[U-Boot-Users] [PATCH 6/6] Add a flattened device tree (fdt) command (2 of 2)
Modifications to the existing code to support the new fdt command.
Signed-off-by: Gerald Van Baren vanbaren@cideas.com --- README | 33 ++++++++++--- board/mpc8360emds/config.mk | 6 ++ board/mpc8360emds/mpc8360emds.c | 30 +++++++++-- board/mpc8360emds/pci.c | 20 ++++++++ common/Makefile | 2 +- common/cmd_bootm.c | 65 +++++++++++++++++++++---- cpu/mpc83xx/cpu.c | 102 ++++++++++++++++++++++++++++++++++++++- include/configs/MPC8360EMDS.h | 6 ++- 8 files changed, 237 insertions(+), 27 deletions(-)
diff --git a/README b/README index 1542864..87d6d10 100644 --- a/README +++ b/README @@ -164,6 +164,7 @@ Directory Hierarchy: - lib_mips Files generic to MIPS architecture - lib_nios Files generic to NIOS architecture - lib_ppc Files generic to PowerPC architecture +- libfdt Library files to support flattened device trees - net Networking code - post Power On Self Test - rtc Real Time Clock drivers @@ -430,12 +431,23 @@ The following options need to be configured: expect it to be in bytes, others in MB. Define CONFIG_MEMSIZE_IN_BYTES to make it in bytes.
- CONFIG_OF_FLAT_TREE + CONFIG_OF_LIBFDT / CONFIG_OF_FLAT_TREE
New kernel versions are expecting firmware settings to be - passed using flat open firmware trees. - The environment variable "disable_of", when set, disables this - functionality. + passed using flattened device trees (based on open firmware + concepts). + + CONFIG_OF_LIBFDT + * New libfdt-based support + * Adds the "fdt" command + * The bootm command does _not_ modify the fdt + + CONFIG_OF_FLAT_TREE + * Deprecated, see CONFIG_OF_LIBFDT + * Original ft_build.c-based support + * Automatically modifies the dft as part of the bootm command + * The environment variable "disable_of", when set, + disables this functionality.
CONFIG_OF_FLAT_TREE_MAX_SIZE
@@ -448,13 +460,16 @@ The following options need to be configured:
CONFIG_OF_HAS_BD_T
- The resulting flat device tree will have a copy of the bd_t. - Space should be pre-allocated in the dts for the bd_t. + * CONFIG_OF_LIBFDT - enables the "fdt bd_t" command + * CONFIG_OF_FLAT_TREE - The resulting flat device tree + will have a copy of the bd_t. Space should be + pre-allocated in the dts for the bd_t.
CONFIG_OF_HAS_UBOOT_ENV
- The resulting flat device tree will have a copy of u-boot's - environment variables + * CONFIG_OF_LIBFDT - enables the "fdt bd_t" command + * CONFIG_OF_FLAT_TREE - The resulting flat device tree + will have a copy of u-boot's environment variables
CONFIG_OF_BOARD_SETUP
@@ -721,6 +736,8 @@ The following options need to be configured:
#define CONFIG_COMMANDS (CFG_CMD_ALL & ~CFG_CMD_NET)
+ Other Commands: + fdt (flattened device tree) command: CONFIG_OF_LIBFDT
Note: Don't enable the "icache" and "dcache" commands (configuration option CFG_CMD_CACHE) unless you know diff --git a/board/mpc8360emds/config.mk b/board/mpc8360emds/config.mk index 9ace886..d2a9435 100644 --- a/board/mpc8360emds/config.mk +++ b/board/mpc8360emds/config.mk @@ -26,3 +26,9 @@ #
TEXT_BASE = 0xFE000000 + +# +# Additional board-specific libraries +# +BOARDLIBS = libfdt/libfdt.a + diff --git a/board/mpc8360emds/mpc8360emds.c b/board/mpc8360emds/mpc8360emds.c index 535884c..deadb5f 100644 --- a/board/mpc8360emds/mpc8360emds.c +++ b/board/mpc8360emds/mpc8360emds.c @@ -31,6 +31,10 @@ #if defined(CONFIG_OF_FLAT_TREE) #include <ft_build.h> #endif +#if defined(CONFIG_OF_LIBFDT) +#include <libfdt.h> +#include <libfdt_env.h> +#endif
const qe_iop_conf_t qe_iop_conf_tab[] = { /* GETH1 */ @@ -658,22 +662,36 @@ U_BOOT_CMD(ecc, 4, 0, do_ecc, " - disables injects\n" " - re-inits memory"); #endif /* if defined(CONFIG_DDR_ECC) && defined(CONFIG_DDR_ECC_CMD) */
-#if defined(CONFIG_OF_FLAT_TREE) && defined(CONFIG_OF_BOARD_SETUP) +#if (defined(CONFIG_OF_FLAT_TREE) || defined(CONFIG_OF_LIBFDT)) \ + && defined(CONFIG_OF_BOARD_SETUP) void ft_board_setup(void *blob, bd_t *bd) { +#if defined(CONFIG_OF_LIBFDT) + int nodeoffset; + int err; + int tmp[2]; + + nodeoffset = fdt_path_offset (fdt, "/memory"); + if (nodeoffset >= 0) { + tmp[0] = cpu_to_be32(bd->bi_memstart); + tmp[1] = cpu_to_be32(bd->bi_memsize); + err = fdt_setprop(fdt, nodeoffset, "reg", tmp, sizeof(tmp)); + } +#else u32 *p; int len;
-#ifdef CONFIG_PCI - ft_pci_setup(blob, bd); -#endif - ft_cpu_setup(blob, bd); - p = ft_get_prop(blob, "/memory/reg", &len); if (p != NULL) { *p++ = cpu_to_be32(bd->bi_memstart); *p = cpu_to_be32(bd->bi_memsize); } +#endif + +#ifdef CONFIG_PCI + ft_pci_setup(blob, bd); +#endif + ft_cpu_setup(blob, bd); } #endif diff --git a/board/mpc8360emds/pci.c b/board/mpc8360emds/pci.c index 67cd709..158effe 100644 --- a/board/mpc8360emds/pci.c +++ b/board/mpc8360emds/pci.c @@ -21,6 +21,10 @@ #if defined(CONFIG_OF_FLAT_TREE) #include <ft_build.h> #endif +#if defined(CONFIG_OF_LIBFDT) +#include <libfdt.h> +#include <libfdt_env.h> +#endif
#include <asm/fsl_i2c.h>
@@ -299,6 +303,22 @@ void pci_init_board(void) } #endif /* CONFIG_PCISLAVE */
+#if defined(CONFIG_OF_LIBFDT) +void +ft_pci_setup(void *blob, bd_t *bd) +{ + int nodeoffset; + int err; + int tmp[2]; + + nodeoffset = fdt_path_offset (fdt, "/" OF_SOC "/pci@8500"); + if (nodeoffset >= 0) { + tmp[0] = cpu_to_be32(hose[0].first_busno); + tmp[1] = cpu_to_be32(hose[0].last_busno); + err = fdt_setprop(fdt, nodeoffset, "bus-range", tmp, sizeof(tmp)); + } +} +#endif /* CONFIG_OF_LIBFDT */ #ifdef CONFIG_OF_FLAT_TREE void ft_pci_setup(void *blob, bd_t *bd) diff --git a/common/Makefile b/common/Makefile index 6f81c4a..74a6af2 100644 --- a/common/Makefile +++ b/common/Makefile @@ -32,7 +32,7 @@ COBJS = main.o ACEX1K.o altera.o bedbug.o circbuf.o cmd_autoscript.o \ cmd_cache.o cmd_console.o \ cmd_date.o cmd_dcr.o cmd_diag.o cmd_display.o cmd_doc.o cmd_dtt.o \ cmd_eeprom.o cmd_elf.o cmd_ext2.o \ - cmd_fat.o cmd_fdc.o cmd_fdos.o cmd_flash.o cmd_fpga.o \ + cmd_fat.o cmd_fdc.o cmd_fdt.o cmd_fdos.o cmd_flash.o cmd_fpga.o \ cmd_i2c.o cmd_ide.o cmd_immap.o cmd_itest.o cmd_jffs2.o \ cmd_load.o cmd_log.o \ cmd_mem.o cmd_mii.o cmd_misc.o cmd_mmc.o \ diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index c0ed076..ab8648f 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -34,7 +34,11 @@ #include <environment.h> #include <asm/byteorder.h>
-#ifdef CONFIG_OF_FLAT_TREE +#if defined(CONFIG_OF_LIBFDT) +#include <fdt.h> +#include <libfdt.h> +#endif +#if defined(CONFIG_OF_FLAT_TREE) #include <ft_build.h> #endif
@@ -467,7 +471,7 @@ U_BOOT_CMD( "[addr [arg ...]]\n - boot application image stored in memory\n" "\tpassing arguments 'arg ...'; when booting a Linux kernel,\n" "\t'arg' can be the address of an initrd image\n" -#ifdef CONFIG_OF_FLAT_TREE +#if defined(CONFIG_OF_FLAT_TREE) || defined(CONFIG_OF_LIBFDT) "\tWhen booting a Linux kernel which requires a flat device-tree\n" "\ta third argument is required which is the address of the of the\n" "\tdevice-tree blob. To boot that kernel without an initrd image,\n" @@ -529,7 +533,7 @@ do_bootm_linux (cmd_tbl_t *cmdtp, int flag, bd_t *kbd; void (*kernel)(bd_t *, ulong, ulong, ulong, ulong); image_header_t *hdr = &header; -#ifdef CONFIG_OF_FLAT_TREE +#if defined(CONFIG_OF_FLAT_TREE) || defined(CONFIG_OF_LIBFDT) char *of_flat_tree = NULL; ulong of_data = 0; #endif @@ -622,7 +626,7 @@ do_bootm_linux (cmd_tbl_t *cmdtp, int flag, * Check if there is an initrd image */
-#ifdef CONFIG_OF_FLAT_TREE +#if defined(CONFIG_OF_FLAT_TREE) || defined(CONFIG_OF_LIBFDT) /* Look for a '-' which indicates to ignore the ramdisk argument */ if (argc >= 3 && strcmp(argv[2], "-") == 0) { debug ("Skipping initrd\n"); @@ -739,12 +743,15 @@ do_bootm_linux (cmd_tbl_t *cmdtp, int flag, len = data = 0; }
-#ifdef CONFIG_OF_FLAT_TREE +#if defined(CONFIG_OF_FLAT_TREE) || defined(CONFIG_OF_LIBFDT) if(argc > 3) { of_flat_tree = (char *) simple_strtoul(argv[3], NULL, 16); hdr = (image_header_t *)of_flat_tree; - - if (*(ulong *)of_flat_tree == OF_DT_HEADER) { +#if defined(CONFIG_OF_LIBFDT) + if (be32_to_cpu(fdt_magic(of_flat_tree)) == FDT_MAGIC) { +#else + if (*(ulong *)of_flat_tree == OF_DT_HEADER) { +#endif #ifndef CFG_NO_FLASH if (addr2info((ulong)of_flat_tree) != NULL) of_data = (ulong)of_flat_tree; @@ -787,7 +794,11 @@ do_bootm_linux (cmd_tbl_t *cmdtp, int flag, printf("ERROR: uImage is not uncompressed\n"); return; } +#if defined(CONFIG_OF_LIBFDT) + if (be32_to_cpu(fdt_magic(of_flat_tree + sizeof(image_header_t))) != FDT_MAGIC) { +#else if (*((ulong *)(of_flat_tree + sizeof(image_header_t))) != OF_DT_HEADER) { +#endif printf ("ERROR: uImage data is not a flat device tree\n"); return; } @@ -824,12 +835,20 @@ do_bootm_linux (cmd_tbl_t *cmdtp, int flag, of_data += 4 - tail; }
+#if defined(CONFIG_OF_LIBFDT) + if (be32_to_cpu(fdt_magic(of_data)) != FDT_MAGIC) { +#else if (((struct boot_param_header *)of_data)->magic != OF_DT_HEADER) { +#endif printf ("ERROR: image is not a flat device tree\n"); return; }
+#if defined(CONFIG_OF_LIBFDT) + if (be32_to_cpu(fdt_totalsize(of_data)) != ntohl(len_ptr[2])) { +#else if (((struct boot_param_header *)of_data)->totalsize != ntohl(len_ptr[2])) { +#endif printf ("ERROR: flat device tree size does not agree with image\n"); return; } @@ -913,7 +932,31 @@ do_bootm_linux (cmd_tbl_t *cmdtp, int flag, unlock_ram_in_cache(); #endif
-#ifdef CONFIG_OF_FLAT_TREE +#if defined(CONFIG_OF_LIBFDT) + /* move of_flat_tree if needed */ + if (of_data) { + int err; + ulong of_start, of_len; + of_len = be32_to_cpu(fdt_totalsize(of_data)); + /* provide extra 8k pad */ + if (initrd_start) + of_start = initrd_start - of_len - 8192; + else + of_start = (ulong)kbd - of_len - 8192; + of_start &= ~(4096 - 1); /* align on page */ + debug ("## device tree at 0x%08lX ... 0x%08lX (len=%ld=0x%lX)\n", + of_data, of_data + of_len - 1, of_len, of_len); + + + printf (" Loading Device Tree to %08lx, end %08lx ... ", + of_start, of_start + of_len - 1); + err = fdt_open_into(of_start, of_data, of_len); + if (err != 0) { + printf ("libfdt: %s\n", fdt_strerror(err)); + } + } +#endif +#if defined(CONFIG_OF_FLAT_TREE) /* move of_flat_tree if needed */ if (of_data) { ulong of_start, of_len; @@ -942,13 +985,13 @@ do_bootm_linux (cmd_tbl_t *cmdtp, int flag, * r6: Start of command line string * r7: End of command line string */ -#ifdef CONFIG_OF_FLAT_TREE +#if defined(CONFIG_OF_FLAT_TREE) || defined(CONFIG_OF_LIBFDT) if (!of_flat_tree) /* no device tree; boot old style */ #endif (*kernel) (kbd, initrd_start, initrd_end, cmd_start, cmd_end); /* does not return */
-#ifdef CONFIG_OF_FLAT_TREE +#if defined(CONFIG_OF_FLAT_TREE) || defined(CONFIG_OF_LIBFDT) /* * Linux Kernel Parameters (passing device tree): * r3: ptr to OF flat tree, followed by the board info data @@ -957,8 +1000,10 @@ do_bootm_linux (cmd_tbl_t *cmdtp, int flag, * r6: NULL * r7: NULL */ +#if defined(CONFIG_OF_FLAT_TREE) ft_setup(of_flat_tree, kbd, initrd_start, initrd_end); /* ft_dump_blob(of_flat_tree); */ +#endif
(*kernel) ((bd_t *)of_flat_tree, (ulong)kernel, 0, 0, 0); #endif diff --git a/cpu/mpc83xx/cpu.c b/cpu/mpc83xx/cpu.c index e4bc405..851241a 100644 --- a/cpu/mpc83xx/cpu.c +++ b/cpu/mpc83xx/cpu.c @@ -30,8 +30,14 @@ #include <watchdog.h> #include <command.h> #include <mpc83xx.h> -#include <ft_build.h> #include <asm/processor.h> +#if defined(CONFIG_OF_FLAT_TREE) +#include <ft_build.h> +#endif +#if defined(CONFIG_OF_LIBFDT) +#include <libfdt.h> +#include <libfdt_env.h> +#endif
DECLARE_GLOBAL_DATA_PTR;
@@ -291,6 +297,100 @@ void watchdog_reset (void) } #endif
+#if defined(CONFIG_OF_LIBFDT) + +/* + * Fixups to the fdt. If "create" is TRUE, the node is created + * unconditionally. If "create" is FALSE, the node is updated + * only if it already exists. + */ +#define FT_UPDATE 0x00000000 /* update existing property only */ +#define FT_CREATE 0x00000001 /* create property if it doesn't exist */ +#define FT_BUSFREQ 0x00000002 /* source is bd->bi_busfreq */ +#define FT_ENETADDR 0x00000004 /* source is bd->bi_enetaddr */ +static const struct { + int createflags; + char *node; + char *prop; +} fixup_props[] = { + { FT_CREATE | FT_BUSFREQ, + "/cpus/" OF_CPU, + "bus-frequency", + }, + { FT_CREATE | FT_BUSFREQ, + "/cpus/" OF_SOC, + "bus-frequency" + }, + { FT_CREATE | FT_BUSFREQ, + "/" OF_SOC "/serial@4500/", + "clock-frequency" + }, + { FT_CREATE | FT_BUSFREQ, + "/" OF_SOC "/serial@4600/", + "clock-frequency" + }, +#ifdef CONFIG_MPC83XX_TSEC1 + { FT_UPDATE | FT_ENETADDR, + "/" OF_SOC "/ethernet@24000, + "mac-address", + }, + { FT_UPDATE | FT_ENETADDR, + "/" OF_SOC "/ethernet@24000, + "local-mac-address", + }, +#endif +#ifdef CONFIG_MPC83XX_TSEC2 + { FT_UPDATE | FT_ENETADDR, + "/" OF_SOC "/ethernet@25000, + "mac-address", + }, + { FT_UPDATE | FT_ENETADDR, + "/" OF_SOC "/ethernet@25000, + "local-mac-address", + }, +#endif +}; + +void +ft_cpu_setup(void *blob, bd_t *bd) +{ + int nodeoffset; + int err; + int j; + + for (j = 0; j < (sizeof(fixup_props) / sizeof(fixup_props[0])); j++) { + nodeoffset = fdt_path_offset (fdt, fixup_props[j].node); + if (nodeoffset >= 0) { + /* + * If unconditional create or the property already exists... + */ + if ((fixup_props[j].createflags & FT_CREATE) || + (fdt_get_property(fdt, nodeoffset, fixup_props[j].prop, 0))) { + if (fixup_props[j].createflags & FT_BUSFREQ) { + u32 tmp; + + tmp = cpu_to_be32(bd->bi_busfreq); + err = fdt_setprop(fdt, nodeoffset, + fixup_props[j].prop, &tmp, sizeof(tmp)); + } else if (fixup_props[j].createflags & FT_ENETADDR) { + err = fdt_setprop(fdt, nodeoffset, + fixup_props[j].prop, bd->bi_enetaddr, 6); + } else { + printf("ft_cpu_setup: %s %s has no flag for the value to set\n", + fixup_props[j].node, + fixup_props[j].prop); + } + if (err < 0) + printf("libfdt: %s %s returned %s\n", + fixup_props[j].node, + fixup_props[j].prop, + fdt_strerror(err)); + } + } + } +} +#endif + #if defined(CONFIG_OF_FLAT_TREE) void ft_cpu_setup(void *blob, bd_t *bd) diff --git a/include/configs/MPC8360EMDS.h b/include/configs/MPC8360EMDS.h index d2af0e1..79937dc 100644 --- a/include/configs/MPC8360EMDS.h +++ b/include/configs/MPC8360EMDS.h @@ -342,8 +342,12 @@ #endif
/* pass open firmware flat tree */ -#define CONFIG_OF_FLAT_TREE 1 +#define CONFIG_OF_LIBFDT 1 +#undef CONFIG_OF_FLAT_TREE #define CONFIG_OF_BOARD_SETUP 1 +#define CONFIG_OF_HAS_BD_T 1 +#define CONFIG_OF_HAS_UBOOT_ENV 1 +
/* maximum size of the flat tree (8K) */ #define OF_FLAT_TREE_MAX_SIZE 8192
I found a couple of whitespace violations, the patch following this email applies on top of the fdt cmd patches 1-6 to fix them.
Sorry, gvb
Jerry Van Baren
