[U-Boot] [PATCH 0/2] ARM: UniPhier: some cleanups and bug fix
Masahiro Yamada (2): ARM: UniPhier: consolidate board_postclk_init() function ARM: UniPhier: call pin_init() also in the normal boot
arch/arm/cpu/armv7/uniphier/Kconfig | 4 +++ arch/arm/cpu/armv7/uniphier/Makefile | 1 + .../uniphier/{ph1-ld4 => }/board_postclk_init.c | 9 +++-- arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile | 5 +-- arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile | 4 +-- .../armv7/uniphier/ph1-pro4/board_postclk_init.c | 41 ---------------------- arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile | 5 +-- .../armv7/uniphier/ph1-sld8/board_postclk_init.c | 1 - include/configs/uniphier-common.h | 4 +-- 9 files changed, 21 insertions(+), 53 deletions(-) rename arch/arm/cpu/armv7/uniphier/{ph1-ld4 => }/board_postclk_init.c (86%) delete mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/board_postclk_init.c delete mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/board_postclk_init.c
This commit merges arch/arm/cpu/armv7/uniphier/ph1-*/board_postclk_init.c to arch/arm/cpu/armv7/uniphier/board_postclk_init.c
Because PH1-Pro4 does not have the BCU block, add __weak to bcu_init().
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
arch/arm/cpu/armv7/uniphier/Makefile | 1 + .../uniphier/{ph1-ld4 => }/board_postclk_init.c | 6 ++-- arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile | 4 +-- arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile | 4 +-- .../armv7/uniphier/ph1-pro4/board_postclk_init.c | 41 ---------------------- arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile | 4 +-- .../armv7/uniphier/ph1-sld8/board_postclk_init.c | 1 - 7 files changed, 11 insertions(+), 50 deletions(-) rename arch/arm/cpu/armv7/uniphier/{ph1-ld4 => }/board_postclk_init.c (90%) delete mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/board_postclk_init.c delete mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/board_postclk_init.c
diff --git a/arch/arm/cpu/armv7/uniphier/Makefile b/arch/arm/cpu/armv7/uniphier/Makefile index dd57469..0f64d25 100644 --- a/arch/arm/cpu/armv7/uniphier/Makefile +++ b/arch/arm/cpu/armv7/uniphier/Makefile @@ -8,6 +8,7 @@ obj-$(CONFIG_SPL_BUILD) += spl.o obj-y += timer.o obj-y += reset.o obj-y += cache_uniphier.o +obj-$(CONFIG_BOARD_POSTCLK_INIT) += board_postclk_init.o obj-y += dram_init.o obj-$(CONFIG_DISPLAY_CPUINFO) += cpu_info.o obj-$(CONFIG_BOARD_LATE_INIT) += board_late_init.o diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/board_postclk_init.c b/arch/arm/cpu/armv7/uniphier/board_postclk_init.c similarity index 90% rename from arch/arm/cpu/armv7/uniphier/ph1-ld4/board_postclk_init.c rename to arch/arm/cpu/armv7/uniphier/board_postclk_init.c index 5bb8179..3db336f 100644 --- a/arch/arm/cpu/armv7/uniphier/ph1-ld4/board_postclk_init.c +++ b/arch/arm/cpu/armv7/uniphier/board_postclk_init.c @@ -5,11 +5,13 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#include <common.h> +#include <linux/compiler.h> #include <asm/arch/led.h> #include <asm/arch/board.h>
-void bcu_init(void); +void __weak bcu_init(void) +{ +}; void sbc_init(void); void sg_init(void); void pll_init(void); diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile b/arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile index 1df0219..e9e9b32 100644 --- a/arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile @@ -6,6 +6,6 @@ obj-$(CONFIG_DISPLAY_BOARDINFO) += board_info.o obj-y += platdevice.o obj-y += boot-mode.o obj-$(CONFIG_DEBUG_LL) += lowlevel_debug.o -obj-$(CONFIG_BOARD_POSTCLK_INIT) += board_postclk_init.o bcu_init.o \ - sbc_init.o sg_init.o pll_init.o clkrst_init.o pinctrl.o +obj-$(CONFIG_BOARD_POSTCLK_INIT) += bcu_init.o sbc_init.o sg_init.o \ + pll_init.o clkrst_init.o pinctrl.o obj-$(CONFIG_DRAM_INIT) += pll_spectrum.o umc_init.o diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile b/arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile index 144e6fc..272fecc 100644 --- a/arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile @@ -6,6 +6,6 @@ obj-$(CONFIG_DISPLAY_BOARDINFO) += board_info.o obj-y += platdevice.o obj-y += boot-mode.o obj-$(CONFIG_DEBUG_LL) += lowlevel_debug.o -obj-$(CONFIG_BOARD_POSTCLK_INIT) += board_postclk_init.o sbc_init.o \ - sg_init.o pll_init.o clkrst_init.o pinctrl.o +obj-$(CONFIG_BOARD_POSTCLK_INIT) += sbc_init.o sg_init.o \ + pll_init.o clkrst_init.o pinctrl.o obj-$(CONFIG_DRAM_INIT) += pll_spectrum.o umc_init.o diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/board_postclk_init.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/board_postclk_init.c deleted file mode 100644 index 9a53743..0000000 --- a/arch/arm/cpu/armv7/uniphier/ph1-pro4/board_postclk_init.c +++ /dev/null @@ -1,41 +0,0 @@ -/* - * Copyright (C) 2012-2014 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <asm/arch/led.h> -#include <asm/arch/board.h> - -void sbc_init(void); -void sg_init(void); -void pll_init(void); -void pin_init(void); -void clkrst_init(void); - -int board_postclk_init(void) -{ - sbc_init(); - - sg_init(); - - uniphier_board_reset(); - - pll_init(); - - uniphier_board_init(); - - led_write(B, 1, , ); - - clkrst_init(); - - led_write(B, 2, , ); - - pin_init(); - - led_write(B, 3, , ); - - return 0; -} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile b/arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile index 1df0219..e9e9b32 100644 --- a/arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile @@ -6,6 +6,6 @@ obj-$(CONFIG_DISPLAY_BOARDINFO) += board_info.o obj-y += platdevice.o obj-y += boot-mode.o obj-$(CONFIG_DEBUG_LL) += lowlevel_debug.o -obj-$(CONFIG_BOARD_POSTCLK_INIT) += board_postclk_init.o bcu_init.o \ - sbc_init.o sg_init.o pll_init.o clkrst_init.o pinctrl.o +obj-$(CONFIG_BOARD_POSTCLK_INIT) += bcu_init.o sbc_init.o sg_init.o \ + pll_init.o clkrst_init.o pinctrl.o obj-$(CONFIG_DRAM_INIT) += pll_spectrum.o umc_init.o diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/board_postclk_init.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/board_postclk_init.c deleted file mode 100644 index 287b33c..0000000 --- a/arch/arm/cpu/armv7/uniphier/ph1-sld8/board_postclk_init.c +++ /dev/null @@ -1 +0,0 @@ -#include "../ph1-ld4/board_postclk_init.c"
CONFIG_UNIPHIER_SERIAL has been moved to Kconfig and it is defined in ./.config but not in spl/.config, so pin_init() should be called from the normal image so that UART works correctly.
arch/arm/cpu/armv7/uniphier/Kconfig | 4 ++++ arch/arm/cpu/armv7/uniphier/board_postclk_init.c | 3 ++- arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile | 5 +++-- arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile | 4 ++-- arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile | 5 +++-- include/configs/uniphier-common.h | 4 ++-- 6 files changed, 16 insertions(+), 9 deletions(-)
diff --git a/arch/arm/cpu/armv7/uniphier/Kconfig b/arch/arm/cpu/armv7/uniphier/Kconfig index 011c6d9..36b7f11 100644 --- a/arch/arm/cpu/armv7/uniphier/Kconfig +++ b/arch/arm/cpu/armv7/uniphier/Kconfig @@ -32,6 +32,10 @@ config CMD_PINMON The boot mode pins are latched when the system reset is deasserted and determine which device the system should load a boot image from.
+config SOC_INIT + bool + default SPL_BUILD + config DRAM_INIT bool default SPL_BUILD diff --git a/arch/arm/cpu/armv7/uniphier/board_postclk_init.c b/arch/arm/cpu/armv7/uniphier/board_postclk_init.c index 3db336f..89e44bb 100644 --- a/arch/arm/cpu/armv7/uniphier/board_postclk_init.c +++ b/arch/arm/cpu/armv7/uniphier/board_postclk_init.c @@ -20,6 +20,7 @@ void clkrst_init(void);
int board_postclk_init(void) { +#ifdef CONFIG_SOC_INIT bcu_init();
sbc_init(); @@ -37,7 +38,7 @@ int board_postclk_init(void) clkrst_init();
led_write(B, 2, , ); - +#endif pin_init();
led_write(B, 3, , ); diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile b/arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile index e9e9b32..f0c66c6 100644 --- a/arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile @@ -6,6 +6,7 @@ obj-$(CONFIG_DISPLAY_BOARDINFO) += board_info.o obj-y += platdevice.o obj-y += boot-mode.o obj-$(CONFIG_DEBUG_LL) += lowlevel_debug.o -obj-$(CONFIG_BOARD_POSTCLK_INIT) += bcu_init.o sbc_init.o sg_init.o \ - pll_init.o clkrst_init.o pinctrl.o +obj-$(CONFIG_SOC_INIT) += bcu_init.o sbc_init.o sg_init.o pll_init.o \ + clkrst_init.o +obj-$(CONFIG_BOARD_POSTCLK_INIT) += pinctrl.o obj-$(CONFIG_DRAM_INIT) += pll_spectrum.o umc_init.o diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile b/arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile index 272fecc..0e8f4c5 100644 --- a/arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile @@ -6,6 +6,6 @@ obj-$(CONFIG_DISPLAY_BOARDINFO) += board_info.o obj-y += platdevice.o obj-y += boot-mode.o obj-$(CONFIG_DEBUG_LL) += lowlevel_debug.o -obj-$(CONFIG_BOARD_POSTCLK_INIT) += sbc_init.o sg_init.o \ - pll_init.o clkrst_init.o pinctrl.o +obj-$(CONFIG_SOC_INIT) += sbc_init.o sg_init.o pll_init.o clkrst_init.o +obj-$(CONFIG_BOARD_POSTCLK_INIT) += pinctrl.o obj-$(CONFIG_DRAM_INIT) += pll_spectrum.o umc_init.o diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile b/arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile index e9e9b32..f0c66c6 100644 --- a/arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile @@ -6,6 +6,7 @@ obj-$(CONFIG_DISPLAY_BOARDINFO) += board_info.o obj-y += platdevice.o obj-y += boot-mode.o obj-$(CONFIG_DEBUG_LL) += lowlevel_debug.o -obj-$(CONFIG_BOARD_POSTCLK_INIT) += bcu_init.o sbc_init.o sg_init.o \ - pll_init.o clkrst_init.o pinctrl.o +obj-$(CONFIG_SOC_INIT) += bcu_init.o sbc_init.o sg_init.o pll_init.o \ + clkrst_init.o +obj-$(CONFIG_BOARD_POSTCLK_INIT) += pinctrl.o obj-$(CONFIG_DRAM_INIT) += pll_spectrum.o umc_init.o diff --git a/include/configs/uniphier-common.h b/include/configs/uniphier-common.h index 45becc1..7c4dba0 100644 --- a/include/configs/uniphier-common.h +++ b/include/configs/uniphier-common.h @@ -248,9 +248,9 @@ are defined. Select only one of them."
#define CONFIG_SYS_TEXT_BASE 0x84000000
-#if defined(CONFIG_SPL_BUILD) #define CONFIG_BOARD_POSTCLK_INIT -#else + +#ifndef CONFIG_SPL_BUILD #define CONFIG_SKIP_LOWLEVEL_INIT #endif
2014-11-11 22:18 GMT+09:00 Masahiro Yamada yamada.m@jp.panasonic.com:
Series, applied to u-boot-uniphier/master.
Masahiro YAMADA
Masahiro Yamada
