[U-Boot] [Patch v2, batch 3 01/17] common: Update cmd_bdinfo for PPC
Add board detail function to print more individual board information.
Signed-off-by: York Sun yorksun@freescale.com CC: Wolfgang Denk wd@denx.de CC: Tom Rini trini@ti.com
--- common/cmd_bdinfo.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/common/cmd_bdinfo.c b/common/cmd_bdinfo.c index 85279d5..3bf8cf2 100644 --- a/common/cmd_bdinfo.c +++ b/common/cmd_bdinfo.c @@ -84,6 +84,12 @@ static void print_mhz(const char *name, unsigned long hz) }
#if defined(CONFIG_PPC) +static void __board_detail(void) +{ + /* Please define boot_detail() for your platform */ +} + +void board_detail(void) __attribute__((weak, alias("__board_detail")));
int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { @@ -169,6 +175,7 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) printf("IP addr = %s\n", getenv("ipaddr")); printf("baudrate = %6u bps\n", bd->bi_baudrate); print_num("relocaddr", gd->relocaddr); + board_detail(); return 0; }
Print more detail information including core voltage, RCW source, switch settings, etc. with bdinfo command.
Signed-off-by: York Sun yorksun@freescale.com CC: Wolfgang Denk wd@denx.de CC: Tom Rini trini@ti.com --- board/freescale/t4qds/t4qds.c | 100 +++++++++++++++++++++++++++++++++++++++++ 1 file changed, 100 insertions(+)
diff --git a/board/freescale/t4qds/t4qds.c b/board/freescale/t4qds/t4qds.c index a84218c..c1bb8bf 100644 --- a/board/freescale/t4qds/t4qds.c +++ b/board/freescale/t4qds/t4qds.c @@ -643,6 +643,106 @@ void ft_board_setup(void *blob, bd_t *bd) }
/* + * This function is called by bdinfo to print detail board information. + * As an exmaple for future board, we organize the messages into + * several sections. If applicable, the message is in the format of + * <name> = <value> + * It should aligned with normal output of bdinfo command. + * + * Voltage: Core, DDR and another configurable voltages + * Clock : Critical clocks which are not printed already + * RCW : RCW source if not printed already + * Misc : Other important information not in above catagories + */ +void board_detail(void) +{ + int i; + u8 brdcfg[16], dutcfg[16], rst_ctl; + int vdd, rcwsrc; + static const char * const clk[] = {"66.67", "100", "125", "133.33"}; + + for (i = 0; i < 16; i++) { + brdcfg[i] = qixis_read(offsetof(struct qixis, brdcfg[0]) + i); + dutcfg[i] = qixis_read(offsetof(struct qixis, dutcfg[0]) + i); + } + + /* Voltage secion */ + if (!select_i2c_ch_pca9547(I2C_MUX_CH_VOL_MONITOR)) { + vdd = read_voltage(); + if (vdd > 0) + printf("Core voltage= %d mV\n", vdd); + select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT); + } + + printf("XVDD = 1.%d V\n", ((brdcfg[8] & 0xf) - 4) * 5 + 25); + + /* clock section */ + printf("SYSCLK = %s MHz\nDDRCLK = %s MHz\n", + clk[(brdcfg[11] >> 2) & 0x3], clk[brdcfg[11] & 3]); + + /* RCW section */ + rcwsrc = (dutcfg[0] << 1) + (dutcfg[1] & 1); + puts("RCW source = "); + switch (rcwsrc) { + case 0x017: + case 0x01f: + puts("8-bit NOR\n"); + break; + case 0x027: + case 0x02F: + puts("16-bit NOR\n"); + break; + case 0x040: + puts("SDHC/eMMC\n"); + break; + case 0x044: + puts("SPI 16-bit addressing\n"); + break; + case 0x045: + puts("SPI 24-bit addressing\n"); + break; + case 0x048: + puts("I2C normal addressing\n"); + break; + case 0x049: + puts("I2C extended addressing\n"); + break; + case 0x108: + case 0x109: + case 0x10a: + case 0x10b: + puts("8-bit NAND, 2KB\n"); + break; + default: + if ((rcwsrc >= 0x080) && (rcwsrc <= 0x09f)) + puts("Hard-coded RCW\n"); + else if ((rcwsrc >= 0x110) && (rcwsrc <= 0x11f)) + puts("8-bit NAND, 4KB\n"); + else + puts("unknown\n"); + break; + } + + /* Misc section */ + rst_ctl = QIXIS_READ(rst_ctl); + puts("HRESET_REQ = "); + switch (rst_ctl & 0x30) { + case 0x00: + puts("Ignored\n"); + break; + case 0x10: + puts("Assert HRESET\n"); + break; + case 0x30: + puts("Reset system\n"); + break; + default: + puts("N/A\n"); + break; + } +} + +/* * Reverse engineering switch settings. * Some bits cannot be figured out. They will be displayed as * underscore in binary format. mask[] has those bits.
Calculate reserved fields according to IFC bank count
1. Move csor_ext register behind csor register and fix res offset 2. move ifc bank count to config_mpc85xx.h to support 8 bank count
There's no IFC controller instead of eLBC controller on some platforms, such as MPC8536, P2041, P3041, P4080 etc, so there's no macro definition for the number of IFC chip select(CONFIG_SYS_FSL_IFC_BANK_COUNT) which is used in the IFC controller header file fsl_ifc.h on these platforms.
Signed-off-by: Mingkai Hu Mingkai.hu@freescale.com --- arch/powerpc/cpu/mpc85xx/cpu.c | 2 +- arch/powerpc/cpu/mpc8xxx/fsl_ifc.c | 58 ++++++++++++++++++++++++++++- arch/powerpc/include/asm/config_mpc85xx.h | 7 ++++ arch/powerpc/include/asm/fsl_ifc.h | 42 +++++++++++++++------ 4 files changed, 96 insertions(+), 13 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu.c b/arch/powerpc/cpu/mpc85xx/cpu.c index df2ab6d..379a7df 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu.c +++ b/arch/powerpc/cpu/mpc85xx/cpu.c @@ -34,8 +34,8 @@ #include <asm/io.h> #include <asm/mmu.h> #include <asm/fsl_ifc.h> -#include <asm/fsl_law.h> #include <asm/fsl_lbc.h> +#include <asm/fsl_law.h> #include <post.h> #include <asm/processor.h> #include <asm/fsl_ddr_sdram.h> diff --git a/arch/powerpc/cpu/mpc8xxx/fsl_ifc.c b/arch/powerpc/cpu/mpc8xxx/fsl_ifc.c index 56b319f..f0da355 100644 --- a/arch/powerpc/cpu/mpc8xxx/fsl_ifc.c +++ b/arch/powerpc/cpu/mpc8xxx/fsl_ifc.c @@ -26,7 +26,7 @@ void print_ifc_regs(void) int i, j;
printf("IFC Controller Registers\n"); - for (i = 0; i < FSL_IFC_BANK_COUNT; i++) { + for (i = 0; i < CONFIG_SYS_FSL_IFC_BANK_COUNT; i++) { printf("CSPR%d:0x%08X\tAMASK%d:0x%08X\tCSOR%d:0x%08X\n", i, get_ifc_cspr(i), i, get_ifc_amask(i), i, get_ifc_csor(i)); @@ -94,4 +94,60 @@ void init_early_memctl_regs(void) set_ifc_amask(IFC_CS3, CONFIG_SYS_AMASK3); set_ifc_csor(IFC_CS3, CONFIG_SYS_CSOR3); #endif + +#ifdef CONFIG_SYS_CSPR4_EXT + set_ifc_cspr_ext(IFC_CS4, CONFIG_SYS_CSPR4_EXT); +#endif +#if defined(CONFIG_SYS_CSPR4) && defined(CONFIG_SYS_CSOR4) + set_ifc_ftim(IFC_CS4, IFC_FTIM0, CONFIG_SYS_CS4_FTIM0); + set_ifc_ftim(IFC_CS4, IFC_FTIM1, CONFIG_SYS_CS4_FTIM1); + set_ifc_ftim(IFC_CS4, IFC_FTIM2, CONFIG_SYS_CS4_FTIM2); + set_ifc_ftim(IFC_CS4, IFC_FTIM3, CONFIG_SYS_CS4_FTIM3); + + set_ifc_cspr(IFC_CS4, CONFIG_SYS_CSPR4); + set_ifc_amask(IFC_CS4, CONFIG_SYS_AMASK4); + set_ifc_csor(IFC_CS4, CONFIG_SYS_CSOR4); +#endif + +#ifdef CONFIG_SYS_CSPR5_EXT + set_ifc_cspr_ext(IFC_CS5, CONFIG_SYS_CSPR5_EXT); +#endif +#if defined(CONFIG_SYS_CSPR5) && defined(CONFIG_SYS_CSOR5) + set_ifc_ftim(IFC_CS5, IFC_FTIM0, CONFIG_SYS_CS5_FTIM0); + set_ifc_ftim(IFC_CS5, IFC_FTIM1, CONFIG_SYS_CS5_FTIM1); + set_ifc_ftim(IFC_CS5, IFC_FTIM2, CONFIG_SYS_CS5_FTIM2); + set_ifc_ftim(IFC_CS5, IFC_FTIM3, CONFIG_SYS_CS5_FTIM3); + + set_ifc_cspr(IFC_CS5, CONFIG_SYS_CSPR5); + set_ifc_amask(IFC_CS5, CONFIG_SYS_AMASK5); + set_ifc_csor(IFC_CS5, CONFIG_SYS_CSOR5); +#endif + +#ifdef CONFIG_SYS_CSPR6_EXT + set_ifc_cspr_ext(IFC_CS6, CONFIG_SYS_CSPR6_EXT); +#endif +#if defined(CONFIG_SYS_CSPR6) && defined(CONFIG_SYS_CSOR6) + set_ifc_ftim(IFC_CS6, IFC_FTIM0, CONFIG_SYS_CS6_FTIM0); + set_ifc_ftim(IFC_CS6, IFC_FTIM1, CONFIG_SYS_CS6_FTIM1); + set_ifc_ftim(IFC_CS6, IFC_FTIM2, CONFIG_SYS_CS6_FTIM2); + set_ifc_ftim(IFC_CS6, IFC_FTIM3, CONFIG_SYS_CS6_FTIM3); + + set_ifc_cspr(IFC_CS6, CONFIG_SYS_CSPR6); + set_ifc_amask(IFC_CS6, CONFIG_SYS_AMASK6); + set_ifc_csor(IFC_CS6, CONFIG_SYS_CSOR6); +#endif + +#ifdef CONFIG_SYS_CSPR7_EXT + set_ifc_cspr_ext(IFC_CS7, CONFIG_SYS_CSPR7_EXT); +#endif +#if defined(CONFIG_SYS_CSPR7) && defined(CONFIG_SYS_CSOR7) + set_ifc_ftim(IFC_CS7, IFC_FTIM0, CONFIG_SYS_CS7_FTIM0); + set_ifc_ftim(IFC_CS7, IFC_FTIM1, CONFIG_SYS_CS7_FTIM1); + set_ifc_ftim(IFC_CS7, IFC_FTIM2, CONFIG_SYS_CS7_FTIM2); + set_ifc_ftim(IFC_CS7, IFC_FTIM3, CONFIG_SYS_CS7_FTIM3); + + set_ifc_cspr(IFC_CS7, CONFIG_SYS_CSPR7); + set_ifc_amask(IFC_CS7, CONFIG_SYS_AMASK7); + set_ifc_csor(IFC_CS7, CONFIG_SYS_CSOR7); +#endif } diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 5def364..7a1cdc7 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -139,6 +139,7 @@ #define CONFIG_SYS_FSL_SEC_COMPAT 4 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 #define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_SYS_FSL_IFC_BANK_COUNT 4 #define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.2" #define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY @@ -491,6 +492,7 @@ #define CONFIG_TSECV2 #define CONFIG_SYS_FSL_SEC_COMPAT 4 #define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_SYS_FSL_IFC_BANK_COUNT 3 #define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_NAND_FSL_IFC #define CONFIG_SYS_FSL_ERRATUM_IFC_A003399 @@ -504,6 +506,7 @@ #define CONFIG_TSECV2 #define CONFIG_SYS_FSL_SEC_COMPAT 4 #define CONFIG_NUM_DDR_CONTROLLERS 2 +#define CONFIG_SYS_FSL_IFC_BANK_COUNT 3 #define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_NAND_FSL_IFC #define CONFIG_SYS_FSL_ERRATUM_IFC_A003399 @@ -529,6 +532,7 @@ #define CONFIG_SYS_NUM_FM2_10GEC 2 #define CONFIG_NUM_DDR_CONTROLLERS 3 #define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_4_7 +#define CONFIG_SYS_FSL_IFC_BANK_COUNT 8 #define CONFIG_SYS_FMAN_V3 #define CONFIG_SYS_FM_MURAM_SIZE 0x60000 #define CONFIG_SYS_FSL_TBCLK_DIV 16 @@ -562,6 +566,7 @@ #define CONFIG_SYS_NUM_FM2_10GEC 1 #define CONFIG_NUM_DDR_CONTROLLERS 2 #define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_4_7 +#define CONFIG_SYS_FSL_IFC_BANK_COUNT 8 #define CONFIG_SYS_FMAN_V3 #define CONFIG_SYS_FM_MURAM_SIZE 0x60000 #define CONFIG_SYS_FSL_TBCLK_DIV 16 @@ -590,6 +595,7 @@ #define CONFIG_SYS_NUM_FM1_DTSEC 4 #define CONFIG_NUM_DDR_CONTROLLERS 1 #define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_4_7 +#define CONFIG_SYS_FSL_IFC_BANK_COUNT 4 #define CONFIG_SYS_FMAN_V3 #define CONFIG_SYS_FM_MURAM_SIZE 0x60000 #define CONFIG_SYS_FSL_TBCLK_DIV 16 @@ -612,6 +618,7 @@ #define CONFIG_SYS_NUM_FM1_10GEC 2 #define CONFIG_NUM_DDR_CONTROLLERS 2 #define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_4_7 +#define CONFIG_SYS_FSL_IFC_BANK_COUNT 4 #define CONFIG_SYS_FMAN_V3 #define CONFIG_SYS_FM_MURAM_SIZE 0x60000 #define CONFIG_SYS_FSL_TBCLK_DIV 16 diff --git a/arch/powerpc/include/asm/fsl_ifc.h b/arch/powerpc/include/asm/fsl_ifc.h index ba41b73..debcb6b 100644 --- a/arch/powerpc/include/asm/fsl_ifc.h +++ b/arch/powerpc/include/asm/fsl_ifc.h @@ -21,6 +21,7 @@ #ifndef __ASM_PPC_FSL_IFC_H #define __ASM_PPC_FSL_IFC_H
+#ifdef CONFIG_FSL_IFC #include <config.h> #include <common.h>
@@ -798,13 +799,15 @@ extern void init_early_memctl_regs(void); #define set_ifc_ftim(i, j, v) \ (out_be32(&(IFC_BASE_ADDR)->ftim_cs[i].ftim[j], v))
-#define FSL_IFC_BANK_COUNT 4 - enum ifc_chip_sel { IFC_CS0, IFC_CS1, IFC_CS2, IFC_CS3, + IFC_CS4, + IFC_CS5, + IFC_CS6, + IFC_CS7, };
enum ifc_ftims { @@ -907,6 +910,22 @@ struct fsl_ifc_gpcm { u32 res4[0x1F3]; };
+#ifdef CONFIG_SYS_FSL_IFC_BANK_COUNT +#if (CONFIG_SYS_FSL_IFC_BANK_COUNT <= 8) +#define CONFIG_SYS_FSL_IFC_CSPR_RES \ + (0x25 - CONFIG_SYS_FSL_IFC_BANK_COUNT * 3) +#define CONFIG_SYS_FSL_IFC_AMASK_RES \ + (0x24 - CONFIG_SYS_FSL_IFC_BANK_COUNT * 3) +#define CONFIG_SYS_FSL_IFC_CSOR_RES \ + (0x24 - CONFIG_SYS_FSL_IFC_BANK_COUNT * 3) +#define CONFIG_SYS_FSL_IFC_FTIM_RES \ + (0x90 - CONFIG_SYS_FSL_IFC_BANK_COUNT * 0xc) +#else +#error IFC BANK count not vaild +#endif +#else +#error IFC BANK count not defined +#endif
/* * IFC Controller Registers @@ -918,24 +937,24 @@ struct fsl_ifc { u32 cspr_ext; u32 cspr; u32 res2; - } cspr_cs[FSL_IFC_BANK_COUNT]; - u32 res3[0x19]; + } cspr_cs[CONFIG_SYS_FSL_IFC_BANK_COUNT]; + u32 res3[CONFIG_SYS_FSL_IFC_CSPR_RES]; struct { u32 amask; u32 res4[0x2]; - } amask_cs[FSL_IFC_BANK_COUNT]; - u32 res5[0x17]; + } amask_cs[CONFIG_SYS_FSL_IFC_BANK_COUNT]; + u32 res5[CONFIG_SYS_FSL_IFC_AMASK_RES]; struct { - u32 csor_ext; u32 csor; + u32 csor_ext; u32 res6; - } csor_cs[FSL_IFC_BANK_COUNT]; - u32 res7[0x19]; + } csor_cs[CONFIG_SYS_FSL_IFC_BANK_COUNT]; + u32 res7[CONFIG_SYS_FSL_IFC_CSOR_RES]; struct { u32 ftim[4]; u32 res8[0x8]; - } ftim_cs[FSL_IFC_BANK_COUNT]; - u32 res9[0x60]; + } ftim_cs[CONFIG_SYS_FSL_IFC_BANK_COUNT]; + u32 res9[CONFIG_SYS_FSL_IFC_FTIM_RES]; u32 rb_stat; u32 res10[0x2]; u32 ifc_gcr; @@ -961,6 +980,7 @@ struct fsl_ifc { #undef CSPR_MSEL_NOR #define CSPR_MSEL_NOR CSPR_MSEL_GPCM #endif +#endif /* CONFIG_FSL_IFC */
#endif /* __ASSEMBLY__ */ #endif /* __ASM_PPC_FSL_IFC_H */
Even B4860 has chassis generation 2, but its PCIe registers are at the same location as other corenet SoCs.
Signed-off-by: Ed Swarthout ed.swarthout@freescale.com --- arch/powerpc/include/asm/immap_85xx.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 0cada07..e0e4e1d 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -2954,7 +2954,7 @@ struct ccsr_pman { #define CONFIG_SYS_MPC85xx_IFC_OFFSET 0x124000 #define CONFIG_SYS_MPC85xx_GPIO_OFFSET 0x130000 #define CONFIG_SYS_FSL_CORENET_RMAN_OFFSET 0x1e0000 -#ifdef CONFIG_SYS_FSL_QORIQ_CHASSIS2 +#if defined(CONFIG_SYS_FSL_QORIQ_CHASSIS2) && !defined(CONFIG_PPC_B4860) #define CONFIG_SYS_MPC85xx_PCIE1_OFFSET 0x240000 #define CONFIG_SYS_MPC85xx_PCIE2_OFFSET 0x250000 #define CONFIG_SYS_MPC85xx_PCIE3_OFFSET 0x260000
For T4/B4, the clockgen node compatible string is updated to version 2. Add clock-frequency setting for this new version.
Signed-off-by: Tang Yuantian Yuantian.Tang@freescale.com --- arch/powerpc/cpu/mpc85xx/fdt.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/powerpc/cpu/mpc85xx/fdt.c b/arch/powerpc/cpu/mpc85xx/fdt.c index 24eb978..c7ab146 100644 --- a/arch/powerpc/cpu/mpc85xx/fdt.c +++ b/arch/powerpc/cpu/mpc85xx/fdt.c @@ -663,6 +663,8 @@ void ft_cpu_setup(void *blob, bd_t *bd) #ifdef CONFIG_FSL_CORENET do_fixup_by_compat_u32(blob, "fsl,qoriq-clockgen-1.0", "clock-frequency", CONFIG_SYS_CLK_FREQ, 1); + do_fixup_by_compat_u32(blob, "fsl,qoriq-clockgen-2", + "clock-frequency", CONFIG_SYS_CLK_FREQ, 1); #endif
fdt_fixup_memory(blob, (u64)bd->bi_memstart, (u64)bd->bi_memsize);
1, Implemented board_ft_fman_fixup_port() to fix port for kernel. 2, Implemented fdt_fixup_board_enet() to fix node status of different slots and interfaces. 3, Adding detection of slot present for XGMII interface. 4, There is no PHY for XFI, so removed related phy address settings.
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com --- arch/powerpc/include/asm/fsl_serdes.h | 1 + board/freescale/t4qds/eth.c | 104 ++++++++++++++++++++++++++++----- include/configs/t4qds.h | 4 -- 3 files changed, 91 insertions(+), 18 deletions(-)
diff --git a/arch/powerpc/include/asm/fsl_serdes.h b/arch/powerpc/include/asm/fsl_serdes.h index 6cd7379..c462455 100644 --- a/arch/powerpc/include/asm/fsl_serdes.h +++ b/arch/powerpc/include/asm/fsl_serdes.h @@ -91,6 +91,7 @@ enum srds {
int is_serdes_configured(enum srds_prtcl device); void fsl_serdes_init(void); +enum srds_prtcl serdes_get_prtcl(int serdes, int cfg, int lane);
#ifdef CONFIG_FSL_CORENET #ifdef CONFIG_SYS_FSL_QORIQ_CHASSIS2 diff --git a/board/freescale/t4qds/eth.c b/board/freescale/t4qds/eth.c index a49c7d4..8d2c33f 100644 --- a/board/freescale/t4qds/eth.c +++ b/board/freescale/t4qds/eth.c @@ -52,7 +52,7 @@ #define EMI1_SLOT4 4 #define EMI1_SLOT5 5 #define EMI1_SLOT7 7 -#define EMI2 8 /* tmp, FIXME */ +#define EMI2 8 /* Slot6 and Slot8 do not have EMI connections */
static int mdio_mux[NUM_FM_PORTS]; @@ -180,21 +180,86 @@ static int t4240qds_mdio_init(char *realbusname, u8 muxval) void board_ft_fman_fixup_port(void *blob, char * prop, phys_addr_t pa, enum fm_port port, int offset) { - if (mdio_mux[port] == EMI1_RGMII) - fdt_set_phy_handle(blob, prop, pa, "phy_rgmii"); - - /* TODO: will do with dts */ + if (fm_info_get_enet_if(port) == PHY_INTERFACE_MODE_SGMII) { + switch (port) { + case FM1_DTSEC9: + fdt_set_phy_handle(blob, prop, pa, "phy_sgmii4"); + break; + case FM1_DTSEC10: + fdt_set_phy_handle(blob, prop, pa, "phy_sgmii3"); + break; + case FM2_DTSEC9: + fdt_set_phy_handle(blob, prop, pa, "phy_sgmii12"); + break; + case FM2_DTSEC10: + fdt_set_phy_handle(blob, prop, pa, "phy_sgmii11"); + break; + default: + break; + } + } }
void fdt_fixup_board_enet(void *fdt) { - /* TODO: will do with dts */ + int i; + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 prtcl2 = in_be32(&gur->rcwsr[4]) & FSL_CORENET2_RCWSR4_SRDS2_PRTCL; + + prtcl2 >>= FSL_CORENET2_RCWSR4_SRDS2_PRTCL_SHIFT; + for (i = FM1_DTSEC1; i < NUM_FM_PORTS; i++) { + switch (fm_info_get_enet_if(i)) { + case PHY_INTERFACE_MODE_SGMII: + switch (mdio_mux[i]) { + case EMI1_SLOT1: + fdt_status_okay_by_alias(fdt, "emi1_slot1"); + break; + case EMI1_SLOT2: + fdt_status_okay_by_alias(fdt, "emi1_slot2"); + break; + case EMI1_SLOT3: + fdt_status_okay_by_alias(fdt, "emi1_slot3"); + break; + case EMI1_SLOT4: + fdt_status_okay_by_alias(fdt, "emi1_slot4"); + break; + default: + break; + } + break; + case PHY_INTERFACE_MODE_XGMII: + /* check if it's XFI interface for 10g */ + if ((prtcl2 == 56) || (prtcl2 == 57)) { + fdt_status_okay_by_alias(fdt, "emi2_xfislot3"); + break; + } + switch (i) { + case FM1_10GEC1: + fdt_status_okay_by_alias(fdt, "emi2_xauislot1"); + break; + case FM1_10GEC2: + fdt_status_okay_by_alias(fdt, "emi2_xauislot2"); + break; + case FM2_10GEC1: + fdt_status_okay_by_alias(fdt, "emi2_xauislot3"); + break; + case FM2_10GEC2: + fdt_status_okay_by_alias(fdt, "emi2_xauislot4"); + break; + default: + break; + } + break; + default: + break; + } + } }
int board_eth_init(bd_t *bis) { #if defined(CONFIG_FMAN_ENET) - int i; + int i, idx, lane, slot; struct memac_mdio_info dtsec_mdio_info; struct memac_mdio_info tgec_mdio_info; ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); @@ -293,7 +358,7 @@ int board_eth_init(bd_t *bis) }
for (i = FM1_DTSEC1; i < FM1_DTSEC1 + CONFIG_SYS_NUM_FM1_DTSEC; i++) { - int idx = i - FM1_DTSEC1, lane, slot; + idx = i - FM1_DTSEC1; switch (fm_info_get_enet_if(i)) { case PHY_INTERFACE_MODE_SGMII: lane = serdes_get_first_lane(FSL_SRDS_1, @@ -334,8 +399,16 @@ int board_eth_init(bd_t *bis) }
for (i = FM1_10GEC1; i < FM1_10GEC1 + CONFIG_SYS_NUM_FM1_10GEC; i++) { + idx = i - FM1_10GEC1; switch (fm_info_get_enet_if(i)) { case PHY_INTERFACE_MODE_XGMII: + lane = serdes_get_first_lane(FSL_SRDS_1, + XAUI_FM1_MAC9 + idx); + if (lane < 0) + break; + slot = lane_to_slot_fsm1[lane]; + if (QIXIS_READ(present2) & (1 << (slot - 1))) + fm_disable_port(i); mdio_mux[i] = EMI2; fm_info_set_mdio(i, mii_dev_for_muxval(mdio_mux[i])); break; @@ -344,7 +417,6 @@ int board_eth_init(bd_t *bis) } }
- #if (CONFIG_SYS_NUM_FMAN == 2) switch (srds_prtcl_s2) { case 1: @@ -418,10 +490,6 @@ int board_eth_init(bd_t *bis) case 56: case 57: /* XFI in Slot3, SGMII in Slot4 */ - fm_info_set_phy_address(FM1_10GEC1, XFI_CARD_PORT1_PHY_ADDR); - fm_info_set_phy_address(FM1_10GEC2, XFI_CARD_PORT2_PHY_ADDR); - fm_info_set_phy_address(FM2_10GEC2, XFI_CARD_PORT3_PHY_ADDR); - fm_info_set_phy_address(FM2_10GEC1, XFI_CARD_PORT4_PHY_ADDR); fm_info_set_phy_address(FM2_DTSEC1, SGMII_CARD_PORT1_PHY_ADDR); fm_info_set_phy_address(FM2_DTSEC2, SGMII_CARD_PORT2_PHY_ADDR); fm_info_set_phy_address(FM2_DTSEC3, SGMII_CARD_PORT3_PHY_ADDR); @@ -433,7 +501,7 @@ int board_eth_init(bd_t *bis) }
for (i = FM2_DTSEC1; i < FM2_DTSEC1 + CONFIG_SYS_NUM_FM2_DTSEC; i++) { - int idx = i - FM2_DTSEC1, lane, slot; + idx = i - FM2_DTSEC1; switch (fm_info_get_enet_if(i)) { case PHY_INTERFACE_MODE_SGMII: lane = serdes_get_first_lane(FSL_SRDS_2, @@ -477,8 +545,16 @@ int board_eth_init(bd_t *bis) }
for (i = FM2_10GEC1; i < FM2_10GEC1 + CONFIG_SYS_NUM_FM2_10GEC; i++) { + idx = i - FM2_10GEC1; switch (fm_info_get_enet_if(i)) { case PHY_INTERFACE_MODE_XGMII: + lane = serdes_get_first_lane(FSL_SRDS_2, + XAUI_FM2_MAC9 + idx); + if (lane < 0) + break; + slot = lane_to_slot_fsm2[lane]; + if (QIXIS_READ(present2) & (1 << (slot - 1))) + fm_disable_port(i); mdio_mux[i] = EMI2; fm_info_set_mdio(i, mii_dev_for_muxval(mdio_mux[i])); break; diff --git a/include/configs/t4qds.h b/include/configs/t4qds.h index a8346f0..ef8c5b2 100644 --- a/include/configs/t4qds.h +++ b/include/configs/t4qds.h @@ -649,10 +649,6 @@ unsigned long get_board_ddr_clk(void); #define SGMII_CARD_PORT2_PHY_ADDR 0x1D #define SGMII_CARD_PORT3_PHY_ADDR 0x1E #define SGMII_CARD_PORT4_PHY_ADDR 0x1F -#define XFI_CARD_PORT1_PHY_ADDR 0x1 /* tmp, FIXME below addr */ -#define XFI_CARD_PORT2_PHY_ADDR 0x2 -#define XFI_CARD_PORT3_PHY_ADDR 0x3 -#define XFI_CARD_PORT4_PHY_ADDR 0x4 #define QSGMII_CARD_PHY_ADDR 0x5 #define FM1_10GEC1_PHY_ADDR 0x0 #define FM1_10GEC2_PHY_ADDR 0x1
- set proper compatible property name for mEMAC. - fixed ft_fixup_port for dual-role mEMAC, which will lead to MAC node disabled incorrectly.
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com --- drivers/net/fm/fm.h | 2 ++ drivers/net/fm/init.c | 25 +++++++++++++++++++++++++ 2 files changed, 27 insertions(+)
diff --git a/drivers/net/fm/fm.h b/drivers/net/fm/fm.h index 228df33..ba581e9 100644 --- a/drivers/net/fm/fm.h +++ b/drivers/net/fm/fm.h @@ -152,4 +152,6 @@ struct fm_eth { #define MAX_RXBUF_LOG2 11 #define MAX_RXBUF_LEN (1 << MAX_RXBUF_LOG2)
+#define PORT_IS_ENABLED(port) fm_info[fm_port_to_index(port)].enabled + #endif /* __FM_H__ */ diff --git a/drivers/net/fm/init.c b/drivers/net/fm/init.c index d12ec9b..5908c32 100644 --- a/drivers/net/fm/init.c +++ b/drivers/net/fm/init.c @@ -238,6 +238,26 @@ static void ft_fixup_port(void *blob, struct fm_eth_info *info, char *prop) return ; }
+#ifdef CONFIG_SYS_FMAN_V3 + /* + * Physically FM1_DTSEC9 and FM1_10GEC1 use the same dual-role MAC, when + * FM1_10GEC1 is enabled and FM1_DTSEC9 is disabled, ensure that the + * dual-role MAC is not disabled, ditto for other dual-role MACs. + */ + if (((info->port == FM1_DTSEC9) && (PORT_IS_ENABLED(FM1_10GEC1))) || + ((info->port == FM1_DTSEC10) && (PORT_IS_ENABLED(FM1_10GEC2))) || + ((info->port == FM1_10GEC1) && (PORT_IS_ENABLED(FM1_DTSEC9))) || + ((info->port == FM1_10GEC2) && (PORT_IS_ENABLED(FM1_DTSEC10))) +#if (CONFIG_SYS_NUM_FMAN == 2) + || + ((info->port == FM2_DTSEC9) && (PORT_IS_ENABLED(FM2_10GEC1))) || + ((info->port == FM2_DTSEC10) && (PORT_IS_ENABLED(FM2_10GEC2))) || + ((info->port == FM2_10GEC1) && (PORT_IS_ENABLED(FM2_DTSEC9))) || + ((info->port == FM2_10GEC2) && (PORT_IS_ENABLED(FM2_DTSEC10))) +#endif + ) + return; +#endif /* board code might have caused offset to change */ off = fdt_node_offset_by_compat_reg(blob, prop, paddr);
@@ -255,10 +275,15 @@ void fdt_fixup_fman_ethernet(void *blob) { int i;
+#ifdef CONFIG_SYS_FMAN_V3 + for (i = 0; i < ARRAY_SIZE(fm_info); i++) + ft_fixup_port(blob, &fm_info[i], "fsl,fman-memac"); +#else for (i = 0; i < ARRAY_SIZE(fm_info); i++) { if (fm_info[i].type == FM_ETH_1G_E) ft_fixup_port(blob, &fm_info[i], "fsl,fman-1g-mac"); else ft_fixup_port(blob, &fm_info[i], "fsl,fman-10g-mac"); } +#endif }
Removed unused declare serdes_get_prtcl() which was no longer needed.
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com --- arch/powerpc/include/asm/fsl_serdes.h | 1 - 1 file changed, 1 deletion(-)
diff --git a/arch/powerpc/include/asm/fsl_serdes.h b/arch/powerpc/include/asm/fsl_serdes.h index c462455..6cd7379 100644 --- a/arch/powerpc/include/asm/fsl_serdes.h +++ b/arch/powerpc/include/asm/fsl_serdes.h @@ -91,7 +91,6 @@ enum srds {
int is_serdes_configured(enum srds_prtcl device); void fsl_serdes_init(void); -enum srds_prtcl serdes_get_prtcl(int serdes, int cfg, int lane);
Hmmm... I see this is going to be a common thread for these patches...
This is added by the patch RIGHT BEFORE it, so it would have been trivial to squash. We cannot apply known-bad patches. I SHOULD just reject both of them, and ask for a new version, but I will just fix this one up by hand.
Andy
The VSC8574 is a quad-port Gigabit Ethernet transceiver with four SerDes interfaces for quad-port dual media capability. This driver supports SGMII and QSGMII MAC mode. For now SGMII mode is tested.
Signed-off-by: Roy Zang tie-fei.zang@freescale.com Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com --- drivers/net/phy/vitesse.c | 67 +++++++++++++++++++++++++++++++++++++++++++++ include/phy.h | 2 ++ 2 files changed, 69 insertions(+)
diff --git a/drivers/net/phy/vitesse.c b/drivers/net/phy/vitesse.c index 6c5cb99..c283d82 100644 --- a/drivers/net/phy/vitesse.c +++ b/drivers/net/phy/vitesse.c @@ -48,6 +48,19 @@ #define MIIM_VSC8601_SKEW_CTRL 0x1c
#define PHY_EXT_PAGE_ACCESS 0x1f +#define PHY_EXT_PAGE_ACCESS_GENERAL 0x10 +#define PHY_EXT_PAGE_ACCESS_EXTENDED3 0x3 + +/* Vitesse VSC8574 control register */ +#define MIIM_VSC8574_MAC_SERDES_CON 0x10 +#define MIIM_VSC8574_MAC_SERDES_ANEG 0x80 +#define MIIM_VSC8574_GENERAL18 0x12 +#define MIIM_VSC8574_GENERAL19 0x13 + +/* Vitesse VSC8574 gerenal purpose register 18 */ +#define MIIM_VSC8574_18G_SGMII 0x80f0 +#define MIIM_VSC8574_18G_QSGMII 0x80e0 +#define MIIM_VSC8574_18G_CMDSTAT 0x8000
/* CIS8201 */ static int vitesse_config(struct phy_device *phydev) @@ -145,6 +158,49 @@ static int vsc8601_config(struct phy_device *phydev) return 0; }
+static int vsc8574_config(struct phy_device *phydev) +{ + u32 val; + /* configure regiser 19G for MAC */ + phy_write(phydev, MDIO_DEVAD_NONE, PHY_EXT_PAGE_ACCESS, + PHY_EXT_PAGE_ACCESS_GENERAL); + + val = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_VSC8574_GENERAL19); + if (phydev->interface == PHY_INTERFACE_MODE_QSGMII) { + /* set bit 15:14 to '01' for QSGMII mode */ + val = (val & 0x3fff) | (1 << 14); + phy_write(phydev, MDIO_DEVAD_NONE, + MIIM_VSC8574_GENERAL19, val); + /* Enable 4 ports MAC QSGMII */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_VSC8574_GENERAL18, + MIIM_VSC8574_18G_QSGMII); + } else { + /* set bit 15:14 to '00' for SGMII mode */ + val = val & 0x3fff; + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_VSC8574_GENERAL19, val); + /* Enable 4 ports MAC SGMII */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_VSC8574_GENERAL18, + MIIM_VSC8574_18G_SGMII); + } + val = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_VSC8574_GENERAL18); + /* When bit 15 is cleared the command has completed */ + while (val & MIIM_VSC8574_18G_CMDSTAT) + val = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_VSC8574_GENERAL18); + + /* Enable Serdes Auto-negotiation */ + phy_write(phydev, MDIO_DEVAD_NONE, PHY_EXT_PAGE_ACCESS, + PHY_EXT_PAGE_ACCESS_EXTENDED3); + val = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_VSC8574_MAC_SERDES_CON); + val = val | MIIM_VSC8574_MAC_SERDES_ANEG; + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_VSC8574_MAC_SERDES_CON, val); + + phy_write(phydev, MDIO_DEVAD_NONE, PHY_EXT_PAGE_ACCESS, 0); + + genphy_config_aneg(phydev); + + return 0; +} + static struct phy_driver VSC8211_driver = { .name = "Vitesse VSC8211", .uid = 0xfc4b0, @@ -185,6 +241,16 @@ static struct phy_driver VSC8234_driver = { .shutdown = &genphy_shutdown, };
+static struct phy_driver VSC8574_driver = { + .name = "Vitesse VSC8574", + .uid = 0x704a0, + .mask = 0xffff0, + .features = PHY_GBIT_FEATURES, + .config = &vsc8574_config, + .startup = &vitesse_startup, + .shutdown = &genphy_shutdown, +}; + static struct phy_driver VSC8601_driver = { .name = "Vitesse VSC8601", .uid = 0x70420, @@ -244,6 +310,7 @@ int phy_vitesse_init(void) phy_register(&VSC8244_driver); phy_register(&VSC8211_driver); phy_register(&VSC8221_driver); + phy_register(&VSC8574_driver); phy_register(&VSC8662_driver); phy_register(&cis8201_driver); phy_register(&cis8204_driver); diff --git a/include/phy.h b/include/phy.h index 58ca273..44d5eaf 100644 --- a/include/phy.h +++ b/include/phy.h @@ -52,6 +52,7 @@ typedef enum { PHY_INTERFACE_MODE_MII, PHY_INTERFACE_MODE_GMII, PHY_INTERFACE_MODE_SGMII, + PHY_INTERFACE_MODE_QSGMII, PHY_INTERFACE_MODE_TBI, PHY_INTERFACE_MODE_RMII, PHY_INTERFACE_MODE_RGMII, @@ -67,6 +68,7 @@ static const char *phy_interface_strings[] = { [PHY_INTERFACE_MODE_MII] = "mii", [PHY_INTERFACE_MODE_GMII] = "gmii", [PHY_INTERFACE_MODE_SGMII] = "sgmii", + [PHY_INTERFACE_MODE_QSGMII] = "qsgmii", [PHY_INTERFACE_MODE_TBI] = "tbi", [PHY_INTERFACE_MODE_RMII] = "rmii", [PHY_INTERFACE_MODE_RGMII] = "rgmii",
Use QSGMII card PHY address as default SGMII card PHY address, QSGMII card PHY address is variable depends on different slot.
Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com --- board/freescale/t4qds/eth.c | 123 +++++++++++++++++++++++-------------------- include/configs/t4qds.h | 1 - 2 files changed, 67 insertions(+), 57 deletions(-)
diff --git a/board/freescale/t4qds/eth.c b/board/freescale/t4qds/eth.c index 8d2c33f..2232eea 100644 --- a/board/freescale/t4qds/eth.c +++ b/board/freescale/t4qds/eth.c @@ -71,6 +71,13 @@ static const char *mdio_names[] = {
static u8 lane_to_slot_fsm1[] = {1, 1, 1, 1, 2, 2, 2, 2}; static u8 lane_to_slot_fsm2[] = {3, 3, 3, 3, 4, 4, 4, 4}; +static u8 slot_qsgmii_phyaddr[5][4] = { + {0, 0, 0, 0},/* not used, to make index match slot No. */ + {0, 1, 2, 3}, + {4, 5, 6, 7}, + {8, 9, 0xa, 0xb}, + {0xc, 0xd, 0xe, 0xf}, +};
static const char *t4240qds_mdio_name_for_muxval(u8 muxval) { @@ -313,44 +320,48 @@ int board_eth_init(bd_t *bis) case 28: case 36: /* SGMII in Slot1 and Slot2 */ - fm_info_set_phy_address(FM1_DTSEC1, SGMII_CARD_PORT1_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC2, SGMII_CARD_PORT2_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC3, SGMII_CARD_PORT3_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC4, SGMII_CARD_PORT4_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC5, SGMII_CARD_PORT1_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC6, SGMII_CARD_PORT2_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC1, slot_qsgmii_phyaddr[2][0]); + fm_info_set_phy_address(FM1_DTSEC2, slot_qsgmii_phyaddr[2][1]); + fm_info_set_phy_address(FM1_DTSEC3, slot_qsgmii_phyaddr[2][2]); + fm_info_set_phy_address(FM1_DTSEC4, slot_qsgmii_phyaddr[2][3]); + fm_info_set_phy_address(FM1_DTSEC5, slot_qsgmii_phyaddr[1][0]); + fm_info_set_phy_address(FM1_DTSEC6, slot_qsgmii_phyaddr[1][1]); if ((srds_prtcl_s2 != 56) && (srds_prtcl_s2 != 57)) { fm_info_set_phy_address(FM1_DTSEC9, - SGMII_CARD_PORT4_PHY_ADDR); + slot_qsgmii_phyaddr[1][3]); fm_info_set_phy_address(FM1_DTSEC10, - SGMII_CARD_PORT3_PHY_ADDR); + slot_qsgmii_phyaddr[1][2]); } break; case 38: - fm_info_set_phy_address(FM1_DTSEC5, QSGMII_CARD_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC6, QSGMII_CARD_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC1, slot_qsgmii_phyaddr[2][0]); + fm_info_set_phy_address(FM1_DTSEC2, slot_qsgmii_phyaddr[2][1]); + fm_info_set_phy_address(FM1_DTSEC3, slot_qsgmii_phyaddr[2][2]); + fm_info_set_phy_address(FM1_DTSEC4, slot_qsgmii_phyaddr[2][3]); + fm_info_set_phy_address(FM1_DTSEC5, slot_qsgmii_phyaddr[1][0]); + fm_info_set_phy_address(FM1_DTSEC6, slot_qsgmii_phyaddr[1][1]); if ((srds_prtcl_s2 != 56) && (srds_prtcl_s2 != 57)) { fm_info_set_phy_address(FM1_DTSEC9, - QSGMII_CARD_PHY_ADDR); + slot_qsgmii_phyaddr[1][3]); fm_info_set_phy_address(FM1_DTSEC10, - QSGMII_CARD_PHY_ADDR); + slot_qsgmii_phyaddr[1][2]); } break; case 40: case 46: case 48: - fm_info_set_phy_address(FM1_DTSEC5, SGMII_CARD_PORT1_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC6, SGMII_CARD_PORT2_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC5, slot_qsgmii_phyaddr[1][0]); + fm_info_set_phy_address(FM1_DTSEC6, slot_qsgmii_phyaddr[1][1]); if ((srds_prtcl_s2 != 56) && (srds_prtcl_s2 != 57)) { fm_info_set_phy_address(FM1_DTSEC10, - SGMII_CARD_PORT3_PHY_ADDR); + slot_qsgmii_phyaddr[1][3]); fm_info_set_phy_address(FM1_DTSEC9, - SGMII_CARD_PORT4_PHY_ADDR); + slot_qsgmii_phyaddr[1][2]); } - fm_info_set_phy_address(FM1_DTSEC1, QSGMII_CARD_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC2, QSGMII_CARD_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC3, QSGMII_CARD_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC4, QSGMII_CARD_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC1, slot_qsgmii_phyaddr[2][0]); + fm_info_set_phy_address(FM1_DTSEC2, slot_qsgmii_phyaddr[2][1]); + fm_info_set_phy_address(FM1_DTSEC3, slot_qsgmii_phyaddr[2][2]); + fm_info_set_phy_address(FM1_DTSEC4, slot_qsgmii_phyaddr[2][3]); break; default: puts("Invalid SerDes1 protocol for T4240QDS\n"); @@ -436,64 +447,64 @@ int board_eth_init(bd_t *bis) case 26: /* XAUI/HiGig in Slot3, SGMII in Slot4 */ fm_info_set_phy_address(FM2_10GEC1, FM2_10GEC1_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC1, SGMII_CARD_PORT1_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC2, SGMII_CARD_PORT2_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC3, SGMII_CARD_PORT3_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC4, SGMII_CARD_PORT4_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC1, slot_qsgmii_phyaddr[4][0]); + fm_info_set_phy_address(FM2_DTSEC2, slot_qsgmii_phyaddr[4][1]); + fm_info_set_phy_address(FM2_DTSEC3, slot_qsgmii_phyaddr[4][2]); + fm_info_set_phy_address(FM2_DTSEC4, slot_qsgmii_phyaddr[4][3]); break; case 28: case 36: /* SGMII in Slot3 and Slot4 */ - fm_info_set_phy_address(FM2_DTSEC1, SGMII_CARD_PORT1_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC2, SGMII_CARD_PORT2_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC3, SGMII_CARD_PORT3_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC4, SGMII_CARD_PORT4_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC5, SGMII_CARD_PORT1_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC6, SGMII_CARD_PORT2_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC9, SGMII_CARD_PORT4_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC10, SGMII_CARD_PORT3_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC1, slot_qsgmii_phyaddr[4][0]); + fm_info_set_phy_address(FM2_DTSEC2, slot_qsgmii_phyaddr[4][1]); + fm_info_set_phy_address(FM2_DTSEC3, slot_qsgmii_phyaddr[4][2]); + fm_info_set_phy_address(FM2_DTSEC4, slot_qsgmii_phyaddr[4][3]); + fm_info_set_phy_address(FM2_DTSEC5, slot_qsgmii_phyaddr[3][0]); + fm_info_set_phy_address(FM2_DTSEC6, slot_qsgmii_phyaddr[3][1]); + fm_info_set_phy_address(FM2_DTSEC9, slot_qsgmii_phyaddr[3][3]); + fm_info_set_phy_address(FM2_DTSEC10, slot_qsgmii_phyaddr[3][2]); break; case 38: /* QSGMII in Slot3 and Slot4 */ - fm_info_set_phy_address(FM2_DTSEC1, QSGMII_CARD_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC2, QSGMII_CARD_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC3, QSGMII_CARD_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC4, QSGMII_CARD_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC5, QSGMII_CARD_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC6, QSGMII_CARD_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC9, QSGMII_CARD_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC10, QSGMII_CARD_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC1, slot_qsgmii_phyaddr[4][0]); + fm_info_set_phy_address(FM2_DTSEC2, slot_qsgmii_phyaddr[4][1]); + fm_info_set_phy_address(FM2_DTSEC3, slot_qsgmii_phyaddr[4][2]); + fm_info_set_phy_address(FM2_DTSEC4, slot_qsgmii_phyaddr[4][3]); + fm_info_set_phy_address(FM2_DTSEC5, slot_qsgmii_phyaddr[3][0]); + fm_info_set_phy_address(FM2_DTSEC6, slot_qsgmii_phyaddr[3][1]); + fm_info_set_phy_address(FM2_DTSEC9, slot_qsgmii_phyaddr[3][3]); + fm_info_set_phy_address(FM2_DTSEC10, slot_qsgmii_phyaddr[3][2]); break; case 40: case 46: case 48: /* SGMII in Slot3 */ - fm_info_set_phy_address(FM2_DTSEC5, SGMII_CARD_PORT1_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC6, SGMII_CARD_PORT2_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC9, SGMII_CARD_PORT4_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC10, SGMII_CARD_PORT3_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC5, slot_qsgmii_phyaddr[3][0]); + fm_info_set_phy_address(FM2_DTSEC6, slot_qsgmii_phyaddr[3][1]); + fm_info_set_phy_address(FM2_DTSEC9, slot_qsgmii_phyaddr[3][3]); + fm_info_set_phy_address(FM2_DTSEC10, slot_qsgmii_phyaddr[3][2]); /* QSGMII in Slot4 */ - fm_info_set_phy_address(FM2_DTSEC1, QSGMII_CARD_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC2, QSGMII_CARD_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC3, QSGMII_CARD_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC4, QSGMII_CARD_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC1, slot_qsgmii_phyaddr[4][0]); + fm_info_set_phy_address(FM2_DTSEC2, slot_qsgmii_phyaddr[4][1]); + fm_info_set_phy_address(FM2_DTSEC3, slot_qsgmii_phyaddr[4][2]); + fm_info_set_phy_address(FM2_DTSEC4, slot_qsgmii_phyaddr[4][3]); break; case 50: case 52: case 54: fm_info_set_phy_address(FM2_10GEC1, FM2_10GEC1_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC1, QSGMII_CARD_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC2, QSGMII_CARD_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC3, QSGMII_CARD_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC4, QSGMII_CARD_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC1, slot_qsgmii_phyaddr[4][0]); + fm_info_set_phy_address(FM2_DTSEC2, slot_qsgmii_phyaddr[4][1]); + fm_info_set_phy_address(FM2_DTSEC3, slot_qsgmii_phyaddr[4][2]); + fm_info_set_phy_address(FM2_DTSEC4, slot_qsgmii_phyaddr[4][3]); break; case 56: case 57: /* XFI in Slot3, SGMII in Slot4 */ - fm_info_set_phy_address(FM2_DTSEC1, SGMII_CARD_PORT1_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC2, SGMII_CARD_PORT2_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC3, SGMII_CARD_PORT3_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC4, SGMII_CARD_PORT4_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC1, slot_qsgmii_phyaddr[4][0]); + fm_info_set_phy_address(FM2_DTSEC2, slot_qsgmii_phyaddr[4][1]); + fm_info_set_phy_address(FM2_DTSEC3, slot_qsgmii_phyaddr[4][2]); + fm_info_set_phy_address(FM2_DTSEC4, slot_qsgmii_phyaddr[4][3]); break; default: puts("Invalid SerDes2 protocol for T4240QDS\n"); diff --git a/include/configs/t4qds.h b/include/configs/t4qds.h index ef8c5b2..b5462b7 100644 --- a/include/configs/t4qds.h +++ b/include/configs/t4qds.h @@ -649,7 +649,6 @@ unsigned long get_board_ddr_clk(void); #define SGMII_CARD_PORT2_PHY_ADDR 0x1D #define SGMII_CARD_PORT3_PHY_ADDR 0x1E #define SGMII_CARD_PORT4_PHY_ADDR 0x1F -#define QSGMII_CARD_PHY_ADDR 0x5 #define FM1_10GEC1_PHY_ADDR 0x0 #define FM1_10GEC2_PHY_ADDR 0x1 #define FM2_10GEC1_PHY_ADDR 0x2
This is what we have done for the UTMI PHY on P3041/P5020. Then the PHY initialization can be reused in kernel without “usb start” command.
Signed-off-by: Roy Zang tie-fei.zang@freescale.com --- arch/powerpc/cpu/mpc85xx/cpu_init.c | 22 ++++++++++++++++++++++ drivers/usb/host/ehci-fsl.c | 21 --------------------- 2 files changed, 22 insertions(+), 21 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index de9d916..d61791a 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -623,6 +623,28 @@ skip_l2: } #endif
+#if defined(CONFIG_SYS_FSL_USB_DUAL_PHY_ENABLE) + ccsr_usb_phy_t *usb_phy = + (void *)CONFIG_SYS_MPC85xx_USB1_PHY_ADDR; + setbits_be32(&usb_phy->pllprg[1], + CONFIG_SYS_FSL_USB_PLLPRG2_PHY2_CLK_EN | + CONFIG_SYS_FSL_USB_PLLPRG2_PHY1_CLK_EN | + CONFIG_SYS_FSL_USB_PLLPRG2_MFI | + CONFIG_SYS_FSL_USB_PLLPRG2_PLL_EN); + setbits_be32(&usb_phy->port1.ctrl, + CONFIG_SYS_FSL_USB_CTRL_PHY_EN); + setbits_be32(&usb_phy->port1.drvvbuscfg, + CONFIG_SYS_FSL_USB_DRVVBUS_CR_EN); + setbits_be32(&usb_phy->port1.pwrfltcfg, + CONFIG_SYS_FSL_USB_PWRFLT_CR_EN); + setbits_be32(&usb_phy->port2.ctrl, + CONFIG_SYS_FSL_USB_CTRL_PHY_EN); + setbits_be32(&usb_phy->port2.drvvbuscfg, + CONFIG_SYS_FSL_USB_DRVVBUS_CR_EN); + setbits_be32(&usb_phy->port2.pwrfltcfg, + CONFIG_SYS_FSL_USB_PWRFLT_CR_EN); +#endif + #ifdef CONFIG_FMAN_ENET fman_enet_init(); #endif diff --git a/drivers/usb/host/ehci-fsl.c b/drivers/usb/host/ehci-fsl.c index 77c41f3..f54b408 100644 --- a/drivers/usb/host/ehci-fsl.c +++ b/drivers/usb/host/ehci-fsl.c @@ -89,27 +89,6 @@ int ehci_hcd_init(int index, struct ehci_hccr **hccr, struct ehci_hcor **hcor)
if (!strcmp(phy_type, "utmi")) { #if defined(CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY) -#if defined(CONFIG_SYS_FSL_USB_DUAL_PHY_ENABLE) - ccsr_usb_phy_t *usb_phy = - (void *)CONFIG_SYS_MPC85xx_USB1_PHY_ADDR; - setbits_be32(&usb_phy->pllprg[1], - CONFIG_SYS_FSL_USB_PLLPRG2_PHY2_CLK_EN | - CONFIG_SYS_FSL_USB_PLLPRG2_PHY1_CLK_EN | - CONFIG_SYS_FSL_USB_PLLPRG2_MFI | - CONFIG_SYS_FSL_USB_PLLPRG2_PLL_EN); - setbits_be32(&usb_phy->port1.ctrl, - CONFIG_SYS_FSL_USB_CTRL_PHY_EN); - setbits_be32(&usb_phy->port1.drvvbuscfg, - CONFIG_SYS_FSL_USB_DRVVBUS_CR_EN); - setbits_be32(&usb_phy->port1.pwrfltcfg, - CONFIG_SYS_FSL_USB_PWRFLT_CR_EN); - setbits_be32(&usb_phy->port2.ctrl, - CONFIG_SYS_FSL_USB_CTRL_PHY_EN); - setbits_be32(&usb_phy->port2.drvvbuscfg, - CONFIG_SYS_FSL_USB_DRVVBUS_CR_EN); - setbits_be32(&usb_phy->port2.pwrfltcfg, - CONFIG_SYS_FSL_USB_PWRFLT_CR_EN); -#endif setbits_be32(&ehci->control, PHY_CLK_SEL_UTMI); setbits_be32(&ehci->control, UTMI_PHY_EN); udelay(1000); /* delay required for PHY Clk to appear */
The workaround has been updated to use a slightly different magic number. Change from 0x00003000 to 0x30003000.
Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/cpu/mpc85xx/ddr-gen3.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/powerpc/cpu/mpc85xx/ddr-gen3.c b/arch/powerpc/cpu/mpc85xx/ddr-gen3.c index ef0dd1d..c5b4720 100644 --- a/arch/powerpc/cpu/mpc85xx/ddr-gen3.c +++ b/arch/powerpc/cpu/mpc85xx/ddr-gen3.c @@ -142,7 +142,7 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, } } #ifdef CONFIG_SYS_FSL_ERRATUM_A_004934 - out_be32(&ddr->debug[28], 0x00003000); + out_be32(&ddr->debug[28], 0x30003000); #endif
#ifdef CONFIG_SYS_FSL_ERRATUM_DDR_A003474
This gives boards flexibility to assign other than default addresses to each DDR controller. For example, DDR controler 2 can have 0 as the base and DDR controller 1 has higher memory.
Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/cpu/mpc8xxx/ddr/main.c | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/main.c b/arch/powerpc/cpu/mpc8xxx/ddr/main.c index 1a8d593..7a8636d 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/main.c +++ b/arch/powerpc/cpu/mpc8xxx/ddr/main.c @@ -186,7 +186,7 @@ const char * step_to_string(unsigned int step) { return step_string_tbl[s]; }
-unsigned long long step_assign_addresses(fsl_ddr_info_t *pinfo, +static unsigned long long __step_assign_addresses(fsl_ddr_info_t *pinfo, unsigned int dbw_cap_adj[]) { int i, j; @@ -354,6 +354,11 @@ unsigned long long step_assign_addresses(fsl_ddr_info_t *pinfo, return total_mem; }
+/* Use weak function to allow board file to override the address assignment */ +__attribute__((weak, alias("__step_assign_addresses"))) +unsigned long long step_assign_addresses(fsl_ddr_info_t *pinfo, + unsigned int dbw_cap_adj[]); + unsigned long long fsl_ddr_compute(fsl_ddr_info_t *pinfo, unsigned int start_step, unsigned int size_only)
B4860QDS requires DDRC2 has 0 as base address and DDRC1 has higher address. This is the requirement for DSP cores to run in 32-bit address space.
Signed-off-by: York Sun yorksun@freescale.com --- board/freescale/b4860qds/ddr.c | 72 ++++++++++++++++++++++++++++++++++++++++ 1 file changed, 72 insertions(+)
diff --git a/board/freescale/b4860qds/ddr.c b/board/freescale/b4860qds/ddr.c index dd4c0f6..b82b3d4 100644 --- a/board/freescale/b4860qds/ddr.c +++ b/board/freescale/b4860qds/ddr.c @@ -13,6 +13,7 @@ #include <asm/fsl_ddr_sdram.h> #include <asm/fsl_ddr_dimm_params.h> #include <asm/fsl_law.h> +#include <../arch/powerpc/cpu/mpc8xxx/ddr/ddr.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -188,3 +189,74 @@ phys_size_t initdram(int board_type) puts(" DDR: "); return dram_size; } + +unsigned long long step_assign_addresses(fsl_ddr_info_t *pinfo, + unsigned int dbw_cap_adj[]) +{ + int i, j; + unsigned long long total_mem, current_mem_base, total_ctlr_mem; + unsigned long long rank_density, ctlr_density = 0; + + current_mem_base = 0ull; + total_mem = 0; + /* + * This board has soldered DDR chips. DDRC1 has two rank. + * DDRC2 has only one rank. + * Assigning DDRC2 to lower address and DDRC1 to higher address. + */ + if (pinfo->memctl_opts[0].memctl_interleaving) { + rank_density = pinfo->dimm_params[0][0].rank_density >> + dbw_cap_adj[0]; + ctlr_density = rank_density; + + debug("rank density is 0x%llx, ctlr density is 0x%llx\n", + rank_density, ctlr_density); + for (i = CONFIG_NUM_DDR_CONTROLLERS - 1; i >= 0; i--) { + switch (pinfo->memctl_opts[i].memctl_interleaving_mode) { + case FSL_DDR_CACHE_LINE_INTERLEAVING: + case FSL_DDR_PAGE_INTERLEAVING: + case FSL_DDR_BANK_INTERLEAVING: + case FSL_DDR_SUPERBANK_INTERLEAVING: + total_ctlr_mem = 2 * ctlr_density; + break; + default: + panic("Unknown interleaving mode"); + } + pinfo->common_timing_params[i].base_address = + current_mem_base; + pinfo->common_timing_params[i].total_mem = + total_ctlr_mem; + total_mem = current_mem_base + total_ctlr_mem; + debug("ctrl %d base 0x%llx\n", i, current_mem_base); + debug("ctrl %d total 0x%llx\n", i, total_ctlr_mem); + } + } else { + /* + * Simple linear assignment if memory + * controllers are not interleaved. + */ + for (i = CONFIG_NUM_DDR_CONTROLLERS - 1; i >= 0; i--) { + total_ctlr_mem = 0; + pinfo->common_timing_params[i].base_address = + current_mem_base; + for (j = 0; j < CONFIG_DIMM_SLOTS_PER_CTLR; j++) { + /* Compute DIMM base addresses. */ + unsigned long long cap = + pinfo->dimm_params[i][j].capacity; + pinfo->dimm_params[i][j].base_address = + current_mem_base; + debug("ctrl %d dimm %d base 0x%llx\n", + i, j, current_mem_base); + current_mem_base += cap; + total_ctlr_mem += cap; + } + debug("ctrl %d total 0x%llx\n", i, total_ctlr_mem); + pinfo->common_timing_params[i].total_mem = + total_ctlr_mem; + total_mem += total_ctlr_mem; + } + } + debug("Total mem by %s is 0x%llx\n", __func__, total_mem); + + return total_mem; +}
Only clear IRE bit in qixis brdcfg5 register and keep other bits unchanged.
Signed-off-by: Ed Swarthout Ed.Swarthout@freescale.com Signed-off-by: York Sun yorksun@freescale.com --- board/freescale/t4qds/t4240qds_qixis.h | 2 +- board/freescale/t4qds/t4qds.c | 4 ++-- 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/board/freescale/t4qds/t4240qds_qixis.h b/board/freescale/t4qds/t4240qds_qixis.h index efb718d..485353d 100644 --- a/board/freescale/t4qds/t4240qds_qixis.h +++ b/board/freescale/t4qds/t4240qds_qixis.h @@ -42,7 +42,7 @@ #define QIXIS_DDRCLK_125 0x2 #define QIXIS_DDRCLK_133 0x3
-#define BRDCFG5_RESET 0x00 +#define BRDCFG5_IRE 0x20 /* i2c Remote i2c1 enable */
#define BRDCFG12_SD3EN_MASK 0x20 #define BRDCFG12_SD3MX_MASK 0x08 diff --git a/board/freescale/t4qds/t4qds.c b/board/freescale/t4qds/t4qds.c index c1bb8bf..d521008 100644 --- a/board/freescale/t4qds/t4qds.c +++ b/board/freescale/t4qds/t4qds.c @@ -504,8 +504,8 @@ int board_early_init_r(void) setup_portals(); #endif
- /* Disable remote I2C connectoin */ - QIXIS_WRITE(brdcfg[5], BRDCFG5_RESET); + /* Disable remote I2C connection to qixis fpga */ + QIXIS_WRITE(brdcfg[5], QIXIS_READ(brdcfg[5]) & ~BRDCFG5_IRE);
/* * Adjust core voltage according to voltage ID
QSGMII card assumed to be used by default, but if SGMII card is used, it will use different PHY address, but we don't know which card is used until we access PHY on the card. So we check the card type slot by slot, if we can read a PHY ID by reading a SGMII PHY address on a slot, then the slot must have a SGMII card pluged, we mark all ports on that slot, and fix dts to use the SGMII card PHY address when doing dts fixup for the marked ports.
Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com --- board/freescale/t4qds/eth.c | 137 +++++++++++++++++++++++++++++++++++++++++-- 1 file changed, 133 insertions(+), 4 deletions(-)
diff --git a/board/freescale/t4qds/eth.c b/board/freescale/t4qds/eth.c index 2232eea..b649df0 100644 --- a/board/freescale/t4qds/eth.c +++ b/board/freescale/t4qds/eth.c @@ -78,6 +78,7 @@ static u8 slot_qsgmii_phyaddr[5][4] = { {8, 9, 0xa, 0xb}, {0xc, 0xd, 0xe, 0xf}, }; +static u8 qsgmiiphy_fix[NUM_FM_PORTS] = {0};
static const char *t4240qds_mdio_name_for_muxval(u8 muxval) { @@ -189,17 +190,87 @@ void board_ft_fman_fixup_port(void *blob, char * prop, phys_addr_t pa, { if (fm_info_get_enet_if(port) == PHY_INTERFACE_MODE_SGMII) { switch (port) { + case FM1_DTSEC1: + if (qsgmiiphy_fix[port]) + fdt_set_phy_handle(blob, prop, pa, + "sgmii_phy21"); + break; + case FM1_DTSEC2: + if (qsgmiiphy_fix[port]) + fdt_set_phy_handle(blob, prop, pa, + "sgmii_phy22"); + break; + case FM1_DTSEC3: + if (qsgmiiphy_fix[port]) + fdt_set_phy_handle(blob, prop, pa, + "sgmii_phy23"); + break; + case FM1_DTSEC4: + if (qsgmiiphy_fix[port]) + fdt_set_phy_handle(blob, prop, pa, + "sgmii_phy24"); + break; + case FM1_DTSEC6: + if (qsgmiiphy_fix[port]) + fdt_set_phy_handle(blob, prop, pa, + "sgmii_phy12"); + break; case FM1_DTSEC9: - fdt_set_phy_handle(blob, prop, pa, "phy_sgmii4"); + if (qsgmiiphy_fix[port]) + fdt_set_phy_handle(blob, prop, pa, + "sgmii_phy14"); + else + fdt_set_phy_handle(blob, prop, pa, + "phy_sgmii4"); break; case FM1_DTSEC10: - fdt_set_phy_handle(blob, prop, pa, "phy_sgmii3"); + if (qsgmiiphy_fix[port]) + fdt_set_phy_handle(blob, prop, pa, + "sgmii_phy13"); + else + fdt_set_phy_handle(blob, prop, pa, + "phy_sgmii3"); + break; + case FM2_DTSEC1: + if (qsgmiiphy_fix[port]) + fdt_set_phy_handle(blob, prop, pa, + "sgmii_phy41"); + break; + case FM2_DTSEC2: + if (qsgmiiphy_fix[port]) + fdt_set_phy_handle(blob, prop, pa, + "sgmii_phy42"); + break; + case FM2_DTSEC3: + if (qsgmiiphy_fix[port]) + fdt_set_phy_handle(blob, prop, pa, + "sgmii_phy43"); + break; + case FM2_DTSEC4: + if (qsgmiiphy_fix[port]) + fdt_set_phy_handle(blob, prop, pa, + "sgmii_phy44"); + break; + case FM2_DTSEC6: + if (qsgmiiphy_fix[port]) + fdt_set_phy_handle(blob, prop, pa, + "sgmii_phy32"); break; case FM2_DTSEC9: - fdt_set_phy_handle(blob, prop, pa, "phy_sgmii12"); + if (qsgmiiphy_fix[port]) + fdt_set_phy_handle(blob, prop, pa, + "sgmii_phy34"); + else + fdt_set_phy_handle(blob, prop, pa, + "phy_sgmii12"); break; case FM2_DTSEC10: - fdt_set_phy_handle(blob, prop, pa, "phy_sgmii11"); + if (qsgmiiphy_fix[port]) + fdt_set_phy_handle(blob, prop, pa, + "sgmii_phy33"); + else + fdt_set_phy_handle(blob, prop, pa, + "phy_sgmii11"); break; default: break; @@ -263,6 +334,62 @@ void fdt_fixup_board_enet(void *fdt) } }
+static void initialize_qsgmiiphy_fix(void) +{ + int i; + unsigned short reg; + + for (i = 1; i <= 4; i++) { + /* + * Try to read if a SGMII card is used, we do it slot by slot. + * if a SGMII PHY address is valid on a slot, then we mark + * all ports on the slot, then fix the PHY address for the + * marked port when doing dtb fixup. + */ + if (miiphy_read(mdio_names[i], + SGMII_CARD_PORT1_PHY_ADDR, MII_PHYSID2, ®) != 0) { + debug("Slot%d PHY ID register 2 read failed\n", i); + continue; + } + + debug("Slot%d MII_PHYSID2 @ 0x1c= 0x%04x\n", i, reg); + + if (reg == 0xFFFF) { + /* No physical device present at this address */ + continue; + } + + switch (i) { + case 1: + qsgmiiphy_fix[FM1_DTSEC5] = 1; + qsgmiiphy_fix[FM1_DTSEC6] = 1; + qsgmiiphy_fix[FM1_DTSEC9] = 1; + qsgmiiphy_fix[FM1_DTSEC10] = 1; + break; + case 2: + qsgmiiphy_fix[FM1_DTSEC1] = 1; + qsgmiiphy_fix[FM1_DTSEC2] = 1; + qsgmiiphy_fix[FM1_DTSEC3] = 1; + qsgmiiphy_fix[FM1_DTSEC4] = 1; + break; + case 3: + qsgmiiphy_fix[FM2_DTSEC5] = 1; + qsgmiiphy_fix[FM2_DTSEC6] = 1; + qsgmiiphy_fix[FM2_DTSEC9] = 1; + qsgmiiphy_fix[FM2_DTSEC10] = 1; + break; + case 4: + qsgmiiphy_fix[FM2_DTSEC1] = 1; + qsgmiiphy_fix[FM2_DTSEC2] = 1; + qsgmiiphy_fix[FM2_DTSEC3] = 1; + qsgmiiphy_fix[FM2_DTSEC4] = 1; + break; + default: + break; + } + } +} + int board_eth_init(bd_t *bis) { #if defined(CONFIG_FMAN_ENET) @@ -575,6 +702,8 @@ int board_eth_init(bd_t *bis) } #endif /* CONFIG_SYS_NUM_FMAN */
+ initialize_qsgmiiphy_fix(); + cpu_eth_init(bis); #endif /* CONFIG_FMAN_ENET */
There are some duplicate SRIO macro definitions should be remove in below header files:
include/configs/P3041DS.h include/configs/P4080DS.h include/configs/P5020DS.h
Signed-off-by: Liu Gang Gang.Liu@freescale.com --- include/configs/P3041DS.h | 4 ---- include/configs/P4080DS.h | 4 ---- include/configs/P5020DS.h | 4 ---- 3 files changed, 12 deletions(-)
diff --git a/include/configs/P3041DS.h b/include/configs/P3041DS.h index a0a4a3c..468cc67 100644 --- a/include/configs/P3041DS.h +++ b/include/configs/P3041DS.h @@ -40,10 +40,6 @@ #define CONFIG_SRIO2 /* SRIO port 2 */ #define CONFIG_SYS_DPAA_RMAN
-#define CONFIG_SYS_SRIO -#define CONFIG_SRIO1 /* SRIO port 1 */ -#define CONFIG_SRIO2 /* SRIO port 2 */ - #define CONFIG_ICS307_REFCLK_HZ 25000000 /* ICS307 ref clk freq */
#include "corenet_ds.h" diff --git a/include/configs/P4080DS.h b/include/configs/P4080DS.h index 257258b..7a8373a 100644 --- a/include/configs/P4080DS.h +++ b/include/configs/P4080DS.h @@ -36,10 +36,6 @@ #define CONFIG_SRIO1 /* SRIO port 1 */ #define CONFIG_SRIO2 /* SRIO port 2 */
-#define CONFIG_SYS_SRIO -#define CONFIG_SRIO1 /* SRIO port 1 */ -#define CONFIG_SRIO2 /* SRIO port 2 */ - #define CONFIG_ICS307_REFCLK_HZ 33333000 /* ICS307 ref clk freq */
#include "corenet_ds.h" diff --git a/include/configs/P5020DS.h b/include/configs/P5020DS.h index a32b610..6a4bee9 100644 --- a/include/configs/P5020DS.h +++ b/include/configs/P5020DS.h @@ -41,10 +41,6 @@ #define CONFIG_SYS_FSL_RAID_ENGINE #define CONFIG_SYS_DPAA_RMAN
Tom, Wolfgang, I can take this in through my tree, but I'd like an ACK before I do so.
-- 1.7.9.5
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
On 05/10/2013 04:16 PM, Andy Fleming wrote:
On Mon, Mar 25, 2013 at 12:39 PM, York Sun <yorksun@freescale.com mailto:yorksun@freescale.com> wrote:
Signed-off-by: York Sun <yorksun@freescale.com mailto:yorksun@freescale.com> CC: Wolfgang Denk <wd@denx.de mailto:wd@denx.de> CC: Tom Rini <trini@ti.com mailto:trini@ti.com>
This should be using __weak from <linux/compiler.h>
- -- Tom
Andy Fleming
York Sun
