Re: [U-Boot] [PATCH v5 3/3] ARM: tegra: Add support for nyan-big board
Hi Tom,
On 10 December 2014 at 14:09, Tom Warren TWarren@nvidia.com wrote:
Simon,
-----Original Message----- From: sjg@google.com [mailto:sjg@google.com] On Behalf Of Simon Glass Sent: Wednesday, December 10, 2014 2:04 PM To: Tom Warren Cc: U-Boot Mailing List; Stephen Warren; Allen Martin; Stephen Warren; Albert Aribaud Subject: Re: [PATCH v5 3/3] ARM: tegra: Add support for nyan-big board
Hi Tom,
On 10 December 2014 at 12:36, Simon Glass sjg@chromium.org wrote:
Hi Tom,
On Dec 10, 2014 12:05 PM, "Tom Warren" TWarren@nvidia.com wrote:
Simon,
-----Original Message----- From: sjg@google.com [mailto:sjg@google.com] On Behalf Of Simon Glass Sent: Wednesday, December 10, 2014 10:50 AM To: Tom Warren Cc: U-Boot Mailing List; Allen Martin; Albert Aribaud; Stephen Warren; Stephen Warren Subject: Re: [PATCH v5 3/3] ARM: tegra: Add support for nyan-big board
Hi Tom,
On 10 December 2014 at 10:39, Tom Warren TWarren@nvidia.com
wrote:
Simon,
The v4 PCIE patch series fails to apply to u-boot-tegra/master after
rebasing my repo against both ARM master and U-Boot 'master' master (i.e. FETCH_HEAD =
32fdf0e4d82bdca5d64d86330e461e59685f9959 branch 'master' of
git://git.denx.de/u-boot). 3 - 4 patches fail when using git am.
I worked thru the conflicts for both branches (my master rebased against
ARM and U-Boot TOT), and did a MAKEALL -s tegra, and jetson-tk1, beaver and cardhu fail to build (jetson err log below). Looks like you developed this with your DM I2C series in place?
To submit a PR from the Tegra repo, I need to either rebase first against
ARM master (my SOP), or against U-Boot 'master'. So you patches, if they're bound for the Tegra repo, need to work in one of those scenarios.
Tom
Thanks for looking at it. This series depends on the I2C driver model series. It's available at u-boot-dm/i2c-working if you want to check it out. I plan to apply that very soon.
I'm sorry I didn't make that clear in this series. I mentioned it on the list at one point but should have added it here. If you like, you could ack it and I can apply to u-boot-dm after I2C is in there.
I can't ACK something that I can't get to apply to my repo nor build nor test. So you'll have to wait on that from Stephen, Thierry (based on code review) or someone that wants to add DM I2C to Tegra, apply your PCIe patches, and test. That's not my normal workflow, though, and I don't have the BW to devote to extra hurdles right now.
You could try applying to u-boot-dm/i2c-working. It only has the DM i2c series in it, plus Tegra stuff. I put a lot of time into cleaning up this Tegra series to save you and Thierry time.
Also Thierry took a look the PCIe series and responded here:
http://patchwork.ozlabs.org/patch/410175/
There were three nits which I have addressed.
For this Nyan-big patch I really don't need a test credit (would be nice, but not necessary). After all it's a new board and if problems are found they can be fixed. But I do need to apply it before DM I2C. Stephen has looked at a few revs.
How about this for a plan:
- Apply Nyan-big to DM
- Apply DM I2C series to DM
- Pull request to mainline (final for DM this release unless SPL is resolved
somehow)
Then if you have time:
- Tom - apply PCIe to Tegra tree
The problem there is that I'd need to wait for the PR to mainline to go thru before I could rebase Tegra against mainline, and only then apply PCIe patches. Time-wise, it's obviously better for you to do this in one fell swoop from the DM repo.
Does the nyan-big patchset apply/build cleanly in u-boot-tegra/master? If so, I can apply it and do a Tegra test build and then send a PR to Albert if all is clear.
OK, true.
The Tegra tree is too far behind master, but if you catch it up you can make it work:
(try-nyan=9e10b9: b/ common/ doc/ sandbox/) u> pwclient git-am 417781 Applying patch #417781 using 'git am' Description: [U-Boot,v5,1/3] dts: Bring in Chrome OS keyboard device tree definition Applying: dts: Bring in Chrome OS keyboard device tree definition (try-nyan=ddebcc: b/ common/ doc/ sandbox/) u> pwclient git-am 417782 Applying patch #417782 using 'git am' Description: [U-Boot,v5,2/3] tegra: dts: Sync tegra124.dtsi with linux kernel Applying: tegra: dts: Sync tegra124.dtsi with linux kernel ^[[A(try-nyan=9df313: b/ common/ doc/ sandbox/) u> pwclient git-am 417783 Applying patch #417783 using 'git am' Description: [U-Boot,v5,3/3] ARM: tegra: Add support for nyan-big board Applying: ARM: tegra: Add support for nyan-big board error: patch failed: arch/arm/dts/Makefile:31 error: arch/arm/dts/Makefile: patch does not apply Patch failed at 0001 ARM: tegra: Add support for nyan-big board The copy of the patch that failed is found in: /usr/local/google/home/sjg/u/.git/rebase-apply/patch When you have resolved this problem, run "git am --continue". If you prefer to skip this patch, run "git am --skip" instead. To restore the original branch and stop patching, run "git am --abort". (try-nyan=9df313: b/ common/ doc/ sandbox/) u> patch -p1 < /usr/local/google/home/sjg/u/.git/rebase-apply/patch patching file arch/arm/cpu/armv7/tegra124/Kconfig patching file arch/arm/dts/Makefile Hunk #1 succeeded at 29 with fuzz 2 (offset -2 lines). patching file arch/arm/dts/tegra124-nyan-big.dts patching file board/nvidia/nyan-big/Kconfig patching file board/nvidia/nyan-big/MAINTAINERS patching file board/nvidia/nyan-big/Makefile patching file board/nvidia/nyan-big/nyan-big.c patching file board/nvidia/nyan-big/pinmux-config-nyan-big.h patching file board/nvidia/venice2/as3722_init.h patching file configs/nyan-big_defconfig patching file include/configs/nyan-big.h
Then:
git add arch/arm/cpu/armv7/tegra124/Kconfig arch/arm/dts/Makefile board/nvidia/venice2/as3722_init.h arch/arm/dts/tegra124-nyan-big.dts board/nvidia/nyan-big/ configs/nyan-big_defconfig include/configs/nyan-big.h git am --resolved
I've pushed it to u-boot-dm/for-tom.
It all builds cleanly for me.
If you don't have time, I could do this last bit through DM. In any case the problem is that it is getting late and we need to resolve this soon.
Tom
drivers/power/as3722.c: In function 'as3722_read': drivers/power/as3722.c:34: warning: passing argument 1 of 'i2c_read' makes integer from pointer without a cast include/i2c.h:235: note: expected 'uint8_t' but argument is of type 'struct
udevice *'
drivers/power/as3722.c:34: warning: passing argument 3 of 'i2c_read' makes integer from pointer without a cast include/i2c.h:235: note: expected 'int' but argument is of type 'u8 *' drivers/power/as3722.c:34: warning: passing argument 4 of 'i2c_read' makes pointer from integer without a cast include/i2c.h:235: note: expected 'uint8_t *' but argument is of type 'int' drivers/power/as3722.c:34: error: too few arguments to function 'i2c_read' drivers/power/as3722.c: In function 'as3722_write': drivers/power/as3722.c:45: warning: passing argument 1 of 'i2c_write' makes integer from pointer without a cast include/i2c.h:238: note: expected 'uint8_t' but argument is of type 'struct
udevice *'
drivers/power/as3722.c:45: warning: passing argument 3 of 'i2c_write' makes integer from pointer without a cast include/i2c.h:238: note: expected 'int' but argument is of type 'u8 *' drivers/power/as3722.c:45: warning: passing argument 4 of 'i2c_write' makes pointer from integer without a cast include/i2c.h:238: note: expected 'uint8_t *' but argument is of type 'int' drivers/power/as3722.c:45: error: too few arguments to function
'i2c_write'
drivers/power/as3722.c: In function 'as3722_init': drivers/power/as3722.c:245: warning: implicit declaration of function
'i2c_get_chip_for_busnum'
make[1]: *** [drivers/power/as3722.o] Error 1 make: *** [drivers/power] Error 2 make: *** Waiting for unfinished jobs....
> -----Original Message----- > From: Tom Warren > Sent: Wednesday, December 10, 2014 8:46 AM > To: Simon Glass; U-Boot Mailing List > Cc: Allen Martin; Albert Aribaud; Stephen Warren; Stephen Warren > Subject: RE: [PATCH v5 3/3] ARM: tegra: Add support for nyan-big > board > > Simon, > > > -----Original Message----- > > From: sjg@google.com [mailto:sjg@google.com] On Behalf Of > > Simon Glass > > Sent: Wednesday, December 10, 2014 8:01 AM > > To: U-Boot Mailing List > > Cc: Allen Martin; Simon Glass; Albert Aribaud; Tom Warren; > > Stephen Warren; Stephen Warren > > Subject: Re: [PATCH v5 3/3] ARM: tegra: Add support for > > nyan-big board > > > > Hi, > > > > On 4 December 2014 at 06:36, Simon Glass sjg@chromium.org
wrote:
> > > From: Allen Martin amartin@nvidia.com > > > > > > Nyan-big is a Tegra124 clamshell board that is very similar > > > to venice2, but it has a different panel, the sdcard cd and > > > wp sense are flipped, and it has a different revision of the AS3722
PMIC.
> > > > > > This is the Acer Chromebook 13 CB5-311-T7NN (13.3-inch HD, > > > NVIDIA Tegra K1, 2GB). The display is not currently > > > supported, so it should boot on other nyan-based Chromebooks > > > also, but only the device tree for nyan-big is provided here. > > > > > > The device tree file is from Linux but with features removed > > > which are unlikely to be supported in U-Boot soon > > > (regulators,
pinmux).
> > > Also the addresses are updated to 32-bit. > > > > > > Signed-off-by: Allen Martin amartin@nvidia.com > > > Signed-off-by: Simon Glass sjg@chromium.org (rebase, > > > change to 'nyan-big', fix pinmux that resets nyan-big) > > > > > > --- > > > > > > Changes in v5: > > > - Remove call to pinmux_set_tristate_input_clamping() > > > > > > > Any further comments on v5 please? > > > > I would like to apply this patch before the DM I2C series, so > > that I2C works correct for nyan-big also. > > > > Tom are you looking at the rest of the PCI-e series? I resent > > it so would like to get that in soon - the patches originally > > date from August. > I was waiting for Thierry or Stephen to Ack the series, or > provide other feedback. I don't have time/boards to test this right
now.
> > If someone can say it looks good, or has been tested on X board, etc. > I can apply it. > > Tom > > > > Regards, > > Simon > -- > nvpublic
Hi Tom,
On 10 December 2014 at 14:45, Simon Glass sjg@chromium.org wrote:
Hi Tom,
Simon,
Hi Tom,
Hi Tom,
Simon,
Hi Tom,
wrote:
> Simon, > > The v4 PCIE patch series fails to apply to u-boot-tegra/master > after rebasing my repo against both ARM master and U-Boot 'master' master (i.e. FETCH_HEAD = > 32fdf0e4d82bdca5d64d86330e461e59685f9959 branch 'master' of git://git.denx.de/u-boot). 3 - 4 patches fail when using git am. > > I worked thru the conflicts for both branches (my master rebased > against ARM and U-Boot TOT), and did a MAKEALL -s tegra, and jetson-tk1, beaver and cardhu fail to build (jetson err log below). Looks like you developed this with your DM I2C series in place? > > To submit a PR from the Tegra repo, I need to either rebase first > against ARM master (my SOP), or against U-Boot 'master'. So you patches, if they're bound for the Tegra repo, need to work in one of those scenarios. > > Tom
somehow)
OK, true.
Then:
Further to this, the I2C patches are in u-boot-dm/master now, except for this Tegra I2C conversion, which depends on the nyan-big series:
http://patchwork.ozlabs.org/patch/419730/
So I would like to bring in the nyan-big series to the DM tree, add this Tegra I2C patch and then we are ready to sort out the PCIe series. What do you think of that plan? Or if you prefer, I can issue a pull request to mainline for the DM stuff to date and you can do the rest?
Tom
Regards, Simon > > drivers/power/as3722.c: In function 'as3722_read': > drivers/power/as3722.c:34: warning: passing argument 1 of 'i2c_read' > makes integer from pointer without a cast > include/i2c.h:235: note: expected 'uint8_t' but argument is of > type 'struct udevice *' > drivers/power/as3722.c:34: warning: passing argument 3 of 'i2c_read' > makes integer from pointer without a cast > include/i2c.h:235: note: expected 'int' but argument is of type 'u8 *' > drivers/power/as3722.c:34: warning: passing argument 4 of 'i2c_read' > makes pointer from integer without a cast > include/i2c.h:235: note: expected 'uint8_t *' but argument is of > type 'int' > drivers/power/as3722.c:34: error: too few arguments to function > 'i2c_read' > drivers/power/as3722.c: In function 'as3722_write': > drivers/power/as3722.c:45: warning: passing argument 1 of 'i2c_write' > makes integer from pointer without a cast > include/i2c.h:238: note: expected 'uint8_t' but argument is of > type 'struct udevice *' > drivers/power/as3722.c:45: warning: passing argument 3 of 'i2c_write' > makes integer from pointer without a cast > include/i2c.h:238: note: expected 'int' but argument is of type 'u8 *' > drivers/power/as3722.c:45: warning: passing argument 4 of 'i2c_write' > makes pointer from integer without a cast > include/i2c.h:238: note: expected 'uint8_t *' but argument is of > type 'int' > drivers/power/as3722.c:45: error: too few arguments to function 'i2c_write' > drivers/power/as3722.c: In function 'as3722_init': > drivers/power/as3722.c:245: warning: implicit declaration of > function 'i2c_get_chip_for_busnum' > make[1]: *** [drivers/power/as3722.o] Error 1 > make: *** [drivers/power] Error 2 > make: *** Waiting for unfinished jobs.... > >> -----Original Message----- >> From: Tom Warren >> Sent: Wednesday, December 10, 2014 8:46 AM >> To: Simon Glass; U-Boot Mailing List >> Cc: Allen Martin; Albert Aribaud; Stephen Warren; Stephen Warren >> Subject: RE: [PATCH v5 3/3] ARM: tegra: Add support for nyan-big >> board >> >> Simon, >> >> > -----Original Message----- >> > From: sjg@google.com [mailto:sjg@google.com] On Behalf Of >> > Simon Glass >> > Sent: Wednesday, December 10, 2014 8:01 AM >> > To: U-Boot Mailing List >> > Cc: Allen Martin; Simon Glass; Albert Aribaud; Tom Warren; >> > Stephen Warren; Stephen Warren >> > Subject: Re: [PATCH v5 3/3] ARM: tegra: Add support for >> > nyan-big board >> > >> > Hi, >> > >> > On 4 December 2014 at 06:36, Simon Glass sjg@chromium.org
wrote:
>> > > From: Allen Martin amartin@nvidia.com >> > > >> > > Nyan-big is a Tegra124 clamshell board that is very similar >> > > to venice2, but it has a different panel, the sdcard cd and >> > > wp sense are flipped, and it has a different revision of the AS3722
PMIC.
>> > > >> > > This is the Acer Chromebook 13 CB5-311-T7NN (13.3-inch HD, >> > > NVIDIA Tegra K1, 2GB). The display is not currently >> > > supported, so it should boot on other nyan-based Chromebooks >> > > also, but only the device tree for nyan-big is provided here. >> > > >> > > The device tree file is from Linux but with features removed >> > > which are unlikely to be supported in U-Boot soon >> > > (regulators, pinmux). >> > > Also the addresses are updated to 32-bit. >> > > >> > > Signed-off-by: Allen Martin amartin@nvidia.com >> > > Signed-off-by: Simon Glass sjg@chromium.org (rebase, >> > > change to 'nyan-big', fix pinmux that resets nyan-big) >> > > >> > > --- >> > > >> > > Changes in v5: >> > > - Remove call to pinmux_set_tristate_input_clamping() >> > > >> > >> > Any further comments on v5 please? >> > >> > I would like to apply this patch before the DM I2C series, so >> > that I2C works correct for nyan-big also. >> > >> > Tom are you looking at the rest of the PCI-e series? I resent >> > it so would like to get that in soon - the patches originally >> > date from August. >> I was waiting for Thierry or Stephen to Ack the series, or >> provide other feedback. I don't have time/boards to test this right
now.
>> >> If someone can say it looks good, or has been tested on X board, etc. >> I can apply it. >> >> Tom >> > >> > Regards, >> > Simon >> -- >> nvpublic
