Re: [U-Boot] [PATCH] arm: socfpga: Fixed Phy not found error. Fixed QSPI flash not found error Disabled Hardware watch dog by default. Updated MMC clock.
On Thursday, December 17, 2015 at 07:59:34 AM, ShengjiangWu wrote:
Hi Marek Vasut,
I will submit it later, thanks for your reminder.
Thanks.
Also, please do not top-post and please keep the entire Cc list intact. Also keep the ML in the list.
Best Regards Shengjiang Wu
------------------ Original ------------------ From: "marex";marex@denx.de; Date: Thu, Dec 17, 2015 11:46 AM To: "ShengjiangWu"shengjiangwu@qq.com; Cc: "u-boot"u-boot@lists.denx.de; "shengjiangwu"shengjiangwu@gmail.com; "clsee"clsee@altera.com; "dinguyen"dinguyen@opensource.altera.com; "dinh.linux"dinh.linux@gmail.com; "pavel"pavel@denx.de; "sr"sr@denx.de; Subject: Re: [PATCH] arm: socfpga: Fixed Phy not found error. Fixed QSPI flash not found error Disabled Hardware watch dog by default. Updated MMC clock.
Fix your mailer please.
Updated pinmux and clock for EMAC1 and QSPI flash. U-BOOT-2015-10 can run on Cyclone V SoC Development Kit (SoCDK) with this fix. Signed-off-by: swu <shengjiangwu@gmail.com> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Dinh Nguyen <dinh.linux@gmail.com> Cc: Pavel Machek <pavel@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Stefan Roese <sr@denx.de>
Please repost the patch using git send-email , details are at [1] and the process is very similar to Linux.
I briefly skimmed across the patch. I don't understand why do you replace almost the entire pinmux just to fix ethernet issue. (ethernet works on SoCDK I believe, which is another odd thing).
Furthermore, if you're fixing multiple things, split them into multiple patches.
Finally, do not disable HW watchdog.
[1] www.denx.de/wiki/U-Boot/Patches
Best regards, Marek Vasut
