[PATCH v5] board: rockchip: add Radxa ROCK 3 Model C
Based on rock-3a-rk3568_defconfig. Tested on v1.31 revision.
Board Specifications: - Rockchip RK3566 - 1/2/4GB LPDDR4 2112MT/s - eMMC socket - uSD card slot - M.2 2230 Connector - GbE LAN with POE - 3.5mm jack with mic - HDMI 2.0, MIPI DSI/CSI - USB 3.0 Host, USB 2.0 Host/OTG - 40-pin GPIO expansion ports
Signed-off-by: Maxim Moskalets maximmosk4@gmail.com Suggested-by: Jonas Karlman jonas@kwiboo.se Reviewed-by: Jonas Karlman jonas@kwiboo.se --- v5: fixed board info v4: fixed typo in commit-msg moved maintainers record to file for rk3568 boards renamed from ROCK 3 Model C to ROCK3C v3: add suggested by Jonas Karlman jonas@kwiboo.se in https://lore.kernel.org/all/bbb81dd1-e318-423d-8258-db7556ce6850@kwiboo.se/ v2: rebase to updated upstream dts --- arch/arm/dts/rk3566-rock-3c-u-boot.dtsi | 10 +++ board/rockchip/evb_rk3568/MAINTAINERS | 7 ++ configs/rock-3c-rk3566_defconfig | 97 +++++++++++++++++++++++++ doc/board/rockchip/rockchip.rst | 1 + 4 files changed, 115 insertions(+) create mode 100644 arch/arm/dts/rk3566-rock-3c-u-boot.dtsi create mode 100644 configs/rock-3c-rk3566_defconfig
diff --git a/arch/arm/dts/rk3566-rock-3c-u-boot.dtsi b/arch/arm/dts/rk3566-rock-3c-u-boot.dtsi new file mode 100644 index 00000000000..fd7f5367b75 --- /dev/null +++ b/arch/arm/dts/rk3566-rock-3c-u-boot.dtsi @@ -0,0 +1,10 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +#include "rk356x-u-boot.dtsi" + +&sfc { + flash@0 { + bootph-pre-ram; + bootph-some-ram; + }; +}; diff --git a/board/rockchip/evb_rk3568/MAINTAINERS b/board/rockchip/evb_rk3568/MAINTAINERS index e5b0986ead9..ba4884db8e1 100644 --- a/board/rockchip/evb_rk3568/MAINTAINERS +++ b/board/rockchip/evb_rk3568/MAINTAINERS @@ -69,3 +69,10 @@ S: Maintained F: configs/rock-3a-rk3568_defconfig F: arch/arm/dts/rk3568-rock-3a.dts F: arch/arm/dts/rk3568-rock-3a-u-boot.dtsi + +ROCK-3C +M: Jonas Karlman jonas@kwiboo.se +M: Maxim Moskalets maximmosk4@gmail.com +S: Maintained +F: arch/arm/dts/rk3566-rock-3c-u-boot.dtsi +F: configs/rock-3c-rk3566_defconfig diff --git a/configs/rock-3c-rk3566_defconfig b/configs/rock-3c-rk3566_defconfig new file mode 100644 index 00000000000..f44b202c8c3 --- /dev/null +++ b/configs/rock-3c-rk3566_defconfig @@ -0,0 +1,97 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SF_DEFAULT_SPEED=24000000 +CONFIG_SF_DEFAULT_MODE=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3566-rock-3c" +CONFIG_ROCKCHIP_RK3568=y +CONFIG_ROCKCHIP_SPI_IMAGE=y +CONFIG_SPL_SERIAL=y +CONFIG_DEBUG_UART_BASE=0xFE660000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI=y +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_PCI=y +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3566-rock-3c.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x60000 +CONFIG_SPL_ATF=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_POWEROFF=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_SCSI_AHCI=y +CONFIG_AHCI_PCI=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_LED=y +CONFIG_LED_GPIO=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_SF_DEFAULT_BUS=4 +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_XTX=y +CONFIG_PHY_REALTEK=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y +CONFIG_NVME_PCI=y +CONFIG_PCIE_DW_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y +CONFIG_SPL_PINCTRL=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_SPL_RAM=y +CONFIG_SCSI=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_ROCKCHIP_SFC=y +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_ERRNO_STR=y diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index bedc52e03e2..60357af6caa 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -105,6 +105,7 @@ List of mainline supported Rockchip boards: - Pine64 SOQuartz on Model A (soquartz-model-a-rk3566) - Powkiddy X55 (powkiddy-x55-rk3566) - Radxa CM3 IO Board (radxa-cm3-io-rk3566) + - Radxa ROCK 3C (rock-3c-rk3566)
* rk3568 - Rockchip Evb-RK3568 (evb-rk3568)
- Rockchip RK3566
- eMMC socket
- uSD card slot
- GbE LAN with POE
please add
``` / { leds { led-0 { default-state = "on"; }; }; }; ```
to turn LED on at U-Boot. (make CONFIG_LED_GPIO work)
-- FUKAUMI Naoki Radxa Computer (Shenzhen) Co., Ltd.
+&sfc {
- flash@0 {
bootph-pre-ram;
bootph-some-ram;
- rk3568
FUKAUMI Naoki
Maxim Moskalets
