[U-Boot] [PATCH 0/5] *** SUBJECT HERE ***
The below patches introduce aardvark pcie driver and enable pcie for Armada 37xx.
Ken Ma (1): arm64: a37xx: defconfigs: enable PCI_CMD and E1000 driver
Wilson Ding (4): arm64: a37xx: populate pcie memory region arm64: a37xx: pci: add support for aardvark pcie driver arm64: a37xx: defconfigs: enable aardvark pcie driver arm64: a37xx: dts: enable pcie port
arch/arm/dts/armada-3720-db.dts | 8 + arch/arm/dts/armada-3720-espressobin.dts | 7 + arch/arm/dts/armada-37xx.dtsi | 16 + arch/arm/mach-mvebu/armada3700/cpu.c | 8 + configs/mvebu_db-88f3720_defconfig | 5 + configs/mvebu_espressobin-88f3720_defconfig | 5 + drivers/pci/Kconfig | 10 + drivers/pci/Makefile | 1 + drivers/pci/pci-aardvark.c | 690 ++++++++++++++++++++++++++++ 9 files changed, 750 insertions(+) create mode 100644 drivers/pci/pci-aardvark.c
This patch added a new region of 32MiB AT 0xe800.0000 to Armada37x0's memory map. This region is supposed to be mapped in MMU in order to enable the access to the PCI I/O or MEM resources.
Signed-off-by: Wilson Ding dingwei@marvell.com Reviewed-on: http://vgitil04.il.marvell.com:8080/38724 Tested-by: iSoC Platform CI ykjenk@marvell.com Reviewed-by: Victor Gu xigu@marvell.com Signed-off-by: Ken Ma make@marvell.com Cc: Simon Glass sjg@chromium.org Cc: Stefan Roese sr@denx.de --- arch/arm/mach-mvebu/armada3700/cpu.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/arch/arm/mach-mvebu/armada3700/cpu.c b/arch/arm/mach-mvebu/armada3700/cpu.c index 6499eec..cfe4469 100644 --- a/arch/arm/mach-mvebu/armada3700/cpu.c +++ b/arch/arm/mach-mvebu/armada3700/cpu.c @@ -46,6 +46,14 @@ static struct mm_region mvebu_mem_map[] = { PTE_BLOCK_NON_SHARE }, { + /* PCI regions */ + .phys = 0xe8000000UL, + .virt = 0xe8000000UL, + .size = 0x02000000UL, /* 32MiB master PCI space */ + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE + }, + { /* List terminator */ 0, }
/* PCI regions */
PTE_BLOCK_NON_SHARE
- { /* List terminator */ 0, }
Complete series applied to u-boot-marvell/master.
Thanks, Stefan
This patch introduced the Aardvark PCIe driver based driver model. The PCIe driver is supposed to work in Root Complex mode. It only supports X1 lane width.
Signed-off-by: Wilson Ding dingwei@marvell.com Reviewed-on: http://vgitil04.il.marvell.com:8080/38725 Reviewed-by: Victor Gu xigu@marvell.com Reviewed-by: Hua Jing jinghua@marvell.com Tested-by: Hua Jing jinghua@marvell.com Cc: Simon Glass sjg@chromium.org Cc: Stefan Roese sr@denx.de Signed-off-by: Ken Ma make@marvell.com --- drivers/pci/Kconfig | 10 + drivers/pci/Makefile | 1 + drivers/pci/pci-aardvark.c | 690 +++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 701 insertions(+) create mode 100644 drivers/pci/pci-aardvark.c
diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index da6421f..c20a0cc 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -26,6 +26,16 @@ config DM_PCI_COMPAT measure when porting a board to use driver model for PCI. Once the board is fully supported, this option should be disabled.
+config PCI_AARDVARK + bool "Enable Aardvark PCIe driver" + default n + depends on DM_PCI + depends on ARMADA_3700 + help + Say Y here if you want to enable PCIe controller support on + Armada37x0 SoCs. The PCIe controller on Armada37x0 is based on + Aardvark hardware. + config PCI_PNP bool "Enable Plug & Play support for PCI" depends on PCI || DM_PCI diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index 8fbab46..40ebc06 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -30,6 +30,7 @@ obj-$(CONFIG_SH4_PCI) += pci_sh4.o obj-$(CONFIG_SH7751_PCI) +=pci_sh7751.o obj-$(CONFIG_SH7780_PCI) +=pci_sh7780.o obj-$(CONFIG_PCI_TEGRA) += pci_tegra.o +obj-$(CONFIG_PCI_AARDVARK) += pci-aardvark.o obj-$(CONFIG_PCIE_DW_MVEBU) += pcie_dw_mvebu.o obj-$(CONFIG_PCIE_LAYERSCAPE) += pcie_layerscape.o obj-$(CONFIG_PCIE_LAYERSCAPE) += pcie_layerscape_fixup.o diff --git a/drivers/pci/pci-aardvark.c b/drivers/pci/pci-aardvark.c new file mode 100644 index 0000000..69a4d81 --- /dev/null +++ b/drivers/pci/pci-aardvark.c @@ -0,0 +1,690 @@ +/* + * *************************************************************************** + * Copyright (C) 2015 Marvell International Ltd. + * *************************************************************************** + * This program is free software: you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the Free + * Software Foundation, either version 2 of the License, or any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + * *************************************************************************** + */ +/* pcie_advk.c + * + * Ported from Linux driver - driver/pci/host/pci-aardvark.c + * + * Author: Victor Gu xigu@marvell.com + * Hezi Shahmoon hezi.shahmoon@marvell.com + * + */ + +#include <common.h> +#include <dm.h> +#include <pci.h> +#include <asm/io.h> +#include <asm-generic/gpio.h> +#include <linux/ioport.h> + +/* PCIe core registers */ +#define PCIE_CORE_CMD_STATUS_REG 0x4 +#define PCIE_CORE_CMD_IO_ACCESS_EN BIT(0) +#define PCIE_CORE_CMD_MEM_ACCESS_EN BIT(1) +#define PCIE_CORE_CMD_MEM_IO_REQ_EN BIT(2) +#define PCIE_CORE_DEV_CTRL_STATS_REG 0xc8 +#define PCIE_CORE_DEV_CTRL_STATS_RELAX_ORDER_DISABLE (0 << 4) +#define PCIE_CORE_DEV_CTRL_STATS_SNOOP_DISABLE (0 << 11) +#define PCIE_CORE_LINK_CTRL_STAT_REG 0xd0 +#define PCIE_CORE_LINK_TRAINING BIT(5) +#define PCIE_CORE_ERR_CAPCTL_REG 0x118 +#define PCIE_CORE_ERR_CAPCTL_ECRC_CHK_TX BIT(5) +#define PCIE_CORE_ERR_CAPCTL_ECRC_CHK_TX_EN BIT(6) +#define PCIE_CORE_ERR_CAPCTL_ECRC_CHECK BIT(7) +#define PCIE_CORE_ERR_CAPCTL_ECRC_CHECK_RCV BIT(8) + +/* PIO registers base address and register offsets */ +#define PIO_BASE_ADDR 0x4000 +#define PIO_CTRL (PIO_BASE_ADDR + 0x0) +#define PIO_CTRL_TYPE_MASK GENMASK(3, 0) +#define PIO_CTRL_ADDR_WIN_DISABLE BIT(24) +#define PIO_STAT (PIO_BASE_ADDR + 0x4) +#define PIO_COMPLETION_STATUS_SHIFT 7 +#define PIO_COMPLETION_STATUS_MASK GENMASK(9, 7) +#define PIO_COMPLETION_STATUS_OK 0 +#define PIO_COMPLETION_STATUS_UR 1 +#define PIO_COMPLETION_STATUS_CRS 2 +#define PIO_COMPLETION_STATUS_CA 4 +#define PIO_NON_POSTED_REQ BIT(10) +#define PIO_ERR_STATUS BIT(11) +#define PIO_ADDR_LS (PIO_BASE_ADDR + 0x8) +#define PIO_ADDR_MS (PIO_BASE_ADDR + 0xc) +#define PIO_WR_DATA (PIO_BASE_ADDR + 0x10) +#define PIO_WR_DATA_STRB (PIO_BASE_ADDR + 0x14) +#define PIO_RD_DATA (PIO_BASE_ADDR + 0x18) +#define PIO_START (PIO_BASE_ADDR + 0x1c) +#define PIO_ISR (PIO_BASE_ADDR + 0x20) + +/* Aardvark Control registers */ +#define CONTROL_BASE_ADDR 0x4800 +#define PCIE_CORE_CTRL0_REG (CONTROL_BASE_ADDR + 0x0) +#define PCIE_GEN_SEL_MSK 0x3 +#define PCIE_GEN_SEL_SHIFT 0x0 +#define SPEED_GEN_1 0 +#define SPEED_GEN_2 1 +#define SPEED_GEN_3 2 +#define IS_RC_MSK 1 +#define IS_RC_SHIFT 2 +#define LANE_CNT_MSK 0x18 +#define LANE_CNT_SHIFT 0x3 +#define LANE_COUNT_1 (0 << LANE_CNT_SHIFT) +#define LANE_COUNT_2 (1 << LANE_CNT_SHIFT) +#define LANE_COUNT_4 (2 << LANE_CNT_SHIFT) +#define LANE_COUNT_8 (3 << LANE_CNT_SHIFT) +#define LINK_TRAINING_EN BIT(6) +#define PCIE_CORE_CTRL2_REG (CONTROL_BASE_ADDR + 0x8) +#define PCIE_CORE_CTRL2_RESERVED 0x7 +#define PCIE_CORE_CTRL2_TD_ENABLE BIT(4) +#define PCIE_CORE_CTRL2_STRICT_ORDER_ENABLE BIT(5) +#define PCIE_CORE_CTRL2_ADDRWIN_MAP_ENABLE BIT(6) + +/* LMI registers base address and register offsets */ +#define LMI_BASE_ADDR 0x6000 +#define CFG_REG (LMI_BASE_ADDR + 0x0) +#define LTSSM_SHIFT 24 +#define LTSSM_MASK 0x3f +#define LTSSM_L0 0x10 + +/* PCIe core controller registers */ +#define CTRL_CORE_BASE_ADDR 0x18000 +#define CTRL_CONFIG_REG (CTRL_CORE_BASE_ADDR + 0x0) +#define CTRL_MODE_SHIFT 0x0 +#define CTRL_MODE_MASK 0x1 +#define PCIE_CORE_MODE_DIRECT 0x0 +#define PCIE_CORE_MODE_COMMAND 0x1 + +/* Transaction types */ +#define PCIE_CONFIG_RD_TYPE0 0x8 +#define PCIE_CONFIG_RD_TYPE1 0x9 +#define PCIE_CONFIG_WR_TYPE0 0xa +#define PCIE_CONFIG_WR_TYPE1 0xb + +/* PCI_BDF shifts 8bit, so we need extra 4bit shift */ +#define PCIE_BDF(dev) (dev << 4) +#define PCIE_CONF_BUS(bus) (((bus) & 0xff) << 20) +#define PCIE_CONF_DEV(dev) (((dev) & 0x1f) << 15) +#define PCIE_CONF_FUNC(fun) (((fun) & 0x7) << 12) +#define PCIE_CONF_REG(reg) ((reg) & 0xffc) +#define PCIE_CONF_ADDR(bus, devfn, where) \ + (PCIE_CONF_BUS(bus) | PCIE_CONF_DEV(PCI_SLOT(devfn)) | \ + PCIE_CONF_FUNC(PCI_FUNC(devfn)) | PCIE_CONF_REG(where)) + +/* PCIe Retries & Timeout definitions */ +#define MAX_RETRIES 10 +#define PIO_WAIT_TIMEOUT 100 +#define LINK_WAIT_TIMEOUT 100000 + +#define CFG_RD_UR_VAL 0xFFFFFFFF +#define CFG_RD_CRS_VAL 0xFFFF0001 + +DECLARE_GLOBAL_DATA_PTR; + +/** + * struct pcie_advk - Advk PCIe controller state + * + * @reg_base: The base address of the register space. + * @first_busno: This driver supports multiple PCIe controllers. + * first_busno stores the bus number of the PCIe root-port + * number which may vary depending on the PCIe setup + * (PEX switches etc). + * @device: The pointer to PCI uclass device. + */ +struct pcie_advk { + void *base; + int first_busno; + struct udevice *dev; +}; + +static inline void advk_writel(struct pcie_advk *pcie, uint val, uint reg) +{ + writel(val, pcie->base + reg); +} + +static inline uint advk_readl(struct pcie_advk *pcie, uint reg) +{ + return readl(pcie->base + reg); +} + +/** + * pcie_advk_addr_valid() - Check for valid bus address + * + * @bdf: The PCI device to access + * @first_busno: Bus number of the PCIe controller root complex + * + * Return: 1 on valid, 0 on invalid + */ +static int pcie_advk_addr_valid(pci_dev_t bdf, int first_busno) +{ + /* + * In PCIE-E only a single device (0) can exist + * on the local bus. Beyound the local bus, there might be + * a Switch and everything is possible. + */ + if ((PCI_BUS(bdf) == first_busno) && (PCI_DEV(bdf) > 0)) + return 0; + + return 1; +} + +/** + * pcie_advk_wait_pio() - Wait for PIO access to be accomplished + * + * @pcie: The PCI device to access + * + * Wait up to 1 micro second for PIO access to be accomplished. + * + * Return 1 (true) if PIO access is accomplished. + * Return 0 (false) if PIO access is timed out. + */ +static int pcie_advk_wait_pio(struct pcie_advk *pcie) +{ + uint start, isr; + uint count; + + for (count = 0; count < MAX_RETRIES; count++) { + start = advk_readl(pcie, PIO_START); + isr = advk_readl(pcie, PIO_ISR); + if (!start && isr) + return 1; + /* + * Do not check the PIO state too frequently, + * 100us delay is appropriate. + */ + udelay(PIO_WAIT_TIMEOUT); + } + + dev_err(pcie->dev, "config read/write timed out\n"); + return 0; +} + +/** + * pcie_advk_check_pio_status() - Validate PIO status and get the read result + * + * @pcie: Pointer to the PCI bus + * @read: Read from or write to configuration space - true(read) false(write) + * @read_val: Pointer to the read result, only valid when read is true + * + */ +static int pcie_advk_check_pio_status(struct pcie_advk *pcie, + bool read, + uint *read_val) +{ + uint reg; + unsigned int status; + char *strcomp_status, *str_posted; + + reg = advk_readl(pcie, PIO_STAT); + status = (reg & PIO_COMPLETION_STATUS_MASK) >> + PIO_COMPLETION_STATUS_SHIFT; + + switch (status) { + case PIO_COMPLETION_STATUS_OK: + if (reg & PIO_ERR_STATUS) { + strcomp_status = "COMP_ERR"; + break; + } + /* Get the read result */ + if (read) + *read_val = advk_readl(pcie, PIO_RD_DATA); + /* No error */ + strcomp_status = NULL; + break; + case PIO_COMPLETION_STATUS_UR: + if (read) { + /* For reading, UR is not an error status. */ + *read_val = CFG_RD_UR_VAL; + strcomp_status = NULL; + } else { + strcomp_status = "UR"; + } + break; + case PIO_COMPLETION_STATUS_CRS: + if (read) { + /* For reading, CRS is not an error status. */ + *read_val = CFG_RD_CRS_VAL; + strcomp_status = NULL; + } else { + strcomp_status = "CRS"; + } + break; + case PIO_COMPLETION_STATUS_CA: + strcomp_status = "CA"; + break; + default: + strcomp_status = "Unknown"; + break; + } + + if (!strcomp_status) + return 0; + + if (reg & PIO_NON_POSTED_REQ) + str_posted = "Non-posted"; + else + str_posted = "Posted"; + + dev_err(pcie->dev, "%s PIO Response Status: %s, %#x @ %#x\n", + str_posted, strcomp_status, reg, + advk_readl(pcie, PIO_ADDR_LS)); + + return -EFAULT; +} + +/** + * pcie_advk_read_config() - Read from configuration space + * + * @bus: Pointer to the PCI bus + * @bdf: Identifies the PCIe device to access + * @offset: The offset into the device's configuration space + * @valuep: A pointer at which to store the read value + * @size: Indicates the size of access to perform + * + * Read a value of size @size from offset @offset within the configuration + * space of the device identified by the bus, device & function numbers in @bdf + * on the PCI bus @bus. + * + * Return: 0 on success + */ +static int pcie_advk_read_config(struct udevice *bus, pci_dev_t bdf, + uint offset, ulong *valuep, + enum pci_size_t size) +{ + struct pcie_advk *pcie = dev_get_priv(bus); + uint reg; + int ret; + + dev_dbg(pcie->dev, "PCIE CFG read: (b,d,f)=(%2d,%2d,%2d) ", + PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf)); + + if (!pcie_advk_addr_valid(bdf, pcie->first_busno)) { + dev_dbg(pcie->dev, "- out of range\n"); + *valuep = pci_get_ff(size); + return 0; + } + + /* Start PIO */ + advk_writel(pcie, 0, PIO_START); + advk_writel(pcie, 1, PIO_ISR); + + /* Program the control register */ + reg = advk_readl(pcie, PIO_CTRL); + reg &= ~PIO_CTRL_TYPE_MASK; + if (PCI_BUS(bdf) == pcie->first_busno) + reg |= PCIE_CONFIG_RD_TYPE0; + else + reg |= PCIE_CONFIG_RD_TYPE1; + advk_writel(pcie, reg, PIO_CTRL); + + /* Program the address registers */ + reg = PCIE_BDF(bdf) | PCIE_CONF_REG(offset); + advk_writel(pcie, reg, PIO_ADDR_LS); + advk_writel(pcie, 0, PIO_ADDR_MS); + + /* Start the transfer */ + advk_writel(pcie, 1, PIO_START); + + if (!pcie_advk_wait_pio(pcie)) + return -EINVAL; + + /* Check PIO status and get the read result */ + ret = pcie_advk_check_pio_status(pcie, true, ®); + if (ret) + return ret; + + dev_dbg(pcie->dev, "(addr,size,val)=(0x%04x, %d, 0x%08x)\n", + offset, size, reg); + *valuep = pci_conv_32_to_size(reg, offset, size); + + return 0; +} + +/** + * pcie_calc_datastrobe() - Calculate data strobe + * + * @offset: The offset into the device's configuration space + * @size: Indicates the size of access to perform + * + * Calculate data strobe according to offset and size + * + */ +static uint pcie_calc_datastrobe(uint offset, enum pci_size_t size) +{ + uint bytes, data_strobe; + + switch (size) { + case PCI_SIZE_8: + bytes = 1; + break; + case PCI_SIZE_16: + bytes = 2; + break; + default: + bytes = 4; + } + + data_strobe = GENMASK(bytes - 1, 0) << (offset & 0x3); + + return data_strobe; +} + +/** + * pcie_advk_write_config() - Write to configuration space + * + * @bus: Pointer to the PCI bus + * @bdf: Identifies the PCIe device to access + * @offset: The offset into the device's configuration space + * @value: The value to write + * @size: Indicates the size of access to perform + * + * Write the value @value of size @size from offset @offset within the + * configuration space of the device identified by the bus, device & function + * numbers in @bdf on the PCI bus @bus. + * + * Return: 0 on success + */ +static int pcie_advk_write_config(struct udevice *bus, pci_dev_t bdf, + uint offset, ulong value, + enum pci_size_t size) +{ + struct pcie_advk *pcie = dev_get_priv(bus); + uint reg; + + dev_dbg(pcie->dev, "PCIE CFG write: (b,d,f)=(%2d,%2d,%2d) ", + PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf)); + dev_dbg(pcie->dev, "(addr,size,val)=(0x%04x, %d, 0x%08lx)\n", + offset, size, value); + + if (!pcie_advk_addr_valid(bdf, pcie->first_busno)) { + dev_dbg(pcie->dev, "- out of range\n"); + return 0; + } + + /* Start PIO */ + advk_writel(pcie, 0, PIO_START); + advk_writel(pcie, 1, PIO_ISR); + + /* Program the control register */ + reg = advk_readl(pcie, PIO_CTRL); + reg &= ~PIO_CTRL_TYPE_MASK; + if (PCI_BUS(bdf) == pcie->first_busno) + reg |= PCIE_CONFIG_WR_TYPE0; + else + reg |= PCIE_CONFIG_WR_TYPE1; + advk_writel(pcie, reg, PIO_CTRL); + + /* Program the address registers */ + reg = PCIE_BDF(bdf) | PCIE_CONF_REG(offset); + advk_writel(pcie, reg, PIO_ADDR_LS); + advk_writel(pcie, 0, PIO_ADDR_MS); + dev_dbg(pcie->dev, "\tPIO req. - addr = 0x%08x\n", reg); + + /* Program the data register */ + reg = pci_conv_size_to_32(0, value, offset, size); + advk_writel(pcie, reg, PIO_WR_DATA); + dev_dbg(pcie->dev, "\tPIO req. - val = 0x%08x\n", reg); + + /* Program the data strobe */ + reg = pcie_calc_datastrobe(offset, size); + advk_writel(pcie, reg, PIO_WR_DATA_STRB); + dev_dbg(pcie->dev, "\tPIO req. - strb = 0x%02x\n", reg); + + /* Start the transfer */ + advk_writel(pcie, 1, PIO_START); + + if (!pcie_advk_wait_pio(pcie)) { + dev_dbg(pcie->dev, "- wait pio timeout\n"); + return -EINVAL; + } + + /* Check PIO status */ + pcie_advk_check_pio_status(pcie, false, ®); + + return 0; +} + +/** + * pcie_advk_link_up() - Check if PCIe link is up or not + * + * @pcie: The PCI device to access + * + * Return 1 (true) on link up. + * Return 0 (false) on link down. + */ +static int pcie_advk_link_up(struct pcie_advk *pcie) +{ + u32 val, ltssm_state; + + val = advk_readl(pcie, CFG_REG); + ltssm_state = (val >> LTSSM_SHIFT) & LTSSM_MASK; + return ltssm_state >= LTSSM_L0; +} + +/** + * pcie_advk_wait_for_link() - Wait for link training to be accomplished + * + * @pcie: The PCI device to access + * + * Wait up to 1 second for link training to be accomplished. + * + * Return 1 (true) if link training ends up with link up success. + * Return 0 (false) if link training ends up with link up failure. + */ +static int pcie_advk_wait_for_link(struct pcie_advk *pcie) +{ + int retries; + + /* check if the link is up or not */ + for (retries = 0; retries < MAX_RETRIES; retries++) { + if (pcie_advk_link_up(pcie)) { + printf("PCIE-%d: Link up\n", pcie->first_busno); + return 0; + } + + udelay(LINK_WAIT_TIMEOUT); + } + + printf("PCIE-%d: Link down\n", pcie->first_busno); + + return -ETIMEDOUT; +} + +/** + * pcie_advk_setup_hw() - PCIe initailzation + * + * @pcie: The PCI device to access + * + * Return: 0 on success + */ +static int pcie_advk_setup_hw(struct pcie_advk *pcie) +{ + u32 reg; + + /* Set to Direct mode */ + reg = advk_readl(pcie, CTRL_CONFIG_REG); + reg &= ~(CTRL_MODE_MASK << CTRL_MODE_SHIFT); + reg |= ((PCIE_CORE_MODE_DIRECT & CTRL_MODE_MASK) << CTRL_MODE_SHIFT); + advk_writel(pcie, reg, CTRL_CONFIG_REG); + + /* Set PCI global control register to RC mode */ + reg = advk_readl(pcie, PCIE_CORE_CTRL0_REG); + reg |= (IS_RC_MSK << IS_RC_SHIFT); + advk_writel(pcie, reg, PCIE_CORE_CTRL0_REG); + + /* Set Advanced Error Capabilities and Control PF0 register */ + reg = PCIE_CORE_ERR_CAPCTL_ECRC_CHK_TX | + PCIE_CORE_ERR_CAPCTL_ECRC_CHK_TX_EN | + PCIE_CORE_ERR_CAPCTL_ECRC_CHECK | + PCIE_CORE_ERR_CAPCTL_ECRC_CHECK_RCV; + advk_writel(pcie, reg, PCIE_CORE_ERR_CAPCTL_REG); + + /* Set PCIe Device Control and Status 1 PF0 register */ + reg = PCIE_CORE_DEV_CTRL_STATS_RELAX_ORDER_DISABLE | + PCIE_CORE_DEV_CTRL_STATS_SNOOP_DISABLE; + advk_writel(pcie, reg, PCIE_CORE_DEV_CTRL_STATS_REG); + + /* Program PCIe Control 2 to disable strict ordering */ + reg = PCIE_CORE_CTRL2_RESERVED | + PCIE_CORE_CTRL2_TD_ENABLE; + advk_writel(pcie, reg, PCIE_CORE_CTRL2_REG); + + /* Set GEN2 */ + reg = advk_readl(pcie, PCIE_CORE_CTRL0_REG); + reg &= ~PCIE_GEN_SEL_MSK; + reg |= SPEED_GEN_2; + advk_writel(pcie, reg, PCIE_CORE_CTRL0_REG); + + /* Set lane X1 */ + reg = advk_readl(pcie, PCIE_CORE_CTRL0_REG); + reg &= ~LANE_CNT_MSK; + reg |= LANE_COUNT_1; + advk_writel(pcie, reg, PCIE_CORE_CTRL0_REG); + + /* Enable link training */ + reg = advk_readl(pcie, PCIE_CORE_CTRL0_REG); + reg |= LINK_TRAINING_EN; + advk_writel(pcie, reg, PCIE_CORE_CTRL0_REG); + + /* + * Enable AXI address window location generation: + * When it is enabled, the default outbound window + * configurations (Default User Field: 0xD0074CFC) + * are used to transparent address translation for + * the outbound transactions. Thus, PCIe address + * windows are not required. + */ + reg = advk_readl(pcie, PCIE_CORE_CTRL2_REG); + reg |= PCIE_CORE_CTRL2_ADDRWIN_MAP_ENABLE; + advk_writel(pcie, reg, PCIE_CORE_CTRL2_REG); + + /* + * Bypass the address window mapping for PIO: + * Since PIO access already contains all required + * info over AXI interface by PIO registers, the + * address window is not required. + */ + reg = advk_readl(pcie, PIO_CTRL); + reg |= PIO_CTRL_ADDR_WIN_DISABLE; + advk_writel(pcie, reg, PIO_CTRL); + + /* Start link training */ + reg = advk_readl(pcie, PCIE_CORE_LINK_CTRL_STAT_REG); + reg |= PCIE_CORE_LINK_TRAINING; + advk_writel(pcie, reg, PCIE_CORE_LINK_CTRL_STAT_REG); + + /* Wait for PCIe link up */ + if (pcie_advk_wait_for_link(pcie)) + return -ENXIO; + + reg = advk_readl(pcie, PCIE_CORE_CMD_STATUS_REG); + reg |= PCIE_CORE_CMD_MEM_ACCESS_EN | + PCIE_CORE_CMD_IO_ACCESS_EN | + PCIE_CORE_CMD_MEM_IO_REQ_EN; + advk_writel(pcie, reg, PCIE_CORE_CMD_STATUS_REG); + + return 0; +} + +/** + * pcie_advk_probe() - Probe the PCIe bus for active link + * + * @dev: A pointer to the device being operated on + * + * Probe for an active link on the PCIe bus and configure the controller + * to enable this port. + * + * Return: 0 on success, else -ENODEV + */ +static int pcie_advk_probe(struct udevice *dev) +{ + struct pcie_advk *pcie = dev_get_priv(dev); + +#ifdef CONFIG_DM_GPIO + struct gpio_desc reset_gpio; + + gpio_request_by_name(dev, "reset-gpio", 0, &reset_gpio, + GPIOD_IS_OUT); + /* + * Issue reset to add-in card through the dedicated GPIO. + * Some boards are connecting the card reset pin to common system + * reset wire and others are using separate GPIO port. + * In the last case we have to release a reset of the addon card + * using this GPIO. + * + * FIX-ME: + * The PCIe RESET signal is not supposed to be released along + * with the SOC RESET signal. It should be lowered as early as + * possible before PCIe PHY initialization. Moreover, the PCIe + * clock should be gated as well. + */ + if (dm_gpio_is_valid(&reset_gpio)) { + dev_dbg(pcie->dev, "Toggle PCIE Reset GPIO ...\n"); + dm_gpio_set_value(&reset_gpio, 0); + mdelay(200); + dm_gpio_set_value(&reset_gpio, 1); + } +#else + dev_dbg(pcie->dev, "PCIE Reset on GPIO support is missing\n"); +#endif /* CONFIG_DM_GPIO */ + + pcie->first_busno = dev->seq; + pcie->dev = pci_get_controller(dev); + + return pcie_advk_setup_hw(pcie); +} + +/** + * pcie_advk_ofdata_to_platdata() - Translate from DT to device state + * + * @dev: A pointer to the device being operated on + * + * Translate relevant data from the device tree pertaining to device @dev into + * state that the driver will later make use of. This state is stored in the + * device's private data structure. + * + * Return: 0 on success, else -EINVAL + */ +static int pcie_advk_ofdata_to_platdata(struct udevice *dev) +{ + struct pcie_advk *pcie = dev_get_priv(dev); + + /* Get the register base address */ + pcie->base = (void *)dev_read_addr_index(dev, 0); + if ((fdt_addr_t)pcie->base == FDT_ADDR_T_NONE) + return -EINVAL; + + return 0; +} + +static const struct dm_pci_ops pcie_advk_ops = { + .read_config = pcie_advk_read_config, + .write_config = pcie_advk_write_config, +}; + +static const struct udevice_id pcie_advk_ids[] = { + { .compatible = "marvell,armada-37xx-pcie" }, + { } +}; + +U_BOOT_DRIVER(pcie_advk) = { + .name = "pcie_advk", + .id = UCLASS_PCI, + .of_match = pcie_advk_ids, + .ops = &pcie_advk_ops, + .ofdata_to_platdata = pcie_advk_ofdata_to_platdata, + .probe = pcie_advk_probe, + .priv_auto_alloc_size = sizeof(struct pcie_advk), +};
Signed-off-by: Wilson Ding dingwei@marvell.com Cc: Simon Glass sjg@chromium.org Cc: Stefan Roese sr@denx.de Signed-off-by: Ken Ma make@marvell.com --- configs/mvebu_db-88f3720_defconfig | 3 +++ configs/mvebu_espressobin-88f3720_defconfig | 3 +++ 2 files changed, 6 insertions(+)
diff --git a/configs/mvebu_db-88f3720_defconfig b/configs/mvebu_db-88f3720_defconfig index 1d6233a..ad37efe 100644 --- a/configs/mvebu_db-88f3720_defconfig +++ b/configs/mvebu_db-88f3720_defconfig @@ -44,6 +44,9 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_PCI_AARDVARK=y CONFIG_MVEBU_COMPHY_SUPPORT=y CONFIG_PINCTRL=y CONFIG_PINCTRL_ARMADA_37XX=y diff --git a/configs/mvebu_espressobin-88f3720_defconfig b/configs/mvebu_espressobin-88f3720_defconfig index bbf39cd..510f057 100644 --- a/configs/mvebu_espressobin-88f3720_defconfig +++ b/configs/mvebu_espressobin-88f3720_defconfig @@ -44,6 +44,9 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_PCI_AARDVARK=y CONFIG_MVEBU_COMPHY_SUPPORT=y CONFIG_PINCTRL=y CONFIG_PINCTRL_ARMADA_37XX=y
This patch enabled PCIe port on both devel-board and espressobin board.
Cc: Simon Glass sjg@chromium.org Cc: Stefan Roese sr@denx.de Signed-off-by: Wilson Ding dingwei@marvell.com Signed-off-by: Ken Ma make@marvell.com --- arch/arm/dts/armada-3720-db.dts | 8 ++++++++ arch/arm/dts/armada-3720-espressobin.dts | 7 +++++++ arch/arm/dts/armada-37xx.dtsi | 16 ++++++++++++++++ 3 files changed, 31 insertions(+)
diff --git a/arch/arm/dts/armada-3720-db.dts b/arch/arm/dts/armada-3720-db.dts index 52fc134..770c08a 100644 --- a/arch/arm/dts/armada-3720-db.dts +++ b/arch/arm/dts/armada-3720-db.dts @@ -154,3 +154,11 @@ &usb3 { status = "okay"; }; + +/* CON17 */ +&pcie0 { + pinctrl-names = "default"; + pinctrl-0 = <&pcie_pins>; + reset-gpio = <&gpiosb 3 GPIO_ACTIVE_HIGH>; + status = "okay"; +}; diff --git a/arch/arm/dts/armada-3720-espressobin.dts b/arch/arm/dts/armada-3720-espressobin.dts index 4e70d88..7bfccb0 100644 --- a/arch/arm/dts/armada-3720-espressobin.dts +++ b/arch/arm/dts/armada-3720-espressobin.dts @@ -141,3 +141,10 @@ &usb3 { status = "okay"; }; + +&pcie0 { + pinctrl-names = "default"; + pinctrl-0 = <&pcie_pins>; + reset-gpio = <&gpiosb 3 GPIO_ACTIVE_HIGH>; + status = "okay"; +}; diff --git a/arch/arm/dts/armada-37xx.dtsi b/arch/arm/dts/armada-37xx.dtsi index 9fc87c9..5400742 100644 --- a/arch/arm/dts/armada-37xx.dtsi +++ b/arch/arm/dts/armada-37xx.dtsi @@ -294,5 +294,21 @@ max-lanes = <2>; }; }; + + pcie0: pcie@d0070000 { + compatible = "marvell,armada-37xx-pcie"; + reg = <0 0xd0070000 0 0x20000>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + num-lanes = <1>; + status = "disabled"; + + bus-range = <0 0xff>; + ranges = <0x82000000 0 0xe8000000 + 0 0xe8000000 0 0x1000000 /* Port 0 MEM */ + 0x81000000 0 0xe9000000 + 0 0xe9000000 0 0x10000>; /* Port 0 IO*/ + }; }; };
Cc: Simon Glass sjg@chromium.org Cc: Stefan Roese sr@denx.de Signed-off-by: Ken Ma make@marvell.com --- configs/mvebu_db-88f3720_defconfig | 2 ++ configs/mvebu_espressobin-88f3720_defconfig | 2 ++ 2 files changed, 4 insertions(+)
diff --git a/configs/mvebu_db-88f3720_defconfig b/configs/mvebu_db-88f3720_defconfig index ad37efe..980c0df 100644 --- a/configs/mvebu_db-88f3720_defconfig +++ b/configs/mvebu_db-88f3720_defconfig @@ -17,6 +17,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y @@ -44,6 +45,7 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y +CONFIG_E1000=y CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_PCI_AARDVARK=y diff --git a/configs/mvebu_espressobin-88f3720_defconfig b/configs/mvebu_espressobin-88f3720_defconfig index 510f057..aedb83a 100644 --- a/configs/mvebu_espressobin-88f3720_defconfig +++ b/configs/mvebu_espressobin-88f3720_defconfig @@ -17,6 +17,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y @@ -44,6 +45,7 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y +CONFIG_E1000=y CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_PCI_AARDVARK=y
make@marvell.com
Stefan Roese
