Hi Tom,
Please pull the fixex for rockchip platform: - pmic fix for rk8xx; - pinctrl fix for rk3188/rv1126/rk3588; - mkimage fix for rockcihp "-l" option;
CI: https://source.denx.de/u-boot/custodians/u-boot-rockchip/-/pipelines/21111
Thanks, - Kever
The following changes since commit ca6a992e09441d6cca73439c63c3735f86b36ea4:
cmd: sound: fix help text (2024-06-13 09:31:56 -0600)
https://source.denx.de/u-boot/custodians/u-boot-rockchip.git tags/u-boot-rockchip-20240614
for you to fetch changes up to 3f9a19befe9277db2a337552912c6ddbcc0c8b10:
rockchip: mkimage: fix mkimage -l for header v1 (2024-06-14 17:07:59 +0800)
---------------------------------------------------------------- Chris Morgan (2): Revert "board: rockchip: Add early ADC button detect for RGxx3" board: rockchip: rgxx3: Use sdmmc0 as first device
Jonas Karlman (3): pinctrl: rockchip: rk3188: Fix support for IOMUX_GPIO_ONLY flag pinctrl: rockchip: rv1126: Fix support for IOMUX_L_SOURCE_PMU flag pinctrl: rockchip: rk3588: Fix support for rockchip_get_mux()
Quentin Schulz (4): regulator: rk8xx: fix incorrect device used for _ldo_[sg]et_suspend_value regulator: rk8xx: pass pmic udevice instead of regulator to all internal functions regulator: rk8xx: clarify operator precedence rockchip: mkimage: fix mkimage -l for header v1
arch/arm/dts/rk3566-anbernic-rgxx3-u-boot.dtsi | 2 +- board/anbernic/rgxx3_rk3566/rgxx3-rk3566.c | 64 ------------------------ drivers/pinctrl/rockchip/pinctrl-rockchip-core.c | 40 ++++++++++++--- drivers/power/regulator/rk8xx.c | 54 ++++++++++---------- tools/rkcommon.c | 2 +- 5 files changed, 63 insertions(+), 99 deletions(-)
On Sat, Jun 15, 2024 at 08:11:49PM +0800, Kever Yang wrote:
Hi Tom,
Thanks,
- Kever
Kever Yang
