[U-Boot] [PATCH v2 0/2] Add Rock960 board support
This patchset adds board support for Vamrs Limited Rock960, which is one of the 96Boards Consumer Edition platform based on Rockchip RK3399 SoC.
On this board, U-Boot will be loaded by ATF as a BL33 image which in turn loads Linux kernel from eMMC or SD card. Instructions for building and flashing the images are specified in board README.md file.
More information about this board can be found in 96Boards product page: https://www.96boards.org/product/rock960/
The board support includes only the necessary interfaces required to boot Linux kernel.
Thanks, Mani
Manivannan Sadhasivam (2): arm: dts: Add Rock960 devicetree support board: Add Vamrs Limited Rock960 board support
arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3399-rock960.dts | 348 ++++++++++++++++++++ arch/arm/mach-rockchip/rk3399/Kconfig | 16 + board/vamrs/rock960_rk3399/Kconfig | 15 + board/vamrs/rock960_rk3399/MAINTAINERS | 6 + board/vamrs/rock960_rk3399/Makefile | 6 + board/vamrs/rock960_rk3399/README | 79 +++++ board/vamrs/rock960_rk3399/rock960-rk3399.c | 50 +++ configs/rock960-rk3399_defconfig | 62 ++++ include/configs/rock960_rk3399.h | 15 + 10 files changed, 598 insertions(+) create mode 100644 arch/arm/dts/rk3399-rock960.dts create mode 100644 board/vamrs/rock960_rk3399/Kconfig create mode 100644 board/vamrs/rock960_rk3399/MAINTAINERS create mode 100644 board/vamrs/rock960_rk3399/Makefile create mode 100644 board/vamrs/rock960_rk3399/README create mode 100644 board/vamrs/rock960_rk3399/rock960-rk3399.c create mode 100644 configs/rock960-rk3399_defconfig create mode 100644 include/configs/rock960_rk3399.h
Add devicetree support for Vamrs Limited Rock960. This board is one of the 96Boards Consumer Edition platform.
Signed-off-by: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org ---
Changes in v2:
* Added missing DTB entry in arch/arm/dts/Makefile
arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3399-rock960.dts | 348 ++++++++++++++++++++++++++++++++ 2 files changed, 349 insertions(+) create mode 100644 arch/arm/dts/rk3399-rock960.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index ebfa2272627..9b891826b73 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -51,6 +51,7 @@ dtb-$(CONFIG_ARCH_ROCKCHIP) += \ rk3399-puma-ddr1333.dtb \ rk3399-puma-ddr1600.dtb \ rk3399-puma-ddr1866.dtb \ + rk3399-rock960.dtb \ rv1108-evb.dtb dtb-$(CONFIG_ARCH_MESON) += \ meson-gxbb-nanopi-k2.dtb \ diff --git a/arch/arm/dts/rk3399-rock960.dts b/arch/arm/dts/rk3399-rock960.dts new file mode 100644 index 00000000000..8662548e642 --- /dev/null +++ b/arch/arm/dts/rk3399-rock960.dts @@ -0,0 +1,348 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org + */ + +/dts-v1/; +#include <dt-bindings/pwm/pwm.h> +#include <dt-bindings/pinctrl/rockchip.h> +#include "rk3399.dtsi" +#include "rk3399-sdram-lpddr3-4GB-1600.dtsi" + +/ { + model = "Vamrs Limited Rock960 96Board"; + compatible = "rockchip,rk3399-rock960", "rockchip,rk3399"; + + chosen { + stdout-path = &uart2; + u-boot,spl-boot-order = \ + &sdhci, &sdmmc; + }; + + vccsys: vccsys { + compatible = "regulator-fixed"; + regulator-name = "vccsys"; + regulator-boot-on; + regulator-always-on; + }; + + vcc3v3_sys: vcc3v3-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + vcc5v0_sys: vcc5v0-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + vcc5v0_usb: vcc5v0-usb { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_usb"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + vcc5v0_host0: vcc5v0-host0-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_host0"; + gpio = <&gpio4 25 GPIO_ACTIVE_HIGH>; + }; + + vcc5v0_host1: vcc5v0-host1-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_host1"; + gpio = <&gpio4 25 GPIO_ACTIVE_HIGH>; + }; + + vcc5v0_host2: vcc5v0-host2-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_host2"; + gpio = <&gpio4 25 GPIO_ACTIVE_HIGH>; + }; + + vbus_typec: vbus-typec-regulator { + compatible = "regulator-fixed"; + regulator-name = "vbus_typec"; + gpio = <&gpio1 3 GPIO_ACTIVE_HIGH>; + }; + + vdd_log: vdd-log { + compatible = "pwm-regulator"; + pwms = <&pwm2 0 25000 1>; + regulator-name = "vdd_log"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1400000>; + regulator-init-microvolt = <900000>; + }; +}; + +&emmc_phy { + status = "okay"; +}; + +&pwm0 { + status = "okay"; +}; + +&pwm2 { + status = "okay"; +}; + +&pwm3 { + status = "okay"; +}; + +&saradc { + status = "okay"; +}; + +&sdmmc { + u-boot,dm-pre-reloc; + bus-width = <4>; + status = "okay"; +}; + +&sdhci { + bus-width = <8>; + mmc-hs400-1_8v; + mmc-hs400-enhanced-strobe; + non-removable; + status = "okay"; +}; + +&uart2 { + status = "okay"; +}; + +&i2c0 { + status = "okay"; + clock-frequency = <400000>; + i2c-scl-falling-time-ns = <50>; + i2c-scl-rising-time-ns = <100>; + u-boot,dm-pre-reloc; + + rk808: pmic@1b { + compatible = "rockchip,rk808"; + reg = <0x1b>; + interrupt-parent = <&gpio1>; + interrupts = <21 IRQ_TYPE_LEVEL_LOW>; + #clock-cells = <1>; + clock-output-names = "rtc_clko_soc", "rtc_clko_wifi"; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int_l>; + rockchip,system-power-controller; + wakeup-source; + + vcc1-supply = <&vcc5v0_sys>; + vcc2-supply = <&vcc5v0_sys>; + vcc3-supply = <&vcc5v0_sys>; + vcc4-supply = <&vcc5v0_sys>; + vcc6-supply = <&vcc5v0_sys>; + vcc7-supply = <&vcc5v0_sys>; + vcc8-supply = <&vcc5v0_sys>; + vcc9-supply = <&vcc5v0_sys>; + vcc10-supply = <&vcc5v0_sys>; + vcc11-supply = <&vcc5v0_sys>; + vcc12-supply = <&vcc3v3_sys>; + vcc13-supply = <&vcc5v0_sys>; + vcc14-supply = <&vcc5v0_sys>; + vddio-supply = <&vcc_1v8>; + + regulators { + vdd_center: DCDC_REG1 { + regulator-name = "vdd_center"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_l: DCDC_REG2 { + regulator-name = "vdd_cpu_l"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_1v8: DCDC_REG4 { + regulator-name = "vcc_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc1v8_dvp: LDO_REG1 { + regulator-name = "vcc1v8_dvp"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcca1v8_hdmi: LDO_REG2 { + regulator-name = "vcca1v8_hdmi"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcca_1v8: LDO_REG3 { + regulator-name = "vcca_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc_sdio: LDO_REG4 { + regulator-name = "vcc_sdio"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3000000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3000000>; + }; + }; + + vcca1v8_mipi: LDO_REG5 { + regulator-name = "vcca1v8_mipi"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v5: LDO_REG6 { + regulator-name = "vcc_1v5"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1500000>; + }; + }; + + vcca0v9_hdmi: LDO_REG7 { + regulator-name = "vcca0v9_hdmi"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_3v0: LDO_REG8 { + regulator-name = "vcc_3v0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3000000>; + }; + }; + }; + }; + + vdd_cpu_b: regulator@40 { + compatible = "silergy,syr827"; + reg = <0x40>; + fcs,suspend-voltage-selector = <0>; + regulator-name = "vdd_cpu_b"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <1000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_gpu: regulator@41 { + compatible = "silergy,syr828"; + reg = <0x41>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_gpu"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <1000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; +}; + +&pinctrl { + pmic { + pmic_int_l: pmic-int-l { + rockchip,pins = + <1 21 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; +};
Add board support for Vamrs Limited Rock960 board, which is one of the 96Boards Consumer Edition platform.
Rock960 features: * CPU: ARMv8 64bit Big-Little architecture, * Big: dual-core Cortex-A72 * Little: quad-core Cortex-A53 * IRAM: 200KB * DRAM: 2GB/4GB LPDDR3 @ 1866MHz * eMMC: 16/32GB eMMC 5.1 * PMU: RK808 * SD/MMC * USB: * 1x USB 3.0 type A, 1x USB 2.0 type A (host mode only) and 1x USB 3.0 type C OTG * Display: * 1x HDMI 2.0(Type A - full) up to 4Kx2K@60Hz, 1x 4L - MIPI DSI up to 1080p@60Hz, 1x DP 1.2(Type C) up to 4Kx2K@60 * Camera: 2x 4-lane MIPI CSI * PCI-E: 4- lane M.2 PCI-E 2.1 * Low Speed Expansion Connector * High Speed Expansion Connector
Changes in v2: None
arch/arm/mach-rockchip/rk3399/Kconfig | 16 +++++ board/vamrs/rock960_rk3399/Kconfig | 15 ++++ board/vamrs/rock960_rk3399/MAINTAINERS | 6 ++ board/vamrs/rock960_rk3399/Makefile | 6 ++ board/vamrs/rock960_rk3399/README | 79 +++++++++++++++++++++ board/vamrs/rock960_rk3399/rock960-rk3399.c | 50 +++++++++++++ configs/rock960-rk3399_defconfig | 62 ++++++++++++++++ include/configs/rock960_rk3399.h | 15 ++++ 8 files changed, 249 insertions(+) create mode 100644 board/vamrs/rock960_rk3399/Kconfig create mode 100644 board/vamrs/rock960_rk3399/MAINTAINERS create mode 100644 board/vamrs/rock960_rk3399/Makefile create mode 100644 board/vamrs/rock960_rk3399/README create mode 100644 board/vamrs/rock960_rk3399/rock960-rk3399.c create mode 100644 configs/rock960-rk3399_defconfig create mode 100644 include/configs/rock960_rk3399.h
diff --git a/arch/arm/mach-rockchip/rk3399/Kconfig b/arch/arm/mach-rockchip/rk3399/Kconfig index 415466a49bb..ce4605187e3 100644 --- a/arch/arm/mach-rockchip/rk3399/Kconfig +++ b/arch/arm/mach-rockchip/rk3399/Kconfig @@ -28,6 +28,21 @@ config TARGET_PUMA_RK3399 * HDMI, eDP, MIPI-DSI, MIPI-DSI/CSI and MIPI-CSI * SPI, I2C, I2S, UART, GPIO, ...
+config TARGET_ROCK960_RK3399 + bool "Vamrs Limited Rock960 board" + help + Support for Rock960 board. This board complies with + 96Board Consumer Edition Specification. + + Features: + * Rockchip RK3399 SoC (2xCortex A72, 4xCortex A53, ARM Mali T860MP4) + * 2GiB/4GiB RAM + * 16/32GB eMMC, uSD slot + * WiFi, Bluetooth + * 1x USB 3.0 type A, 1x USB 2.0 type A (host mode only), 1x USB 3.0 type C OTG + * HDMI + * 20-pin low speed and 40-pin high speed expanders, 6 LED, 3 buttons + endchoice
config SYS_SOC @@ -38,5 +53,6 @@ config SYS_MALLOC_F_LEN
source "board/rockchip/evb_rk3399/Kconfig" source "board/theobroma-systems/puma_rk3399/Kconfig" +source "board/vamrs/rock960_rk3399/Kconfig"
endif diff --git a/board/vamrs/rock960_rk3399/Kconfig b/board/vamrs/rock960_rk3399/Kconfig new file mode 100644 index 00000000000..cacc53f3780 --- /dev/null +++ b/board/vamrs/rock960_rk3399/Kconfig @@ -0,0 +1,15 @@ +if TARGET_ROCK960_RK3399 + +config SYS_BOARD + default "rock960_rk3399" + +config SYS_VENDOR + default "vamrs" + +config SYS_CONFIG_NAME + default "rock960_rk3399" + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + +endif diff --git a/board/vamrs/rock960_rk3399/MAINTAINERS b/board/vamrs/rock960_rk3399/MAINTAINERS new file mode 100644 index 00000000000..9f3fe75f4fb --- /dev/null +++ b/board/vamrs/rock960_rk3399/MAINTAINERS @@ -0,0 +1,6 @@ +ROCK960-RK3399 +M: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org +S: Maintained +F: board/rockchip/rock960_rk3399 +F: include/configs/rock960_rk3399.h +F: configs/rock960-rk3399_defconfig diff --git a/board/vamrs/rock960_rk3399/Makefile b/board/vamrs/rock960_rk3399/Makefile new file mode 100644 index 00000000000..6c3e475b3a8 --- /dev/null +++ b/board/vamrs/rock960_rk3399/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org +# + +obj-y += rock960-rk3399.o diff --git a/board/vamrs/rock960_rk3399/README b/board/vamrs/rock960_rk3399/README new file mode 100644 index 00000000000..be6b5cd1d34 --- /dev/null +++ b/board/vamrs/rock960_rk3399/README @@ -0,0 +1,79 @@ +Introduction +============ + +Rock960 is a 96Boards Consumer Edition platform featuring the Rockchip +RK3399 SoC. + +Rock960 features: + * CPU: ARMv8 64bit Big-Little architecture, + * Big: dual-core Cortex-A72 + * Little: quad-core Cortex-A53 + * IRAM: 200KB + * DRAM: 2GB/4GB LPDDR3 @ 1866MHz + * eMMC: 16/32GB eMMC 5.1 + * PMU: RK808 + * SD/MMC + * USB: + * 1x USB 3.0 type A, 1x USB 2.0 type A (host mode only) and + 1x USB 3.0 type C OTG + * Display: + * 1x HDMI 2.0(Type A - full) up to 4Kx2K@60Hz, + 1x 4L - MIPI DSI up to 1080p@60Hz, + 1x DP 1.2(Type C) up to 4Kx2K@60 + * Camera: 2x 4-lane MIPI CSI + * PCI-E: 4- lane M.2 PCI-E 2.1 + * Low Speed Expansion Connector + * High Speed Expansion Connector + +Here is the step-by-step to boot to U-Boot on rk3399. + +Get the Source and prebuild binary +================================== + + > git clone https://github.com/96rocks/rkbin.git + > git clone https://github.com/rockchip-linux/rkdeveloptool.git + +Compile the U-Boot +================== + + > cd ../u-boot + > export ARCH=arm64 + > export CROSS_COMPILE=aarch64-linux-gnu- + > make rock960-rk3399_defconfig + > make + +Compile the rkdeveloptool +========================= + Follow instructions in latest README + > cd ../rkdeveloptool + > autoreconf -i + > ./configure + > make + > sudo make install + +Package the image +================= + +Package the image for Rockchip miniloader +------------------------------------------ + > cd ../rkbin + > ./tools/loaderimage --pack --uboot u-boot/u-boot-dtb.bin uboot.img 0x200000 + + > ../u-boot/tools/mkimage -n rk3399 -T rksd -d rk3399_ddr_933MHz_v1.08.bin idbloader.img + > cat ./rk33/rk3399_miniloader_v1.06.bin >> idbloader.img + + Get uboot.img and idbloader.img in this step. + +Flash the image to eMMC +======================= + +Flash the image with Rockchip miniloader +---------------------------------------- +Power on(or reset with RESET KEY) with MASKROM KEY preesed, and then: + > rkdeveloptool db ./rk33/rk3399_loader_v1.08.106.bin + > rkdeveloptool wl 0x40 idbloader.img + > rkdeveloptool wl 0x4000 uboot.img + > rkdeveloptool wl 0x6000 ./img/rk3399/trust.img + > rkdeveloptool rd + +You should be able to get U-Boot log in console/UART2(baurdrate 1500000) diff --git a/board/vamrs/rock960_rk3399/rock960-rk3399.c b/board/vamrs/rock960_rk3399/rock960-rk3399.c new file mode 100644 index 00000000000..d3775b22191 --- /dev/null +++ b/board/vamrs/rock960_rk3399/rock960-rk3399.c @@ -0,0 +1,50 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org + */ + +#include <common.h> +#include <dm.h> +#include <dm/pinctrl.h> +#include <dm/uclass-internal.h> +#include <asm/arch/periph.h> +#include <power/regulator.h> +#include <spl.h> + +int board_init(void) +{ + int ret; + + ret = regulators_enable_boot_on(false); + if (ret) + debug("%s: Cannot enable boot on regulator\n", __func__); + + return 0; +} + +void spl_board_init(void) +{ + struct udevice *pinctrl; + int ret; + + ret = uclass_get_device(UCLASS_PINCTRL, 0, &pinctrl); + if (ret) { + debug("%s: Cannot find pinctrl device\n", __func__); + goto err; + } + + /* Enable debug UART */ + ret = pinctrl_request_noflags(pinctrl, PERIPH_ID_UART_DBG); + if (ret) { + debug("%s: Failed to set up console UART\n", __func__); + goto err; + } + + preloader_console_init(); + return; +err: + printf("%s: Error %d\n", __func__, ret); + + /* No way to report error here */ + hang(); +} diff --git a/configs/rock960-rk3399_defconfig b/configs/rock960-rk3399_defconfig new file mode 100644 index 00000000000..998c7a4b707 --- /dev/null +++ b/configs/rock960-rk3399_defconfig @@ -0,0 +1,62 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_TEXT_BASE=0x00200000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_ROCKCHIP_RK3399=y +CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x4000 +CONFIG_TARGET_ROCK960_RK3399=y +CONFIG_DEBUG_UART_BASE=0xFF1A0000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_BAUDRATE=1500000 +CONFIG_SPL_STACK_R_ADDR=0x80000 +CONFIG_DEFAULT_DEVICE_TREE="rk3399-rock960" +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-rockchip/make_fit_atf.py" +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock960.dtb" +CONFIG_SYS_PROMPT="rock960 => " +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 +CONFIG_SPL_ATF=y +CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_OF_PLATDATA=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MMC_DW=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_ROCKCHIP_RK3399=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_PWM=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_SYSRESET=y +CONFIG_USE_TINY_PRINTF=y +CONFIG_ERRNO_STR=y diff --git a/include/configs/rock960_rk3399.h b/include/configs/rock960_rk3399.h new file mode 100644 index 00000000000..746d24cbff5 --- /dev/null +++ b/include/configs/rock960_rk3399.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org + */ + +#ifndef __ROCK960_RK3399_H +#define __ROCK960_RK3399_H + +#include <configs/rk3399_common.h> + +#define CONFIG_SYS_MMC_ENV_DEV 1 + +#define SDRAM_BANK_SIZE (2UL << 30) + +#endif
