[U-Boot] [PATCH v2 0/2] ARM: imx6: DHCOM i.MX6 PDK: Fixing reset
here the second version of those patches.
regards, Claudius
Changes from v1: - u-boot specific wdt-reboot device node now in separate dtsi - Squashed patch 2 to 4, because possible bisecting issues in certain configurations (when SPL needs to use do_reset) - Improved patch description: more detailed and descriptive
Claudius Heine (2): ARM: dts: dh-imx6: add u-boot specific wdt-reboot node ARM: imx6: DHCOM i.MX6 PDK: Enable sysreset driver and wdt command
arch/arm/dts/imx6q-dhcom-pdk2-u-boot.dtsi | 11 +++++++++++ configs/dh_imx6_defconfig | 3 +++ include/configs/dh_imx6.h | 5 +++++ 3 files changed, 19 insertions(+) create mode 100644 arch/arm/dts/imx6q-dhcom-pdk2-u-boot.dtsi
The wdt-reboot node is needed for the sysreset_watchdog driver to register a watchdog as a reset handler in case 'CONFIG_SYSRESET' is enabled.
Signed-off-by: Claudius Heine ch@denx.de --- arch/arm/dts/imx6q-dhcom-pdk2-u-boot.dtsi | 11 +++++++++++ 1 file changed, 11 insertions(+) create mode 100644 arch/arm/dts/imx6q-dhcom-pdk2-u-boot.dtsi
diff --git a/arch/arm/dts/imx6q-dhcom-pdk2-u-boot.dtsi b/arch/arm/dts/imx6q-dhcom-pdk2-u-boot.dtsi new file mode 100644 index 0000000000..b94231edb3 --- /dev/null +++ b/arch/arm/dts/imx6q-dhcom-pdk2-u-boot.dtsi @@ -0,0 +1,11 @@ +// SPDX-License-Identifier: (GPL-2.0+) +/* + * Copyright (C) 2019 Claudius Heine ch@denx.de + */ + +/ { + wdt-reboot { + compatible = "wdt-reboot"; + wdt = <&wdog1>; + }; +};
The wdt-reboot node is needed for the sysreset_watchdog driver to register a watchdog as a reset handler in case 'CONFIG_SYSRESET' is enabled. Signed-off-by: Claudius Heine ch@denx.de
Applied to u-boot-imx, -next, thanks !
Best regards, Stefano Babic
The SPL does not have DM enabled and therefor still needs to use the hardware watchdog interface provided by the imx-watchdog driver.
Fixes: broken reset command after f2929d11a639 ("watchdog: imx: Use immediate reset bits for expire_now")
Signed-off-by: Claudius Heine ch@denx.de --- configs/dh_imx6_defconfig | 3 +++ include/configs/dh_imx6.h | 5 +++++ 2 files changed, 8 insertions(+)
diff --git a/configs/dh_imx6_defconfig b/configs/dh_imx6_defconfig index 4055812007..e5c44381b2 100644 --- a/configs/dh_imx6_defconfig +++ b/configs/dh_imx6_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SATA=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_WDT=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT4_WRITE=y @@ -77,6 +78,8 @@ CONFIG_DM_SCSI=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_MXC_SPI=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_WATCHDOG=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_GADGET=y diff --git a/include/configs/dh_imx6.h b/include/configs/dh_imx6.h index d4bd88f511..77074aaa06 100644 --- a/include/configs/dh_imx6.h +++ b/include/configs/dh_imx6.h @@ -87,6 +87,11 @@ #endif
/* Watchdog */ +#if defined(CONFIG_SPL_BUILD) +#undef CONFIG_WDT +#undef CONFIG_WATCHDOG +#define CONFIG_HW_WATCHDOG +#endif
/* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE
The SPL does not have DM enabled and therefor still needs to use the hardware watchdog interface provided by the imx-watchdog driver. Fixes: broken reset command after f2929d11a639 ("watchdog: imx: Use immediate reset bits for expire_now") Signed-off-by: Claudius Heine ch@denx.de
Claudius Heine
sbabic@denx.de
