[PATCH 1/2] config: stm32mp15: remove CONFIG_FASTBOOT_USB_DEV
The CONFIG_FASTBOOT_USB_DEV is used to select USB OTG controller other than 0 but it is not the case for STM32MP15 boards; it can be removed to simplify the STM32MP15 defconfig files.
On STM32MP15x boards, we have only one USB device with instance 0, so the device is hardcoded arch/arm/mach-stm32mp/cpu.c with the command "fastboot 0" and this define is not used in config files (include/configs/stm32mp15_st_common.h).
Fixes: 4633fd51c5d7 ("stm32mp1: activate FASTBOOT on eMMC") Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
configs/stm32mp15_basic_defconfig | 1 - configs/stm32mp15_defconfig | 1 - configs/stm32mp15_trusted_defconfig | 1 - 3 files changed, 3 deletions(-)
diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index 13355ebb4692..174eb42d6447 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -102,7 +102,6 @@ CONFIG_SET_DFU_ALT_INFO=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0xC0000000 CONFIG_FASTBOOT_BUF_SIZE=0x02000000 -CONFIG_FASTBOOT_USB_DEV=1 CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_FLASH_MMC_DEV=1 CONFIG_FASTBOOT_MMC_BOOT_SUPPORT=y diff --git a/configs/stm32mp15_defconfig b/configs/stm32mp15_defconfig index 2669aae0f2f4..b25477c64d03 100644 --- a/configs/stm32mp15_defconfig +++ b/configs/stm32mp15_defconfig @@ -75,7 +75,6 @@ CONFIG_SET_DFU_ALT_INFO=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0xC0000000 CONFIG_FASTBOOT_BUF_SIZE=0x02000000 -CONFIG_FASTBOOT_USB_DEV=1 CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_FLASH_MMC_DEV=1 CONFIG_FASTBOOT_MMC_BOOT_SUPPORT=y diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index 5f0fb4565105..e93a66f867cf 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -76,7 +76,6 @@ CONFIG_SET_DFU_ALT_INFO=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0xC0000000 CONFIG_FASTBOOT_BUF_SIZE=0x02000000 -CONFIG_FASTBOOT_USB_DEV=1 CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_FLASH_MMC_DEV=1 CONFIG_FASTBOOT_MMC_BOOT_SUPPORT=y
Remove the support of the fastboot "oem format" command for STM32MP15x boards and removed the associated env variable "partitions". This command is not required; with fastboot tool, the GPT partition can be handle with "flash" command in "gpt" target (=CONFIG_FASTBOOT_GPT_NAME), for example: fastboot flash gpt gpt.bin
This patch avoids to define the GPT partitioning in U-Boot environment, which is incompatible with planned modifications, for example to support TF-A firmware update.
configs/stm32mp15_basic_defconfig | 1 - configs/stm32mp15_defconfig | 1 - configs/stm32mp15_trusted_defconfig | 1 - include/configs/stm32mp15_common.h | 14 -------------- include/configs/stm32mp15_st_common.h | 1 - 5 files changed, 18 deletions(-)
diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index 174eb42d6447..dc67873d3934 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -109,7 +109,6 @@ CONFIG_FASTBOOT_MMC_BOOT1_NAME="mmc1boot0" CONFIG_FASTBOOT_MMC_BOOT2_NAME="mmc1boot1" CONFIG_FASTBOOT_MMC_USER_SUPPORT=y CONFIG_FASTBOOT_MMC_USER_NAME="mmc1" -CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_FASTBOOT_CMD_OEM_PARTCONF=y CONFIG_FASTBOOT_CMD_OEM_BOOTBUS=y CONFIG_GPIO_HOG=y diff --git a/configs/stm32mp15_defconfig b/configs/stm32mp15_defconfig index b25477c64d03..fd8c9121762e 100644 --- a/configs/stm32mp15_defconfig +++ b/configs/stm32mp15_defconfig @@ -82,7 +82,6 @@ CONFIG_FASTBOOT_MMC_BOOT1_NAME="mmc1boot0" CONFIG_FASTBOOT_MMC_BOOT2_NAME="mmc1boot1" CONFIG_FASTBOOT_MMC_USER_SUPPORT=y CONFIG_FASTBOOT_MMC_USER_NAME="mmc1" -CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_FASTBOOT_CMD_OEM_PARTCONF=y CONFIG_FASTBOOT_CMD_OEM_BOOTBUS=y CONFIG_GPIO_HOG=y diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index e93a66f867cf..ec6298a0cb4a 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -83,7 +83,6 @@ CONFIG_FASTBOOT_MMC_BOOT1_NAME="mmc1boot0" CONFIG_FASTBOOT_MMC_BOOT2_NAME="mmc1boot1" CONFIG_FASTBOOT_MMC_USER_SUPPORT=y CONFIG_FASTBOOT_MMC_USER_NAME="mmc1" -CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_FASTBOOT_CMD_OEM_PARTCONF=y CONFIG_FASTBOOT_CMD_OEM_BOOTBUS=y CONFIG_GPIO_HOG=y diff --git a/include/configs/stm32mp15_common.h b/include/configs/stm32mp15_common.h index 7db72a19ed95..29a1197b5ae2 100644 --- a/include/configs/stm32mp15_common.h +++ b/include/configs/stm32mp15_common.h @@ -92,19 +92,6 @@ "run distro_bootcmd;" \ "fi;\0"
-#ifdef CONFIG_FASTBOOT_CMD_OEM_FORMAT -/* eMMC default partitions for fastboot command: oem format */ -#define STM32MP_PARTS_DEFAULT \ - "partitions=" \ - "name=ssbl,size=2M;" \ - "name=bootfs,size=64MB,bootable;" \ - "name=vendorfs,size=16M;" \ - "name=rootfs,size=746M;" \ - "name=userfs,size=-\0" -#else -#define STM32MP_PARTS_DEFAULT -#endif - #define STM32MP_EXTRA \ "env_check=if env info -p -d -q; then env save; fi\0" \ "boot_net_usb_start=true\0" @@ -138,7 +125,6 @@ #define CFG_EXTRA_ENV_SETTINGS \ STM32MP_MEM_LAYOUT \ STM32MP_BOOTCMD \ - STM32MP_PARTS_DEFAULT \ BOOTENV \ STM32MP_EXTRA \ STM32MP_BOARD_EXTRA_ENV diff --git a/include/configs/stm32mp15_st_common.h b/include/configs/stm32mp15_st_common.h index 866cd7a719f8..b45982a35b8c 100644 --- a/include/configs/stm32mp15_st_common.h +++ b/include/configs/stm32mp15_st_common.h @@ -47,7 +47,6 @@ #define CFG_EXTRA_ENV_SETTINGS \ STM32MP_MEM_LAYOUT \ ST_STM32MP1_BOOTCMD \ - STM32MP_PARTS_DEFAULT \ BOOTENV \ STM32MP_EXTRA \ STM32MP_BOARD_EXTRA_ENV
- "partitions=" \
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com
Thanks Patrice
- "partitions=" \
Applied to u-boot-stm/next
Thanks Patrice
Hi Patrick
Thanks Patrice
Thanks Patrice
Patrice CHOTARD
Patrick Delaunay
