[PATCH 1/1] doc: qemu: debug UART settings for QEMU ARM virt
Provide the settings for the debug UART on the QEMU ARM virt board.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- doc/board/emulation/qemu-arm.rst | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/doc/board/emulation/qemu-arm.rst b/doc/board/emulation/qemu-arm.rst index ca751d4af4..8d7fda10f1 100644 --- a/doc/board/emulation/qemu-arm.rst +++ b/doc/board/emulation/qemu-arm.rst @@ -80,3 +80,13 @@ can be enabled with the following command line parameters: -drive if=none,file=disk.img,id=mydisk -device nvme,drive=mydisk,serial=foo
These have been tested in QEMU 2.9.0 but should work in at least 2.5.0 as well. + +Debug UART +---------- + +The debug UART on the ARM virt board uses these settings:: + + CONFIG_DEBUG_UART=y + CONFIG_DEBUG_UART_PL010=y + CONFIG_DEBUG_UART_BASE=0x9000000 + CONFIG_DEBUG_UART_CLOCK=0 -- 2.28.0
