[U-Boot] [PATCH 0/3] rockchip: rk3328: add CONFIG_RAM_ROCKCHIP_DEBUG support
It would be great to allow user to get extra information for debugging issues with TPL. We can reuse the existing code for rk3399 which print out results of memory configuration at TPL.
Matwey V. Kornilov (3): rockchip: rk3328: use common struct sdram_base_params for struct rk3328_sdram_params rockchip: rk3328: use common struct sdram_cap_info for struct rk3328_sdram_channel rockchip: rk3328: call sdram_print_ddr_info() at init
arch/arm/dts/rk3328-sdram-ddr3-666.dtsi | 2 + arch/arm/dts/rk3328-sdram-lpddr3-1600.dtsi | 2 + arch/arm/dts/rk3328-sdram-lpddr3-666.dtsi | 2 + arch/arm/include/asm/arch-rockchip/sdram_rk3328.h | 17 +--- drivers/ram/rockchip/Makefile | 2 +- drivers/ram/rockchip/sdram_rk3328.c | 116 +++++++++++----------- 6 files changed, 68 insertions(+), 73 deletions(-)
Currently, struct sdram_base_params and struct rk3328_sdram_params have similar layouts.
Signed-off-by: Matwey V. Kornilov matwey.kornilov@gmail.com --- arch/arm/dts/rk3328-sdram-ddr3-666.dtsi | 2 ++ arch/arm/dts/rk3328-sdram-lpddr3-1600.dtsi | 2 ++ arch/arm/dts/rk3328-sdram-lpddr3-666.dtsi | 2 ++ arch/arm/include/asm/arch-rockchip/sdram_rk3328.h | 4 +--- drivers/ram/rockchip/sdram_rk3328.c | 28 +++++++++++------------ 5 files changed, 21 insertions(+), 17 deletions(-)
diff --git a/arch/arm/dts/rk3328-sdram-ddr3-666.dtsi b/arch/arm/dts/rk3328-sdram-ddr3-666.dtsi index d99e7e0352..5a26115448 100644 --- a/arch/arm/dts/rk3328-sdram-ddr3-666.dtsi +++ b/arch/arm/dts/rk3328-sdram-ddr3-666.dtsi @@ -26,6 +26,8 @@
333 3 + 1 + 0 0
0x00000000 diff --git a/arch/arm/dts/rk3328-sdram-lpddr3-1600.dtsi b/arch/arm/dts/rk3328-sdram-lpddr3-1600.dtsi index cc0011cf7b..11c1df9164 100644 --- a/arch/arm/dts/rk3328-sdram-lpddr3-1600.dtsi +++ b/arch/arm/dts/rk3328-sdram-lpddr3-1600.dtsi @@ -27,6 +27,8 @@ 800 6 1 + 0 + 1
0x00000000 0x43041008 diff --git a/arch/arm/dts/rk3328-sdram-lpddr3-666.dtsi b/arch/arm/dts/rk3328-sdram-lpddr3-666.dtsi index 62d809e833..ad3f3e7ee8 100644 --- a/arch/arm/dts/rk3328-sdram-lpddr3-666.dtsi +++ b/arch/arm/dts/rk3328-sdram-lpddr3-666.dtsi @@ -26,6 +26,8 @@
333 6 + 1 + 0 0
0x00000000 diff --git a/arch/arm/include/asm/arch-rockchip/sdram_rk3328.h b/arch/arm/include/asm/arch-rockchip/sdram_rk3328.h index 11411ead10..ea5f5bfd86 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_rk3328.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_rk3328.h @@ -428,9 +428,7 @@ struct rk3328_sdram_channel {
struct rk3328_sdram_params { struct rk3328_sdram_channel ch; - unsigned int ddr_freq; - unsigned int dramtype; - unsigned int odt; + struct sdram_base_params base; struct rk3328_ddr_pctl_regs pctl_regs; struct rk3328_ddr_phy_regs phy_regs; struct rk3328_ddr_skew skew; diff --git a/drivers/ram/rockchip/sdram_rk3328.c b/drivers/ram/rockchip/sdram_rk3328.c index 656696ac3c..59b1638785 100644 --- a/drivers/ram/rockchip/sdram_rk3328.c +++ b/drivers/ram/rockchip/sdram_rk3328.c @@ -122,7 +122,7 @@ static void rkclk_configure_ddr(struct dram_info *dram, clrbits_le32(PHY_REG(phy_base, 0xef), 1 << 7);
/* for inno ddr phy need 2*freq */ - rkclk_set_dpll(dram, sdram_params->ddr_freq * 2); + rkclk_set_dpll(dram, sdram_params->base.ddr_freq * 2); }
static void phy_soft_reset(struct dram_info *dram) @@ -154,7 +154,7 @@ static int pctl_cfg(struct dram_info *dram, * dfi_lp_en_pd=1,dfi_lp_wakeup_pd=2 * hw_lp_idle_x32=1 */ - if (sdram_params->dramtype == LPDDR3) { + if (sdram_params->base.dramtype == LPDDR3) { setbits_le32(pctl_base + DDR_PCTL2_DFILPCFG0, 1); clrsetbits_le32(pctl_base + DDR_PCTL2_DFILPCFG0, 0xf << 4, @@ -230,7 +230,7 @@ static unsigned int calculate_ddrconfig(struct rk3328_sdram_params *sdram_params row = sdram_ch.cs0_row; bank = sdram_ch.bk;
- if (sdram_params->dramtype == DDR4) { + if (sdram_params->base.dramtype == DDR4) { tmp = ((cs - 1) << 6) | ((row - 13) << 3) | (bw & 0x2) | die_bw; for (i = 10; i < 17; i++) { if (((tmp & 0x7) == (ddr4_cfg_2_rbc[i - 10] & 0x7)) && @@ -286,9 +286,9 @@ static void set_ctl_address_map(struct dram_info *dram,
copy_to_reg((u32 *)(pctl_base + DDR_PCTL2_ADDRMAP0), &addrmap[sdram_ch.ddrconfig][0], 9 * 4); - if (sdram_params->dramtype == LPDDR3 && sdram_ch.row_3_4) + if (sdram_params->base.dramtype == LPDDR3 && sdram_ch.row_3_4) setbits_le32(pctl_base + DDR_PCTL2_ADDRMAP6, 1 << 31); - if (sdram_params->dramtype == DDR4 && sdram_ch.bw == 0x1) + if (sdram_params->base.dramtype == DDR4 && sdram_ch.bw == 0x1) setbits_le32(pctl_base + DDR_PCTL2_PCCFG, 1 << 8);
if (sdram_ch.rank == 1) @@ -332,7 +332,7 @@ static void set_ds_odt(struct dram_info *dram, u32 cmd_drv, clk_drv, dqs_drv, dqs_odt; void __iomem *phy_base = dram->phy;
- if (sdram_params->dramtype == DDR3) { + if (sdram_params->base.dramtype == DDR3) { cmd_drv = PHY_DDR3_RON_RTT_34ohm; clk_drv = PHY_DDR3_RON_RTT_45ohm; dqs_drv = PHY_DDR3_RON_RTT_34ohm; @@ -373,7 +373,7 @@ static void phy_cfg(struct dram_info *dram, u32 i; void __iomem *phy_base = dram->phy;
- phy_dll_bypass_set(dram, sdram_params->ddr_freq); + phy_dll_bypass_set(dram, sdram_params->base.ddr_freq); for (i = 0; sdram_params->phy_regs.phy[i][0] != 0xFFFFFFFF; i++) { writel(sdram_params->phy_regs.phy[i][1], phy_base + sdram_params->phy_regs.phy[i][0]); @@ -587,7 +587,7 @@ static void dram_all_config(struct dram_info *dram,
set_ddrconfig(dram, sdram_ch.ddrconfig);
- sys_reg |= SYS_REG_ENC_DDRTYPE(sdram_params->dramtype); + sys_reg |= SYS_REG_ENC_DDRTYPE(sdram_params->base.dramtype); sys_reg |= SYS_REG_ENC_ROW_3_4(sdram_ch.row_3_4, 0); sys_reg |= SYS_REG_ENC_RANK(sdram_ch.rank, 0); sys_reg |= SYS_REG_ENC_COL(sdram_ch.col, 0); @@ -653,7 +653,7 @@ static int sdram_init(struct dram_info *dram, rkclk_ddr_reset(dram, 1, 1, 1, 0); rkclk_configure_ddr(dram, sdram_params); if (pre_init == 0) { - switch (sdram_params->dramtype) { + switch (sdram_params->base.dramtype) { case DDR3: printf("DDR3\n"); break; @@ -685,13 +685,13 @@ static int sdram_init(struct dram_info *dram, continue;
/* do ddr gate training */ - if (data_training(dram, 0, sdram_params->dramtype) != 0) { + if (data_training(dram, 0, sdram_params->base.dramtype) != 0) { printf("data training error\n"); return -1; }
- if (sdram_params->dramtype == DDR4) - write_vrefdq(dram, 0x3, 5670, sdram_params->dramtype); + if (sdram_params->base.dramtype == DDR4) + write_vrefdq(dram, 0x3, 5670, sdram_params->base.dramtype);
if (pre_init == 0) { rx_deskew_switch_adjust(dram); @@ -724,7 +724,7 @@ static u64 dram_detect_cap(struct dram_info *dram, u32 cs; u32 bw = 1; u64 cap = 0; - u32 dram_type = sdram_params->dramtype; + u32 dram_type = sdram_params->base.dramtype; u32 pwrctl;
if (dram_type != DDR4) { @@ -907,7 +907,7 @@ static int dram_detect_cs1_row(struct rk3328_sdram_params *sdram_params, else cs1_bit = 0;
- if (sdram_params->dramtype == DDR4) { + if (sdram_params->base.dramtype == DDR4) { if (sdram_ch.dbw == 0) bktmp = sdram_ch.bk + 2; else
Currently, struct sdram_cap_info and struct rk3328_sdram_channel have similar layouts.
Signed-off-by: Matwey V. Kornilov matwey.kornilov@gmail.com --- arch/arm/include/asm/arch-rockchip/sdram_rk3328.h | 13 +--- drivers/ram/rockchip/sdram_rk3328.c | 90 +++++++++++------------ 2 files changed, 46 insertions(+), 57 deletions(-)
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_rk3328.h b/arch/arm/include/asm/arch-rockchip/sdram_rk3328.h index ea5f5bfd86..e09fecd376 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_rk3328.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_rk3328.h @@ -411,18 +411,7 @@ struct rk3328_ddr_skew { };
struct rk3328_sdram_channel { - unsigned int rank; - unsigned int col; - /* 3:8bank, 2:4bank */ - unsigned int bk; - /* channel buswidth, 2:32bit, 1:16bit, 0:8bit */ - unsigned int bw; - /* die buswidth, 2:32bit, 1:16bit, 0:8bit */ - unsigned int dbw; - unsigned int row_3_4; - unsigned int cs0_row; - unsigned int cs1_row; - unsigned int ddrconfig; + struct sdram_cap_info cap_info; struct rk3328_msch_timings noc_timings; };
diff --git a/drivers/ram/rockchip/sdram_rk3328.c b/drivers/ram/rockchip/sdram_rk3328.c index 59b1638785..c2537cc95d 100644 --- a/drivers/ram/rockchip/sdram_rk3328.c +++ b/drivers/ram/rockchip/sdram_rk3328.c @@ -223,12 +223,12 @@ static unsigned int calculate_ddrconfig(struct rk3328_sdram_params *sdram_params u32 i, tmp; u32 ddrconf = -1;
- cs = sdram_ch.rank; - bw = sdram_ch.bw; - die_bw = sdram_ch.dbw; - col = sdram_ch.col; - row = sdram_ch.cs0_row; - bank = sdram_ch.bk; + cs = sdram_ch.cap_info.rank; + bw = sdram_ch.cap_info.bw; + die_bw = sdram_ch.cap_info.dbw; + col = sdram_ch.cap_info.col; + row = sdram_ch.cap_info.cs0_row; + bank = sdram_ch.cap_info.bk;
if (sdram_params->base.dramtype == DDR4) { tmp = ((cs - 1) << 6) | ((row - 13) << 3) | (bw & 0x2) | die_bw; @@ -285,13 +285,13 @@ static void set_ctl_address_map(struct dram_info *dram, void __iomem *pctl_base = dram->pctl;
copy_to_reg((u32 *)(pctl_base + DDR_PCTL2_ADDRMAP0), - &addrmap[sdram_ch.ddrconfig][0], 9 * 4); - if (sdram_params->base.dramtype == LPDDR3 && sdram_ch.row_3_4) + &addrmap[sdram_ch.cap_info.ddrconfig][0], 9 * 4); + if (sdram_params->base.dramtype == LPDDR3 && sdram_ch.cap_info.row_3_4) setbits_le32(pctl_base + DDR_PCTL2_ADDRMAP6, 1 << 31); - if (sdram_params->base.dramtype == DDR4 && sdram_ch.bw == 0x1) + if (sdram_params->base.dramtype == DDR4 && sdram_ch.cap_info.bw == 0x1) setbits_le32(pctl_base + DDR_PCTL2_PCCFG, 1 << 8);
- if (sdram_ch.rank == 1) + if (sdram_ch.cap_info.rank == 1) clrsetbits_le32(pctl_base + DDR_PCTL2_ADDRMAP0, 0x1f, 0x1f); }
@@ -378,7 +378,7 @@ static void phy_cfg(struct dram_info *dram, writel(sdram_params->phy_regs.phy[i][1], phy_base + sdram_params->phy_regs.phy[i][0]); } - if (sdram_ch.bw == 2) { + if (sdram_ch.cap_info.bw == 2) { clrsetbits_le32(PHY_REG(phy_base, 0), 0xf << 4, 0xf << 4); } else { clrsetbits_le32(PHY_REG(phy_base, 0), 0xf << 4, 3 << 4); @@ -585,18 +585,18 @@ static void dram_all_config(struct dram_info *dram, { u32 sys_reg = 0, tmp = 0;
- set_ddrconfig(dram, sdram_ch.ddrconfig); + set_ddrconfig(dram, sdram_ch.cap_info.ddrconfig);
sys_reg |= SYS_REG_ENC_DDRTYPE(sdram_params->base.dramtype); - sys_reg |= SYS_REG_ENC_ROW_3_4(sdram_ch.row_3_4, 0); - sys_reg |= SYS_REG_ENC_RANK(sdram_ch.rank, 0); - sys_reg |= SYS_REG_ENC_COL(sdram_ch.col, 0); - sys_reg |= SYS_REG_ENC_BK(sdram_ch.bk, 0); - SYS_REG_ENC_CS0_ROW(sdram_ch.cs0_row, sys_reg, tmp, 0); - if (sdram_ch.cs1_row) - SYS_REG_ENC_CS1_ROW(sdram_ch.cs1_row, sys_reg, tmp, 0); - sys_reg |= SYS_REG_ENC_BW(sdram_ch.bw, 0); - sys_reg |= SYS_REG_ENC_DBW(sdram_ch.dbw, 0); + sys_reg |= SYS_REG_ENC_ROW_3_4(sdram_ch.cap_info.row_3_4, 0); + sys_reg |= SYS_REG_ENC_RANK(sdram_ch.cap_info.rank, 0); + sys_reg |= SYS_REG_ENC_COL(sdram_ch.cap_info.col, 0); + sys_reg |= SYS_REG_ENC_BK(sdram_ch.cap_info.bk, 0); + SYS_REG_ENC_CS0_ROW(sdram_ch.cap_info.cs0_row, sys_reg, tmp, 0); + if (sdram_ch.cap_info.cs1_row) + SYS_REG_ENC_CS1_ROW(sdram_ch.cap_info.cs1_row, sys_reg, tmp, 0); + sys_reg |= SYS_REG_ENC_BW(sdram_ch.cap_info.bw, 0); + sys_reg |= SYS_REG_ENC_DBW(sdram_ch.cap_info.dbw, 0);
writel(sys_reg, &dram->grf->os_reg[2]);
@@ -673,7 +673,7 @@ static int sdram_init(struct dram_info *dram, /* release ctrl presetn, and config ctl registers */ rkclk_ddr_reset(dram, 1, 0, 0, 0); pctl_cfg(dram, sdram_params); - sdram_ch.ddrconfig = calculate_ddrconfig(sdram_params); + sdram_ch.cap_info.ddrconfig = calculate_ddrconfig(sdram_params); set_ctl_address_map(dram, sdram_params); phy_cfg(dram, sdram_params);
@@ -820,17 +820,17 @@ static u64 dram_detect_cap(struct dram_info *dram, /* restore auto low-power */ writel(pwrctl, pctl_base + DDR_PCTL2_PWRCTL);
- sdram_ch.rank = cs + 1; - sdram_ch.col = col; - sdram_ch.bk = bk; - sdram_ch.dbw = dbw; - sdram_ch.bw = bw; - sdram_ch.cs0_row = row; + sdram_ch.cap_info.rank = cs + 1; + sdram_ch.cap_info.col = col; + sdram_ch.cap_info.bk = bk; + sdram_ch.cap_info.dbw = dbw; + sdram_ch.cap_info.bw = bw; + sdram_ch.cap_info.cs0_row = row; if (cs) - sdram_ch.cs1_row = row; + sdram_ch.cap_info.cs1_row = row; else - sdram_ch.cs1_row = 0; - sdram_ch.row_3_4 = row_3_4; + sdram_ch.cap_info.cs1_row = 0; + sdram_ch.cap_info.row_3_4 = row_3_4;
if (dram_type == DDR4) cap = 1llu << (cs + row + bk + col + ((dbw == 0) ? 2 : 1) + bw); @@ -856,7 +856,7 @@ static u32 remodify_sdram_params(struct rk3328_sdram_params *sdram_params)
tmp &= ~((3ul << 30) | (3ul << 24) | (3ul << 12));
- switch (sdram_ch.dbw) { + switch (sdram_ch.cap_info.dbw) { case 2: tmp |= (3ul << 30); break; @@ -869,16 +869,16 @@ static u32 remodify_sdram_params(struct rk3328_sdram_params *sdram_params) break; }
- if (sdram_ch.rank == 2) + if (sdram_ch.cap_info.rank == 2) tmp |= 3 << 24; else tmp |= 1 << 24;
- tmp |= (2 - sdram_ch.bw) << 12; + tmp |= (2 - sdram_ch.cap_info.bw) << 12;
sdram_params->pctl_regs.pctl[tmp_adr][1] = tmp;
- if (sdram_ch.bw == 2) + if (sdram_ch.cap_info.bw == 2) sdram_ch.noc_timings.ddrtiming.b.bwratio = 0; else sdram_ch.noc_timings.ddrtiming.b.bwratio = 1; @@ -893,9 +893,9 @@ static int dram_detect_cs1_row(struct rk3328_sdram_params *sdram_params, u32 cs1_bit; void __iomem *test_addr, *cs1_addr; u32 row, bktmp, coltmp, bw; - u32 ddrconf = sdram_ch.ddrconfig; + u32 ddrconf = sdram_ch.cap_info.ddrconfig;
- if (sdram_ch.rank == 2) { + if (sdram_ch.cap_info.rank == 2) { cs1_bit = addrmap[ddrconf][0] + 8;
if (cs1_bit > 31) @@ -908,18 +908,18 @@ static int dram_detect_cs1_row(struct rk3328_sdram_params *sdram_params, cs1_bit = 0;
if (sdram_params->base.dramtype == DDR4) { - if (sdram_ch.dbw == 0) - bktmp = sdram_ch.bk + 2; + if (sdram_ch.cap_info.dbw == 0) + bktmp = sdram_ch.cap_info.bk + 2; else - bktmp = sdram_ch.bk + 1; + bktmp = sdram_ch.cap_info.bk + 1; } else { - bktmp = sdram_ch.bk; + bktmp = sdram_ch.cap_info.bk; } - bw = sdram_ch.bw; - coltmp = sdram_ch.col; + bw = sdram_ch.cap_info.bw; + coltmp = sdram_ch.cap_info.col;
/* detect cs1 row */ - for (row = sdram_ch.cs0_row; row > 12; row--) { + for (row = sdram_ch.cap_info.cs0_row; row > 12; row--) { test_addr = (void __iomem *)(SDRAM_ADDR + cs1_addr + (1ul << (row + cs1_bit + bktmp + coltmp + bw - 1ul))); @@ -954,7 +954,7 @@ static int sdram_init_detect(struct dram_info *dram, sdram_init(dram, sdram_params, 0);
/* redetect cs1 row */ - sdram_ch.cs1_row = + sdram_ch.cap_info.cs1_row = dram_detect_cs1_row(sdram_params, 0);
Make it possible to use CONFIG_RAM_ROCKCHIP_DEBUG when debuging TPL issues.
Signed-off-by: Matwey V. Kornilov matwey.kornilov@gmail.com --- drivers/ram/rockchip/Makefile | 2 +- drivers/ram/rockchip/sdram_rk3328.c | 2 ++ 2 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/ram/rockchip/Makefile b/drivers/ram/rockchip/Makefile index feb1f82d00..f857abce1f 100644 --- a/drivers/ram/rockchip/Makefile +++ b/drivers/ram/rockchip/Makefile @@ -3,7 +3,6 @@ # Copyright (c) 2017 Theobroma Systems Design und Consulting GmbH #
-obj-$(CONFIG_RAM_ROCKCHIP_DEBUG) += sdram_debug.o obj-$(CONFIG_ROCKCHIP_RK3368) = dmc-rk3368.o obj-$(CONFIG_ROCKCHIP_RK3128) = sdram_rk3128.o obj-$(CONFIG_ROCKCHIP_RK3188) = sdram_rk3188.o @@ -11,3 +10,4 @@ obj-$(CONFIG_ROCKCHIP_RK322X) = sdram_rk322x.o obj-$(CONFIG_ROCKCHIP_RK3288) = sdram_rk3288.o obj-$(CONFIG_ROCKCHIP_RK3328) = sdram_rk3328.o obj-$(CONFIG_RAM_RK3399) += sdram_rk3399.o +obj-$(CONFIG_RAM_ROCKCHIP_DEBUG) += sdram_debug.o diff --git a/drivers/ram/rockchip/sdram_rk3328.c b/drivers/ram/rockchip/sdram_rk3328.c index c2537cc95d..6884f53ae5 100644 --- a/drivers/ram/rockchip/sdram_rk3328.c +++ b/drivers/ram/rockchip/sdram_rk3328.c @@ -684,6 +684,8 @@ static int sdram_init(struct dram_info *dram, while ((readl(pctl_base + DDR_PCTL2_STAT) & 0x7) == 0) continue;
+ sdram_print_ddr_info(&sdram_ch.cap_info, &sdram_params->base); + /* do ddr gate training */ if (data_training(dram, 0, sdram_params->base.dramtype) != 0) { printf("data training error\n");
Matwey V. Kornilov
