[PULL] Please pull qcom/qcom-next
Hi Tom,
The highlights are:
* Fixed boot regression due to broken memory parsing * Enable HW RNG and KASLR on all platforms * Add support for Snapdragon X1 Elite hardware (clk/pinctrl) * Add support for QCS9100 ride automotive development platform (clk/ufs) * Add support for PCIe on SM8550, SM8650 and X1E * Implement software debounce for PMIC buttons
Additionally, some minor improvements to "ufetch" have been pulled in:
* Show CPU architecture (arm/mips/etc) * Make CONFIG_BLK optional * Fix 32-bit support
The following changes since commit 82d262ae162d859d3b0bbcd40a9464e890b009da:
Merge patch series "MediaTek MT7629 OF_UPSTREAM migration (v2)" (2025-01-21 09:29:05 -0600)
git@source.denx.de:/u-boot/custodians/u-boot-snapdragon.git HEAD
for you to fetch changes up to 599a1f9076d34c29d3683e0f833706478d62d9e0:
MAINTAINERS: maintain qcs9100_defconfig (2025-01-22 17:14:24 +0100)
---------------------------------------------------------------- Caleb Connolly (2): button: qcom-pmic: add software debounce MAINTAINERS: maintain qcs9100_defconfig
J. Neuschäfer (3): cmd: ufetch: Fix type mismatch on 32-bit cmd: Allow building ufetch without CONFIG_BLK cmd: ufetch: Show CPU architecture under "CPU"
Neil Armstrong (17): clk: qcom: Add X1E80100 clock driver qcom_defconfig: enable X1E80100 clock driver pinctrl: qcom: Add X1E80100 pinctrl driver qcom_defconfig: enable X1E80100 pinctrl driver pinctrl: qcom: sm8550: add pcie1_clk_req_n function pinctrl: qcom: sm8650: add pcie[01]_clk_req_n function pinctrl: qcom: x1e80100: add pcie[3456ab]_clk functions regulator: qcom-rpmh-regulator: add support for pmc8380 regulators clk: qcom: add clk_phy_mux_enable() for PCIe PIPE clock clk: qcom: sm8550: add support for PCIe clocks clk: qcom: sm8650: add support for PCIe clocks clk: qcom: x1e80100: add support for PCIe clocks rng: msm: add support for newer Qualcomm hwrandom IPs configs: qcom_defconfig: enable RNG driver and command pci: pcie_dw_common: introduce pcie_dw_find_capability() pci: Add support for Qualcomm PCIe controller phy: qcom: add QMP PCIe PHY driver
Sam Day (1): mach-snapdragon: pass fdt to qcom_parse_memory
Tengfei Fan (1): arm64: dts: qcom: qcs9100: Add support for the QCS9100 Ride and Ride Rev3 boards
Varadarajan Narayanan (5): dts: qcs9100-ride-r3-u-boot: add override dtsi clk/qcom: add initial clock driver for qcs9100 phy: qcom: Add SA8775 to QMP UFS PHY driver qcom_defconfig: enable SA8775P clock driver configs: add qcs9100_defconfig
MAINTAINERS | 1 + arch/arm/dts/qcs9100-ride-r3-u-boot.dtsi | 20 + arch/arm/mach-snapdragon/board.c | 15 +- cmd/Kconfig | 1 - cmd/ufetch.c | 17 +- configs/qcom_defconfig | 6 + configs/qcs9100_defconfig | 18 + drivers/button/button-qcom-pmic.c | 14 +- drivers/clk/qcom/Kconfig | 16 + drivers/clk/qcom/Makefile | 2 + drivers/clk/qcom/clock-qcom.c | 19 + drivers/clk/qcom/clock-qcom.h | 2 + drivers/clk/qcom/clock-sa8775p.c | 142 +++ drivers/clk/qcom/clock-sm8550.c | 36 + drivers/clk/qcom/clock-sm8650.c | 36 + drivers/clk/qcom/clock-x1e80100.c | 402 +++++++ drivers/pci/Kconfig | 8 + drivers/pci/Makefile | 1 + drivers/pci/pcie_dw_common.c | 42 + drivers/pci/pcie_dw_common.h | 2 + drivers/pci/pcie_dw_qcom.c | 571 ++++++++++ drivers/phy/qcom/Kconfig | 6 + drivers/phy/qcom/Makefile | 1 + drivers/phy/qcom/phy-qcom-qmp-pcie-qhp.h | 123 +++ drivers/phy/qcom/phy-qcom-qmp-pcie.c | 1131 ++++++++++++++++++++ drivers/phy/qcom/phy-qcom-qmp-pcs-misc-v3.h | 17 + drivers/phy/qcom/phy-qcom-qmp-pcs-pcie-v4.h | 72 ++ drivers/phy/qcom/phy-qcom-qmp-pcs-pcie-v4_20.h | 19 + drivers/phy/qcom/phy-qcom-qmp-pcs-pcie-v5.h | 17 + drivers/phy/qcom/phy-qcom-qmp-pcs-pcie-v5_20.h | 23 + drivers/phy/qcom/phy-qcom-qmp-pcs-pcie-v6.h | 17 + drivers/phy/qcom/phy-qcom-qmp-pcs-pcie-v6_20.h | 25 + drivers/phy/qcom/phy-qcom-qmp-pcs-v5.h | 34 + drivers/phy/qcom/phy-qcom-qmp-pcs-v6.h | 32 + drivers/phy/qcom/phy-qcom-qmp-pcs-v6_20.h | 19 + drivers/phy/qcom/phy-qcom-qmp-qserdes-com-v5.h | 124 +++ drivers/phy/qcom/phy-qcom-qmp-qserdes-ln-shrd-v6.h | 32 + drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx-v5.h | 231 ++++ drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx-v6.h | 83 ++ drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx-v6_20.h | 51 + drivers/phy/qcom/phy-qcom-qmp-ufs.c | 171 +++ drivers/pinctrl/qcom/Kconfig | 7 + drivers/pinctrl/qcom/Makefile | 1 + drivers/pinctrl/qcom/pinctrl-sm8550.c | 1 + drivers/pinctrl/qcom/pinctrl-sm8650.c | 2 + drivers/pinctrl/qcom/pinctrl-x1e80100.c | 105 ++ drivers/power/regulator/qcom-rpmh-regulator.c | 19 + drivers/rng/msm_rng.c | 13 +- dts/upstream/src/arm64/qcom/qcs9100-ride-r3.dts | 11 + dts/upstream/src/arm64/qcom/qcs9100-ride.dts | 11 + include/pci.h | 4 + 51 files changed, 3756 insertions(+), 17 deletions(-) create mode 100644 arch/arm/dts/qcs9100-ride-r3-u-boot.dtsi create mode 100644 configs/qcs9100_defconfig create mode 100644 drivers/clk/qcom/clock-sa8775p.c create mode 100644 drivers/clk/qcom/clock-x1e80100.c create mode 100644 drivers/pci/pcie_dw_qcom.c create mode 100644 drivers/phy/qcom/phy-qcom-qmp-pcie-qhp.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-pcie.c create mode 100644 drivers/phy/qcom/phy-qcom-qmp-pcs-misc-v3.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-pcs-pcie-v4.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-pcs-pcie-v4_20.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-pcs-pcie-v5.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-pcs-pcie-v5_20.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-pcs-pcie-v6.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-pcs-pcie-v6_20.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-pcs-v5.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-pcs-v6.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-pcs-v6_20.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-qserdes-com-v5.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-qserdes-ln-shrd-v6.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx-v5.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx-v6.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx-v6_20.h create mode 100644 drivers/pinctrl/qcom/pinctrl-x1e80100.c create mode 100644 dts/upstream/src/arm64/qcom/qcs9100-ride-r3.dts create mode 100644 dts/upstream/src/arm64/qcom/qcs9100-ride.dts
On Wed, Jan 22, 2025 at 05:17:45PM +0100, Caleb Connolly wrote:
Hi Tom,
The highlights are:
- Fixed boot regression due to broken memory parsing
- Enable HW RNG and KASLR on all platforms
- Add support for Snapdragon X1 Elite hardware (clk/pinctrl)
- Add support for QCS9100 ride automotive development platform (clk/ufs)
- Add support for PCIe on SM8550, SM8650 and X1E
- Implement software debounce for PMIC buttons
- Show CPU architecture (arm/mips/etc)
- Make CONFIG_BLK optional
- Fix 32-bit support
Caleb Connolly
