[PATCH] mtd: nand: mxs_nand_spl: Remove the page aligned access
The mxs_nand_spl driver can support to read from page unaligned offset, so don't need to set bl_len to ask spl_load_simple_fit to handle the page unaligned access.
Actually spl_load_simple_fit has two parts of reading: spl_simple_fit_read and spl_load_fit_image. The spl_load_fit_image can handle the page unaligned offset, but the spl_simple_fit_read can't do it. spl_simple_fit_read requires the FIT location at page aligned offset.
Hence, remove the nand_get_mtd overwrite function from mxs_nand_spl to use page unaligned read by driver.
Signed-off-by: Ye Li ye.li@nxp.com --- drivers/mtd/nand/raw/mxs_nand_spl.c | 5 ----- 1 file changed, 5 deletions(-)
diff --git a/drivers/mtd/nand/raw/mxs_nand_spl.c b/drivers/mtd/nand/raw/mxs_nand_spl.c index 9e0b8afb..59a67ee 100644 --- a/drivers/mtd/nand/raw/mxs_nand_spl.c +++ b/drivers/mtd/nand/raw/mxs_nand_spl.c @@ -283,11 +283,6 @@ int nand_spl_load_image(uint32_t offs, unsigned int size, void *buf) return 0; }
-struct mtd_info *nand_get_mtd(void) -{ - return mtd; -} - int nand_default_bbt(struct mtd_info *mtd) { return 0;
return mtd;
int nand_default_bbt(struct mtd_info *mtd) { return 0; -- 2.7.4
Ye Li,
Tested-by: Tim Harvey tharvey@gateworks.com #gw_ventana
Note however that I use UBIFS to store the kernel/dtb's and do not use a FIT image
Best Regards,
Tim
The mxs_nand_spl driver can support to read from page unaligned offset, so don't need to set bl_len to ask spl_load_simple_fit to handle the page unaligned access. Actually spl_load_simple_fit has two parts of reading: spl_simple_fit_read and spl_load_fit_image. The spl_load_fit_image can handle the page unaligned offset, but the spl_simple_fit_read can't do it. spl_simple_fit_read requires the FIT location at page aligned offset. Hence, remove the nand_get_mtd overwrite function from mxs_nand_spl to use page unaligned read by driver. Signed-off-by: Ye Li ye.li@nxp.com Tested-by: Tim Harvey tharvey@gateworks.com #gw_ventana
Best regards, Stefano Babic
sbabic@denx.de
Tim Harvey
Ye Li
