[U-Boot] [PATCH 07/07] Coldfire: mcfmii: Allow non-autonegotiating PHYs to use mii command.
Modified mii_init to support boards with PHYs that are not set to autonegotiate, but still want to use u-boot's mii commands to probe the smi bus. Such PHYs will not set the Autonegotiate-done bit.
--- drivers/net/mcfmii.c | 27 +++++++++++++++++++-------- 1 files changed, 19 insertions(+), 8 deletions(-)
diff --git a/drivers/net/mcfmii.c b/drivers/net/mcfmii.c index 2b733c6..4f1c0a0 100644 --- a/drivers/net/mcfmii.c +++ b/drivers/net/mcfmii.c @@ -226,7 +226,8 @@ void __mii_init(void) volatile FEC_T *fecp; struct eth_device *dev; int miispd = 0, i = 0; - u16 autoneg = 0; + u16 status = 0; + u16 linkgood = 0;
/* retrieve from register structure */ dev = eth_get_dev(); @@ -250,22 +251,32 @@ void __mii_init(void)
info->phy_addr = mii_discover_phy(dev);
-#define AUTONEGLINK (PHY_BMSR_AUTN_COMP | PHY_BMSR_LS) while (i < MCFFEC_TOUT_LOOP) { - autoneg = 0; - miiphy_read(dev->name, info->phy_addr, PHY_BMSR, &autoneg); + status = 0; i++; - - if ((autoneg & AUTONEGLINK) == AUTONEGLINK) + /* Read PHY control register */ + miiphy_read(dev->name, info->phy_addr, PHY_BMCR, &status); + + /* If phy set to autonegotiate, wait for autonegotiation done, + * if phy is not autonegotiating, just wait for link up. + */ + if ((status & PHY_BMCR_AUTON) == PHY_BMCR_AUTON) { + linkgood = (PHY_BMSR_AUTN_COMP | PHY_BMSR_LS); + } else { + linkgood = PHY_BMSR_LS; + } + /* Read PHY status register */ + miiphy_read(dev->name, info->phy_addr, PHY_BMSR, &status); + if ((status & linkgood) == linkgood) break;
udelay(500); } if (i >= MCFFEC_TOUT_LOOP) { - printf("Auto Negotiation not complete\n"); + printf("Link UP timeout\n"); }
- /* adapt to the half/full speed settings */ + /* adapt to the duplex and speed settings of the phy */ info->dup_spd = miiphy_duplex(dev->name, info->phy_addr) << 16; info->dup_spd |= miiphy_speed(dev->name, info->phy_addr); }
Signed-off-by: Richard Retanubun RichardRetanubun@RuggedCom.com ---
Rebased on:
commit 9d8811c5bd2b7dd6307742cf22fbdb7953b6f816 Merge: 716ebf4... bd99ec1... Author: Wolfgang Denk wd@denx.de Date: Tue Feb 3 23:16:15 2009 +0100
Richard Retanubun
