[U-Boot] [PATCH v2 0/2] ARM: dts: at91: add dts files for the boards of SAMA5D3
The purpose of the patchset is add the dts files for boards, sama5d3 Xplained board and sama5d3xek board.
Changes in v2: - Fix spi flash compatible using "spi-flash".
Wenyou Yang (2): ARM: at91: dt: add dts files for sama5d3ek board ARM: at91: dt: add dts file for sama5d3 Xplained
arch/arm/dts/Makefile | 7 + arch/arm/dts/at91-sama5d3_xplained.dts | 341 ++++++++ arch/arm/dts/sama5d3.dtsi | 1505 ++++++++++++++++++++++++++++++++ arch/arm/dts/sama5d31.dtsi | 16 + arch/arm/dts/sama5d31ek.dts | 52 ++ arch/arm/dts/sama5d33.dtsi | 14 + arch/arm/dts/sama5d33ek.dts | 45 + arch/arm/dts/sama5d34.dtsi | 16 + arch/arm/dts/sama5d34ek.dts | 62 ++ arch/arm/dts/sama5d35.dtsi | 18 + arch/arm/dts/sama5d35ek.dts | 55 ++ arch/arm/dts/sama5d36.dtsi | 20 + arch/arm/dts/sama5d36ek.dts | 57 ++ arch/arm/dts/sama5d36ek_cmp.dts | 55 ++ arch/arm/dts/sama5d3_can.dtsi | 74 ++ arch/arm/dts/sama5d3_emac.dtsi | 55 ++ arch/arm/dts/sama5d3_gmac.dtsi | 88 ++ arch/arm/dts/sama5d3_lcd.dtsi | 215 +++++ arch/arm/dts/sama5d3_mci2.dtsi | 59 ++ arch/arm/dts/sama5d3_tcb1.dtsi | 39 + arch/arm/dts/sama5d3_uart.dtsi | 79 ++ arch/arm/dts/sama5d3xcm.dtsi | 123 +++ arch/arm/dts/sama5d3xcm_cmp.dtsi | 166 ++++ arch/arm/dts/sama5d3xdm.dtsi | 41 + arch/arm/dts/sama5d3xmb.dtsi | 221 +++++ arch/arm/dts/sama5d3xmb_cmp.dtsi | 230 +++++ 26 files changed, 3653 insertions(+) create mode 100644 arch/arm/dts/at91-sama5d3_xplained.dts create mode 100644 arch/arm/dts/sama5d3.dtsi create mode 100644 arch/arm/dts/sama5d31.dtsi create mode 100644 arch/arm/dts/sama5d31ek.dts create mode 100644 arch/arm/dts/sama5d33.dtsi create mode 100644 arch/arm/dts/sama5d33ek.dts create mode 100644 arch/arm/dts/sama5d34.dtsi create mode 100644 arch/arm/dts/sama5d34ek.dts create mode 100644 arch/arm/dts/sama5d35.dtsi create mode 100644 arch/arm/dts/sama5d35ek.dts create mode 100644 arch/arm/dts/sama5d36.dtsi create mode 100644 arch/arm/dts/sama5d36ek.dts create mode 100644 arch/arm/dts/sama5d36ek_cmp.dts create mode 100644 arch/arm/dts/sama5d3_can.dtsi create mode 100644 arch/arm/dts/sama5d3_emac.dtsi create mode 100644 arch/arm/dts/sama5d3_gmac.dtsi create mode 100644 arch/arm/dts/sama5d3_lcd.dtsi create mode 100644 arch/arm/dts/sama5d3_mci2.dtsi create mode 100644 arch/arm/dts/sama5d3_tcb1.dtsi create mode 100644 arch/arm/dts/sama5d3_uart.dtsi create mode 100644 arch/arm/dts/sama5d3xcm.dtsi create mode 100644 arch/arm/dts/sama5d3xcm_cmp.dtsi create mode 100644 arch/arm/dts/sama5d3xdm.dtsi create mode 100644 arch/arm/dts/sama5d3xmb.dtsi create mode 100644 arch/arm/dts/sama5d3xmb_cmp.dtsi
Add the dts files for sama5d3ek board.
The dts files is copied from the kernel, do changes as below. - add reg property for the pinctrl node. - move the gpio (pioA, pioB, pioC ...) nodes as the pinctrl's slibling nodes. - fix the compile warning.
Signed-off-by: Wenyou Yang wenyou.yang@atmel.com ARM: at91: sama5d3: fix spi
arch/arm/dts/Makefile | 4 + arch/arm/dts/sama5d3.dtsi | 1505 ++++++++++++++++++++++++++++++++++++++ arch/arm/dts/sama5d31.dtsi | 16 + arch/arm/dts/sama5d31ek.dts | 52 ++ arch/arm/dts/sama5d33.dtsi | 14 + arch/arm/dts/sama5d33ek.dts | 45 ++ arch/arm/dts/sama5d34.dtsi | 16 + arch/arm/dts/sama5d34ek.dts | 62 ++ arch/arm/dts/sama5d35.dtsi | 18 + arch/arm/dts/sama5d35ek.dts | 55 ++ arch/arm/dts/sama5d36.dtsi | 20 + arch/arm/dts/sama5d36ek.dts | 57 ++ arch/arm/dts/sama5d36ek_cmp.dts | 55 ++ arch/arm/dts/sama5d3_can.dtsi | 74 ++ arch/arm/dts/sama5d3_emac.dtsi | 55 ++ arch/arm/dts/sama5d3_gmac.dtsi | 88 +++ arch/arm/dts/sama5d3_lcd.dtsi | 215 ++++++ arch/arm/dts/sama5d3_mci2.dtsi | 59 ++ arch/arm/dts/sama5d3_tcb1.dtsi | 39 + arch/arm/dts/sama5d3_uart.dtsi | 79 ++ arch/arm/dts/sama5d3xcm.dtsi | 123 ++++ arch/arm/dts/sama5d3xcm_cmp.dtsi | 166 +++++ arch/arm/dts/sama5d3xdm.dtsi | 41 ++ arch/arm/dts/sama5d3xmb.dtsi | 221 ++++++ arch/arm/dts/sama5d3xmb_cmp.dtsi | 230 ++++++ 25 files changed, 3309 insertions(+) create mode 100644 arch/arm/dts/sama5d3.dtsi create mode 100644 arch/arm/dts/sama5d31.dtsi create mode 100644 arch/arm/dts/sama5d31ek.dts create mode 100644 arch/arm/dts/sama5d33.dtsi create mode 100644 arch/arm/dts/sama5d33ek.dts create mode 100644 arch/arm/dts/sama5d34.dtsi create mode 100644 arch/arm/dts/sama5d34ek.dts create mode 100644 arch/arm/dts/sama5d35.dtsi create mode 100644 arch/arm/dts/sama5d35ek.dts create mode 100644 arch/arm/dts/sama5d36.dtsi create mode 100644 arch/arm/dts/sama5d36ek.dts create mode 100644 arch/arm/dts/sama5d36ek_cmp.dts create mode 100644 arch/arm/dts/sama5d3_can.dtsi create mode 100644 arch/arm/dts/sama5d3_emac.dtsi create mode 100644 arch/arm/dts/sama5d3_gmac.dtsi create mode 100644 arch/arm/dts/sama5d3_lcd.dtsi create mode 100644 arch/arm/dts/sama5d3_mci2.dtsi create mode 100644 arch/arm/dts/sama5d3_tcb1.dtsi create mode 100644 arch/arm/dts/sama5d3_uart.dtsi create mode 100644 arch/arm/dts/sama5d3xcm.dtsi create mode 100644 arch/arm/dts/sama5d3xcm_cmp.dtsi create mode 100644 arch/arm/dts/sama5d3xdm.dtsi create mode 100644 arch/arm/dts/sama5d3xmb.dtsi create mode 100644 arch/arm/dts/sama5d3xmb_cmp.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 8dbaea0..5bc4f06 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -294,6 +294,10 @@ dtb-$(CONFIG_SOC_KEYSTONE) += k2hk-evm.dtb \ dtb-$(CONFIG_TARGET_SAMA5D2_XPLAINED) += \ at91-sama5d2_xplained.dtb
+dtb-$(CONFIG_TARGET_SAMA5D3XEK) += \ + sama5d36ek.dtb \ + sama5d36ek_cmp.dtb + targets += $(dtb-y)
# Add any required device tree compiler flags here diff --git a/arch/arm/dts/sama5d3.dtsi b/arch/arm/dts/sama5d3.dtsi new file mode 100644 index 0000000..bb4ff30 --- /dev/null +++ b/arch/arm/dts/sama5d3.dtsi @@ -0,0 +1,1505 @@ +/* + * sama5d3.dtsi - Device Tree Include file for SAMA5D3 family SoC + * applies to SAMA5D31, SAMA5D33, SAMA5D34, SAMA5D35, SAMA5D36 SoC + * + * Copyright (C) 2013 Atmel, + * 2013 Ludovic Desroches ludovic.desroches@atmel.com + * + * Licensed under GPLv2 or later. + */ + +#include "skeleton.dtsi" +#include <dt-bindings/dma/at91.h> +#include <dt-bindings/pinctrl/at91.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/clock/at91.h> + +/ { + model = "Atmel SAMA5D3 family SoC"; + compatible = "atmel,sama5d3", "atmel,sama5"; + interrupt-parent = <&aic>; + + aliases { + serial0 = &dbgu; + serial1 = &usart0; + serial2 = &usart1; + serial3 = &usart2; + serial4 = &usart3; + serial5 = &uart0; + gpio0 = &pioA; + gpio1 = &pioB; + gpio2 = &pioC; + gpio3 = &pioD; + gpio4 = &pioE; + tcb0 = &tcb0; + i2c0 = &i2c0; + i2c1 = &i2c1; + i2c2 = &i2c2; + ssc0 = &ssc0; + ssc1 = &ssc1; + pwm0 = &pwm0; + }; + cpus { + #address-cells = <1>; + #size-cells = <0>; + cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a5"; + reg = <0x0>; + }; + }; + + pmu { + compatible = "arm,cortex-a5-pmu"; + interrupts = <46 IRQ_TYPE_LEVEL_HIGH 0>; + }; + + memory { + reg = <0x20000000 0x8000000>; + }; + + clocks { + slow_xtal: slow_xtal { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + }; + + main_xtal: main_xtal { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + }; + + adc_op_clk: adc_op_clk{ + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <1000000>; + }; + }; + + sram: sram@00300000 { + compatible = "mmio-sram"; + reg = <0x00300000 0x20000>; + }; + + ahb { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + apb { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + mmc0: mmc@f0000000 { + compatible = "atmel,hsmci"; + reg = <0xf0000000 0x600>; + interrupts = <21 IRQ_TYPE_LEVEL_HIGH 0>; + dmas = <&dma0 2 AT91_DMA_CFG_PER_ID(0)>; + dma-names = "rxtx"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_mmc0_clk_cmd_dat0 &pinctrl_mmc0_dat1_3 &pinctrl_mmc0_dat4_7>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&mci0_clk>; + clock-names = "mci_clk"; + }; + + spi0: spi@f0004000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "atmel,at91rm9200-spi"; + reg = <0xf0004000 0x100>; + interrupts = <24 IRQ_TYPE_LEVEL_HIGH 3>; + dmas = <&dma0 2 AT91_DMA_CFG_PER_ID(1)>, + <&dma0 2 AT91_DMA_CFG_PER_ID(2)>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_spi0>; + clocks = <&spi0_clk>; + clock-names = "spi_clk"; + status = "disabled"; + }; + + ssc0: ssc@f0008000 { + compatible = "atmel,at91sam9g45-ssc"; + reg = <0xf0008000 0x4000>; + interrupts = <38 IRQ_TYPE_LEVEL_HIGH 4>; + dmas = <&dma0 2 AT91_DMA_CFG_PER_ID(13)>, + <&dma0 2 AT91_DMA_CFG_PER_ID(14)>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ssc0_tx &pinctrl_ssc0_rx>; + clocks = <&ssc0_clk>; + clock-names = "pclk"; + status = "disabled"; + }; + + tcb0: timer@f0010000 { + compatible = "atmel,at91sam9x5-tcb"; + reg = <0xf0010000 0x100>; + interrupts = <26 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&tcb0_clk>, <&clk32k>; + clock-names = "t0_clk", "slow_clk"; + }; + + i2c0: i2c@f0014000 { + compatible = "atmel,at91sam9x5-i2c"; + reg = <0xf0014000 0x4000>; + interrupts = <18 IRQ_TYPE_LEVEL_HIGH 6>; + dmas = <&dma0 2 AT91_DMA_CFG_PER_ID(7)>, + <&dma0 2 AT91_DMA_CFG_PER_ID(8)>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c0>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&twi0_clk>; + status = "disabled"; + }; + + i2c1: i2c@f0018000 { + compatible = "atmel,at91sam9x5-i2c"; + reg = <0xf0018000 0x4000>; + interrupts = <19 IRQ_TYPE_LEVEL_HIGH 6>; + dmas = <&dma0 2 AT91_DMA_CFG_PER_ID(9)>, + <&dma0 2 AT91_DMA_CFG_PER_ID(10)>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&twi1_clk>; + status = "disabled"; + }; + + usart0: serial@f001c000 { + compatible = "atmel,at91sam9260-usart"; + reg = <0xf001c000 0x100>; + interrupts = <12 IRQ_TYPE_LEVEL_HIGH 5>; + dmas = <&dma0 2 AT91_DMA_CFG_PER_ID(3)>, + <&dma0 2 (AT91_DMA_CFG_PER_ID(4) | AT91_DMA_CFG_FIFOCFG_ASAP)>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usart0>; + clocks = <&usart0_clk>; + clock-names = "usart"; + status = "disabled"; + }; + + usart1: serial@f0020000 { + compatible = "atmel,at91sam9260-usart"; + reg = <0xf0020000 0x100>; + interrupts = <13 IRQ_TYPE_LEVEL_HIGH 5>; + dmas = <&dma0 2 AT91_DMA_CFG_PER_ID(5)>, + <&dma0 2 (AT91_DMA_CFG_PER_ID(6) | AT91_DMA_CFG_FIFOCFG_ASAP)>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usart1>; + clocks = <&usart1_clk>; + clock-names = "usart"; + status = "disabled"; + }; + + uart0: serial@f0024000 { + compatible = "atmel,at91sam9260-usart"; + reg = <0xf0024000 0x100>; + interrupts = <16 IRQ_TYPE_LEVEL_HIGH 5>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart0>; + clocks = <&uart0_clk>; + clock-names = "usart"; + status = "disabled"; + }; + + pwm0: pwm@f002c000 { + compatible = "atmel,sama5d3-pwm"; + reg = <0xf002c000 0x300>; + interrupts = <28 IRQ_TYPE_LEVEL_HIGH 4>; + #pwm-cells = <3>; + clocks = <&pwm_clk>; + status = "disabled"; + }; + + isi: isi@f0034000 { + compatible = "atmel,at91sam9g45-isi"; + reg = <0xf0034000 0x4000>; + interrupts = <37 IRQ_TYPE_LEVEL_HIGH 5>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_isi_data_0_7>; + clocks = <&isi_clk>; + clock-names = "isi_clk"; + status = "disabled"; + port { + #address-cells = <1>; + #size-cells = <0>; + }; + }; + + sfr: sfr@f0038000 { + compatible = "atmel,sama5d3-sfr", "syscon"; + reg = <0xf0038000 0x60>; + }; + + mmc1: mmc@f8000000 { + compatible = "atmel,hsmci"; + reg = <0xf8000000 0x600>; + interrupts = <22 IRQ_TYPE_LEVEL_HIGH 0>; + dmas = <&dma1 2 AT91_DMA_CFG_PER_ID(0)>; + dma-names = "rxtx"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_mmc1_clk_cmd_dat0 &pinctrl_mmc1_dat1_3>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&mci1_clk>; + clock-names = "mci_clk"; + }; + + spi1: spi@f8008000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "atmel,at91rm9200-spi"; + reg = <0xf8008000 0x100>; + interrupts = <25 IRQ_TYPE_LEVEL_HIGH 3>; + dmas = <&dma1 2 AT91_DMA_CFG_PER_ID(15)>, + <&dma1 2 AT91_DMA_CFG_PER_ID(16)>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_spi1>; + clocks = <&spi1_clk>; + clock-names = "spi_clk"; + status = "disabled"; + }; + + ssc1: ssc@f800c000 { + compatible = "atmel,at91sam9g45-ssc"; + reg = <0xf800c000 0x4000>; + interrupts = <39 IRQ_TYPE_LEVEL_HIGH 4>; + dmas = <&dma1 2 AT91_DMA_CFG_PER_ID(3)>, + <&dma1 2 AT91_DMA_CFG_PER_ID(4)>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ssc1_tx &pinctrl_ssc1_rx>; + clocks = <&ssc1_clk>; + clock-names = "pclk"; + status = "disabled"; + }; + + adc0: adc@f8018000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "atmel,at91sam9x5-adc"; + reg = <0xf8018000 0x100>; + interrupts = <29 IRQ_TYPE_LEVEL_HIGH 5>; + pinctrl-names = "default"; + pinctrl-0 = < + &pinctrl_adc0_adtrg + &pinctrl_adc0_ad0 + &pinctrl_adc0_ad1 + &pinctrl_adc0_ad2 + &pinctrl_adc0_ad3 + &pinctrl_adc0_ad4 + &pinctrl_adc0_ad5 + &pinctrl_adc0_ad6 + &pinctrl_adc0_ad7 + &pinctrl_adc0_ad8 + &pinctrl_adc0_ad9 + &pinctrl_adc0_ad10 + &pinctrl_adc0_ad11 + >; + clocks = <&adc_clk>, + <&adc_op_clk>; + clock-names = "adc_clk", "adc_op_clk"; + atmel,adc-channels-used = <0xfff>; + atmel,adc-startup-time = <40>; + atmel,adc-use-external-triggers; + atmel,adc-vref = <3000>; + atmel,adc-res = <10 12>; + atmel,adc-sample-hold-time = <11>; + atmel,adc-res-names = "lowres", "highres"; + status = "disabled"; + + trigger@0 { + reg = <0>; + trigger-name = "external-rising"; + trigger-value = <0x1>; + trigger-external; + }; + trigger@1 { + reg = <1>; + trigger-name = "external-falling"; + trigger-value = <0x2>; + trigger-external; + }; + trigger@2 { + reg = <2>; + trigger-name = "external-any"; + trigger-value = <0x3>; + trigger-external; + }; + trigger@3 { + reg = <3>; + trigger-name = "continuous"; + trigger-value = <0x6>; + }; + }; + + i2c2: i2c@f801c000 { + compatible = "atmel,at91sam9x5-i2c"; + reg = <0xf801c000 0x4000>; + interrupts = <20 IRQ_TYPE_LEVEL_HIGH 6>; + dmas = <&dma1 2 AT91_DMA_CFG_PER_ID(11)>, + <&dma1 2 AT91_DMA_CFG_PER_ID(12)>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&twi2_clk>; + status = "disabled"; + }; + + usart2: serial@f8020000 { + compatible = "atmel,at91sam9260-usart"; + reg = <0xf8020000 0x100>; + interrupts = <14 IRQ_TYPE_LEVEL_HIGH 5>; + dmas = <&dma1 2 AT91_DMA_CFG_PER_ID(7)>, + <&dma1 2 (AT91_DMA_CFG_PER_ID(8) | AT91_DMA_CFG_FIFOCFG_ASAP)>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usart2>; + clocks = <&usart2_clk>; + clock-names = "usart"; + status = "disabled"; + }; + + usart3: serial@f8024000 { + compatible = "atmel,at91sam9260-usart"; + reg = <0xf8024000 0x100>; + interrupts = <15 IRQ_TYPE_LEVEL_HIGH 5>; + dmas = <&dma1 2 AT91_DMA_CFG_PER_ID(9)>, + <&dma1 2 (AT91_DMA_CFG_PER_ID(10) | AT91_DMA_CFG_FIFOCFG_ASAP)>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usart3>; + clocks = <&usart3_clk>; + clock-names = "usart"; + status = "disabled"; + }; + + sha@f8034000 { + compatible = "atmel,at91sam9g46-sha"; + reg = <0xf8034000 0x100>; + interrupts = <42 IRQ_TYPE_LEVEL_HIGH 0>; + dmas = <&dma1 2 AT91_DMA_CFG_PER_ID(17)>; + dma-names = "tx"; + clocks = <&sha_clk>; + clock-names = "sha_clk"; + }; + + aes@f8038000 { + compatible = "atmel,at91sam9g46-aes"; + reg = <0xf8038000 0x100>; + interrupts = <43 IRQ_TYPE_LEVEL_HIGH 0>; + dmas = <&dma1 2 AT91_DMA_CFG_PER_ID(18)>, + <&dma1 2 AT91_DMA_CFG_PER_ID(19)>; + dma-names = "tx", "rx"; + clocks = <&aes_clk>; + clock-names = "aes_clk"; + }; + + tdes@f803c000 { + compatible = "atmel,at91sam9g46-tdes"; + reg = <0xf803c000 0x100>; + interrupts = <44 IRQ_TYPE_LEVEL_HIGH 0>; + dmas = <&dma1 2 AT91_DMA_CFG_PER_ID(20)>, + <&dma1 2 AT91_DMA_CFG_PER_ID(21)>; + dma-names = "tx", "rx"; + clocks = <&tdes_clk>; + clock-names = "tdes_clk"; + }; + + trng@f8040000 { + compatible = "atmel,at91sam9g45-trng"; + reg = <0xf8040000 0x100>; + interrupts = <45 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&trng_clk>; + }; + + dma0: dma-controller@ffffe600 { + compatible = "atmel,at91sam9g45-dma"; + reg = <0xffffe600 0x200>; + interrupts = <30 IRQ_TYPE_LEVEL_HIGH 0>; + #dma-cells = <2>; + clocks = <&dma0_clk>; + clock-names = "dma_clk"; + }; + + dma1: dma-controller@ffffe800 { + compatible = "atmel,at91sam9g45-dma"; + reg = <0xffffe800 0x200>; + interrupts = <31 IRQ_TYPE_LEVEL_HIGH 0>; + #dma-cells = <2>; + clocks = <&dma1_clk>; + clock-names = "dma_clk"; + }; + + ramc0: ramc@ffffea00 { + compatible = "atmel,sama5d3-ddramc"; + reg = <0xffffea00 0x200>; + clocks = <&ddrck>, <&mpddr_clk>; + clock-names = "ddrck", "mpddr"; + }; + + dbgu: serial@ffffee00 { + compatible = "atmel,at91sam9260-dbgu", "atmel,at91sam9260-usart"; + reg = <0xffffee00 0x200>; + interrupts = <2 IRQ_TYPE_LEVEL_HIGH 7>; + dmas = <&dma1 2 AT91_DMA_CFG_PER_ID(13)>, + <&dma1 2 (AT91_DMA_CFG_PER_ID(14) | AT91_DMA_CFG_FIFOCFG_ASAP)>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_dbgu>; + clocks = <&dbgu_clk>; + clock-names = "usart"; + status = "disabled"; + }; + + aic: interrupt-controller@fffff000 { + #interrupt-cells = <3>; + compatible = "atmel,sama5d3-aic"; + interrupt-controller; + reg = <0xfffff000 0x200>; + atmel,external-irqs = <47>; + }; + + pinctrl@fffff200 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "atmel,sama5d3-pinctrl", "atmel,at91sam9x5-pinctrl", "simple-bus"; + ranges = <0xfffff200 0xfffff200 0xa00>; + atmel,mux-mask = < + /* A B C */ + 0xffffffff 0xc0fc0000 0xc0ff0000 /* pioA */ + 0xffffffff 0x0ff8ffff 0x00000000 /* pioB */ + 0xffffffff 0xbc00f1ff 0x7c00fc00 /* pioC */ + 0xffffffff 0xc001c0e0 0x0001c1e0 /* pioD */ + 0xffffffff 0xbf9f8000 0x18000000 /* pioE */ + >; + reg = <0xfffff200 0x100 /* pioA */ + 0xfffff400 0x100 /* pioB */ + 0xfffff600 0x100 /* pioC */ + 0xfffff800 0x100 /* pioD */ + 0xfffffa00 0x100 /* pioE */ + >; + + /* shared pinctrl settings */ + adc0 { + pinctrl_adc0_adtrg: adc0_adtrg { + atmel,pins = + <AT91_PIOD 19 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* PD19 periph A ADTRG */ + }; + pinctrl_adc0_ad0: adc0_ad0 { + atmel,pins = + <AT91_PIOD 20 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* PD20 periph A AD0 */ + }; + pinctrl_adc0_ad1: adc0_ad1 { + atmel,pins = + <AT91_PIOD 21 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* PD21 periph A AD1 */ + }; + pinctrl_adc0_ad2: adc0_ad2 { + atmel,pins = + <AT91_PIOD 22 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* PD22 periph A AD2 */ + }; + pinctrl_adc0_ad3: adc0_ad3 { + atmel,pins = + <AT91_PIOD 23 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* PD23 periph A AD3 */ + }; + pinctrl_adc0_ad4: adc0_ad4 { + atmel,pins = + <AT91_PIOD 24 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* PD24 periph A AD4 */ + }; + pinctrl_adc0_ad5: adc0_ad5 { + atmel,pins = + <AT91_PIOD 25 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* PD25 periph A AD5 */ + }; + pinctrl_adc0_ad6: adc0_ad6 { + atmel,pins = + <AT91_PIOD 26 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* PD26 periph A AD6 */ + }; + pinctrl_adc0_ad7: adc0_ad7 { + atmel,pins = + <AT91_PIOD 27 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* PD27 periph A AD7 */ + }; + pinctrl_adc0_ad8: adc0_ad8 { + atmel,pins = + <AT91_PIOD 28 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* PD28 periph A AD8 */ + }; + pinctrl_adc0_ad9: adc0_ad9 { + atmel,pins = + <AT91_PIOD 29 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* PD29 periph A AD9 */ + }; + pinctrl_adc0_ad10: adc0_ad10 { + atmel,pins = + <AT91_PIOD 30 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* PD30 periph A AD10, conflicts with PCK0 */ + }; + pinctrl_adc0_ad11: adc0_ad11 { + atmel,pins = + <AT91_PIOD 31 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* PD31 periph A AD11, conflicts with PCK1 */ + }; + }; + + dbgu { + pinctrl_dbgu: dbgu-0 { + atmel,pins = + <AT91_PIOB 30 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB30 periph A */ + AT91_PIOB 31 AT91_PERIPH_A AT91_PINCTRL_PULL_UP>; /* PB31 periph A with pullup */ + }; + }; + + i2c0 { + pinctrl_i2c0: i2c0-0 { + atmel,pins = + <AT91_PIOA 30 AT91_PERIPH_A AT91_PINCTRL_NONE /* PA30 periph A TWD0 pin, conflicts with URXD1, ISI_VSYNC */ + AT91_PIOA 31 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* PA31 periph A TWCK0 pin, conflicts with UTXD1, ISI_HSYNC */ + }; + }; + + i2c1 { + pinctrl_i2c1: i2c1-0 { + atmel,pins = + <AT91_PIOC 26 AT91_PERIPH_B AT91_PINCTRL_NONE /* PC26 periph B TWD1 pin, conflicts with SPI1_NPCS1, ISI_D11 */ + AT91_PIOC 27 AT91_PERIPH_B AT91_PINCTRL_NONE>; /* PC27 periph B TWCK1 pin, conflicts with SPI1_NPCS2, ISI_D10 */ + }; + }; + + i2c2 { + pinctrl_i2c2: i2c2-0 { + atmel,pins = + <AT91_PIOA 18 AT91_PERIPH_B AT91_PINCTRL_NONE /* TWD2 pin, conflicts with LCDDAT18, ISI_D2 */ + AT91_PIOA 19 AT91_PERIPH_B AT91_PINCTRL_NONE>; /* TWCK2 pin, conflicts with LCDDAT19, ISI_D3 */ + }; + }; + + isi { + pinctrl_isi_data_0_7: isi-0-data-0-7 { + atmel,pins = + <AT91_PIOA 16 AT91_PERIPH_C AT91_PINCTRL_NONE /* PA16 periph C ISI_D0, conflicts with LCDDAT16 */ + AT91_PIOA 17 AT91_PERIPH_C AT91_PINCTRL_NONE /* PA17 periph C ISI_D1, conflicts with LCDDAT17 */ + AT91_PIOA 18 AT91_PERIPH_C AT91_PINCTRL_NONE /* PA18 periph C ISI_D2, conflicts with LCDDAT18, TWD2 */ + AT91_PIOA 19 AT91_PERIPH_C AT91_PINCTRL_NONE /* PA19 periph C ISI_D3, conflicts with LCDDAT19, TWCK2 */ + AT91_PIOA 20 AT91_PERIPH_C AT91_PINCTRL_NONE /* PA20 periph C ISI_D4, conflicts with LCDDAT20, PWMH0 */ + AT91_PIOA 21 AT91_PERIPH_C AT91_PINCTRL_NONE /* PA21 periph C ISI_D5, conflicts with LCDDAT21, PWML0 */ + AT91_PIOA 22 AT91_PERIPH_C AT91_PINCTRL_NONE /* PA22 periph C ISI_D6, conflicts with LCDDAT22, PWMH1 */ + AT91_PIOA 23 AT91_PERIPH_C AT91_PINCTRL_NONE /* PA23 periph C ISI_D7, conflicts with LCDDAT23, PWML1 */ + AT91_PIOC 30 AT91_PERIPH_C AT91_PINCTRL_NONE /* PC30 periph C ISI_PCK, conflicts with UTXD0 */ + AT91_PIOA 31 AT91_PERIPH_C AT91_PINCTRL_NONE /* PA31 periph C ISI_HSYNC, conflicts with TWCK0, UTXD1 */ + AT91_PIOA 30 AT91_PERIPH_C AT91_PINCTRL_NONE>; /* PA30 periph C ISI_VSYNC, conflicts with TWD0, URXD1 */ + }; + + pinctrl_isi_data_8_9: isi-0-data-8-9 { + atmel,pins = + <AT91_PIOC 29 AT91_PERIPH_C AT91_PINCTRL_NONE /* PC29 periph C ISI_PD8, conflicts with URXD0, PWMFI2 */ + AT91_PIOC 28 AT91_PERIPH_C AT91_PINCTRL_NONE>; /* PC28 periph C ISI_PD9, conflicts with SPI1_NPCS3, PWMFI0 */ + }; + + pinctrl_isi_data_10_11: isi-0-data-10-11 { + atmel,pins = + <AT91_PIOC 27 AT91_PERIPH_C AT91_PINCTRL_NONE /* PC27 periph C ISI_PD10, conflicts with SPI1_NPCS2, TWCK1 */ + AT91_PIOC 26 AT91_PERIPH_C AT91_PINCTRL_NONE>; /* PC26 periph C ISI_PD11, conflicts with SPI1_NPCS1, TWD1 */ + }; + }; + + mmc0 { + pinctrl_mmc0_clk_cmd_dat0: mmc0_clk_cmd_dat0 { + atmel,pins = + <AT91_PIOD 9 AT91_PERIPH_A AT91_PINCTRL_NONE /* PD9 periph A MCI0_CK */ + AT91_PIOD 0 AT91_PERIPH_A AT91_PINCTRL_PULL_UP /* PD0 periph A MCI0_CDA with pullup */ + AT91_PIOD 1 AT91_PERIPH_A AT91_PINCTRL_PULL_UP>; /* PD1 periph A MCI0_DA0 with pullup */ + }; + pinctrl_mmc0_dat1_3: mmc0_dat1_3 { + atmel,pins = + <AT91_PIOD 2 AT91_PERIPH_A AT91_PINCTRL_PULL_UP /* PD2 periph A MCI0_DA1 with pullup */ + AT91_PIOD 3 AT91_PERIPH_A AT91_PINCTRL_PULL_UP /* PD3 periph A MCI0_DA2 with pullup */ + AT91_PIOD 4 AT91_PERIPH_A AT91_PINCTRL_PULL_UP>; /* PD4 periph A MCI0_DA3 with pullup */ + }; + pinctrl_mmc0_dat4_7: mmc0_dat4_7 { + atmel,pins = + <AT91_PIOD 5 AT91_PERIPH_A AT91_PINCTRL_PULL_UP /* PD5 periph A MCI0_DA4 with pullup, conflicts with TIOA0, PWMH2 */ + AT91_PIOD 6 AT91_PERIPH_A AT91_PINCTRL_PULL_UP /* PD6 periph A MCI0_DA5 with pullup, conflicts with TIOB0, PWML2 */ + AT91_PIOD 7 AT91_PERIPH_A AT91_PINCTRL_PULL_UP /* PD7 periph A MCI0_DA6 with pullup, conlicts with TCLK0, PWMH3 */ + AT91_PIOD 8 AT91_PERIPH_A AT91_PINCTRL_PULL_UP>; /* PD8 periph A MCI0_DA7 with pullup, conflicts with PWML3 */ + }; + }; + + mmc1 { + pinctrl_mmc1_clk_cmd_dat0: mmc1_clk_cmd_dat0 { + atmel,pins = + <AT91_PIOB 24 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB24 periph A MCI1_CK, conflicts with GRX5 */ + AT91_PIOB 19 AT91_PERIPH_A AT91_PINCTRL_PULL_UP /* PB19 periph A MCI1_CDA with pullup, conflicts with GTX4 */ + AT91_PIOB 20 AT91_PERIPH_A AT91_PINCTRL_PULL_UP>; /* PB20 periph A MCI1_DA0 with pullup, conflicts with GTX5 */ + }; + pinctrl_mmc1_dat1_3: mmc1_dat1_3 { + atmel,pins = + <AT91_PIOB 21 AT91_PERIPH_A AT91_PINCTRL_PULL_UP /* PB21 periph A MCI1_DA1 with pullup, conflicts with GTX6 */ + AT91_PIOB 22 AT91_PERIPH_A AT91_PINCTRL_PULL_UP /* PB22 periph A MCI1_DA2 with pullup, conflicts with GTX7 */ + AT91_PIOB 23 AT91_PERIPH_A AT91_PINCTRL_PULL_UP>; /* PB23 periph A MCI1_DA3 with pullup, conflicts with GRX4 */ + }; + }; + + nand0 { + pinctrl_nand0_ale_cle: nand0_ale_cle-0 { + atmel,pins = + <AT91_PIOE 21 AT91_PERIPH_A AT91_PINCTRL_PULL_UP /* PE21 periph A with pullup */ + AT91_PIOE 22 AT91_PERIPH_A AT91_PINCTRL_PULL_UP>; /* PE22 periph A with pullup */ + }; + }; + + pwm0 { + pinctrl_pwm0_pwmh0_0: pwm0_pwmh0-0 { + atmel,pins = + <AT91_PIOA 20 AT91_PERIPH_B AT91_PINCTRL_NONE>; /* conflicts with ISI_D4 and LCDDAT20 */ + }; + pinctrl_pwm0_pwmh0_1: pwm0_pwmh0-1 { + atmel,pins = + <AT91_PIOB 0 AT91_PERIPH_B AT91_PINCTRL_NONE>; /* conflicts with GTX0 */ + }; + pinctrl_pwm0_pwml0_0: pwm0_pwml0-0 { + atmel,pins = + <AT91_PIOA 21 AT91_PERIPH_B AT91_PINCTRL_NONE>; /* conflicts with ISI_D5 and LCDDAT21 */ + }; + pinctrl_pwm0_pwml0_1: pwm0_pwml0-1 { + atmel,pins = + <AT91_PIOB 1 AT91_PERIPH_B AT91_PINCTRL_NONE>; /* conflicts with GTX1 */ + }; + + pinctrl_pwm0_pwmh1_0: pwm0_pwmh1-0 { + atmel,pins = + <AT91_PIOA 22 AT91_PERIPH_B AT91_PINCTRL_NONE>; /* conflicts with ISI_D6 and LCDDAT22 */ + }; + pinctrl_pwm0_pwmh1_1: pwm0_pwmh1-1 { + atmel,pins = + <AT91_PIOB 4 AT91_PERIPH_B AT91_PINCTRL_NONE>; /* conflicts with GRX0 */ + }; + pinctrl_pwm0_pwmh1_2: pwm0_pwmh1-2 { + atmel,pins = + <AT91_PIOB 27 AT91_PERIPH_C AT91_PINCTRL_NONE>; /* conflicts with G125CKO and RTS1 */ + }; + pinctrl_pwm0_pwml1_0: pwm0_pwml1-0 { + atmel,pins = + <AT91_PIOA 23 AT91_PERIPH_B AT91_PINCTRL_NONE>; /* conflicts with ISI_D7 and LCDDAT23 */ + }; + pinctrl_pwm0_pwml1_1: pwm0_pwml1-1 { + atmel,pins = + <AT91_PIOB 5 AT91_PERIPH_B AT91_PINCTRL_NONE>; /* conflicts with GRX1 */ + }; + pinctrl_pwm0_pwml1_2: pwm0_pwml1-2 { + atmel,pins = + <AT91_PIOE 31 AT91_PERIPH_B AT91_PINCTRL_NONE>; /* conflicts with IRQ */ + }; + + pinctrl_pwm0_pwmh2_0: pwm0_pwmh2-0 { + atmel,pins = + <AT91_PIOB 8 AT91_PERIPH_B AT91_PINCTRL_NONE>; /* conflicts with GTXCK */ + }; + pinctrl_pwm0_pwmh2_1: pwm0_pwmh2-1 { + atmel,pins = + <AT91_PIOD 5 AT91_PERIPH_C AT91_PINCTRL_NONE>; /* conflicts with MCI0_DA4 and TIOA0 */ + }; + pinctrl_pwm0_pwml2_0: pwm0_pwml2-0 { + atmel,pins = + <AT91_PIOB 9 AT91_PERIPH_B AT91_PINCTRL_NONE>; /* conflicts with GTXEN */ + }; + pinctrl_pwm0_pwml2_1: pwm0_pwml2-1 { + atmel,pins = + <AT91_PIOD 6 AT91_PERIPH_C AT91_PINCTRL_NONE>; /* conflicts with MCI0_DA5 and TIOB0 */ + }; + + pinctrl_pwm0_pwmh3_0: pwm0_pwmh3-0 { + atmel,pins = + <AT91_PIOB 12 AT91_PERIPH_B AT91_PINCTRL_NONE>; /* conflicts with GRXDV */ + }; + pinctrl_pwm0_pwmh3_1: pwm0_pwmh3-1 { + atmel,pins = + <AT91_PIOD 7 AT91_PERIPH_C AT91_PINCTRL_NONE>; /* conflicts with MCI0_DA6 and TCLK0 */ + }; + pinctrl_pwm0_pwml3_0: pwm0_pwml3-0 { + atmel,pins = + <AT91_PIOB 13 AT91_PERIPH_B AT91_PINCTRL_NONE>; /* conflicts with GRXER */ + }; + pinctrl_pwm0_pwml3_1: pwm0_pwml3-1 { + atmel,pins = + <AT91_PIOD 8 AT91_PERIPH_C AT91_PINCTRL_NONE>; /* conflicts with MCI0_DA7 */ + }; + }; + + spi0 { + pinctrl_spi0: spi0-0 { + atmel,pins = + <AT91_PIOD 10 AT91_PERIPH_A AT91_PINCTRL_NONE /* PD10 periph A SPI0_MISO pin */ + AT91_PIOD 11 AT91_PERIPH_A AT91_PINCTRL_NONE /* PD11 periph A SPI0_MOSI pin */ + AT91_PIOD 12 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* PD12 periph A SPI0_SPCK pin */ + }; + }; + + spi1 { + pinctrl_spi1: spi1-0 { + atmel,pins = + <AT91_PIOC 22 AT91_PERIPH_A AT91_PINCTRL_NONE /* PC22 periph A SPI1_MISO pin */ + AT91_PIOC 23 AT91_PERIPH_A AT91_PINCTRL_NONE /* PC23 periph A SPI1_MOSI pin */ + AT91_PIOC 24 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* PC24 periph A SPI1_SPCK pin */ + }; + }; + + ssc0 { + pinctrl_ssc0_tx: ssc0_tx { + atmel,pins = + <AT91_PIOC 16 AT91_PERIPH_A AT91_PINCTRL_NONE /* PC16 periph A TK0 */ + AT91_PIOC 17 AT91_PERIPH_A AT91_PINCTRL_NONE /* PC17 periph A TF0 */ + AT91_PIOC 18 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* PC18 periph A TD0 */ + }; + + pinctrl_ssc0_rx: ssc0_rx { + atmel,pins = + <AT91_PIOC 19 AT91_PERIPH_A AT91_PINCTRL_NONE /* PC19 periph A RK0 */ + AT91_PIOC 20 AT91_PERIPH_A AT91_PINCTRL_NONE /* PC20 periph A RF0 */ + AT91_PIOC 21 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* PC21 periph A RD0 */ + }; + }; + + ssc1 { + pinctrl_ssc1_tx: ssc1_tx { + atmel,pins = + <AT91_PIOB 2 AT91_PERIPH_B AT91_PINCTRL_NONE /* PB2 periph B TK1, conflicts with GTX2 */ + AT91_PIOB 3 AT91_PERIPH_B AT91_PINCTRL_NONE /* PB3 periph B TF1, conflicts with GTX3 */ + AT91_PIOB 6 AT91_PERIPH_B AT91_PINCTRL_NONE>; /* PB6 periph B TD1, conflicts with TD1 */ + }; + + pinctrl_ssc1_rx: ssc1_rx { + atmel,pins = + <AT91_PIOB 7 AT91_PERIPH_B AT91_PINCTRL_NONE /* PB7 periph B RK1, conflicts with EREFCK */ + AT91_PIOB 10 AT91_PERIPH_B AT91_PINCTRL_NONE /* PB10 periph B RF1, conflicts with GTXER */ + AT91_PIOB 11 AT91_PERIPH_B AT91_PINCTRL_NONE>; /* PB11 periph B RD1, conflicts with GRXCK */ + }; + }; + + uart0 { + pinctrl_uart0: uart0-0 { + atmel,pins = + <AT91_PIOC 29 AT91_PERIPH_A AT91_PINCTRL_NONE /* conflicts with PWMFI2, ISI_D8 */ + AT91_PIOC 30 AT91_PERIPH_A AT91_PINCTRL_PULL_UP>; /* conflicts with ISI_PCK */ + }; + }; + + uart1 { + pinctrl_uart1: uart1-0 { + atmel,pins = + <AT91_PIOA 30 AT91_PERIPH_B AT91_PINCTRL_NONE /* conflicts with TWD0, ISI_VSYNC */ + AT91_PIOA 31 AT91_PERIPH_B AT91_PINCTRL_PULL_UP>; /* conflicts with TWCK0, ISI_HSYNC */ + }; + }; + + usart0 { + pinctrl_usart0: usart0-0 { + atmel,pins = + <AT91_PIOD 17 AT91_PERIPH_A AT91_PINCTRL_NONE /* PD17 periph A */ + AT91_PIOD 18 AT91_PERIPH_A AT91_PINCTRL_PULL_UP>; /* PD18 periph A with pullup */ + }; + + pinctrl_usart0_rts_cts: usart0_rts_cts-0 { + atmel,pins = + <AT91_PIOD 15 AT91_PERIPH_A AT91_PINCTRL_NONE /* PD15 periph A, conflicts with SPI0_NPCS2, CANTX0 */ + AT91_PIOD 16 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* PD16 periph A, conflicts with SPI0_NPCS3, PWMFI3 */ + }; + }; + + usart1 { + pinctrl_usart1: usart1-0 { + atmel,pins = + <AT91_PIOB 28 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB28 periph A */ + AT91_PIOB 29 AT91_PERIPH_A AT91_PINCTRL_PULL_UP>; /* PB29 periph A with pullup */ + }; + + pinctrl_usart1_rts_cts: usart1_rts_cts-0 { + atmel,pins = + <AT91_PIOB 26 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB26 periph A, conflicts with GRX7 */ + AT91_PIOB 27 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* PB27 periph A, conflicts with G125CKO */ + }; + }; + + usart2 { + pinctrl_usart2: usart2-0 { + atmel,pins = + <AT91_PIOE 25 AT91_PERIPH_B AT91_PINCTRL_NONE /* PE25 periph B, conflicts with A25 */ + AT91_PIOE 26 AT91_PERIPH_B AT91_PINCTRL_PULL_UP>; /* PE26 periph B with pullup, conflicts NCS0 */ + }; + + pinctrl_usart2_rts_cts: usart2_rts_cts-0 { + atmel,pins = + <AT91_PIOE 23 AT91_PERIPH_B AT91_PINCTRL_NONE /* PE23 periph B, conflicts with A23 */ + AT91_PIOE 24 AT91_PERIPH_B AT91_PINCTRL_NONE>; /* PE24 periph B, conflicts with A24 */ + }; + }; + + usart3 { + pinctrl_usart3: usart3-0 { + atmel,pins = + <AT91_PIOE 18 AT91_PERIPH_B AT91_PINCTRL_NONE /* PE18 periph B, conflicts with A18 */ + AT91_PIOE 19 AT91_PERIPH_B AT91_PINCTRL_PULL_UP>; /* PE19 periph B with pullup, conflicts with A19 */ + }; + + pinctrl_usart3_rts_cts: usart3_rts_cts-0 { + atmel,pins = + <AT91_PIOE 16 AT91_PERIPH_B AT91_PINCTRL_NONE /* PE16 periph B, conflicts with A16 */ + AT91_PIOE 17 AT91_PERIPH_B AT91_PINCTRL_NONE>; /* PE17 periph B, conflicts with A17 */ + }; + }; + }; + + pioA: gpio@fffff200 { + compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; + reg = <0xfffff200 0x100>; + interrupts = <6 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioA_clk>; + }; + + pioB: gpio@fffff400 { + compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; + reg = <0xfffff400 0x100>; + interrupts = <7 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioB_clk>; + }; + + pioC: gpio@fffff600 { + compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; + reg = <0xfffff600 0x100>; + interrupts = <8 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioC_clk>; + }; + + pioD: gpio@fffff800 { + compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; + reg = <0xfffff800 0x100>; + interrupts = <9 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioD_clk>; + }; + + pioE: gpio@fffffa00 { + compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; + reg = <0xfffffa00 0x100>; + interrupts = <10 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioE_clk>; + }; + + pmc: pmc@fffffc00 { + compatible = "atmel,sama5d3-pmc", "syscon"; + reg = <0xfffffc00 0x120>; + interrupts = <1 IRQ_TYPE_LEVEL_HIGH 7>; + interrupt-controller; + #address-cells = <1>; + #size-cells = <0>; + #interrupt-cells = <1>; + + main_rc_osc: main_rc_osc { + compatible = "atmel,at91sam9x5-clk-main-rc-osc"; + #clock-cells = <0>; + interrupt-parent = <&pmc>; + interrupts = <AT91_PMC_MOSCRCS>; + clock-frequency = <12000000>; + clock-accuracy = <50000000>; + }; + + main_osc: main_osc { + compatible = "atmel,at91rm9200-clk-main-osc"; + #clock-cells = <0>; + interrupt-parent = <&pmc>; + interrupts = <AT91_PMC_MOSCS>; + clocks = <&main_xtal>; + }; + + main: mainck { + compatible = "atmel,at91sam9x5-clk-main"; + #clock-cells = <0>; + interrupt-parent = <&pmc>; + interrupts = <AT91_PMC_MOSCSELS>; + clocks = <&main_rc_osc &main_osc>; + }; + + plla: pllack@0 { + compatible = "atmel,sama5d3-clk-pll"; + #clock-cells = <0>; + interrupt-parent = <&pmc>; + interrupts = <AT91_PMC_LOCKA>; + clocks = <&main>; + reg = <0>; + atmel,clk-input-range = <8000000 50000000>; + #atmel,pll-clk-output-range-cells = <4>; + atmel,pll-clk-output-ranges = <400000000 1000000000 0 0>; + }; + + plladiv: plladivck { + compatible = "atmel,at91sam9x5-clk-plldiv"; + #clock-cells = <0>; + clocks = <&plla>; + }; + + utmi: utmick { + compatible = "atmel,at91sam9x5-clk-utmi"; + #clock-cells = <0>; + interrupt-parent = <&pmc>; + interrupts = <AT91_PMC_LOCKU>; + clocks = <&main>; + }; + + mck: masterck { + compatible = "atmel,at91sam9x5-clk-master"; + #clock-cells = <0>; + interrupt-parent = <&pmc>; + interrupts = <AT91_PMC_MCKRDY>; + clocks = <&clk32k>, <&main>, <&plladiv>, <&utmi>; + atmel,clk-output-range = <0 166000000>; + atmel,clk-divisors = <1 2 4 3>; + }; + + usb: usbck { + compatible = "atmel,at91sam9x5-clk-usb"; + #clock-cells = <0>; + clocks = <&plladiv>, <&utmi>; + }; + + prog: progck { + compatible = "atmel,at91sam9x5-clk-programmable"; + #address-cells = <1>; + #size-cells = <0>; + interrupt-parent = <&pmc>; + clocks = <&clk32k>, <&main>, <&plladiv>, <&utmi>, <&mck>; + + prog0: progck@0 { + #clock-cells = <0>; + reg = <0>; + interrupts = <AT91_PMC_PCKRDY(0)>; + }; + + prog1: progck@1 { + #clock-cells = <0>; + reg = <1>; + interrupts = <AT91_PMC_PCKRDY(1)>; + }; + + prog2: progck@2 { + #clock-cells = <0>; + reg = <2>; + interrupts = <AT91_PMC_PCKRDY(2)>; + }; + }; + + smd: smdclk { + compatible = "atmel,at91sam9x5-clk-smd"; + #clock-cells = <0>; + clocks = <&plladiv>, <&utmi>; + }; + + systemck { + compatible = "atmel,at91rm9200-clk-system"; + #address-cells = <1>; + #size-cells = <0>; + + ddrck: ddrck@2 { + #clock-cells = <0>; + reg = <2>; + clocks = <&mck>; + }; + + smdck: smdck@4 { + #clock-cells = <0>; + reg = <4>; + clocks = <&smd>; + }; + + uhpck: uhpck@6 { + #clock-cells = <0>; + reg = <6>; + clocks = <&usb>; + }; + + udpck: udpck@7 { + #clock-cells = <0>; + reg = <7>; + clocks = <&usb>; + }; + + pck0: pck@8 { + #clock-cells = <0>; + reg = <8>; + clocks = <&prog0>; + }; + + pck1: pck@9 { + #clock-cells = <0>; + reg = <9>; + clocks = <&prog1>; + }; + + pck2: pck@10 { + #clock-cells = <0>; + reg = <10>; + clocks = <&prog2>; + }; + }; + + periphck { + compatible = "atmel,at91sam9x5-clk-peripheral"; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&mck>; + + dbgu_clk: dbgu_clk@2 { + #clock-cells = <0>; + reg = <2>; + }; + + hsmc_clk: hsmc_clk@5 { + #clock-cells = <0>; + reg = <5>; + }; + + pioA_clk: pioA_clk@6 { + #clock-cells = <0>; + reg = <6>; + }; + + pioB_clk: pioB_clk@7 { + #clock-cells = <0>; + reg = <7>; + }; + + pioC_clk: pioC_clk@8 { + #clock-cells = <0>; + reg = <8>; + }; + + pioD_clk: pioD_clk@9 { + #clock-cells = <0>; + reg = <9>; + }; + + pioE_clk: pioE_clk@10 { + #clock-cells = <0>; + reg = <10>; + }; + + usart0_clk: usart0_clk@12 { + #clock-cells = <0>; + reg = <12>; + atmel,clk-output-range = <0 66000000>; + }; + + usart1_clk: usart1_clk@13 { + #clock-cells = <0>; + reg = <13>; + atmel,clk-output-range = <0 66000000>; + }; + + usart2_clk: usart2_clk@14 { + #clock-cells = <0>; + reg = <14>; + atmel,clk-output-range = <0 66000000>; + }; + + usart3_clk: usart3_clk@15 { + #clock-cells = <0>; + reg = <15>; + atmel,clk-output-range = <0 66000000>; + }; + + uart0_clk: uart0_clk@16 { + #clock-cells = <0>; + reg = <16>; + atmel,clk-output-range = <0 66000000>; + }; + + twi0_clk: twi0_clk@18 { + reg = <18>; + #clock-cells = <0>; + atmel,clk-output-range = <0 16625000>; + }; + + twi1_clk: twi1_clk@19 { + #clock-cells = <0>; + reg = <19>; + atmel,clk-output-range = <0 16625000>; + }; + + twi2_clk: twi2_clk@20 { + #clock-cells = <0>; + reg = <20>; + atmel,clk-output-range = <0 16625000>; + }; + + mci0_clk: mci0_clk@21 { + #clock-cells = <0>; + reg = <21>; + }; + + mci1_clk: mci1_clk@22 { + #clock-cells = <0>; + reg = <22>; + }; + + spi0_clk: spi0_clk@24 { + #clock-cells = <0>; + reg = <24>; + atmel,clk-output-range = <0 133000000>; + }; + + spi1_clk: spi1_clk@25 { + #clock-cells = <0>; + reg = <25>; + atmel,clk-output-range = <0 133000000>; + }; + + tcb0_clk: tcb0_clk@26 { + #clock-cells = <0>; + reg = <26>; + atmel,clk-output-range = <0 133000000>; + }; + + pwm_clk: pwm_clk@28 { + #clock-cells = <0>; + reg = <28>; + }; + + adc_clk: adc_clk@29 { + #clock-cells = <0>; + reg = <29>; + atmel,clk-output-range = <0 66000000>; + }; + + dma0_clk: dma0_clk@30 { + #clock-cells = <0>; + reg = <30>; + }; + + dma1_clk: dma1_clk@31 { + #clock-cells = <0>; + reg = <31>; + }; + + uhphs_clk: uhphs_clk@32 { + #clock-cells = <0>; + reg = <32>; + }; + + udphs_clk: udphs_clk@33 { + #clock-cells = <0>; + reg = <33>; + }; + + isi_clk: isi_clk@37 { + #clock-cells = <0>; + reg = <37>; + }; + + ssc0_clk: ssc0_clk@38 { + #clock-cells = <0>; + reg = <38>; + atmel,clk-output-range = <0 66000000>; + }; + + ssc1_clk: ssc1_clk@39 { + #clock-cells = <0>; + reg = <39>; + atmel,clk-output-range = <0 66000000>; + }; + + sha_clk: sha_clk@42 { + #clock-cells = <0>; + reg = <42>; + }; + + aes_clk: aes_clk@43 { + #clock-cells = <0>; + reg = <43>; + }; + + tdes_clk: tdes_clk@44 { + #clock-cells = <0>; + reg = <44>; + }; + + trng_clk: trng_clk@45 { + #clock-cells = <0>; + reg = <45>; + }; + + fuse_clk: fuse_clk@48 { + #clock-cells = <0>; + reg = <48>; + }; + + mpddr_clk: mpddr_clk@49 { + #clock-cells = <0>; + reg = <49>; + }; + }; + }; + + rstc@fffffe00 { + compatible = "atmel,sama5d3-rstc", "atmel,at91sam9g45-rstc"; + reg = <0xfffffe00 0x10>; + clocks = <&clk32k>; + }; + + shutdown-controller@fffffe10 { + compatible = "atmel,at91sam9x5-shdwc"; + reg = <0xfffffe10 0x10>; + clocks = <&clk32k>; + }; + + pit: timer@fffffe30 { + compatible = "atmel,at91sam9260-pit"; + reg = <0xfffffe30 0xf>; + interrupts = <3 IRQ_TYPE_LEVEL_HIGH 5>; + clocks = <&mck>; + }; + + watchdog@fffffe40 { + compatible = "atmel,at91sam9260-wdt"; + reg = <0xfffffe40 0x10>; + interrupts = <4 IRQ_TYPE_LEVEL_HIGH 7>; + clocks = <&clk32k>; + atmel,watchdog-type = "hardware"; + atmel,reset-type = "all"; + atmel,dbg-halt; + status = "disabled"; + }; + + sckc@fffffe50 { + compatible = "atmel,at91sam9x5-sckc"; + reg = <0xfffffe50 0x4>; + + slow_rc_osc: slow_rc_osc { + compatible = "atmel,at91sam9x5-clk-slow-rc-osc"; + #clock-cells = <0>; + clock-frequency = <32768>; + clock-accuracy = <50000000>; + atmel,startup-time-usec = <75>; + }; + + slow_osc: slow_osc { + compatible = "atmel,at91sam9x5-clk-slow-osc"; + #clock-cells = <0>; + clocks = <&slow_xtal>; + atmel,startup-time-usec = <1200000>; + }; + + clk32k: slowck { + compatible = "atmel,at91sam9x5-clk-slow"; + #clock-cells = <0>; + clocks = <&slow_rc_osc &slow_osc>; + }; + }; + + rtc@fffffeb0 { + compatible = "atmel,at91rm9200-rtc"; + reg = <0xfffffeb0 0x30>; + interrupts = <1 IRQ_TYPE_LEVEL_HIGH 7>; + clocks = <&clk32k>; + }; + }; + + usb0: gadget@00500000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "atmel,sama5d3-udc"; + reg = <0x00500000 0x100000 + 0xf8030000 0x4000>; + interrupts = <33 IRQ_TYPE_LEVEL_HIGH 2>; + clocks = <&udphs_clk>, <&utmi>; + clock-names = "pclk", "hclk"; + status = "disabled"; + + ep0: endpoint@0 { + reg = <0>; + atmel,fifo-size = <64>; + atmel,nb-banks = <1>; + }; + + ep1: endpoint@1 { + reg = <1>; + atmel,fifo-size = <1024>; + atmel,nb-banks = <3>; + atmel,can-dma; + atmel,can-isoc; + }; + + ep2: endpoint@2 { + reg = <2>; + atmel,fifo-size = <1024>; + atmel,nb-banks = <3>; + atmel,can-dma; + atmel,can-isoc; + }; + + ep3: endpoint@3 { + reg = <3>; + atmel,fifo-size = <1024>; + atmel,nb-banks = <2>; + atmel,can-dma; + }; + + ep4: endpoint@4 { + reg = <4>; + atmel,fifo-size = <1024>; + atmel,nb-banks = <2>; + atmel,can-dma; + }; + + ep5: endpoint@5 { + reg = <5>; + atmel,fifo-size = <1024>; + atmel,nb-banks = <2>; + atmel,can-dma; + }; + + ep6: endpoint@6 { + reg = <6>; + atmel,fifo-size = <1024>; + atmel,nb-banks = <2>; + atmel,can-dma; + }; + + ep7i: endpoint@7 { + reg = <7>; + atmel,fifo-size = <1024>; + atmel,nb-banks = <2>; + atmel,can-dma; + }; + + ep8: endpoint@8 { + reg = <8>; + atmel,fifo-size = <1024>; + atmel,nb-banks = <2>; + }; + + ep9: endpoint@9 { + reg = <9>; + atmel,fifo-size = <1024>; + atmel,nb-banks = <2>; + }; + + ep10: endpoint@10 { + reg = <10>; + atmel,fifo-size = <1024>; + atmel,nb-banks = <2>; + }; + + ep11: endpoint@11 { + reg = <11>; + atmel,fifo-size = <1024>; + atmel,nb-banks = <2>; + }; + + ep12: endpoint@12 { + reg = <12>; + atmel,fifo-size = <1024>; + atmel,nb-banks = <2>; + }; + + ep13: endpoint@13 { + reg = <13>; + atmel,fifo-size = <1024>; + atmel,nb-banks = <2>; + }; + + ep14: endpoint@14 { + reg = <14>; + atmel,fifo-size = <1024>; + atmel,nb-banks = <2>; + }; + + ep15: endpoint@15 { + reg = <15>; + atmel,fifo-size = <1024>; + atmel,nb-banks = <2>; + }; + }; + + usb1: ohci@00600000 { + compatible = "atmel,at91rm9200-ohci", "usb-ohci"; + reg = <0x00600000 0x100000>; + interrupts = <32 IRQ_TYPE_LEVEL_HIGH 2>; + clocks = <&uhphs_clk>, <&uhphs_clk>, <&uhpck>; + clock-names = "ohci_clk", "hclk", "uhpck"; + status = "disabled"; + }; + + usb2: ehci@00700000 { + compatible = "atmel,at91sam9g45-ehci", "usb-ehci"; + reg = <0x00700000 0x100000>; + interrupts = <32 IRQ_TYPE_LEVEL_HIGH 2>; + clocks = <&utmi>, <&uhphs_clk>; + clock-names = "usb_clk", "ehci_clk"; + status = "disabled"; + }; + + nand0: nand@60000000 { + compatible = "atmel,at91rm9200-nand"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + reg = < 0x60000000 0x01000000 /* EBI CS3 */ + 0xffffc070 0x00000490 /* SMC PMECC regs */ + 0xffffc500 0x00000100 /* SMC PMECC Error Location regs */ + 0x00110000 0x00018000 /* ROM code */ + >; + interrupts = <5 IRQ_TYPE_LEVEL_HIGH 6>; + atmel,nand-addr-offset = <21>; + atmel,nand-cmd-offset = <22>; + atmel,nand-has-dma; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_nand0_ale_cle>; + atmel,pmecc-lookup-table-offset = <0x0 0x8000>; + status = "disabled"; + + nfc@70000000 { + compatible = "atmel,sama5d3-nfc"; + #address-cells = <1>; + #size-cells = <1>; + reg = < + 0x70000000 0x08000000 /* NFC Command Registers */ + 0xffffc000 0x00000070 /* NFC HSMC regs */ + 0x00200000 0x00100000 /* NFC SRAM banks */ + >; + clocks = <&hsmc_clk>; + }; + }; + }; +}; diff --git a/arch/arm/dts/sama5d31.dtsi b/arch/arm/dts/sama5d31.dtsi new file mode 100644 index 0000000..883878b --- /dev/null +++ b/arch/arm/dts/sama5d31.dtsi @@ -0,0 +1,16 @@ +/* + * sama5d31.dtsi - Device Tree Include file for SAMA5D31 SoC + * + * Copyright (C) 2013 Boris BREZILLON b.brezillon@overkiz.com + * + * Licensed under GPLv2 or later. + */ +#include "sama5d3.dtsi" +#include "sama5d3_lcd.dtsi" +#include "sama5d3_emac.dtsi" +#include "sama5d3_mci2.dtsi" +#include "sama5d3_uart.dtsi" + +/ { + compatible = "atmel,sama5d31", "atmel,sama5d3", "atmel,sama5"; +}; diff --git a/arch/arm/dts/sama5d31ek.dts b/arch/arm/dts/sama5d31ek.dts new file mode 100644 index 0000000..04eec0d --- /dev/null +++ b/arch/arm/dts/sama5d31ek.dts @@ -0,0 +1,52 @@ +/* + * sama5d31ek.dts - Device Tree file for SAMA5D31-EK board + * + * Copyright (C) 2013 Atmel, + * 2013 Ludovic Desroches ludovic.desroches@atmel.com + * + * Licensed under GPLv2 or later. + */ +/dts-v1/; +#include "sama5d31.dtsi" +#include "sama5d3xmb.dtsi" +#include "sama5d3xdm.dtsi" + +/ { + model = "Atmel SAMA5D31-EK"; + compatible = "atmel,sama5d31ek", "atmel,sama5d3xmb", "atmel,sama5d3xcm", "atmel,sama5d31", "atmel,sama5d3", "atmel,sama5"; + + ahb { + apb { + spi0: spi@f0004000 { + status = "okay"; + }; + + ssc0: ssc@f0008000 { + status = "okay"; + }; + + i2c0: i2c@f0014000 { + status = "okay"; + }; + + i2c1: i2c@f0018000 { + status = "okay"; + }; + + macb1: ethernet@f802c000 { + status = "okay"; + }; + }; + }; + + leds { + d3 { + label = "d3"; + gpios = <&pioE 24 GPIO_ACTIVE_HIGH>; + }; + }; + + sound { + status = "okay"; + }; +}; diff --git a/arch/arm/dts/sama5d33.dtsi b/arch/arm/dts/sama5d33.dtsi new file mode 100644 index 0000000..4b4434a --- /dev/null +++ b/arch/arm/dts/sama5d33.dtsi @@ -0,0 +1,14 @@ +/* + * sama5d33.dtsi - Device Tree Include file for SAMA5D33 SoC + * + * Copyright (C) 2013 Boris BREZILLON b.brezillon@overkiz.com + * + * Licensed under GPLv2 or later. + */ +#include "sama5d3.dtsi" +#include "sama5d3_lcd.dtsi" +#include "sama5d3_gmac.dtsi" + +/ { + compatible = "atmel,sama5d33", "atmel,sama5d3", "atmel,sama5"; +}; diff --git a/arch/arm/dts/sama5d33ek.dts b/arch/arm/dts/sama5d33ek.dts new file mode 100644 index 0000000..cbd6a3f --- /dev/null +++ b/arch/arm/dts/sama5d33ek.dts @@ -0,0 +1,45 @@ +/* + * sama5d33ek.dts - Device Tree file for SAMA5D33-EK board + * + * Copyright (C) 2013 Atmel, + * 2013 Ludovic Desroches ludovic.desroches@atmel.com + * + * Licensed under GPLv2 or later. + */ +/dts-v1/; +#include "sama5d33.dtsi" +#include "sama5d3xmb.dtsi" +#include "sama5d3xdm.dtsi" + +/ { + model = "Atmel SAMA5D33-EK"; + compatible = "atmel,sama5d33ek", "atmel,sama5d3xmb", "atmel,sama5d3xcm", "atmel,sama5d33", "atmel,sama5d3", "atmel,sama5"; + + ahb { + apb { + spi0: spi@f0004000 { + status = "okay"; + }; + + ssc0: ssc@f0008000 { + status = "okay"; + }; + + i2c0: i2c@f0014000 { + status = "okay"; + }; + + i2c1: i2c@f0018000 { + status = "okay"; + }; + + macb0: ethernet@f0028000 { + status = "okay"; + }; + }; + }; + + sound { + status = "okay"; + }; +}; diff --git a/arch/arm/dts/sama5d34.dtsi b/arch/arm/dts/sama5d34.dtsi new file mode 100644 index 0000000..aa01573 --- /dev/null +++ b/arch/arm/dts/sama5d34.dtsi @@ -0,0 +1,16 @@ +/* + * sama5d34.dtsi - Device Tree Include file for SAMA5D34 SoC + * + * Copyright (C) 2013 Boris BREZILLON b.brezillon@overkiz.com + * + * Licensed under GPLv2 or later. + */ +#include "sama5d3.dtsi" +#include "sama5d3_lcd.dtsi" +#include "sama5d3_gmac.dtsi" +#include "sama5d3_can.dtsi" +#include "sama5d3_mci2.dtsi" + +/ { + compatible = "atmel,sama5d34", "atmel,sama5d3", "atmel,sama5"; +}; diff --git a/arch/arm/dts/sama5d34ek.dts b/arch/arm/dts/sama5d34ek.dts new file mode 100644 index 0000000..878aa16 --- /dev/null +++ b/arch/arm/dts/sama5d34ek.dts @@ -0,0 +1,62 @@ +/* + * sama5d34ek.dts - Device Tree file for SAMA5D34-EK board + * + * Copyright (C) 2013 Atmel, + * 2013 Ludovic Desroches ludovic.desroches@atmel.com + * + * Licensed under GPLv2 or later. + */ +/dts-v1/; +#include "sama5d34.dtsi" +#include "sama5d3xmb.dtsi" +#include "sama5d3xdm.dtsi" + +/ { + model = "Atmel SAMA5D34-EK"; + compatible = "atmel,sama5d34ek", "atmel,sama5d3xmb", "atmel,sama5d3xcm", "atmel,sama5d34", "atmel,sama5d3", "atmel,sama5"; + + ahb { + apb { + spi0: spi@f0004000 { + status = "okay"; + }; + + ssc0: ssc@f0008000 { + status = "okay"; + }; + + can0: can@f000c000 { + status = "okay"; + }; + + i2c0: i2c@f0014000 { + status = "okay"; + }; + + i2c1: i2c@f0018000 { + status = "okay"; + + 24c256@50 { + compatible = "24c256"; + reg = <0x50>; + pagesize = <64>; + }; + }; + + macb0: ethernet@f0028000 { + status = "okay"; + }; + }; + }; + + leds { + d3 { + label = "d3"; + gpios = <&pioE 24 GPIO_ACTIVE_HIGH>; + }; + }; + + sound { + status = "okay"; + }; +}; diff --git a/arch/arm/dts/sama5d35.dtsi b/arch/arm/dts/sama5d35.dtsi new file mode 100644 index 0000000..16c39f4 --- /dev/null +++ b/arch/arm/dts/sama5d35.dtsi @@ -0,0 +1,18 @@ +/* + * sama5d35.dtsi - Device Tree Include file for SAMA5D35 SoC + * + * Copyright (C) 2013 Boris BREZILLON b.brezillon@overkiz.com + * + * Licensed under GPLv2 or later. + */ +#include "sama5d3.dtsi" +#include "sama5d3_gmac.dtsi" +#include "sama5d3_emac.dtsi" +#include "sama5d3_can.dtsi" +#include "sama5d3_mci2.dtsi" +#include "sama5d3_uart.dtsi" +#include "sama5d3_tcb1.dtsi" + +/ { + compatible = "atmel,sama5d35", "atmel,sama5d3", "atmel,sama5"; +}; diff --git a/arch/arm/dts/sama5d35ek.dts b/arch/arm/dts/sama5d35ek.dts new file mode 100644 index 0000000..e812f5c --- /dev/null +++ b/arch/arm/dts/sama5d35ek.dts @@ -0,0 +1,55 @@ +/* + * sama5d35ek.dts - Device Tree file for SAMA5D35-EK board + * + * Copyright (C) 2013 Atmel, + * 2013 Ludovic Desroches ludovic.desroches@atmel.com + * + * Licensed under GPLv2 or later. + */ +/dts-v1/; +#include "sama5d35.dtsi" +#include "sama5d3xmb.dtsi" + +/ { + model = "Atmel SAMA5D35-EK"; + compatible = "atmel,sama5d35ek", "atmel,sama5d3xmb", "atmel,sama5d3xcm", "atmel,sama5d35", "atmel,sama5d3", "atmel,sama5"; + + ahb { + apb { + spi0: spi@f0004000 { + status = "okay"; + }; + + can0: can@f000c000 { + status = "okay"; + }; + + i2c1: i2c@f0018000 { + status = "okay"; + }; + + macb0: ethernet@f0028000 { + status = "okay"; + }; + + isi: isi@f0034000 { + status = "okay"; + }; + + macb1: ethernet@f802c000 { + status = "okay"; + }; + }; + }; + + gpio_keys { + compatible = "gpio-keys"; + + pb_user1 { + label = "pb_user1"; + gpios = <&pioE 27 GPIO_ACTIVE_HIGH>; + linux,code = <0x100>; + wakeup-source; + }; + }; +}; diff --git a/arch/arm/dts/sama5d36.dtsi b/arch/arm/dts/sama5d36.dtsi new file mode 100644 index 0000000..e85139e --- /dev/null +++ b/arch/arm/dts/sama5d36.dtsi @@ -0,0 +1,20 @@ +/* + * sama5d36.dtsi - Device Tree Include file for SAMA5D36 SoC + * + * Copyright (C) 2013 Atmel, + * 2013 Josh Wu josh.wu@atmel.com + * + * Licensed under GPLv2 or later. + */ +#include "sama5d3.dtsi" +#include "sama5d3_can.dtsi" +#include "sama5d3_gmac.dtsi" +#include "sama5d3_emac.dtsi" +#include "sama5d3_lcd.dtsi" +#include "sama5d3_mci2.dtsi" +#include "sama5d3_tcb1.dtsi" +#include "sama5d3_uart.dtsi" + +/ { + compatible = "atmel,sama5d36", "atmel,sama5d3", "atmel,sama5"; +}; diff --git a/arch/arm/dts/sama5d36ek.dts b/arch/arm/dts/sama5d36ek.dts new file mode 100644 index 0000000..1fa7989 --- /dev/null +++ b/arch/arm/dts/sama5d36ek.dts @@ -0,0 +1,57 @@ +/* + * sama5d36ek.dts - Device Tree file for SAMA5D36-EK board + * + * Copyright (C) 2013 Atmel, + * 2013 Josh Wu josh.wu@atmel.com + * + * Licensed under GPLv2 or later. + */ +/dts-v1/; +#include "sama5d36.dtsi" +#include "sama5d3xmb.dtsi" +#include "sama5d3xdm.dtsi" + +/ { + model = "Atmel SAMA5D36-EK"; + compatible = "atmel,sama5d36ek", "atmel,sama5d3xmb", "atmel,sama5d3xcm", "atmel,sama5d36", "atmel,sama5d3", "atmel,sama5"; + + aliases { + spi0 = &spi0; + }; + + ahb { + apb { + spi0: spi@f0004000 { + status = "okay"; + }; + + ssc0: ssc@f0008000 { + status = "okay"; + }; + + can0: can@f000c000 { + status = "okay"; + }; + + i2c0: i2c@f0014000 { + status = "okay"; + }; + + i2c1: i2c@f0018000 { + status = "okay"; + }; + + macb0: ethernet@f0028000 { + status = "okay"; + }; + + macb1: ethernet@f802c000 { + status = "okay"; + }; + }; + }; + + sound { + status = "okay"; + }; +}; diff --git a/arch/arm/dts/sama5d36ek_cmp.dts b/arch/arm/dts/sama5d36ek_cmp.dts new file mode 100644 index 0000000..be41490 --- /dev/null +++ b/arch/arm/dts/sama5d36ek_cmp.dts @@ -0,0 +1,55 @@ +/* + * sama5d36ek_cmp.dts - Device Tree file for SAMA5D36-EK CMP board + * + * Copyright (C) 2016 Atmel, + * + * Licensed under GPLv2 or later. + */ +/dts-v1/; +#include "sama5d36.dtsi" +#include "sama5d3xmb_cmp.dtsi" + +/ { + model = "Atmel SAMA5D36-EK"; + compatible = "atmel,sama5d36ek", "atmel,sama5d3xmb", "atmel,sama5d3xcm", "atmel,sama5d36", "atmel,sama5d3", "atmel,sama5"; + + aliases { + spi0 = &spi0; + }; + + ahb { + apb { + spi0: spi@f0004000 { + status = "okay"; + }; + + ssc0: ssc@f0008000 { + status = "okay"; + }; + + can0: can@f000c000 { + status = "okay"; + }; + + i2c0: i2c@f0014000 { + status = "okay"; + }; + + i2c1: i2c@f0018000 { + status = "okay"; + }; + + macb0: ethernet@f0028000 { + status = "okay"; + }; + + macb1: ethernet@f802c000 { + status = "okay"; + }; + }; + }; + + sound { + status = "okay"; + }; +}; diff --git a/arch/arm/dts/sama5d3_can.dtsi b/arch/arm/dts/sama5d3_can.dtsi new file mode 100644 index 0000000..177f088 --- /dev/null +++ b/arch/arm/dts/sama5d3_can.dtsi @@ -0,0 +1,74 @@ +/* + * sama5d3_can.dtsi - Device Tree Include file for SAMA5D3 SoC with + * CAN support + * + * Copyright (C) 2013 Boris BREZILLON b.brezillon@overkiz.com + * + * Licensed under GPLv2. + */ + +#include <dt-bindings/pinctrl/at91.h> +#include <dt-bindings/interrupt-controller/irq.h> + +/ { + ahb { + apb { + pinctrl@fffff200 { + can0 { + pinctrl_can0_rx_tx: can0_rx_tx { + atmel,pins = + <AT91_PIOD 14 AT91_PERIPH_C AT91_PINCTRL_NONE /* PD14 periph C RX, conflicts with SCK0, SPI0_NPCS1 */ + AT91_PIOD 15 AT91_PERIPH_C AT91_PINCTRL_NONE>; /* PD15 periph C TX, conflicts with CTS0, SPI0_NPCS2 */ + }; + }; + + can1 { + pinctrl_can1_rx_tx: can1_rx_tx { + atmel,pins = + <AT91_PIOB 14 AT91_PERIPH_B AT91_PINCTRL_NONE /* PB14 periph B RX, conflicts with GCRS */ + AT91_PIOB 15 AT91_PERIPH_B AT91_PINCTRL_NONE>; /* PB15 periph B TX, conflicts with GCOL */ + }; + }; + + }; + + pmc: pmc@fffffc00 { + periphck { + can0_clk: can0_clk@40 { + #clock-cells = <0>; + reg = <40>; + atmel,clk-output-range = <0 66000000>; + }; + + can1_clk: can1_clk@41 { + #clock-cells = <0>; + reg = <41>; + atmel,clk-output-range = <0 66000000>; + }; + }; + }; + + can0: can@f000c000 { + compatible = "atmel,at91sam9x5-can"; + reg = <0xf000c000 0x300>; + interrupts = <40 IRQ_TYPE_LEVEL_HIGH 3>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_can0_rx_tx>; + clocks = <&can0_clk>; + clock-names = "can_clk"; + status = "disabled"; + }; + + can1: can@f8010000 { + compatible = "atmel,at91sam9x5-can"; + reg = <0xf8010000 0x300>; + interrupts = <41 IRQ_TYPE_LEVEL_HIGH 3>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_can1_rx_tx>; + clocks = <&can1_clk>; + clock-names = "can_clk"; + status = "disabled"; + }; + }; + }; +}; diff --git a/arch/arm/dts/sama5d3_emac.dtsi b/arch/arm/dts/sama5d3_emac.dtsi new file mode 100644 index 0000000..b654e50 --- /dev/null +++ b/arch/arm/dts/sama5d3_emac.dtsi @@ -0,0 +1,55 @@ +/* + * sama5d3_emac.dtsi - Device Tree Include file for SAMA5D3 SoC with + * Ethernet. + * + * Copyright (C) 2013 Boris BREZILLON b.brezillon@overkiz.com + * + * Licensed under GPLv2. + */ + +#include <dt-bindings/pinctrl/at91.h> +#include <dt-bindings/interrupt-controller/irq.h> + +/ { + ahb { + apb { + pinctrl@fffff200 { + macb1 { + pinctrl_macb1_rmii: macb1_rmii-0 { + atmel,pins = + <AT91_PIOC 0 AT91_PERIPH_A AT91_PINCTRL_NONE /* PC0 periph A ETX0, conflicts with TIOA3 */ + AT91_PIOC 1 AT91_PERIPH_A AT91_PINCTRL_NONE /* PC1 periph A ETX1, conflicts with TIOB3 */ + AT91_PIOC 2 AT91_PERIPH_A AT91_PINCTRL_NONE /* PC2 periph A ERX0, conflicts with TCLK3 */ + AT91_PIOC 3 AT91_PERIPH_A AT91_PINCTRL_NONE /* PC3 periph A ERX1, conflicts with TIOA4 */ + AT91_PIOC 4 AT91_PERIPH_A AT91_PINCTRL_NONE /* PC4 periph A ETXEN, conflicts with TIOB4 */ + AT91_PIOC 5 AT91_PERIPH_A AT91_PINCTRL_NONE /* PC5 periph A ECRSDV,conflicts with TCLK4 */ + AT91_PIOC 6 AT91_PERIPH_A AT91_PINCTRL_NONE /* PC6 periph A ERXER, conflicts with TIOA5 */ + AT91_PIOC 7 AT91_PERIPH_A AT91_PINCTRL_NONE /* PC7 periph A EREFCK, conflicts with TIOB5 */ + AT91_PIOC 8 AT91_PERIPH_A AT91_PINCTRL_NONE /* PC8 periph A EMDC, conflicts with TCLK5 */ + AT91_PIOC 9 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* PC9 periph A EMDIO */ + }; + }; + }; + + pmc: pmc@fffffc00 { + periphck { + macb1_clk: macb1_clk@35 { + #clock-cells = <0>; + reg = <35>; + }; + }; + }; + + macb1: ethernet@f802c000 { + compatible = "cdns,at91sam9260-macb", "cdns,macb"; + reg = <0xf802c000 0x100>; + interrupts = <35 IRQ_TYPE_LEVEL_HIGH 3>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_macb1_rmii>; + clocks = <&macb1_clk>, <&macb1_clk>; + clock-names = "hclk", "pclk"; + status = "disabled"; + }; + }; + }; +}; diff --git a/arch/arm/dts/sama5d3_gmac.dtsi b/arch/arm/dts/sama5d3_gmac.dtsi new file mode 100644 index 0000000..81f6367 --- /dev/null +++ b/arch/arm/dts/sama5d3_gmac.dtsi @@ -0,0 +1,88 @@ +/* + * sama5d3_gmac.dtsi - Device Tree Include file for SAMA5D3 SoC with + * Gigabit Ethernet. + * + * Copyright (C) 2013 Boris BREZILLON b.brezillon@overkiz.com + * + * Licensed under GPLv2. + */ + +#include <dt-bindings/pinctrl/at91.h> +#include <dt-bindings/interrupt-controller/irq.h> + +/ { + ahb { + apb { + pinctrl@fffff200 { + macb0 { + pinctrl_macb0_data_rgmii: macb0_data_rgmii { + atmel,pins = + <AT91_PIOB 0 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB0 periph A GTX0, conflicts with PWMH0 */ + AT91_PIOB 1 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB1 periph A GTX1, conflicts with PWML0 */ + AT91_PIOB 2 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB2 periph A GTX2, conflicts with TK1 */ + AT91_PIOB 3 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB3 periph A GTX3, conflicts with TF1 */ + AT91_PIOB 4 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB4 periph A GRX0, conflicts with PWMH1 */ + AT91_PIOB 5 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB5 periph A GRX1, conflicts with PWML1 */ + AT91_PIOB 6 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB6 periph A GRX2, conflicts with TD1 */ + AT91_PIOB 7 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* PB7 periph A GRX3, conflicts with RK1 */ + }; + pinctrl_macb0_data_gmii: macb0_data_gmii { + atmel,pins = + <AT91_PIOB 19 AT91_PERIPH_B AT91_PINCTRL_NONE /* PB19 periph B GTX4, conflicts with MCI1_CDA */ + AT91_PIOB 20 AT91_PERIPH_B AT91_PINCTRL_NONE /* PB20 periph B GTX5, conflicts with MCI1_DA0 */ + AT91_PIOB 21 AT91_PERIPH_B AT91_PINCTRL_NONE /* PB21 periph B GTX6, conflicts with MCI1_DA1 */ + AT91_PIOB 22 AT91_PERIPH_B AT91_PINCTRL_NONE /* PB22 periph B GTX7, conflicts with MCI1_DA2 */ + AT91_PIOB 23 AT91_PERIPH_B AT91_PINCTRL_NONE /* PB23 periph B GRX4, conflicts with MCI1_DA3 */ + AT91_PIOB 24 AT91_PERIPH_B AT91_PINCTRL_NONE /* PB24 periph B GRX5, conflicts with MCI1_CK */ + AT91_PIOB 25 AT91_PERIPH_B AT91_PINCTRL_NONE /* PB25 periph B GRX6, conflicts with SCK1 */ + AT91_PIOB 26 AT91_PERIPH_B AT91_PINCTRL_NONE>; /* PB26 periph B GRX7, conflicts with CTS1 */ + }; + pinctrl_macb0_signal_rgmii: macb0_signal_rgmii { + atmel,pins = + <AT91_PIOB 8 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB8 periph A GTXCK, conflicts with PWMH2 */ + AT91_PIOB 9 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB9 periph A GTXEN, conflicts with PWML2 */ + AT91_PIOB 11 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB11 periph A GRXCK, conflicts with RD1 */ + AT91_PIOB 13 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB13 periph A GRXER, conflicts with PWML3 */ + AT91_PIOB 16 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB16 periph A GMDC */ + AT91_PIOB 17 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB17 periph A GMDIO */ + AT91_PIOB 18 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* PB18 periph A G125CK */ + }; + pinctrl_macb0_signal_gmii: macb0_signal_gmii { + atmel,pins = + <AT91_PIOB 9 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB9 periph A GTXEN, conflicts with PWML2 */ + AT91_PIOB 10 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB10 periph A GTXER, conflicts with RF1 */ + AT91_PIOB 11 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB11 periph A GRXCK, conflicts with RD1 */ + AT91_PIOB 12 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB12 periph A GRXDV, conflicts with PWMH3 */ + AT91_PIOB 13 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB13 periph A GRXER, conflicts with PWML3 */ + AT91_PIOB 14 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB14 periph A GCRS, conflicts with CANRX1 */ + AT91_PIOB 15 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB15 periph A GCOL, conflicts with CANTX1 */ + AT91_PIOB 16 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB16 periph A GMDC */ + AT91_PIOB 17 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB17 periph A GMDIO */ + AT91_PIOB 27 AT91_PERIPH_B AT91_PINCTRL_NONE>; /* PB27 periph B G125CKO */ + }; + + }; + }; + + pmc: pmc@fffffc00 { + periphck { + macb0_clk: macb0_clk@34 { + #clock-cells = <0>; + reg = <34>; + }; + }; + }; + + macb0: ethernet@f0028000 { + compatible = "atmel,sama5d3-gem"; + reg = <0xf0028000 0x100>; + interrupts = <34 IRQ_TYPE_LEVEL_HIGH 3>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_macb0_data_rgmii &pinctrl_macb0_signal_rgmii>; + clocks = <&macb0_clk>, <&macb0_clk>; + clock-names = "hclk", "pclk"; + status = "disabled"; + }; + }; + }; +}; diff --git a/arch/arm/dts/sama5d3_lcd.dtsi b/arch/arm/dts/sama5d3_lcd.dtsi new file mode 100644 index 0000000..14d7c2b --- /dev/null +++ b/arch/arm/dts/sama5d3_lcd.dtsi @@ -0,0 +1,215 @@ +/* + * sama5d3_lcd.dtsi - Device Tree Include file for SAMA5D3 SoC with + * LCD support + * + * Copyright (C) 2013 Boris BREZILLON b.brezillon@overkiz.com + * + * Licensed under GPLv2. + */ + +#include <dt-bindings/pinctrl/at91.h> +#include <dt-bindings/interrupt-controller/irq.h> + +/ { + ahb { + apb { + hlcdc: hlcdc@f0030000 { + compatible = "atmel,sama5d3-hlcdc"; + reg = <0xf0030000 0x2000>; + interrupts = <36 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&lcdc_clk>, <&lcdck>, <&clk32k>; + clock-names = "periph_clk","sys_clk", "slow_clk"; + status = "disabled"; + + hlcdc-display-controller { + compatible = "atmel,hlcdc-display-controller"; + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0>; + }; + }; + + hlcdc_pwm: hlcdc-pwm { + compatible = "atmel,hlcdc-pwm"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lcd_pwm>; + #pwm-cells = <3>; + }; + }; + + pinctrl@fffff200 { + lcd { + pinctrl_lcd_base: lcd-base-0 { + atmel,pins = + <AT91_PIOA 26 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDVSYNC */ + AT91_PIOA 27 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDHSYNC */ + AT91_PIOA 25 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDDISP */ + AT91_PIOA 29 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDDEN */ + AT91_PIOA 28 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* LCDPCK */ + }; + + pinctrl_lcd_pwm: lcd-pwm-0 { + atmel,pins = <AT91_PIOA 24 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* LCDPWM */ + }; + + pinctrl_lcd_rgb444: lcd-rgb-0 { + atmel,pins = + <AT91_PIOA 0 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD0 pin */ + AT91_PIOA 1 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD1 pin */ + AT91_PIOA 2 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD2 pin */ + AT91_PIOA 3 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD3 pin */ + AT91_PIOA 4 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD4 pin */ + AT91_PIOA 5 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD5 pin */ + AT91_PIOA 6 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD6 pin */ + AT91_PIOA 7 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD7 pin */ + AT91_PIOA 8 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD8 pin */ + AT91_PIOA 9 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD9 pin */ + AT91_PIOA 10 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD10 pin */ + AT91_PIOA 11 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* LCDD11 pin */ + }; + + pinctrl_lcd_rgb565: lcd-rgb-1 { + atmel,pins = + <AT91_PIOA 0 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD0 pin */ + AT91_PIOA 1 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD1 pin */ + AT91_PIOA 2 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD2 pin */ + AT91_PIOA 3 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD3 pin */ + AT91_PIOA 4 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD4 pin */ + AT91_PIOA 5 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD5 pin */ + AT91_PIOA 6 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD6 pin */ + AT91_PIOA 7 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD7 pin */ + AT91_PIOA 8 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD8 pin */ + AT91_PIOA 9 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD9 pin */ + AT91_PIOA 10 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD10 pin */ + AT91_PIOA 11 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD11 pin */ + AT91_PIOA 12 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD12 pin */ + AT91_PIOA 13 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD13 pin */ + AT91_PIOA 14 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD14 pin */ + AT91_PIOA 15 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* LCDD15 pin */ + }; + + pinctrl_lcd_rgb666: lcd-rgb-2 { + atmel,pins = + <AT91_PIOA 0 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD0 pin */ + AT91_PIOA 1 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD1 pin */ + AT91_PIOA 2 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD2 pin */ + AT91_PIOA 3 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD3 pin */ + AT91_PIOA 4 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD4 pin */ + AT91_PIOA 5 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD5 pin */ + AT91_PIOA 6 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD6 pin */ + AT91_PIOA 7 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD7 pin */ + AT91_PIOA 8 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD8 pin */ + AT91_PIOA 9 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD9 pin */ + AT91_PIOA 10 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD10 pin */ + AT91_PIOA 11 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD11 pin */ + AT91_PIOA 12 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD12 pin */ + AT91_PIOA 13 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD13 pin */ + AT91_PIOA 14 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD14 pin */ + AT91_PIOA 15 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD15 pin */ + AT91_PIOA 16 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD16 pin */ + AT91_PIOA 17 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* LCDD17 pin */ + }; + + pinctrl_lcd_rgb666_alt: lcd-rgb-2-alt { + atmel,pins = + <AT91_PIOA 0 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD0 pin */ + AT91_PIOA 1 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD1 pin */ + AT91_PIOA 2 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD2 pin */ + AT91_PIOA 3 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD3 pin */ + AT91_PIOA 4 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD4 pin */ + AT91_PIOA 5 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD5 pin */ + AT91_PIOA 6 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD6 pin */ + AT91_PIOA 7 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD7 pin */ + AT91_PIOA 8 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD8 pin */ + AT91_PIOA 9 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD9 pin */ + AT91_PIOA 10 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD10 pin */ + AT91_PIOA 11 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD11 pin */ + AT91_PIOA 12 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD12 pin */ + AT91_PIOA 13 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD13 pin */ + AT91_PIOA 14 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD14 pin */ + AT91_PIOA 15 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD15 pin */ + AT91_PIOC 14 AT91_PERIPH_C AT91_PINCTRL_NONE /* LCDD16 pin */ + AT91_PIOC 13 AT91_PERIPH_C AT91_PINCTRL_NONE>; /* LCDD17 pin */ + }; + + pinctrl_lcd_rgb888: lcd-rgb-3 { + atmel,pins = + <AT91_PIOA 0 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD0 pin */ + AT91_PIOA 1 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD1 pin */ + AT91_PIOA 2 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD2 pin */ + AT91_PIOA 3 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD3 pin */ + AT91_PIOA 4 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD4 pin */ + AT91_PIOA 5 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD5 pin */ + AT91_PIOA 6 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD6 pin */ + AT91_PIOA 7 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD7 pin */ + AT91_PIOA 8 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD8 pin */ + AT91_PIOA 9 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD9 pin */ + AT91_PIOA 10 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD10 pin */ + AT91_PIOA 11 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD11 pin */ + AT91_PIOA 12 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD12 pin */ + AT91_PIOA 13 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD13 pin */ + AT91_PIOA 14 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD14 pin */ + AT91_PIOA 15 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD15 pin */ + AT91_PIOA 16 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD16 pin */ + AT91_PIOA 17 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD17 pin */ + AT91_PIOA 18 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD18 pin */ + AT91_PIOA 19 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD19 pin */ + AT91_PIOA 20 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD20 pin */ + AT91_PIOA 21 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD21 pin */ + AT91_PIOA 22 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD22 pin */ + AT91_PIOA 23 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* LCDD23 pin */ + }; + + pinctrl_lcd_rgb888_alt: lcd-rgb-3-alt { + atmel,pins = + <AT91_PIOA 0 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD0 pin */ + AT91_PIOA 1 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD1 pin */ + AT91_PIOA 2 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD2 pin */ + AT91_PIOA 3 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD3 pin */ + AT91_PIOA 4 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD4 pin */ + AT91_PIOA 5 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD5 pin */ + AT91_PIOA 6 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD6 pin */ + AT91_PIOA 7 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD7 pin */ + AT91_PIOA 8 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD8 pin */ + AT91_PIOA 9 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD9 pin */ + AT91_PIOA 10 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD10 pin */ + AT91_PIOA 11 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD11 pin */ + AT91_PIOA 12 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD12 pin */ + AT91_PIOA 13 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD13 pin */ + AT91_PIOA 14 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD14 pin */ + AT91_PIOA 15 AT91_PERIPH_A AT91_PINCTRL_NONE /* LCDD15 pin */ + AT91_PIOC 14 AT91_PERIPH_C AT91_PINCTRL_NONE /* LCDD16 pin */ + AT91_PIOC 13 AT91_PERIPH_C AT91_PINCTRL_NONE /* LCDD17 pin */ + AT91_PIOC 12 AT91_PERIPH_C AT91_PINCTRL_NONE /* LCDD18 pin */ + AT91_PIOC 11 AT91_PERIPH_C AT91_PINCTRL_NONE /* LCDD19 pin */ + AT91_PIOC 10 AT91_PERIPH_C AT91_PINCTRL_NONE /* LCDD20 pin */ + AT91_PIOC 15 AT91_PERIPH_C AT91_PINCTRL_NONE /* LCDD21 pin */ + AT91_PIOE 27 AT91_PERIPH_C AT91_PINCTRL_NONE /* LCDD22 pin */ + AT91_PIOE 28 AT91_PERIPH_C AT91_PINCTRL_NONE>; /* LCDD23 pin */ + }; + }; + }; + + pmc: pmc@fffffc00 { + periphck { + lcdc_clk: lcdc_clk@36 { + #clock-cells = <0>; + reg = <36>; + }; + }; + + systemck { + lcdck: lcdck@3 { + #clock-cells = <0>; + reg = <3>; + clocks = <&mck>; + }; + }; + }; + }; + }; +}; diff --git a/arch/arm/dts/sama5d3_mci2.dtsi b/arch/arm/dts/sama5d3_mci2.dtsi new file mode 100644 index 0000000..2d289ed --- /dev/null +++ b/arch/arm/dts/sama5d3_mci2.dtsi @@ -0,0 +1,59 @@ +/* + * sama5d3_mci2.dtsi - Device Tree Include file for SAMA5D3 SoC with + * 3 MMC ports + * + * Copyright (C) 2013 Boris BREZILLON b.brezillon@overkiz.com + * + * Licensed under GPLv2. + */ + +#include <dt-bindings/pinctrl/at91.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/clock/at91.h> + +/ { + ahb { + apb { + pinctrl@fffff200 { + mmc2 { + pinctrl_mmc2_clk_cmd_dat0: mmc2_clk_cmd_dat0 { + atmel,pins = + <AT91_PIOC 15 AT91_PERIPH_A AT91_PINCTRL_NONE /* PC15 periph A MCI2_CK, conflicts with PCK2 */ + AT91_PIOC 10 AT91_PERIPH_A AT91_PINCTRL_PULL_UP /* PC10 periph A MCI2_CDA with pullup */ + AT91_PIOC 11 AT91_PERIPH_A AT91_PINCTRL_PULL_UP>; /* PC11 periph A MCI2_DA0 with pullup */ + }; + pinctrl_mmc2_dat1_3: mmc2_dat1_3 { + atmel,pins = + <AT91_PIOC 12 AT91_PERIPH_A AT91_PINCTRL_PULL_UP /* PC12 periph A MCI2_DA1 with pullup, conflicts with TIOA1 */ + AT91_PIOC 13 AT91_PERIPH_A AT91_PINCTRL_PULL_UP /* PC13 periph A MCI2_DA2 with pullup, conflicts with TIOB1 */ + AT91_PIOC 14 AT91_PERIPH_A AT91_PINCTRL_PULL_UP>; /* PC14 periph A MCI2_DA3 with pullup, conflicts with TCLK1 */ + }; + }; + }; + + pmc: pmc@fffffc00 { + periphck { + mci2_clk: mci2_clk@23 { + #clock-cells = <0>; + reg = <23>; + }; + }; + }; + + mmc2: mmc@f8004000 { + compatible = "atmel,hsmci"; + reg = <0xf8004000 0x600>; + interrupts = <23 IRQ_TYPE_LEVEL_HIGH 0>; + dmas = <&dma1 2 AT91_DMA_CFG_PER_ID(1)>; + dma-names = "rxtx"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_mmc2_clk_cmd_dat0 &pinctrl_mmc2_dat1_3>; + clocks = <&mci2_clk>; + clock-names = "mci_clk"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + }; + }; +}; diff --git a/arch/arm/dts/sama5d3_tcb1.dtsi b/arch/arm/dts/sama5d3_tcb1.dtsi new file mode 100644 index 0000000..5be60b4 --- /dev/null +++ b/arch/arm/dts/sama5d3_tcb1.dtsi @@ -0,0 +1,39 @@ +/* + * sama5d3_tcb1.dtsi - Device Tree Include file for SAMA5D3 SoC with + * 2 TC blocks. + * + * Copyright (C) 2013 Boris BREZILLON b.brezillon@overkiz.com + * + * Licensed under GPLv2. + */ + +#include <dt-bindings/pinctrl/at91.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/clock/at91.h> + +/ { + aliases { + tcb1 = &tcb1; + }; + + ahb { + apb { + pmc: pmc@fffffc00 { + periphck { + tcb1_clk: tcb1_clk@27 { + #clock-cells = <0>; + reg = <27>; + }; + }; + }; + + tcb1: timer@f8014000 { + compatible = "atmel,at91sam9x5-tcb"; + reg = <0xf8014000 0x100>; + interrupts = <27 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&tcb1_clk>, <&clk32k>; + clock-names = "t0_clk", "slow_clk"; + }; + }; + }; +}; diff --git a/arch/arm/dts/sama5d3_uart.dtsi b/arch/arm/dts/sama5d3_uart.dtsi new file mode 100644 index 0000000..6a547fd --- /dev/null +++ b/arch/arm/dts/sama5d3_uart.dtsi @@ -0,0 +1,79 @@ +/* + * sama5d3_uart.dtsi - Device Tree Include file for SAMA5D3 SoC with + * UART support + * + * Copyright (C) 2013 Boris BREZILLON b.brezillon@overkiz.com + * + * Licensed under GPLv2. + */ + +#include <dt-bindings/pinctrl/at91.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/clock/at91.h> + +/ { + aliases { + serial5 = &uart0; + serial6 = &uart1; + }; + + ahb { + apb { + pinctrl@fffff200 { + uart0 { + pinctrl_uart0: uart0-0 { + atmel,pins = + <AT91_PIOC 29 AT91_PERIPH_A AT91_PINCTRL_NONE /* PC29 periph A, conflicts with PWMFI2, ISI_D8 */ + AT91_PIOC 30 AT91_PERIPH_A AT91_PINCTRL_PULL_UP>; /* PC30 periph A with pullup, conflicts with ISI_PCK */ + }; + }; + + uart1 { + pinctrl_uart1: uart1-0 { + atmel,pins = + <AT91_PIOA 30 AT91_PERIPH_B AT91_PINCTRL_NONE /* PA30 periph B, conflicts with TWD0, ISI_VSYNC */ + AT91_PIOA 31 AT91_PERIPH_B AT91_PINCTRL_PULL_UP>; /* PA31 periph B with pullup, conflicts with TWCK0, ISI_HSYNC */ + }; + }; + }; + + pmc: pmc@fffffc00 { + periphck { + uart0_clk: uart0_clk@16 { + #clock-cells = <0>; + reg = <16>; + atmel,clk-output-range = <0 66000000>; + }; + + uart1_clk: uart1_clk@17 { + #clock-cells = <0>; + reg = <17>; + atmel,clk-output-range = <0 66000000>; + }; + }; + }; + + uart0: serial@f0024000 { + compatible = "atmel,at91sam9260-usart"; + reg = <0xf0024000 0x200>; + interrupts = <16 IRQ_TYPE_LEVEL_HIGH 5>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart0>; + clocks = <&uart0_clk>; + clock-names = "usart"; + status = "disabled"; + }; + + uart1: serial@f8028000 { + compatible = "atmel,at91sam9260-usart"; + reg = <0xf8028000 0x200>; + interrupts = <17 IRQ_TYPE_LEVEL_HIGH 5>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + clocks = <&uart1_clk>; + clock-names = "usart"; + status = "disabled"; + }; + }; + }; +}; diff --git a/arch/arm/dts/sama5d3xcm.dtsi b/arch/arm/dts/sama5d3xcm.dtsi new file mode 100644 index 0000000..2cf9c36 --- /dev/null +++ b/arch/arm/dts/sama5d3xcm.dtsi @@ -0,0 +1,123 @@ +/* + * sama5d3xcm.dtsi - Device Tree Include file for SAMA5D3x CPU Module + * + * Copyright (C) 2013 Atmel, + * 2013 Ludovic Desroches ludovic.desroches@atmel.com + * + * Licensed under GPLv2 or later. + */ + +/ { + compatible = "atmel,sama5d3xcm", "atmel,sama5d3", "atmel,sama5"; + + chosen { + bootargs = "rootfstype=ubifs ubi.mtd=5 root=ubi0:rootfs"; + stdout-path = "serial0:115200n8"; + }; + + memory { + reg = <0x20000000 0x20000000>; + }; + + clocks { + slow_xtal { + clock-frequency = <32768>; + }; + + main_xtal { + clock-frequency = <12000000>; + }; + }; + + ahb { + apb { + spi0: spi@f0004000 { + cs-gpios = <&pioD 13 0>, <0>, <0>, <0>; + }; + + macb0: ethernet@f0028000 { + phy-mode = "rgmii"; + #address-cells = <1>; + #size-cells = <0>; + + ethernet-phy@1 { + reg = <0x1>; + interrupt-parent = <&pioB>; + interrupts = <25 IRQ_TYPE_EDGE_FALLING>; + txen-skew-ps = <800>; + txc-skew-ps = <3000>; + rxdv-skew-ps = <400>; + rxc-skew-ps = <3000>; + rxd0-skew-ps = <400>; + rxd1-skew-ps = <400>; + rxd2-skew-ps = <400>; + rxd3-skew-ps = <400>; + }; + + ethernet-phy@7 { + reg = <0x7>; + interrupt-parent = <&pioB>; + interrupts = <25 IRQ_TYPE_EDGE_FALLING>; + txen-skew-ps = <800>; + txc-skew-ps = <3000>; + rxdv-skew-ps = <400>; + rxc-skew-ps = <3000>; + rxd0-skew-ps = <400>; + rxd1-skew-ps = <400>; + rxd2-skew-ps = <400>; + rxd3-skew-ps = <400>; + }; + }; + }; + + nand0: nand@60000000 { + nand-bus-width = <8>; + nand-ecc-mode = "hw"; + atmel,has-pmecc; + atmel,pmecc-cap = <4>; + atmel,pmecc-sector-size = <512>; + nand-on-flash-bbt; + status = "okay"; + + at91bootstrap@0 { + label = "at91bootstrap"; + reg = <0x0 0x40000>; + }; + + bootloader@40000 { + label = "bootloader"; + reg = <0x40000 0x80000>; + }; + + bootloaderenv@c0000 { + label = "bootloader env"; + reg = <0xc0000 0xc0000>; + }; + + dtb@180000 { + label = "device tree"; + reg = <0x180000 0x80000>; + }; + + kernel@200000 { + label = "kernel"; + reg = <0x200000 0x600000>; + }; + + rootfs@800000 { + label = "rootfs"; + reg = <0x800000 0x0f800000>; + }; + }; + }; + + leds { + compatible = "gpio-leds"; + + d2 { + label = "d2"; + gpios = <&pioE 25 GPIO_ACTIVE_LOW>; /* PE25, conflicts with A25, RXD2 */ + linux,default-trigger = "heartbeat"; + }; + }; +}; diff --git a/arch/arm/dts/sama5d3xcm_cmp.dtsi b/arch/arm/dts/sama5d3xcm_cmp.dtsi new file mode 100644 index 0000000..77638c3 --- /dev/null +++ b/arch/arm/dts/sama5d3xcm_cmp.dtsi @@ -0,0 +1,166 @@ +/* + * sama5d3xcm_cmp.dtsi - Device Tree Include file for SAMA5D36 CMP CPU Module + * + * Copyright (C) 2016 Atmel, + * + * Licensed under GPLv2 or later. + */ + +/ { + compatible = "atmel,sama5d3xcm", "atmel,sama5d3", "atmel,sama5"; + + chosen { + bootargs = "rootfstype=ubifs ubi.mtd=5 root=ubi0:rootfs"; + stdout-path = "serial0:115200n8"; + }; + + memory { + reg = <0x20000000 0x20000000>; + }; + + clocks { + slow_xtal { + clock-frequency = <32768>; + }; + + main_xtal { + clock-frequency = <12000000>; + }; + }; + + ahb { + apb { + spi0: spi@f0004000 { + cs-gpios = <&pioD 13 0>, <0>, <0>, <0>; + }; + + macb0: ethernet@f0028000 { + phy-mode = "rgmii"; + #address-cells = <1>; + #size-cells = <0>; + + ethernet-phy@1 { + reg = <0x1>; + interrupt-parent = <&pioB>; + interrupts = <25 IRQ_TYPE_EDGE_FALLING>; + txen-skew-ps = <800>; + txc-skew-ps = <3000>; + rxdv-skew-ps = <400>; + rxc-skew-ps = <3000>; + rxd0-skew-ps = <400>; + rxd1-skew-ps = <400>; + rxd2-skew-ps = <400>; + rxd3-skew-ps = <400>; + }; + + ethernet-phy@7 { + reg = <0x7>; + interrupt-parent = <&pioB>; + interrupts = <25 IRQ_TYPE_EDGE_FALLING>; + txen-skew-ps = <800>; + txc-skew-ps = <3000>; + rxdv-skew-ps = <400>; + rxc-skew-ps = <3000>; + rxd0-skew-ps = <400>; + rxd1-skew-ps = <400>; + rxd2-skew-ps = <400>; + rxd3-skew-ps = <400>; + }; + }; + + i2c1: i2c@f0018000 { + pmic: act8865@5b { + compatible = "active-semi,act8865"; + reg = <0x5b>; + status = "disabled"; + + regulators { + vcc_1v8_reg: DCDC_REG1 { + regulator-name = "VCC_1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + }; + + vcc_1v2_reg: DCDC_REG2 { + regulator-name = "VCC_1V2"; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1300000>; + regulator-always-on; + }; + + vcc_3v3_reg: DCDC_REG3 { + regulator-name = "VCC_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vddana_reg: LDO_REG1 { + regulator-name = "VDDANA"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vddfuse_reg: LDO_REG2 { + regulator-name = "FUSE_2V5"; + regulator-min-microvolt = <2500000>; + regulator-max-microvolt = <2500000>; + }; + }; + }; + }; + }; + + nand0: nand@60000000 { + nand-bus-width = <8>; + nand-ecc-mode = "hw"; + atmel,has-pmecc; + atmel,pmecc-cap = <4>; + atmel,pmecc-sector-size = <512>; + nand-on-flash-bbt; + status = "okay"; + + at91bootstrap@0 { + label = "at91bootstrap"; + reg = <0x0 0x40000>; + }; + + bootloader@40000 { + label = "bootloader"; + reg = <0x40000 0x80000>; + }; + + bootloaderenv@c0000 { + label = "bootloader env"; + reg = <0xc0000 0xc0000>; + }; + + dtb@180000 { + label = "device tree"; + reg = <0x180000 0x80000>; + }; + + kernel@200000 { + label = "kernel"; + reg = <0x200000 0x600000>; + }; + + rootfs@800000 { + label = "rootfs"; + reg = <0x800000 0x0f800000>; + }; + }; + }; + + leds { + compatible = "gpio-leds"; + + d2 { + label = "d2"; + gpios = <&pioE 25 GPIO_ACTIVE_LOW>; /* PE25, conflicts with A25, RXD2 */ + linux,default-trigger = "heartbeat"; + }; + }; +}; diff --git a/arch/arm/dts/sama5d3xdm.dtsi b/arch/arm/dts/sama5d3xdm.dtsi new file mode 100644 index 0000000..035ab72 --- /dev/null +++ b/arch/arm/dts/sama5d3xdm.dtsi @@ -0,0 +1,41 @@ +/* + * sama5d3dm.dtsi - Device Tree file for SAMA5 display module + * + * Copyright (C) 2013 Atmel, + * 2013 Ludovic Desroches ludovic.desroches@atmel.com + * + * Licensed under GPLv2 or later. + */ + +/ { + ahb { + apb { + i2c1: i2c@f0018000 { + qt1070: keyboard@1b { + compatible = "qt1070"; + reg = <0x1b>; + interrupt-parent = <&pioE>; + interrupts = <31 0x0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_qt1070_irq>; + wakeup-source; + }; + }; + + adc0: adc@f8018000 { + atmel,adc-ts-wires = <4>; + atmel,adc-ts-pressure-threshold = <10000>; + status = "okay"; + }; + + pinctrl@fffff200 { + board { + pinctrl_qt1070_irq: qt1070_irq { + atmel,pins = + <AT91_PIOE 31 AT91_PERIPH_GPIO AT91_PINCTRL_PULL_UP_DEGLITCH>; /* PE31 GPIO with pull up deglith */ + }; + }; + }; + }; + }; +}; diff --git a/arch/arm/dts/sama5d3xmb.dtsi b/arch/arm/dts/sama5d3xmb.dtsi new file mode 100644 index 0000000..0f8fe82 --- /dev/null +++ b/arch/arm/dts/sama5d3xmb.dtsi @@ -0,0 +1,221 @@ +/* + * sama5d3xmb.dts - Device Tree file for SAMA5D3x mother board + * + * Copyright (C) 2013 Atmel, + * 2013 Ludovic Desroches ludovic.desroches@atmel.com + * + * Licensed under GPLv2 or later. + */ +#include "sama5d3xcm.dtsi" + +/ { + compatible = "atmel,sama5d3xmb", "atmel,sama5d3xcm", "atmel,sama5d3", "atmel,sama5"; + + ahb { + apb { + mmc0: mmc@f0000000 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_mmc0_clk_cmd_dat0 &pinctrl_mmc0_dat1_3 &pinctrl_mmc0_cd>; + status = "okay"; + slot@0 { + reg = <0>; + bus-width = <4>; + cd-gpios = <&pioD 17 GPIO_ACTIVE_HIGH>; + }; + }; + + spi0: spi@f0004000 { + dmas = <0>, <0>; /* Do not use DMA for spi0 */ + + spi_flash@0 { + compatible = "spi-flash"; + spi-max-frequency = <50000000>; + reg = <0>; + }; + }; + + ssc0: ssc@f0008000 { + atmel,clk-from-rk-pin; + }; + + /* + * i2c0 conflicts with ISI: + * disable it to allow the use of ISI + * can not enable audio when i2c0 disabled + */ + i2c0: i2c@f0014000 { + wm8904: wm8904@1a { + compatible = "wlf,wm8904"; + reg = <0x1a>; + clocks = <&pck0>; + clock-names = "mclk"; + }; + }; + + i2c1: i2c@f0018000 { + ov2640: camera@0x30 { + compatible = "ovti,ov2640"; + reg = <0x30>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pck1_as_isi_mck &pinctrl_sensor_power &pinctrl_sensor_reset>; + resetb-gpios = <&pioE 24 GPIO_ACTIVE_LOW>; + pwdn-gpios = <&pioE 29 GPIO_ACTIVE_HIGH>; + /* use pck1 for the master clock of ov2640 */ + clocks = <&pck1>; + clock-names = "xvclk"; + assigned-clocks = <&pck1>; + assigned-clock-rates = <25000000>; + + port { + ov2640_0: endpoint { + remote-endpoint = <&isi_0>; + bus-width = <8>; + }; + }; + }; + }; + + usart1: serial@f0020000 { + dmas = <0>, <0>; /* Do not use DMA for usart1 */ + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usart1 &pinctrl_usart1_rts_cts>; + status = "okay"; + }; + + isi: isi@f0034000 { + port { + isi_0: endpoint { + remote-endpoint = <&ov2640_0>; + bus-width = <8>; + vsync-active = <1>; + hsync-active = <1>; + }; + }; + }; + + mmc1: mmc@f8000000 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_mmc1_clk_cmd_dat0 &pinctrl_mmc1_dat1_3 &pinctrl_mmc1_cd>; + status = "okay"; + slot@0 { + reg = <0>; + bus-width = <4>; + cd-gpios = <&pioD 18 GPIO_ACTIVE_HIGH>; + }; + }; + + adc0: adc@f8018000 { + pinctrl-names = "default"; + pinctrl-0 = < + &pinctrl_adc0_adtrg + &pinctrl_adc0_ad0 + &pinctrl_adc0_ad1 + &pinctrl_adc0_ad2 + &pinctrl_adc0_ad3 + &pinctrl_adc0_ad4 + >; + status = "okay"; + }; + + macb1: ethernet@f802c000 { + phy-mode = "rmii"; + + #address-cells = <1>; + #size-cells = <0>; + phy0: ethernet-phy@1 { + /*interrupt-parent = <&pioE>;*/ + /*interrupts = <30 IRQ_TYPE_EDGE_FALLING>;*/ + reg = <1>; + }; + }; + + pinctrl@fffff200 { + board { + pinctrl_mmc0_cd: mmc0_cd { + atmel,pins = + <AT91_PIOD 17 AT91_PERIPH_GPIO AT91_PINCTRL_PULL_UP_DEGLITCH>; /* PD17 GPIO with pullup deglitch */ + }; + + pinctrl_mmc1_cd: mmc1_cd { + atmel,pins = + <AT91_PIOD 18 AT91_PERIPH_GPIO AT91_PINCTRL_PULL_UP_DEGLITCH>; /* PD18 GPIO with pullup deglitch */ + }; + + pinctrl_pck0_as_audio_mck: pck0_as_audio_mck { + atmel,pins = + <AT91_PIOD 30 AT91_PERIPH_B AT91_PINCTRL_NONE>; /* PD30 periph B */ + }; + + pinctrl_pck1_as_isi_mck: pck1_as_isi_mck-0 { + atmel,pins = + <AT91_PIOD 31 AT91_PERIPH_B AT91_PINCTRL_NONE>; /* PD31 periph B ISI_MCK */ + }; + + pinctrl_sensor_reset: sensor_reset-0 { + atmel,pins = + <AT91_PIOE 24 AT91_PERIPH_GPIO AT91_PINCTRL_NONE>; /* PE24 gpio */ + }; + + pinctrl_sensor_power: sensor_power-0 { + atmel,pins = + <AT91_PIOE 29 AT91_PERIPH_GPIO AT91_PINCTRL_NONE>; /* PE29 gpio */ + }; + + pinctrl_usba_vbus: usba_vbus { + atmel,pins = + <AT91_PIOD 29 AT91_PERIPH_GPIO AT91_PINCTRL_DEGLITCH>; /* PD29 GPIO with deglitch */ + }; + }; + }; + + dbgu: serial@ffffee00 { + dmas = <0>, <0>; /* Do not use DMA for dbgu */ + status = "okay"; + }; + + watchdog@fffffe40 { + status = "okay"; + }; + }; + + usb0: gadget@00500000 { + atmel,vbus-gpio = <&pioD 29 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usba_vbus>; + status = "okay"; + }; + + usb1: ohci@00600000 { + num-ports = <3>; + atmel,vbus-gpio = <&pioD 25 GPIO_ACTIVE_HIGH + &pioD 26 GPIO_ACTIVE_LOW + &pioD 27 GPIO_ACTIVE_LOW + >; + status = "okay"; + }; + + usb2: ehci@00700000 { + status = "okay"; + }; + }; + + sound { + compatible = "atmel,asoc-wm8904"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pck0_as_audio_mck>; + + atmel,model = "wm8904 @ SAMA5D3EK"; + atmel,audio-routing = + "Headphone Jack", "HPOUTL", + "Headphone Jack", "HPOUTR", + "IN2L", "Line In Jack", + "IN2R", "Line In Jack", + "Mic", "MICBIAS", + "IN1L", "Mic"; + + atmel,ssc-controller = <&ssc0>; + atmel,audio-codec = <&wm8904>; + + status = "disabled"; + }; +}; diff --git a/arch/arm/dts/sama5d3xmb_cmp.dtsi b/arch/arm/dts/sama5d3xmb_cmp.dtsi new file mode 100644 index 0000000..6f706d8 --- /dev/null +++ b/arch/arm/dts/sama5d3xmb_cmp.dtsi @@ -0,0 +1,230 @@ +/* + * sama5d3xmb_cmp.dts - Device Tree file for SAMA5D3x CMP mother board + * + * Copyright (C) 2016 Atmel, + * + * Licensed under GPLv2 or later. + */ +#include "sama5d3xcm_cmp.dtsi" + +/ { + compatible = "atmel,sama5d3xmb", "atmel,sama5d3xcm", "atmel,sama5d3", "atmel,sama5"; + + ahb { + apb { + mmc0: mmc@f0000000 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_mmc0_clk_cmd_dat0 &pinctrl_mmc0_dat1_3 &pinctrl_mmc0_cd>; + status = "okay"; + slot@0 { + reg = <0>; + bus-width = <4>; + cd-gpios = <&pioD 17 GPIO_ACTIVE_HIGH>; + }; + }; + + spi0: spi@f0004000 { + dmas = <0>, <0>; /* Do not use DMA for spi0 */ + + spi_flash@0 { + compatible = "spi-flash"; + spi-max-frequency = <50000000>; + reg = <0>; + }; + }; + + ssc0: ssc@f0008000 { + atmel,clk-from-rk-pin; + }; + + /* + * i2c0 conflicts with ISI: + * disable it to allow the use of ISI + * can not enable audio when i2c0 disabled + */ + i2c0: i2c@f0014000 { + wm8904: wm8904@1a { + compatible = "wlf,wm8904"; + reg = <0x1a>; + clocks = <&pck0>; + clock-names = "mclk"; + }; + }; + + i2c1: i2c@f0018000 { + ov2640: camera@0x30 { + compatible = "ovti,ov2640"; + reg = <0x30>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pck1_as_isi_mck &pinctrl_sensor_power &pinctrl_sensor_reset>; + resetb-gpios = <&pioE 24 GPIO_ACTIVE_LOW>; + pwdn-gpios = <&pioE 29 GPIO_ACTIVE_HIGH>; + /* use pck1 for the master clock of ov2640 */ + clocks = <&pck1>; + clock-names = "xvclk"; + assigned-clocks = <&pck1>; + assigned-clock-rates = <25000000>; + + port { + ov2640_0: endpoint { + remote-endpoint = <&isi_0>; + bus-width = <8>; + }; + }; + }; + }; + + usart1: serial@f0020000 { + dmas = <0>, <0>; /* Do not use DMA for usart1 */ + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usart1 &pinctrl_usart1_rts_cts>; + status = "okay"; + }; + + isi: isi@f0034000 { + port { + isi_0: endpoint { + remote-endpoint = <&ov2640_0>; + bus-width = <8>; + vsync-active = <1>; + hsync-active = <1>; + }; + }; + }; + + mmc1: mmc@f8000000 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_mmc1_clk_cmd_dat0 &pinctrl_mmc1_dat1_3 &pinctrl_mmc1_cd>; + status = "okay"; + slot@0 { + reg = <0>; + bus-width = <4>; + cd-gpios = <&pioD 18 GPIO_ACTIVE_HIGH>; + }; + }; + + adc0: adc@f8018000 { + pinctrl-names = "default"; + pinctrl-0 = < + &pinctrl_adc0_adtrg + &pinctrl_adc0_ad0 + &pinctrl_adc0_ad1 + &pinctrl_adc0_ad2 + &pinctrl_adc0_ad3 + &pinctrl_adc0_ad4 + >; + status = "okay"; + }; + + macb1: ethernet@f802c000 { + phy-mode = "rmii"; + + #address-cells = <1>; + #size-cells = <0>; + phy0: ethernet-phy@1 { + /*interrupt-parent = <&pioE>;*/ + /*interrupts = <30 IRQ_TYPE_EDGE_FALLING>;*/ + reg = <1>; + }; + }; + + pinctrl@fffff200 { + board { + pinctrl_gpio_keys: gpio_keys { + atmel,pins = + <AT91_PIOE 27 AT91_PERIPH_GPIO AT91_PINCTRL_PULL_UP>; + }; + + pinctrl_mmc0_cd: mmc0_cd { + atmel,pins = + <AT91_PIOD 17 AT91_PERIPH_GPIO AT91_PINCTRL_PULL_UP_DEGLITCH>; /* PD17 GPIO with pullup deglitch */ + }; + + pinctrl_mmc1_cd: mmc1_cd { + atmel,pins = + <AT91_PIOD 18 AT91_PERIPH_GPIO AT91_PINCTRL_PULL_UP_DEGLITCH>; /* PD18 GPIO with pullup deglitch */ + }; + + pinctrl_pck0_as_audio_mck: pck0_as_audio_mck { + atmel,pins = + <AT91_PIOD 30 AT91_PERIPH_B AT91_PINCTRL_NONE>; /* PD30 periph B */ + }; + + pinctrl_pck1_as_isi_mck: pck1_as_isi_mck-0 { + atmel,pins = + <AT91_PIOD 31 AT91_PERIPH_B AT91_PINCTRL_NONE>; /* PD31 periph B ISI_MCK */ + }; + + pinctrl_sensor_reset: sensor_reset-0 { + atmel,pins = + <AT91_PIOE 24 AT91_PERIPH_GPIO AT91_PINCTRL_NONE>; /* PE24 gpio */ + }; + + pinctrl_sensor_power: sensor_power-0 { + atmel,pins = + <AT91_PIOE 29 AT91_PERIPH_GPIO AT91_PINCTRL_NONE>; /* PE29 gpio */ + }; + + pinctrl_usba_vbus: usba_vbus { + atmel,pins = + <AT91_PIOD 29 AT91_PERIPH_GPIO AT91_PINCTRL_DEGLITCH>; /* PD29 GPIO with deglitch */ + }; + }; + }; + + dbgu: serial@ffffee00 { + dmas = <0>, <0>; /* Do not use DMA for dbgu */ + status = "okay"; + }; + + watchdog@fffffe40 { + status = "okay"; + }; + }; + + usb0: gadget@00500000 { + atmel,vbus-gpio = <&pioD 29 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usba_vbus>; + status = "okay"; + }; + }; + + sound { + compatible = "atmel,asoc-wm8904"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pck0_as_audio_mck>; + + atmel,model = "wm8904 @ SAMA5D3EK"; + atmel,audio-routing = + "Headphone Jack", "HPOUTL", + "Headphone Jack", "HPOUTR", + "IN2L", "Line In Jack", + "IN2R", "Line In Jack", + "Mic", "MICBIAS", + "IN1L", "Mic"; + + atmel,ssc-controller = <&ssc0>; + atmel,audio-codec = <&wm8904>; + + status = "disabled"; + }; + + /* Conflict with LCD pins */ + gpio_keys { + compatible = "gpio-keys"; + status = "okay"; + + #address-cells = <1>; + #size-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_keys>; + + pb_user1 { + label = "pb_user1"; + gpios = <&pioE 27 GPIO_ACTIVE_HIGH>; + linux,code = <0x100>; + gpio-key,wakeup; + }; + }; +};
Add the dts file for sama5d3 Xplained board.
The dts files is copied from the kernel, do changes. - fix the compile warning.
Signed-off-by: Wenyou Yang wenyou.yang@atmel.com ---
Changes in v2: None
arch/arm/dts/Makefile | 3 + arch/arm/dts/at91-sama5d3_xplained.dts | 341 +++++++++++++++++++++++++++++++++ 2 files changed, 344 insertions(+) create mode 100644 arch/arm/dts/at91-sama5d3_xplained.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 5bc4f06..a65a983 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -298,6 +298,9 @@ dtb-$(CONFIG_TARGET_SAMA5D3XEK) += \ sama5d36ek.dtb \ sama5d36ek_cmp.dtb
+dtb-$(CONFIG_TARGET_SAMA5D3_XPLAINED) += \ + at91-sama5d3_xplained.dtb + targets += $(dtb-y)
# Add any required device tree compiler flags here diff --git a/arch/arm/dts/at91-sama5d3_xplained.dts b/arch/arm/dts/at91-sama5d3_xplained.dts new file mode 100644 index 0000000..2ee2e3b --- /dev/null +++ b/arch/arm/dts/at91-sama5d3_xplained.dts @@ -0,0 +1,341 @@ +/* + * at91-sama5d3_xplained.dts - Device Tree file for the SAMA5D3 Xplained board + * + * Copyright (C) 2014 Atmel, + * 2014 Nicolas Ferre nicolas.ferre@atmel.com + * + * Licensed under GPLv2 or later. + */ +/dts-v1/; +#include "sama5d36.dtsi" + +/ { + model = "SAMA5D3 Xplained"; + compatible = "atmel,sama5d3-xplained", "atmel,sama5d3", "atmel,sama5"; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + aliases { + spi0 = &spi0; + }; + + memory { + reg = <0x20000000 0x10000000>; + }; + + clocks { + slow_xtal { + clock-frequency = <32768>; + }; + + main_xtal { + clock-frequency = <12000000>; + }; + }; + + ahb { + apb { + mmc0: mmc@f0000000 { + pinctrl-0 = <&pinctrl_mmc0_clk_cmd_dat0 &pinctrl_mmc0_dat1_3 &pinctrl_mmc0_dat4_7 &pinctrl_mmc0_cd>; + vmmc-supply = <&vcc_mmc0_reg>; + vqmmc-supply = <&vcc_3v3_reg>; + status = "okay"; + slot@0 { + reg = <0>; + bus-width = <8>; + cd-gpios = <&pioE 0 GPIO_ACTIVE_LOW>; + }; + }; + + mmc1: mmc@f8000000 { + vmmc-supply = <&vcc_3v3_reg>; + vqmmc-supply = <&vcc_3v3_reg>; + status = "disabled"; + slot@0 { + reg = <0>; + bus-width = <4>; + cd-gpios = <&pioE 1 GPIO_ACTIVE_LOW>; + }; + }; + + spi0: spi@f0004000 { + cs-gpios = <&pioD 13 0>, <0>, <0>, <&pioD 16 0>; + status = "okay"; + }; + + can0: can@f000c000 { + status = "okay"; + }; + + i2c0: i2c@f0014000 { + pinctrl-0 = <&pinctrl_i2c0_pu>; + status = "okay"; + }; + + i2c1: i2c@f0018000 { + status = "okay"; + + pmic: act8865@5b { + compatible = "active-semi,act8865"; + reg = <0x5b>; + status = "disabled"; + + regulators { + vcc_1v8_reg: DCDC_REG1 { + regulator-name = "VCC_1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + }; + + vcc_1v2_reg: DCDC_REG2 { + regulator-name = "VCC_1V2"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-always-on; + }; + + vcc_3v3_reg: DCDC_REG3 { + regulator-name = "VCC_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vddfuse_reg: LDO_REG1 { + regulator-name = "FUSE_2V5"; + regulator-min-microvolt = <2500000>; + regulator-max-microvolt = <2500000>; + }; + + vddana_reg: LDO_REG2 { + regulator-name = "VDDANA"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + }; + }; + }; + + macb0: ethernet@f0028000 { + phy-mode = "rgmii"; + #address-cells = <1>; + #size-cells = <0>; + status = "okay"; + + ethernet-phy@7 { + reg = <0x7>; + }; + }; + + pwm0: pwm@f002c000 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm0_pwmh0_0 &pinctrl_pwm0_pwmh1_0>; + status = "okay"; + }; + + usart0: serial@f001c000 { + status = "okay"; + }; + + usart1: serial@f0020000 { + pinctrl-0 = <&pinctrl_usart1 &pinctrl_usart1_rts_cts>; + status = "okay"; + }; + + uart0: serial@f0024000 { + status = "okay"; + }; + + mmc1: mmc@f8000000 { + pinctrl-0 = <&pinctrl_mmc1_clk_cmd_dat0 &pinctrl_mmc1_dat1_3 &pinctrl_mmc1_cd>; + status = "okay"; + slot@0 { + reg = <0>; + bus-width = <4>; + cd-gpios = <&pioE 1 GPIO_ACTIVE_HIGH>; + }; + }; + + spi1: spi@f8008000 { + cs-gpios = <&pioC 25 0>; + status = "okay"; + }; + + adc0: adc@f8018000 { + pinctrl-0 = < + &pinctrl_adc0_adtrg + &pinctrl_adc0_ad0 + &pinctrl_adc0_ad1 + &pinctrl_adc0_ad2 + &pinctrl_adc0_ad3 + &pinctrl_adc0_ad4 + &pinctrl_adc0_ad5 + &pinctrl_adc0_ad6 + &pinctrl_adc0_ad7 + &pinctrl_adc0_ad8 + &pinctrl_adc0_ad9 + >; + status = "okay"; + }; + + i2c2: i2c@f801c000 { + dmas = <0>, <0>; /* Do not use DMA for i2c2 */ + pinctrl-0 = <&pinctrl_i2c2_pu>; + status = "okay"; + }; + + macb1: ethernet@f802c000 { + phy-mode = "rmii"; + #address-cells = <1>; + #size-cells = <0>; + status = "okay"; + + ethernet-phy@1 { + reg = <0x1>; + }; + }; + + dbgu: serial@ffffee00 { + status = "okay"; + }; + + pinctrl@fffff200 { + board { + pinctrl_i2c0_pu: i2c0_pu { + atmel,pins = + <AT91_PIOA 30 AT91_PERIPH_A AT91_PINCTRL_PULL_UP>, + <AT91_PIOA 31 AT91_PERIPH_A AT91_PINCTRL_PULL_UP>; + }; + + pinctrl_i2c2_pu: i2c2_pu { + atmel,pins = + <AT91_PIOA 18 AT91_PERIPH_B AT91_PINCTRL_PULL_UP>, + <AT91_PIOA 19 AT91_PERIPH_B AT91_PINCTRL_PULL_UP>; + }; + + pinctrl_key_gpio: key_gpio_0 { + atmel,pins = + <AT91_PIOE 29 AT91_PERIPH_GPIO AT91_PINCTRL_PULL_UP_DEGLITCH>; + }; + + pinctrl_mmc0_cd: mmc0_cd { + atmel,pins = + <AT91_PIOE 0 AT91_PERIPH_GPIO AT91_PINCTRL_PULL_UP_DEGLITCH>; + }; + + pinctrl_mmc1_cd: mmc1_cd { + atmel,pins = + <AT91_PIOE 1 AT91_PERIPH_GPIO AT91_PINCTRL_PULL_UP_DEGLITCH>; + }; + + pinctrl_usba_vbus: usba_vbus { + atmel,pins = + <AT91_PIOE 9 AT91_PERIPH_GPIO AT91_PINCTRL_DEGLITCH>; /* PE9, conflicts with A9 */ + }; + }; + }; + }; + + nand0: nand@60000000 { + nand-bus-width = <8>; + nand-ecc-mode = "hw"; + atmel,has-pmecc; + atmel,pmecc-cap = <4>; + atmel,pmecc-sector-size = <512>; + nand-on-flash-bbt; + status = "okay"; + + at91bootstrap@0 { + label = "at91bootstrap"; + reg = <0x0 0x40000>; + }; + + bootloader@40000 { + label = "bootloader"; + reg = <0x40000 0x80000>; + }; + + bootloaderenv@c0000 { + label = "bootloader env"; + reg = <0xc0000 0xc0000>; + }; + + dtb@180000 { + label = "device tree"; + reg = <0x180000 0x80000>; + }; + + kernel@200000 { + label = "kernel"; + reg = <0x200000 0x600000>; + }; + + rootfs@800000 { + label = "rootfs"; + reg = <0x800000 0x0f800000>; + }; + }; + + usb0: gadget@00500000 { + atmel,vbus-gpio = <&pioE 9 GPIO_ACTIVE_HIGH>; /* PE9, conflicts with A9 */ + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usba_vbus>; + status = "okay"; + }; + + usb1: ohci@00600000 { + num-ports = <3>; + atmel,vbus-gpio = <0 + &pioE 3 GPIO_ACTIVE_LOW + &pioE 4 GPIO_ACTIVE_LOW + >; + status = "okay"; + }; + + usb2: ehci@00700000 { + status = "okay"; + }; + }; + + vcc_mmc0_reg: fixedregulator@0 { + compatible = "regulator-fixed"; + gpio = <&pioE 2 GPIO_ACTIVE_LOW>; + regulator-name = "mmc0-card-supply"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + gpio_keys { + compatible = "gpio-keys"; + + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_key_gpio>; + + bp3 { + label = "PB_USER"; + gpios = <&pioE 29 GPIO_ACTIVE_LOW>; + linux,code = <0x104>; + wakeup-source; + }; + }; + + leds { + compatible = "gpio-leds"; + + d2 { + label = "d2"; + gpios = <&pioE 23 GPIO_ACTIVE_LOW>; /* PE23, conflicts with A23, CTS2 */ + linux,default-trigger = "heartbeat"; + }; + + d3 { + label = "d3"; + gpios = <&pioE 24 GPIO_ACTIVE_HIGH>; + }; + }; +};
Wenyou Yang
