0x04)
+#define GIC_SH_SMASK31_0 (GIC_SH_SMASK_BASE + 0x00) +#define GIC_SH_SMASK63_32 (GIC_SH_SMASK_BASE + 0x04)
+#define GIC_SH_MAP_PIN(n) (GIC_SH_MAP_PIN_BASE + (n) * 4)
+#define GIC_SH_MAP_VPE(n, v) (GIC_SH_MAP_VPE_BASE + (n) * 0x20 + ((v) / 32) * 4) +#define GIC_SH_MAP_VPE31_0(n) GIC_SH_MAP_VPE(n, 0)
+/* GIC_SH_MAP_PIN fields */ +#define GIC_MAP_TO_PIN BIT(31) +#define GIC_MAP_TO_NMI BIT(30) +#define GIC_MAP GENMASK(5, 0) +#define GIC_MAP_SHIFT 0
+static void cm_init(void __iomem *cm_base) +{
- u32 num_cores;
- num_cores = ((readl(cm_base + GCR_CONFIG) &
GCR_CONFIG_PCORES) >>
GCR_CONFIG_PCORES_SHIFT) + 1;
- writel((1 << num_cores) - 1, cm_base + GCR_ACCESS);
- writel(GCR_REG0_BASE_VALUE, cm_base + GCR_REG0_BASE);
- writel(GCR_REG1_BASE_VALUE, cm_base + GCR_REG1_BASE);
- writel(GCR_REG2_BASE_VALUE, cm_base + GCR_REG2_BASE);
- writel(GCR_REG3_BASE_VALUE, cm_base + GCR_REG3_BASE);
- clrsetbits_32(cm_base + GCR_REG0_MASK,
GCR_REGn_MASK_ADDRMASK |
GCR_REGn_MASK_CMTGT,
GCR_REGn_MASK_CMTGT_IOCU0);
- clrsetbits_32(cm_base + GCR_REG1_MASK,
(GCR_REG1_MASK_VALUE <<
- clrsetbits_32(cm_base + GCR_REG2_MASK,
(GCR_REG2_MASK_VALUE <<
- clrsetbits_32(cm_base + GCR_REG3_MASK,
(GCR_REG3_MASK_VALUE <<
- clrbits_32(cm_base + GCR_BASE, CM_DEFAULT_TARGET_MASK);
- setbits_32(cm_base + GCR_CONTROL, GCR_CONTROL_SYNCCTL);
+static void gic_init(void) +{
- void __iomem *gic_base = (void *)KSEG1ADDR(MIPS_GIC_BASE);
- int i;
- /* Interrupt 0..5: Level Trigger, Active High */
- writel(0, gic_base + GIC_SH_TRIG31_0);
- writel(0x3f, gic_base + GIC_SH_RMASK31_0);
- writel(0x3f, gic_base + GIC_SH_POL31_0);
- writel(0x3f, gic_base + GIC_SH_SMASK31_0);
- /* Interrupt 56..63: Edge Trigger, Rising Edge */
- /* Hardcoded to set up the last 8 external interrupts for
IPI. */
- writel(0xff000000, gic_base + GIC_SH_TRIG63_32);
- writel(0xff000000, gic_base + GIC_SH_RMASK63_32);
- writel(0xff000000, gic_base + GIC_SH_POL63_32);
- writel(0xff000000, gic_base + GIC_SH_SMASK63_32);
- /* Map interrupt source to particular hardware interrupt
pin */
- /* source {0,1,2,3,4,5} -> pin {0,0,4,3,0,5} */
- writel(GIC_MAP_TO_PIN | 0, gic_base + GIC_SH_MAP_PIN(0));
- writel(GIC_MAP_TO_PIN | 0, gic_base + GIC_SH_MAP_PIN(1));
- writel(GIC_MAP_TO_PIN | 4, gic_base + GIC_SH_MAP_PIN(2));
- writel(GIC_MAP_TO_PIN | 3, gic_base + GIC_SH_MAP_PIN(3));
- writel(GIC_MAP_TO_PIN | 0, gic_base + GIC_SH_MAP_PIN(4));
- writel(GIC_MAP_TO_PIN | 5, gic_base + GIC_SH_MAP_PIN(5));
- /* source 56~59 -> pin 1, 60~63 -> pin 2 */
- writel(GIC_MAP_TO_PIN | 1, gic_base + GIC_SH_MAP_PIN(56));
- writel(GIC_MAP_TO_PIN | 1, gic_base + GIC_SH_MAP_PIN(57));
- writel(GIC_MAP_TO_PIN | 1, gic_base + GIC_SH_MAP_PIN(58));
- writel(GIC_MAP_TO_PIN | 1, gic_base + GIC_SH_MAP_PIN(59));
- writel(GIC_MAP_TO_PIN | 2, gic_base + GIC_SH_MAP_PIN(60));
- writel(GIC_MAP_TO_PIN | 2, gic_base + GIC_SH_MAP_PIN(61));
- writel(GIC_MAP_TO_PIN | 2, gic_base + GIC_SH_MAP_PIN(62));
- writel(GIC_MAP_TO_PIN | 2, gic_base + GIC_SH_MAP_PIN(63));
- /* Interrupt map to VPE (bit mask) */
- for (i = 0; i < 32; i++)
writel(BIT(0), gic_base + GIC_SH_MAP_VPE31_0(i));
* Direct GIC_int 56..63 to vpe 0..3
* MIPS Linux convention that last 16 interrupts
implemented be set
* aside for IPI signaling.
* The actual interrupts are tied low and software sends
interrupts
* via GIC_SH_WEDGE writes.
- for (i = 0; i < 4; i++) {
writel(BIT(i), gic_base + GIC_SH_MAP_VPE31_0(i +
56));
60));
+void mt7621_cps_init(void) +{
- void __iomem *cm_base = (void
*)KSEG1ADDR(CONFIG_MIPS_CM_BASE);
- /* Enable GIC */
- writel(MIPS_GIC_BASE | GCR_GIC_EN, cm_base +
GCR_GIC_BASE);
- /* Enable CPC */
- writel(MIPS_CPC_BASE | GCR_CPC_EN, cm_base +
GCR_CPC_BASE);
- gic_init();
- cm_init(cm_base);
+} diff --git a/arch/mips/mach-mtmips/mt7621/spl/dram.c b/arch/mips/mach-mtmips/mt7621/spl/dram.c new file mode 100644 index 0000000000..827c4a71e9 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/spl/dram.c @@ -0,0 +1,155 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+#include <asm/io.h> +#include <asm/sections.h> +#include <asm/byteorder.h> +#include <asm/addrspace.h> +#include <linux/string.h> +#include "../mt7621.h" +#include "dram.h"
+static const u32 ddr2_act[DDR_PARAM_SIZE] = { +#if defined(CONFIG_MT7621_DRAM_DDR2_512M)
- 0xAA00AA00, 0xAA00AA00, 0x00000007, 0x22174441,
- 0x00000000, 0xF0748661, 0x40001273, 0x9F0A0481,
- 0x0304692F, 0x15602842, 0x00008888, 0x88888888,
- 0x00000000, 0x00000000, 0x00000000, 0x07100000,
- 0x00001B63, 0x00002000, 0x00004000, 0x00006000,
- 0x00000000, 0x00000000, 0x00000000, 0x00000000,
+#elif defined(CONFIG_MT7621_DRAM_DDR2_512M_W9751G6KB_A02_1066MHZ)
- 0xAA00AA00, 0xAA00AA00, 0x00000007, 0x33484584,
- 0x00000000, 0xF07486A1, 0x50001273, 0x9F010481,
- 0x0304693F, 0x15602842, 0x00008888, 0x88888888,
- 0x00000000, 0x00000000, 0x00000010, 0x07100000,
- 0x00001F73, 0x00002000, 0x00004000, 0x00006000,
+#elif defined(CONFIG_MT7621_DRAM_DDR2_1024M_W971GG6KB25_800MHZ)
- 0xAA00AA00, 0xAA00AA00, 0x00000007, 0x22174430,
- 0x01000000, 0xF0748661, 0x40001273, 0x9F0F0481,
+#elif defined(CONFIG_MT7621_DRAM_DDR2_1024M_W971GG6KB18_1066MHZ)
- 0x01000000, 0xF07486A1, 0x50001273, 0x9F070481,
+#else /* CONFIG_MT7621_DRAM_DDR2_1024M */
+#endif +};
+static const u32 ddr3_act[DDR_PARAM_SIZE] = { +#if defined(CONFIG_MT7621_DRAM_DDR3_1024M)
- 0xAA00AA00, 0xAA00AA00, 0x00000007, 0x44694683,
- 0x01000000, 0xF07486A1, 0xC287221D, 0x9F060481,
- 0x03046948, 0x15602842, 0x00008888, 0x88888888,
- 0x00000000, 0x00000000, 0x00000210, 0x07100000,
- 0x00001B61, 0x00002040, 0x00004010, 0x00006000,
- 0x0C000000, 0x07070000, 0x00000000, 0x00000000,
+#elif defined(CONFIG_MT7621_DRAM_DDR3_4096M)
- 0x01000000, 0xF07486A1, 0xC287221D, 0x9F0F0481,
- 0x00000000, 0x00000000, 0x00000240, 0x07100000,
+#elif defined(CONFIG_MT7621_DRAM_DDR3_1024M_KGD)
- 0xFF00FF00, 0xFF00FF00, 0x00000007, 0x44694683,
- 0x01000000, 0xF07406A1, 0xC287221D, 0x9F060481,
- 0x03046923, 0x152f2842, 0x00008888, 0x88888888,
- 0x0C000000, 0x07070000, 0x000C0000, 0x00000000,
+#else /* CONFIG_MT7621_DRAM_DDR3_2048M */
- 0xAA00AA00, 0xAA00AA00, 0x00000007, 0x44694673,
- 0x01000000, 0xF07486A1, 0xC287221D, 0x9F050481,
- 0x00000000, 0x00000000, 0x00000220, 0x07100000,
+#endif +};
+#if defined(CONFIG_MT7621_DRAM_FREQ_400) +#define DDR_FREQ_PARAM 0x41000000 +#elif defined(CONFIG_MT7621_DRAM_FREQ_1066) +#define DDR_FREQ_PARAM 0x21000000 +#elif defined(CONFIG_MT7621_DRAM_FREQ_1200) +#define DDR_FREQ_PARAM 0x11000000 +#else /* CONFIG_MT7621_DRAM_FREQ_800 */ +#define DDR_FREQ_PARAM 0x31000000 +#endif
+#define RG_MEPL_FBDIV_S 4 +#define RG_MEPL_FBDIV_M 0x7f
+static inline void word_copy(u32 *dest, const u32 *src, u32 count) +{
- u32 i;
- for (i = 0; i < count; i++)
dest[i] = src[i];
+static u32 calc_cpu_pll_val(void) +{
- u32 div, baseval, fb;
- div = get_xtal_mhz();
- if (div == 40) {
div /= 2;
baseval = 0xc0005802;
- } else {
baseval = 0xc0004802;
- fb = CONFIG_MT7621_CPU_FREQ / div - 1;
- if (fb > RG_MEPL_FBDIV_M)
fb = RG_MEPL_FBDIV_M;
- return baseval | (fb << RG_MEPL_FBDIV_S);
+void prepare_stage_bin(void) +{
- u32 stage_size;
- const struct stage_header *stock_stage_bin =
(const struct stage_header *)__image_copy_end;
- struct stage_header *new_stage_bin =
(struct stage_header *)STAGE_LOAD_ADDR;
- if (be32_to_cpu(stock_stage_bin->ep) != STAGE_LOAD_ADDR) {
/* Possible wrong binary blob. Hang here */
for (;;)
perhaps a panic() with an according error message should be used?
This should be ok if simple printf is used.
- stage_size = be32_to_cpu(stock_stage_bin->stage_size);
- word_copy((u32 *)new_stage_bin, (const u32
*)stock_stage_bin,
(stage_size + sizeof(u32) - 1) / sizeof(u32));
- word_copy(new_stage_bin->ddr2_act, ddr2_act,
DDR_PARAM_SIZE);
- word_copy(new_stage_bin->ddr3_act, ddr3_act,
DDR_PARAM_SIZE);
- new_stage_bin->cpu_pll_cfg = calc_cpu_pll_val();
- new_stage_bin->ddr_pll_cfg = DDR_FREQ_PARAM;
- new_stage_bin->baudrate = CONFIG_BAUDRATE;
+} diff --git a/arch/mips/mach-mtmips/mt7621/spl/dram.h b/arch/mips/mach-mtmips/mt7621/spl/dram.h new file mode 100644 index 0000000000..7322c58276 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/spl/dram.h @@ -0,0 +1,39 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/*
+#ifndef _MT7621_DRAM_H_ +#define _MT7621_DRAM_H_
+#define STAGE_LOAD_ADDR 0xBE108800
+#ifndef __ASSEMBLY__ +#include <linux/types.h>
+#define DDR_PARAM_SIZE 24
+struct stage_header {
- u32 jump_insn[2];
- u32 ep;
- u32 stage_size;
- u32 has_stage2;
- u32 next_ep;
- u32 next_size;
- u32 next_offset;
- u32 cpu_pll_cfg;
- u32 ddr_pll_cfg;
- u32 reserved2[6];
- char build_tag[32];
- u32 ddr3_act[DDR_PARAM_SIZE];
- u32 padding1[2];
- u32 ddr2_act[DDR_PARAM_SIZE];
- u32 padding2[2];
- u32 baudrate;
- u32 padding3;
+}; +#endif
+#endif /* _MT7621_DRAM_H_ */ diff --git a/arch/mips/mach-mtmips/mt7621/spl/launch.c b/arch/mips/mach-mtmips/mt7621/spl/launch.c new file mode 100644 index 0000000000..37c20a5f56 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/spl/launch.c @@ -0,0 +1,100 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+#include <asm/io.h> +#include <asm/cm.h> +#include <asm/sections.h> +#include <asm/addrspace.h> +#include <asm/mipsmtregs.h> +#include <linux/sizes.h> +#include <time.h> +#include <cpu_func.h> +#include "launch.h" +#include "../mt7621.h"
+/* Cluster Power Controller (CPC) offsets */ +#define CPC_CL_OTHER 0x2010 +#define CPC_CO_CMD 0x4000
+/* CPC_CL_OTHER fields */ +#define CPC_CL_OTHER_CORENUM_SHIFT 16 +#define CPC_CL_OTHER_CORENUM GENMASK(23, 16)
+/* CPC_CO_CMD */ +#define PWR_UP 3
+#define NUM_CORES 2 +#define NUM_CPUS 4 +#define WAIT_CPUS_TIMEOUT 4000
+static void copy_launch_wait_code(void) +{
- memset((void *)KSEG1, 0, SZ_4K);
- memcpy((void *)KSEG1ADDR(LAUNCH_WAITCODE),
&launch_wait_code_start,
&launch_wait_code_end - &launch_wait_code_start);
- invalidate_dcache_range(KSEG0, SZ_4K);
+static void bootup_secondary_core(void) +{
- void __iomem *cpcbase = (void __iomem
*)KSEG1ADDR(MIPS_CPC_BASE);
- int i;
- for (i = 1; i < NUM_CORES; i++) {
writel(i << CPC_CL_OTHER_CORENUM_SHIFT, cpcbase +
CPC_CL_OTHER);
writel(PWR_UP, cpcbase + CPC_CO_CMD);
+void secondary_cpu_init(void) +{
- void __iomem *sysc = (void __iomem
- u32 i, dual_core = 0, cpuready = 1, cpumask = 0x03;
- ulong wait_tick;
- struct cpulaunch_t *c;
- /* Copy LAUNCH wait code used by other VPEs */
- copy_launch_wait_code();
- dual_core = readl(sysc + SYSCTL_CHIP_REV_ID_REG) & CPU_ID;
- if (dual_core) {
/* Bootup secondary core for MT7621A */
cpumask = 0x0f;
/* Make BootROM/TPL redirect Core1's bootup flow
to our entry point */
writel((uintptr_t)&_start, sysc +
BOOT_SRAM_BASE_REG);
bootup_secondary_core();
- /* Join the coherent domain */
- join_coherent_domain(dual_core ? 2 : 1);
- /* Bootup Core0/VPE1 */
- boot_vpe1();
- /* Wait for all CPU ready */
- wait_tick = get_timer(0) + WAIT_CPUS_TIMEOUT;
- while (time_before(get_timer(0), wait_tick)) {
/* CPU0 is obviously ready */
for (i = 1; i < NUM_CPUS; i++) {
c = (struct cpulaunch_t
*)(KSEG0ADDR(CPULAUNCH) +
(i <<
LOG2CPULAUNCH));
if (c->flags & LAUNCH_FREADY)
cpuready |= BIT(i);
if ((cpuready & cpumask) == cpumask)
break;
+} diff --git a/arch/mips/mach-mtmips/mt7621/spl/launch.h b/arch/mips/mach-mtmips/mt7621/spl/launch.h new file mode 100644 index 0000000000..f34250d605 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/spl/launch.h @@ -0,0 +1,52 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/*
+#ifndef _LAUNCH_H_ +#define _LAUNCH_H_
+struct cpulaunch_t {
- unsigned long pc;
- unsigned long gp;
- unsigned long sp;
- unsigned long a0;
- unsigned long _pad[3]; /* pad to cache line size to avoid
thrashing */
- unsigned long flags;
+extern char launch_wait_code_start; +extern char launch_wait_code_end;
+void join_coherent_domain(int ncores); +void boot_vpe1(void);
+#else
+#define LAUNCH_PC 0 +#define LAUNCH_GP 4 +#define LAUNCH_SP 8 +#define LAUNCH_A0 12 +#define LAUNCH_FLAGS 28
+#define LOG2CPULAUNCH 5
+#define LAUNCH_FREADY 1 +#define LAUNCH_FGO 2 +#define LAUNCH_FGONE 4
+#define LAUNCH_WAITCODE 0x00000d00 +#define SCRLAUNCH 0x00000e00 +#define CPULAUNCH 0x00000f00 +#define NCPULAUNCH 8
+/* Polling period in count cycles for secondary CPU's */ +#define LAUNCHPERIOD 10000
+#endif /* _LAUNCH_H_ */ diff --git a/arch/mips/mach-mtmips/mt7621/spl/launch_ll.S b/arch/mips/mach-mtmips/mt7621/spl/launch_ll.S new file mode 100644 index 0000000000..55a8fff9af --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/spl/launch_ll.S @@ -0,0 +1,357 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/*
+#include <asm/cm.h> +#include <asm/asm.h> +#include <asm/regdef.h> +#include <asm/cacheops.h> +#include <asm/mipsregs.h> +#include <asm/addrspace.h> +#include <asm/mipsmtregs.h> +#include "launch.h"
- .macro cache_loop curr, end, line_sz, op
+10: cache \op, 0(\curr)
- PTR_ADDU \curr, \curr, \line_sz
- bne \curr, \end, 10b
- .endm
- .set mt
- Join the coherent domain
- a0 = number of cores
+LEAF(join_coherent_domain)
* Enable coherence and allow interventions from all other
cores.
* (Write access enabled via GCR_ACCESS by core 0.)
- li t1, 1
- sll t1, a0
- addiu t1, -1
- li t0, KSEG1ADDR(CONFIG_MIPS_CM_BASE)
- sw t1, GCR_Cx_COHERENCE(t0)
- ehb
- move t2, zero
+_next_coherent_core:
- sll t1, t2, GCR_Cx_OTHER_CORENUM_SHIFT
- sw t1, GCR_Cx_OTHER(t0)
+_busy_wait_coherent_core:
- lw t1, GCR_CO_COHERENCE(t0)
- beqz t1, _busy_wait_coherent_core
nop
- addiu t2, 1
- bne t2, a0, _next_coherent_core
nop
- jr ra
nop
the nop's are actually redundant in normal reorder assembly mode and could be omitted. The assembler will add them automatically if there are no other instructions feasible for the delay slot
OK. I'll remove all redundant nop's.
- END(join_coherent_domain)
- All VPEs other than VPE0 will go here.
+LEAF(launch_vpe_entry)
- mfc0 t0, CP0_EBASE
- and t0, t0, MIPS_EBASE_CPUNUM
- /* per-VPE cpulaunch_t */
- li a0, KSEG0ADDR(CPULAUNCH)
- sll t1, t0, LOG2CPULAUNCH
- addu a0, t1
- /* Set CPU online flag */
- li t0, LAUNCH_FREADY
- sw t0, LAUNCH_FLAGS(a0)
- /* Enable count interrupt in mask, but do not enable
interrupts */
- mfc0 t0, CP0_STATUS
- ori t0, STATUSF_IP7
- mtc0 t0, CP0_STATUS
- /* VPEs executing in wait code do not need a stack */
- li t9, KSEG0ADDR(LAUNCH_WAITCODE)
- jr t9
nop
- END(launch_vpe_entry)
- This function will not be executed in place.
- It will be copied into memory, and VPEs other than VPE0 will be
- started to run into this in-memory function.
+LEAF(launch_wait_code)
- .globl launch_wait_code_start
+launch_wait_code_start:
- move t0, a0
+start_poll:
- /* Poll CPU go flag */
- mtc0 zero, CP0_COUNT
- li t1, LAUNCHPERIOD
- mtc0 t1, CP0_COMPARE
+time_wait:
- /* Software wait */
- mfc0 t2, CP0_COUNT
- subu t2, t1
- bltz t2, time_wait
nop
- /* Check the launch flag */
- lw t3, LAUNCH_FLAGS(t0)
- and t3, LAUNCH_FGO
- beqz t3, start_poll
nop
- /* Reset the counter and interrupts to give naive clients
a chance */
- mfc0 t1, CP0_STATUS
- ins t1, zero, STATUSB_IP7, 1
- mtc0 t1, CP0_STATUS
- mfc0 t1, CP0_COUNT
- subu t1, 1
- /* Jump to kernel */
- lw t9, LAUNCH_PC(t0)
- lw gp, LAUNCH_GP(t0)
- lw sp, LAUNCH_SP(t0)
- lw a0, LAUNCH_A0(t0)
- move a1, zero
- move a2, zero
- move a3, zero
- ori t3, LAUNCH_FGONE
- sw t3, LAUNCH_FLAGS(t0)
- jr t9
nop
- .globl launch_wait_code_end
+launch_wait_code_end:
- END(launch_wait_code)
- Core1 will go here.
+LEAF(launch_core_entry)
- /* Disable caches */
- bal mips_cache_disable
nop
- /* Initialize L1 cache only */
- li a0, CONFIG_SYS_ICACHE_SIZE
- li a1, CONFIG_SYS_ICACHE_LINE_SIZE
- li a2, CONFIG_SYS_DCACHE_SIZE
- li a3, CONFIG_SYS_DCACHE_LINE_SIZE
- mtc0 zero, CP0_TAGLO
- mtc0 zero, CP0_TAGLO, 2
- ehb
* Initialize the I-cache first,
- li t0, KSEG0
- addu t1, t0, a0
- /* clear tag to invalidate */
- cache_loop t0, t1, a1, INDEX_STORE_TAG_I
+#ifdef CONFIG_SYS_MIPS_CACHE_INIT_RAM_LOAD
- /* fill once, so data field parity is correct */
- PTR_LI t0, KSEG0
- cache_loop t0, t1, a1, FILL
- /* invalidate again - prudent but not strictly necessary
- PTR_LI t0, KSEG0
* then initialize D-cache.
- PTR_LI t0, KSEG0
- PTR_ADDU t1, t0, a2
- /* clear all tags */
- cache_loop t0, t1, a3, INDEX_STORE_TAG_D
- /* load from each line (in cached space) */
- PTR_LI t0, KSEG0
+2: LONG_L zero, 0(t0)
- PTR_ADDU t0, a3
bne t0, t1, 2b
- PTR_LI t0, KSEG0
- /* Set Cache Mode */
- mfc0 t0, CP0_CONFIG
- li t1, CONF_CM_CACHABLE_COW
- ins t0, t1, 0, 3
- mtc0 t0, CP0_CONFIG
- li a0, 2
- bal join_coherent_domain
nop
- bal boot_vpe1
nop
- b launch_vpe_entry
nop
- END(launch_core_entry)
- Bootup VPE1.
- This subroutine must be executed from VPE0 with VPECONF0[MVP]
already set.
+LEAF(boot_vpe1)
- mfc0 t0, CP0_MVPCONF0
- /* a0 = number of TCs - 1 */
- ext a0, t0, MVPCONF0_PTC_SHIFT, 8
- beqz a0, _vpe1_init_done
nop
- /* a1 = number of VPEs - 1 */
- ext a1, t0, MVPCONF0_PVPE_SHIFT, 4
- beqz a1, _vpe1_init_done
nop
- /* a2 = current TC No. */
- move a2, zero
- /* Enter VPE Configuration State */
- mfc0 t0, CP0_MVPCONTROL
- or t0, MVPCONTROL_VPC
- mtc0 t0, CP0_MVPCONTROL
- ehb
+_next_tc:
- /* Set the TC number to be used on MTTR and MFTR
instructions */
- mfc0 t0, CP0_VPECONTROL
- ins t0, a2, 0, 8
- mtc0 t0, CP0_VPECONTROL
- ehb
- /* TC0 is already bound */
- beqz a2, _next_vpe
nop
- /* Halt current TC */
- li t0, TCHALT_H
- mttc0 t0, CP0_TCHALT
- ehb
- /* If there is spare TC, bind it to the last VPE (VPE[a1])
- slt t1, a1, a2
- bnez t1, _vpe_bind_tc
move t1, a1
- /* Set Exclusive TC for active TC */
- mftc0 t0, CP0_VPECONF0
- ins t0, a2, VPECONF0_XTC_SHIFT, 8
- mttc0 t0, CP0_VPECONF0
- move t1, a2
+_vpe_bind_tc:
- /* Bind TC to a VPE */
- mftc0 t0, CP0_TCBIND
- ins t0, t1, TCBIND_CURVPE_SHIFT, 4
- mttc0 t0, CP0_TCBIND
* Set up CP0_TCSTATUS register:
* Disable Coprocessor Usable bits
* Disable MDMX/DSP ASE
* Clear Dirty TC
* not dynamically allocatable
* not allocated
* Kernel mode
* interrupt exempt
* ASID 0
- li t0, TCSTATUS_IXMT
- mttc0 t0, CP0_TCSTATUS
+_next_vpe:
- slt t1, a1, a2
- bnez t1, _done_vpe # No more VPEs
nop
- /* Disable TC multi-threading */
- mftc0 t0, CP0_VPECONTROL
- ins t0, zero, VPECONTROL_TE_SHIFT, 1
- mttc0 t0, CP0_VPECONTROL
- /* Skip following configuration for TC0 */
- beqz a2, _done_vpe
nop
- /* Deactivate VPE, set Master VPE */
- ins t0, zero, VPECONF0_VPA_SHIFT, 1
- or t0, VPECONF0_MVP
- mttc0 t0, CP0_STATUS
- mttc0 zero, CP0_EPC
- mttc0 zero, CP0_CAUSE
- mttc0 t0, CP0_CONFIG
* VPE1 of each core can execute cached as its L1 I$ has
already
* been initialized.
* and the L2$ has been initialized or "disabled" via CCA
override.
- PTR_LA t0, _start
- mttc0 t0, CP0_TCRESTART
- /* Unset Interrupt Exempt, set Activate Thread */
- mftc0 t0, CP0_TCSTATUS
- ins t0, zero, TCSTATUS_IXMT_SHIFT, 1
- ori t0, TCSTATUS_A
- /* Resume TC */
- mttc0 zero, CP0_TCHALT
- /* Activate VPE */
- ori t0, VPECONF0_VPA
+_done_vpe:
- addu a2, 1
- sltu t0, a0, a2
- beqz t0, _next_tc
nop
- /* Enable all activated VPE to execute */
- ori t0, MVPCONTROL_EVP
- /* Exit VPE Configuration State */
- ins t0, zero, MVPCONTROL_VPC_SHIFT, 1
- ehb
+_vpe1_init_done:
- jr ra
nop
- END(boot_vpe1)
diff --git a/arch/mips/mach-mtmips/mt7621/spl/serial.c b/arch/mips/mach-mtmips/mt7621/spl/serial.c new file mode 100644 index 0000000000..5cf093a078 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/spl/serial.c @@ -0,0 +1,24 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+#include <asm/io.h> +#include "../mt7621.h"
+void mtmips_spl_serial_init(void) +{ +#ifdef CONFIG_SPL_SERIAL
SYSCTL_SIZE);
+#if CONFIG_CONS_INDEX == 1
+#elif CONFIG_CONS_INDEX == 2
+#elif CONFIG_CONS_INDEX == 3
+#endif /* CONFIG_CONS_INDEX */ +#endif /* CONFIG_SPL_SERIAL */ +} diff --git a/arch/mips/mach-mtmips/mt7621/spl/spl.c b/arch/mips/mach-mtmips/mt7621/spl/spl.c new file mode 100644 index 0000000000..71d01aa7f5 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/spl/spl.c @@ -0,0 +1,95 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+#include <spl.h> +#include <init.h> +#include <image.h> +#include <vsprintf.h> +#include <malloc.h> +#include <asm/io.h> +#include <asm/sections.h> +#include <asm/addrspace.h> +#include <asm/byteorder.h> +#include <asm/global_data.h> +#include <linux/sizes.h> +#include <mach/serial.h> +#include "../mt7621.h" +#include "dram.h"
+DECLARE_GLOBAL_DATA_PTR;
+struct tpl_info {
- u32 magic;
- u32 size;
+void set_timer_freq_simple(void) +{
- u32 div = get_xtal_mhz();
- /* Round down cpu freq */
- gd->arch.timer_freq = rounddown(CONFIG_MT7621_CPU_FREQ,
div) * 500000; +}
+void __noreturn board_init_f(ulong dummy) +{
- spl_init();
* mtmips_spl_serial_init() is useful if debug uart is
enabled,
* or DM based serial is not enabled.
- mtmips_spl_serial_init();
- preloader_console_init();
- board_init_r(NULL, 0);
+void board_boot_order(u32 *spl_boot_list) +{ +#ifdef CONFIG_MT7621_BOOT_FROM_NAND
- spl_boot_list[0] = BOOT_DEVICE_NAND;
+#else
- spl_boot_list[0] = BOOT_DEVICE_NOR;
+#endif +}
+unsigned long spl_nor_get_uboot_base(void) +{
- const struct tpl_info *tpli;
- const image_header_t *hdr;
- u32 addr;
- addr = FLASH_MMAP_BASE + TPL_INFO_OFFSET;
- tpli = (const struct tpl_info *)KSEG1ADDR(addr);
- if (tpli->magic == TPL_INFO_MAGIC) {
addr = FLASH_MMAP_BASE + tpli->size;
hdr = (const image_header_t *)KSEG1ADDR(addr);
if (image_get_magic(hdr) == IH_MAGIC) {
addr += sizeof(*hdr) +
return KSEG1ADDR(addr);
- panic("Unable to locate SPL payload\n");
+uint32_t spl_nand_get_uboot_raw_page(void) +{
- const struct stage_header *sh = (const struct stage_header
*)&_start;
- u32 addr;
- addr = image_get_header_size() + be32_to_cpu(sh-
stage_size);
- addr = ALIGN(addr, SZ_4K);
- return addr;
+} diff --git a/arch/mips/mach-mtmips/mt7621/spl/start.S b/arch/mips/mach-mtmips/mt7621/spl/start.S new file mode 100644 index 0000000000..3cad3567e7 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/spl/start.S @@ -0,0 +1,226 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/*
+#include <asm-offsets.h> +#include <config.h> +#include <asm/asm.h> +#include <asm/regdef.h> +#include <asm/mipsregs.h> +#include <asm/cacheops.h> +#include <asm/addrspace.h> +#include <asm/mipsmtregs.h> +#include <asm/cm.h> +#include "../mt7621.h" +#include "dram.h"
+#ifndef CONFIG_SYS_INIT_SP_ADDR +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + \
CONFIG_SYS_INIT_SP_OFFSET)
- .macro init_wr sel
- MTC0 zero, CP0_WATCHLO,\sel
- mtc0 t1, CP0_WATCHHI,\sel
- .endm
- .macro setup_stack_gd
- li t0, -16
- PTR_LI t1, CONFIG_SYS_INIT_SP_ADDR
- and sp, t1, t0 # force 16 byte
alignment
- PTR_SUBU \
sp, sp, GD_SIZE # reserve space for
gd
- and sp, sp, t0 # force 16 byte
alignment
- move k0, sp # save gd
pointer +#if CONFIG_VAL(SYS_MALLOC_F_LEN) && \
- !CONFIG_IS_ENABLED(INIT_STACK_WITHOUT_MALLOC_F)
- li t2, CONFIG_VAL(SYS_MALLOC_F_LEN)
- PTR_SUBU \
sp, sp, t2 # reserve space for
early malloc
alignment +#endif
- move fp, sp
- /* Clear gd */
- move t0, k0
+1:
- PTR_S zero, 0(t0)
- PTR_ADDIU t0, PTRSIZE
- blt t0, t1, 1b
nop
- PTR_S sp, GD_MALLOC_BASE(k0) # gd-
malloc_base offset
- .endm
- .set noreorder
+ENTRY(_start)
- b 1f
- /* Stage header required by BootROM */
- .org 0x8
- .word 0 # ep, filled by mkimage
- .word 0 # stage_size, filled by
mkimage
- .word 0 # has_stage2
- .word 0 # next_ep
- .word 0 # next_size
- .word 0 # next_offset
+1:
- /* Init CP0 Status */
- and t0, ST0_IMPL
- or t0, ST0_BEV | ST0_ERL
- ehb
- /* Clear Watch Status bits and disable watch exceptions */
- li t1, 0x7 # Clear I, R and W
conditions
- init_wr 0
- init_wr 1
- init_wr 2
- init_wr 3
- /* Clear WP, IV and SW interrupts */
- mtc0 zero, CP0_CAUSE
- /* Clear timer interrupt (CP0_COUNT cleared on branch to
'reset') */
- mtc0 zero, CP0_COMPARE
- /* VPE1 goes to wait code directly */
- mfc0 t0, CP0_TCBIND
- andi t0, TCBIND_CURVPE
- bnez t0, launch_vpe_entry
nop
- /* Core1 goes to specific launch entry */
- PTR_LI t0, KSEG1ADDR(CONFIG_MIPS_CM_BASE)
- lw t1, GCR_Cx_ID(t0)
- bnez t1, launch_core_entry
nop
- /* MT7530 reset */
- li t0, KSEG1ADDR(SYSCTL_BASE)
- lw t1, SYSCTL_RSTCTL_REG(t0)
- ori t1, MCM_RST
- sw t1, SYSCTL_RSTCTL_REG(t0)
- /* Disable DMA route for PSE SRAM set by BootROM */
- PTR_LI t0, KSEG1ADDR(DMA_CFG_ARB_BASE)
- sw zero, DMA_ROUTE_REG(t0)
- /* Set CPU clock to 500MHz (Required if boot from NAND) */
- lw t1, SYSCTL_CLKCFG0_REG(t0)
- ins t1, zero, 30, 2 # CPU_CLK_SEL
- sw t1, SYSCTL_CLKCFG0_REG(t0)
- /* Set CPU clock divider to 1/1 */
- li t0, KSEG1ADDR(RBUS_BASE)
- li t1, 0x101
- sw t1, RBUS_DYN_CFG0_REG(t0)
- /* (Re-)initialize the SRAM */
- bal mips_sram_init
nop
- /* Set up temporary stack */
- li sp, SP_ADDR_TEMP
- /* Setup full CPS */
- bal mips_cm_map
nop
- bal mt7621_cps_init
nop
- /* Prepare for CPU/DDR initialization binary blob */
- bal prepare_stage_bin
nop
- /* Call CPU/DDR initialization binary blob */
- li t9, STAGE_LOAD_ADDR
- jalr t9
nop
- /* Switch CPU PLL source */
- li t2, 1
- ins t1, t2, CPU_CLK_SEL_S, 2
* Currently SPL is running on locked L2 cache (on KSEG0).
* To reset the entire cache, we have to writeback SPL to
DRAM first.
* Cache flush won't work here. Use memcpy instead.
- la a0, __text_start
- move a1, a0
- la a2, __image_copy_end
- sub a2, a2, a1
- li a3, 5
- ins a0, a3, 29, 3 # convert to KSEG1
- bal memcpy
nop
nop
- /* Reset caches */
- bal mips_cache_reset
nop
- /* Disable SRAM */
- li t0, KSEG1ADDR(FE_BASE)
- li t1, FE_PSE_RESET
- sw t1, FE_RST_GLO_REG(t0)
- /* Clear the .bss section */
- la a0, __bss_start
- la a1, __bss_end
+1: sw zero, 0(a0)
- addiu a0, 4
- ble a0, a1, 1b
nop
- /* Set up initial stack and global data */
- setup_stack_gd
+#if CONFIG_IS_ENABLED(INIT_STACK_WITHOUT_MALLOC_F)
- /* Set malloc base */
- li t0, (CONFIG_SYS_INIT_SP_ADDR + 15) & (~15)
- PTR_S t0, GD_MALLOC_BASE(k0) # gd-
malloc_base offset
+#if defined(CONFIG_DEBUG_UART) && defined(CONFIG_SPL_SERIAL)
- /* Earliest point to set up debug uart */
- bal debug_uart_init
nop
- /* Setup timer */
- bal set_timer_freq_simple
nop
- /* Bootup secondary CPUs */
- bal secondary_cpu_init
nop
- move a0, zero # a0 <-- boot_flags =
0
- bal board_init_f
move ra, zero
- END(_start)
diff --git a/arch/mips/mach-mtmips/mt7621/sram_init.S b/arch/mips/mach-mtmips/mt7621/sram_init.S new file mode 100644 index 0000000000..74ddd6bcd7 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/sram_init.S @@ -0,0 +1,22 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+#include <asm/addrspace.h> +#include <asm/asm.h> +#include <asm/regdef.h> +#include "mt7621.h"
+LEAF(mips_sram_init)
- li t1, (FE_PSE_RAM | FE_PSE_MEM_EN)
- jr ra
- END(mips_sram_init)
diff --git a/arch/mips/mach-mtmips/mt7621/tpl/Makefile b/arch/mips/mach-mtmips/mt7621/tpl/Makefile new file mode 100644 index 0000000000..471ad74249 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/tpl/Makefile @@ -0,0 +1,4 @@
+extra-y += start.o
+obj-y += tpl.o diff --git a/arch/mips/mach-mtmips/mt7621/tpl/start.S b/arch/mips/mach-mtmips/mt7621/tpl/start.S new file mode 100644 index 0000000000..19b09f7251 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/tpl/start.S @@ -0,0 +1,161 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/*
+#include <asm-offsets.h> +#include <config.h> +#include <asm/asm.h> +#include <asm/regdef.h> +#include <asm/addrspace.h> +#include <asm/mipsregs.h> +#include <asm/cm.h> +#include "../mt7621.h"
+#define SP_ADDR_TEMP 0xbe10dff0
- .set noreorder
- .endm
- .macro uhi_mips_exception
- move k0, t9 # preserve t9 in k0
- move k1, a0 # preserve a0 in k1
- li t9, 15 # UHI exception operation
- li a0, 0 # Use hard register context
- sdbbp 1 # Invoke UHI operation
- .endm
+ENTRY(_start)
- b reset
* Store TPL size here.
* This will be used by SPL to locate u-boot payload.
- .org TPL_INFO_OFFSET
- .word TPL_INFO_MAGIC
- .word __image_copy_len
- /* Exception vector */
- .org 0x200
- /* TLB refill, 32 bit task */
- uhi_mips_exception
- .org 0x280
- /* XTLB refill, 64 bit task */
- .org 0x300
- /* Cache error exception */
- .org 0x380
- /* General exception */
- .org 0x400
- /* Catch interrupt exceptions */
- .org 0x480
- /* EJTAG debug exception */
+1: b 1b
nop
- .org 0x500
+reset:
- /* Set KSEG0 to Uncached */
- ins t0, zero, 0, 3
- ori t0, t0, CONF_CM_UNCACHED
- ehb
- /* Check for CPU number */
- beqz t0, 1f
nop
- /* Secondary core goes to specified SPL entry address */
- lw t0, BOOT_SRAM_BASE_REG(t0)
- jr t0
nop
+1: mfc0 t0, CP0_STATUS
- and t0, ST0_IMPL
nop
conditions
- init_wr 0
- init_wr 1
- init_wr 2
- init_wr 3
'reset') */
- /* Setup basic CPS */
- bal mips_cm_map
nop
- li t1, GCR_REG0_BASE_VALUE
- sw t1, GCR_REG0_BASE(t0)
- li t1, ((GCR_REG0_MASK_VALUE <<
GCR_REGn_MASK_ADDRMASK_SHIFT) | \
- sw t1, GCR_REG0_MASK(t0)
- lw t1, GCR_BASE(t0)
- ins t1, zero, 0, 2 #
CM_DEFAULT_TARGET
- sw t1, GCR_BASE(t0)
- lw t1, GCR_CONTROL(t0)
- li t2, GCR_CONTROL_SYNCCTL
- or t1, t1, t2
- sw t1, GCR_CONTROL(t0)
- /* Increase SPI frequency */
- li t0, KSEG1ADDR(SPI_BASE)
- li t1, 5
- sw t1, SPI_SPACE_REG(t0)
- /* Set CPU clock to 500MHz */
- li t1, 0x101
- /* Initialize the SRAM */
nop
- /* Set up initial stack */
- bal tpl_main
nop
- END(_start)
diff --git a/arch/mips/mach-mtmips/mt7621/tpl/tpl.c b/arch/mips/mach-mtmips/mt7621/tpl/tpl.c new file mode 100644 index 0000000000..77bcf0ddf0 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7621/tpl/tpl.c @@ -0,0 +1,146 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+#include <image.h> +#include <asm/sections.h> +#include <asm/cacheops.h> +#include <asm/mipsregs.h> +#include <asm/cm.h>
+#define INDEX_STORE_DATA_SD 0x0f
+typedef void __noreturn (*image_entry_noargs_t)(void);
+static inline void ehb(void) +{
- __asm__ __volatile__ ("ehb");
this is already available as execution_hazard_barrier() in arch/mips/include/asm/system.h. There is also sync() and instruction_hazard_barrier() if needed.
OK.
- Lock L2 cache and fill data
- Assume that data is 4-byte aligned and start_addr/size is 32-
byte aligned
+static void fill_lock_l2cache(uintptr_t dataptr, ulong start_addr, ulong size) +{
- ulong slsize = CONFIG_SYS_DCACHE_LINE_SIZE;
- ulong end_addr = start_addr + size;
- const u32 *data = (u32 *)dataptr;
- ulong i, addr;
- u32 val;
- /* Clear WSC & SPR bit in ErrCtl */
- val = read_c0_ecc();
- val &= 0xcfffffff;
- write_c0_ecc(val);
- ehb();
- for (addr = start_addr; addr < end_addr; addr += slsize) {
/* Set STagLo to lock cache line */
write_c0_staglo((addr & 0x1ffff800) | 0xa0);
mips_cache(INDEX_STORE_TAG_SD, (void *)addr);
/* Fill data */
for (i = 0; i < slsize; i += 8) {
val = *data++;
__write_32bit_c0_register($28, 5, val); /*
sdtaglo */
val = *data++;
__write_32bit_c0_register($29, 5, val); /*
sdtaghi */
mips_cache(INDEX_STORE_DATA_SD, (void
*)(addr + i));
+/* A simple function to initialize MT7621's cache */ +static void mt7621_cache_init(void) +{
- ulong lsize = CONFIG_SYS_DCACHE_LINE_SIZE;
- ulong addr;
- u32 val;
- /* Enable CCA override. Set to uncached */
- val = readl(cm_base + GCR_BASE);
- val &= ~CCA_DEFAULT_OVR_MASK;
- val |= CCA_DEFAULT_OVREN | (2 << CCA_DEFAULT_OVR_SHIFT);
- writel(val, cm_base + GCR_BASE);
- /* Initialize L1 I-Cache */
- write_c0_taglo(0);
- write_c0_taghi(0);
- for (addr = 0; addr < CONFIG_SYS_ICACHE_SIZE; addr +=
lsize)
mips_cache(INDEX_STORE_TAG_I, (void *)addr);
- /* Initialize L1 D-Cache */
- write_c0_dtaglo(0);
- __write_32bit_c0_register($29, 2, 0); /* dtaghi */
- for (addr = 0; addr < CONFIG_SYS_DCACHE_SIZE; addr +=
lsize)
mips_cache(INDEX_STORE_TAG_D, (void *)addr);
- /* Initialize L2 Cache */
- write_c0_staglo(0);
- __write_32bit_c0_register($29, 4, 0); /* staghi */
- for (addr = 0; addr < (256 << 10); addr += lsize)
- /* Dsiable CCA override */
- val &= ~(CCA_DEFAULT_OVR_MASK | CCA_DEFAULT_OVREN);
- /* Set KSEG0 to non-coherent cached (important!) */
- val = read_c0_config();
- val &= ~CONF_CM_CMASK;
- val |= CONF_CM_CACHABLE_NONCOHERENT;
- write_c0_config(val);
- ehb();
- /* Again, invalidate L1 D-Cache */
lsize)
mips_cache(INDEX_WRITEBACK_INV_D, (void *)addr);
- /* Invalidate L1 I-Cache */
lsize)
mips_cache(INDEX_INVALIDATE_I, (void *)addr);
- /* Disable L2 cache bypass */
- val = read_c0_config2();
- val &= ~MIPS_CONF_IMPL;
- write_c0_config2(val);
- ehb();
+void __noreturn tpl_main(void) +{
- const image_header_t *hdr = (const image_header_t
*)__image_copy_end;
- image_entry_noargs_t image_entry;
- u32 loadaddr, size;
- uintptr_t data;
- /* Initialize the cache first */
- mt7621_cache_init();
- if (image_get_magic(hdr) != IH_MAGIC)
goto failed;
- loadaddr = image_get_load(hdr);
- size = image_get_size(hdr);
- image_entry = (image_entry_noargs_t)image_get_ep(hdr);
- /* Load TPL image to L2 cache */
- data = (uintptr_t)__image_copy_end + sizeof(struct
image_header);
- fill_lock_l2cache(data, loadaddr, size);
- /* Jump to SPL */
- image_entry();
+failed:
- for (;;)
+} diff --git a/include/configs/mt7621.h b/include/configs/mt7621.h new file mode 100644 index 0000000000..580d5fde0c --- /dev/null +++ b/include/configs/mt7621.h @@ -0,0 +1,67 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/*
+#ifndef __CONFIG_MT7621_H +#define __CONFIG_MT7621_H
+#define CONFIG_SYS_HZ 1000 +#define CONFIG_SYS_MIPS_TIMER_FREQ 440000000
+#define CONFIG_SYS_BOOTPARAMS_LEN 0x20000
+#define CONFIG_SYS_SDRAM_BASE 0x80000000
+#define CONFIG_VERY_BIG_RAM +#define CONFIG_MAX_MEM_MAPPED 0x1c000000
+#define CONFIG_SYS_INIT_SP_OFFSET 0x800000
+#define CONFIG_SYS_BOOTM_LEN 0x2000000
+#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_CBSIZE 1024
+#define CONFIG_SYS_NONCACHED_MEMORY 0x100000
+/* MMC */ +#define MMC_SUPPORTS_TUNING
+/* NAND */ +#define CONFIG_SYS_MAX_NAND_DEVICE 1
+/* Serial SPL */ +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_SERIAL) +#define CONFIG_SYS_NS16550_MEM32 +#define CONFIG_SYS_NS16550_CLK 50000000 +#define CONFIG_SYS_NS16550_REG_SIZE -4 +#define CONFIG_SYS_NS16550_COM1 0xbe000c00 +#endif
+/* Serial common */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, \
230400, 460800, 921600 }
+/* SPL */ +#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE
+#ifdef CONFIG_TPL_BUILD +#define CONFIG_SPL_START_S_PATH "arch/mips/mach- mtmips/mt7621/tpl" +/* .bss will not be used by TPL */ +#define CONFIG_SPL_BSS_START_ADDR 0x80000000 +#define CONFIG_SPL_BSS_MAX_SIZE 0 +#else +#define CONFIG_SPL_START_S_PATH "arch/mips/mach- mtmips/mt7621/spl" +#define CONFIG_SPL_BSS_START_ADDR 0x80140000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 +#define CONFIG_SPL_MAX_SIZE 0x30000 +#endif
+/* Dummy value */ +#define CONFIG_SYS_UBOOT_BASE 0 +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0
+#endif /* __CONFIG_MT7621_H */
The mt7621_rfb board supports integrated giga PHYs plus one external giga PHYs. It also has up to 512MiB DDR3, 16MB SPI-NOR, 3 mini PCI-e x1 slots, SDXC and USB.
The mt7621_nand_rfb board is almost the same as mt7621_rfb board, but it uses NAND flash and SDXC is not available.
Reviewed-by: Stefan Roese sr@denx.de Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v5 changes: Fix defconfig file names in MAINTAINERS Remove unused configs in defconfig files Move pinctrl default states to board dts files v4 changes: Modify defconfig files for booting from flash v3 changes: none v2 changes: Add config file for mt7621-rfb boards --- arch/mips/dts/Makefile | 2 + arch/mips/dts/mediatek,mt7621-nand-rfb.dts | 67 +++++++++++++++++ arch/mips/dts/mediatek,mt7621-rfb.dts | 82 +++++++++++++++++++++ arch/mips/mach-mtmips/mt7621/Kconfig | 20 ++++++ board/mediatek/mt7621/MAINTAINERS | 8 +++ board/mediatek/mt7621/Makefile | 3 + board/mediatek/mt7621/board.c | 6 ++ configs/mt7621_nand_rfb_defconfig | 83 ++++++++++++++++++++++ configs/mt7621_rfb_defconfig | 82 +++++++++++++++++++++ 9 files changed, 353 insertions(+) create mode 100644 arch/mips/dts/mediatek,mt7621-nand-rfb.dts create mode 100644 arch/mips/dts/mediatek,mt7621-rfb.dts create mode 100644 board/mediatek/mt7621/MAINTAINERS create mode 100644 board/mediatek/mt7621/Makefile create mode 100644 board/mediatek/mt7621/board.c create mode 100644 configs/mt7621_nand_rfb_defconfig create mode 100644 configs/mt7621_rfb_defconfig
diff --git a/arch/mips/dts/Makefile b/arch/mips/dts/Makefile index 95144b24dc..1b179116c9 100644 --- a/arch/mips/dts/Makefile +++ b/arch/mips/dts/Makefile @@ -16,6 +16,8 @@ dtb-$(CONFIG_BOARD_COMTREND_WAP5813N) += comtrend,wap-5813n.dtb dtb-$(CONFIG_BOARD_HUAWEI_HG556A) += huawei,hg556a.dtb dtb-$(CONFIG_BOARD_MT7620_RFB) += mediatek,mt7620-rfb.dtb dtb-$(CONFIG_BOARD_MT7620_MT7530_RFB) += mediatek,mt7620-mt7530-rfb.dtb +dtb-$(CONFIG_BOARD_MT7621_RFB) += mediatek,mt7621-rfb.dtb +dtb-$(CONFIG_BOARD_MT7621_NAND_RFB) += mediatek,mt7621-nand-rfb.dtb dtb-$(CONFIG_BOARD_MT7628_RFB) += mediatek,mt7628-rfb.dtb dtb-$(CONFIG_BOARD_GARDENA_SMART_GATEWAY_MT7688) += gardena-smart-gateway-mt7688.dtb dtb-$(CONFIG_BOARD_LINKIT_SMART_7688) += linkit-smart-7688.dtb diff --git a/arch/mips/dts/mediatek,mt7621-nand-rfb.dts b/arch/mips/dts/mediatek,mt7621-nand-rfb.dts new file mode 100644 index 0000000000..67ba298b0a --- /dev/null +++ b/arch/mips/dts/mediatek,mt7621-nand-rfb.dts @@ -0,0 +1,67 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 MediaTek Inc. All rights reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +/dts-v1/; + +#include "mt7621.dtsi" + +/ { + compatible = "mediatek,mt7621-nand-rfb", "mediatek,mt7621-soc"; + model = "MediaTek MT7621 RFB (NAND)"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = &uart0; + }; +}; + +&pinctrl { + state_default: pin_state { + nand { + groups = "spi", "sdxc"; + function = "nand"; + }; + + gpios { + groups = "i2c", "uart3", "pcie reset"; + function = "gpio"; + }; + + wdt { + groups = "wdt"; + function = "wdt rst"; + }; + + jtag { + groups = "jtag"; + function = "jtag"; + }; + }; +}; + +&uart0 { + status = "okay"; +}; + +&gpio { + status = "okay"; +}; + +ð { + status = "okay"; +}; + +&ssusb { + status = "okay"; +}; + +&u3phy { + status = "okay"; +}; diff --git a/arch/mips/dts/mediatek,mt7621-rfb.dts b/arch/mips/dts/mediatek,mt7621-rfb.dts new file mode 100644 index 0000000000..ff7eaf0f20 --- /dev/null +++ b/arch/mips/dts/mediatek,mt7621-rfb.dts @@ -0,0 +1,82 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 MediaTek Inc. All rights reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +/dts-v1/; + +#include "mt7621.dtsi" + +/ { + compatible = "mediatek,mt7621-rfb", "mediatek,mt7621-soc"; + model = "MediaTek MT7621 RFB (SPI-NOR)"; + + aliases { + serial0 = &uart0; + spi0 = &spi; + }; + + chosen { + stdout-path = &uart0; + }; +}; + +&pinctrl { + state_default: pin_state { + gpios { + groups = "i2c", "uart3", "pcie reset"; + function = "gpio"; + }; + + wdt { + groups = "wdt"; + function = "wdt rst"; + }; + + jtag { + groups = "jtag"; + function = "jtag"; + }; + }; +}; + +&uart0 { + status = "okay"; +}; + +&gpio { + status = "okay"; +}; + +&spi { + status = "okay"; + num-cs = <2>; + + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + spi-max-frequency = <25000000>; + reg = <0>; + }; +}; + +ð { + status = "okay"; +}; + +&mmc { + cap-sd-highspeed; + + status = "okay"; +}; + +&ssusb { + status = "okay"; +}; + +&u3phy { + status = "okay"; +}; diff --git a/arch/mips/mach-mtmips/mt7621/Kconfig b/arch/mips/mach-mtmips/mt7621/Kconfig index 37d512c68f..008a28f991 100644 --- a/arch/mips/mach-mtmips/mt7621/Kconfig +++ b/arch/mips/mach-mtmips/mt7621/Kconfig @@ -79,6 +79,26 @@ config MT7621_BOOT_FROM_NAND choice prompt "Board select"
+config BOARD_MT7621_RFB + bool "MediaTek MT7621 RFB (SPI-NOR)" + help + The reference design of MT7621A (WS3010) booting from SPI-NOR flash. + The board can be configured with DDR2 (64MiB~256MiB) or DDR3 + (128MiB~512MiB). The board has 16 MiB SPI-NOR flash, built-in MT7530 + GbE switch, 1 UART, 1 USB 2.0 host, 1 USB 3.0 host, 1 SDXC, 3 PCIe + sockets, 1 RGMII to external GbE PHY, 2 audio jacks (in/out), + JTAG pins and expansion GPIO pins. + +config BOARD_MT7621_NAND_RFB + bool "MediaTek MT7621 RFB (NAND)" + help + The reference design of MT7621A (WS3010) booting from NAND flash. + The board can be configured with DDR2 (64MiB~256MiB) or DDR3 + (128MiB~512MiB). The board has 128 MiB parallel NAND flash, built-in + MT7530 GbE switch, 1 UART, 1 USB 2.0 host, 1 USB 3.0 host, 3 PCIe + sockets, 1 RGMII to external GbE PHY, 2 audio jacks (in/out), + JTAG pins and expansion GPIO pins. + endchoice
config SYS_CONFIG_NAME diff --git a/board/mediatek/mt7621/MAINTAINERS b/board/mediatek/mt7621/MAINTAINERS new file mode 100644 index 0000000000..f83141cea1 --- /dev/null +++ b/board/mediatek/mt7621/MAINTAINERS @@ -0,0 +1,8 @@ +MT7621_RFB BOARD +M: Weijie Gao weijie.gao@mediatek.com +S: Maintained +F: board/mediatek/mt7621 +F: configs/mt7621_rfb_defconfig +F: configs/mt7621_nand_rfb_defconfig +F: arch/mips/dts/mediatek,mt7621-rfb.dts +F: arch/mips/dts/mediatek,mt7621-nand-rfb.dts diff --git a/board/mediatek/mt7621/Makefile b/board/mediatek/mt7621/Makefile new file mode 100644 index 0000000000..db129c5aba --- /dev/null +++ b/board/mediatek/mt7621/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0 + +obj-y += board.o diff --git a/board/mediatek/mt7621/board.c b/board/mediatek/mt7621/board.c new file mode 100644 index 0000000000..0496f3f806 --- /dev/null +++ b/board/mediatek/mt7621/board.c @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 MediaTek Inc. All rights reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ diff --git a/configs/mt7621_nand_rfb_defconfig b/configs/mt7621_nand_rfb_defconfig new file mode 100644 index 0000000000..f733427eb1 --- /dev/null +++ b/configs/mt7621_nand_rfb_defconfig @@ -0,0 +1,83 @@ +CONFIG_MIPS=y +CONFIG_SYS_MALLOC_LEN=0x100000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x1000 +CONFIG_DEFAULT_DEVICE_TREE="mediatek,mt7621-nand-rfb" +CONFIG_SPL_SERIAL=y +CONFIG_SPL_SYS_MALLOC_F_LEN=0x100000 +CONFIG_SPL=y +CONFIG_DEBUG_UART_BASE=0xbe000c00 +CONFIG_DEBUG_UART_CLOCK=50000000 +CONFIG_SYS_LOAD_ADDR=0x83000000 +CONFIG_ARCH_MTMIPS=y +CONFIG_SOC_MT7621=y +CONFIG_MT7621_BOOT_FROM_NAND=y +CONFIG_BOARD_MT7621_NAND_RFB=y +# CONFIG_MIPS_CACHE_SETUP is not set +# CONFIG_MIPS_CACHE_DISABLE is not set +CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y +CONFIG_MIPS_BOOT_FDT=y +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_NAND_SUPPORT=y +CONFIG_SPL_NAND_BASE=y +CONFIG_SPL_NAND_IDENT=y +# CONFIG_BOOTM_NETBSD is not set +# CONFIG_BOOTM_PLAN9 is not set +# CONFIG_BOOTM_RTEMS is not set +# CONFIG_BOOTM_VXWORKS is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_CRC32 is not set +# CONFIG_CMD_DM is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_PART=y +# CONFIG_CMD_PINMUX is not set +CONFIG_CMD_USB=y +# CONFIG_CMD_NFS is not set +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_ISO_PARTITION is not set +CONFIG_EFI_PARTITION=y +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_PARTITION_TYPE_GUID=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +# CONFIG_I2C is not set +# CONFIG_INPUT is not set +CONFIG_MMC=y +# CONFIG_MMC_QUIRKS is not set +# CONFIG_MMC_HW_PARTITIONING is not set +CONFIG_MMC_MTK=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_MT7621=y +CONFIG_SYS_NAND_ONFI_DETECTION=y +CONFIG_MEDIATEK_ETH=y +CONFIG_PHY=y +CONFIG_PHY_MTK_TPHY=y +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYSRESET=y +CONFIG_SYSRESET_RESETCTL=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_MTK=y +CONFIG_USB_STORAGE=y +CONFIG_WDT=y +CONFIG_WDT_MT7621=y +CONFIG_FAT_WRITE=y +# CONFIG_BINMAN_FDT is not set +CONFIG_LZMA=y +# CONFIG_GZIP is not set +CONFIG_SPL_LZMA=y diff --git a/configs/mt7621_rfb_defconfig b/configs/mt7621_rfb_defconfig new file mode 100644 index 0000000000..ae62360e63 --- /dev/null +++ b/configs/mt7621_rfb_defconfig @@ -0,0 +1,82 @@ +CONFIG_MIPS=y +CONFIG_SYS_MALLOC_LEN=0x100000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x1000 +CONFIG_DEFAULT_DEVICE_TREE="mediatek,mt7621-rfb" +CONFIG_SPL_SERIAL=y +CONFIG_SPL_SYS_MALLOC_F_LEN=0x40000 +CONFIG_SPL=y +CONFIG_DEBUG_UART_BASE=0xbe000c00 +CONFIG_DEBUG_UART_CLOCK=50000000 +CONFIG_SYS_LOAD_ADDR=0x83000000 +CONFIG_ARCH_MTMIPS=y +CONFIG_SOC_MT7621=y +# CONFIG_MIPS_CACHE_SETUP is not set +# CONFIG_MIPS_CACHE_DISABLE is not set +CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y +CONFIG_MIPS_BOOT_FDT=y +CONFIG_DEBUG_UART=y +CONFIG_TPL_SYS_MALLOC_F_LEN=0x1000 +CONFIG_FIT=y +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_NOR_SUPPORT=y +CONFIG_TPL=y +# CONFIG_TPL_FRAMEWORK is not set +# CONFIG_BOOTM_NETBSD is not set +# CONFIG_BOOTM_PLAN9 is not set +# CONFIG_BOOTM_RTEMS is not set +# CONFIG_BOOTM_VXWORKS is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_CRC32 is not set +# CONFIG_CMD_DM is not set +CONFIG_CMD_GPIO=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y +# CONFIG_CMD_PINMUX is not set +CONFIG_CMD_SPI=y +# CONFIG_CMD_NFS is not set +CONFIG_DOS_PARTITION=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_ISO_PARTITION is not set +CONFIG_EFI_PARTITION=y +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_PARTITION_TYPE_GUID=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +# CONFIG_I2C is not set +# CONFIG_INPUT is not set +CONFIG_MMC=y +# CONFIG_MMC_QUIRKS is not set +# CONFIG_MMC_HW_PARTITIONING is not set +CONFIG_MMC_MTK=y +CONFIG_SF_DEFAULT_SPEED=20000000 +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_ISSI=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_XMC=y +CONFIG_SPI_FLASH_XTX=y +CONFIG_MEDIATEK_ETH=y +CONFIG_PHY=y +CONFIG_PHY_MTK_TPHY=y +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SPI=y +CONFIG_MT7621_SPI=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_RESETCTL=y +CONFIG_WDT=y +CONFIG_WDT_MT7621=y +# CONFIG_BINMAN_FDT is not set +CONFIG_LZMA=y +# CONFIG_GZIP is not set +CONFIG_SPL_LZMA=y
The MT7621 requires external binary blob being executed during u-boot's boot-up flow. It's necessary to provide a guide here for users to correctly build the u-boot.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v5 changes: none v4 changes: new --- doc/board/mediatek/mt7621.rst | 48 +++++++++++++++++++++++++++++++++++ 1 file changed, 48 insertions(+) create mode 100644 doc/board/mediatek/mt7621.rst
diff --git a/doc/board/mediatek/mt7621.rst b/doc/board/mediatek/mt7621.rst new file mode 100644 index 0000000000..4f400a4ca4 --- /dev/null +++ b/doc/board/mediatek/mt7621.rst @@ -0,0 +1,48 @@ +.. SPDX-License-Identifier: GPL-2.0 + +mt7621_rfb/mt7621_nand_rfb +========================== + +U-Boot for the MediaTek MT7621 boards + +Quick Start +----------- + +- Get the DDR initialization binary blob +- Configure CPU and DDR parameters +- Build U-Boot + +Get the DDR initialization binary blob +-------------------- + +Download one from: + - https://raw.githubusercontent.com/mtk-openwrt/mt7621-lowlevel-preloader/mast... + - https://raw.githubusercontent.com/mtk-openwrt/mt7621-lowlevel-preloader/mast... + +mt7621_stage_sram_noprint.bin has removed all output logs. To use this one, +download and rename it to mt7621_stage_sram.bin + +Put the binary blob to the u-boot build directory. + +Configure CPU and DDR parameters +-------------------------------- + +menuconfig > MIPS architecture > MediaTek MIPS platforms > CPU & DDR configuration + +Select the correct DDR timing parameters for your board. The size shown here +must match the DDR size of you board. + +The frequency of CPU and DDR can also be adjusted. + +Build U-Boot +------------ + +.. code-block:: bash + + $ export CROSS_COMPILE=mipsel-linux- + $ make O=build mt7621_rfb_defconfig # or mt7621_nand_rfb_defconfig + $ cp mt7621_stage_sram.bin ./build/mt7621_stage_sram.bin + $ # or cp mt7621_stage_sram_noprint.bin ./build/mt7621_stage_sram.bin + $ make O=build + +Burn the u-boot-mt7621.bin to the SPI-NOR or NAND flash.
This patch adds a clock driver for MediaTek MT7621 SoC. This driver provides clock gate control as well as getting clock frequency for CPU/SYS/XTAL and some peripherals.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v5 changes: Remove the use of common.h Use GENMASK and BITS for register fields Add request() to check clk id Adjust probe() due to clkctrl node becomes a subnode of sysc Use regmap api to read memc registers v4 changes: none v3 changes: update clock definitions to match upstream kernel v2 changes: none --- drivers/clk/mtmips/Makefile | 1 + drivers/clk/mtmips/clk-mt7621.c | 294 +++++++++++++++++++++++++ include/dt-bindings/clock/mt7621-clk.h | 46 ++++ 3 files changed, 341 insertions(+) create mode 100644 drivers/clk/mtmips/clk-mt7621.c create mode 100644 include/dt-bindings/clock/mt7621-clk.h
diff --git a/drivers/clk/mtmips/Makefile b/drivers/clk/mtmips/Makefile index 732e7f2545..ee8b5afe87 100644 --- a/drivers/clk/mtmips/Makefile +++ b/drivers/clk/mtmips/Makefile @@ -1,4 +1,5 @@ # SPDX-License-Identifier: GPL-2.0
obj-$(CONFIG_SOC_MT7620) += clk-mt7620.o +obj-$(CONFIG_SOC_MT7621) += clk-mt7621.o obj-$(CONFIG_SOC_MT7628) += clk-mt7628.o diff --git a/drivers/clk/mtmips/clk-mt7621.c b/drivers/clk/mtmips/clk-mt7621.c new file mode 100644 index 0000000000..bdb645246c --- /dev/null +++ b/drivers/clk/mtmips/clk-mt7621.c @@ -0,0 +1,294 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 MediaTek Inc. All rights reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <clk-uclass.h> +#include <dm.h> +#include <dm/device_compat.h> +#include <regmap.h> +#include <syscon.h> +#include <dt-bindings/clock/mt7621-clk.h> +#include <linux/bitops.h> +#include <linux/io.h> + +#define SYSC_MAP_SIZE 0x100 +#define MEMC_MAP_SIZE 0x1000 + +/* SYSC */ +#define SYSCFG0_REG 0x10 +#define XTAL_MODE_SEL_S 6 +#define XTAL_MODE_SEL_M GENMASK(8, 6) + +#define CLKCFG0_REG 0x2c +#define CPU_CLK_SEL_S 30 +#define CPU_CLK_SEL_M GENMASK(31, 30) +#define PERI_CLK_SEL BIT(4) + +#define CLKCFG1_REG 0x30 + +#define CUR_CLK_STS_REG 0x44 +#define CUR_CPU_FDIV_S 8 +#define CUR_CPU_FDIV_M GENMASK(12, 8) +#define CUR_CPU_FFRAC_S 0 +#define CUR_CPU_FFRAC_M GENMASK(4, 0) + +/* MEMC */ +#define MEMPLL1_REG 0x0604 +#define RG_MEPL_DIV2_SEL_S 1 +#define RG_MEPL_DIV2_SEL_M GENMASK(2, 1) + +#define MEMPLL6_REG 0x0618 +#define MEMPLL18_REG 0x0648 +#define RG_MEPL_PREDIV_S 12 +#define RG_MEPL_PREDIV_M GENMASK(13, 12) +#define RG_MEPL_FBDIV_S 4 +#define RG_MEPL_FBDIV_M GENMASK(10, 4) + +/* Fixed 500M clock */ +#define GMPLL_CLK 500000000 + +struct mt7621_clk_priv { + void __iomem *sysc_base; + int cpu_clk; + int ddr_clk; + int sys_clk; + int xtal_clk; +}; + +enum mt7621_clk_src { + CLK_SRC_CPU, + CLK_SRC_DDR, + CLK_SRC_SYS, + CLK_SRC_XTAL, + CLK_SRC_PERI, + CLK_SRC_125M, + CLK_SRC_150M, + CLK_SRC_250M, + CLK_SRC_270M, + + __CLK_SRC_MAX +}; + +struct mt7621_clk_map { + u32 cgbit; + enum mt7621_clk_src clksrc; +}; + +#define CLK_MAP(_id, _cg, _src) \ + [_id] = { .cgbit = (_cg), .clksrc = (_src) } + +#define CLK_MAP_SRC(_id, _src) \ + [_id] = { .cgbit = UINT32_MAX, .clksrc = (_src) } + +static const struct mt7621_clk_map mt7621_clk_mappings[] = { + CLK_MAP_SRC(MT7621_CLK_XTAL, CLK_SRC_XTAL), + CLK_MAP_SRC(MT7621_CLK_CPU, CLK_SRC_CPU), + CLK_MAP_SRC(MT7621_CLK_BUS, CLK_SRC_SYS), + CLK_MAP_SRC(MT7621_CLK_50M, CLK_SRC_PERI), + CLK_MAP_SRC(MT7621_CLK_125M, CLK_SRC_125M), + CLK_MAP_SRC(MT7621_CLK_150M, CLK_SRC_150M), + CLK_MAP_SRC(MT7621_CLK_250M, CLK_SRC_250M), + CLK_MAP_SRC(MT7621_CLK_270M, CLK_SRC_270M), + + CLK_MAP(MT7621_CLK_HSDMA, 5, CLK_SRC_150M), + CLK_MAP(MT7621_CLK_FE, 6, CLK_SRC_250M), + CLK_MAP(MT7621_CLK_SP_DIVTX, 7, CLK_SRC_270M), + CLK_MAP(MT7621_CLK_TIMER, 8, CLK_SRC_PERI), + CLK_MAP(MT7621_CLK_PCM, 11, CLK_SRC_270M), + CLK_MAP(MT7621_CLK_PIO, 13, CLK_SRC_PERI), + CLK_MAP(MT7621_CLK_GDMA, 14, CLK_SRC_SYS), + CLK_MAP(MT7621_CLK_NAND, 15, CLK_SRC_125M), + CLK_MAP(MT7621_CLK_I2C, 16, CLK_SRC_PERI), + CLK_MAP(MT7621_CLK_I2S, 17, CLK_SRC_270M), + CLK_MAP(MT7621_CLK_SPI, 18, CLK_SRC_SYS), + CLK_MAP(MT7621_CLK_UART1, 19, CLK_SRC_PERI), + CLK_MAP(MT7621_CLK_UART2, 20, CLK_SRC_PERI), + CLK_MAP(MT7621_CLK_UART3, 21, CLK_SRC_PERI), + CLK_MAP(MT7621_CLK_ETH, 23, CLK_SRC_PERI), + CLK_MAP(MT7621_CLK_PCIE0, 24, CLK_SRC_125M), + CLK_MAP(MT7621_CLK_PCIE1, 25, CLK_SRC_125M), + CLK_MAP(MT7621_CLK_PCIE2, 26, CLK_SRC_125M), + CLK_MAP(MT7621_CLK_CRYPTO, 29, CLK_SRC_250M), + CLK_MAP(MT7621_CLK_SHXC, 30, CLK_SRC_PERI), + + CLK_MAP_SRC(MT7621_CLK_MAX, __CLK_SRC_MAX), + + CLK_MAP_SRC(MT7621_CLK_DDR, CLK_SRC_DDR), +}; + +static ulong mt7621_clk_get_rate(struct clk *clk) +{ + struct mt7621_clk_priv *priv = dev_get_priv(clk->dev); + u32 val; + + switch (mt7621_clk_mappings[clk->id].clksrc) { + case CLK_SRC_CPU: + return priv->cpu_clk; + case CLK_SRC_DDR: + return priv->ddr_clk; + case CLK_SRC_SYS: + return priv->sys_clk; + case CLK_SRC_XTAL: + return priv->xtal_clk; + case CLK_SRC_PERI: + val = readl(priv->sysc_base + CLKCFG0_REG); + if (val & PERI_CLK_SEL) + return priv->xtal_clk; + else + return GMPLL_CLK / 10; + case CLK_SRC_125M: + return 125000000; + case CLK_SRC_150M: + return 150000000; + case CLK_SRC_250M: + return 250000000; + case CLK_SRC_270M: + return 270000000; + default: + return 0; + } +} + +static int mt7621_clk_enable(struct clk *clk) +{ + struct mt7621_clk_priv *priv = dev_get_priv(clk->dev); + u32 cgbit; + + cgbit = mt7621_clk_mappings[clk->id].cgbit; + if (cgbit == UINT32_MAX) + return -ENOSYS; + + setbits_32(priv->sysc_base + CLKCFG1_REG, BIT(cgbit)); + + return 0; +} + +static int mt7621_clk_disable(struct clk *clk) +{ + struct mt7621_clk_priv *priv = dev_get_priv(clk->dev); + u32 cgbit; + + cgbit = mt7621_clk_mappings[clk->id].cgbit; + if (cgbit == UINT32_MAX) + return -ENOSYS; + + clrbits_32(priv->sysc_base + CLKCFG1_REG, BIT(cgbit)); + + return 0; +} + +static int mt7621_clk_request(struct clk *clk) +{ + if (clk->id >= ARRAY_SIZE(mt7621_clk_mappings)) + return -EINVAL; + return 0; +} + +const struct clk_ops mt7621_clk_ops = { + .request = mt7621_clk_request, + .enable = mt7621_clk_enable, + .disable = mt7621_clk_disable, + .get_rate = mt7621_clk_get_rate, +}; + +static void mt7621_get_clocks(struct mt7621_clk_priv *priv, struct regmap *memc) +{ + u32 bs, xtal_sel, clkcfg0, cur_clk, mempll, dividx, fb; + u32 xtal_clk, xtal_div, ffiv, ffrac, cpu_clk, ddr_clk; + static const u32 xtal_div_tbl[] = {0, 1, 2, 2}; + + bs = readl(priv->sysc_base + SYSCFG0_REG); + clkcfg0 = readl(priv->sysc_base + CLKCFG0_REG); + cur_clk = readl(priv->sysc_base + CUR_CLK_STS_REG); + + xtal_sel = (bs & XTAL_MODE_SEL_M) >> XTAL_MODE_SEL_S; + + if (xtal_sel <= 2) + xtal_clk = 20 * 1000 * 1000; + else if (xtal_sel <= 5) + xtal_clk = 40 * 1000 * 1000; + else + xtal_clk = 25 * 1000 * 1000; + + switch ((clkcfg0 & CPU_CLK_SEL_M) >> CPU_CLK_SEL_S) { + case 0: + cpu_clk = GMPLL_CLK; + break; + case 1: + regmap_read(memc, MEMPLL18_REG, &mempll); + dividx = (mempll & RG_MEPL_PREDIV_M) >> RG_MEPL_PREDIV_S; + fb = (mempll & RG_MEPL_FBDIV_M) >> RG_MEPL_FBDIV_S; + xtal_div = 1 << xtal_div_tbl[dividx]; + cpu_clk = (fb + 1) * xtal_clk / xtal_div; + break; + default: + cpu_clk = xtal_clk; + } + + ffiv = (cur_clk & CUR_CPU_FDIV_M) >> CUR_CPU_FDIV_S; + ffrac = (cur_clk & CUR_CPU_FFRAC_M) >> CUR_CPU_FFRAC_S; + cpu_clk = cpu_clk / ffiv * ffrac; + + regmap_read(memc, MEMPLL6_REG, &mempll); + dividx = (mempll & RG_MEPL_PREDIV_M) >> RG_MEPL_PREDIV_S; + fb = (mempll & RG_MEPL_FBDIV_M) >> RG_MEPL_FBDIV_S; + xtal_div = 1 << xtal_div_tbl[dividx]; + ddr_clk = fb * xtal_clk / xtal_div; + + regmap_read(memc, MEMPLL1_REG, &bs); + if (((bs & RG_MEPL_DIV2_SEL_M) >> RG_MEPL_DIV2_SEL_S) == 0) + ddr_clk *= 2; + + priv->cpu_clk = cpu_clk; + priv->sys_clk = cpu_clk / 4; + priv->ddr_clk = ddr_clk; + priv->xtal_clk = xtal_clk; +} + +static int mt7621_clk_probe(struct udevice *dev) +{ + struct mt7621_clk_priv *priv = dev_get_priv(dev); + struct ofnode_phandle_args args; + struct udevice *pdev; + struct regmap *memc; + int ret; + + pdev = dev_get_parent(dev); + if (!pdev) + return -ENODEV; + + priv->sysc_base = dev_remap_addr(pdev); + if (!priv->sysc_base) + return -EINVAL; + + /* get corresponding memc phandle */ + ret = dev_read_phandle_with_args(dev, "mediatek,memc", NULL, 0, 0, + &args); + if (ret) + return ret; + + memc = syscon_node_to_regmap(args.node); + if (IS_ERR(memc)) + return PTR_ERR(memc); + + mt7621_get_clocks(priv, memc); + + return 0; +} + +static const struct udevice_id mt7621_clk_ids[] = { + { .compatible = "mediatek,mt7621-clk" }, + { } +}; + +U_BOOT_DRIVER(mt7621_clk) = { + .name = "mt7621-clk", + .id = UCLASS_CLK, + .of_match = mt7621_clk_ids, + .probe = mt7621_clk_probe, + .priv_auto = sizeof(struct mt7621_clk_priv), + .ops = &mt7621_clk_ops, +}; diff --git a/include/dt-bindings/clock/mt7621-clk.h b/include/dt-bindings/clock/mt7621-clk.h new file mode 100644 index 0000000000..978c67951b --- /dev/null +++ b/include/dt-bindings/clock/mt7621-clk.h @@ -0,0 +1,46 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2022 MediaTek Inc. All rights reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#ifndef _DT_BINDINGS_MT7621_CLK_H_ +#define _DT_BINDINGS_MT7621_CLK_H_ + +#define MT7621_CLK_XTAL 0 +#define MT7621_CLK_CPU 1 +#define MT7621_CLK_BUS 2 +#define MT7621_CLK_50M 3 +#define MT7621_CLK_125M 4 +#define MT7621_CLK_150M 5 +#define MT7621_CLK_250M 6 +#define MT7621_CLK_270M 7 + +#define MT7621_CLK_HSDMA 8 +#define MT7621_CLK_FE 9 +#define MT7621_CLK_SP_DIVTX 10 +#define MT7621_CLK_TIMER 11 +#define MT7621_CLK_PCM 12 +#define MT7621_CLK_PIO 13 +#define MT7621_CLK_GDMA 14 +#define MT7621_CLK_NAND 15 +#define MT7621_CLK_I2C 16 +#define MT7621_CLK_I2S 17 +#define MT7621_CLK_SPI 18 +#define MT7621_CLK_UART1 19 +#define MT7621_CLK_UART2 20 +#define MT7621_CLK_UART3 21 +#define MT7621_CLK_ETH 22 +#define MT7621_CLK_PCIE0 23 +#define MT7621_CLK_PCIE1 24 +#define MT7621_CLK_PCIE2 25 +#define MT7621_CLK_CRYPTO 26 +#define MT7621_CLK_SHXC 27 + +#define MT7621_CLK_MAX 28 + +/* for u-boot only */ +#define MT7621_CLK_DDR 29 + +#endif /* _DT_BINDINGS_MT7621_CLK_H_ */
- Copyright (C) 2022 MediaTek Inc. All rights reserved.
- Author: Weijie Gao weijie.gao@mediatek.com
- void __iomem *sysc_base;
- int cpu_clk;
- int ddr_clk;
- int sys_clk;
- int xtal_clk;
- CLK_SRC_CPU,
- CLK_SRC_DDR,
- CLK_SRC_SYS,
- CLK_SRC_XTAL,
- CLK_SRC_PERI,
- CLK_SRC_125M,
- CLK_SRC_150M,
- CLK_SRC_250M,
- CLK_SRC_270M,
- __CLK_SRC_MAX
- u32 cgbit;
- enum mt7621_clk_src clksrc;
- [_id] = { .cgbit = (_cg), .clksrc = (_src) }
- [_id] = { .cgbit = UINT32_MAX, .clksrc = (_src) }
- CLK_MAP_SRC(MT7621_CLK_XTAL, CLK_SRC_XTAL),
- CLK_MAP_SRC(MT7621_CLK_CPU, CLK_SRC_CPU),
- CLK_MAP_SRC(MT7621_CLK_BUS, CLK_SRC_SYS),
- CLK_MAP_SRC(MT7621_CLK_50M, CLK_SRC_PERI),
- CLK_MAP_SRC(MT7621_CLK_125M, CLK_SRC_125M),
- CLK_MAP_SRC(MT7621_CLK_150M, CLK_SRC_150M),
- CLK_MAP_SRC(MT7621_CLK_250M, CLK_SRC_250M),
- CLK_MAP_SRC(MT7621_CLK_270M, CLK_SRC_270M),
- CLK_MAP(MT7621_CLK_HSDMA, 5, CLK_SRC_150M),
- CLK_MAP(MT7621_CLK_FE, 6, CLK_SRC_250M),
- CLK_MAP(MT7621_CLK_SP_DIVTX, 7, CLK_SRC_270M),
- CLK_MAP(MT7621_CLK_TIMER, 8, CLK_SRC_PERI),
- CLK_MAP(MT7621_CLK_PCM, 11, CLK_SRC_270M),
- CLK_MAP(MT7621_CLK_PIO, 13, CLK_SRC_PERI),
- CLK_MAP(MT7621_CLK_GDMA, 14, CLK_SRC_SYS),
- CLK_MAP(MT7621_CLK_NAND, 15, CLK_SRC_125M),
- CLK_MAP(MT7621_CLK_I2C, 16, CLK_SRC_PERI),
- CLK_MAP(MT7621_CLK_I2S, 17, CLK_SRC_270M),
- CLK_MAP(MT7621_CLK_SPI, 18, CLK_SRC_SYS),
- CLK_MAP(MT7621_CLK_UART1, 19, CLK_SRC_PERI),
- CLK_MAP(MT7621_CLK_UART2, 20, CLK_SRC_PERI),
- CLK_MAP(MT7621_CLK_UART3, 21, CLK_SRC_PERI),
- CLK_MAP(MT7621_CLK_ETH, 23, CLK_SRC_PERI),
- CLK_MAP(MT7621_CLK_PCIE0, 24, CLK_SRC_125M),
- CLK_MAP(MT7621_CLK_PCIE1, 25, CLK_SRC_125M),
- CLK_MAP(MT7621_CLK_PCIE2, 26, CLK_SRC_125M),
- CLK_MAP(MT7621_CLK_CRYPTO, 29, CLK_SRC_250M),
- CLK_MAP(MT7621_CLK_SHXC, 30, CLK_SRC_PERI),
- CLK_MAP_SRC(MT7621_CLK_MAX, __CLK_SRC_MAX),
- CLK_MAP_SRC(MT7621_CLK_DDR, CLK_SRC_DDR),
- struct mt7621_clk_priv *priv = dev_get_priv(clk->dev);
- u32 val;
- switch (mt7621_clk_mappings[clk->id].clksrc) {
- case CLK_SRC_CPU:
- case CLK_SRC_DDR:
- case CLK_SRC_SYS:
- case CLK_SRC_XTAL:
- case CLK_SRC_PERI:
else
- case CLK_SRC_125M:
return 125000000;
- case CLK_SRC_150M:
return 150000000;
- case CLK_SRC_250M:
return 250000000;
- case CLK_SRC_270M:
return 270000000;
- default:
- u32 cgbit;
- cgbit = mt7621_clk_mappings[clk->id].cgbit;
- if (cgbit == UINT32_MAX)
return -ENOSYS;
- setbits_32(priv->sysc_base + CLKCFG1_REG, BIT(cgbit));
- u32 cgbit;
return -ENOSYS;
- clrbits_32(priv->sysc_base + CLKCFG1_REG, BIT(cgbit));
- if (clk->id >= ARRAY_SIZE(mt7621_clk_mappings))
return -EINVAL;
- .request = mt7621_clk_request,
- .enable = mt7621_clk_enable,
- .disable = mt7621_clk_disable,
- .get_rate = mt7621_clk_get_rate,
- u32 bs, xtal_sel, clkcfg0, cur_clk, mempll, dividx, fb;
- u32 xtal_clk, xtal_div, ffiv, ffrac, cpu_clk, ddr_clk;
- static const u32 xtal_div_tbl[] = {0, 1, 2, 2};
- bs = readl(priv->sysc_base + SYSCFG0_REG);
- clkcfg0 = readl(priv->sysc_base + CLKCFG0_REG);
- cur_clk = readl(priv->sysc_base + CUR_CLK_STS_REG);
- xtal_sel = (bs & XTAL_MODE_SEL_M) >> XTAL_MODE_SEL_S;
- if (xtal_sel <= 2)
- else if (xtal_sel <= 5)
- else
- switch ((clkcfg0 & CPU_CLK_SEL_M) >> CPU_CLK_SEL_S) {
You can use FIELD_GET here
ditto for most of the rest of the shifts
- case 0:
break;
- case 1:
break;
- default:
cpu_clk = xtal_clk;
- ffiv = (cur_clk & CUR_CPU_FDIV_M) >> CUR_CPU_FDIV_S;
- ffrac = (cur_clk & CUR_CPU_FFRAC_M) >> CUR_CPU_FFRAC_S;
- cpu_clk = cpu_clk / ffiv * ffrac;
- regmap_read(memc, MEMPLL6_REG, &mempll);
- dividx = (mempll & RG_MEPL_PREDIV_M) >> RG_MEPL_PREDIV_S;
- fb = (mempll & RG_MEPL_FBDIV_M) >> RG_MEPL_FBDIV_S;
- xtal_div = 1 << xtal_div_tbl[dividx];
- ddr_clk = fb * xtal_clk / xtal_div;
- regmap_read(memc, MEMPLL1_REG, &bs);
- if (((bs & RG_MEPL_DIV2_SEL_M) >> RG_MEPL_DIV2_SEL_S) == 0)
ddr_clk *= 2;
- priv->cpu_clk = cpu_clk;
- priv->sys_clk = cpu_clk / 4;
- priv->ddr_clk = ddr_clk;
- priv->xtal_clk = xtal_clk;
- struct mt7621_clk_priv *priv = dev_get_priv(dev);
- struct ofnode_phandle_args args;
- struct udevice *pdev;
- struct regmap *memc;
- int ret;
- pdev = dev_get_parent(dev);
- if (!pdev)
return -ENODEV;
- priv->sysc_base = dev_remap_addr(pdev);
- if (!priv->sysc_base)
return -EINVAL;
- /* get corresponding memc phandle */
- ret = dev_read_phandle_with_args(dev, "mediatek,memc", NULL, 0, 0,
&args);
- if (ret)
return ret;
- memc = syscon_node_to_regmap(args.node);
- if (IS_ERR(memc))
- mt7621_get_clocks(priv, memc);
- { .compatible = "mediatek,mt7621-clk" },
- .name = "mt7621-clk",
- .id = UCLASS_CLK,
- .of_match = mt7621_clk_ids,
- .probe = mt7621_clk_probe,
- .priv_auto = sizeof(struct mt7621_clk_priv),
- .ops = &mt7621_clk_ops,
With that fixed,
Reviewed-by: Sean Anderson seanga2@gmail.com
This patch adds reset controller bits definition header file for MediaTek MT7621 SoC
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v5 changes: none v4 changes: none v3 changes: none v2 changes: none --- include/dt-bindings/reset/mt7621-reset.h | 38 ++++++++++++++++++++++++ 1 file changed, 38 insertions(+) create mode 100644 include/dt-bindings/reset/mt7621-reset.h
diff --git a/include/dt-bindings/reset/mt7621-reset.h b/include/dt-bindings/reset/mt7621-reset.h new file mode 100644 index 0000000000..8e4341f040 --- /dev/null +++ b/include/dt-bindings/reset/mt7621-reset.h @@ -0,0 +1,38 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2022 MediaTek Inc. All rights reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#ifndef _DT_BINDINGS_MT7621_RESET_H_ +#define _DT_BINDINGS_MT7621_RESET_H_ + +#define RST_PPE 31 +#define RST_SDXC 30 +#define RST_CRYPTO 29 +#define RST_AUX_STCK 28 +#define RST_PCIE2 26 +#define RST_PCIE1 25 +#define RST_PCIE0 24 +#define RST_GMAC 23 +#define RST_UART3 21 +#define RST_UART2 20 +#define RST_UART1 19 +#define RST_SPI 18 +#define RST_I2S 17 +#define RST_I2C 16 +#define RST_NFI 15 +#define RST_GDMA 14 +#define RST_PIO 13 +#define RST_PCM 11 +#define RST_MC 10 +#define RST_INTC 9 +#define RST_TIMER 8 +#define RST_SPDIFTX 7 +#define RST_FE 6 +#define RST_HSDMA 5 +#define RST_MCM 2 +#define RST_SYS 0 + +#endif /* _DT_BINDINGS_MT7621_RESET_H_ */
This patch adds pinctrl support for MediaTek MT7621 SoC. The MT7621 SoC supports pinconf, but it is not the same as mt7628.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v5 changes: Remove the use of common.h v4 changes: none v3 changes: none v2 changes: none --- drivers/pinctrl/mtmips/Kconfig | 9 + drivers/pinctrl/mtmips/Makefile | 1 + drivers/pinctrl/mtmips/pinctrl-mt7621.c | 306 ++++++++++++++++++ .../pinctrl/mtmips/pinctrl-mtmips-common.c | 4 +- .../pinctrl/mtmips/pinctrl-mtmips-common.h | 12 + 5 files changed, 330 insertions(+), 2 deletions(-) create mode 100644 drivers/pinctrl/mtmips/pinctrl-mt7621.c
diff --git a/drivers/pinctrl/mtmips/Kconfig b/drivers/pinctrl/mtmips/Kconfig index 844d5b743f..456f3ea25d 100644 --- a/drivers/pinctrl/mtmips/Kconfig +++ b/drivers/pinctrl/mtmips/Kconfig @@ -12,6 +12,15 @@ config PINCTRL_MT7620 The driver is controlled by a device tree node which contains the pin mux functions for each available pin groups.
+config PINCTRL_MT7621 + bool "MediaTek MT7621 pin control driver" + select PINCTRL_MTMIPS + depends on SOC_MT7621 && PINCTRL_GENERIC + help + Support pin multiplexing control on MediaTek MT7621. + The driver is controlled by a device tree node which contains + the pin mux functions for each available pin groups. + config PINCTRL_MT7628 bool "MediaTek MT7628 pin control driver" select PINCTRL_MTMIPS diff --git a/drivers/pinctrl/mtmips/Makefile b/drivers/pinctrl/mtmips/Makefile index ba945a89a7..8fece4f5fa 100644 --- a/drivers/pinctrl/mtmips/Makefile +++ b/drivers/pinctrl/mtmips/Makefile @@ -5,4 +5,5 @@ obj-$(CONFIG_PINCTRL_MTMIPS) += pinctrl-mtmips-common.o
# SoC Drivers obj-$(CONFIG_PINCTRL_MT7620) += pinctrl-mt7620.o +obj-$(CONFIG_PINCTRL_MT7621) += pinctrl-mt7621.o obj-$(CONFIG_PINCTRL_MT7628) += pinctrl-mt7628.o diff --git a/drivers/pinctrl/mtmips/pinctrl-mt7621.c b/drivers/pinctrl/mtmips/pinctrl-mt7621.c new file mode 100644 index 0000000000..3e98a01bad --- /dev/null +++ b/drivers/pinctrl/mtmips/pinctrl-mt7621.c @@ -0,0 +1,306 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 MediaTek Inc. All rights reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <dm.h> +#include <dm/pinctrl.h> +#include <dm/device_compat.h> +#include <linux/bitops.h> +#include <linux/io.h> + +#include "pinctrl-mtmips-common.h" + +#define SYSC_MAP_SIZE 0x100 + +#define PAD_UART1_GPIO0_OFS 0x00 +#define PAD_UART3_I2C_OFS 0x04 +#define PAD_UART2_JTAG_OFS 0x08 +#define PAD_PERST_WDT_OFS 0x0c +#define PAD_RGMII2_MDIO_OFS 0x10 +#define PAD_SDXC_SPI_OFS 0x14 +#define GPIOMODE_OFS 0x18 +#define PAD_BOPT_ESWINT_OFS 0x28 + +#define ESWINT_SHIFT 20 +#define SDXC_SHIFT 18 +#define SPI_SHIFT 16 +#define RGMII2_SHIFT 15 +#define RGMII1_SHIFT 14 +#define MDIO_SHIFT 12 +#define PERST_SHIFT 10 +#define WDT_SHIFT 8 +#define JTAG_SHIFT 7 +#define UART2_SHIFT 5 +#define UART3_SHIFT 3 +#define I2C_SHIFT 2 +#define UART1_SHIFT 1 +#define GPIO0_SHIFT 0 /* Dummy */ + +#define GM4_MASK 3 + +#define E4_E2_M 0x03 +#define E4_E2_S 4 +#define PULL_UP BIT(3) +#define PULL_DOWN BIT(2) +#define SMT BIT(1) +#define SR BIT(0) + +struct mt7621_pinctrl_priv { + struct mtmips_pinctrl_priv mp; +}; + +#if CONFIG_IS_ENABLED(PINMUX) +static const struct mtmips_pmx_func esw_int_grp[] = { + FUNC("gpio", 1), + FUNC("esw int", 0), +}; + +static const struct mtmips_pmx_func sdxc_grp[] = { + FUNC("nand", 2), + FUNC("gpio", 1), + FUNC("sdxc", 0), +}; + +static const struct mtmips_pmx_func spi_grp[] = { + FUNC("nand", 2), + FUNC("gpio", 1), + FUNC("spi", 0), +}; + +static const struct mtmips_pmx_func rgmii2_grp[] = { + FUNC("gpio", 1), + FUNC("rgmii", 0), +}; + +static const struct mtmips_pmx_func rgmii1_grp[] = { + FUNC("gpio", 1), + FUNC("rgmii", 0), +}; + +static const struct mtmips_pmx_func mdio_grp[] = { + FUNC("gpio", 1), + FUNC("mdio", 0), +}; + +static const struct mtmips_pmx_func perst_grp[] = { + FUNC("refclk", 2), + FUNC("gpio", 1), + FUNC("pcie reset", 0), +}; + +static const struct mtmips_pmx_func wdt_grp[] = { + FUNC("refclk", 2), + FUNC("gpio", 1), + FUNC("wdt rst", 0), +}; + +static const struct mtmips_pmx_func jtag_grp[] = { + FUNC("gpio", 1), + FUNC("jtag", 0), +}; + +static const struct mtmips_pmx_func uart2_grp[] = { + FUNC("spdif", 3), + FUNC("pcm", 2), + FUNC("gpio", 1), + FUNC("uart", 0), +}; + +static const struct mtmips_pmx_func uart3_grp[] = { + FUNC("spdif", 3), + FUNC("i2s", 2), + FUNC("gpio", 1), + FUNC("uart", 0), +}; + +static const struct mtmips_pmx_func i2c_grp[] = { + FUNC("gpio", 1), + FUNC("i2c", 0), +}; + +static const struct mtmips_pmx_func uart1_grp[] = { + FUNC("gpio", 1), + FUNC("uart", 0), +}; + +static const struct mtmips_pmx_func gpio0_grp[] = { + FUNC("gpio", 0), +}; + +static const struct mtmips_pmx_group mt7621_pmx_data[] = { + GRP_PCONF("esw int", esw_int_grp, GPIOMODE_OFS, ESWINT_SHIFT, 1, + PAD_BOPT_ESWINT_OFS, 0), + GRP_PCONF("sdxc", sdxc_grp, GPIOMODE_OFS, SDXC_SHIFT, GM4_MASK, + PAD_SDXC_SPI_OFS, 16), + GRP_PCONF("spi", spi_grp, GPIOMODE_OFS, SPI_SHIFT, GM4_MASK, + PAD_SDXC_SPI_OFS, 0), + GRP_PCONF("rgmii2", rgmii2_grp, GPIOMODE_OFS, RGMII2_SHIFT, 1, + PAD_RGMII2_MDIO_OFS, 16), + GRP("rgmii1", rgmii1_grp, GPIOMODE_OFS, RGMII1_SHIFT, 1), + GRP_PCONF("mdio", mdio_grp, GPIOMODE_OFS, MDIO_SHIFT, GM4_MASK, + PAD_RGMII2_MDIO_OFS, 0), + GRP_PCONF("pcie reset", perst_grp, GPIOMODE_OFS, PERST_SHIFT, GM4_MASK, + PAD_PERST_WDT_OFS, 16), + GRP_PCONF("wdt", wdt_grp, GPIOMODE_OFS, WDT_SHIFT, GM4_MASK, + PAD_PERST_WDT_OFS, 0), + GRP_PCONF("jtag", jtag_grp, GPIOMODE_OFS, JTAG_SHIFT, 1, + PAD_UART2_JTAG_OFS, 16), + GRP_PCONF("uart2", uart2_grp, GPIOMODE_OFS, UART2_SHIFT, GM4_MASK, + PAD_UART2_JTAG_OFS, 0), + GRP_PCONF("uart3", uart3_grp, GPIOMODE_OFS, UART3_SHIFT, GM4_MASK, + PAD_UART3_I2C_OFS, 16), + GRP_PCONF("i2c", i2c_grp, GPIOMODE_OFS, I2C_SHIFT, 1, + PAD_UART3_I2C_OFS, 0), + GRP_PCONF("uart1", uart1_grp, GPIOMODE_OFS, UART1_SHIFT, 1, + PAD_UART1_GPIO0_OFS, 16), + GRP_PCONF("gpio0", gpio0_grp, GPIOMODE_OFS, GPIO0_SHIFT, 1, + PAD_UART1_GPIO0_OFS, 0), +}; + +static int mt7621_get_groups_count(struct udevice *dev) +{ + return ARRAY_SIZE(mt7621_pmx_data); +} + +static const char *mt7621_get_group_name(struct udevice *dev, + unsigned int selector) +{ + return mt7621_pmx_data[selector].name; +} +#endif /* CONFIG_IS_ENABLED(PINMUX) */ + +#if CONFIG_IS_ENABLED(PINCONF) +static const struct pinconf_param mt7621_conf_params[] = { + { "bias-disable", PIN_CONFIG_BIAS_DISABLE, 0 }, + { "bias-pull-up", PIN_CONFIG_BIAS_PULL_UP, 1 }, + { "bias-pull-down", PIN_CONFIG_BIAS_PULL_DOWN, 1 }, + { "input-schmitt-enable", PIN_CONFIG_INPUT_SCHMITT_ENABLE, 1 }, + { "input-schmitt-disable", PIN_CONFIG_INPUT_SCHMITT_ENABLE, 0 }, + { "drive-strength", PIN_CONFIG_DRIVE_STRENGTH, 0 }, + { "slew-rate", PIN_CONFIG_SLEW_RATE, 0 }, +}; + +static const u32 mt7621_pconf_drv_strength_tbl[] = {2, 4, 6, 8}; + +static int mt7621_pinconf_group_set(struct udevice *dev, + unsigned int group_selector, + unsigned int param, unsigned int arg) +{ + struct mt7621_pinctrl_priv *priv = dev_get_priv(dev); + const struct mtmips_pmx_group *grp = &mt7621_pmx_data[group_selector]; + u32 clr = 0, set = 0; + int i; + + if (!grp->pconf_avail) + return 0; + + switch (param) { + case PIN_CONFIG_BIAS_DISABLE: + clr = PULL_UP | PULL_DOWN; + break; + + case PIN_CONFIG_BIAS_PULL_UP: + clr = PULL_DOWN; + set = PULL_UP; + break; + + case PIN_CONFIG_BIAS_PULL_DOWN: + clr = PULL_UP; + set = PULL_DOWN; + break; + + case PIN_CONFIG_INPUT_SCHMITT_ENABLE: + if (arg) + set = SMT; + else + clr = SMT; + break; + + case PIN_CONFIG_DRIVE_STRENGTH: + for (i = 0; i < ARRAY_SIZE(mt7621_pconf_drv_strength_tbl); i++) + if (mt7621_pconf_drv_strength_tbl[i] == arg) + break; + + if (i >= ARRAY_SIZE(mt7621_pconf_drv_strength_tbl)) + return -EINVAL; + + clr = E4_E2_M << E4_E2_S; + set = i << E4_E2_S; + break; + + case PIN_CONFIG_SLEW_RATE: + if (arg) + set = SR; + else + clr = SR; + break; + + default: + return -EINVAL; + } + + mtmips_pinctrl_reg_set(&priv->mp, grp->pconf_reg, grp->pconf_shift, + clr, set); + + return 0; +} +#endif + +static int mt7621_pinctrl_probe(struct udevice *dev) +{ + struct mt7621_pinctrl_priv *priv = dev_get_priv(dev); + int ret = 0; + +#if CONFIG_IS_ENABLED(PINMUX) + ret = mtmips_pinctrl_probe(&priv->mp, ARRAY_SIZE(mt7621_pmx_data), + mt7621_pmx_data); +#endif /* CONFIG_IS_ENABLED(PINMUX) */ + + return ret; +} + +static int mt7621_pinctrl_of_to_plat(struct udevice *dev) +{ + struct mt7621_pinctrl_priv *priv = dev_get_priv(dev); + + priv->mp.base = (void __iomem *)dev_remap_addr_index(dev, 0); + + if (!priv->mp.base) + return -EINVAL; + + return 0; +} + +static const struct pinctrl_ops mt7621_pinctrl_ops = { +#if CONFIG_IS_ENABLED(PINMUX) + .get_groups_count = mt7621_get_groups_count, + .get_group_name = mt7621_get_group_name, + .get_functions_count = mtmips_get_functions_count, + .get_function_name = mtmips_get_function_name, + .pinmux_group_set = mtmips_pinmux_group_set, +#endif /* CONFIG_IS_ENABLED(PINMUX) */ +#if CONFIG_IS_ENABLED(PINCONF) + .pinconf_num_params = ARRAY_SIZE(mt7621_conf_params), + .pinconf_params = mt7621_conf_params, + .pinconf_group_set = mt7621_pinconf_group_set, +#endif /* CONFIG_IS_ENABLED(PINCONF) */ + .set_state = pinctrl_generic_set_state, +}; + +static const struct udevice_id mt7621_pinctrl_ids[] = { + { .compatible = "mediatek,mt7621-pinctrl" }, + { } +}; + +U_BOOT_DRIVER(mt7621_pinctrl) = { + .name = "mt7621-pinctrl", + .id = UCLASS_PINCTRL, + .of_match = mt7621_pinctrl_ids, + .of_to_plat = mt7621_pinctrl_of_to_plat, + .ops = &mt7621_pinctrl_ops, + .probe = mt7621_pinctrl_probe, + .priv_auto = sizeof(struct mt7621_pinctrl_priv), +}; diff --git a/drivers/pinctrl/mtmips/pinctrl-mtmips-common.c b/drivers/pinctrl/mtmips/pinctrl-mtmips-common.c index e361916eb2..869b781068 100644 --- a/drivers/pinctrl/mtmips/pinctrl-mtmips-common.c +++ b/drivers/pinctrl/mtmips/pinctrl-mtmips-common.c @@ -13,8 +13,8 @@
-static void mtmips_pinctrl_reg_set(struct mtmips_pinctrl_priv *priv, - u32 reg, u32 shift, u32 mask, u32 value) +void mtmips_pinctrl_reg_set(struct mtmips_pinctrl_priv *priv, + u32 reg, u32 shift, u32 mask, u32 value) { u32 val;
diff --git a/drivers/pinctrl/mtmips/pinctrl-mtmips-common.h b/drivers/pinctrl/mtmips/pinctrl-mtmips-common.h index b51d8f009c..1f1023ef42 100644 --- a/drivers/pinctrl/mtmips/pinctrl-mtmips-common.h +++ b/drivers/pinctrl/mtmips/pinctrl-mtmips-common.h @@ -22,6 +22,10 @@ struct mtmips_pmx_group { u32 shift; char mask;
+ int pconf_avail; + u32 pconf_reg; + u32 pconf_shift; + int nfuncs; const struct mtmips_pmx_func *funcs; }; @@ -42,6 +46,14 @@ struct mtmips_pinctrl_priv { { .name = (_name), .reg = (_reg), .shift = (_shift), .mask = (_mask), \ .funcs = (_funcs), .nfuncs = ARRAY_SIZE(_funcs) }
+#define GRP_PCONF(_name, _funcs, _reg, _shift, _mask, _pconf_reg, _pconf_shift) \ + { .name = (_name), .reg = (_reg), .shift = (_shift), .mask = (_mask), \ + .funcs = (_funcs), .nfuncs = ARRAY_SIZE(_funcs), .pconf_avail = 1, \ + .pconf_reg = (_pconf_reg), .pconf_shift = (_pconf_shift) } + +void mtmips_pinctrl_reg_set(struct mtmips_pinctrl_priv *priv, + u32 reg, u32 shift, u32 mask, u32 value); + int mtmips_get_functions_count(struct udevice *dev); const char *mtmips_get_function_name(struct udevice *dev, unsigned int selector);
This patch makes xhci-mtk driver available for MediaTek MT7621 SoC
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v5 changes: none v4 changes: none v3 changes: none v2 changes: none --- drivers/usb/host/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/usb/host/Kconfig b/drivers/usb/host/Kconfig index 8f77412cc7..8f7bfe1602 100644 --- a/drivers/usb/host/Kconfig +++ b/drivers/usb/host/Kconfig @@ -34,7 +34,7 @@ config USB_XHCI_DWC3_OF_SIMPLE
config USB_XHCI_MTK bool "Support for MediaTek on-chip xHCI USB controller" - depends on ARCH_MEDIATEK + depends on ARCH_MEDIATEK || SOC_MT7621 help Enables support for the on-chip xHCI controller on MediaTek SoCs.
This patch makes mtk-tphy driver available for MediaTek MT7621 SoC
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v5 changes: none v4 changes: none v3 changes: none v2 changes: none --- drivers/phy/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/phy/Kconfig b/drivers/phy/Kconfig index c01d9e09b9..1708d4f533 100644 --- a/drivers/phy/Kconfig +++ b/drivers/phy/Kconfig @@ -266,7 +266,7 @@ config MT76X8_USB_PHY config PHY_MTK_TPHY bool "MediaTek T-PHY Driver" depends on PHY - depends on ARCH_MEDIATEK + depends on ARCH_MEDIATEK || SOC_MT7621 help MediaTek T-PHY driver supports usb2.0, usb3.0 ports, PCIe and SATA, and meanwhile supports two version T-PHY which have
This patch makes mt7621_spi driver available for MediaTek MT7621 SoC
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v5 changes: none v4 changes: none v3 changes: none v2 changes: none --- drivers/spi/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index a1e515cb2b..2923ed8db3 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -240,7 +240,7 @@ config MT7620_SPI
config MT7621_SPI bool "MediaTek MT7621 SPI driver" - depends on SOC_MT7628 + depends on SOC_MT7621 || SOC_MT7628 help Enable the MT7621 SPI driver. This driver can be used to access the SPI NOR flash on platforms embedding this Ralink / MediaTek
This patch makes mt7621_gpio driver available for MediaTek MT7621 SoC
Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v5 changes: none v4 changes: none v3 changes: none v2 changes: none --- drivers/gpio/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index 149a62ffe6..a6b174339e 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -552,7 +552,7 @@ config MT7620_GPIO
config MT7621_GPIO bool "MediaTek MT7621 GPIO driver" - depends on DM_GPIO && SOC_MT7628 + depends on DM_GPIO && (SOC_MT7621 || SOC_MT7628) default y help Say yes here to support MediaTek MT7621 compatible GPIOs.
This patch makes mt7621_wdt driver available for MediaTek MT7621 SoC
Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v5 changes: none v4 changes: none v3 changes: none v2 changes: none --- drivers/watchdog/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/watchdog/Kconfig b/drivers/watchdog/Kconfig index c3eb8a8aec..dfb02aa468 100644 --- a/drivers/watchdog/Kconfig +++ b/drivers/watchdog/Kconfig @@ -191,7 +191,7 @@ config WDT_MT7620
config WDT_MT7621 bool "MediaTek MT7621 watchdog timer support" - depends on WDT && SOC_MT7628 + depends on WDT && (SOC_MT7621 || SOC_MT7628) help Select this to enable Ralink / Mediatek watchdog timer, which can be found on some MediaTek chips.
This patch adds SDXC support for MediaTek MT7621 SoC
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v5 changes: none v4 changes: none v3 changes: none v2 changes: none --- drivers/mmc/mtk-sd.c | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/drivers/mmc/mtk-sd.c b/drivers/mmc/mtk-sd.c index 97182ffd7f..e61e8cf4b9 100644 --- a/drivers/mmc/mtk-sd.c +++ b/drivers/mmc/mtk-sd.c @@ -1761,6 +1761,18 @@ static const struct msdc_compatible mt7620_compat = { .default_pad_dly = true, };
+static const struct msdc_compatible mt7621_compat = { + .clk_div_bits = 8, + .pad_tune0 = false, + .async_fifo = true, + .data_tune = true, + .busy_check = false, + .stop_clk_fix = false, + .enhance_rx = false, + .builtin_pad_ctrl = true, + .default_pad_dly = true, +}; + static const struct msdc_compatible mt7622_compat = { .clk_div_bits = 12, .pad_tune0 = true, @@ -1809,6 +1821,7 @@ static const struct msdc_compatible mt8183_compat = {
static const struct udevice_id msdc_ids[] = { { .compatible = "mediatek,mt7620-mmc", .data = (ulong)&mt7620_compat }, + { .compatible = "mediatek,mt7621-mmc", .data = (ulong)&mt7621_compat }, { .compatible = "mediatek,mt7622-mmc", .data = (ulong)&mt7622_compat }, { .compatible = "mediatek,mt7623-mmc", .data = (ulong)&mt7623_compat }, { .compatible = "mediatek,mt8512-mmc", .data = (ulong)&mt8512_compat },
The iobase address from dts node is actually physical address. It's identical to the virtual address in ARM platform. This is ok because this driver was used only by ARM platforms (mt7622/mt7623 ...).
But now this driver will be used by mt7621 which is a MIPS SoC. For MIPS platform the physical address space is mapped to KSEG0 and KSEG1 and this makes the virtual address apparently not idential to its physical address.
To solve this issue, this patch replaces dev_read_addr with dev_remap_addr to get the remapped iobase address.
Reviewed-by: Ramon Fried rfried.dev@gmail.com Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v5 changes: none v4 changes: new --- drivers/net/mtk_eth.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/mtk_eth.c b/drivers/net/mtk_eth.c index 666ddeb10d..caa83b7cec 100644 --- a/drivers/net/mtk_eth.c +++ b/drivers/net/mtk_eth.c @@ -1419,7 +1419,7 @@ static int mtk_eth_of_to_plat(struct udevice *dev)
priv->soc = dev_get_driver_data(dev);
- pdata->iobase = dev_read_addr(dev); + pdata->iobase = (phys_addr_t)dev_remap_addr(dev);
/* get corresponding ethsys phandle */ ret = dev_read_phandle_with_args(dev, "mediatek,ethsys", NULL, 0, 0,
The address returned by regmap_get_range() is not remapped. Directly r/w to this address is ok for ARM platforms since it's idential to the virtual address.
But for MIPS platform only virtual address should be used for access. To solve this issue, the regmap api regmap_read/regmap_write should be used since they will remap address before accessing.
Reviewed-by: Ramon Fried rfried.dev@gmail.com Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v5 changes: none v4 changes: new --- drivers/net/mtk_eth.c | 22 +++++++++++----------- 1 file changed, 11 insertions(+), 11 deletions(-)
diff --git a/drivers/net/mtk_eth.c b/drivers/net/mtk_eth.c index caa83b7cec..ac1e8abd71 100644 --- a/drivers/net/mtk_eth.c +++ b/drivers/net/mtk_eth.c @@ -159,9 +159,10 @@ struct mtk_eth_priv {
void __iomem *fe_base; void __iomem *gmac_base; - void __iomem *ethsys_base; void __iomem *sgmii_base;
+ struct regmap *ethsys_regmap; + struct mii_dev *mdio_bus; int (*mii_read)(struct mtk_eth_priv *priv, u8 phy, u8 reg); int (*mii_write)(struct mtk_eth_priv *priv, u8 phy, u8 reg, u16 val); @@ -233,7 +234,12 @@ static void mtk_gmac_rmw(struct mtk_eth_priv *priv, u32 reg, u32 clr, u32 set) static void mtk_ethsys_rmw(struct mtk_eth_priv *priv, u32 reg, u32 clr, u32 set) { - clrsetbits_le32(priv->ethsys_base + reg, clr, set); + uint val; + + regmap_read(priv->ethsys_regmap, reg, &val); + val &= ~clr; + val |= set; + regmap_write(priv->ethsys_regmap, reg, val); }
/* Direct MDIO clause 22/45 access via SoC */ @@ -1427,15 +1433,9 @@ static int mtk_eth_of_to_plat(struct udevice *dev) if (ret) return ret;
- regmap = syscon_node_to_regmap(args.node); - if (IS_ERR(regmap)) - return PTR_ERR(regmap); - - priv->ethsys_base = regmap_get_range(regmap, 0); - if (!priv->ethsys_base) { - dev_err(dev, "Unable to find ethsys\n"); - return -ENODEV; - } + priv->ethsys_regmap = syscon_node_to_regmap(args.node); + if (IS_ERR(priv->ethsys_regmap)) + return PTR_ERR(priv->ethsys_regmap);
/* Reset controllers */ ret = reset_get_by_name(dev, "fe", &priv->rst_fe);
This patch adds GMAC support for MediaTek MT7621 SoC. MT7621 has the same GMAC/Switch configuration as MT7623.
Reviewed-by: Ramon Fried rfried.dev@gmail.com Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v5 changes: none v4 changes: Split unrelated changes to new patches v3 changes: Add register remap needed by mt7621 Fix use of noncached_alloc v2 changes: none --- drivers/net/mtk_eth.c | 21 +++++++++++++++------ 1 file changed, 15 insertions(+), 6 deletions(-)
diff --git a/drivers/net/mtk_eth.c b/drivers/net/mtk_eth.c index ac1e8abd71..4fe7ee0d36 100644 --- a/drivers/net/mtk_eth.c +++ b/drivers/net/mtk_eth.c @@ -145,7 +145,8 @@ enum mtk_switch { enum mtk_soc { SOC_MT7623, SOC_MT7629, - SOC_MT7622 + SOC_MT7622, + SOC_MT7621 };
struct mtk_eth_priv { @@ -675,12 +676,18 @@ static int mt7530_pad_clk_setup(struct mtk_eth_priv *priv, int mode) static int mt7530_setup(struct mtk_eth_priv *priv) { u16 phy_addr, phy_val; - u32 val; + u32 val, txdrv; int i;
- /* Select 250MHz clk for RGMII mode */ - mtk_ethsys_rmw(priv, ETHSYS_CLKCFG0_REG, - ETHSYS_TRGMII_CLK_SEL362_5, 0); + if (priv->soc != SOC_MT7621) { + /* Select 250MHz clk for RGMII mode */ + mtk_ethsys_rmw(priv, ETHSYS_CLKCFG0_REG, + ETHSYS_TRGMII_CLK_SEL362_5, 0); + + txdrv = 8; + } else { + txdrv = 4; + }
/* Modify HWTRAP first to allow direct access to internal PHYs */ mt753x_reg_read(priv, HWTRAP_REG, &val); @@ -738,7 +745,8 @@ static int mt7530_setup(struct mtk_eth_priv *priv) /* Lower Tx Driving for TRGMII path */ for (i = 0 ; i < NUM_TRGMII_CTRL ; i++) mt753x_reg_write(priv, MT7530_TRGMII_TD_ODT(i), - (8 << TD_DM_DRVP_S) | (8 << TD_DM_DRVN_S)); + (txdrv << TD_DM_DRVP_S) | + (txdrv << TD_DM_DRVN_S));
for (i = 0 ; i < NUM_TRGMII_CTRL; i++) mt753x_reg_rmw(priv, MT7530_TRGMII_RD(i), RD_TAP_M, 16); @@ -1540,6 +1548,7 @@ static const struct udevice_id mtk_eth_ids[] = { { .compatible = "mediatek,mt7629-eth", .data = SOC_MT7629 }, { .compatible = "mediatek,mt7623-eth", .data = SOC_MT7623 }, { .compatible = "mediatek,mt7622-eth", .data = SOC_MT7622 }, + { .compatible = "mediatek,mt7621-eth", .data = SOC_MT7621 }, {} };
This patch adds NAND flash controller driver for MediaTek MT7621 SoC. The NAND flash controller of MT7621 supports only SLC NAND flashes. It supports 4~12 bits correction with maximum 4KB page size.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com v5 changes: remove unused code from spl loader v4 changes: Add support for spl loader v3 changes: none v2 changes: none --- drivers/mtd/nand/raw/Kconfig | 17 +- drivers/mtd/nand/raw/Makefile | 2 + drivers/mtd/nand/raw/mt7621_nand.c | 1224 ++++++++++++++++++++++++ drivers/mtd/nand/raw/mt7621_nand.h | 29 + drivers/mtd/nand/raw/mt7621_nand_spl.c | 237 +++++ 5 files changed, 1507 insertions(+), 2 deletions(-) create mode 100644 drivers/mtd/nand/raw/mt7621_nand.c create mode 100644 drivers/mtd/nand/raw/mt7621_nand.h create mode 100644 drivers/mtd/nand/raw/mt7621_nand_spl.c
diff --git a/drivers/mtd/nand/raw/Kconfig b/drivers/mtd/nand/raw/Kconfig index d75f371c95..1663f1941c 100644 --- a/drivers/mtd/nand/raw/Kconfig +++ b/drivers/mtd/nand/raw/Kconfig @@ -521,12 +521,25 @@ config TEGRA_NAND help Enables support for NAND Flash chips on Tegra SoCs platforms.
+config NAND_MT7621 + bool "Support for MediaTek MT7621 NAND flash controller" + depends on SOC_MT7621 + select SYS_NAND_SELF_INIT + select SPL_SYS_NAND_SELF_INIT + imply CMD_NAND + help + This enables NAND driver for the NAND flash controller on MediaTek + MT7621 platform. + The controller supports 4~12 bits correction per 512 bytes with a + maximum 4KB page size. + comment "Generic NAND options"
config SYS_NAND_BLOCK_SIZE hex "NAND chip eraseblock size" depends on ARCH_SUNXI || SPL_NAND_SUPPORT || TPL_NAND_SUPPORT - depends on !NAND_MXS && !NAND_DENALI_DT && !NAND_LPC32XX_MLC && !NAND_FSL_IFC + depends on !NAND_MXS && !NAND_DENALI_DT && !NAND_LPC32XX_MLC && \ + !NAND_FSL_IFC && !NAND_MT7621 help Number of data bytes in one eraseblock for the NAND chip on the board. This is the multiple of NAND_PAGE_SIZE and the number of @@ -551,7 +564,7 @@ config SYS_NAND_PAGE_SIZE depends on ARCH_SUNXI || NAND_OMAP_GPMC || NAND_LPC32XX_SLC || \ SPL_NAND_SIMPLE || (NAND_MXC && SPL_NAND_SUPPORT) || \ (NAND_ATMEL && SPL_NAND_SUPPORT) || SPL_GENERATE_ATMEL_PMECC_HEADER - depends on !NAND_MXS && !NAND_DENALI_DT && !NAND_LPC32XX_MLC + depends on !NAND_MXS && !NAND_DENALI_DT && !NAND_LPC32XX_MLC && !NAND_MT7621 help Number of data bytes in one page for the NAND chip on the board, not including the OOB area. diff --git a/drivers/mtd/nand/raw/Makefile b/drivers/mtd/nand/raw/Makefile index 6ec3581d20..cfc9c0fff0 100644 --- a/drivers/mtd/nand/raw/Makefile +++ b/drivers/mtd/nand/raw/Makefile @@ -72,6 +72,7 @@ obj-$(CONFIG_NAND_ZYNQ) += zynq_nand.o obj-$(CONFIG_NAND_STM32_FMC2) += stm32_fmc2_nand.o obj-$(CONFIG_CORTINA_NAND) += cortina_nand.o obj-$(CONFIG_ROCKCHIP_NAND) += rockchip_nfc.o +obj-$(CONFIG_NAND_MT7621) += mt7621_nand.o
else # minimal SPL drivers
@@ -80,5 +81,6 @@ obj-$(CONFIG_NAND_FSL_IFC) += fsl_ifc_spl.o obj-$(CONFIG_NAND_MXC) += mxc_nand_spl.o obj-$(CONFIG_NAND_MXS) += mxs_nand_spl.o mxs_nand.o obj-$(CONFIG_NAND_SUNXI) += sunxi_nand_spl.o +obj-$(CONFIG_NAND_MT7621) += mt7621_nand_spl.o mt7621_nand.o
endif # drivers diff --git a/drivers/mtd/nand/raw/mt7621_nand.c b/drivers/mtd/nand/raw/mt7621_nand.c new file mode 100644 index 0000000000..a8ad5e2a30 --- /dev/null +++ b/drivers/mtd/nand/raw/mt7621_nand.c @@ -0,0 +1,1224 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 MediaTek Inc. All rights reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <log.h> +#include <nand.h> +#include <malloc.h> +#include <asm/addrspace.h> +#include <linux/io.h> +#include <linux/iopoll.h> +#include <linux/sizes.h> +#include <linux/bitops.h> +#include "mt7621_nand.h" + +/* NFI core registers */ +#define NFI_CNFG 0x000 +#define CNFG_OP_MODE_S 12 +#define CNFG_OP_MODE_M GENMASK(14, 12) +#define CNFG_OP_CUSTOM 6 +#define CNFG_AUTO_FMT_EN BIT(9) +#define CNFG_HW_ECC_EN BIT(8) +#define CNFG_BYTE_RW BIT(6) +#define CNFG_READ_MODE BIT(1) + +#define NFI_PAGEFMT 0x004 +#define PAGEFMT_FDM_ECC_S 12 +#define PAGEFMT_FDM_ECC_M GENMASK(15, 12) +#define PAGEFMT_FDM_S 8 +#define PAGEFMT_FDM_M GENMASK(11, 8) +#define PAGEFMT_SPARE_S 4 +#define PAGEFMT_SPARE_M GENMASK(5, 4) +#define PAGEFMT_PAGE_S 0 +#define PAGEFMT_PAGE_M GENMASK(1, 0) + +#define NFI_CON 0x008 +#define CON_NFI_SEC_S 12 +#define CON_NFI_SEC_M GENMASK(15, 12) +#define CON_NFI_BWR BIT(9) +#define CON_NFI_BRD BIT(8) +#define CON_NFI_RST BIT(1) +#define CON_FIFO_FLUSH BIT(0) + +#define NFI_ACCCON 0x00c +#define ACCCON_POECS_S 28 +#define ACCCON_POECS_MAX 0x0f +#define ACCCON_POECS_DEF 3 +#define ACCCON_PRECS_S 22 +#define ACCCON_PRECS_MAX 0x3f +#define ACCCON_PRECS_DEF 3 +#define ACCCON_C2R_S 16 +#define ACCCON_C2R_MAX 0x3f +#define ACCCON_C2R_DEF 7 +#define ACCCON_W2R_S 12 +#define ACCCON_W2R_MAX 0x0f +#define ACCCON_W2R_DEF 7 +#define ACCCON_WH_S 8 +#define ACCCON_WH_MAX 0x0f +#define ACCCON_WH_DEF 15 +#define ACCCON_WST_S 4 +#define ACCCON_WST_MAX 0x0f +#define ACCCON_WST_DEF 15 +#define ACCCON_WST_MIN 3 +#define ACCCON_RLT_S 0 +#define ACCCON_RLT_MAX 0x0f +#define ACCCON_RLT_DEF 15 +#define ACCCON_RLT_MIN 3 + +#define NFI_CMD 0x020 + +#define NFI_ADDRNOB 0x030 +#define ADDR_ROW_NOB_S 4 +#define ADDR_ROW_NOB_M GENMASK(6, 4) +#define ADDR_COL_NOB_S 0 +#define ADDR_COL_NOB_M GENMASK(2, 0) + +#define NFI_COLADDR 0x034 +#define NFI_ROWADDR 0x038 + +#define NFI_STRDATA 0x040 +#define STR_DATA BIT(0) + +#define NFI_CNRNB 0x044 +#define CB2R_TIME_S 4 +#define CB2R_TIME_M GENMASK(7, 4) +#define STR_CNRNB BIT(0) + +#define NFI_DATAW 0x050 +#define NFI_DATAR 0x054 + +#define NFI_PIO_DIRDY 0x058 +#define PIO_DIRDY BIT(0) + +#define NFI_STA 0x060 +#define STA_NFI_FSM_S 16 +#define STA_NFI_FSM_M GENMASK(19, 16) +#define STA_FSM_CUSTOM_DATA 14 +#define STA_BUSY BIT(8) +#define STA_ADDR BIT(1) +#define STA_CMD BIT(0) + +#define NFI_ADDRCNTR 0x070 +#define SEC_CNTR_S 12 +#define SEC_CNTR_M GENMASK(15, 12) +#define SEC_ADDR_S 0 +#define SEC_ADDR_M GENMASK(9, 0) + +#define NFI_CSEL 0x090 +#define CSEL_S 0 +#define CSEL_M GENMASK(1, 0) + +#define NFI_FDM0L 0x0a0 +#define NFI_FDML(n) (0x0a0 + ((n) << 3)) + +#define NFI_FDM0M 0x0a4 +#define NFI_FDMM(n) (0x0a4 + ((n) << 3)) + +#define NFI_MASTER_STA 0x210 +#define MAS_ADDR GENMASK(11, 9) +#define MAS_RD GENMASK(8, 6) +#define MAS_WR GENMASK(5, 3) +#define MAS_RDDLY GENMASK(2, 0) + +/* ECC engine registers */ +#define ECC_ENCCON 0x000 +#define ENC_EN BIT(0) + +#define ECC_ENCCNFG 0x004 +#define ENC_CNFG_MSG_S 16 +#define ENC_CNFG_MSG_M GENMASK(28, 16) +#define ENC_MODE_S 4 +#define ENC_MODE_M GENMASK(5, 4) +#define ENC_MODE_NFI 1 +#define ENC_TNUM_S 0 +#define ENC_TNUM_M GENMASK(2, 0) + +#define ECC_ENCIDLE 0x00c +#define ENC_IDLE BIT(0) + +#define ECC_DECCON 0x100 +#define DEC_EN BIT(0) + +#define ECC_DECCNFG 0x104 +#define DEC_EMPTY_EN BIT(31) +#define DEC_CS_S 16 +#define DEC_CS_M GENMASK(28, 16) +#define DEC_CON_S 12 +#define DEC_CON_M GENMASK(13, 12) +#define DEC_CON_EL 2 +#define DEC_MODE_S 4 +#define DEC_MODE_M GENMASK(5, 4) +#define DEC_MODE_NFI 1 +#define DEC_TNUM_S 0 +#define DEC_TNUM_M GENMASK(2, 0) + +#define ECC_DECIDLE 0x10c +#define DEC_IDLE BIT(1) + +#define ECC_DECENUM 0x114 +#define ERRNUM_S 2 +#define ERRNUM_M GENMASK(3, 0) + +#define ECC_DECDONE 0x118 +#define DEC_DONE7 BIT(7) +#define DEC_DONE6 BIT(6) +#define DEC_DONE5 BIT(5) +#define DEC_DONE4 BIT(4) +#define DEC_DONE3 BIT(3) +#define DEC_DONE2 BIT(2) +#define DEC_DONE1 BIT(1) +#define DEC_DONE0 BIT(0) + +#define ECC_DECEL(n) (0x11c + (n) * 4) +#define DEC_EL_ODD_S 16 +#define DEC_EL_EVEN_S 0 +#define DEC_EL_M 0x1fff +#define DEC_EL_BYTE_POS_S 3 +#define DEC_EL_BIT_POS_M GENMASK(2, 0) + +#define ECC_FDMADDR 0x13c + +/* ENCIDLE and DECIDLE */ +#define ECC_IDLE BIT(0) + +#define ACCTIMING(tpoecs, tprecs, tc2r, tw2r, twh, twst, trlt) \ + ((tpoecs) << ACCCON_POECS_S | (tprecs) << ACCCON_PRECS_S | \ + (tc2r) << ACCCON_C2R_S | (tw2r) << ACCCON_W2R_S | \ + (twh) << ACCCON_WH_S | (twst) << ACCCON_WST_S | (trlt)) + +#define MASTER_STA_MASK (MAS_ADDR | MAS_RD | MAS_WR | \ + MAS_RDDLY) +#define NFI_RESET_TIMEOUT 1000000 +#define NFI_CORE_TIMEOUT 500000 +#define ECC_ENGINE_TIMEOUT 500000 + +#define ECC_SECTOR_SIZE 512 +#define ECC_PARITY_BITS 13 + +#define NFI_FDM_SIZE 8 + +/* Register base */ +#define NFI_BASE 0x1e003000 +#define NFI_ECC_BASE 0x1e003800 + +static struct mt7621_nfc nfc_dev; + +static const u16 mt7621_nfi_page_size[] = { SZ_512, SZ_2K, SZ_4K }; +static const u8 mt7621_nfi_spare_size[] = { 16, 26, 27, 28 }; +static const u8 mt7621_ecc_strength[] = { 4, 6, 8, 10, 12 }; + +static inline u32 nfi_read32(struct mt7621_nfc *nfc, u32 reg) +{ + return readl(nfc->nfi_regs + reg); +} + +static inline void nfi_write32(struct mt7621_nfc *nfc, u32 reg, u32 val) +{ + writel(val, nfc->nfi_regs + reg); +} + +static inline u16 nfi_read16(struct mt7621_nfc *nfc, u32 reg) +{ + return readw(nfc->nfi_regs + reg); +} + +static inline void nfi_write16(struct mt7621_nfc *nfc, u32 reg, u16 val) +{ + writew(val, nfc->nfi_regs + reg); +} + +static inline void ecc_write16(struct mt7621_nfc *nfc, u32 reg, u16 val) +{ + writew(val, nfc->ecc_regs + reg); +} + +static inline u32 ecc_read32(struct mt7621_nfc *nfc, u32 reg) +{ + return readl(nfc->ecc_regs + reg); +} + +static inline void ecc_write32(struct mt7621_nfc *nfc, u32 reg, u32 val) +{ + return writel(val, nfc->ecc_regs + reg); +} + +static inline u8 *oob_fdm_ptr(struct nand_chip *nand, int sect) +{ + return nand->oob_poi + sect * NFI_FDM_SIZE; +} + +static inline u8 *oob_ecc_ptr(struct mt7621_nfc *nfc, int sect) +{ + struct nand_chip *nand = &nfc->nand; + + return nand->oob_poi + nand->ecc.steps * NFI_FDM_SIZE + + sect * (nfc->spare_per_sector - NFI_FDM_SIZE); +} + +static inline u8 *page_data_ptr(struct nand_chip *nand, const u8 *buf, + int sect) +{ + return (u8 *)buf + sect * nand->ecc.size; +} + +static int mt7621_ecc_wait_idle(struct mt7621_nfc *nfc, u32 reg) +{ + u32 val; + int ret; + + ret = readw_poll_timeout(nfc->ecc_regs + reg, val, val & ECC_IDLE, + ECC_ENGINE_TIMEOUT); + if (ret) { + pr_warn("ECC engine timed out entering idle mode\n"); + return -EIO; + } + + return 0; +} + +static int mt7621_ecc_decoder_wait_done(struct mt7621_nfc *nfc, u32 sect) +{ + u32 val; + int ret; + + ret = readw_poll_timeout(nfc->ecc_regs + ECC_DECDONE, val, + val & (1 << sect), ECC_ENGINE_TIMEOUT); + if (ret) { + pr_warn("ECC decoder for sector %d timed out\n", sect); + return -ETIMEDOUT; + } + + return 0; +} + +static void mt7621_ecc_encoder_op(struct mt7621_nfc *nfc, bool enable) +{ + mt7621_ecc_wait_idle(nfc, ECC_ENCIDLE); + ecc_write16(nfc, ECC_ENCCON, enable ? ENC_EN : 0); +} + +static void mt7621_ecc_decoder_op(struct mt7621_nfc *nfc, bool enable) +{ + mt7621_ecc_wait_idle(nfc, ECC_DECIDLE); + ecc_write16(nfc, ECC_DECCON, enable ? DEC_EN : 0); +} + +static int mt7621_ecc_correct_check(struct mt7621_nfc *nfc, u8 *sector_buf, + u8 *fdm_buf, u32 sect) +{ + struct nand_chip *nand = &nfc->nand; + u32 decnum, num_error_bits, fdm_end_bits; + u32 error_locations, error_bit_loc; + u32 error_byte_pos, error_bit_pos; + int bitflips = 0; + u32 i; + + decnum = ecc_read32(nfc, ECC_DECENUM); + num_error_bits = (decnum >> (sect << ERRNUM_S)) & ERRNUM_M; + fdm_end_bits = (nand->ecc.size + NFI_FDM_SIZE) << 3; + + if (!num_error_bits) + return 0; + + if (num_error_bits == ERRNUM_M) + return -1; + + for (i = 0; i < num_error_bits; i++) { + error_locations = ecc_read32(nfc, ECC_DECEL(i / 2)); + error_bit_loc = (error_locations >> ((i % 2) * DEC_EL_ODD_S)) & + DEC_EL_M; + error_byte_pos = error_bit_loc >> DEC_EL_BYTE_POS_S; + error_bit_pos = error_bit_loc & DEC_EL_BIT_POS_M; + + if (error_bit_loc < (nand->ecc.size << 3)) { + if (sector_buf) { + sector_buf[error_byte_pos] ^= + (1 << error_bit_pos); + } + } else if (error_bit_loc < fdm_end_bits) { + if (fdm_buf) { + fdm_buf[error_byte_pos - nand->ecc.size] ^= + (1 << error_bit_pos); + } + } + + bitflips++; + } + + return bitflips; +} + +static int mt7621_nfc_wait_write_completion(struct mt7621_nfc *nfc, + struct nand_chip *nand) +{ + u16 val; + int ret; + + ret = readw_poll_timeout(nfc->nfi_regs + NFI_ADDRCNTR, val, + ((val & SEC_CNTR_M) >> SEC_CNTR_S) >= nand->ecc.steps, + NFI_CORE_TIMEOUT); + + if (ret) { + pr_warn("NFI core write operation timed out\n"); + return -ETIMEDOUT; + } + + return ret; +} + +static void mt7621_nfc_hw_reset(struct mt7621_nfc *nfc) +{ + u32 val; + int ret; + + /* reset all registers and force the NFI master to terminate */ + nfi_write16(nfc, NFI_CON, CON_FIFO_FLUSH | CON_NFI_RST); + + /* wait for the master to finish the last transaction */ + ret = readw_poll_timeout(nfc->nfi_regs + NFI_MASTER_STA, val, + !(val & MASTER_STA_MASK), NFI_RESET_TIMEOUT); + if (ret) { + pr_warn("Failed to reset NFI master in %dms\n", + NFI_RESET_TIMEOUT); + } + + /* ensure any status register affected by the NFI master is reset */ + nfi_write16(nfc, NFI_CON, CON_FIFO_FLUSH | CON_NFI_RST); + nfi_write16(nfc, NFI_STRDATA, 0); +} + +static inline void mt7621_nfc_hw_init(struct mt7621_nfc *nfc) +{ + u32 acccon; + + /* + * CNRNB: nand ready/busy register + * ------------------------------- + * 7:4: timeout register for polling the NAND busy/ready signal + * 0 : poll the status of the busy/ready signal after [7:4]*16 cycles. + */ + nfi_write16(nfc, NFI_CNRNB, CB2R_TIME_M | STR_CNRNB); + + mt7621_nfc_hw_reset(nfc); + + /* Apply default access timing */ + acccon = ACCTIMING(ACCCON_POECS_DEF, ACCCON_PRECS_DEF, ACCCON_C2R_DEF, + ACCCON_W2R_DEF, ACCCON_WH_DEF, ACCCON_WST_DEF, + ACCCON_RLT_DEF); + + nfi_write32(nfc, NFI_ACCCON, acccon); +} + +static int mt7621_nfc_send_command(struct mt7621_nfc *nfc, u8 command) +{ + u32 val; + int ret; + + nfi_write32(nfc, NFI_CMD, command); + + ret = readl_poll_timeout(nfc->nfi_regs + NFI_STA, val, !(val & STA_CMD), + NFI_CORE_TIMEOUT); + if (ret) { + pr_warn("NFI core timed out entering command mode\n"); + return -EIO; + } + + return 0; +} + +static int mt7621_nfc_send_address_byte(struct mt7621_nfc *nfc, int addr) +{ + u32 val; + int ret; + + nfi_write32(nfc, NFI_COLADDR, addr); + nfi_write32(nfc, NFI_ROWADDR, 0); + nfi_write16(nfc, NFI_ADDRNOB, 1); + + ret = readl_poll_timeout(nfc->nfi_regs + NFI_STA, val, + !(val & STA_ADDR), NFI_CORE_TIMEOUT); + if (ret) { + pr_warn("NFI core timed out entering address mode\n"); + return -EIO; + } + + return 0; +} + +static void mt7621_nfc_cmd_ctrl(struct mtd_info *mtd, int dat, + unsigned int ctrl) +{ + struct mt7621_nfc *nfc = nand_get_controller_data(mtd_to_nand(mtd)); + + if (ctrl & NAND_ALE) { + mt7621_nfc_send_address_byte(nfc, dat & 0xff); + } else if (ctrl & NAND_CLE) { + mt7621_nfc_hw_reset(nfc); + nfi_write16(nfc, NFI_CNFG, CNFG_OP_CUSTOM << CNFG_OP_MODE_S); + mt7621_nfc_send_command(nfc, dat); + } +} + +static int mt7621_nfc_dev_ready(struct mtd_info *mtd) +{ + struct mt7621_nfc *nfc = nand_get_controller_data(mtd_to_nand(mtd)); + + if (nfi_read32(nfc, NFI_STA) & STA_BUSY) + return 0; + + return 1; +} + +static void mt7621_nfc_select_chip(struct mtd_info *mtd, int chipnr) +{ + struct mt7621_nfc *nfc = nand_get_controller_data(mtd_to_nand(mtd)); + + nfi_write16(nfc, NFI_CSEL, 0); +} + +static void mt7621_nfc_wait_pio_ready(struct mt7621_nfc *nfc) +{ + int ret; + u16 val; + + ret = readw_poll_timeout(nfc->nfi_regs + NFI_PIO_DIRDY, val, + val & PIO_DIRDY, NFI_CORE_TIMEOUT); + if (ret < 0) + pr_err("NFI core PIO mode not ready\n"); +} + +static u32 mt7621_nfc_pio_read(struct mt7621_nfc *nfc, bool br) +{ + u32 reg; + + /* after each byte read, the NFI_STA reg is reset by the hardware */ + reg = (nfi_read32(nfc, NFI_STA) & STA_NFI_FSM_M) >> STA_NFI_FSM_S; + if (reg != STA_FSM_CUSTOM_DATA) { + reg = nfi_read16(nfc, NFI_CNFG); + reg |= CNFG_READ_MODE | CNFG_BYTE_RW; + if (!br) + reg &= ~CNFG_BYTE_RW; + nfi_write16(nfc, NFI_CNFG, reg); + + /* + * set to max sector to allow the HW to continue reading over + * unaligned accesses + */ + nfi_write16(nfc, NFI_CON, CON_NFI_SEC_M | CON_NFI_BRD); + + /* trigger to fetch data */ + nfi_write16(nfc, NFI_STRDATA, STR_DATA); + } + + mt7621_nfc_wait_pio_ready(nfc); + + return nfi_read32(nfc, NFI_DATAR); +} + +static void mt7621_nfc_read_data(struct mt7621_nfc *nfc, u8 *buf, u32 len) +{ + while (((uintptr_t)buf & 3) && len) { + *buf = mt7621_nfc_pio_read(nfc, true); + buf++; + len--; + } + + while (len >= 4) { + *(u32 *)buf = mt7621_nfc_pio_read(nfc, false); + buf += 4; + len -= 4; + } + + while (len) { + *buf = mt7621_nfc_pio_read(nfc, true); + buf++; + len--; + } +} + +static void mt7621_nfc_read_data_discard(struct mt7621_nfc *nfc, u32 len) +{ + while (len >= 4) { + mt7621_nfc_pio_read(nfc, false); + len -= 4; + } + + while (len) { + mt7621_nfc_pio_read(nfc, true); + len--; + } +} + +static void mt7621_nfc_pio_write(struct mt7621_nfc *nfc, u32 val, bool bw) +{ + u32 reg; + + reg = (nfi_read32(nfc, NFI_STA) & STA_NFI_FSM_M) >> STA_NFI_FSM_S; + if (reg != STA_FSM_CUSTOM_DATA) { + reg = nfi_read16(nfc, NFI_CNFG); + reg &= ~(CNFG_READ_MODE | CNFG_BYTE_RW); + if (bw) + reg |= CNFG_BYTE_RW; + nfi_write16(nfc, NFI_CNFG, reg); + + nfi_write16(nfc, NFI_CON, CON_NFI_SEC_M | CON_NFI_BWR); + nfi_write16(nfc, NFI_STRDATA, STR_DATA); + } + + mt7621_nfc_wait_pio_ready(nfc); + nfi_write32(nfc, NFI_DATAW, val); +} + +static void mt7621_nfc_write_data(struct mt7621_nfc *nfc, const u8 *buf, + u32 len) +{ + while (((uintptr_t)buf & 3) && len) { + mt7621_nfc_pio_write(nfc, *buf, true); + buf++; + len--; + } + + while (len >= 4) { + mt7621_nfc_pio_write(nfc, *(const u32 *)buf, false); + buf += 4; + len -= 4; + } + + while (len) { + mt7621_nfc_pio_write(nfc, *buf, true); + buf++; + len--; + } +} + +static void mt7621_nfc_write_data_empty(struct mt7621_nfc *nfc, u32 len) +{ + while (len >= 4) { + mt7621_nfc_pio_write(nfc, 0xffffffff, false); + len -= 4; + } + + while (len) { + mt7621_nfc_pio_write(nfc, 0xff, true); + len--; + } +} + +static void mt7621_nfc_write_byte(struct mtd_info *mtd, u8 byte) +{ + struct mt7621_nfc *nfc = nand_get_controller_data(mtd_to_nand(mtd)); + + mt7621_nfc_pio_write(nfc, byte, true); +} + +static void mt7621_nfc_write_buf(struct mtd_info *mtd, const u8 *buf, int len) +{ + struct mt7621_nfc *nfc = nand_get_controller_data(mtd_to_nand(mtd)); + + return mt7621_nfc_write_data(nfc, buf, len); +} + +static u8 mt7621_nfc_read_byte(struct mtd_info *mtd) +{ + struct mt7621_nfc *nfc = nand_get_controller_data(mtd_to_nand(mtd)); + + return mt7621_nfc_pio_read(nfc, true); +} + +static void mt7621_nfc_read_buf(struct mtd_info *mtd, u8 *buf, int len) +{ + struct mt7621_nfc *nfc = nand_get_controller_data(mtd_to_nand(mtd)); + + mt7621_nfc_read_data(nfc, buf, len); +} + +static int mt7621_nfc_calc_ecc_strength(struct mt7621_nfc *nfc, + u32 avail_ecc_bytes) +{ + struct nand_chip *nand = &nfc->nand; + struct mtd_info *mtd = nand_to_mtd(nand); + u32 strength; + int i; + + strength = avail_ecc_bytes * 8 / ECC_PARITY_BITS; + + /* Find the closest supported ecc strength */ + for (i = ARRAY_SIZE(mt7621_ecc_strength) - 1; i >= 0; i--) { + if (mt7621_ecc_strength[i] <= strength) + break; + } + + if (unlikely(i < 0)) { + pr_err("OOB size (%u) is not supported\n", mtd->oobsize); + return -EINVAL; + } + + nand->ecc.strength = mt7621_ecc_strength[i]; + nand->ecc.bytes = + DIV_ROUND_UP(nand->ecc.strength * ECC_PARITY_BITS, 8); + + pr_debug("ECC strength adjusted to %u bits\n", nand->ecc.strength); + + return i; +} + +static int mt7621_nfc_set_spare_per_sector(struct mt7621_nfc *nfc) +{ + struct nand_chip *nand = &nfc->nand; + struct mtd_info *mtd = nand_to_mtd(nand); + u32 size; + int i; + + size = nand->ecc.bytes + NFI_FDM_SIZE; + + /* Find the closest supported spare size */ + for (i = 0; i < ARRAY_SIZE(mt7621_nfi_spare_size); i++) { + if (mt7621_nfi_spare_size[i] >= size) + break; + } + + if (unlikely(i >= ARRAY_SIZE(mt7621_nfi_spare_size))) { + pr_err("OOB size (%u) is not supported\n", mtd->oobsize); + return -EINVAL; + } + + nfc->spare_per_sector = mt7621_nfi_spare_size[i]; + + return i; +} + +static int mt7621_nfc_ecc_init(struct mt7621_nfc *nfc) +{ + struct nand_chip *nand = &nfc->nand; + struct mtd_info *mtd = nand_to_mtd(nand); + u32 spare_per_sector, encode_block_size, decode_block_size; + u32 ecc_enccfg, ecc_deccfg; + int ecc_cap; + + nand->ecc.options |= NAND_ECC_CUSTOM_PAGE_ACCESS; + + nand->ecc.size = ECC_SECTOR_SIZE; + nand->ecc.steps = mtd->writesize / nand->ecc.size; + + spare_per_sector = mtd->oobsize / nand->ecc.steps; + + ecc_cap = mt7621_nfc_calc_ecc_strength(nfc, + spare_per_sector - NFI_FDM_SIZE); + if (ecc_cap < 0) + return ecc_cap; + + /* Sector + FDM */ + encode_block_size = (nand->ecc.size + NFI_FDM_SIZE) * 8; + ecc_enccfg = ecc_cap | (ENC_MODE_NFI << ENC_MODE_S) | + (encode_block_size << ENC_CNFG_MSG_S); + + /* Sector + FDM + ECC parity bits */ + decode_block_size = ((nand->ecc.size + NFI_FDM_SIZE) * 8) + + nand->ecc.strength * ECC_PARITY_BITS; + ecc_deccfg = ecc_cap | (DEC_MODE_NFI << DEC_MODE_S) | + (decode_block_size << DEC_CS_S) | + (DEC_CON_EL << DEC_CON_S) | DEC_EMPTY_EN; + + mt7621_ecc_encoder_op(nfc, false); + ecc_write32(nfc, ECC_ENCCNFG, ecc_enccfg); + + mt7621_ecc_decoder_op(nfc, false); + ecc_write32(nfc, ECC_DECCNFG, ecc_deccfg); + + return 0; +} + +static int mt7621_nfc_set_page_format(struct mt7621_nfc *nfc) +{ + struct nand_chip *nand = &nfc->nand; + struct mtd_info *mtd = nand_to_mtd(nand); + int i, spare_size; + u32 pagefmt; + + spare_size = mt7621_nfc_set_spare_per_sector(nfc); + if (spare_size < 0) + return spare_size; + + for (i = 0; i < ARRAY_SIZE(mt7621_nfi_page_size); i++) { + if (mt7621_nfi_page_size[i] == mtd->writesize) + break; + } + + if (unlikely(i >= ARRAY_SIZE(mt7621_nfi_page_size))) { + pr_err("Page size (%u) is not supported\n", mtd->writesize); + return -EINVAL; + } + + pagefmt = i | (spare_size << PAGEFMT_SPARE_S) | + (NFI_FDM_SIZE << PAGEFMT_FDM_S) | + (NFI_FDM_SIZE << PAGEFMT_FDM_ECC_S); + + nfi_write16(nfc, NFI_PAGEFMT, pagefmt); + + return 0; +} + +static int mt7621_nfc_attach_chip(struct nand_chip *nand) +{ + struct mt7621_nfc *nfc = nand_get_controller_data(nand); + int ret; + + if (nand->options & NAND_BUSWIDTH_16) { + pr_err("16-bit buswidth is not supported"); + return -EINVAL; + } + + ret = mt7621_nfc_ecc_init(nfc); + if (ret) + return ret; + + return mt7621_nfc_set_page_format(nfc); +} + +static void mt7621_nfc_write_fdm(struct mt7621_nfc *nfc) +{ + struct nand_chip *nand = &nfc->nand; + u32 vall, valm; + u8 *oobptr; + int i, j; + + for (i = 0; i < nand->ecc.steps; i++) { + vall = 0; + valm = 0; + oobptr = oob_fdm_ptr(nand, i); + + for (j = 0; j < 4; j++) + vall |= (u32)oobptr[j] << (j * 8); + + for (j = 0; j < 4; j++) + valm |= (u32)oobptr[j + 4] << (j * 8); + + nfi_write32(nfc, NFI_FDML(i), vall); + nfi_write32(nfc, NFI_FDMM(i), valm); + } +} + +static void mt7621_nfc_read_sector_fdm(struct mt7621_nfc *nfc, u32 sect) +{ + struct nand_chip *nand = &nfc->nand; + u32 vall, valm; + u8 *oobptr; + int i; + + vall = nfi_read32(nfc, NFI_FDML(sect)); + valm = nfi_read32(nfc, NFI_FDMM(sect)); + oobptr = oob_fdm_ptr(nand, sect); + + for (i = 0; i < 4; i++) + oobptr[i] = (vall >> (i * 8)) & 0xff; + + for (i = 0; i < 4; i++) + oobptr[i + 4] = (valm >> (i * 8)) & 0xff; +} + +static int mt7621_nfc_read_page_hwecc(struct mtd_info *mtd, + struct nand_chip *nand, uint8_t *buf, + int oob_required, int page) +{ + struct mt7621_nfc *nfc = nand_get_controller_data(nand); + int bitflips = 0, ret = 0; + int rc, i; + + nand_read_page_op(nand, page, 0, NULL, 0); + + nfi_write16(nfc, NFI_CNFG, (CNFG_OP_CUSTOM << CNFG_OP_MODE_S) | + CNFG_READ_MODE | CNFG_AUTO_FMT_EN | CNFG_HW_ECC_EN); + + mt7621_ecc_decoder_op(nfc, true); + + nfi_write16(nfc, NFI_CON, + CON_NFI_BRD | (nand->ecc.steps << CON_NFI_SEC_S)); + + for (i = 0; i < nand->ecc.steps; i++) { + if (buf) + mt7621_nfc_read_data(nfc, page_data_ptr(nand, buf, i), + nand->ecc.size); + else + mt7621_nfc_read_data_discard(nfc, nand->ecc.size); + + rc = mt7621_ecc_decoder_wait_done(nfc, i); + + mt7621_nfc_read_sector_fdm(nfc, i); + + if (rc < 0) { + ret = -EIO; + continue; + } + + rc = mt7621_ecc_correct_check(nfc, + buf ? page_data_ptr(nand, buf, i) : NULL, + oob_fdm_ptr(nand, i), i); + + if (rc < 0) { + pr_warn("Uncorrectable ECC error at page %d step %d\n", + page, i); + bitflips = nand->ecc.strength + 1; + mtd->ecc_stats.failed++; + } else { + if (rc > bitflips) + bitflips = rc; + mtd->ecc_stats.corrected += rc; + } + } + + mt7621_ecc_decoder_op(nfc, false); + + nfi_write16(nfc, NFI_CON, 0); + + if (ret < 0) + return ret; + + return bitflips; +} + +static int mt7621_nfc_read_page_raw(struct mtd_info *mtd, + struct nand_chip *nand, uint8_t *buf, + int oob_required, int page) +{ + struct mt7621_nfc *nfc = nand_get_controller_data(nand); + int i; + + nand_read_page_op(nand, page, 0, NULL, 0); + + nfi_write16(nfc, NFI_CNFG, (CNFG_OP_CUSTOM << CNFG_OP_MODE_S) | + CNFG_READ_MODE); + + nfi_write16(nfc, NFI_CON, + CON_NFI_BRD | (nand->ecc.steps << CON_NFI_SEC_S)); + + for (i = 0; i < nand->ecc.steps; i++) { + /* Read data */ + if (buf) + mt7621_nfc_read_data(nfc, page_data_ptr(nand, buf, i), + nand->ecc.size); + else + mt7621_nfc_read_data_discard(nfc, nand->ecc.size); + + /* Read FDM */ + mt7621_nfc_read_data(nfc, oob_fdm_ptr(nand, i), NFI_FDM_SIZE); + + /* Read ECC parity data */ + mt7621_nfc_read_data(nfc, oob_ecc_ptr(nfc, i), + nfc->spare_per_sector - NFI_FDM_SIZE); + } + + nfi_write16(nfc, NFI_CON, 0); + + return 0; +} + +static int mt7621_nfc_read_oob_hwecc(struct mtd_info *mtd, + struct nand_chip *nand, int page) +{ + return mt7621_nfc_read_page_hwecc(mtd, nand, NULL, 1, page); +} + +static int mt7621_nfc_read_oob_raw(struct mtd_info *mtd, + struct nand_chip *nand, int page) +{ + return mt7621_nfc_read_page_raw(mtd, nand, NULL, 1, page); +} + +static int mt7621_nfc_check_empty_page(struct nand_chip *nand, const u8 *buf) +{ + struct mtd_info *mtd = nand_to_mtd(nand); + u8 *oobptr; + u32 i, j; + + if (buf) { + for (i = 0; i < mtd->writesize; i++) + if (buf[i] != 0xff) + return 0; + } + + for (i = 0; i < nand->ecc.steps; i++) { + oobptr = oob_fdm_ptr(nand, i); + for (j = 0; j < NFI_FDM_SIZE; j++) + if (oobptr[j] != 0xff) + return 0; + } + + return 1; +} + +static int mt7621_nfc_write_page_hwecc(struct mtd_info *mtd, + struct nand_chip *nand, + const u8 *buf, int oob_required, + int page) +{ + struct mt7621_nfc *nfc = nand_get_controller_data(nand); + + if (mt7621_nfc_check_empty_page(nand, buf)) { + /* + * MT7621 ECC engine always generates parity code for input + * pages, even for empty pages. Doing so will write back ECC + * parity code to the oob region, which means such pages will + * no longer be empty pages. + * + * To avoid this, stop write operation if current page is an + * empty page. + */ + return 0; + } + + nand_prog_page_begin_op(nand, page, 0, NULL, 0); + + nfi_write16(nfc, NFI_CNFG, (CNFG_OP_CUSTOM << CNFG_OP_MODE_S) | + CNFG_AUTO_FMT_EN | CNFG_HW_ECC_EN); + + mt7621_ecc_encoder_op(nfc, true); + + mt7621_nfc_write_fdm(nfc); + + nfi_write16(nfc, NFI_CON, + CON_NFI_BWR | (nand->ecc.steps << CON_NFI_SEC_S)); + + if (buf) + mt7621_nfc_write_data(nfc, buf, mtd->writesize); + else + mt7621_nfc_write_data_empty(nfc, mtd->writesize); + + mt7621_nfc_wait_write_completion(nfc, nand); + + mt7621_ecc_encoder_op(nfc, false); + + nfi_write16(nfc, NFI_CON, 0); + + return nand_prog_page_end_op(nand); +} + +static int mt7621_nfc_write_page_raw(struct mtd_info *mtd, + struct nand_chip *nand, + const u8 *buf, int oob_required, + int page) +{ + struct mt7621_nfc *nfc = nand_get_controller_data(nand); + int i; + + nand_prog_page_begin_op(nand, page, 0, NULL, 0); + + nfi_write16(nfc, NFI_CNFG, (CNFG_OP_CUSTOM << CNFG_OP_MODE_S)); + + nfi_write16(nfc, NFI_CON, + CON_NFI_BWR | (nand->ecc.steps << CON_NFI_SEC_S)); + + for (i = 0; i < nand->ecc.steps; i++) { + /* Write data */ + if (buf) + mt7621_nfc_write_data(nfc, page_data_ptr(nand, buf, i), + nand->ecc.size); + else + mt7621_nfc_write_data_empty(nfc, nand->ecc.size); + + /* Write FDM */ + mt7621_nfc_write_data(nfc, oob_fdm_ptr(nand, i), + NFI_FDM_SIZE); + + /* Write dummy ECC parity data */ + mt7621_nfc_write_data_empty(nfc, nfc->spare_per_sector - + NFI_FDM_SIZE); + } + + mt7621_nfc_wait_write_completion(nfc, nand); + + nfi_write16(nfc, NFI_CON, 0); + + return nand_prog_page_end_op(nand); +} + +static int mt7621_nfc_write_oob_hwecc(struct mtd_info *mtd, + struct nand_chip *nand, int page) +{ + return mt7621_nfc_write_page_hwecc(mtd, nand, NULL, 1, page); +} + +static int mt7621_nfc_write_oob_raw(struct mtd_info *mtd, + struct nand_chip *nand, int page) +{ + return mt7621_nfc_write_page_raw(mtd, nand, NULL, 1, page); +} + +static int mt7621_nfc_ooblayout_free(struct mtd_info *mtd, int section, + struct mtd_oob_region *oob_region) +{ + struct nand_chip *nand = mtd_to_nand(mtd); + + if (section >= nand->ecc.steps) + return -ERANGE; + + oob_region->length = NFI_FDM_SIZE - 1; + oob_region->offset = section * NFI_FDM_SIZE + 1; + + return 0; +} + +static int mt7621_nfc_ooblayout_ecc(struct mtd_info *mtd, int section, + struct mtd_oob_region *oob_region) +{ + struct nand_chip *nand = mtd_to_nand(mtd); + + if (section) + return -ERANGE; + + oob_region->offset = NFI_FDM_SIZE * nand->ecc.steps; + oob_region->length = mtd->oobsize - oob_region->offset; + + return 0; +} + +static const struct mtd_ooblayout_ops mt7621_nfc_ooblayout_ops = { + .rfree = mt7621_nfc_ooblayout_free, + .ecc = mt7621_nfc_ooblayout_ecc, +}; + +/* + * This function will override the default one which is not supposed to be + * used for ECC syndrome based pages. + */ +static int mt7621_nfc_block_bad(struct mtd_info *mtd, loff_t ofs) +{ + struct nand_chip *nand = mtd_to_nand(mtd); + struct mtd_oob_ops ops; + int ret, i = 0; + u16 bad; + + memset(&ops, 0, sizeof(ops)); + ops.oobbuf = (uint8_t *)&bad; + ops.ooboffs = nand->badblockpos; + if (nand->options & NAND_BUSWIDTH_16) { + ops.ooboffs &= ~0x01; + ops.ooblen = 2; + } else { + ops.ooblen = 1; + } + ops.mode = MTD_OPS_RAW; + + /* Read from first/last page(s) if necessary */ + if (nand->bbt_options & NAND_BBT_SCANLASTPAGE) + ofs += mtd->erasesize - mtd->writesize; + + do { + ret = mtd_read_oob(mtd, ofs, &ops); + if (ret) + return ret; + + if (likely(nand->badblockbits == 8)) + ret = bad != 0xFF; + else + ret = hweight8(bad) < nand->badblockbits; + + i++; + ofs += mtd->writesize; + } while (!ret && (nand->bbt_options & NAND_BBT_SCAN2NDPAGE) && i < 2); + + return ret; +} + +static void mt7621_nfc_init_chip(struct mt7621_nfc *nfc) +{ + struct nand_chip *nand = &nfc->nand; + struct mtd_info *mtd; + int ret; + + nand_set_controller_data(nand, nfc); + + nand->options |= NAND_NO_SUBPAGE_WRITE; + + nand->ecc.mode = NAND_ECC_HW_SYNDROME; + nand->ecc.read_page = mt7621_nfc_read_page_hwecc; + nand->ecc.read_page_raw = mt7621_nfc_read_page_raw; + nand->ecc.write_page = mt7621_nfc_write_page_hwecc; + nand->ecc.write_page_raw = mt7621_nfc_write_page_raw; + nand->ecc.read_oob = mt7621_nfc_read_oob_hwecc; + nand->ecc.read_oob_raw = mt7621_nfc_read_oob_raw; + nand->ecc.write_oob = mt7621_nfc_write_oob_hwecc; + nand->ecc.write_oob_raw = mt7621_nfc_write_oob_raw; + + nand->dev_ready = mt7621_nfc_dev_ready; + nand->select_chip = mt7621_nfc_select_chip; + nand->write_byte = mt7621_nfc_write_byte; + nand->write_buf = mt7621_nfc_write_buf; + nand->read_byte = mt7621_nfc_read_byte; + nand->read_buf = mt7621_nfc_read_buf; + nand->cmd_ctrl = mt7621_nfc_cmd_ctrl; + nand->block_bad = mt7621_nfc_block_bad; + + mtd = nand_to_mtd(nand); + mtd_set_ooblayout(mtd, &mt7621_nfc_ooblayout_ops); + + /* Reset NFI master */ + mt7621_nfc_hw_init(nfc); + + ret = nand_scan_ident(mtd, 1, NULL); + if (ret) + return; + + mt7621_nfc_attach_chip(nand); + + ret = nand_scan_tail(mtd); + if (ret) + return; + + nand_register(0, mtd); +} + +static void mt7621_nfc_set_regs(struct mt7621_nfc *nfc) +{ + nfc->nfi_regs = (void __iomem *)CKSEG1ADDR(NFI_BASE); + nfc->ecc_regs = (void __iomem *)CKSEG1ADDR(NFI_ECC_BASE); +} + +void mt7621_nfc_spl_init(struct mt7621_nfc *nfc) +{ + struct nand_chip *nand = &nfc->nand; + + mt7621_nfc_set_regs(nfc); + + nand_set_controller_data(nand, nfc); + + nand->options |= NAND_NO_SUBPAGE_WRITE; + + nand->ecc.mode = NAND_ECC_HW_SYNDROME; + nand->ecc.read_page = mt7621_nfc_read_page_hwecc; + + nand->dev_ready = mt7621_nfc_dev_ready; + nand->select_chip = mt7621_nfc_select_chip; + nand->read_byte = mt7621_nfc_read_byte; + nand->read_buf = mt7621_nfc_read_buf; + nand->cmd_ctrl = mt7621_nfc_cmd_ctrl; + + /* Reset NFI master */ + mt7621_nfc_hw_init(nfc); +} + +int mt7621_nfc_spl_post_init(struct mt7621_nfc *nfc) +{ + struct nand_chip *nand = &nfc->nand; + int nand_maf_id, nand_dev_id; + struct nand_flash_dev *type; + + type = nand_get_flash_type(&nand->mtd, nand, &nand_maf_id, + &nand_dev_id, NULL); + + if (IS_ERR(type)) + return PTR_ERR(type); + + nand->numchips = 1; + nand->mtd.size = nand->chipsize; + + return mt7621_nfc_attach_chip(nand); +} + +void board_nand_init(void) +{ + mt7621_nfc_set_regs(&nfc_dev); + mt7621_nfc_init_chip(&nfc_dev); +} diff --git a/drivers/mtd/nand/raw/mt7621_nand.h b/drivers/mtd/nand/raw/mt7621_nand.h new file mode 100644 index 0000000000..af4bc55961 --- /dev/null +++ b/drivers/mtd/nand/raw/mt7621_nand.h @@ -0,0 +1,29 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2022 MediaTek Inc. All rights reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#ifndef _MT7621_NAND_H_ +#define _MT7621_NAND_H_ + +#include <linux/types.h> +#include <linux/mtd/mtd.h> +#include <linux/compiler.h> +#include <linux/mtd/rawnand.h> + +struct mt7621_nfc { + struct nand_chip nand; + + void __iomem *nfi_regs; + void __iomem *ecc_regs; + + u32 spare_per_sector; +}; + +/* for SPL */ +void mt7621_nfc_spl_init(struct mt7621_nfc *nfc); +int mt7621_nfc_spl_post_init(struct mt7621_nfc *nfc); + +#endif /* _MT7621_NAND_H_ */ diff --git a/drivers/mtd/nand/raw/mt7621_nand_spl.c b/drivers/mtd/nand/raw/mt7621_nand_spl.c new file mode 100644 index 0000000000..114fc8b7ce --- /dev/null +++ b/drivers/mtd/nand/raw/mt7621_nand_spl.c @@ -0,0 +1,237 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 MediaTek Inc. All rights reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <image.h> +#include <malloc.h> +#include <linux/sizes.h> +#include <linux/delay.h> +#include <linux/mtd/rawnand.h> +#include "mt7621_nand.h" + +static struct mt7621_nfc nfc_dev; +static u8 *buffer; +static int nand_valid; + +static void nand_command_lp(struct mtd_info *mtd, unsigned int command, + int column, int page_addr) +{ + register struct nand_chip *chip = mtd_to_nand(mtd); + + /* Command latch cycle */ + chip->cmd_ctrl(mtd, command, NAND_NCE | NAND_CLE | NAND_CTRL_CHANGE); + + if (column != -1 || page_addr != -1) { + int ctrl = NAND_CTRL_CHANGE | NAND_NCE | NAND_ALE; + + /* Serially input address */ + if (column != -1) { + chip->cmd_ctrl(mtd, column, ctrl); + ctrl &= ~NAND_CTRL_CHANGE; + if (command != NAND_CMD_READID) + chip->cmd_ctrl(mtd, column >> 8, ctrl); + } + if (page_addr != -1) { + chip->cmd_ctrl(mtd, page_addr, ctrl); + chip->cmd_ctrl(mtd, page_addr >> 8, + NAND_NCE | NAND_ALE); + if (chip->options & NAND_ROW_ADDR_3) + chip->cmd_ctrl(mtd, page_addr >> 16, + NAND_NCE | NAND_ALE); + } + } + chip->cmd_ctrl(mtd, NAND_CMD_NONE, NAND_NCE | NAND_CTRL_CHANGE); + + /* + * Program and erase have their own busy handlers status, sequential + * in and status need no delay. + */ + switch (command) { + case NAND_CMD_STATUS: + case NAND_CMD_READID: + case NAND_CMD_SET_FEATURES: + return; + + case NAND_CMD_READ0: + chip->cmd_ctrl(mtd, NAND_CMD_READSTART, + NAND_NCE | NAND_CLE | NAND_CTRL_CHANGE); + chip->cmd_ctrl(mtd, NAND_CMD_NONE, + NAND_NCE | NAND_CTRL_CHANGE); + } + + /* + * Apply this short delay always to ensure that we do wait tWB in + * any case on any machine. + */ + ndelay(100); + + nand_wait_ready(mtd); +} + +static int nfc_read_page_hwecc(struct mtd_info *mtd, void *buf, + unsigned int page) +{ + struct nand_chip *chip = mtd_to_nand(mtd); + int ret; + + chip->cmdfunc(mtd, NAND_CMD_READ0, 0x0, page); + + ret = chip->ecc.read_page(mtd, chip, buf, 1, page); + if (ret < 0 || ret > chip->ecc.strength) + return -1; + + return 0; +} + +static int nfc_read_oob_hwecc(struct mtd_info *mtd, void *buf, u32 len, + unsigned int page) +{ + struct nand_chip *chip = mtd_to_nand(mtd); + int ret; + + chip->cmdfunc(mtd, NAND_CMD_READ0, 0x0, page); + + ret = chip->ecc.read_page(mtd, chip, NULL, 1, page); + if (ret < 0) + return -1; + + if (len > mtd->oobsize) + len = mtd->oobsize; + + memcpy(buf, chip->oob_poi, len); + + return 0; +} + +static int nfc_check_bad_block(struct mtd_info *mtd, unsigned int page) +{ + struct nand_chip *chip = mtd_to_nand(mtd); + u32 pages_per_block, i = 0; + int ret; + u8 bad; + + pages_per_block = 1 << (mtd->erasesize_shift - mtd->writesize_shift); + + /* Read from first/last page(s) if necessary */ + if (chip->bbt_options & NAND_BBT_SCANLASTPAGE) { + page += pages_per_block - 1; + if (chip->bbt_options & NAND_BBT_SCAN2NDPAGE) + page--; + } + + do { + ret = nfc_read_oob_hwecc(mtd, &bad, 1, page); + if (ret) + return ret; + + ret = bad != 0xFF; + + i++; + page++; + } while (!ret && (chip->bbt_options & NAND_BBT_SCAN2NDPAGE) && i < 2); + + return ret; +} + +int nand_spl_load_image(uint32_t offs, unsigned int size, void *dest) +{ + struct mt7621_nfc *nfc = &nfc_dev; + struct nand_chip *chip = &nfc->nand; + struct mtd_info *mtd = &chip->mtd; + u32 addr, col, page, chksz; + bool check_bad = true; + + if (!nand_valid) + return -ENODEV; + + while (size) { + if (check_bad || !(offs & mtd->erasesize_mask)) { + addr = offs & (~mtd->erasesize_mask); + page = addr >> mtd->writesize_shift; + if (nfc_check_bad_block(mtd, page)) { + /* Skip bad block */ + if (addr >= mtd->size - mtd->erasesize) + return -1; + + offs += mtd->erasesize; + continue; + } + + check_bad = false; + } + + col = offs & mtd->writesize_mask; + page = offs >> mtd->writesize_shift; + chksz = min(mtd->writesize - col, (uint32_t)size); + + if (unlikely(chksz < mtd->writesize)) { + /* Not reading a full page */ + if (nfc_read_page_hwecc(mtd, buffer, page)) + return -1; + + memcpy(dest, buffer + col, chksz); + } else { + if (nfc_read_page_hwecc(mtd, dest, page)) + return -1; + } + + dest += chksz; + offs += chksz; + size -= chksz; + } + + return 0; +} + +int nand_default_bbt(struct mtd_info *mtd) +{ + return 0; +} + +unsigned long nand_size(void) +{ + if (!nand_valid) + return 0; + + /* Unlikely that NAND size > 2GBytes */ + if (nfc_dev.nand.chipsize <= SZ_2G) + return nfc_dev.nand.chipsize; + + return SZ_2G; +} + +void nand_deselect(void) +{ +} + +void nand_init(void) +{ + struct mtd_info *mtd; + struct nand_chip *chip; + + if (nand_valid) + return; + + mt7621_nfc_spl_init(&nfc_dev); + + chip = &nfc_dev.nand; + mtd = &chip->mtd; + chip->cmdfunc = nand_command_lp; + + if (mt7621_nfc_spl_post_init(&nfc_dev)) + return; + + mtd->erasesize_shift = ffs(mtd->erasesize) - 1; + mtd->writesize_shift = ffs(mtd->writesize) - 1; + mtd->erasesize_mask = (1 << mtd->erasesize_shift) - 1; + mtd->writesize_mask = (1 << mtd->writesize_shift) - 1; + + buffer = malloc(mtd->writesize); + if (!buffer) + return; + + nand_valid = 1; +}
This patch removes the dependency to SPL_NAND_DRIVERS for SPL_NAND_BASE to allow minimal spl nand driver to use nand base for probing NAND chips.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v5 changes: none v4 changes: new --- common/spl/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 50ff113cab..eee9315e43 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -764,7 +764,7 @@ config SPL_NAND_SIMPLE expose the cmd_ctrl() interface.
config SPL_NAND_BASE - depends on SPL_NAND_DRIVERS + depends on SPL_NAND_SUPPORT bool "Use Base NAND Driver" help Include nand_base.c in the SPL.
If the payload is compressed, SPL_COPY_PAYLOAD_ONLY should always be set since the payload will not be directly read to its load address. The payload will first be read to a temporary buffer, and then be decompressed to its load address, without image header.
If the payload is not compressed, and SPL_COPY_PAYLOAD_ONLY is set, image header should be skipped on loading. Otherwise image header should also be read to its load address.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v5 changes: none v4 changes: new --- common/spl/spl_legacy.c | 21 +++++++++++++++++++-- 1 file changed, 19 insertions(+), 2 deletions(-)
diff --git a/common/spl/spl_legacy.c b/common/spl/spl_legacy.c index 2ec7154423..ae8731c782 100644 --- a/common/spl/spl_legacy.c +++ b/common/spl/spl_legacy.c @@ -88,15 +88,29 @@ int spl_load_legacy_img(struct spl_image_info *spl_image, /* Read header into local struct */ load->read(load, header, sizeof(hdr), &hdr);
+ /* + * If the payload is compressed, the decompressed data should be + * directly write to its load address. + */ + if (spl_image_get_comp(&hdr) != IH_COMP_NONE) + spl_image->flags |= SPL_COPY_PAYLOAD_ONLY; + ret = spl_parse_image_header(spl_image, bootdev, &hdr); if (ret) return ret;
- dataptr = header + sizeof(hdr); - /* Read image */ switch (spl_image_get_comp(&hdr)) { case IH_COMP_NONE: + dataptr = header; + + /* + * Image header will be skipped only if SPL_COPY_PAYLOAD_ONLY + * is set + */ + if (spl_image->flags & SPL_COPY_PAYLOAD_ONLY) + dataptr += sizeof(hdr); + load->read(load, dataptr, spl_image->size, (void *)(unsigned long)spl_image->load_addr); break; @@ -104,6 +118,9 @@ int spl_load_legacy_img(struct spl_image_info *spl_image, case IH_COMP_LZMA: lzma_len = LZMA_LEN;
+ /* dataptr points to compressed payload */ + dataptr = header + sizeof(hdr); + debug("LZMA: Decompressing %08lx to %08lx\n", dataptr, spl_image->load_addr); src = malloc(spl_image->size);
Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
Add support to load legacy image with payload compressed. This redirects the boot flow for all legacy images. If the payload is not compresses, the actual behavior will remain unchanged.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v5 changes: none v4 changes: new --- common/spl/spl_nand.c | 27 +++++++++++++++++++++++++++ 1 file changed, 27 insertions(+)
diff --git a/common/spl/spl_nand.c b/common/spl/spl_nand.c index fc61b447a5..3f3007a35d 100644 --- a/common/spl/spl_nand.c +++ b/common/spl/spl_nand.c @@ -59,6 +59,21 @@ static ulong spl_nand_fit_read(struct spl_load_info *load, ulong offs, return size / load->bl_len; }
+static ulong spl_nand_legacy_read(struct spl_load_info *load, ulong offs, + ulong size, void *dst) +{ + int err; + + debug("%s: offs %lx, size %lx, dst %p\n", + __func__, offs, size, dst); + + err = nand_spl_load_image(offs, size, dst); + if (err) + return 0; + + return size; +} + struct mtd_info * __weak nand_get_mtd(void) { return NULL; @@ -96,6 +111,18 @@ static int spl_nand_load_element(struct spl_image_info *spl_image, load.bl_len = bl_len; load.read = spl_nand_fit_read; return spl_load_imx_container(spl_image, &load, offset / bl_len); + } else if (IS_ENABLED(CONFIG_SPL_LEGACY_IMAGE_FORMAT) && + image_get_magic(header) == IH_MAGIC) { + struct spl_load_info load; + + debug("Found legacy image\n"); + load.dev = NULL; + load.priv = NULL; + load.filename = NULL; + load.bl_len = 1; + load.read = spl_nand_legacy_read; + + return spl_load_legacy_img(spl_image, bootdev, &load, offset); } else { err = spl_parse_image_header(spl_image, bootdev, header); if (err)
s/compresses/compressed/
I'll correct this in next patch series.
The BootROM of MT7621 requires a image header for SPL to record its size and load address when booting from NAND.
To create such an image, one can use the following command line: mkimage -T mtk_image -a 0x80200000 -e 0x80200000 -n "mt7621=1" -d u-boot-spl-ddr.bin u-boot-spl-ddr.img
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v5 changes: none v4 changes: new --- tools/mtk_image.c | 182 ++++++++++++++++++++++++++++++++++++++++++++++ tools/mtk_image.h | 24 ++++++ 2 files changed, 206 insertions(+)
diff --git a/tools/mtk_image.c b/tools/mtk_image.c index 418c5fd54b..de5ce4d964 100644 --- a/tools/mtk_image.c +++ b/tools/mtk_image.c @@ -6,7 +6,9 @@ * Author: Weijie Gao weijie.gao@mediatek.com */
+#include <time.h> #include <image.h> +#include <u-boot/crc.h> #include <u-boot/sha256.h> #include "imagetool.h" #include "mtk_image.h" @@ -251,17 +253,45 @@ static uint32_t img_size; static enum brlyt_img_type hdr_media; static uint32_t hdr_offset; static int use_lk_hdr; +static int use_mt7621_hdr; static bool is_arm64_image;
/* LK image name */ static char lk_name[32] = "U-Boot";
+/* CRC32 normal table required by MT7621 image */ +static uint32_t crc32tbl[256]; + /* NAND header selected by user */ static const union nand_boot_header *hdr_nand;
/* GFH header + 2 * 4KB pages of NAND */ static char hdr_tmp[sizeof(struct gfh_header) + 0x2000];
+static uint32_t crc32_normal_cal(uint32_t crc, const void *data, size_t length, + const uint32_t *crc32c_table) +{ + const uint8_t *p = data; + + while (length--) + crc = crc32c_table[(uint8_t)((crc >> 24) ^ *p++)] ^ (crc << 8); + + return crc; +} + +static void crc32_normal_init(uint32_t *crc32c_table, uint32_t poly) +{ + uint32_t v, i, j; + + for (i = 0; i < 256; i++) { + v = i << 24; + for (j = 0; j < 8; j++) + v = (v << 1) ^ ((v & (1 << 31)) ? poly : 0); + + crc32c_table[i] = v; + } +} + static int mtk_image_check_image_types(uint8_t type) { if (type == IH_TYPE_MTKIMAGE) @@ -283,6 +313,7 @@ static int mtk_brom_parse_imagename(const char *imagename) static const char *hdr_offs = ""; static const char *nandinfo = ""; static const char *lk = ""; + static const char *mt7621 = ""; static const char *arm64_param = "";
key = buf; @@ -332,6 +363,9 @@ static int mtk_brom_parse_imagename(const char *imagename) if (!strcmp(key, "lk")) lk = val;
+ if (!strcmp(key, "mt7621")) + mt7621 = val; + if (!strcmp(key, "lkname")) snprintf(lk_name, sizeof(lk_name), "%s", val);
@@ -352,6 +386,13 @@ static int mtk_brom_parse_imagename(const char *imagename) return 0; }
+ /* if user specified MT7621 image header, skip following checks */ + if (mt7621 && mt7621[0] == '1') { + use_mt7621_hdr = 1; + free(buf); + return 0; + } + /* parse media type */ for (i = 0; i < ARRAY_SIZE(brom_images); i++) { if (!strcmp(brom_images[i].name, media)) { @@ -419,6 +460,13 @@ static int mtk_image_vrec_header(struct image_tool_params *params, return 0; }
+ if (use_mt7621_hdr) { + tparams->header_size = image_get_header_size(); + tparams->hdr = &hdr_tmp; + memset(&hdr_tmp, 0, tparams->header_size); + return 0; + } + if (hdr_media == BRLYT_TYPE_NAND || hdr_media == BRLYT_TYPE_SNAND) tparams->header_size = 2 * le16_to_cpu(hdr_nand->pagesize); else @@ -579,9 +627,90 @@ static int mtk_image_verify_nand_header(const uint8_t *ptr, int print) return 0; }
+static uint32_t crc32be_cal(const void *data, size_t length) +{ + uint32_t crc = 0; + uint8_t c; + + if (crc32tbl[1] != MT7621_IH_CRC_POLYNOMIAL) + crc32_normal_init(crc32tbl, MT7621_IH_CRC_POLYNOMIAL); + + crc = crc32_normal_cal(crc, data, length, crc32tbl); + + for (; length; length >>= 8) { + c = length & 0xff; + crc = crc32_normal_cal(crc, &c, 1, crc32tbl); + } + + return ~crc; +} + +static int mtk_image_verify_mt7621_header(const uint8_t *ptr, int print) +{ + const image_header_t *hdr = (const image_header_t *)ptr; + struct mt7621_nand_header *nhdr; + uint32_t spl_size, crcval; + image_header_t header; + int ret; + + spl_size = image_get_size(hdr); + + if (spl_size > img_size) { + if (print) + printf("Incomplete SPL image\n"); + return -1; + } + + ret = image_check_hcrc(hdr); + if (!ret) { + if (print) + printf("Bad header CRC\n"); + return -1; + } + + ret = image_check_dcrc(hdr); + if (!ret) { + if (print) + printf("Bad data CRC\n"); + return -1; + } + + /* Copy header so we can blank CRC field for re-calculation */ + memmove(&header, hdr, image_get_header_size()); + image_set_hcrc(&header, 0); + + nhdr = (struct mt7621_nand_header *)header.ih_name; + crcval = be32_to_cpu(nhdr->crc); + nhdr->crc = 0; + + if (crcval != crc32be_cal(&header, image_get_header_size())) { + if (print) + printf("Bad NAND header CRC\n"); + return -1; + } + + if (print) { + printf("Load Address: %08x\n", image_get_load(hdr)); + + printf("Image Name: %.*s\n", MT7621_IH_NMLEN, + image_get_name(hdr)); + + if (IMAGE_ENABLE_TIMESTAMP) { + printf("Created: "); + genimg_print_time((time_t)image_get_time(hdr)); + } + + printf("Data Size: "); + genimg_print_size(image_get_data_size(hdr)); + } + + return 0; +} + static int mtk_image_verify_header(unsigned char *ptr, int image_size, struct image_tool_params *params) { + image_header_t *hdr = (image_header_t *)ptr; union lk_hdr *lk = (union lk_hdr *)ptr;
/* nothing to verify for LK image header */ @@ -590,6 +719,9 @@ static int mtk_image_verify_header(unsigned char *ptr, int image_size,
img_size = image_size;
+ if (image_get_magic(hdr) == IH_MAGIC) + return mtk_image_verify_mt7621_header(ptr, 0); + if (!strcmp((char *)ptr, NAND_BOOT_NAME)) return mtk_image_verify_nand_header(ptr, 0); else @@ -600,6 +732,7 @@ static int mtk_image_verify_header(unsigned char *ptr, int image_size,
static void mtk_image_print_header(const void *ptr) { + image_header_t *hdr = (image_header_t *)ptr; union lk_hdr *lk = (union lk_hdr *)ptr;
if (le32_to_cpu(lk->magic) == LK_PART_MAGIC) { @@ -610,6 +743,11 @@ static void mtk_image_print_header(const void *ptr)
printf("Image Type: MediaTek BootROM Loadable Image\n");
+ if (image_get_magic(hdr) == IH_MAGIC) { + mtk_image_verify_mt7621_header(ptr, 1); + return; + } + if (!strcmp((char *)ptr, NAND_BOOT_NAME)) mtk_image_verify_nand_header(ptr, 1); else @@ -773,6 +911,45 @@ static void mtk_image_set_nand_header(void *ptr, off_t filesize, filesize - 2 * le16_to_cpu(hdr_nand->pagesize) - SHA256_SUM_LEN); }
+static void mtk_image_set_mt7621_header(void *ptr, off_t filesize, + uint32_t loadaddr) +{ + image_header_t *hdr = (image_header_t *)ptr; + struct mt7621_stage1_header *shdr; + struct mt7621_nand_header *nhdr; + uint32_t datasize, crcval; + + datasize = filesize - image_get_header_size(); + nhdr = (struct mt7621_nand_header *)hdr->ih_name; + shdr = (struct mt7621_stage1_header *)(ptr + image_get_header_size()); + + shdr->ep = cpu_to_be32(loadaddr); + shdr->stage_size = cpu_to_be32(datasize); + + image_set_magic(hdr, IH_MAGIC); + image_set_time(hdr, time(NULL)); + image_set_size(hdr, datasize); + image_set_load(hdr, loadaddr); + image_set_ep(hdr, loadaddr); + image_set_os(hdr, IH_OS_U_BOOT); + image_set_arch(hdr, IH_ARCH_MIPS); + image_set_type(hdr, IH_TYPE_STANDALONE); + image_set_comp(hdr, IH_COMP_NONE); + + crcval = crc32(0, (uint8_t *)shdr, datasize); + image_set_dcrc(hdr, crcval); + + strncpy(nhdr->ih_name, "MT7621 NAND", MT7621_IH_NMLEN); + + nhdr->ih_stage_offset = cpu_to_be32(image_get_header_size()); + + crcval = crc32be_cal(hdr, image_get_header_size()); + nhdr->crc = cpu_to_be32(crcval); + + crcval = crc32(0, (uint8_t *)hdr, image_get_header_size()); + image_set_hcrc(hdr, crcval); +} + static void mtk_image_set_header(void *ptr, struct stat *sbuf, int ifd, struct image_tool_params *params) { @@ -791,6 +968,11 @@ static void mtk_image_set_header(void *ptr, struct stat *sbuf, int ifd, img_gen = true; img_size = sbuf->st_size;
+ if (use_mt7621_hdr) { + mtk_image_set_mt7621_header(ptr, sbuf->st_size, params->addr); + return; + } + if (hdr_media == BRLYT_TYPE_NAND || hdr_media == BRLYT_TYPE_SNAND) mtk_image_set_nand_header(ptr, sbuf->st_size, params->addr); else diff --git a/tools/mtk_image.h b/tools/mtk_image.h index 7dda71ce88..d868545a33 100644 --- a/tools/mtk_image.h +++ b/tools/mtk_image.h @@ -200,4 +200,28 @@ union lk_hdr {
#define LK_PART_MAGIC 0x58881688
+/* MT7621 NAND SPL image header */ + +#define MT7621_IH_NMLEN 12 +#define MT7621_IH_CRC_POLYNOMIAL 0x04c11db7 + +struct mt7621_nand_header { + char ih_name[MT7621_IH_NMLEN]; + uint32_t nand_ac_timing; + uint32_t ih_stage_offset; + uint32_t ih_bootloader_offset; + uint32_t nand_info_1_data; + uint32_t crc; +}; + +struct mt7621_stage1_header { + uint32_t jump_insn[2]; + uint32_t ep; + uint32_t stage_size; + uint32_t has_stage2; + uint32_t next_ep; + uint32_t next_size; + uint32_t next_offset; +}; + #endif /* _MTK_IMAGE_H */
Update maintainer for MediaTek MIPS platform
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v5 changes: none v4 changes: Add new files v3 changes: none v2 changes: none --- MAINTAINERS | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/MAINTAINERS b/MAINTAINERS index 56be0bfad0..f8b713aaf1 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -995,15 +995,23 @@ R: GSS_MTK_Uboot_upstream GSS_MTK_Uboot_upstream@mediatek.com S: Maintained F: arch/mips/mach-mtmips/ F: arch/mips/dts/mt7620.dtsi +F: arch/mips/dts/mt7621.dtsi F: arch/mips/dts/mt7620-u-boot.dtsi +F: arch/mips/dts/mt7621-u-boot.dtsi F: include/configs/mt7620.h +F: include/configs/mt7621.h F: include/dt-bindings/clock/mt7620-clk.h +F: include/dt-bindings/clock/mt7621-clk.h F: include/dt-bindings/clock/mt7628-clk.h F: include/dt-bindings/reset/mt7620-reset.h +F: include/dt-bindings/reset/mt7621-reset.h F: include/dt-bindings/reset/mt7628-reset.h F: drivers/clk/mtmips/ F: drivers/pinctrl/mtmips/ F: drivers/gpio/mt7620_gpio.c +F: drivers/mtd/nand/raw/mt7621_nand.c +F: drivers/mtd/nand/raw/mt7621_nand.h +F: drivers/mtd/nand/raw/mt7621_nand_spl.c F: drivers/net/mt7620-eth.c F: drivers/phy/mt7620-usb-phy.c F: drivers/reset/reset-mtmips.c
Daniel Schwierzeck
Sean Anderson
Weijie Gao
