[U-Boot] [PATCH V2] Drivers: USB: Remove Legacy CONFIG_USB_DAVINCI
This patch removes CONFIG_USB_DAVINCI. It's a legacy option that isn't defined anywhere, and there is a newer MUSB driver.
Signed-off-by: Adam Ford aford173@gmail.com Reviewed-by: Jean-Jacques Hiblot jjhiblot@ti.com --- V2: Rebase on origin/master Remove drivers/usb/musb/davinci.c Remove drivers/usb/musb/davinci.h
diff --git a/drivers/usb/musb/Kconfig b/drivers/usb/musb/Kconfig index dd42f69a6b..7e6be03f4a 100644 --- a/drivers/usb/musb/Kconfig +++ b/drivers/usb/musb/Kconfig @@ -11,9 +11,6 @@ config USB_MUSB_HCD config USB_MUSB_UDC bool "Legacy USB Device Controller"
-config USB_DAVINCI - bool "Legacy MUSB DaVinci" - config USB_OMAP3 bool "Legacy MUSB OMAP3 / OMAP4" depends on ARCH_OMAP2PLUS diff --git a/drivers/usb/musb/Makefile b/drivers/usb/musb/Makefile index bdb3cd87f6..1242ce1c8c 100644 --- a/drivers/usb/musb/Makefile +++ b/drivers/usb/musb/Makefile @@ -5,7 +5,6 @@
obj-$(CONFIG_USB_MUSB_HCD) += musb_hcd.o musb_core.o obj-$(CONFIG_USB_MUSB_UDC) += musb_udc.o musb_core.o -obj-$(CONFIG_USB_DAVINCI) += davinci.o obj-$(CONFIG_USB_OMAP3) += omap3.o obj-$(CONFIG_USB_DA8XX) += da8xx.o obj-$(CONFIG_USB_AM35X) += am35x.o diff --git a/drivers/usb/musb/davinci.c b/drivers/usb/musb/davinci.c deleted file mode 100644 index 46cdb5ad1f..0000000000 --- a/drivers/usb/musb/davinci.c +++ /dev/null @@ -1,123 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * TI's Davinci platform specific USB wrapper functions. - * - * Copyright (c) 2008 Texas Instruments - * - * Author: Thomas Abraham t-abraham@ti.com, Texas Instruments - */ - -#include <common.h> -#include <asm/io.h> -#include "davinci.h" -#include <asm/arch/hardware.h> - -#if !defined(CONFIG_DV_USBPHY_CTL) -#define CONFIG_DV_USBPHY_CTL (USBPHY_SESNDEN | USBPHY_VBDTCTEN) -#endif - -/* MUSB platform configuration */ -struct musb_config musb_cfg = { - .regs = (struct musb_regs *)MENTOR_USB0_BASE, - .timeout = DAVINCI_USB_TIMEOUT, - .musb_speed = 0, -}; - -/* MUSB module register overlay */ -struct davinci_usb_regs *dregs; - -/* - * Enable the USB phy - */ -static u8 phy_on(void) -{ - u32 timeout; -#ifdef DAVINCI_DM365EVM - u32 val; -#endif - /* Wait until the USB phy is turned on */ -#ifdef DAVINCI_DM365EVM - writel(USBPHY_PHY24MHZ | USBPHY_SESNDEN | - USBPHY_VBDTCTEN, USBPHY_CTL_PADDR); -#else - writel(CONFIG_DV_USBPHY_CTL, USBPHY_CTL_PADDR); -#endif - timeout = musb_cfg.timeout; - -#ifdef DAVINCI_DM365EVM - /* Set the ownership of GIO33 to USB */ - val = readl(PINMUX4); - val &= ~(PINMUX4_USBDRVBUS_BITCLEAR); - val |= PINMUX4_USBDRVBUS_BITSET; - writel(val, PINMUX4); -#endif - while (timeout--) - if (readl(USBPHY_CTL_PADDR) & USBPHY_PHYCLKGD) - return 1; - - /* USB phy was not turned on */ - return 0; -} - -/* - * Disable the USB phy - */ -static void phy_off(void) -{ - /* powerdown the on-chip PHY and its oscillator */ - writel(USBPHY_OSCPDWN | USBPHY_PHYPDWN, USBPHY_CTL_PADDR); -} - -void __enable_vbus(void) -{ - /* - * nothing to do, vbus is handled through the cpu. - * Define this function in board code, if it is - * different on your board. - */ -} -void enable_vbus(void) - __attribute__((weak, alias("__enable_vbus"))); - -/* - * This function performs Davinci platform specific initialization for usb0. - */ -int musb_platform_init(void) -{ - u32 revision; - - /* enable USB VBUS */ - enable_vbus(); - - /* start the on-chip USB phy and its pll */ - if (!phy_on()) - return -1; - - /* reset the controller */ - dregs = (struct davinci_usb_regs *)DAVINCI_USB0_BASE; - writel(1, &dregs->ctrlr); - udelay(5000); - - /* Returns zero if e.g. not clocked */ - revision = readl(&dregs->version); - if (!revision) - return -1; - - /* Disable all interrupts */ - writel(DAVINCI_USB_USBINT_MASK | DAVINCI_USB_RXINT_MASK | - DAVINCI_USB_TXINT_MASK , &dregs->intmsksetr); - return 0; -} - -/* - * This function performs Davinci platform specific deinitialization for usb0. - */ -void musb_platform_deinit(void) -{ - /* Turn of the phy */ - phy_off(); - - /* flush any interrupts */ - writel(DAVINCI_USB_USBINT_MASK | DAVINCI_USB_TXINT_MASK | - DAVINCI_USB_RXINT_MASK , &dregs->intclrr); -} diff --git a/drivers/usb/musb/davinci.h b/drivers/usb/musb/davinci.h deleted file mode 100644 index 29bb08c307..0000000000 --- a/drivers/usb/musb/davinci.h +++ /dev/null @@ -1,73 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * TI's Davinci platform specific USB wrapper functions. - * - * Copyright (c) 2008 Texas Instruments - * - * Author: Thomas Abraham t-abraham@ti.com, Texas Instruments - */ - -#ifndef __DAVINCI_USB_H__ -#define __DAVINCI_USB_H__ - -#include <asm/arch/hardware.h> -#include "musb_core.h" - -/* Base address of DAVINCI usb0 wrapper */ -#define DAVINCI_USB0_BASE 0x01C64000 - -/* Base address of DAVINCI musb core */ -#define MENTOR_USB0_BASE (DAVINCI_USB0_BASE+0x400) - -/* - * Davinci platform USB wrapper register overlay. Note: Only the required - * registers are included in this structure. It can be expanded as required. - */ -struct davinci_usb_regs { - u32 version; - u32 ctrlr; - u32 reserved[0x20]; - u32 intclrr; - u32 intmskr; - u32 intmsksetr; -}; - -#define DAVINCI_USB_TX_ENDPTS_MASK 0x1f /* ep0 + 4 tx */ -#define DAVINCI_USB_RX_ENDPTS_MASK 0x1e /* 4 rx */ -#define DAVINCI_USB_USBINT_SHIFT 16 -#define DAVINCI_USB_TXINT_SHIFT 0 -#define DAVINCI_USB_RXINT_SHIFT 8 -#define DAVINCI_INTR_DRVVBUS 0x0100 - -#define DAVINCI_USB_USBINT_MASK 0x01ff0000 /* 8 Mentor, DRVVBUS */ -#define DAVINCI_USB_TXINT_MASK \ - (DAVINCI_USB_TX_ENDPTS_MASK << DAVINCI_USB_TXINT_SHIFT) -#define DAVINCI_USB_RXINT_MASK \ - (DAVINCI_USB_RX_ENDPTS_MASK << DAVINCI_USB_RXINT_SHIFT) -#define MGC_BUSCTL_OFFSET(_bEnd, _bOffset) \ - (0x80 + (8*(_bEnd)) + (_bOffset)) - -/* Integrated highspeed/otg PHY */ -#define USBPHY_CTL_PADDR (DAVINCI_SYSTEM_MODULE_BASE + 0x34) -#define USBPHY_PHY24MHZ (1 << 13) -#define USBPHY_PHYCLKGD (1 << 8) -#define USBPHY_SESNDEN (1 << 7) /* v(sess_end) comparator */ -#define USBPHY_VBDTCTEN (1 << 6) /* v(bus) comparator */ -#define USBPHY_PHYPLLON (1 << 4) /* override pll suspend */ -#define USBPHY_CLKO1SEL (1 << 3) -#define USBPHY_OSCPDWN (1 << 2) -#define USBPHY_PHYPDWN (1 << 0) - -/* Timeout for Davinci USB module */ -#define DAVINCI_USB_TIMEOUT 0x3FFFFFF - -/* IO Expander I2C address and VBUS enable mask */ -#define IOEXP_I2C_ADDR 0x3A -#define IOEXP_VBUSEN_MASK 1 - -/* extern functions */ -extern void lpsc_on(unsigned int id); -extern int i2c_write(uchar chip, uint addr, int alen, uchar *buffer, int len); -extern int i2c_read(uchar chip, uint addr, int alen, uchar *buffer, int len); -extern void enable_vbus(void); -#endif /* __DAVINCI_USB_H__ */ diff --git a/drivers/usb/musb/musb_udc.c b/drivers/usb/musb/musb_udc.c index f1d6d85862..7620114bec 100644 --- a/drivers/usb/musb/musb_udc.c +++ b/drivers/usb/musb/musb_udc.c @@ -46,8 +46,6 @@ #include "omap3.h" #elif defined(CONFIG_USB_AM35X) #include "am35x.h" -#elif defined(CONFIG_USB_DAVINCI) -#include "davinci.h" #endif
/* Define MUSB_DEBUG for debugging */
Applied after fixing the tags, please use usb: musb: next time.
Adam Ford
