[PATCH 0/2] Cleanup K3 binman FIT images
Instead of duplicating the same FIT formats over and over again for different K3 devices, make use of the templating support to have FIT templates for the same.
Note: I purposely did not add the trial to template out the non-FIT bootloader image (tiboot3.bin) as it reduces the readibility and understandability of how the image is packaged because of the various different boot flows.
Boot logs: https://gist.github.com/nehamalcom/9abe7955ebb4a251923e76412834c886
Neha Malcom Francis (2): arm: dts: k3-binman: Add support for FIT templates arm: dts: k3-*-binman: Move to using templated FITs
arch/arm/dts/k3-am625-sk-binman.dtsi | 157 +-------- .../dts/k3-am625-verdin-wifi-dev-binman.dtsi | 155 +------- arch/arm/dts/k3-am62a-sk-binman.dtsi | 158 +-------- arch/arm/dts/k3-am64x-binman.dtsi | 151 +------- arch/arm/dts/k3-am65x-binman.dtsi | 273 +------------- arch/arm/dts/k3-binman.dtsi | 327 +++++++++++++++++ arch/arm/dts/k3-j7200-binman.dtsi | 159 +-------- arch/arm/dts/k3-j721e-binman.dtsi | 332 +----------------- arch/arm/dts/k3-j721s2-binman.dtsi | 157 +-------- 9 files changed, 381 insertions(+), 1488 deletions(-)
Add templates for FIT images used extensively across K3 boards with most of the code common. This includes the FIT portions of: - tispl.bin - u-boot.img - sysfw.itb (in case of legacy boot flow)
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- arch/arm/dts/k3-binman.dtsi | 327 ++++++++++++++++++++++++++++++++++++ 1 file changed, 327 insertions(+)
diff --git a/arch/arm/dts/k3-binman.dtsi b/arch/arm/dts/k3-binman.dtsi index 2ea2dd18a1..677a017403 100644 --- a/arch/arm/dts/k3-binman.dtsi +++ b/arch/arm/dts/k3-binman.dtsi @@ -113,4 +113,331 @@ }; };
+&binman { + itb_template: template-5 { + fit { + description = "SYSFW and Config fragments"; + #address-cells = <1>; + images { + sysfw.bin { + description = "sysfw"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "sysfw.bin"; + }; + }; + board-cfg.bin { + description = "board-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&board_cfg>; + keyfile = "custMpk.pem"; + }; + board_cfg: board-cfg { + filename = "board-cfg.bin"; + type = "blob-ext"; + }; + + }; + pm-cfg.bin { + description = "pm-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&pm_cfg>; + keyfile = "custMpk.pem"; + }; + pm_cfg: pm-cfg { + filename = "pm-cfg.bin"; + type = "blob-ext"; + }; + }; + rm-cfg.bin { + description = "rm-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&rm_cfg>; + keyfile = "custMpk.pem"; + }; + rm_cfg: rm-cfg { + filename = "rm-cfg.bin"; + type = "blob-ext"; + }; + }; + sec-cfg.bin { + description = "sec-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&sec_cfg>; + keyfile = "custMpk.pem"; + }; + sec_cfg: sec-cfg { + filename = "sec-cfg.bin"; + type = "blob-ext"; + }; + }; + }; + }; + }; + + itb_unsigned_template: template-6 { + fit { + description = "SYSFW and Config fragments"; + #address-cells = <1>; + images { + sysfw.bin { + description = "sysfw"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "sysfw.bin_fs"; + }; + }; + board-cfg.bin { + description = "board-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + board-cfg { + filename = "board-cfg.bin"; + type = "blob-ext"; + }; + + }; + pm-cfg.bin { + description = "pm-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + pm-cfg { + filename = "pm-cfg.bin"; + type = "blob-ext"; + }; + }; + rm-cfg.bin { + description = "rm-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + rm-cfg { + filename = "rm-cfg.bin"; + type = "blob-ext"; + }; + }; + sec-cfg.bin { + description = "sec-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + sec-cfg { + filename = "sec-cfg.bin"; + type = "blob-ext"; + }; + }; + }; + }; + }; +}; + +#else + +&binman { + ti_spl_template: template-1 { + filename = "tispl.bin"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + ti-secure { + content = <&atf>; + keyfile = "custMpk.pem"; + }; + atf: atf-bl31 { + }; + }; + + tee { + description = "OP-TEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + ti-secure { + content = <&tee>; + keyfile = "custMpk.pem"; + }; + tee: tee-os { + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + ti-secure { + content = <&u_boot_spl_nodtb>; + keyfile = "custMpk.pem"; + + }; + u_boot_spl_nodtb: blob-ext { + filename = "spl/u-boot-spl-nodtb.bin"; + }; + }; + + }; + }; + }; + ti_spl_unsigned_template: template-2 { + filename = "tispl.bin_unsigned"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + atf-bl31 { + filename = "bl31.bin"; + }; + }; + + tee { + description = "OP-TEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + tee-os { + filename = "tee-raw.bin"; + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + blob-ext { + filename = "spl/u-boot-spl-nodtb.bin"; + }; + }; + }; + }; + }; + u_boot_template: template-3 { + filename = "u-boot.img"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + ti-secure { + content = <&u_boot_nodtb>; + keyfile = "custMpk.pem"; + }; + u_boot_nodtb: u-boot-nodtb { + }; + hash { + algo = "crc32"; + }; + }; + }; + }; + }; + u_boot_unsigned_template: template-4 { + filename = "u-boot.img_unsigned"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + blob { + filename = "u-boot-nodtb.bin"; + }; + hash { + algo = "crc32"; + }; + }; + }; + }; + }; + +}; + #endif
Hi Neha,
What is the DM binary?
Hi Simon
On Thu, 2023-11-16 at 09:03 -0700, Simon Glass wrote:
Hi Neha,
From [1]:
DM - Device Management firmware also called TI System Control Interface server (TISCI Server) - This component purely plays the role of managing device resources such as power, clock, interrupts, dma etc. This firmware runs on a dedicated or multi-use microcontroller outside the security enclave.
[1] https://docs.u-boot.org/en/latest/board/ti/am62x_sk.html
Cheers
Marcel
Hi Marcel,
On 16/11/23 22:13, Marcel Ziswiler wrote:
Hi Simon
Hi Neha,
From [1]:
Cheers
Marcel
Thanks for explaining!
- tispl.bin
- u-boot.img
Signed-off-by: Neha Malcom Francis n-francis@ti.com Reviewed-by: Simon Glass sjg@chromium.org
Reduce redundancy in code by using templates to generate the A72 boot binaries (tispl.bin and u-boot.img) as well as R5 boot binary sysfw.itb (for legacy boot following devices J721E and AM65x).
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- arch/arm/dts/k3-am625-sk-binman.dtsi | 157 +-------- .../dts/k3-am625-verdin-wifi-dev-binman.dtsi | 155 +------- arch/arm/dts/k3-am62a-sk-binman.dtsi | 158 +-------- arch/arm/dts/k3-am64x-binman.dtsi | 151 +------- arch/arm/dts/k3-am65x-binman.dtsi | 273 +------------- arch/arm/dts/k3-j7200-binman.dtsi | 159 +-------- arch/arm/dts/k3-j721e-binman.dtsi | 332 +----------------- arch/arm/dts/k3-j721s2-binman.dtsi | 157 +-------- 8 files changed, 54 insertions(+), 1488 deletions(-)
diff --git a/arch/arm/dts/k3-am625-sk-binman.dtsi b/arch/arm/dts/k3-am625-sk-binman.dtsi index 41277bf4bf..b7b5368886 100644 --- a/arch/arm/dts/k3-am625-sk-binman.dtsi +++ b/arch/arm/dts/k3-am625-sk-binman.dtsi @@ -141,10 +141,7 @@
#ifdef CONFIG_TARGET_AM625_A53_EVM
-#define SPL_NODTB "spl/u-boot-spl-nodtb.bin" #define SPL_AM625_SK_DTB "spl/dts/k3-am625-sk.dtb" - -#define UBOOT_NODTB "u-boot-nodtb.bin" #define AM625_SK_DTB "u-boot.dtb"
&binman { @@ -155,55 +152,11 @@ }; }; ti-spl { - filename = "tispl.bin"; - pad-byte = <0xff>; + insert-template = <&ti_spl_template>;
fit { - description = "Configuration to load ATF and SPL"; - #address-cells = <1>; - images { - - atf { - description = "ARM Trusted Firmware"; - type = "firmware"; - arch = "arm64"; - compression = "none"; - os = "arm-trusted-firmware"; - load = <CONFIG_K3_ATF_LOAD_ADDR>; - entry = <CONFIG_K3_ATF_LOAD_ADDR>; - ti-secure { - content = <&atf>; - keyfile = "custMpk.pem"; - }; - atf: atf-bl31 { - }; - }; - - tee { - description = "OP-TEE"; - type = "tee"; - arch = "arm64"; - compression = "none"; - os = "tee"; - load = <0x9e800000>; - entry = <0x9e800000>; - ti-secure { - content = <&tee>; - keyfile = "custMpk.pem"; - }; - tee: tee-os { - }; - }; - dm { - description = "DM binary"; - type = "firmware"; - arch = "arm32"; - compression = "none"; - os = "DM"; - load = <0x89000000>; - entry = <0x89000000>; ti-secure { content = <&dm>; keyfile = "custMpk.pem"; @@ -213,23 +166,6 @@ }; };
- spl { - description = "SPL (64-bit)"; - type = "standalone"; - os = "U-Boot"; - arch = "arm64"; - compression = "none"; - load = <CONFIG_SPL_TEXT_BASE>; - entry = <CONFIG_SPL_TEXT_BASE>; - ti-secure { - content = <&u_boot_spl_nodtb>; - keyfile = "custMpk.pem"; - }; - u_boot_spl_nodtb: blob-ext { - filename = SPL_NODTB; - }; - }; - fdt-0 { description = "k3-am625-sk"; type = "flat_dt"; @@ -263,29 +199,12 @@
&binman { u-boot { - filename = "u-boot.img"; - pad-byte = <0xff>; + insert-template = <&u_boot_template>;
fit { - description = "FIT image with multiple configurations"; - images { uboot { - description = "U-Boot for AM625 board"; - type = "firmware"; - os = "u-boot"; - arch = "arm"; - compression = "none"; - load = <CONFIG_TEXT_BASE>; - ti-secure { - content = <&u_boot_nodtb>; - keyfile = "custMpk.pem"; - }; - u_boot_nodtb: u-boot-nodtb { - }; - hash { - algo = "crc32"; - }; + description = "U-Boot for AM625 Board"; };
fdt-0 { @@ -323,67 +242,17 @@
&binman { ti-spl_unsigned { - filename = "tispl.bin_unsigned"; - pad-byte = <0xff>; + insert-template = <&ti_spl_unsigned_template>;
- atf { - description = "ARM Trusted Firmware"; - type = "firmware"; - arch = "arm64"; - compression = "none"; - os = "arm-trusted-firmware"; - load = <CONFIG_K3_ATF_LOAD_ADDR>; - entry = <CONFIG_K3_ATF_LOAD_ADDR>; - atf-bl31 { - filename = "bl31.bin"; - }; - }; - - tee { - description = "OP-TEE"; - type = "tee"; - arch = "arm64"; - compression = "none"; - os = "tee"; - load = <0x9e800000>; - entry = <0x9e800000>; - tee-os { - filename = "tee-raw.bin"; - }; - }; - dm { - description = "DM binary"; - type = "firmware"; - arch = "arm32"; - compression = "none"; - os = "DM"; - load = <0x89000000>; - entry = <0x89000000>; blob-ext { filename = "ti-dm.bin"; }; };
- spl { - description = "SPL (64-bit)"; - type = "standalone"; - os = "U-Boot"; - arch = "arm64"; - compression = "none"; - load = <CONFIG_SPL_TEXT_BASE>; - entry = <CONFIG_SPL_TEXT_BASE>; - blob { - filename = "spl/u-boot-spl-nodtb.bin"; - }; - }; - fdt-0 { description = "k3-am625-sk"; type = "flat_dt"; @@ -411,26 +280,12 @@
&binman { u-boot_unsigned { - filename = "u-boot.img_unsigned"; - pad-byte = <0xff>; + insert-template = <&u_boot_unsigned_template>;
fit { - description = "FIT image with multiple configurations"; - images { uboot { - description = "U-Boot for AM625 board"; - type = "firmware"; - os = "u-boot"; - arch = "arm"; - compression = "none"; - load = <CONFIG_TEXT_BASE>; - blob { - filename = UBOOT_NODTB; - }; - hash { - algo = "crc32"; - }; + description = "U-Boot for AM625 Board"; };
fdt-0 { diff --git a/arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi b/arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi index 089b2a5f5c..eafd3310bb 100644 --- a/arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi +++ b/arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi @@ -214,10 +214,7 @@
#ifdef CONFIG_TARGET_VERDIN_AM62_A53
-#define SPL_NODTB "spl/u-boot-spl-nodtb.bin" #define SPL_VERDIN_AM62_DTB "spl/dts/k3-am625-verdin-wifi-dev.dtb" - -#define UBOOT_NODTB "u-boot-nodtb.bin" #define VERDIN_AM62_DTB "u-boot.dtb"
&binman { @@ -228,54 +225,12 @@ }; }; ti-spl { - filename = "tispl.bin"; - pad-byte = <0xff>; + insert-template = <&ti_spl_template>;
images { - atf { - description = "ARM Trusted Firmware"; - type = "firmware"; - arch = "arm64"; - compression = "none"; - os = "arm-trusted-firmware"; - load = <CONFIG_K3_ATF_LOAD_ADDR>; - entry = <CONFIG_K3_ATF_LOAD_ADDR>; - ti-secure { - content = <&atf>; - keyfile = "custMpk.pem"; - }; - atf: atf-bl31 { - }; - }; - - tee { - description = "OP-TEE"; - type = "tee"; - arch = "arm64"; - compression = "none"; - os = "tee"; - load = <0x9e800000>; - entry = <0x9e800000>; - ti-secure { - content = <&tee>; - keyfile = "custMpk.pem"; - }; - tee: tee-os { - }; - }; - dm { - description = "DM binary"; - type = "firmware"; - arch = "arm32"; - compression = "none"; - os = "DM"; - load = <0x89000000>; - entry = <0x89000000>; ti-secure { content = <&dm>; keyfile = "custMpk.pem"; @@ -285,23 +240,6 @@ }; };
- spl { - description = "SPL (64-bit)"; - type = "standalone"; - os = "U-Boot"; - arch = "arm64"; - compression = "none"; - load = <CONFIG_SPL_TEXT_BASE>; - entry = <CONFIG_SPL_TEXT_BASE>; - ti-secure { - content = <&u_boot_spl_nodtb>; - keyfile = "custMpk.pem"; - }; - u_boot_spl_nodtb: blob-ext { - filename = SPL_NODTB; - }; - }; - fdt-0 { description = "k3-am625-verdin-wifi-dev"; type = "flat_dt"; @@ -333,29 +271,12 @@
fit { - description = "FIT image with multiple configurations"; - images { uboot { - description = "U-Boot for AM625 board"; - type = "firmware"; - os = "u-boot"; - arch = "arm"; - compression = "none"; - load = <CONFIG_TEXT_BASE>; - ti-secure { - content = <&u_boot_nodtb>; - keyfile = "custMpk.pem"; - }; - u_boot_nodtb: u-boot-nodtb { - }; - hash { - algo = "crc32"; - }; + description = "U-Boot fot AM625 Verdin Board"; };
fdt-0 { @@ -392,66 +313,16 @@
fit { - description = "Configuration to load ATF and SPL"; - #address-cells = <1>; - images { - atf { - description = "ARM Trusted Firmware"; - type = "firmware"; - arch = "arm64"; - compression = "none"; - os = "arm-trusted-firmware"; - load = <CONFIG_K3_ATF_LOAD_ADDR>; - entry = <CONFIG_K3_ATF_LOAD_ADDR>; - atf-bl31 { - filename = "bl31.bin"; - }; - }; - - tee { - description = "OP-TEE"; - type = "tee"; - arch = "arm64"; - compression = "none"; - os = "tee"; - load = <0x9e800000>; - entry = <0x9e800000>; - tee-os { - filename = "tee-raw.bin"; - }; - }; - dm { - description = "DM binary"; - type = "firmware"; - arch = "arm32"; - compression = "none"; - os = "DM"; - load = <0x89000000>; - entry = <0x89000000>; blob-ext { filename = "ti-dm.bin"; }; };
- spl { - description = "SPL (64-bit)"; - type = "standalone"; - os = "U-Boot"; - arch = "arm64"; - compression = "none"; - load = <CONFIG_SPL_TEXT_BASE>; - entry = <CONFIG_SPL_TEXT_BASE>; - blob { - filename = "spl/u-boot-spl-nodtb.bin"; - }; - }; - fdt-0 { description = "k3-am625-verdin-wifi-dev"; type = "flat_dt"; @@ -479,26 +350,12 @@
fit { - description = "FIT image with multiple configurations"; - images { uboot { - description = "U-Boot for AM625 board"; - type = "firmware"; - os = "u-boot"; - arch = "arm"; - compression = "none"; - load = <CONFIG_TEXT_BASE>; - blob { - filename = UBOOT_NODTB; - }; - hash { - algo = "crc32"; - }; + description = "U-Boot for AM625 Verdin Board"; };
fdt-0 { diff --git a/arch/arm/dts/k3-am62a-sk-binman.dtsi b/arch/arm/dts/k3-am62a-sk-binman.dtsi index de09430d93..c5e027d44d 100644 --- a/arch/arm/dts/k3-am62a-sk-binman.dtsi +++ b/arch/arm/dts/k3-am62a-sk-binman.dtsi @@ -144,10 +144,7 @@
#ifdef CONFIG_TARGET_AM62A7_A53_EVM
-#define SPL_NODTB "spl/u-boot-spl-nodtb.bin" #define SPL_AM62A7_SK_DTB "spl/dts/k3-am62a7-sk.dtb" - -#define UBOOT_NODTB "u-boot-nodtb.bin" #define AM62A7_SK_DTB "u-boot.dtb"
&binman { @@ -158,55 +155,11 @@ }; }; ti-spl { - filename = "tispl.bin"; - pad-byte = <0xff>; + insert-template = <&ti_spl_template>;
fit { - description = "Configuration to load ATF and SPL"; - #address-cells = <1>; - images { - - atf { - description = "ARM Trusted Firmware"; - type = "firmware"; - arch = "arm64"; - compression = "none"; - os = "arm-trusted-firmware"; - load = <CONFIG_K3_ATF_LOAD_ADDR>; - entry = <CONFIG_K3_ATF_LOAD_ADDR>; - ti-secure { - content = <&atf>; - keyfile = "custMpk.pem"; - }; - atf: atf-bl31 { - }; - }; - - tee { - description = "OP-TEE"; - type = "tee"; - arch = "arm64"; - compression = "none"; - os = "tee"; - load = <0x9e800000>; - entry = <0x9e800000>; - ti-secure { - content = <&tee>; - keyfile = "custMpk.pem"; - }; - tee: tee-os { - }; - }; - dm { - description = "DM binary"; - type = "firmware"; - arch = "arm32"; - compression = "none"; - os = "DM"; - load = <0x89000000>; - entry = <0x89000000>; ti-secure { content = <&dm>; keyfile = "custMpk.pem"; @@ -216,23 +169,6 @@ }; };
- spl { - description = "SPL (64-bit)"; - type = "standalone"; - os = "U-Boot"; - arch = "arm64"; - compression = "none"; - load = <CONFIG_SPL_TEXT_BASE>; - entry = <CONFIG_SPL_TEXT_BASE>; - ti-secure { - content = <&u_boot_spl_nodtb>; - keyfile = "custMpk.pem"; - }; - u_boot_spl_nodtb: blob-ext { - filename = SPL_NODTB; - }; - }; - fdt-0 { description = "k3-am62a7-sk"; type = "flat_dt"; @@ -266,29 +202,12 @@
fit { - description = "FIT image with multiple configurations"; - images { uboot { - description = "U-Boot for AM62Ax board"; - type = "firmware"; - os = "u-boot"; - arch = "arm"; - compression = "none"; - load = <CONFIG_TEXT_BASE>; - ti-secure { - content = <&u_boot_nodtb>; - keyfile = "custMpk.pem"; - }; - u_boot_nodtb: u-boot-nodtb { - }; - hash { - algo = "crc32"; - }; + description = "U-Boot for AM62Ax Board"; };
fdt-0 { @@ -326,67 +245,16 @@
fit { - description = "Configuration to load ATF and SPL"; - #address-cells = <1>; - images { - - atf { - description = "ARM Trusted Firmware"; - type = "firmware"; - arch = "arm64"; - compression = "none"; - os = "arm-trusted-firmware"; - load = <CONFIG_K3_ATF_LOAD_ADDR>; - entry = <CONFIG_K3_ATF_LOAD_ADDR>; - atf-bl31 { - filename = "bl31.bin"; - }; - }; - - tee { - description = "OP-TEE"; - type = "tee"; - arch = "arm64"; - compression = "none"; - os = "tee"; - load = <0x9e800000>; - entry = <0x9e800000>; - tee-os { - filename = "tee-raw.bin"; - }; - }; - dm { - description = "DM binary"; - type = "firmware"; - arch = "arm32"; - compression = "none"; - os = "DM"; - load = <0x89000000>; - entry = <0x89000000>; blob-ext { filename = "ti-dm.bin"; }; };
- spl { - description = "SPL (64-bit)"; - type = "standalone"; - os = "U-Boot"; - arch = "arm64"; - compression = "none"; - load = <CONFIG_SPL_TEXT_BASE>; - entry = <CONFIG_SPL_TEXT_BASE>; - blob { - filename = "spl/u-boot-spl-nodtb.bin"; - }; - }; - fdt-0 { description = "k3-am62a7-sk"; type = "flat_dt"; @@ -414,26 +282,12 @@
fit { - description = "FIT image with multiple configurations"; - images { uboot { - description = "U-Boot for AM62Ax board"; - type = "firmware"; - os = "u-boot"; - arch = "arm"; - compression = "none"; - load = <CONFIG_TEXT_BASE>; - blob { - filename = UBOOT_NODTB; - }; - hash { - algo = "crc32"; - }; + description = "U-Boot for AM62Ax Board"; };
fdt-0 { diff --git a/arch/arm/dts/k3-am64x-binman.dtsi b/arch/arm/dts/k3-am64x-binman.dtsi index a5e54006b4..88df214954 100644 --- a/arch/arm/dts/k3-am64x-binman.dtsi +++ b/arch/arm/dts/k3-am64x-binman.dtsi @@ -118,87 +118,27 @@
#ifdef CONFIG_TARGET_AM642_A53_EVM
-#define SPL_NODTB "spl/u-boot-spl-nodtb.bin" #define SPL_AM642_EVM_DTB "spl/dts/k3-am642-evm.dtb" #define SPL_AM642_SK_DTB "spl/dts/k3-am642-sk.dtb"
-#define UBOOT_NODTB "u-boot-nodtb.bin" #define AM642_EVM_DTB "u-boot.dtb" #define AM642_SK_DTB "arch/arm/dts/k3-am642-sk.dtb"
&binman { ti-spl { - filename = "tispl.bin"; - pad-byte = <0xff>; + insert-template = <&ti_spl_template>;
fit { description = "Configuration to load ATF and SPL"; #address-cells = <1>;
images { - - atf { - description = "ARM Trusted Firmware"; - type = "firmware"; - arch = "arm64"; - compression = "none"; - os = "arm-trusted-firmware"; - load = <CONFIG_K3_ATF_LOAD_ADDR>; - entry = <CONFIG_K3_ATF_LOAD_ADDR>; - ti-secure { - content = <&atf>; - keyfile = "custMpk.pem"; - }; - atf: atf-bl31 { - }; - }; - - tee { - description = "OP-TEE"; - type = "tee"; - arch = "arm64"; - compression = "none"; - os = "tee"; - load = <0x9e800000>; - entry = <0x9e800000>; - ti-secure { - content = <&tee>; - keyfile = "custMpk.pem"; - }; - tee: tee-os { - }; - }; - dm { - description = "DM binary"; - type = "firmware"; - arch = "arm32"; - compression = "none"; - os = "DM"; - load = <0x89000000>; - entry = <0x89000000>; blob-ext { filename = "/dev/null"; }; };
- spl { - description = "SPL (64-bit)"; - type = "standalone"; - os = "U-Boot"; - arch = "arm64"; - compression = "none"; - load = <CONFIG_SPL_TEXT_BASE>; - entry = <CONFIG_SPL_TEXT_BASE>; - ti-secure { - content = <&u_boot_spl_nodtb>; - keyfile = "custMpk.pem"; - - }; - u_boot_spl_nodtb: blob-ext { - filename = SPL_NODTB; - }; - };
fdt-0 { description = "k3-am642-evm"; @@ -254,29 +194,12 @@
fit { - description = "FIT image with multiple configurations"; - images { uboot { - description = "U-Boot for AM64 board"; - type = "firmware"; - os = "u-boot"; - arch = "arm"; - compression = "none"; - load = <CONFIG_TEXT_BASE>; - ti-secure { - content = <&u_boot_nodtb>; - keyfile = "custMpk.pem"; - }; - u_boot_nodtb: u-boot-nodtb { - }; - hash { - algo = "crc32"; - }; + description = "U-Boot for AM64 Board"; };
fdt-0 { @@ -340,65 +263,17 @@
- atf { - description = "ARM Trusted Firmware"; - type = "firmware"; - arch = "arm64"; - compression = "none"; - os = "arm-trusted-firmware"; - load = <CONFIG_K3_ATF_LOAD_ADDR>; - entry = <CONFIG_K3_ATF_LOAD_ADDR>; - atf-bl31 { - }; - }; - - tee { - description = "OP-TEE"; - type = "tee"; - arch = "arm64"; - compression = "none"; - os = "tee"; - load = <0x9e800000>; - entry = <0x9e800000>; - tee-os { - }; - }; - dm { - description = "DM binary"; - type = "firmware"; - arch = "arm32"; - compression = "none"; - os = "DM"; - load = <0x89000000>; - entry = <0x89000000>; blob-ext { filename = "/dev/null"; }; };
- spl { - description = "SPL (64-bit)"; - type = "standalone"; - os = "U-Boot"; - arch = "arm64"; - compression = "none"; - load = <CONFIG_SPL_TEXT_BASE>; - entry = <CONFIG_SPL_TEXT_BASE>; - blob { - filename = "spl/u-boot-spl-nodtb.bin"; - }; - }; - fdt-0 { description = "k3-am642-evm"; type = "flat_dt"; @@ -443,26 +318,12 @@
fit { - description = "FIT image with multiple configurations"; - images { uboot { - description = "U-Boot for AM64 board"; - type = "firmware"; - os = "u-boot"; - arch = "arm"; - compression = "none"; - load = <CONFIG_TEXT_BASE>; - blob { - filename = UBOOT_NODTB; - }; - hash { - algo = "crc32"; - }; + description = "U-Boot for AM64 Board"; };
fdt-0 { diff --git a/arch/arm/dts/k3-am65x-binman.dtsi b/arch/arm/dts/k3-am65x-binman.dtsi index 59605ca597..8cc24da1f3 100644 --- a/arch/arm/dts/k3-am65x-binman.dtsi +++ b/arch/arm/dts/k3-am65x-binman.dtsi @@ -42,77 +42,7 @@ }; itb { filename = "sysfw-am65x_sr2-hs-evm.itb"; - fit { - description = "SYSFW and Config fragments"; - #address-cells = <1>; - images { - sysfw.bin { - description = "sysfw"; - type = "firmware"; - arch = "arm"; - compression = "none"; - blob-ext { - filename = "sysfw.bin"; - }; - }; - board-cfg.bin { - description = "board-cfg"; - type = "firmware"; - arch = "arm"; - compression = "none"; - ti-secure { - content = <&board_cfg>; - keyfile = "custMpk.pem"; - }; - board_cfg: board-cfg { - filename = "board-cfg.bin"; - type = "blob-ext"; - }; - }; - pm-cfg.bin { - description = "pm-cfg"; - type = "firmware"; - arch = "arm"; - compression = "none"; - ti-secure { - content = <&pm_cfg>; - keyfile = "custMpk.pem"; - }; - pm_cfg: pm-cfg { - filename = "pm-cfg.bin"; - type = "blob-ext"; - }; - }; - rm-cfg.bin { - description = "rm-cfg"; - type = "firmware"; - arch = "arm"; - compression = "none"; - ti-secure { - content = <&rm_cfg>; - keyfile = "custMpk.pem";\ - }; - rm_cfg: rm-cfg { - filename = "rm-cfg.bin"; - type = "blob-ext"; - }; - }; - sec-cfg.bin { - description = "sec-cfg"; - type = "firmware"; - arch = "arm"; - compression = "none"; - ti-secure { - content = <&sec_cfg>; - keyfile = "custMpk.pem"; - }; - sec_cfg: sec-cfg { - filename = "sec-cfg.bin"; - type = "blob-ext"; - }; - }; - }; - }; + insert-template = <&itb_template>; }; };
@@ -149,55 +79,14 @@ itb_gp { filename = "sysfw-am65x_sr2-gp-evm.itb"; symlink = "sysfw.itb"; + insert-template = <&itb_unsigned_template>; fit { - description = "SYSFW and Config fragments"; - #address-cells = <1>; images { sysfw.bin { - description = "sysfw"; - type = "firmware"; - arch = "arm"; - compression = "none"; blob-ext { filename = "sysfw.bin_gp"; }; }; - board-cfg.bin { - description = "board-cfg"; - type = "firmware"; - arch = "arm"; - compression = "none"; - blob-ext { - filename = "board-cfg.bin"; - }; - }; - pm-cfg.bin { - description = "pm-cfg"; - type = "firmware"; - arch = "arm"; - compression = "none"; - blob-ext { - filename = "pm-cfg.bin"; - }; - }; - rm-cfg.bin { - description = "rm-cfg"; - type = "firmware"; - arch = "arm"; - compression = "none"; - blob-ext { - filename = "rm-cfg.bin"; - }; - }; - sec-cfg.bin { - description = "sec-cfg"; - type = "firmware"; - arch = "arm"; - compression = "none"; - blob-ext { - filename = "sec-cfg.bin"; - }; - }; }; }; }; @@ -206,86 +95,22 @@
#ifdef CONFIG_TARGET_AM654_A53_EVM
-#define SPL_NODTB "spl/u-boot-spl-nodtb.bin" #define SPL_AM654_EVM_DTB "spl/dts/k3-am654-base-board.dtb" - -#define UBOOT_NODTB "u-boot-nodtb.bin" #define AM654_EVM_DTB "u-boot.dtb"
- spl { - description = "SPL (64-bit)"; - type = "standalone"; - os = "U-Boot"; - arch = "arm64"; - compression = "none"; - load = <CONFIG_SPL_TEXT_BASE>; - entry = <CONFIG_SPL_TEXT_BASE>; - ti-secure { - content = <&u_boot_spl_nodtb>; - keyfile = "custMpk.pem"; - - }; - u_boot_spl_nodtb: blob-ext { - filename = SPL_NODTB; - }; - }; - fdt-0 { description = "k3-am654-base-board"; type = "flat_dt"; @@ -317,29 +142,12 @@
fit { - description = "FIT image with multiple configurations"; - images { uboot { - description = "U-Boot for AM65 board"; - type = "firmware"; - os = "u-boot"; - arch = "arm"; - compression = "none"; - load = <CONFIG_TEXT_BASE>; - ti-secure { - content = <&u_boot_nodtb>; - keyfile = "custMpk.pem"; - }; - u_boot_nodtb: u-boot-nodtb { - }; - hash { - algo = "crc32"; - }; + description = "U-Boot for AM65 Board"; };
fdt-0 { @@ -378,67 +186,16 @@
fit { - description = "Configuration to load ATF and SPL"; - #address-cells = <1>; - images { - - atf { - description = "ARM Trusted Firmware"; - type = "firmware"; - arch = "arm64"; - compression = "none"; - os = "arm-trusted-firmware"; - load = <CONFIG_K3_ATF_LOAD_ADDR>; - entry = <CONFIG_K3_ATF_LOAD_ADDR>; - atf-bl31 { - filename = "bl31.bin"; - }; - }; - - tee { - description = "OP-TEE"; - type = "tee"; - arch = "arm64"; - compression = "none"; - os = "tee"; - load = <0x9e800000>; - entry = <0x9e800000>; - tee-os { - filename = "tee-raw.bin"; - }; - }; - dm { - description = "DM binary"; - type = "firmware"; - arch = "arm32"; - compression = "none"; - os = "DM"; - load = <0x89000000>; - entry = <0x89000000>; blob-ext { filename = "/dev/null"; }; };
- spl { - description = "SPL (64-bit)"; - type = "standalone"; - os = "U-Boot"; - arch = "arm64"; - compression = "none"; - load = <CONFIG_SPL_TEXT_BASE>; - entry = <CONFIG_SPL_TEXT_BASE>; - blob-ext { - filename = SPL_NODTB; - }; - }; - fdt-0 { description = "k3-j721e-common-proc-board"; type = "flat_dt"; @@ -466,26 +223,12 @@
fit { - description = "FIT image with multiple configurations"; - images { uboot { - description = "U-Boot for AM65 board"; - type = "firmware"; - os = "u-boot"; - arch = "arm"; - compression = "none"; - load = <CONFIG_TEXT_BASE>; - blob { - filename = UBOOT_NODTB; - }; - hash { - algo = "crc32"; - }; + description = "U-Boot for AM65 Board"; };
fdt-0 { diff --git a/arch/arm/dts/k3-j7200-binman.dtsi b/arch/arm/dts/k3-j7200-binman.dtsi index 14f7dea65e..10c9d6cba7 100644 --- a/arch/arm/dts/k3-j7200-binman.dtsi +++ b/arch/arm/dts/k3-j7200-binman.dtsi @@ -180,10 +180,7 @@
#ifdef CONFIG_TARGET_J7200_A72_EVM
-#define SPL_NODTB "spl/u-boot-spl-nodtb.bin" #define SPL_J7200_EVM_DTB "spl/dts/k3-j7200-common-proc-board.dtb" - -#define UBOOT_NODTB "u-boot-nodtb.bin" #define J7200_EVM_DTB "u-boot.dtb"
&binman { @@ -194,82 +191,20 @@ }; }; ti-spl { - filename = "tispl.bin"; - pad-byte = <0xff>; + insert-template = <&ti_spl_template>;
fit { - description = "Configuration to load ATF and SPL"; - #address-cells = <1>; - images { - - atf { - description = "ARM Trusted Firmware"; - type = "firmware"; - arch = "arm64"; - compression = "none"; - os = "arm-trusted-firmware"; - load = <CONFIG_K3_ATF_LOAD_ADDR>; - entry = <CONFIG_K3_ATF_LOAD_ADDR>; - ti-secure { - content = <&atf>; - keyfile = "custMpk.pem"; - }; - atf: atf-bl31 { - }; - }; - - tee { - description = "OP-TEE"; - type = "tee"; - arch = "arm64"; - compression = "none"; - os = "tee"; - load = <0x9e800000>; - entry = <0x9e800000>; - ti-secure { - content = <&tee>; - keyfile = "custMpk.pem"; - }; - tee: tee-os { - }; - }; - dm { - description = "DM binary"; - type = "firmware"; - arch = "arm32"; - compression = "none"; - os = "DM"; - load = <0x89000000>; - entry = <0x89000000>; ti-secure { content = <&dm>; keyfile = "custMpk.pem"; }; - dm: blob-ext { filename = "ti-dm.bin"; }; };
- spl { - description = "SPL (64-bit)"; - type = "standalone"; - os = "U-Boot"; - arch = "arm64"; - compression = "none"; - load = <CONFIG_SPL_TEXT_BASE>; - entry = <CONFIG_SPL_TEXT_BASE>; - ti-secure { - content = <&u_boot_spl_nodtb>; - keyfile = "custMpk.pem"; - }; - u_boot_spl_nodtb: blob-ext { - filename = SPL_NODTB; - }; - }; - fdt-0 { description = "k3-j7200-common-proc-board"; type = "flat_dt"; @@ -302,29 +237,12 @@
fit { - description = "FIT image with multiple configurations"; - images { uboot { - description = "U-Boot for J7200 board"; - type = "firmware"; - os = "u-boot"; - arch = "arm"; - compression = "none"; - load = <CONFIG_TEXT_BASE>; - ti-secure { - content = <&u_boot_nodtb>; - keyfile = "custMpk.pem"; - }; - u_boot_nodtb: u-boot-nodtb { - }; - hash { - algo = "crc32"; - }; + description = "U-Boot for J7200 Board"; };
fdt-0 { @@ -362,67 +280,16 @@
- spl { - description = "SPL (64-bit)"; - type = "standalone"; - os = "U-Boot"; - arch = "arm64"; - compression = "none"; - load = <CONFIG_SPL_TEXT_BASE>; - entry = <CONFIG_SPL_TEXT_BASE>; - blob { - filename = SPL_NODTB; - }; - }; - fdt-1 { description = "k3-j7200-common-proc-board"; type = "flat_dt"; @@ -450,26 +317,12 @@
fit { - description = "FIT image with multiple configurations"; - images { uboot { - description = "U-Boot for J7200 board"; - type = "firmware"; - os = "u-boot"; - arch = "arm"; - compression = "none"; - load = <CONFIG_TEXT_BASE>; - blob { - filename = UBOOT_NODTB; - }; - hash { - algo = "crc32"; - }; + description = "U-Boot for J7200 Board"; };
fdt-1 { diff --git a/arch/arm/dts/k3-j721e-binman.dtsi b/arch/arm/dts/k3-j721e-binman.dtsi index 4f566c21a9..5ddb474e3a 100644 --- a/arch/arm/dts/k3-j721e-binman.dtsi +++ b/arch/arm/dts/k3-j721e-binman.dtsi @@ -42,78 +42,7 @@ }; itb { filename = "sysfw-j721e_sr1_1-hs-evm.itb"; - fit { - description = "SYSFW and Config fragments"; - #address-cells = <1>; - images { - sysfw.bin { - description = "sysfw"; - type = "firmware"; - arch = "arm"; - compression = "none"; - blob-ext { - filename = "sysfw.bin"; - }; - }; - board-cfg.bin { - description = "board-cfg"; - type = "firmware"; - arch = "arm"; - compression = "none"; - ti-secure { - content = <&board_cfg>; - keyfile = "custMpk.pem"; - }; - board_cfg: board-cfg { - filename = "board-cfg.bin"; - type = "blob-ext"; - }; - - }; - pm-cfg.bin { - description = "pm-cfg"; - type = "firmware"; - arch = "arm"; - compression = "none"; - ti-secure { - content = <&pm_cfg>; - keyfile = "custMpk.pem"; - }; - pm_cfg: pm-cfg { - filename = "pm-cfg.bin"; - type = "blob-ext"; - }; - }; - rm-cfg.bin { - description = "rm-cfg"; - type = "firmware"; - arch = "arm"; - compression = "none"; - ti-secure { - content = <&rm_cfg>; - keyfile = "custMpk.pem"; - }; - rm_cfg: rm-cfg { - filename = "rm-cfg.bin"; - type = "blob-ext"; - }; - }; - sec-cfg.bin { - description = "sec-cfg"; - type = "firmware"; - arch = "arm"; - compression = "none"; - ti-secure { - content = <&sec_cfg>; - keyfile = "custMpk.pem"; - }; - sec_cfg: sec-cfg { - filename = "sec-cfg.bin"; - type = "blob-ext"; - }; - }; - }; - }; + insert-template = <&itb_template>; }; };
@@ -145,62 +74,7 @@ }; itb_fs { filename = "sysfw-j721e_sr2-hs-fs-evm.itb"; - fit { - description = "SYSFW and Config fragments"; - #address-cells = <1>; - images { - sysfw.bin { - description = "sysfw"; - type = "firmware"; - arch = "arm"; - compression = "none"; - blob-ext { - filename = "sysfw.bin_fs"; - }; - }; - board-cfg.bin { - description = "board-cfg"; - type = "firmware"; - arch = "arm"; - compression = "none"; - board-cfg { - filename = "board-cfg.bin"; - type = "blob-ext"; - }; - - }; - pm-cfg.bin { - description = "pm-cfg"; - type = "firmware"; - arch = "arm"; - compression = "none"; - pm-cfg { - filename = "pm-cfg.bin"; - type = "blob-ext"; - }; - }; - rm-cfg.bin { - description = "rm-cfg"; - type = "firmware"; - arch = "arm"; - compression = "none"; - rm-cfg { - filename = "rm-cfg.bin"; - type = "blob-ext"; - }; - }; - sec-cfg.bin { - description = "sec-cfg"; - type = "firmware"; - arch = "arm"; - compression = "none"; - sec-cfg { - filename = "sec-cfg.bin"; - type = "blob-ext"; - }; - }; - }; - }; + insert-template = <&itb_unsigned_template>; }; };
@@ -237,55 +111,15 @@ itb_gp { filename = "sysfw-j721e-gp-evm.itb"; symlink = "sysfw.itb"; + insert-template = <&itb_unsigned_template>; + fit { - description = "SYSFW and Config fragments"; - #address-cells = <1>; images { sysfw.bin { - description = "sysfw"; - type = "firmware"; - arch = "arm"; - compression = "none"; blob-ext { filename = "sysfw.bin_gp"; }; }; - board-cfg.bin { - description = "board-cfg"; - type = "firmware"; - arch = "arm"; - compression = "none"; - blob-ext { - filename = "board-cfg.bin"; - }; - }; - pm-cfg.bin { - description = "pm-cfg"; - type = "firmware"; - arch = "arm"; - compression = "none"; - blob-ext { - filename = "pm-cfg.bin"; - }; - }; - rm-cfg.bin { - description = "rm-cfg"; - type = "firmware"; - arch = "arm"; - compression = "none"; - blob-ext { - filename = "rm-cfg.bin"; - }; - }; - sec-cfg.bin { - description = "sec-cfg"; - type = "firmware"; - arch = "arm"; - compression = "none"; - blob-ext { - filename = "sec-cfg.bin"; - }; - }; }; }; }; @@ -294,11 +128,9 @@
#ifdef CONFIG_TARGET_J721E_A72_EVM
-#define SPL_NODTB "spl/u-boot-spl-nodtb.bin" #define SPL_J721E_EVM_DTB "spl/dts/k3-j721e-common-proc-board.dtb" #define SPL_J721E_SK_DTB "spl/dts/k3-j721e-sk.dtb"
-#define UBOOT_NODTB "u-boot-nodtb.bin" #define J721E_EVM_DTB "u-boot.dtb" #define J721E_SK_DTB "arch/arm/dts/k3-j721e-sk.dtb"
@@ -310,55 +142,11 @@ }; }; ti-spl { - filename = "tispl.bin"; - pad-byte = <0xff>; + insert-template = <&ti_spl_template>;
fit { - description = "Configuration to load ATF and SPL"; - #address-cells = <1>; - images { - - atf { - description = "ARM Trusted Firmware"; - type = "firmware"; - arch = "arm64"; - compression = "none"; - os = "arm-trusted-firmware"; - load = <CONFIG_K3_ATF_LOAD_ADDR>; - entry = <CONFIG_K3_ATF_LOAD_ADDR>; - ti-secure { - content = <&atf>; - keyfile = "custMpk.pem"; - }; - atf: atf-bl31 { - }; - }; - - tee { - description = "OP-TEE"; - type = "tee"; - arch = "arm64"; - compression = "none"; - os = "tee"; - load = <0x9e800000>; - entry = <0x9e800000>; - ti-secure { - content = <&tee>; - keyfile = "custMpk.pem"; - }; - tee: tee-os { - }; - }; - dm { - description = "DM binary"; - type = "firmware"; - arch = "arm32"; - compression = "none"; - os = "DM"; - load = <0x89000000>; - entry = <0x89000000>; ti-secure { content = <&dm>; keyfile = "custMpk.pem"; @@ -368,24 +156,6 @@ }; };
- spl { - description = "SPL (64-bit)"; - type = "standalone"; - os = "U-Boot"; - arch = "arm64"; - compression = "none"; - load = <CONFIG_SPL_TEXT_BASE>; - entry = <CONFIG_SPL_TEXT_BASE>; - ti-secure { - content = <&u_boot_spl_nodtb>; - keyfile = "custMpk.pem"; - - }; - u_boot_spl_nodtb: blob-ext { - filename = SPL_NODTB; - }; - }; - fdt-0 { description = "k3-j721e-common-proc-board"; type = "flat_dt"; @@ -439,29 +209,12 @@
&binman { u-boot { - filename = "u-boot.img"; - pad-byte = <0xff>; - + insert-template = <&u_boot_template>; fit { - description = "FIT image with multiple configurations";
images { uboot { - description = "U-Boot for j721e board"; - type = "firmware"; - os = "u-boot"; - arch = "arm"; - compression = "none"; - load = <CONFIG_TEXT_BASE>; - ti-secure { - content = <&u_boot_nodtb>; - keyfile = "custMpk.pem"; - }; - u_boot_nodtb: u-boot-nodtb { - }; - hash { - algo = "crc32"; - }; + description = "U-Boot for J721E Board"; };
fdt-0 { @@ -524,67 +277,16 @@
- spl { - description = "SPL (64-bit)"; - type = "standalone"; - os = "U-Boot"; - arch = "arm64"; - compression = "none"; - load = <CONFIG_SPL_TEXT_BASE>; - entry = <CONFIG_SPL_TEXT_BASE>; - blob-ext { - filename = SPL_NODTB; - }; - }; - fdt-0 { description = "k3-j721e-common-proc-board"; type = "flat_dt"; @@ -629,26 +331,12 @@
fit { - description = "FIT image with multiple configurations"; - images { uboot { - description = "U-Boot for j721e board"; - type = "firmware"; - os = "u-boot"; - arch = "arm"; - compression = "none"; - load = <CONFIG_TEXT_BASE>; - blob { - filename = UBOOT_NODTB; - }; - hash { - algo = "crc32"; - }; + description = "U-Boot for J721E Board"; };
fdt-0 { diff --git a/arch/arm/dts/k3-j721s2-binman.dtsi b/arch/arm/dts/k3-j721s2-binman.dtsi index 5bca4e94ec..3922007b3b 100644 --- a/arch/arm/dts/k3-j721s2-binman.dtsi +++ b/arch/arm/dts/k3-j721s2-binman.dtsi @@ -141,11 +141,9 @@
#ifdef CONFIG_TARGET_J721S2_A72_EVM
-#define SPL_NODTB "spl/u-boot-spl-nodtb.bin" #define SPL_J721S2_EVM_DTB "spl/dts/k3-j721s2-common-proc-board.dtb" #define SPL_AM68_SK_DTB "spl/dts/k3-am68-sk-base-board.dtb"
-#define UBOOT_NODTB "u-boot-nodtb.bin" #define J721S2_EVM_DTB "u-boot.dtb" #define AM68_SK_DTB "arch/arm/dts/k3-am68-sk-base-board.dtb"
@@ -157,55 +155,11 @@ }; }; ti-spl { - filename = "tispl.bin"; - pad-byte = <0xff>; + insert-template = <&ti_spl_template>;
fit { - description = "Configuration to load ATF and SPL"; - #address-cells = <1>; - images { - - atf { - description = "ARM Trusted Firmware"; - type = "firmware"; - arch = "arm64"; - compression = "none"; - os = "arm-trusted-firmware"; - load = <CONFIG_K3_ATF_LOAD_ADDR>; - entry = <CONFIG_K3_ATF_LOAD_ADDR>; - ti-secure { - content = <&atf>; - keyfile = "custMpk.pem"; - }; - atf: atf-bl31 { - }; - }; - - tee { - description = "OP-TEE"; - type = "tee"; - arch = "arm64"; - compression = "none"; - os = "tee"; - load = <0x9e800000>; - entry = <0x9e800000>; - ti-secure { - content = <&tee>; - keyfile = "custMpk.pem"; - }; - tee: tee-os { - }; - }; - dm { - description = "DM binary"; - type = "firmware"; - arch = "arm32"; - compression = "none"; - os = "DM"; - load = <0x89000000>; - entry = <0x89000000>; ti-secure { content = <&dm>; keyfile = "custMpk.pem"; @@ -215,23 +169,6 @@ }; };
- spl { - description = "SPL (64-bit)"; - type = "standalone"; - os = "U-Boot"; - arch = "arm64"; - compression = "none"; - load = <CONFIG_SPL_TEXT_BASE>; - entry = <CONFIG_SPL_TEXT_BASE>; - ti-secure { - content = <&u_boot_spl_nodtb>; - keyfile = "custMpk.pem"; - }; - u_boot_spl_nodtb: blob-ext { - filename = SPL_NODTB; - }; - }; - fdt-0 { description = "k3-j721s2-common-proc-board"; type = "flat_dt"; @@ -285,29 +222,12 @@
fit { - description = "FIT image with multiple configurations"; - images { uboot { - description = "U-Boot for J721S2 board"; - type = "firmware"; - os = "u-boot"; - arch = "arm"; - compression = "none"; - load = <CONFIG_TEXT_BASE>; - ti-secure { - content = <&u_boot_nodtb>; - keyfile = "custMpk.pem"; - }; - u_boot_nodtb: u-boot-nodtb { - }; - hash { - algo = "crc32"; - }; + description = "U-Boot for J721S2 Board"; };
fdt-0 { @@ -371,67 +291,16 @@
- spl { - description = "SPL (64-bit)"; - type = "standalone"; - os = "U-Boot"; - arch = "arm64"; - compression = "none"; - load = <CONFIG_SPL_TEXT_BASE>; - entry = <CONFIG_SPL_TEXT_BASE>; - blob { - filename = "spl/u-boot-spl-nodtb.bin"; - }; - }; - fdt-0 { description = "k3-j721s2-common-proc-board"; type = "flat_dt"; @@ -475,26 +344,12 @@
fit { - description = "FIT image with multiple configurations"; - images { uboot { - description = "U-Boot for J721S2 board"; - type = "firmware"; - os = "u-boot"; - arch = "arm"; - compression = "none"; - load = <CONFIG_TEXT_BASE>; - blob { - filename = UBOOT_NODTB; - }; - hash { - algo = "crc32"; - }; + description = "U-Boot for J721S2 Board"; };
fdt-0 {
1488 deletions, nice!
Minor question, why was `ti-secure` not factored out of `dm` nodes like it was for `atf`/`tee` nodes? Guessing it has to do with not all SoCs needing this blob and signing nothing results in something, which messes up the 0 size check when loading it, but it wasn't clear to me.
Anyway,
Acked-by: Andrew Davis afd@ti.com
Hi Andrew,
Yes that's right! It ends up being non-zero for devices that don't have DM and DM load fails.
Anyway,
Hi Neha,
Gosh that's a huge improvement!
Hi Neha,
pad-byte = <0xff>;
fit {
images {
atf {
type = "firmware";
arch = "arm64";
ti-secure {
content = <&atf>;
For ATF/OP-TEE Firewalling, can you keep these nodes intact? Just keep the ti-secure inside atf and tee nodes similar to how you have done that for DM as all the ATF/OPTEE nodes in the tispl.bin would be different for devices w.r.t certifications but we can still use templates for other common stuff.
With this change,
Reviewed-by: Manorit Chawdhry m-chawdhry@ti.com
Regards, Manorit
atf: atf-bl31 {
tee {
type = "tee";
arch = "arm64";
os = "tee";
ti-secure {
content = <&tee>;
tee: tee-os {
dm {
type = "firmware";
arch = "arm32";
os = "DM";
spl {
os = "U-Boot";
arch = "arm64";
ti-secure {
&binman { u-boot {
pad-byte = <0xff>;
fit {
images { uboot {
type = "firmware";
os = "u-boot";
arch = "arm";
ti-secure {
hash {
algo = "crc32";
description = "U-Boot for AM625 Board"; }; fdt-0 {
pad-byte = <0xff>;
fit {
images {
atf {
type = "firmware";
arch = "arm64";
atf-bl31 {
tee {
type = "tee";
arch = "arm64";
os = "tee";
tee-os {
dm {
type = "firmware";
arch = "arm32";
os = "DM";
spl {
os = "U-Boot";
arch = "arm64";
blob {
pad-byte = <0xff>;
fit {
images { uboot {
type = "firmware";
os = "u-boot";
arch = "arm";
blob {
hash {
algo = "crc32";
pad-byte = <0xff>;
fit {
atf {
type = "firmware";
arch = "arm64";
ti-secure {
content = <&atf>;
atf: atf-bl31 {
tee {
type = "tee";
arch = "arm64";
os = "tee";
ti-secure {
content = <&tee>;
tee: tee-os {
dm {
type = "firmware";
arch = "arm32";
os = "DM";
spl {
os = "U-Boot";
arch = "arm64";
ti-secure {
&binman { u-boot {
pad-byte = <0xff>;
fit {
images { uboot {
type = "firmware";
os = "u-boot";
arch = "arm";
ti-secure {
hash {
algo = "crc32";
description = "U-Boot fot AM625 Verdin Board"; }; fdt-0 {
pad-byte = <0xff>;
fit {
images {
atf {
type = "firmware";
arch = "arm64";
atf-bl31 {
tee {
type = "tee";
arch = "arm64";
os = "tee";
tee-os {
dm {
type = "firmware";
arch = "arm32";
os = "DM";
spl {
os = "U-Boot";
arch = "arm64";
blob {
pad-byte = <0xff>;
fit {
images { uboot {
type = "firmware";
os = "u-boot";
arch = "arm";
blob {
hash {
algo = "crc32";
description = "U-Boot for AM625 Verdin Board"; }; fdt-0 {
pad-byte = <0xff>;
fit {
images {
atf {
type = "firmware";
arch = "arm64";
ti-secure {
content = <&atf>;
atf: atf-bl31 {
tee {
type = "tee";
arch = "arm64";
os = "tee";
ti-secure {
content = <&tee>;
tee: tee-os {
dm {
type = "firmware";
arch = "arm32";
os = "DM";
spl {
os = "U-Boot";
arch = "arm64";
ti-secure {
&binman { u-boot {
pad-byte = <0xff>;
fit {
images { uboot {
type = "firmware";
os = "u-boot";
arch = "arm";
ti-secure {
hash {
algo = "crc32";
description = "U-Boot for AM62Ax Board"; }; fdt-0 {
pad-byte = <0xff>;
fit {
images {
atf {
type = "firmware";
arch = "arm64";
atf-bl31 {
tee {
type = "tee";
arch = "arm64";
os = "tee";
tee-os {
dm {
type = "firmware";
arch = "arm32";
os = "DM";
spl {
os = "U-Boot";
arch = "arm64";
blob {
pad-byte = <0xff>;
fit {
images { uboot {
type = "firmware";
os = "u-boot";
arch = "arm";
blob {
hash {
algo = "crc32";
&binman { ti-spl {
pad-byte = <0xff>;
images {
atf {
type = "firmware";
arch = "arm64";
ti-secure {
content = <&atf>;
atf: atf-bl31 {
tee {
type = "tee";
arch = "arm64";
os = "tee";
ti-secure {
content = <&tee>;
tee: tee-os {
dm {
type = "firmware";
arch = "arm32";
os = "DM";
spl {
os = "U-Boot";
arch = "arm64";
ti-secure {
}; fdt-0 { description = "k3-am642-evm";
&binman { u-boot {
pad-byte = <0xff>;
fit {
images { uboot {
type = "firmware";
os = "u-boot";
arch = "arm";
ti-secure {
hash {
algo = "crc32";
description = "U-Boot for AM64 Board"; }; fdt-0 {
pad-byte = <0xff>;
fit {
images {
atf {
type = "firmware";
arch = "arm64";
atf-bl31 {
tee {
type = "tee";
arch = "arm64";
os = "tee";
tee-os {
dm {
type = "firmware";
arch = "arm32";
os = "DM";
spl {
os = "U-Boot";
arch = "arm64";
blob {
pad-byte = <0xff>;
fit {
images { uboot {
type = "firmware";
os = "u-boot";
arch = "arm";
blob {
hash {
algo = "crc32";
fit {
images {
sysfw.bin {
type = "firmware";
arch = "arm";
blob-ext {
board-cfg.bin {
type = "firmware";
arch = "arm";
ti-secure {
type = "blob-ext";
pm-cfg.bin {
type = "firmware";
arch = "arm";
ti-secure {
pm_cfg: pm-cfg {
type = "blob-ext";
rm-cfg.bin {
type = "firmware";
arch = "arm";
ti-secure {
rm_cfg: rm-cfg {
type = "blob-ext";
sec-cfg.bin {
type = "firmware";
arch = "arm";
ti-secure {
sec_cfg: sec-cfg {
type = "blob-ext";
};insert-template = <&itb_template>;
fit {insert-template = <&itb_unsigned_template>;
type = "firmware";
arch = "arm";
board-cfg.bin {
type = "firmware";
arch = "arm";
blob-ext {
pm-cfg.bin {
type = "firmware";
arch = "arm";
blob-ext {
rm-cfg.bin {
type = "firmware";
arch = "arm";
blob-ext {
sec-cfg.bin {
type = "firmware";
arch = "arm";
blob-ext {
&binman { ti-spl {
pad-byte = <0xff>;
fit {
images {
atf {
type = "firmware";
arch = "arm64";
ti-secure {
content = <&atf>;
atf: atf-bl31 {
tee {
type = "tee";
arch = "arm64";
os = "tee";
ti-secure {
content = <&tee>;
tee: tee-os {
dm {
type = "firmware";
arch = "arm32";
os = "DM";
spl {
os = "U-Boot";
arch = "arm64";
ti-secure {
&binman { u-boot {
pad-byte = <0xff>;
fit {
images { uboot {
type = "firmware";
os = "u-boot";
arch = "arm";
ti-secure {
hash {
algo = "crc32";
description = "U-Boot for AM65 Board"; }; fdt-0 {
pad-byte = <0xff>;
fit {
images {
atf {
type = "firmware";
arch = "arm64";
atf-bl31 {
tee {
type = "tee";
arch = "arm64";
os = "tee";
tee-os {
dm {
type = "firmware";
arch = "arm32";
os = "DM";
spl {
os = "U-Boot";
arch = "arm64";
blob-ext {
pad-byte = <0xff>;
fit {
images { uboot {
type = "firmware";
os = "u-boot";
arch = "arm";
blob {
hash {
algo = "crc32";
pad-byte = <0xff>;
fit {
images {
atf {
type = "firmware";
arch = "arm64";
ti-secure {
content = <&atf>;
atf: atf-bl31 {
tee {
type = "tee";
arch = "arm64";
os = "tee";
ti-secure {
content = <&tee>;
tee: tee-os {
dm {
type = "firmware";
arch = "arm32";
os = "DM";
spl {
os = "U-Boot";
arch = "arm64";
ti-secure {
&binman { u-boot {
pad-byte = <0xff>;
fit {
images { uboot {
type = "firmware";
os = "u-boot";
arch = "arm";
ti-secure {
hash {
algo = "crc32";
description = "U-Boot for J7200 Board"; }; fdt-0 {
pad-byte = <0xff>;
fit {
images {
atf {
type = "firmware";
arch = "arm64";
atf-bl31 {
tee {
type = "tee";
arch = "arm64";
os = "tee";
tee-os {
dm {
type = "firmware";
arch = "arm32";
os = "DM";
spl {
os = "U-Boot";
arch = "arm64";
blob {
pad-byte = <0xff>;
fit {
images { uboot {
type = "firmware";
os = "u-boot";
arch = "arm";
blob {
hash {
algo = "crc32";
description = "U-Boot for J7200 Board"; }; fdt-1 {
fit {
images {
sysfw.bin {
type = "firmware";
arch = "arm";
blob-ext {
board-cfg.bin {
type = "firmware";
arch = "arm";
ti-secure {
type = "blob-ext";
pm-cfg.bin {
type = "firmware";
arch = "arm";
ti-secure {
pm_cfg: pm-cfg {
type = "blob-ext";
rm-cfg.bin {
type = "firmware";
arch = "arm";
ti-secure {
rm_cfg: rm-cfg {
type = "blob-ext";
sec-cfg.bin {
type = "firmware";
arch = "arm";
ti-secure {
sec_cfg: sec-cfg {
type = "blob-ext";
fit {
images {
sysfw.bin {
type = "firmware";
arch = "arm";
blob-ext {
board-cfg.bin {
type = "firmware";
arch = "arm";
board-cfg {
type = "blob-ext";
pm-cfg.bin {
type = "firmware";
arch = "arm";
pm-cfg {
type = "blob-ext";
rm-cfg.bin {
type = "firmware";
arch = "arm";
rm-cfg {
type = "blob-ext";
sec-cfg.bin {
type = "firmware";
arch = "arm";
sec-cfg {
type = "blob-ext";
};insert-template = <&itb_unsigned_template>;
- fit {
type = "firmware";
arch = "arm";
board-cfg.bin {
type = "firmware";
arch = "arm";
blob-ext {
pm-cfg.bin {
type = "firmware";
arch = "arm";
blob-ext {
rm-cfg.bin {
type = "firmware";
arch = "arm";
blob-ext {
sec-cfg.bin {
type = "firmware";
arch = "arm";
blob-ext {
pad-byte = <0xff>;
fit {
images {
atf {
type = "firmware";
arch = "arm64";
ti-secure {
content = <&atf>;
atf: atf-bl31 {
tee {
type = "tee";
arch = "arm64";
os = "tee";
ti-secure {
content = <&tee>;
tee: tee-os {
dm {
type = "firmware";
arch = "arm32";
os = "DM";
spl {
os = "U-Boot";
arch = "arm64";
ti-secure {
&binman { u-boot {
pad-byte = <0xff>;
fit {insert-template = <&u_boot_template>;
description = "FIT image with multiple configurations"; images { uboot {
type = "firmware";
os = "u-boot";
arch = "arm";
ti-secure {
hash {
algo = "crc32";
description = "U-Boot for J721E Board"; }; fdt-0 {
pad-byte = <0xff>;
fit {
images {
atf {
type = "firmware";
arch = "arm64";
atf-bl31 {
tee {
type = "tee";
arch = "arm64";
os = "tee";
tee-os {
dm {
type = "firmware";
arch = "arm32";
os = "DM";
spl {
os = "U-Boot";
arch = "arm64";
blob-ext {
pad-byte = <0xff>;
fit {
images { uboot {
type = "firmware";
os = "u-boot";
arch = "arm";
blob {
hash {
algo = "crc32";
pad-byte = <0xff>;
fit {
images {
atf {
type = "firmware";
arch = "arm64";
ti-secure {
content = <&atf>;
atf: atf-bl31 {
tee {
type = "tee";
arch = "arm64";
os = "tee";
ti-secure {
content = <&tee>;
tee: tee-os {
dm {
type = "firmware";
arch = "arm32";
os = "DM";
spl {
os = "U-Boot";
arch = "arm64";
ti-secure {
&binman { u-boot {
pad-byte = <0xff>;
fit {
images { uboot {
type = "firmware";
os = "u-boot";
arch = "arm";
ti-secure {
hash {
algo = "crc32";
description = "U-Boot for J721S2 Board"; }; fdt-0 {
pad-byte = <0xff>;
fit {
images {
atf {
type = "firmware";
arch = "arm64";
atf-bl31 {
tee {
type = "tee";
arch = "arm64";
os = "tee";
tee-os {
dm {
type = "firmware";
arch = "arm32";
os = "DM";
spl {
os = "U-Boot";
arch = "arm64";
blob {
pad-byte = <0xff>;
fit {
images { uboot {
type = "firmware";
os = "u-boot";
arch = "arm";
blob {
hash {
algo = "crc32";
-- 2.34.1
Hi Manorit
On 22/11/23 10:50, Manorit Chawdhry wrote:
Hi Neha,
pad-byte = <0xff>;
fit {
images {
atf {
type = "firmware";
arch = "arm64";
ti-secure {
content = <&atf>;
I believe you will still be able to process firewalling by adding the extra parameters in the board binman DTSI file. The reason for retaining DM was different. For example, for J721E:
diff --git a/arch/arm/dts/k3-j721e-binman.dtsi b/arch/arm/dts/k3-j721e-binman.dtsi index 5ddb474e3a..647b5dc629 100644 --- a/arch/arm/dts/k3-j721e-binman.dtsi +++ b/arch/arm/dts/k3-j721e-binman.dtsi @@ -146,6 +146,27 @@
fit { images { + atf { + ti-secure { + auth-in-place = <0xa02>; + + firewall-257-0 { + /* cpu_0_cpu_0_msmc Background Firewall */ + id = <257>; + region = <0>; + control = <(FWCTRL_EN | FWCTRL_LOCK | + FWCTRL_BG | FWCTRL_CACHE)>; + permissions = <((FWPRIVID_ALL << FWPRIVID_SHIFT) | + FWPERM_SECURE_PRIV_RWCD | + FWPERM_SECURE_USER_RWCD | + FWPERM_NON_SECURE_PRIV_RWCD | + FWPERM_NON_SECURE_USER_RWCD)>; + start_address = <0x0 0x0>; + end_address = <0xff 0xffffffff>; + }; + }; + }; + dm { ti-secure { content = <&dm>;
I have only checked whether this builds fine without any errors. If you could check whether the intended functionality also works, we should be good.
With this change,
Regards, Manorit
atf: atf-bl31 {
Signed-off-by: Neha Malcom Francis n-francis@ti.com Acked-by: Andrew Davis afd@ti.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Manorit Chawdhry m-chawdhry@ti.com
Hi Neha
For the whole series:
Tested-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Thanks!
Cheers
Marcel
Hi Marcel,
On 15/11/23 23:03, Marcel Ziswiler wrote:
Hi Neha
Thanks for testing!
Thanks!
Cheers
Marcel
participants (6)
Andrew Davis
Manorit Chawdhry
Marcel Ziswiler
Neha Malcom Francis
