[PATCH 1/1] dm: core: revert "Don't inline dev_read...() calls with of-platdata"
Compiling sandbox_defconfig with CONFIG_SPL_MMC=y results in
drivers/mmc/mmc-uclass.c:211: undefined reference to `dev_read_u32_default'
Revert the fraudulent patch.
Fixes: ef79ef21a852 ("dm: core: Don't inline dev_read...() calls with of-platdata") Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- include/dm/read.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/dm/read.h b/include/dm/read.h index 56ac076c9f..ca1c60e079 100644 --- a/include/dm/read.h +++ b/include/dm/read.h @@ -30,7 +30,7 @@ static inline const struct device_node *dev_np(const struct udevice *dev) } #endif
-#if !defined(CONFIG_DM_DEV_READ_INLINE) || CONFIG_IS_ENABLED(OF_PLATDATA) +#ifndef CONFIG_DM_DEV_READ_INLINE /** * dev_read_u8() - read a 8-bit integer from a device's DT property *
Hi Heinrich,
On Sat, 18 Feb 2023 at 02:17, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
NAK, sorry
You cannot call mmc_of_parse() when OF_REAL is not enabled, since there is no actual devicetree. This is the case with sandbox_spl, since it uses o-platdata.
The original patch is actually correct.
The real fix is to implement of-platdata in drivers/mmc/sandbox_mmc.c as has been done in rockchip_dw_mmc.c for example. See also:
https://u-boot.readthedocs.io/en/latest/develop/driver-model/of-plat.html
Regards, SImon
- dev_read_u8() - read a 8-bit integer from a device's DT property
-- 2.38.1
