[U-Boot] [PATCH 1/2] OMAP5: Fix gpio_bank_54xx setting
OMAP54XX and DRA7XX SoCs have 8 banks per 32 GPIOs, that is, 256 in total. Fix the gpio bank setting.
Signed-off-by: Axel Lin axel.lin@ingics.com --- arch/arm/cpu/armv7/omap5/hwinit.c | 4 +++- arch/arm/include/asm/arch-omap5/gpio.h | 2 ++ 2 files changed, 5 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/omap5/hwinit.c b/arch/arm/cpu/armv7/omap5/hwinit.c index daf124e..11ba36b 100644 --- a/arch/arm/cpu/armv7/omap5/hwinit.c +++ b/arch/arm/cpu/armv7/omap5/hwinit.c @@ -43,13 +43,15 @@ DECLARE_GLOBAL_DATA_PTR;
u32 *const omap_si_rev = (u32 *)OMAP_SRAM_SCRATCH_OMAP_REV;
-static struct gpio_bank gpio_bank_54xx[6] = { +static struct gpio_bank gpio_bank_54xx[8] = { { (void *)OMAP54XX_GPIO1_BASE, METHOD_GPIO_24XX }, { (void *)OMAP54XX_GPIO2_BASE, METHOD_GPIO_24XX }, { (void *)OMAP54XX_GPIO3_BASE, METHOD_GPIO_24XX }, { (void *)OMAP54XX_GPIO4_BASE, METHOD_GPIO_24XX }, { (void *)OMAP54XX_GPIO5_BASE, METHOD_GPIO_24XX }, { (void *)OMAP54XX_GPIO6_BASE, METHOD_GPIO_24XX }, + { (void *)OMAP54XX_GPIO7_BASE, METHOD_GPIO_24XX }, + { (void *)OMAP54XX_GPIO8_BASE, METHOD_GPIO_24XX }, };
const struct gpio_bank *const omap_gpio_bank = gpio_bank_54xx; diff --git a/arch/arm/include/asm/arch-omap5/gpio.h b/arch/arm/include/asm/arch-omap5/gpio.h index c14dff0..f507a35 100644 --- a/arch/arm/include/asm/arch-omap5/gpio.h +++ b/arch/arm/include/asm/arch-omap5/gpio.h @@ -46,5 +46,7 @@ #define OMAP54XX_GPIO4_BASE 0x48059000 #define OMAP54XX_GPIO5_BASE 0x4805B000 #define OMAP54XX_GPIO6_BASE 0x4805D000 +#define OMAP54XX_GPIO7_BASE 0x48051000 +#define OMAP54XX_GPIO8_BASE 0x48053000
#endif /* _GPIO_OMAP5_H */
Now the omap_gpio driver is used by AM33XX, OMAP3/4, OMAP54XX and DRA7XX SoCs. These SoCs have various gpio count. Thus introduce get_omap_gpio_count() function to get correct gpio count.
Signed-off-by: Axel Lin axel.lin@ingics.com --- arch/arm/cpu/armv7/am33xx/board.c | 5 +++++ arch/arm/cpu/armv7/omap3/board.c | 5 +++++ arch/arm/cpu/armv7/omap4/hwinit.c | 5 +++++ arch/arm/cpu/armv7/omap5/hwinit.c | 5 +++++ arch/arm/include/asm/omap_gpio.h | 1 + drivers/gpio/omap_gpio.c | 2 +- 6 files changed, 22 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/am33xx/board.c b/arch/arm/cpu/armv7/am33xx/board.c index 885fb2d..405d649 100644 --- a/arch/arm/cpu/armv7/am33xx/board.c +++ b/arch/arm/cpu/armv7/am33xx/board.c @@ -51,6 +51,11 @@ static const struct gpio_bank gpio_bank_am33xx[4] = {
const struct gpio_bank *const omap_gpio_bank = gpio_bank_am33xx;
+unsigned int get_omap_gpio_count(void) +{ + return ARRAY_SIZE(gpio_bank_am33xx) * 32; +} + #if defined(CONFIG_OMAP_HSMMC) && !defined(CONFIG_SPL_BUILD) int cpu_mmc_init(bd_t *bis) { diff --git a/arch/arm/cpu/armv7/omap3/board.c b/arch/arm/cpu/armv7/omap3/board.c index b72fadc..950b13f 100644 --- a/arch/arm/cpu/armv7/omap3/board.c +++ b/arch/arm/cpu/armv7/omap3/board.c @@ -65,6 +65,11 @@ static const struct gpio_bank gpio_bank_34xx[6] = {
const struct gpio_bank *const omap_gpio_bank = gpio_bank_34xx;
+unsigned int get_omap_gpio_count(void) +{ + return ARRAY_SIZE(gpio_bank_34xx) * 32; +} + #ifdef CONFIG_SPL_BUILD /* * We use static variables because global data is not ready yet. diff --git a/arch/arm/cpu/armv7/omap4/hwinit.c b/arch/arm/cpu/armv7/omap4/hwinit.c index 81f5a48..3212980 100644 --- a/arch/arm/cpu/armv7/omap4/hwinit.c +++ b/arch/arm/cpu/armv7/omap4/hwinit.c @@ -51,6 +51,11 @@ static const struct gpio_bank gpio_bank_44xx[6] = {
const struct gpio_bank *const omap_gpio_bank = gpio_bank_44xx;
+unsigned int get_omap_gpio_count(void) +{ + return ARRAY_SIZE(gpio_bank_44xx) * 32; +} + #ifdef CONFIG_SPL_BUILD /* * Some tuning of IOs for optimal power and performance diff --git a/arch/arm/cpu/armv7/omap5/hwinit.c b/arch/arm/cpu/armv7/omap5/hwinit.c index 11ba36b..58c77e7 100644 --- a/arch/arm/cpu/armv7/omap5/hwinit.c +++ b/arch/arm/cpu/armv7/omap5/hwinit.c @@ -56,6 +56,11 @@ static struct gpio_bank gpio_bank_54xx[8] = {
+unsigned int get_omap_gpio_count(void) +{ + return ARRAY_SIZE(gpio_bank_54xx) * 32; +} + #ifdef CONFIG_SPL_BUILD /* LPDDR2 specific IO settings */ static void io_settings_lpddr2(void) diff --git a/arch/arm/include/asm/omap_gpio.h b/arch/arm/include/asm/omap_gpio.h index 1ebfa86..5e25707 100644 --- a/arch/arm/include/asm/omap_gpio.h +++ b/arch/arm/include/asm/omap_gpio.h @@ -46,6 +46,7 @@ struct gpio_bank { };
extern const struct gpio_bank *const omap_gpio_bank; +extern unsigned int get_omap_gpio_count(void);
#define METHOD_GPIO_24XX 4
diff --git a/drivers/gpio/omap_gpio.c b/drivers/gpio/omap_gpio.c index a30d7f0..1088803 100644 --- a/drivers/gpio/omap_gpio.c +++ b/drivers/gpio/omap_gpio.c @@ -55,7 +55,7 @@ static inline int get_gpio_index(int gpio)
int gpio_is_valid(int gpio) { - return (gpio >= 0) && (gpio < 192); + return (gpio >= 0) && (gpio < get_omap_gpio_count()); }
static int check_gpio(int gpio)
Axel,
Why do you introduce a function when this stuff is constant and known to the compiler? Just put a #define in every header. You are now uselessly inflating code...
Regards, Lubo
- return ARRAY_SIZE(gpio_bank_am33xx) * 32;
- return ARRAY_SIZE(gpio_bank_34xx) * 32;
- We use static variables because global data is not ready yet.
- return ARRAY_SIZE(gpio_bank_44xx) * 32;
- Some tuning of IOs for optimal power and performance
- return ARRAY_SIZE(gpio_bank_54xx) * 32;
- return (gpio >= 0) && (gpio < get_omap_gpio_count());
Axel Lin
Lubomir Popov
