[U-Boot] [PATCH 00/42] clk: Add Allwinner CLK, RESET support
This series is refined version of Allwinner CLK, RESET support for previous RFC[3] which implements CLK and RESET for - USB - MMC - SPI - UART
This series depends on 'musb shutdown' series [1] and Linux dts(i) sync series [2].
Since this series supporting MMC, the previous version[4] DM_MMC migration changes are squashed and droped reset and clock ccm hacks.
Tested on A64, H3, H5, R40, A83T, A20.
Note: - added previous version fastboot, env changes as-it-is, so we can discuss for further improvements. - V3S, A23, A33 still need to test.
All these changes available at u-boot-sunxi/clk
Any inputs, Jagan.
[1] https://patchwork.ozlabs.org/cover/946738/ [2] https://patchwork.ozlabs.org/cover/953478/ [3] https://patchwork.ozlabs.org/cover/944313/ [4] https://patchwork.ozlabs.org/cover/944180/
Jagan Teki (42): clk: Kconfig: Ascending order to sub directiory kconfigs clk: Add Allwinner A64 CLK driver reset: Add default request ops reset: Add Allwinner RESET driver clk: sunxi: Add Allwinner H3/H5 CLK driver clk: sunxi: Add Allwinner A10/A20 CLK driver clk: sunxi: Add Allwinner A10s/A13 CLK driver clk: sunxi: Add Allwinner A31 CLK driver clk: sunxi: Add Allwinner A23 CLK driver clk: sunxi: a23: Add CLK support for A33 clk: sunxi: Add Allwinner A83T CLK driver clk: sunxi: Add Allwinner R40 CLK driver clk: sunxi: Add Allwinner V3S CLK driver sunxi: Enable CLK musb-new: sunxi: Use CLK and RESET support phy: sun4i-usb: Use CLK and RESET support sunxi: usb: Switch to Generic host controllers usb: host: Drop [e-o]hci-sunxi drivers clk: sunxi: Implement AHB bus MMC clocks clk: sunxi: Implement direct MMC clocks clk: sunxi: Implement AHB bus MMC resets reset: Add get reset by name optionally reset: Add reset valid dm: mmc: sunxi: Add CLK and RESET support fastboot: sunxi: Update fastboot mmc default device env: sunxi: Update default env fat device sunxi: Use mmc_bootdev=2 for MMC2 boot sunxi: A20: Enable DM_MMC mmc: sunxi: Add mmc, emmc H5/A64 compatible sunxi: H3_H5: Enable DM_MMC sunxi: A64: Enable DM_MMC mmc: sunxi: Add A83T emmc compatible sunxi: A83T: Enable DM_MMC sunxi: V40: Enable DM_MMC sunxi: A13/A31: Enable DM_MMC sunxi: A23/A33/V3S: Enable DM_MMC clk: sunxi: Implement SPI clocks clk: sunxi: Implement SPI resets spi: sun4i: Add CLK support spi: Add Allwinner A31 SPI driver clk: sunxi: Implement UART clocks clk: sunxi: Implement UART resets
arch/arm/include/asm/arch-sunxi/ccu.h | 82 +++ arch/arm/mach-sunxi/Kconfig | 22 + board/sunxi/board.c | 2 +- configs/A10-OLinuXino-Lime_defconfig | 1 + configs/A10s-OLinuXino-M_defconfig | 1 + configs/A13-OLinuXinoM_defconfig | 1 + configs/A13-OLinuXino_defconfig | 1 + configs/A20-OLinuXino-Lime2-eMMC_defconfig | 3 + configs/A20-OLinuXino-Lime2_defconfig | 1 + configs/A20-OLinuXino-Lime_defconfig | 1 + configs/A20-OLinuXino_MICRO-eMMC_defconfig | 1 + configs/A20-OLinuXino_MICRO_defconfig | 1 + configs/A20-Olimex-SOM-EVB_defconfig | 1 + configs/A20-Olimex-SOM204-EVB-eMMC_defconfig | 1 + configs/A20-Olimex-SOM204-EVB_defconfig | 2 + configs/Auxtek-T003_defconfig | 1 + configs/Auxtek-T004_defconfig | 1 + configs/Bananapi_defconfig | 1 + configs/Bananapi_m2m_defconfig | 1 + configs/Bananapro_defconfig | 1 + configs/CHIP_defconfig | 1 + configs/CHIP_pro_defconfig | 1 + configs/CSQ_CS908_defconfig | 1 + configs/Colombus_defconfig | 1 + configs/Cubieboard2_defconfig | 1 + configs/Cubieboard_defconfig | 1 + configs/Cubietruck_plus_defconfig | 1 + configs/Hummingbird_A31_defconfig | 1 + configs/Itead_Ibox_A20_defconfig | 1 + configs/Linksprite_pcDuino3_Nano_defconfig | 1 + configs/Linksprite_pcDuino3_defconfig | 1 + configs/Linksprite_pcDuino_defconfig | 1 + configs/MK808C_defconfig | 1 + configs/Marsboard_A10_defconfig | 1 + configs/Mele_A1000G_quad_defconfig | 1 + configs/Mele_A1000_defconfig | 1 + configs/Mele_I7_defconfig | 1 + configs/Mele_M3_defconfig | 2 + configs/Mele_M5_defconfig | 1 + configs/Mele_M9_defconfig | 1 + configs/Mini-X_defconfig | 1 + configs/Orangepi_defconfig | 1 + configs/Orangepi_mini_defconfig | 2 + configs/Sinlinx_SinA31s_defconfig | 1 + configs/Sinlinx_SinA33_defconfig | 3 + configs/Sinovoip_BPI_M2_Plus_defconfig | 1 + configs/Sinovoip_BPI_M2_defconfig | 1 + configs/Sinovoip_BPI_M3_defconfig | 1 + configs/Wexler_TAB7200_defconfig | 1 + configs/Wobo_i5_defconfig | 1 + configs/Yones_Toptech_BD1078_defconfig | 1 + configs/a64-olinuxino_defconfig | 1 + configs/amarula_a64_relic_defconfig | 2 + configs/ba10_tv_box_defconfig | 1 + configs/bananapi_m1_plus_defconfig | 1 + configs/bananapi_m64_defconfig | 1 + configs/ga10h_v1_1_defconfig | 1 + configs/h8_homlet_v2_defconfig | 1 + configs/i12-tvbox_defconfig | 1 + configs/icnova-a20-swac_defconfig | 1 + configs/inet1_defconfig | 1 + configs/inet_q972_defconfig | 1 + configs/jesurun_q5_defconfig | 1 + configs/libretech_all_h3_cc_h2_plus_defconfig | 1 + configs/libretech_all_h3_cc_h3_defconfig | 1 + configs/libretech_all_h3_cc_h5_defconfig | 1 + configs/mixtile_loftq_defconfig | 1 + configs/mk802_a10s_defconfig | 1 + configs/mk802_defconfig | 1 + configs/mk802ii_defconfig | 1 + configs/nanopi_a64_defconfig | 1 + configs/nanopi_m1_defconfig | 1 + configs/nanopi_m1_plus_defconfig | 1 + configs/nanopi_neo2_defconfig | 1 + configs/nanopi_neo_air_defconfig | 1 + configs/nanopi_neo_defconfig | 1 + configs/nanopi_neo_plus2_defconfig | 1 + configs/orangepi_2_defconfig | 1 + configs/orangepi_lite_defconfig | 1 + configs/orangepi_one_defconfig | 1 + configs/orangepi_pc2_defconfig | 1 + configs/orangepi_pc_defconfig | 1 + configs/orangepi_pc_plus_defconfig | 1 + configs/orangepi_plus2e_defconfig | 1 + configs/orangepi_plus_defconfig | 1 + configs/orangepi_prime_defconfig | 1 + configs/orangepi_r1_defconfig | 1 + configs/orangepi_win_defconfig | 1 + configs/orangepi_zero_defconfig | 1 + configs/orangepi_zero_plus2_defconfig | 1 + configs/orangepi_zero_plus_defconfig | 1 + configs/parrot_r16_defconfig | 1 + configs/pine64_plus_defconfig | 1 + configs/r7-tv-dongle_defconfig | 1 + configs/sopine_baseboard_defconfig | 1 + configs/sun8i_a23_evb_defconfig | 1 + configs/sunxi_Gemei_G9_defconfig | 1 + configs/tbs_a711_defconfig | 1 + drivers/clk/Kconfig | 9 +- drivers/clk/Makefile | 1 + drivers/clk/sunxi/Kconfig | 75 +++ drivers/clk/sunxi/Makefile | 17 + drivers/clk/sunxi/clk_a10.c | 104 ++++ drivers/clk/sunxi/clk_a10s.c | 95 ++++ drivers/clk/sunxi/clk_a23.c | 105 ++++ drivers/clk/sunxi/clk_a31.c | 126 +++++ drivers/clk/sunxi/clk_a64.c | 113 +++++ drivers/clk/sunxi/clk_a83t.c | 103 ++++ drivers/clk/sunxi/clk_h3.c | 124 +++++ drivers/clk/sunxi/clk_r40.c | 119 +++++ drivers/clk/sunxi/clk_sunxi.c | 77 +++ drivers/clk/sunxi/clk_v3s.c | 91 ++++ drivers/fastboot/Kconfig | 3 +- drivers/mmc/sunxi_mmc.c | 121 +++-- drivers/phy/allwinner/phy-sun4i-usb.c | 77 ++- drivers/reset/Kconfig | 8 + drivers/reset/Makefile | 1 + drivers/reset/reset-sunxi.c | 124 +++++ drivers/reset/reset-uclass.c | 27 +- drivers/spi/Kconfig | 6 + drivers/spi/Makefile | 1 + drivers/spi/sun4i_spi.c | 40 +- drivers/spi/sun6i_spi.c | 475 ++++++++++++++++++ drivers/usb/host/Kconfig | 2 + drivers/usb/host/Makefile | 2 - drivers/usb/host/ehci-sunxi.c | 204 -------- drivers/usb/host/ohci-sunxi.c | 233 --------- drivers/usb/musb-new/sunxi.c | 82 +-- env/Kconfig | 3 +- include/configs/sun4i.h | 4 - include/configs/sun50i.h | 5 - include/configs/sun5i.h | 4 - include/configs/sun6i.h | 4 - include/configs/sun7i.h | 4 - include/configs/sun8i.h | 4 - include/configs/sunxi-common.h | 5 +- include/reset.h | 36 ++ scripts/config_whitelist.txt | 2 - 138 files changed, 2278 insertions(+), 567 deletions(-) create mode 100644 arch/arm/include/asm/arch-sunxi/ccu.h create mode 100644 drivers/clk/sunxi/Kconfig create mode 100644 drivers/clk/sunxi/Makefile create mode 100644 drivers/clk/sunxi/clk_a10.c create mode 100644 drivers/clk/sunxi/clk_a10s.c create mode 100644 drivers/clk/sunxi/clk_a23.c create mode 100644 drivers/clk/sunxi/clk_a31.c create mode 100644 drivers/clk/sunxi/clk_a64.c create mode 100644 drivers/clk/sunxi/clk_a83t.c create mode 100644 drivers/clk/sunxi/clk_h3.c create mode 100644 drivers/clk/sunxi/clk_r40.c create mode 100644 drivers/clk/sunxi/clk_sunxi.c create mode 100644 drivers/clk/sunxi/clk_v3s.c create mode 100644 drivers/reset/reset-sunxi.c create mode 100644 drivers/spi/sun6i_spi.c delete mode 100644 drivers/usb/host/ehci-sunxi.c delete mode 100644 drivers/usb/host/ohci-sunxi.c
sourcing of sub directiory kconfig files are not in proper order, so keep them in ascending order.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Joe Hershberger joe.hershberger@ni.com --- drivers/clk/Kconfig | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/clk/Kconfig b/drivers/clk/Kconfig index 18bf8a6d28..a99abed9e9 100644 --- a/drivers/clk/Kconfig +++ b/drivers/clk/Kconfig @@ -83,13 +83,13 @@ config CLK_STM32MP1 Enable the STM32 clock (RCC) driver. Enable support for manipulating STM32MP1's on-SoC clocks.
-source "drivers/clk/tegra/Kconfig" -source "drivers/clk/uniphier/Kconfig" -source "drivers/clk/exynos/Kconfig" source "drivers/clk/at91/Kconfig" -source "drivers/clk/renesas/Kconfig" +source "drivers/clk/exynos/Kconfig" source "drivers/clk/mvebu/Kconfig" source "drivers/clk/owl/Kconfig" +source "drivers/clk/renesas/Kconfig" +source "drivers/clk/tegra/Kconfig" +source "drivers/clk/uniphier/Kconfig"
config ICS8N3QV01 bool "Enable ICS8N3QV01 VCXO driver"
Add initial clock driver for Allwinner A64.
Implement USB clock enable and disable functions for OHCI, EHCI, OTG and USBPHY gate and clock registers.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/include/asm/arch-sunxi/ccu.h | 47 ++++++++++++++++++++ drivers/clk/Kconfig | 1 + drivers/clk/Makefile | 1 + drivers/clk/sunxi/Kconfig | 18 ++++++++ drivers/clk/sunxi/Makefile | 9 ++++ drivers/clk/sunxi/clk_a64.c | 62 +++++++++++++++++++++++++++ drivers/clk/sunxi/clk_sunxi.c | 58 +++++++++++++++++++++++++ 7 files changed, 196 insertions(+) create mode 100644 arch/arm/include/asm/arch-sunxi/ccu.h create mode 100644 drivers/clk/sunxi/Kconfig create mode 100644 drivers/clk/sunxi/Makefile create mode 100644 drivers/clk/sunxi/clk_a64.c create mode 100644 drivers/clk/sunxi/clk_sunxi.c
diff --git a/arch/arm/include/asm/arch-sunxi/ccu.h b/arch/arm/include/asm/arch-sunxi/ccu.h new file mode 100644 index 0000000000..f628c893de --- /dev/null +++ b/arch/arm/include/asm/arch-sunxi/ccu.h @@ -0,0 +1,47 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2018 Amarula Solutions. + * Author: Jagan Teki jagan@amarulasolutions.com + */ + +#ifndef _ASM_ARCH_CCU_H +#define _ASM_ARCH_CCU_H + +/** + * ccu_clk_map - common clock unit clock map + * + * @off: ccu clock offset + * @bit: ccu clock bit value + * @ccu_clk_set_rate: ccu clock set rate func + */ +struct ccu_clk_map { + u16 off; + u32 bit; + int (*ccu_clk_set_rate)(void *base, u32 bit, ulong rate); +}; + +/** + * struct ccu_desc - common clock unit descriptor + * + * @clks: mapping clocks descriptor + * @num_clks: number of mapped clocks + */ +struct ccu_desc { + struct ccu_clk_map *clks; + unsigned long num_clks; +}; + +/** + * struct sunxi_clk_priv - sunxi clock private structure + * + * @base: base address + * @desc: ccu descriptor + */ +struct sunxi_clk_priv { + void *base; + const struct ccu_desc *desc; +}; + +extern struct clk_ops sunxi_clk_ops; + +#endif /* _ASM_ARCH_CCU_H */ diff --git a/drivers/clk/Kconfig b/drivers/clk/Kconfig index a99abed9e9..b4992e9ff1 100644 --- a/drivers/clk/Kconfig +++ b/drivers/clk/Kconfig @@ -88,6 +88,7 @@ source "drivers/clk/exynos/Kconfig" source "drivers/clk/mvebu/Kconfig" source "drivers/clk/owl/Kconfig" source "drivers/clk/renesas/Kconfig" +source "drivers/clk/sunxi/Kconfig" source "drivers/clk/tegra/Kconfig" source "drivers/clk/uniphier/Kconfig"
diff --git a/drivers/clk/Makefile b/drivers/clk/Makefile index 146283c723..7cefcd99a0 100644 --- a/drivers/clk/Makefile +++ b/drivers/clk/Makefile @@ -11,6 +11,7 @@ obj-y += tegra/ obj-$(CONFIG_ARCH_ASPEED) += aspeed/ obj-$(CONFIG_ARCH_MESON) += clk_meson.o obj-$(CONFIG_ARCH_ROCKCHIP) += rockchip/ +obj-$(CONFIG_ARCH_SUNXI) += sunxi/ obj-$(CONFIG_CLK_AT91) += at91/ obj-$(CONFIG_CLK_MVEBU) += mvebu/ obj-$(CONFIG_CLK_BCM6345) += clk_bcm6345.o diff --git a/drivers/clk/sunxi/Kconfig b/drivers/clk/sunxi/Kconfig new file mode 100644 index 0000000000..bf5ecb3801 --- /dev/null +++ b/drivers/clk/sunxi/Kconfig @@ -0,0 +1,18 @@ +config CLK_SUNXI + bool "Clock support for Allwinner SoCs" + depends on CLK && ARCH_SUNXI + default y + help + This enables support for common clock driver API on Allwinner + SoCs. + +if CLK_SUNXI + +config CLK_SUN50I_A64 + bool "Clock driver for Allwinner A64" + default MACH_SUN50I + help + This enables common clock driver support for platforms based + on Allwinner A64 SoC. + +endif # CLK_SUNXI diff --git a/drivers/clk/sunxi/Makefile b/drivers/clk/sunxi/Makefile new file mode 100644 index 0000000000..fb20d28333 --- /dev/null +++ b/drivers/clk/sunxi/Makefile @@ -0,0 +1,9 @@ +# +# Copyright (C) 2018 Amarula Solutions. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-$(CONFIG_CLK_SUNXI) += clk_sunxi.o + +obj-$(CONFIG_CLK_SUN50I_A64) += clk_a64.o diff --git a/drivers/clk/sunxi/clk_a64.c b/drivers/clk/sunxi/clk_a64.c new file mode 100644 index 0000000000..9393a01ccf --- /dev/null +++ b/drivers/clk/sunxi/clk_a64.c @@ -0,0 +1,62 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2018 Amarula Solutions. + * Author: Jagan Teki jagan@amarulasolutions.com + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm.h> +#include <errno.h> +#include <asm/arch/ccu.h> +#include <dt-bindings/clock/sun50i-a64-ccu.h> + +static struct ccu_clk_map a64_clks[] = { + [CLK_BUS_OTG] = { 0x060, BIT(23), NULL }, + [CLK_BUS_EHCI0] = { 0x060, BIT(24), NULL }, + [CLK_BUS_EHCI1] = { 0x060, BIT(25), NULL }, + [CLK_BUS_OHCI0] = { 0x060, BIT(28), NULL }, + [CLK_BUS_OHCI1] = { 0x060, BIT(29), NULL }, + + [CLK_USB_PHY0] = { 0x0cc, BIT(8), NULL }, + [CLK_USB_PHY1] = { 0x0cc, BIT(9), NULL }, + [CLK_USB_HSIC] = { 0x0cc, BIT(10), NULL }, + [CLK_USB_HSIC_12M] = { 0x0cc, BIT(11), NULL }, + [CLK_USB_OHCI0] = { 0x0cc, BIT(16), NULL }, + [CLK_USB_OHCI1] = { 0x0cc, BIT(17), NULL }, +}; + +static const struct ccu_desc sun50i_a64_ccu_desc = { + .clks = a64_clks, + .num_clks = ARRAY_SIZE(a64_clks), +}; + +static int a64_clk_probe(struct udevice *dev) +{ + struct sunxi_clk_priv *priv = dev_get_priv(dev); + + priv->base = dev_read_addr_ptr(dev); + if (!priv->base) + return -ENOMEM; + + priv->desc = (const struct ccu_desc *)dev_get_driver_data(dev); + if (!priv->desc) + return -EINVAL; + + return 0; +} + +static const struct udevice_id a64_clk_ids[] = { + { .compatible = "allwinner,sun50i-a64-ccu", + .data = (ulong)&sun50i_a64_ccu_desc }, + { } +}; + +U_BOOT_DRIVER(clk_sun50i_a64) = { + .name = "sun50i_a64_ccu", + .id = UCLASS_CLK, + .of_match = a64_clk_ids, + .priv_auto_alloc_size = sizeof(struct sunxi_clk_priv), + .ops = &sunxi_clk_ops, + .probe = a64_clk_probe, +}; diff --git a/drivers/clk/sunxi/clk_sunxi.c b/drivers/clk/sunxi/clk_sunxi.c new file mode 100644 index 0000000000..791b1ac7f2 --- /dev/null +++ b/drivers/clk/sunxi/clk_sunxi.c @@ -0,0 +1,58 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2018 Amarula Solutions. + * Author: Jagan Teki jagan@amarulasolutions.com + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm.h> +#include <errno.h> +#include <asm/io.h> +#include <asm/arch/ccu.h> +#include <linux/log2.h> + +static int sunxi_clk_enable(struct clk *clk) +{ + struct sunxi_clk_priv *priv = dev_get_priv(clk->dev); + struct ccu_clk_map *map = &priv->desc->clks[clk->id]; + u32 reg; + + if (!map->off || !map->bit) { + debug("%s (CLK#%ld) unhandled\n", __func__, clk->id); + return 0; + } + + debug("%s(#%ld) off#0x%x, BIT(%d)\n", __func__, + clk->id, map->off, ilog2(map->bit)); + + reg = readl(priv->base + map->off); + writel(reg | map->bit, priv->base + map->off); + + return 0; +} + +static int sunxi_clk_disable(struct clk *clk) +{ + struct sunxi_clk_priv *priv = dev_get_priv(clk->dev); + struct ccu_clk_map *map = &priv->desc->clks[clk->id]; + u32 reg; + + if (!map->off || !map->bit) { + debug("%s (CLK#%ld) unhandled\n", __func__, clk->id); + return 0; + } + + debug("%s(#%ld) off#0x%x, BIT(%d)\n", __func__, + clk->id, map->off, ilog2(map->bit)); + + reg = readl(priv->base + map->off); + writel(reg & ~map->bit, priv->base + map->off); + + return 0; +} + +struct clk_ops sunxi_clk_ops = { + .enable = sunxi_clk_enable, + .disable = sunxi_clk_disable, +};
Missing request ops from respective uclass driver generating "synchronous abort" in Allwinner platform, may be in arm. So add default request ops and give a chance to uclass driver to think whether they really need request or not.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/reset/reset-uclass.c | 10 +++++++++- 1 file changed, 9 insertions(+), 1 deletion(-)
diff --git a/drivers/reset/reset-uclass.c b/drivers/reset/reset-uclass.c index 3899537635..99881b8b99 100644 --- a/drivers/reset/reset-uclass.c +++ b/drivers/reset/reset-uclass.c @@ -14,6 +14,11 @@ static inline struct reset_ops *reset_dev_ops(struct udevice *dev) return (struct reset_ops *)dev->driver->ops; }
+static int reset_request_default(struct reset_ctl *reset_ctl) +{ + return 0; +} + static int reset_of_xlate_default(struct reset_ctl *reset_ctl, struct ofnode_phandle_args *args) { @@ -69,7 +74,10 @@ int reset_get_by_index(struct udevice *dev, int index, return ret; }
- ret = ops->request(reset_ctl); + if (ops->request) + ret = ops->request(reset_ctl); + else + ret = reset_request_default(reset_ctl); if (ret) { debug("ops->request() failed: %d\n", ret); return ret;
Add common reset driver for all Allwinner SoC's.
Since CLK and RESET share common DT compatible, it is CLK driver job is to bind the reset driver. So add CLK bind call on respective SoC driver by passing ccu map descriptor so-that reset deassert, deassert operations held based on reset register map defined by CLK driver.
Select DM_RESET via CLK_SUNXI, this make hidden section of RESET since CLK and RESET share common DT compatible and code.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/include/asm/arch-sunxi/ccu.h | 25 ++++++ drivers/clk/sunxi/Kconfig | 1 + drivers/clk/sunxi/clk_a64.c | 22 +++++ drivers/reset/Kconfig | 8 ++ drivers/reset/Makefile | 1 + drivers/reset/reset-sunxi.c | 124 ++++++++++++++++++++++++++ 6 files changed, 181 insertions(+) create mode 100644 drivers/reset/reset-sunxi.c
diff --git a/arch/arm/include/asm/arch-sunxi/ccu.h b/arch/arm/include/asm/arch-sunxi/ccu.h index f628c893de..bacd052ef3 100644 --- a/arch/arm/include/asm/arch-sunxi/ccu.h +++ b/arch/arm/include/asm/arch-sunxi/ccu.h @@ -20,15 +20,31 @@ struct ccu_clk_map { int (*ccu_clk_set_rate)(void *base, u32 bit, ulong rate); };
+/** + * ccu_reset_map - common clock unit reset map + * + * @off: ccu reset offset + * @bit: ccu reset bit value + */ +struct ccu_reset_map { + u16 off; + u32 bit; +}; + /** * struct ccu_desc - common clock unit descriptor * * @clks: mapping clocks descriptor * @num_clks: number of mapped clocks + * @resets: mapping resets descriptor + * @num_resets: number of mapped resets */ struct ccu_desc { struct ccu_clk_map *clks; unsigned long num_clks; + + struct ccu_reset_map *resets; + unsigned long num_resets; };
/** @@ -44,4 +60,13 @@ struct sunxi_clk_priv {
+/** + * sunxi_reset_bind() - reset binding + * + * @dev: reset device + * @count: reset count + * @return 0 success, or error value + */ +int sunxi_reset_bind(struct udevice *dev, ulong count); + #endif /* _ASM_ARCH_CCU_H */ diff --git a/drivers/clk/sunxi/Kconfig b/drivers/clk/sunxi/Kconfig index bf5ecb3801..041d711e58 100644 --- a/drivers/clk/sunxi/Kconfig +++ b/drivers/clk/sunxi/Kconfig @@ -1,6 +1,7 @@ config CLK_SUNXI bool "Clock support for Allwinner SoCs" depends on CLK && ARCH_SUNXI + select DM_RESET default y help This enables support for common clock driver API on Allwinner diff --git a/drivers/clk/sunxi/clk_a64.c b/drivers/clk/sunxi/clk_a64.c index 9393a01ccf..890bf8ca21 100644 --- a/drivers/clk/sunxi/clk_a64.c +++ b/drivers/clk/sunxi/clk_a64.c @@ -10,6 +10,7 @@ #include <errno.h> #include <asm/arch/ccu.h> #include <dt-bindings/clock/sun50i-a64-ccu.h> +#include <dt-bindings/reset/sun50i-a64-ccu.h>
static struct ccu_clk_map a64_clks[] = { [CLK_BUS_OTG] = { 0x060, BIT(23), NULL }, @@ -26,9 +27,24 @@ static struct ccu_clk_map a64_clks[] = { [CLK_USB_OHCI1] = { 0x0cc, BIT(17), NULL }, };
+static struct ccu_reset_map a64_resets[] = { + [RST_USB_PHY0] = { 0x0cc, BIT(0) }, + [RST_USB_PHY1] = { 0x0cc, BIT(1) }, + [RST_USB_HSIC] = { 0x0cc, BIT(2) }, + + [RST_BUS_OTG] = { 0x2c0, BIT(23) }, + [RST_BUS_EHCI0] = { 0x2c0, BIT(24) }, + [RST_BUS_EHCI1] = { 0x2c0, BIT(25) }, + [RST_BUS_OHCI0] = { 0x2c0, BIT(28) }, + [RST_BUS_OHCI1] = { 0x2c0, BIT(29) }, +}; + static const struct ccu_desc sun50i_a64_ccu_desc = { .clks = a64_clks, .num_clks = ARRAY_SIZE(a64_clks), + + .resets = a64_resets, + .num_resets = ARRAY_SIZE(a64_resets), };
static int a64_clk_probe(struct udevice *dev) @@ -46,6 +62,11 @@ static int a64_clk_probe(struct udevice *dev) return 0; }
+static int a64_clk_bind(struct udevice *dev) +{ + return sunxi_reset_bind(dev, 50); +} + static const struct udevice_id a64_clk_ids[] = { { .compatible = "allwinner,sun50i-a64-ccu", .data = (ulong)&sun50i_a64_ccu_desc }, @@ -59,4 +80,5 @@ U_BOOT_DRIVER(clk_sun50i_a64) = { .priv_auto_alloc_size = sizeof(struct sunxi_clk_priv), .ops = &sunxi_clk_ops, .probe = a64_clk_probe, + .bind = a64_clk_bind, }; diff --git a/drivers/reset/Kconfig b/drivers/reset/Kconfig index 33c39b7fb6..bdc06564a0 100644 --- a/drivers/reset/Kconfig +++ b/drivers/reset/Kconfig @@ -98,4 +98,12 @@ config RESET_SOCFPGA help Support for reset controller on SoCFPGA platform.
+config RESET_SUNXI + bool "RESET support for Allwinner SoCs" + depends on DM_RESET && ARCH_SUNXI + default y + help + This enables support for common reset driver for + Allwinner SoCs. + endmenu diff --git a/drivers/reset/Makefile b/drivers/reset/Makefile index ad08be4c8c..698d15a0e0 100644 --- a/drivers/reset/Makefile +++ b/drivers/reset/Makefile @@ -15,3 +15,4 @@ obj-$(CONFIG_AST2500_RESET) += ast2500-reset.o obj-$(CONFIG_RESET_ROCKCHIP) += reset-rockchip.o obj-$(CONFIG_RESET_MESON) += reset-meson.o obj-$(CONFIG_RESET_SOCFPGA) += reset-socfpga.o +obj-$(CONFIG_RESET_SUNXI) += reset-sunxi.o diff --git a/drivers/reset/reset-sunxi.c b/drivers/reset/reset-sunxi.c new file mode 100644 index 0000000000..c0abe41bec --- /dev/null +++ b/drivers/reset/reset-sunxi.c @@ -0,0 +1,124 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2018 Amarula Solutions. + * Author: Jagan Teki jagan@amarulasolutions.com + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <reset-uclass.h> +#include <asm/io.h> +#include <dm/lists.h> +#include <linux/log2.h> +#include <asm/arch/ccu.h> + +struct sunxi_reset_priv { + void *base; + ulong count; + const struct ccu_desc *desc; +}; + +static int sunxi_reset_request(struct reset_ctl *reset_ctl) +{ + struct sunxi_reset_priv *priv = dev_get_priv(reset_ctl->dev); + + debug("%s (RST#%ld)\n", __func__, reset_ctl->id); + + /* check dt-bindings/reset/sun8i-h3-ccu.h for max id */ + if (reset_ctl->id >= priv->count) + return -EINVAL; + + return 0; +} + +static int sunxi_reset_free(struct reset_ctl *reset_ctl) +{ + debug("%s (RST#%ld)\n", __func__, reset_ctl->id); + + return 0; +} + +static int sunxi_reset_assert(struct reset_ctl *reset_ctl) +{ + struct sunxi_reset_priv *priv = dev_get_priv(reset_ctl->dev); + struct ccu_reset_map *map = &priv->desc->resets[reset_ctl->id]; + u32 reg; + + if (!map->off || !map->bit) { + debug("%s (RST#%ld) unhandled\n", __func__, reset_ctl->id); + return 0; + } + + debug("%s(#%ld) off#0x%x, BIT(%d)\n", __func__, + reset_ctl->id, map->off, ilog2(map->bit)); + + reg = readl(priv->base + map->off); + writel(reg & ~map->bit, priv->base + map->off); + + return 0; +} + +static int sunxi_reset_deassert(struct reset_ctl *reset_ctl) +{ + struct sunxi_reset_priv *priv = dev_get_priv(reset_ctl->dev); + struct ccu_reset_map *map = &priv->desc->resets[reset_ctl->id]; + u32 reg; + + if (!map->off || !map->bit) { + debug("%s (RST#%ld) unhandled\n", __func__, reset_ctl->id); + return 0; + } + + debug("%s(#%ld) off#0x%x, BIT(%d)\n", __func__, + reset_ctl->id, map->off, ilog2(map->bit)); + + reg = readl(priv->base + map->off); + writel(reg | map->bit, priv->base + map->off); + + return 0; +} + +struct reset_ops sunxi_reset_ops = { + .request = sunxi_reset_request, + .free = sunxi_reset_free, + .rst_assert = sunxi_reset_assert, + .rst_deassert = sunxi_reset_deassert, +}; + +static int sunxi_reset_probe(struct udevice *dev) +{ + struct sunxi_reset_priv *priv = dev_get_priv(dev); + + priv->base = dev_read_addr_ptr(dev); + + return 0; +} + +int sunxi_reset_bind(struct udevice *dev, ulong count) +{ + struct udevice *rst_dev; + struct sunxi_reset_priv *priv; + int ret; + + ret = device_bind_driver_to_node(dev, "sunxi_reset", "reset", + dev_ofnode(dev), &rst_dev); + if (ret) { + debug("Warning: failed to bind sunxi_reset driver: ret=%d\n", ret); + return ret; + } + priv = malloc(sizeof(struct sunxi_reset_priv)); + priv->count = count; + priv->desc = (const struct ccu_desc *)dev_get_driver_data(dev); + rst_dev->priv = priv; + + return 0; +} + +U_BOOT_DRIVER(reset_sun8i_h3) = { + .name = "sunxi_reset", + .id = UCLASS_RESET, + .ops = &sunxi_reset_ops, + .probe = sunxi_reset_probe, + .priv_auto_alloc_size = sizeof(struct sunxi_reset_priv), +};
Add initial clock driver for Allwinner H3/H5.
- Implement USB bus and USB clocks via ccu_clk_map descriptor for H3/H5, so it can accessed in common clk enable and disable functions from clk_sunxi.c - Implement USB bus and USB resets via ccu_reset_map descriptor for H3/H5, so it can accessed in common reset deassert and assert functions from reset-sunxi.c
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/clk/sunxi/Kconfig | 7 +++ drivers/clk/sunxi/Makefile | 1 + drivers/clk/sunxi/clk_h3.c | 97 ++++++++++++++++++++++++++++++++++++++ 3 files changed, 105 insertions(+) create mode 100644 drivers/clk/sunxi/clk_h3.c
diff --git a/drivers/clk/sunxi/Kconfig b/drivers/clk/sunxi/Kconfig index 041d711e58..c3713bbac2 100644 --- a/drivers/clk/sunxi/Kconfig +++ b/drivers/clk/sunxi/Kconfig @@ -9,6 +9,13 @@ config CLK_SUNXI
if CLK_SUNXI
+config CLK_SUN8I_H3 + bool "Clock driver for Allwinner H3/H5" + default MACH_SUNXI_H3_H5 + help + This enables common clock driver support for platforms based + on Allwinner H3/H5 SoC. + config CLK_SUN50I_A64 bool "Clock driver for Allwinner A64" default MACH_SUN50I diff --git a/drivers/clk/sunxi/Makefile b/drivers/clk/sunxi/Makefile index fb20d28333..dec49f27a1 100644 --- a/drivers/clk/sunxi/Makefile +++ b/drivers/clk/sunxi/Makefile @@ -6,4 +6,5 @@
+obj-$(CONFIG_CLK_SUN8I_H3) += clk_h3.o obj-$(CONFIG_CLK_SUN50I_A64) += clk_a64.o diff --git a/drivers/clk/sunxi/clk_h3.c b/drivers/clk/sunxi/clk_h3.c new file mode 100644 index 0000000000..96bf2f4fa9 --- /dev/null +++ b/drivers/clk/sunxi/clk_h3.c @@ -0,0 +1,97 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2018 Amarula Solutions. + * Author: Jagan Teki jagan@amarulasolutions.com + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm.h> +#include <errno.h> +#include <asm/arch/ccu.h> +#include <dt-bindings/clock/sun8i-h3-ccu.h> +#include <dt-bindings/reset/sun8i-h3-ccu.h> + +static struct ccu_clk_map h3_clks[] = { + [CLK_BUS_OTG] = { 0x060, BIT(23), NULL }, + [CLK_BUS_EHCI0] = { 0x060, BIT(24), NULL }, + [CLK_BUS_EHCI1] = { 0x060, BIT(25), NULL }, + [CLK_BUS_EHCI2] = { 0x060, BIT(26), NULL }, + [CLK_BUS_EHCI3] = { 0x060, BIT(27), NULL }, + [CLK_BUS_OHCI0] = { 0x060, BIT(28), NULL }, + [CLK_BUS_OHCI1] = { 0x060, BIT(29), NULL }, + [CLK_BUS_OHCI2] = { 0x060, BIT(30), NULL }, + [CLK_BUS_OHCI3] = { 0x060, BIT(31), NULL }, + + [CLK_USB_PHY0] = { 0x0cc, BIT(8), NULL }, + [CLK_USB_PHY1] = { 0x0cc, BIT(9), NULL }, + [CLK_USB_PHY2] = { 0x0cc, BIT(10), NULL }, + [CLK_USB_PHY3] = { 0x0cc, BIT(11), NULL }, + [CLK_USB_OHCI0] = { 0x0cc, BIT(16), NULL }, + [CLK_USB_OHCI1] = { 0x0cc, BIT(17), NULL }, + [CLK_USB_OHCI2] = { 0x0cc, BIT(18), NULL }, + [CLK_USB_OHCI3] = { 0x0cc, BIT(19), NULL }, +}; + +static struct ccu_reset_map h3_resets[] = { + [RST_USB_PHY0] = { 0x0cc, BIT(0) }, + [RST_USB_PHY1] = { 0x0cc, BIT(1) }, + [RST_USB_PHY2] = { 0x0cc, BIT(2) }, + [RST_USB_PHY3] = { 0x0cc, BIT(3) }, + + [RST_BUS_OTG] = { 0x2c0, BIT(23) }, + [RST_BUS_EHCI0] = { 0x2c0, BIT(24) }, + [RST_BUS_EHCI1] = { 0x2c0, BIT(25) }, + [RST_BUS_EHCI2] = { 0x2c0, BIT(26) }, + [RST_BUS_EHCI3] = { 0x2c0, BIT(27) }, + [RST_BUS_OHCI0] = { 0x2c0, BIT(28) }, + [RST_BUS_OHCI1] = { 0x2c0, BIT(29) }, + [RST_BUS_OHCI2] = { 0x2c0, BIT(30) }, + [RST_BUS_OHCI3] = { 0x2c0, BIT(31) }, +}; + +static const struct ccu_desc sun8i_h3_ccu_desc = { + .clks = h3_clks, + .num_clks = ARRAY_SIZE(h3_clks), + + .resets = h3_resets, + .num_resets = ARRAY_SIZE(h3_resets), +}; + +static int h3_clk_probe(struct udevice *dev) +{ + struct sunxi_clk_priv *priv = dev_get_priv(dev); + + priv->base = dev_read_addr_ptr(dev); + if (!priv->base) + return -ENOMEM; + + priv->desc = (const struct ccu_desc *)dev_get_driver_data(dev); + if (!priv->desc) + return -EINVAL; + + return 0; +} + +static int h3_clk_bind(struct udevice *dev) +{ + return sunxi_reset_bind(dev, 53); +} + +static const struct udevice_id h3_clk_ids[] = { + { .compatible = "allwinner,sun8i-h3-ccu", + .data = (ulong)&sun8i_h3_ccu_desc }, + { .compatible = "allwinner,sun50i-h5-ccu", + .data = (ulong)&sun8i_h3_ccu_desc }, + { } +}; + +U_BOOT_DRIVER(clk_sun8i_h3) = { + .name = "sun8i_h3_ccu", + .id = UCLASS_CLK, + .of_match = h3_clk_ids, + .priv_auto_alloc_size = sizeof(struct sunxi_clk_priv), + .ops = &sunxi_clk_ops, + .probe = h3_clk_probe, + .bind = h3_clk_bind, +};
Add initial clock driver for Allwinner A10/A20.
- Implement USB ahb and USB clocks via ccu_clk_map descriptor for A10/A20, so it can accessed in common clk enable and disable functions from clk_sunxi.c - Implement USB resets via ccu_reset_map descriptor for A10/A20, so it can accessed in common reset deassert and assert functions from reset-sunxi.c
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/clk/sunxi/Kconfig | 7 ++++ drivers/clk/sunxi/Makefile | 1 + drivers/clk/sunxi/clk_a10.c | 77 +++++++++++++++++++++++++++++++++++++ 3 files changed, 85 insertions(+) create mode 100644 drivers/clk/sunxi/clk_a10.c
diff --git a/drivers/clk/sunxi/Kconfig b/drivers/clk/sunxi/Kconfig index c3713bbac2..fbbf94ef55 100644 --- a/drivers/clk/sunxi/Kconfig +++ b/drivers/clk/sunxi/Kconfig @@ -9,6 +9,13 @@ config CLK_SUNXI
if CLK_SUNXI
+config CLK_SUN4I_A10 + bool "Clock driver for Allwinner A10/A20" + default MACH_SUN4I || MACH_SUN7I + help + This enables common clock driver support for platforms based + on Allwinner A10/A20 SoC. + config CLK_SUN8I_H3 bool "Clock driver for Allwinner H3/H5" default MACH_SUNXI_H3_H5 diff --git a/drivers/clk/sunxi/Makefile b/drivers/clk/sunxi/Makefile index dec49f27a1..bba830922f 100644 --- a/drivers/clk/sunxi/Makefile +++ b/drivers/clk/sunxi/Makefile @@ -6,5 +6,6 @@
+obj-$(CONFIG_CLK_SUN4I_A10) += clk_a10.o obj-$(CONFIG_CLK_SUN8I_H3) += clk_h3.o obj-$(CONFIG_CLK_SUN50I_A64) += clk_a64.o diff --git a/drivers/clk/sunxi/clk_a10.c b/drivers/clk/sunxi/clk_a10.c new file mode 100644 index 0000000000..7492e1367a --- /dev/null +++ b/drivers/clk/sunxi/clk_a10.c @@ -0,0 +1,77 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2018 Amarula Solutions. + * Author: Jagan Teki jagan@amarulasolutions.com + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm.h> +#include <errno.h> +#include <asm/arch/ccu.h> +#include <dt-bindings/clock/sun4i-a10-ccu.h> +#include <dt-bindings/reset/sun4i-a10-ccu.h> + +static struct ccu_clk_map a10_clks[] = { + [CLK_AHB_OTG] = { 0x060, BIT(0), NULL }, + [CLK_AHB_EHCI0] = { 0x060, BIT(1), NULL }, + [CLK_AHB_OHCI0] = { 0x060, BIT(2), NULL }, + [CLK_AHB_EHCI1] = { 0x060, BIT(3), NULL }, + [CLK_AHB_OHCI1] = { 0x060, BIT(4), NULL }, + + [CLK_USB_OHCI0] = { 0x0cc, BIT(6), NULL }, + [CLK_USB_OHCI1] = { 0x0cc, BIT(7), NULL }, + [CLK_USB_PHY] = { 0x0cc, BIT(8), NULL }, +}; + +static struct ccu_reset_map a10_resets[] = { + [RST_USB_PHY0] = { 0x0cc, BIT(0) }, + [RST_USB_PHY1] = { 0x0cc, BIT(1) }, + [RST_USB_PHY2] = { 0x0cc, BIT(2) }, +}; + +static const struct ccu_desc sun4i_a10_ccu_desc = { + .clks = a10_clks, + .num_clks = ARRAY_SIZE(a10_clks), + + .resets = a10_resets, + .num_resets = ARRAY_SIZE(a10_resets), +}; + +static int a10_clk_probe(struct udevice *dev) +{ + struct sunxi_clk_priv *priv = dev_get_priv(dev); + + priv->base = dev_read_addr_ptr(dev); + if (!priv->base) + return -ENOMEM; + + priv->desc = (const struct ccu_desc *)dev_get_driver_data(dev); + if (!priv->desc) + return -EINVAL; + + return 0; +} + +static int a10_clk_bind(struct udevice *dev) +{ + return sunxi_reset_bind(dev, 22); +} + +static const struct udevice_id a10_clk_ids[] = { + { .compatible = "allwinner,sun4i-a10-ccu", + .data = (ulong)&sun4i_a10_ccu_desc }, + { .compatible = "allwinner,sun7i-a20-ccu", + .data = (ulong)&sun4i_a10_ccu_desc }, + { } +}; + +U_BOOT_DRIVER(clk_sun4i_a10) = { + .name = "sun4i_a10_ccu", + .id = UCLASS_CLK, + .of_match = a10_clk_ids, + .priv_auto_alloc_size = sizeof(struct sunxi_clk_priv), + .ops = &sunxi_clk_ops, + .probe = a10_clk_probe, + .bind = a10_clk_bind, +};
Add initial clock driver for Allwinner A10s/A13.
- Implement USB ahb and USB clocks via ccu_clk_map descriptor for A10s/A13, so it can accessed in common clk enable and disable functions from clk_sunxi.c - Implement USB resets via ccu_reset_map descriptor for A10s/A13, so it can accessed in common reset deassert and assert functions from reset-sunxi.c
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/clk/sunxi/Kconfig | 7 ++++ drivers/clk/sunxi/Makefile | 1 + drivers/clk/sunxi/clk_a10s.c | 74 ++++++++++++++++++++++++++++++++++++ 3 files changed, 82 insertions(+) create mode 100644 drivers/clk/sunxi/clk_a10s.c
diff --git a/drivers/clk/sunxi/Kconfig b/drivers/clk/sunxi/Kconfig index fbbf94ef55..b228c2fa3a 100644 --- a/drivers/clk/sunxi/Kconfig +++ b/drivers/clk/sunxi/Kconfig @@ -16,6 +16,13 @@ config CLK_SUN4I_A10 This enables common clock driver support for platforms based on Allwinner A10/A20 SoC.
+config CLK_SUN5I_A10S + bool "Clock driver for Allwinner A10s/A13" + default MACH_SUN5I + help + This enables common clock driver support for platforms based + on Allwinner A10s/A13 SoC. + config CLK_SUN8I_H3 bool "Clock driver for Allwinner H3/H5" default MACH_SUNXI_H3_H5 diff --git a/drivers/clk/sunxi/Makefile b/drivers/clk/sunxi/Makefile index bba830922f..466d4b79d6 100644 --- a/drivers/clk/sunxi/Makefile +++ b/drivers/clk/sunxi/Makefile @@ -7,5 +7,6 @@ obj-$(CONFIG_CLK_SUNXI) += clk_sunxi.o
obj-$(CONFIG_CLK_SUN4I_A10) += clk_a10.o +obj-$(CONFIG_CLK_SUN5I_A10S) += clk_a10s.o obj-$(CONFIG_CLK_SUN8I_H3) += clk_h3.o obj-$(CONFIG_CLK_SUN50I_A64) += clk_a64.o diff --git a/drivers/clk/sunxi/clk_a10s.c b/drivers/clk/sunxi/clk_a10s.c new file mode 100644 index 0000000000..45ef10d7a5 --- /dev/null +++ b/drivers/clk/sunxi/clk_a10s.c @@ -0,0 +1,74 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2018 Amarula Solutions. + * Author: Jagan Teki jagan@amarulasolutions.com + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm.h> +#include <errno.h> +#include <asm/arch/ccu.h> +#include <dt-bindings/clock/sun5i-ccu.h> +#include <dt-bindings/reset/sun5i-ccu.h> + +static struct ccu_clk_map a10s_clks[] = { + [CLK_AHB_OTG] = { 0x060, BIT(0), NULL }, + [CLK_AHB_EHCI] = { 0x060, BIT(1), NULL }, + [CLK_AHB_OHCI] = { 0x060, BIT(2), NULL }, + + [CLK_USB_OHCI] = { 0x0cc, BIT(6), NULL }, + [CLK_USB_PHY0] = { 0x0cc, BIT(8), NULL }, + [CLK_USB_PHY1] = { 0x0cc, BIT(9), NULL }, +}; + +static struct ccu_reset_map a10s_resets[] = { + [RST_USB_PHY0] = { 0x0cc, BIT(0) }, + [RST_USB_PHY1] = { 0x0cc, BIT(1) }, +}; + +static const struct ccu_desc sun5i_a10s_ccu_desc = { + .clks = a10s_clks, + .num_clks = ARRAY_SIZE(a10s_clks), + + .resets = a10s_resets, + .num_resets = ARRAY_SIZE(a10s_resets), +}; + +static int a10s_clk_probe(struct udevice *dev) +{ + struct sunxi_clk_priv *priv = dev_get_priv(dev); + + priv->base = dev_read_addr_ptr(dev); + if (!priv->base) + return -ENOMEM; + + priv->desc = (const struct ccu_desc *)dev_get_driver_data(dev); + if (!priv->desc) + return -EINVAL; + + return 0; +} + +static int a10s_clk_bind(struct udevice *dev) +{ + return sunxi_reset_bind(dev, 10); +} + +static const struct udevice_id a10s_clk_ids[] = { + { .compatible = "allwinner,sun5i-a10s-ccu", + .data = (ulong)&sun5i_a10s_ccu_desc }, + { .compatible = "allwinner,sun5i-a13-ccu", + .data = (ulong)&sun5i_a10s_ccu_desc }, + { } +}; + +U_BOOT_DRIVER(clk_sun5i_a10s) = { + .name = "sun5i_a10s_ccu", + .id = UCLASS_CLK, + .of_match = a10s_clk_ids, + .priv_auto_alloc_size = sizeof(struct sunxi_clk_priv), + .ops = &sunxi_clk_ops, + .probe = a10s_clk_probe, + .bind = a10s_clk_bind, +};
Add initial clock driver for Allwinner A31.
- Implement USB ahb1 and USB clocks via ccu_clk_map descriptor for A31, so it can accessed in common clk enable and disable functions from clk_sunxi.c - Implement USB ahb1 and USB resets via ccu_reset_map descriptor for A31, so it can accessed in common reset deassert and assert functions from reset-sunxi.c
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/clk/sunxi/Kconfig | 7 +++ drivers/clk/sunxi/Makefile | 1 + drivers/clk/sunxi/clk_a31.c | 86 +++++++++++++++++++++++++++++++++++++ 3 files changed, 94 insertions(+) create mode 100644 drivers/clk/sunxi/clk_a31.c
diff --git a/drivers/clk/sunxi/Kconfig b/drivers/clk/sunxi/Kconfig index b228c2fa3a..535b0dc02c 100644 --- a/drivers/clk/sunxi/Kconfig +++ b/drivers/clk/sunxi/Kconfig @@ -23,6 +23,13 @@ config CLK_SUN5I_A10S This enables common clock driver support for platforms based on Allwinner A10s/A13 SoC.
+config CLK_SUN6I_A31 + bool "Clock driver for Allwinner A31/A31s" + default MACH_SUN6I + help + This enables common clock driver support for platforms based + on Allwinner A31/A31s SoC. + config CLK_SUN8I_H3 bool "Clock driver for Allwinner H3/H5" default MACH_SUNXI_H3_H5 diff --git a/drivers/clk/sunxi/Makefile b/drivers/clk/sunxi/Makefile index 466d4b79d6..3cf0071b0c 100644 --- a/drivers/clk/sunxi/Makefile +++ b/drivers/clk/sunxi/Makefile @@ -8,5 +8,6 @@ obj-$(CONFIG_CLK_SUNXI) += clk_sunxi.o
obj-$(CONFIG_CLK_SUN4I_A10) += clk_a10.o obj-$(CONFIG_CLK_SUN5I_A10S) += clk_a10s.o +obj-$(CONFIG_CLK_SUN6I_A31) += clk_a31.o obj-$(CONFIG_CLK_SUN8I_H3) += clk_h3.o obj-$(CONFIG_CLK_SUN50I_A64) += clk_a64.o diff --git a/drivers/clk/sunxi/clk_a31.c b/drivers/clk/sunxi/clk_a31.c new file mode 100644 index 0000000000..c6d82be120 --- /dev/null +++ b/drivers/clk/sunxi/clk_a31.c @@ -0,0 +1,86 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2018 Amarula Solutions B.V. + * Author: Jagan Teki jagan@amarulasolutions.com + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm.h> +#include <errno.h> +#include <asm/arch/ccu.h> +#include <dt-bindings/clock/sun6i-a31-ccu.h> +#include <dt-bindings/reset/sun6i-a31-ccu.h> + +static struct ccu_clk_map a31_clks[] = { + [CLK_AHB1_OTG] = { 0x060, BIT(24), NULL }, + [CLK_AHB1_EHCI0] = { 0x060, BIT(26), NULL }, + [CLK_AHB1_EHCI1] = { 0x060, BIT(27), NULL }, + [CLK_AHB1_OHCI0] = { 0x060, BIT(29), NULL }, + [CLK_AHB1_OHCI1] = { 0x060, BIT(30), NULL }, + [CLK_AHB1_OHCI2] = { 0x060, BIT(31), NULL }, + + [CLK_USB_PHY0] = { 0x0cc, BIT(8), NULL }, + [CLK_USB_PHY1] = { 0x0cc, BIT(9), NULL }, + [CLK_USB_PHY2] = { 0x0cc, BIT(10), NULL }, + [CLK_USB_OHCI0] = { 0x0cc, BIT(16), NULL }, + [CLK_USB_OHCI1] = { 0x0cc, BIT(17), NULL }, + [CLK_USB_OHCI2] = { 0x0cc, BIT(18), NULL }, +}; + +static struct ccu_reset_map a31_resets[] = { + [RST_USB_PHY0] = { 0x0cc, BIT(0) }, + [RST_USB_PHY1] = { 0x0cc, BIT(1) }, + [RST_USB_PHY2] = { 0x0cc, BIT(2) }, + + [RST_AHB1_OTG] = { 0x2c0, BIT(24) }, + [RST_AHB1_EHCI0] = { 0x2c0, BIT(26) }, + [RST_AHB1_EHCI1] = { 0x2c0, BIT(27) }, + [RST_AHB1_OHCI0] = { 0x2c0, BIT(29) }, + [RST_AHB1_OHCI1] = { 0x2c0, BIT(30) }, + [RST_AHB1_OHCI2] = { 0x2c0, BIT(31) }, +}; + +static const struct ccu_desc sun6i_a31_ccu_desc = { + .clks = a31_clks, + .num_clks = ARRAY_SIZE(a31_clks), + + .resets = a31_resets, + .num_resets = ARRAY_SIZE(a31_resets), +}; + +static int a31_clk_probe(struct udevice *dev) +{ + struct sunxi_clk_priv *priv = dev_get_priv(dev); + + priv->base = dev_read_addr_ptr(dev); + if (!priv->base) + return -ENOMEM; + + priv->desc = (const struct ccu_desc *)dev_get_driver_data(dev); + if (!priv->desc) + return -EINVAL; + + return 0; +} + +static int a31_clk_bind(struct udevice *dev) +{ + return sunxi_reset_bind(dev, 56); +} + +static const struct udevice_id a31_clk_ids[] = { + { .compatible = "allwinner,sun6i-a31-ccu", + .data = (ulong)&sun6i_a31_ccu_desc }, + { } +}; + +U_BOOT_DRIVER(clk_sun6i_a31) = { + .name = "sun6i_a31_ccu", + .id = UCLASS_CLK, + .of_match = a31_clk_ids, + .priv_auto_alloc_size = sizeof(struct sunxi_clk_priv), + .ops = &sunxi_clk_ops, + .probe = a31_clk_probe, + .bind = a31_clk_bind, +};
Add initial clock driver for Allwinner A23.
- Implement USB bus and USB clocks via ccu_clk_map descriptor for A23, so it can accessed in common clk enable and disable functions from clk_sunxi.c - Implement USB bus and USB resets via ccu_reset_map descriptor for A23, so it can accessed in common reset deassert and assert functions from reset-sunxi.c
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/clk/sunxi/Kconfig | 7 ++++ drivers/clk/sunxi/Makefile | 1 + drivers/clk/sunxi/clk_a23.c | 79 +++++++++++++++++++++++++++++++++++++ 3 files changed, 87 insertions(+) create mode 100644 drivers/clk/sunxi/clk_a23.c
diff --git a/drivers/clk/sunxi/Kconfig b/drivers/clk/sunxi/Kconfig index 535b0dc02c..54600e8e1f 100644 --- a/drivers/clk/sunxi/Kconfig +++ b/drivers/clk/sunxi/Kconfig @@ -30,6 +30,13 @@ config CLK_SUN6I_A31 This enables common clock driver support for platforms based on Allwinner A31/A31s SoC.
+config CLK_SUN8I_A23 + bool "Clock driver for Allwinner A23" + default MACH_SUN8I_A23 + help + This enables common clock driver support for platforms based + on Allwinner A23 SoC. + config CLK_SUN8I_H3 bool "Clock driver for Allwinner H3/H5" default MACH_SUNXI_H3_H5 diff --git a/drivers/clk/sunxi/Makefile b/drivers/clk/sunxi/Makefile index 3cf0071b0c..6924897036 100644 --- a/drivers/clk/sunxi/Makefile +++ b/drivers/clk/sunxi/Makefile @@ -9,5 +9,6 @@ obj-$(CONFIG_CLK_SUNXI) += clk_sunxi.o obj-$(CONFIG_CLK_SUN4I_A10) += clk_a10.o obj-$(CONFIG_CLK_SUN5I_A10S) += clk_a10s.o obj-$(CONFIG_CLK_SUN6I_A31) += clk_a31.o +obj-$(CONFIG_CLK_SUN8I_A23) += clk_a23.o obj-$(CONFIG_CLK_SUN8I_H3) += clk_h3.o obj-$(CONFIG_CLK_SUN50I_A64) += clk_a64.o diff --git a/drivers/clk/sunxi/clk_a23.c b/drivers/clk/sunxi/clk_a23.c new file mode 100644 index 0000000000..8cd9d3a4bc --- /dev/null +++ b/drivers/clk/sunxi/clk_a23.c @@ -0,0 +1,79 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2018 Amarula Solutions B.V. + * Author: Jagan Teki jagan@amarulasolutions.com + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm.h> +#include <errno.h> +#include <asm/arch/ccu.h> +#include <dt-bindings/clock/sun8i-a23-a33-ccu.h> +#include <dt-bindings/reset/sun8i-a23-a33-ccu.h> + +static struct ccu_clk_map a23_clks[] = { + [CLK_BUS_OTG] = { 0x060, BIT(24), NULL }, + [CLK_BUS_EHCI] = { 0x060, BIT(26), NULL }, + [CLK_BUS_OHCI] = { 0x060, BIT(29), NULL }, + + [CLK_USB_PHY0] = { 0x0cc, BIT(8), NULL }, + [CLK_USB_PHY1] = { 0x0cc, BIT(9), NULL }, + [CLK_USB_HSIC] = { 0x0cc, BIT(10), NULL }, + [CLK_USB_HSIC_12M] = { 0x0cc, BIT(11), NULL }, + [CLK_USB_OHCI] = { 0x0cc, BIT(16), NULL }, +}; + +static struct ccu_reset_map a23_resets[] = { + [RST_USB_PHY0] = { 0x0cc, BIT(0) }, + [RST_USB_PHY1] = { 0x0cc, BIT(1) }, + [RST_USB_HSIC] = { 0x0cc, BIT(2) }, + + [RST_BUS_OTG] = { 0x2c0, BIT(24) }, + [RST_BUS_EHCI] = { 0x2c0, BIT(26) }, + [RST_BUS_OHCI] = { 0x2c0, BIT(29) }, +}; + +static const struct ccu_desc sun8i_a23_ccu_desc = { + .clks = a23_clks, + .num_clks = ARRAY_SIZE(a23_clks), + + .resets = a23_resets, + .num_resets = ARRAY_SIZE(a23_resets), +}; + +static int a23_clk_probe(struct udevice *dev) +{ + struct sunxi_clk_priv *priv = dev_get_priv(dev); + + priv->base = dev_read_addr_ptr(dev); + if (!priv->base) + return -ENOMEM; + + priv->desc = (const struct ccu_desc *)dev_get_driver_data(dev); + if (!priv->desc) + return -EINVAL; + + return 0; +} + +static int a23_clk_bind(struct udevice *dev) +{ + return sunxi_reset_bind(dev, 39); +} + +static const struct udevice_id a23_clk_ids[] = { + { .compatible = "allwinner,sun8i-a23-ccu", + .data = (ulong)&sun8i_a23_ccu_desc }, + { } +}; + +U_BOOT_DRIVER(clk_sun8i_a23) = { + .name = "sun8i_a23_ccu", + .id = UCLASS_CLK, + .of_match = a23_clk_ids, + .priv_auto_alloc_size = sizeof(struct sunxi_clk_priv), + .ops = &sunxi_clk_ops, + .probe = a23_clk_probe, + .bind = a23_clk_bind, +};
A33 has separate clock driver in Linux because of few clock differences wrt to A23 like audio etc,. these may not useful for U-Boot so added a33 ccu compatible on existing a23 clock driver.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/clk/sunxi/Kconfig | 6 +++--- drivers/clk/sunxi/clk_a23.c | 2 ++ 2 files changed, 5 insertions(+), 3 deletions(-)
diff --git a/drivers/clk/sunxi/Kconfig b/drivers/clk/sunxi/Kconfig index 54600e8e1f..38ff99d345 100644 --- a/drivers/clk/sunxi/Kconfig +++ b/drivers/clk/sunxi/Kconfig @@ -31,11 +31,11 @@ config CLK_SUN6I_A31 on Allwinner A31/A31s SoC.
config CLK_SUN8I_A23 - bool "Clock driver for Allwinner A23" - default MACH_SUN8I_A23 + bool "Clock driver for Allwinner A23/A33" + default MACH_SUN8I_A23 || MACH_SUN8I_A33 help This enables common clock driver support for platforms based - on Allwinner A23 SoC. + on Allwinner A23/A33 SoC.
config CLK_SUN8I_H3 bool "Clock driver for Allwinner H3/H5" diff --git a/drivers/clk/sunxi/clk_a23.c b/drivers/clk/sunxi/clk_a23.c index 8cd9d3a4bc..424e065a66 100644 --- a/drivers/clk/sunxi/clk_a23.c +++ b/drivers/clk/sunxi/clk_a23.c @@ -65,6 +65,8 @@ static int a23_clk_bind(struct udevice *dev) static const struct udevice_id a23_clk_ids[] = { { .compatible = "allwinner,sun8i-a23-ccu", .data = (ulong)&sun8i_a23_ccu_desc }, + { .compatible = "allwinner,sun8i-a33-ccu", + .data = (ulong)&sun8i_a23_ccu_desc }, { } };
Add initial clock driver for Allwinner A83T.
- Implement USB bus and USB clocks via ccu_clk_map descriptor for A83T, so it can accessed in common clk enable and disable functions from clk_sunxi.c - Implement USB bus and USB resets via ccu_reset_map descriptor for A83T, so it can accessed in common reset deassert and assert functions from reset-sunxi.c
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/clk/sunxi/Kconfig | 7 ++++ drivers/clk/sunxi/Makefile | 1 + drivers/clk/sunxi/clk_a83t.c | 81 ++++++++++++++++++++++++++++++++++++ 3 files changed, 89 insertions(+) create mode 100644 drivers/clk/sunxi/clk_a83t.c
diff --git a/drivers/clk/sunxi/Kconfig b/drivers/clk/sunxi/Kconfig index 38ff99d345..90af70d171 100644 --- a/drivers/clk/sunxi/Kconfig +++ b/drivers/clk/sunxi/Kconfig @@ -37,6 +37,13 @@ config CLK_SUN8I_A23 This enables common clock driver support for platforms based on Allwinner A23/A33 SoC.
+config CLK_SUN8I_A83T + bool "Clock driver for Allwinner A83T" + default MACH_SUN8I_A83T + help + This enables common clock driver support for platforms based + on Allwinner A83T SoC. + config CLK_SUN8I_H3 bool "Clock driver for Allwinner H3/H5" default MACH_SUNXI_H3_H5 diff --git a/drivers/clk/sunxi/Makefile b/drivers/clk/sunxi/Makefile index 6924897036..4a254c8671 100644 --- a/drivers/clk/sunxi/Makefile +++ b/drivers/clk/sunxi/Makefile @@ -10,5 +10,6 @@ obj-$(CONFIG_CLK_SUN4I_A10) += clk_a10.o obj-$(CONFIG_CLK_SUN5I_A10S) += clk_a10s.o obj-$(CONFIG_CLK_SUN6I_A31) += clk_a31.o obj-$(CONFIG_CLK_SUN8I_A23) += clk_a23.o +obj-$(CONFIG_CLK_SUN8I_A83T) += clk_a83t.o obj-$(CONFIG_CLK_SUN8I_H3) += clk_h3.o obj-$(CONFIG_CLK_SUN50I_A64) += clk_a64.o diff --git a/drivers/clk/sunxi/clk_a83t.c b/drivers/clk/sunxi/clk_a83t.c new file mode 100644 index 0000000000..58d28eb6ad --- /dev/null +++ b/drivers/clk/sunxi/clk_a83t.c @@ -0,0 +1,81 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2018 Amarula Solutions. + * Author: Jagan Teki jagan@amarulasolutions.com + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm.h> +#include <errno.h> +#include <asm/arch/ccu.h> +#include <dt-bindings/clock/sun8i-a83t-ccu.h> +#include <dt-bindings/reset/sun8i-a83t-ccu.h> + +static struct ccu_clk_map a83t_clks[] = { + [CLK_BUS_OTG] = { 0x060, BIT(24), NULL }, + [CLK_BUS_EHCI0] = { 0x060, BIT(26), NULL }, + [CLK_BUS_EHCI1] = { 0x060, BIT(27), NULL }, + [CLK_BUS_OHCI0] = { 0x060, BIT(29), NULL }, + + [CLK_USB_PHY0] = { 0x0cc, BIT(8), NULL }, + [CLK_USB_PHY1] = { 0x0cc, BIT(9), NULL }, + [CLK_USB_HSIC] = { 0x0cc, BIT(10), NULL }, + [CLK_USB_HSIC_12M] = { 0x0cc, BIT(11), NULL }, + [CLK_USB_OHCI0] = { 0x0cc, BIT(16), NULL }, +}; + +static struct ccu_reset_map a83t_resets[] = { + [RST_USB_PHY0] = { 0x0cc, BIT(0) }, + [RST_USB_PHY1] = { 0x0cc, BIT(1) }, + [RST_USB_HSIC] = { 0x0cc, BIT(2) }, + + [RST_BUS_OTG] = { 0x2c0, BIT(24) }, + [RST_BUS_EHCI0] = { 0x2c0, BIT(26) }, + [RST_BUS_EHCI1] = { 0x2c0, BIT(27) }, + [RST_BUS_OHCI0] = { 0x2c0, BIT(29) }, +}; + +static const struct ccu_desc sun8i_a83t_ccu_desc = { + .clks = a83t_clks, + .num_clks = ARRAY_SIZE(a83t_clks), + + .resets = a83t_resets, + .num_resets = ARRAY_SIZE(a83t_resets), +}; + +static int a83t_clk_probe(struct udevice *dev) +{ + struct sunxi_clk_priv *priv = dev_get_priv(dev); + + priv->base = dev_read_addr_ptr(dev); + if (!priv->base) + return -ENOMEM; + + priv->desc = (const struct ccu_desc *)dev_get_driver_data(dev); + if (!priv->desc) + return -EINVAL; + + return 0; +} + +static int a83t_clk_bind(struct udevice *dev) +{ + return sunxi_reset_bind(dev, 44); +} + +static const struct udevice_id a83t_clk_ids[] = { + { .compatible = "allwinner,sun8i-a83t-ccu", + .data = (ulong)&sun8i_a83t_ccu_desc }, + { } +}; + +U_BOOT_DRIVER(clk_sun8i_a83t) = { + .name = "sun8i_a83t_ccu", + .id = UCLASS_CLK, + .of_match = a83t_clk_ids, + .priv_auto_alloc_size = sizeof(struct sunxi_clk_priv), + .ops = &sunxi_clk_ops, + .probe = a83t_clk_probe, + .bind = a83t_clk_bind, +};
Add initial clock driver for Allwinner R40.
- Implement USB bus and USB clocks via ccu_clk_map descriptor for R40, so it can accessed in common clk enable and disable functions from clk_sunxi.c - Implement USB bus and USB resets via ccu_reset_map descriptor for R40, so it can accessed in common reset deassert and assert functions from reset-sunxi.c
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/clk/sunxi/Kconfig | 7 +++ drivers/clk/sunxi/Makefile | 1 + drivers/clk/sunxi/clk_r40.c | 89 +++++++++++++++++++++++++++++++++++++ 3 files changed, 97 insertions(+) create mode 100644 drivers/clk/sunxi/clk_r40.c
diff --git a/drivers/clk/sunxi/Kconfig b/drivers/clk/sunxi/Kconfig index 90af70d171..c45a4ba378 100644 --- a/drivers/clk/sunxi/Kconfig +++ b/drivers/clk/sunxi/Kconfig @@ -44,6 +44,13 @@ config CLK_SUN8I_A83T This enables common clock driver support for platforms based on Allwinner A83T SoC.
+config CLK_SUN8I_R40 + bool "Clock driver for Allwinner R40" + default MACH_SUN8I_R40 + help + This enables common clock driver support for platforms based + on Allwinner R40 SoC. + config CLK_SUN8I_H3 bool "Clock driver for Allwinner H3/H5" default MACH_SUNXI_H3_H5 diff --git a/drivers/clk/sunxi/Makefile b/drivers/clk/sunxi/Makefile index 4a254c8671..61f8b87396 100644 --- a/drivers/clk/sunxi/Makefile +++ b/drivers/clk/sunxi/Makefile @@ -11,5 +11,6 @@ obj-$(CONFIG_CLK_SUN5I_A10S) += clk_a10s.o obj-$(CONFIG_CLK_SUN6I_A31) += clk_a31.o obj-$(CONFIG_CLK_SUN8I_A23) += clk_a23.o obj-$(CONFIG_CLK_SUN8I_A83T) += clk_a83t.o +obj-$(CONFIG_CLK_SUN8I_R40) += clk_r40.o obj-$(CONFIG_CLK_SUN8I_H3) += clk_h3.o obj-$(CONFIG_CLK_SUN50I_A64) += clk_a64.o diff --git a/drivers/clk/sunxi/clk_r40.c b/drivers/clk/sunxi/clk_r40.c new file mode 100644 index 0000000000..746d6734b2 --- /dev/null +++ b/drivers/clk/sunxi/clk_r40.c @@ -0,0 +1,89 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2018 Amarula Solutions. + * Author: Jagan Teki jagan@amarulasolutions.com + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm.h> +#include <errno.h> +#include <asm/arch/ccu.h> +#include <dt-bindings/clock/sun8i-r40-ccu.h> +#include <dt-bindings/reset/sun8i-r40-ccu.h> + +static struct ccu_clk_map r40_clks[] = { + [CLK_BUS_OTG] = { 0x060, BIT(25), NULL }, + [CLK_BUS_EHCI0] = { 0x060, BIT(26), NULL }, + [CLK_BUS_EHCI1] = { 0x060, BIT(27), NULL }, + [CLK_BUS_EHCI2] = { 0x060, BIT(28), NULL }, + [CLK_BUS_OHCI0] = { 0x060, BIT(29), NULL }, + [CLK_BUS_OHCI1] = { 0x060, BIT(30), NULL }, + [CLK_BUS_OHCI2] = { 0x060, BIT(31), NULL }, + + + [CLK_USB_PHY0] = { 0x0cc, BIT(8), NULL }, + [CLK_USB_PHY1] = { 0x0cc, BIT(9), NULL }, + [CLK_USB_PHY2] = { 0x0cc, BIT(10), NULL }, + [CLK_USB_OHCI0] = { 0x0cc, BIT(16), NULL }, + [CLK_USB_OHCI1] = { 0x0cc, BIT(17), NULL }, + [CLK_USB_OHCI2] = { 0x0cc, BIT(18), NULL }, +}; + +static struct ccu_reset_map r40_resets[] = { + [RST_USB_PHY0] = { 0x0cc, BIT(0) }, + [RST_USB_PHY1] = { 0x0cc, BIT(1) }, + [RST_USB_PHY2] = { 0x0cc, BIT(2) }, + + [RST_BUS_OTG] = { 0x2c0, BIT(25) }, + [RST_BUS_EHCI0] = { 0x2c0, BIT(26) }, + [RST_BUS_EHCI1] = { 0x2c0, BIT(27) }, + [RST_BUS_EHCI2] = { 0x2c0, BIT(28) }, + [RST_BUS_OHCI0] = { 0x2c0, BIT(29) }, + [RST_BUS_OHCI1] = { 0x2c0, BIT(30) }, + [RST_BUS_OHCI2] = { 0x2c0, BIT(31) }, +}; + +static const struct ccu_desc sun8i_r40_ccu_desc = { + .clks = r40_clks, + .num_clks = ARRAY_SIZE(r40_clks), + + .resets = r40_resets, + .num_resets = ARRAY_SIZE(r40_resets), +}; + +static int r40_clk_probe(struct udevice *dev) +{ + struct sunxi_clk_priv *priv = dev_get_priv(dev); + + priv->base = dev_read_addr_ptr(dev); + if (!priv->base) + return -ENOMEM; + + priv->desc = (const struct ccu_desc *)dev_get_driver_data(dev); + if (!priv->desc) + return -EINVAL; + + return 0; +} + +static int r40_clk_bind(struct udevice *dev) +{ + return sunxi_reset_bind(dev, 80); +} + +static const struct udevice_id r40_clk_ids[] = { + { .compatible = "allwinner,sun8i-r40-ccu", + .data = (ulong)&sun8i_r40_ccu_desc }, + { } +}; + +U_BOOT_DRIVER(clk_sun8i_r40) = { + .name = "sun8i_r40_ccu", + .id = UCLASS_CLK, + .of_match = r40_clk_ids, + .priv_auto_alloc_size = sizeof(struct sunxi_clk_priv), + .ops = &sunxi_clk_ops, + .probe = r40_clk_probe, + .bind = r40_clk_bind, +};
Add initial clock driver for Allwinner V3S.
- Implement USB bus and USB clocks via ccu_clk_map descriptor for V3S, so it can accessed in common clk enable and disable functions from clk_sunxi.c - Implement USB bus and USB resets via ccu_reset_map descriptor for V3S, so it can accessed in common reset deassert and assert functions from reset-sunxi.c
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/clk/sunxi/Kconfig | 7 ++++ drivers/clk/sunxi/Makefile | 1 + drivers/clk/sunxi/clk_v3s.c | 69 +++++++++++++++++++++++++++++++++++++ 3 files changed, 77 insertions(+) create mode 100644 drivers/clk/sunxi/clk_v3s.c
diff --git a/drivers/clk/sunxi/Kconfig b/drivers/clk/sunxi/Kconfig index c45a4ba378..a6f84e9e56 100644 --- a/drivers/clk/sunxi/Kconfig +++ b/drivers/clk/sunxi/Kconfig @@ -51,6 +51,13 @@ config CLK_SUN8I_R40 This enables common clock driver support for platforms based on Allwinner R40 SoC.
+config CLK_SUN8I_V3S + bool "Clock driver for Allwinner V3S" + default MACH_SUN8I_V3S + help + This enables common clock driver support for platforms based + on Allwinner V3S SoC. + config CLK_SUN8I_H3 bool "Clock driver for Allwinner H3/H5" default MACH_SUNXI_H3_H5 diff --git a/drivers/clk/sunxi/Makefile b/drivers/clk/sunxi/Makefile index 61f8b87396..fbd43527a6 100644 --- a/drivers/clk/sunxi/Makefile +++ b/drivers/clk/sunxi/Makefile @@ -12,5 +12,6 @@ obj-$(CONFIG_CLK_SUN6I_A31) += clk_a31.o obj-$(CONFIG_CLK_SUN8I_A23) += clk_a23.o obj-$(CONFIG_CLK_SUN8I_A83T) += clk_a83t.o obj-$(CONFIG_CLK_SUN8I_R40) += clk_r40.o +obj-$(CONFIG_CLK_SUN8I_V3S) += clk_v3s.o obj-$(CONFIG_CLK_SUN8I_H3) += clk_h3.o obj-$(CONFIG_CLK_SUN50I_A64) += clk_a64.o diff --git a/drivers/clk/sunxi/clk_v3s.c b/drivers/clk/sunxi/clk_v3s.c new file mode 100644 index 0000000000..3bd793eb40 --- /dev/null +++ b/drivers/clk/sunxi/clk_v3s.c @@ -0,0 +1,69 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2018 Amarula Solutions. + * Author: Jagan Teki jagan@amarulasolutions.com + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm.h> +#include <errno.h> +#include <asm/arch/ccu.h> +#include <dt-bindings/clock/sun8i-v3s-ccu.h> +#include <dt-bindings/reset/sun8i-v3s-ccu.h> + +static struct ccu_clk_map v3s_clks[] = { + [CLK_BUS_OTG] = { 0x060, BIT(24), NULL }, + + [CLK_USB_PHY0] = { 0x0cc, BIT(8), NULL }, +}; + +static struct ccu_reset_map v3s_resets[] = { + [RST_USB_PHY0] = { 0x0cc, BIT(0) }, + + [RST_BUS_OTG] = { 0x2c0, BIT(24) }, +}; + +static const struct ccu_desc sun8i_v3s_ccu_desc = { + .clks = v3s_clks, + .num_clks = ARRAY_SIZE(v3s_clks), + + .resets = v3s_resets, + .num_resets = ARRAY_SIZE(v3s_resets), +}; + +static int v3s_clk_probe(struct udevice *dev) +{ + struct sunxi_clk_priv *priv = dev_get_priv(dev); + + priv->base = dev_read_addr_ptr(dev); + if (!priv->base) + return -ENOMEM; + + priv->desc = (const struct ccu_desc *)dev_get_driver_data(dev); + if (!priv->desc) + return -EINVAL; + + return 0; +} + +static int v3s_clk_bind(struct udevice *dev) +{ + return sunxi_reset_bind(dev, 53); +} + +static const struct udevice_id v3s_clk_ids[] = { + { .compatible = "allwinner,sun8i-v3s-ccu", + .data = (ulong)&sun8i_v3s_ccu_desc }, + { } +}; + +U_BOOT_DRIVER(clk_sun8i_v3s) = { + .name = "sun8i_v3s_ccu", + .id = UCLASS_CLK, + .of_match = v3s_clk_ids, + .priv_auto_alloc_size = sizeof(struct sunxi_clk_priv), + .ops = &sunxi_clk_ops, + .probe = v3s_clk_probe, + .bind = v3s_clk_bind, +};
CLK and DM_RESET drivers are now available for most of the Allwinner platforms, so enable in mach-sunxi/Kconfig
Enabling CLK will select DM_RESET by default.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/mach-sunxi/Kconfig | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 558363b52d..dce81b7d53 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -132,6 +132,7 @@ endif
config MACH_SUNXI_H3_H5 bool + select CLK select DM_I2C select PHY_SUN4I_USB select SUNXI_DE2 @@ -147,6 +148,7 @@ choice config MACH_SUN4I bool "sun4i (Allwinner A10)" select CPU_V7A + select CLK select ARM_CORTEX_CPU_IS_UP select DM_MMC if MMC select DM_SCSI if SCSI @@ -158,6 +160,7 @@ config MACH_SUN4I config MACH_SUN5I bool "sun5i (Allwinner A13)" select CPU_V7A + select CLK select ARM_CORTEX_CPU_IS_UP select DRAM_SUN4I select PHY_SUN4I_USB @@ -171,6 +174,7 @@ config MACH_SUN6I select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI + select CLK select DRAM_SUN6I select PHY_SUN4I_USB select SUN6I_P2WI @@ -185,6 +189,7 @@ config MACH_SUN7I select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI + select CLK select DRAM_SUN4I select PHY_SUN4I_USB select SUNXI_GEN_SUN4I @@ -197,6 +202,7 @@ config MACH_SUN8I_A23 select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI + select CLK select DRAM_SUN8I_A23 select PHY_SUN4I_USB select SUNXI_GEN_SUN6I @@ -210,6 +216,7 @@ config MACH_SUN8I_A33 select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI + select CLK select DRAM_SUN8I_A33 select PHY_SUN4I_USB select SUNXI_GEN_SUN6I @@ -220,6 +227,7 @@ config MACH_SUN8I_A33 config MACH_SUN8I_A83T bool "sun8i (Allwinner A83T)" select CPU_V7A + select CLK select DRAM_SUN8I_A83T select PHY_SUN4I_USB select SUNXI_GEN_SUN6I @@ -231,6 +239,7 @@ config MACH_SUN8I_H3 select CPU_V7A select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT + select CLK select ARCH_SUPPORT_PSCI select MACH_SUNXI_H3_H5 select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT @@ -241,6 +250,7 @@ config MACH_SUN8I_R40 select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI + select CLK select SUNXI_GEN_SUN6I select SUPPORT_SPL select SUNXI_DRAM_DW @@ -252,6 +262,7 @@ config MACH_SUN8I_V3S select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI + select CLK select SUNXI_GEN_SUN6I select SUNXI_DRAM_DW select SUNXI_DRAM_DW_16BIT @@ -270,6 +281,7 @@ config MACH_SUN9I config MACH_SUN50I bool "sun50i (Allwinner A64)" select ARM64 + select CLK select DM_I2C select PHY_SUN4I_USB select SUNXI_DE2
Now clock and reset drivers are available for respective SoC's so use clk and reset ops on musb driver.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/usb/musb-new/sunxi.c | 82 +++++++++++++++++++++++------------- 1 file changed, 53 insertions(+), 29 deletions(-)
diff --git a/drivers/usb/musb-new/sunxi.c b/drivers/usb/musb-new/sunxi.c index 9f71b84fd1..440be83f4e 100644 --- a/drivers/usb/musb-new/sunxi.c +++ b/drivers/usb/musb-new/sunxi.c @@ -16,9 +16,11 @@ * This file is part of the Inventra Controller Driver for Linux. */ #include <common.h> +#include <clk.h> #include <dm.h> #include <generic-phy.h> #include <phy-sun4i-usb.h> +#include <reset.h> #include <asm/arch/cpu.h> #include <asm/arch/clock.h> #include <asm/arch/gpio.h> @@ -78,16 +80,15 @@
struct sunxi_musb_config { struct musb_hdrc_config *config; - u8 rst_bit; - u8 clkgate_bit; };
struct sunxi_glue { struct musb_host_data mdata; - struct sunxi_ccm_reg *ccm; struct sunxi_musb_config *cfg; struct device dev; struct phy phy; + struct clk clocks; + struct reset_ctl resets; }; #define to_sunxi_glue(d) container_of(d, struct sunxi_glue, dev)
@@ -291,6 +292,18 @@ static int sunxi_musb_init(struct musb *musb)
pr_debug("%s():\n", __func__);
+ ret = clk_enable(&glue->clocks); + if (ret) { + dev_err(dev, "failed to enable clock\n"); + return ret; + } + + ret = reset_deassert(&glue->resets); + if (ret) { + dev_err(dev, "failed to deassert reset\n"); + return ret; + } + ret = generic_phy_init(&glue->phy); if (ret) { pr_err("failed to init USB PHY\n"); @@ -299,17 +312,6 @@ static int sunxi_musb_init(struct musb *musb)
musb->isr = sunxi_musb_interrupt;
- setbits_le32(&glue->ccm->ahb_gate0, BIT(AHB_GATE_OFFSET_USB0)); - if (glue->cfg->clkgate_bit) - setbits_le32(&glue->ccm->ahb_gate0, - BIT(glue->cfg->clkgate_bit)); -#ifdef CONFIG_SUNXI_GEN_SUN6I - setbits_le32(&glue->ccm->ahb_reset0_cfg, BIT(AHB_GATE_OFFSET_USB0)); - if (glue->cfg->rst_bit) - setbits_le32(&glue->ccm->ahb_reset0_cfg, - BIT(glue->cfg->rst_bit)); -#endif - USBC_ConfigFIFO_Base(); USBC_EnableDpDmPullUp(musb->mregs); USBC_EnableIdPullUp(musb->mregs); @@ -339,16 +341,17 @@ static int sunxi_musb_exit(struct musb *musb) } }
-#ifdef CONFIG_SUNXI_GEN_SUN6I - clrbits_le32(&glue->ccm->ahb_reset0_cfg, BIT(AHB_GATE_OFFSET_USB0)); - if (glue->cfg->rst_bit) - clrbits_le32(&glue->ccm->ahb_reset0_cfg, - BIT(glue->cfg->rst_bit)); -#endif - clrbits_le32(&glue->ccm->ahb_gate0, BIT(AHB_GATE_OFFSET_USB0)); - if (glue->cfg->clkgate_bit) - clrbits_le32(&glue->ccm->ahb_gate0, - BIT(glue->cfg->clkgate_bit)); + ret = reset_assert(&glue->resets); + if (ret) { + dev_err(dev, "failed to deassert reset\n"); + return ret; + } + + ret = clk_disable(&glue->clocks); + if (ret) { + dev_err(dev, "failed to enable clock\n"); + return ret; + }
return 0; } @@ -433,6 +436,7 @@ static int musb_usb_probe(struct udevice *dev) struct usb_bus_priv *priv = dev_get_uclass_priv(dev); struct musb_hdrc_platform_data pdata; void *base = dev_read_addr_ptr(dev); + int clock_nb, reset_nb; int ret;
if (!base) @@ -442,9 +446,31 @@ static int musb_usb_probe(struct udevice *dev) if (!glue->cfg) return -EINVAL;
- glue->ccm = (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; - if (IS_ERR(glue->ccm)) - return PTR_ERR(glue->ccm); + clock_nb = ofnode_count_phandle_with_args(dev_ofnode(dev), "clocks", + "#clock-cells"); + if (clock_nb < 0) { + dev_err(dev, "failed to get clock phandle(%d)\n", clock_nb); + return clock_nb; + } + + ret = clk_get_by_index(dev, 0, &glue->clocks); + if (ret) { + dev_err(dev, "failed to get clock 0\n"); + clk_free(&glue->clocks); + } + + reset_nb = ofnode_count_phandle_with_args(dev_ofnode(dev), "resets", + "#reset-cells"); + if (reset_nb < 0) { + dev_err(dev, "failed to get reset phandle(%d)\n", clock_nb); + return reset_nb; + } + + ret = reset_get_by_index(dev, 0, &glue->resets); + if (ret) { + dev_err(dev, "failed to get reset 0\n"); + reset_free(&glue->resets); + }
ret = generic_phy_get_by_name(dev, "usb", &glue->phy); if (ret) { @@ -499,8 +525,6 @@ static const struct sunxi_musb_config sun4i_a10_cfg = {
static const struct sunxi_musb_config sun8i_h3_cfg = { .config = &musb_config_h3, - .rst_bit = 23, - .clkgate_bit = 23, };
static const struct udevice_id sunxi_musb_ids[] = {
Now clock and reset drivers are available for respective SoC's so use clk and reset ops on phy driver.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/phy/allwinner/phy-sun4i-usb.c | 77 ++++++++++++++++++++------- 1 file changed, 57 insertions(+), 20 deletions(-)
diff --git a/drivers/phy/allwinner/phy-sun4i-usb.c b/drivers/phy/allwinner/phy-sun4i-usb.c index a7d7e3f044..f206fa3f5d 100644 --- a/drivers/phy/allwinner/phy-sun4i-usb.c +++ b/drivers/phy/allwinner/phy-sun4i-usb.c @@ -11,10 +11,12 @@ */
#include <common.h> +#include <clk.h> #include <dm.h> #include <dm/device.h> #include <generic-phy.h> #include <phy-sun4i-usb.h> +#include <reset.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/clock.h> @@ -80,6 +82,7 @@ struct sun4i_usb_phy_cfg { enum sun4i_usb_phy_type type; u32 disc_thresh; u8 phyctl_offset; + bool dedicated_clocks; bool enable_pmu_unk1; bool phy0_dual_route; }; @@ -88,30 +91,21 @@ struct sun4i_usb_phy_info { const char *gpio_vbus; const char *gpio_vbus_det; const char *gpio_id_det; - int rst_mask; } phy_info[] = { { .gpio_vbus = CONFIG_USB0_VBUS_PIN, .gpio_vbus_det = CONFIG_USB0_VBUS_DET, .gpio_id_det = CONFIG_USB0_ID_DET, - .rst_mask = (CCM_USB_CTRL_PHY0_RST | CCM_USB_CTRL_PHY0_CLK), }, { .gpio_vbus = CONFIG_USB1_VBUS_PIN, .gpio_vbus_det = NULL, .gpio_id_det = NULL, - .rst_mask = (CCM_USB_CTRL_PHY1_RST | CCM_USB_CTRL_PHY1_CLK), }, { .gpio_vbus = CONFIG_USB2_VBUS_PIN, .gpio_vbus_det = NULL, .gpio_id_det = NULL, -#ifdef CONFIG_MACH_SUN8I_A83T - .rst_mask = (CCM_USB_CTRL_HSIC_RST | CCM_USB_CTRL_HSIC_CLK | - CCM_USB_CTRL_12M_CLK), -#else - .rst_mask = (CCM_USB_CTRL_PHY2_RST | CCM_USB_CTRL_PHY2_CLK), -#endif }, { .gpio_vbus = CONFIG_USB3_VBUS_PIN, @@ -126,13 +120,13 @@ struct sun4i_usb_phy_plat { int gpio_vbus; int gpio_vbus_det; int gpio_id_det; - int rst_mask; + struct clk clocks; + struct reset_ctl resets; int id; };
struct sun4i_usb_phy_data { void __iomem *base; - struct sunxi_ccm_reg *ccm; const struct sun4i_usb_phy_cfg *cfg; struct sun4i_usb_phy_plat *usb_phy; }; @@ -266,8 +260,19 @@ static int sun4i_usb_phy_init(struct phy *phy) struct sun4i_usb_phy_data *data = dev_get_priv(phy->dev); struct sun4i_usb_phy_plat *usb_phy = &data->usb_phy[phy->id]; u32 val; + int ret;
- setbits_le32(&data->ccm->usb_clk_cfg, usb_phy->rst_mask); + ret = clk_enable(&usb_phy->clocks); + if (ret) { + dev_err(dev, "failed to enable usb_%ldphy clock\n", phy->id); + return ret; + } + + ret = reset_deassert(&usb_phy->resets); + if (ret) { + dev_err(dev, "failed to deassert usb_%ldreset reset\n", phy->id); + return ret; + }
if (data->cfg->type == sun8i_a83t_phy) { if (phy->id == 0) { @@ -308,6 +313,7 @@ static int sun4i_usb_phy_exit(struct phy *phy) { struct sun4i_usb_phy_data *data = dev_get_priv(phy->dev); struct sun4i_usb_phy_plat *usb_phy = &data->usb_phy[phy->id]; + int ret;
if (phy->id == 0) { if (data->cfg->type == sun8i_a83t_phy) { @@ -320,7 +326,17 @@ static int sun4i_usb_phy_exit(struct phy *phy)
sun4i_usb_phy_passby(phy, false);
- clrbits_le32(&data->ccm->usb_clk_cfg, usb_phy->rst_mask); + ret = clk_disable(&usb_phy->clocks); + if (ret) { + dev_err(dev, "failed to disable usb_%ldphy clock\n", phy->id); + return ret; + } + + ret = reset_assert(&usb_phy->resets); + if (ret) { + dev_err(dev, "failed to assert usb_%ldreset reset\n", phy->id); + return ret; + }
return 0; } @@ -407,10 +423,6 @@ static int sun4i_usb_phy_probe(struct udevice *dev) if (IS_ERR(data->base)) return PTR_ERR(data->base);
- data->ccm = (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; - if (IS_ERR(data->ccm)) - return PTR_ERR(data->ccm); - data->usb_phy = plat; for (i = 0; i < data->cfg->num_phys; i++) { struct sun4i_usb_phy_plat *phy = &plat[i]; @@ -448,6 +460,24 @@ static int sun4i_usb_phy_probe(struct udevice *dev) sunxi_gpio_set_pull(phy->gpio_id_det, SUNXI_GPIO_PULL_UP); }
+ if (data->cfg->dedicated_clocks) + snprintf(name, sizeof(name), "usb%d_phy", i); + else + strlcpy(name, "usb_phy", sizeof(name)); + + ret = clk_get_by_name(dev, name, &phy->clocks); + if (ret) { + dev_err(dev, "failed to get usb%d_phy clock phandle\n", i); + return ret; + } + + snprintf(name, sizeof(name), "usb%d_reset", i); + ret = reset_get_by_name(dev, name, &phy->resets); + if (ret) { + dev_err(dev, "failed to get usb%d_reset reset phandle\n", i); + return ret; + } + if (i || data->cfg->phy0_dual_route) { snprintf(name, sizeof(name), "pmu%d", i); phy->pmu = (void __iomem *)devfdt_get_addr_name(dev, name); @@ -456,9 +486,6 @@ static int sun4i_usb_phy_probe(struct udevice *dev) }
phy->id = i; - phy->rst_mask = info->rst_mask; - if ((data->cfg->type == sun8i_h3_phy) && (phy->id == 3)) - phy->rst_mask = (BIT(3) | BIT(11)); };
debug("Allwinner Sun4I USB PHY driver loaded\n"); @@ -470,6 +497,7 @@ static const struct sun4i_usb_phy_cfg sun4i_a10_cfg = { .type = sun4i_a10_phy, .disc_thresh = 3, .phyctl_offset = REG_PHYCTL_A10, + .dedicated_clocks = false, .enable_pmu_unk1 = false, };
@@ -478,6 +506,7 @@ static const struct sun4i_usb_phy_cfg sun5i_a13_cfg = { .type = sun4i_a10_phy, .disc_thresh = 2, .phyctl_offset = REG_PHYCTL_A10, + .dedicated_clocks = false, .enable_pmu_unk1 = false, };
@@ -486,6 +515,7 @@ static const struct sun4i_usb_phy_cfg sun6i_a31_cfg = { .type = sun6i_a31_phy, .disc_thresh = 3, .phyctl_offset = REG_PHYCTL_A10, + .dedicated_clocks = true, .enable_pmu_unk1 = false, };
@@ -494,6 +524,7 @@ static const struct sun4i_usb_phy_cfg sun7i_a20_cfg = { .type = sun4i_a10_phy, .disc_thresh = 2, .phyctl_offset = REG_PHYCTL_A10, + .dedicated_clocks = false, .enable_pmu_unk1 = false, };
@@ -502,6 +533,7 @@ static const struct sun4i_usb_phy_cfg sun8i_a23_cfg = { .type = sun4i_a10_phy, .disc_thresh = 3, .phyctl_offset = REG_PHYCTL_A10, + .dedicated_clocks = true, .enable_pmu_unk1 = false, };
@@ -510,6 +542,7 @@ static const struct sun4i_usb_phy_cfg sun8i_a33_cfg = { .type = sun8i_a33_phy, .disc_thresh = 3, .phyctl_offset = REG_PHYCTL_A33, + .dedicated_clocks = true, .enable_pmu_unk1 = false, };
@@ -517,6 +550,7 @@ static const struct sun4i_usb_phy_cfg sun8i_a83t_cfg = { .num_phys = 3, .type = sun8i_a83t_phy, .phyctl_offset = REG_PHYCTL_A33, + .dedicated_clocks = true, };
static const struct sun4i_usb_phy_cfg sun8i_h3_cfg = { @@ -524,6 +558,7 @@ static const struct sun4i_usb_phy_cfg sun8i_h3_cfg = { .type = sun8i_h3_phy, .disc_thresh = 3, .phyctl_offset = REG_PHYCTL_A33, + .dedicated_clocks = true, .enable_pmu_unk1 = true, .phy0_dual_route = true, }; @@ -533,6 +568,7 @@ static const struct sun4i_usb_phy_cfg sun8i_v3s_cfg = { .type = sun8i_v3s_phy, .disc_thresh = 3, .phyctl_offset = REG_PHYCTL_A33, + .dedicated_clocks = true, .enable_pmu_unk1 = true, .phy0_dual_route = true, }; @@ -542,6 +578,7 @@ static const struct sun4i_usb_phy_cfg sun50i_a64_cfg = { .type = sun50i_a64_phy, .disc_thresh = 3, .phyctl_offset = REG_PHYCTL_A33, + .dedicated_clocks = true, .enable_pmu_unk1 = true, .phy0_dual_route = true, };
Once of key blocker for using USB Generic host controller drivers in Allwinner are CLK and RESET drivers, now these available for USB usage. So switch to use EHCI and OHCI Generic controllers.
Enabling USB is wisely a board choise, so Enable USB_OHCI_HCD where it already have USB_EHCI_HCD
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- configs/A10-OLinuXino-Lime_defconfig | 1 + configs/A10s-OLinuXino-M_defconfig | 1 + configs/A13-OLinuXinoM_defconfig | 1 + configs/A13-OLinuXino_defconfig | 1 + configs/A20-OLinuXino-Lime2-eMMC_defconfig | 1 + configs/A20-OLinuXino-Lime2_defconfig | 1 + configs/A20-OLinuXino-Lime_defconfig | 1 + configs/A20-Olimex-SOM204-EVB_defconfig | 2 ++ configs/Auxtek-T003_defconfig | 1 + configs/Auxtek-T004_defconfig | 1 + configs/Bananapi_defconfig | 1 + configs/Bananapi_m2m_defconfig | 1 + configs/Bananapro_defconfig | 1 + configs/CHIP_defconfig | 1 + configs/CHIP_pro_defconfig | 1 + configs/CSQ_CS908_defconfig | 1 + configs/Colombus_defconfig | 1 + configs/Cubieboard2_defconfig | 1 + configs/Cubieboard_defconfig | 1 + configs/Cubietruck_plus_defconfig | 1 + configs/Hummingbird_A31_defconfig | 1 + configs/Itead_Ibox_A20_defconfig | 1 + configs/Linksprite_pcDuino3_Nano_defconfig | 1 + configs/Linksprite_pcDuino3_defconfig | 1 + configs/Linksprite_pcDuino_defconfig | 1 + configs/MK808C_defconfig | 1 + configs/Marsboard_A10_defconfig | 1 + configs/Mele_A1000G_quad_defconfig | 1 + configs/Mele_A1000_defconfig | 1 + configs/Mele_I7_defconfig | 1 + configs/Mele_M3_defconfig | 1 + configs/Mele_M5_defconfig | 1 + configs/Mele_M9_defconfig | 1 + configs/Mini-X_defconfig | 1 + configs/Orangepi_defconfig | 1 + configs/Orangepi_mini_defconfig | 1 + configs/Sinlinx_SinA31s_defconfig | 1 + configs/Sinlinx_SinA33_defconfig | 1 + configs/Sinovoip_BPI_M2_Plus_defconfig | 1 + configs/Sinovoip_BPI_M2_defconfig | 1 + configs/Sinovoip_BPI_M3_defconfig | 1 + configs/Wexler_TAB7200_defconfig | 1 + configs/Wobo_i5_defconfig | 1 + configs/a64-olinuxino_defconfig | 1 + configs/ba10_tv_box_defconfig | 1 + configs/bananapi_m1_plus_defconfig | 1 + configs/bananapi_m64_defconfig | 1 + configs/ga10h_v1_1_defconfig | 1 + configs/h8_homlet_v2_defconfig | 1 + configs/i12-tvbox_defconfig | 1 + configs/icnova-a20-swac_defconfig | 1 + configs/inet1_defconfig | 1 + configs/inet_q972_defconfig | 1 + configs/jesurun_q5_defconfig | 1 + configs/libretech_all_h3_cc_h2_plus_defconfig | 1 + configs/libretech_all_h3_cc_h3_defconfig | 1 + configs/libretech_all_h3_cc_h5_defconfig | 1 + configs/mixtile_loftq_defconfig | 1 + configs/mk802_a10s_defconfig | 1 + configs/mk802_defconfig | 1 + configs/mk802ii_defconfig | 1 + configs/nanopi_a64_defconfig | 1 + configs/nanopi_m1_defconfig | 1 + configs/nanopi_m1_plus_defconfig | 1 + configs/nanopi_neo2_defconfig | 1 + configs/nanopi_neo_air_defconfig | 1 + configs/nanopi_neo_defconfig | 1 + configs/nanopi_neo_plus2_defconfig | 1 + configs/orangepi_2_defconfig | 1 + configs/orangepi_lite_defconfig | 1 + configs/orangepi_one_defconfig | 1 + configs/orangepi_pc2_defconfig | 1 + configs/orangepi_pc_defconfig | 1 + configs/orangepi_pc_plus_defconfig | 1 + configs/orangepi_plus2e_defconfig | 1 + configs/orangepi_plus_defconfig | 1 + configs/orangepi_prime_defconfig | 1 + configs/orangepi_r1_defconfig | 1 + configs/orangepi_win_defconfig | 1 + configs/orangepi_zero_defconfig | 1 + configs/orangepi_zero_plus2_defconfig | 1 + configs/orangepi_zero_plus_defconfig | 1 + configs/parrot_r16_defconfig | 1 + configs/pine64_plus_defconfig | 1 + configs/r7-tv-dongle_defconfig | 1 + configs/sopine_baseboard_defconfig | 1 + configs/sun8i_a23_evb_defconfig | 1 + configs/sunxi_Gemei_G9_defconfig | 1 + configs/tbs_a711_defconfig | 1 + drivers/usb/host/Kconfig | 2 ++ include/configs/sun4i.h | 4 ---- include/configs/sun50i.h | 5 ----- include/configs/sun5i.h | 4 ---- include/configs/sun6i.h | 4 ---- include/configs/sun7i.h | 4 ---- include/configs/sun8i.h | 4 ---- include/configs/sunxi-common.h | 1 - 97 files changed, 92 insertions(+), 26 deletions(-)
diff --git a/configs/A10-OLinuXino-Lime_defconfig b/configs/A10-OLinuXino-Lime_defconfig index feb1173c0b..e8fecbe15f 100644 --- a/configs/A10-OLinuXino-Lime_defconfig +++ b/configs/A10-OLinuXino-Lime_defconfig @@ -20,5 +20,6 @@ CONFIG_SUN4I_EMAC=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 CONFIG_SCSI=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/A10s-OLinuXino-M_defconfig b/configs/A10s-OLinuXino-M_defconfig index 9498a6d752..bee913cb0b 100644 --- a/configs/A10s-OLinuXino-M_defconfig +++ b/configs/A10s-OLinuXino-M_defconfig @@ -16,5 +16,6 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_SUN4I_EMAC=y CONFIG_AXP152_POWER=y CONFIG_CONS_INDEX=2 +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/A13-OLinuXinoM_defconfig b/configs/A13-OLinuXinoM_defconfig index ed507cdf0b..dd5c25ca9f 100644 --- a/configs/A13-OLinuXinoM_defconfig +++ b/configs/A13-OLinuXinoM_defconfig @@ -18,5 +18,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-olinuxino-micro" # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUNXI_NO_PMIC=y CONFIG_CONS_INDEX=2 +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/A13-OLinuXino_defconfig b/configs/A13-OLinuXino_defconfig index b8ec1e54db..04682dcac4 100644 --- a/configs/A13-OLinuXino_defconfig +++ b/configs/A13-OLinuXino_defconfig @@ -25,6 +25,7 @@ CONFIG_DFU_RAM=y CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_AXP_ALDO3_VOLT=3300 CONFIG_CONS_INDEX=2 +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/A20-OLinuXino-Lime2-eMMC_defconfig b/configs/A20-OLinuXino-Lime2-eMMC_defconfig index 5657fc2594..2851a461e8 100644 --- a/configs/A20-OLinuXino-Lime2-eMMC_defconfig +++ b/configs/A20-OLinuXino-Lime2-eMMC_defconfig @@ -27,6 +27,7 @@ CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 CONFIG_SCSI=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/A20-OLinuXino-Lime2_defconfig b/configs/A20-OLinuXino-Lime2_defconfig index 134d1d3fef..99987a8683 100644 --- a/configs/A20-OLinuXino-Lime2_defconfig +++ b/configs/A20-OLinuXino-Lime2_defconfig @@ -26,6 +26,7 @@ CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 CONFIG_SCSI=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/A20-OLinuXino-Lime_defconfig b/configs/A20-OLinuXino-Lime_defconfig index b7c13a6932..1b59174120 100644 --- a/configs/A20-OLinuXino-Lime_defconfig +++ b/configs/A20-OLinuXino-Lime_defconfig @@ -19,5 +19,6 @@ CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 CONFIG_SCSI=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/A20-Olimex-SOM204-EVB_defconfig b/configs/A20-Olimex-SOM204-EVB_defconfig index cfb7ffa556..0537378ba1 100644 --- a/configs/A20-Olimex-SOM204-EVB_defconfig +++ b/configs/A20-Olimex-SOM204-EVB_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_USB_OHCI_HCD=y CONFIG_ARCH_SUNXI=y CONFIG_SPL=y CONFIG_MACH_SUN7I=y @@ -27,6 +28,7 @@ CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 CONFIG_SCSI=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Auxtek-T003_defconfig b/configs/Auxtek-T003_defconfig index ce4806cf5e..a2bf5037ed 100644 --- a/configs/Auxtek-T003_defconfig +++ b/configs/Auxtek-T003_defconfig @@ -14,5 +14,6 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP152_POWER=y CONFIG_CONS_INDEX=2 +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Auxtek-T004_defconfig b/configs/Auxtek-T004_defconfig index 5faf45c3d7..4c1117e4bb 100644 --- a/configs/Auxtek-T004_defconfig +++ b/configs/Auxtek-T004_defconfig @@ -12,5 +12,6 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP152_POWER=y CONFIG_CONS_INDEX=2 +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Bananapi_defconfig b/configs/Bananapi_defconfig index 7a9b5fe0e5..53752b2e12 100644 --- a/configs/Bananapi_defconfig +++ b/configs/Bananapi_defconfig @@ -19,5 +19,6 @@ CONFIG_ETH_DESIGNWARE=y CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y CONFIG_SCSI=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Bananapi_m2m_defconfig b/configs/Bananapi_m2m_defconfig index 2316437c94..a21796fa67 100644 --- a/configs/Bananapi_m2m_defconfig +++ b/configs/Bananapi_m2m_defconfig @@ -14,6 +14,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-r16-bananapi-m2m" # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_FASTBOOT_CMD_OEM_FORMAT=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_FUNCTION_MASS_STORAGE=y diff --git a/configs/Bananapro_defconfig b/configs/Bananapro_defconfig index 5a8ded0493..ad4ce1f662 100644 --- a/configs/Bananapro_defconfig +++ b/configs/Bananapro_defconfig @@ -22,5 +22,6 @@ CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO4_VOLT=2500 CONFIG_SCSI=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/CHIP_defconfig b/configs/CHIP_defconfig index c122944881..2dfa5237bc 100644 --- a/configs/CHIP_defconfig +++ b/configs/CHIP_defconfig @@ -16,6 +16,7 @@ CONFIG_DFU_RAM=y CONFIG_AXP_ALDO3_VOLT=3300 CONFIG_AXP_ALDO4_VOLT=3300 CONFIG_CONS_INDEX=2 +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/CHIP_pro_defconfig b/configs/CHIP_pro_defconfig index 5d63fadef5..1333877957 100644 --- a/configs/CHIP_pro_defconfig +++ b/configs/CHIP_pro_defconfig @@ -20,6 +20,7 @@ CONFIG_SYS_NAND_OOBSIZE=0x100 CONFIG_AXP_ALDO3_VOLT=3300 CONFIG_AXP_ALDO4_VOLT=3300 CONFIG_CONS_INDEX=2 +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/CSQ_CS908_defconfig b/configs/CSQ_CS908_defconfig index b103e7e00d..7612cc8989 100644 --- a/configs/CSQ_CS908_defconfig +++ b/configs/CSQ_CS908_defconfig @@ -14,6 +14,7 @@ CONFIG_ETH_DESIGNWARE=y CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_AXP_DLDO1_VOLT=3300 +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Colombus_defconfig b/configs/Colombus_defconfig index c85e47cb11..6310420c29 100644 --- a/configs/Colombus_defconfig +++ b/configs/Colombus_defconfig @@ -24,5 +24,6 @@ CONFIG_ETH_DESIGNWARE=y CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO1_VOLT=3300 +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Cubieboard2_defconfig b/configs/Cubieboard2_defconfig index 418da63ba8..6e883155b9 100644 --- a/configs/Cubieboard2_defconfig +++ b/configs/Cubieboard2_defconfig @@ -16,5 +16,6 @@ CONFIG_SCSI_AHCI=y CONFIG_ETH_DESIGNWARE=y CONFIG_SUN7I_GMAC=y CONFIG_SCSI=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Cubieboard_defconfig b/configs/Cubieboard_defconfig index 27223d201e..dbeda7370d 100644 --- a/configs/Cubieboard_defconfig +++ b/configs/Cubieboard_defconfig @@ -15,5 +15,6 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_SCSI_AHCI=y CONFIG_SUN4I_EMAC=y CONFIG_SCSI=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Cubietruck_plus_defconfig b/configs/Cubietruck_plus_defconfig index d76bc6748b..6a0e4c5836 100644 --- a/configs/Cubietruck_plus_defconfig +++ b/configs/Cubietruck_plus_defconfig @@ -22,6 +22,7 @@ CONFIG_CONSOLE_MUX=y CONFIG_AXP_DLDO3_VOLT=2500 CONFIG_AXP_DLDO4_VOLT=3300 CONFIG_AXP_FLDO1_VOLT=1200 +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Hummingbird_A31_defconfig b/configs/Hummingbird_A31_defconfig index 24126fde28..81eb59ebd1 100644 --- a/configs/Hummingbird_A31_defconfig +++ b/configs/Hummingbird_A31_defconfig @@ -16,5 +16,6 @@ CONFIG_ETH_DESIGNWARE=y CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO1_VOLT=3300 +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Itead_Ibox_A20_defconfig b/configs/Itead_Ibox_A20_defconfig index dfef071476..93c89890a7 100644 --- a/configs/Itead_Ibox_A20_defconfig +++ b/configs/Itead_Ibox_A20_defconfig @@ -16,5 +16,6 @@ CONFIG_SCSI_AHCI=y CONFIG_ETH_DESIGNWARE=y CONFIG_SUN7I_GMAC=y CONFIG_SCSI=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Linksprite_pcDuino3_Nano_defconfig b/configs/Linksprite_pcDuino3_Nano_defconfig index 2df6761455..8487263fd8 100644 --- a/configs/Linksprite_pcDuino3_Nano_defconfig +++ b/configs/Linksprite_pcDuino3_Nano_defconfig @@ -19,5 +19,6 @@ CONFIG_ETH_DESIGNWARE=y CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y CONFIG_SCSI=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Linksprite_pcDuino3_defconfig b/configs/Linksprite_pcDuino3_defconfig index d7e9c26cbf..7a1fc26434 100644 --- a/configs/Linksprite_pcDuino3_defconfig +++ b/configs/Linksprite_pcDuino3_defconfig @@ -18,5 +18,6 @@ CONFIG_ETH_DESIGNWARE=y CONFIG_SUN7I_GMAC=y CONFIG_SCSI=y CONFIG_DM_SCSI=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Linksprite_pcDuino_defconfig b/configs/Linksprite_pcDuino_defconfig index 500f885599..b18b02307f 100644 --- a/configs/Linksprite_pcDuino_defconfig +++ b/configs/Linksprite_pcDuino_defconfig @@ -11,5 +11,6 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN4I_EMAC=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/MK808C_defconfig b/configs/MK808C_defconfig index 62768b8656..c3d914efe3 100644 --- a/configs/MK808C_defconfig +++ b/configs/MK808C_defconfig @@ -9,5 +9,6 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Marsboard_A10_defconfig b/configs/Marsboard_A10_defconfig index 55c27b8435..37bdeb0c37 100644 --- a/configs/Marsboard_A10_defconfig +++ b/configs/Marsboard_A10_defconfig @@ -12,5 +12,6 @@ CONFIG_SCSI_AHCI=y CONFIG_SUN4I_EMAC=y CONFIG_SUNXI_NO_PMIC=y CONFIG_SCSI=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Mele_A1000G_quad_defconfig b/configs/Mele_A1000G_quad_defconfig index e084454293..b3a05f2c0d 100644 --- a/configs/Mele_A1000G_quad_defconfig +++ b/configs/Mele_A1000G_quad_defconfig @@ -17,6 +17,7 @@ CONFIG_AXP_DCDC1_VOLT=3300 CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_AXP_DLDO4_VOLT=3300 +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Mele_A1000_defconfig b/configs/Mele_A1000_defconfig index 367f2aaf7a..021753c221 100644 --- a/configs/Mele_A1000_defconfig +++ b/configs/Mele_A1000_defconfig @@ -15,5 +15,6 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_SCSI_AHCI=y CONFIG_SUN4I_EMAC=y CONFIG_SCSI=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Mele_I7_defconfig b/configs/Mele_I7_defconfig index 4fa61d311f..c9398676e2 100644 --- a/configs/Mele_I7_defconfig +++ b/configs/Mele_I7_defconfig @@ -16,5 +16,6 @@ CONFIG_AXP_DCDC1_VOLT=3300 CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_AXP_DLDO4_VOLT=3300 +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Mele_M3_defconfig b/configs/Mele_M3_defconfig index 9f48bd91e0..22497aaeb4 100644 --- a/configs/Mele_M3_defconfig +++ b/configs/Mele_M3_defconfig @@ -15,5 +15,6 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y CONFIG_SUN7I_GMAC=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Mele_M5_defconfig b/configs/Mele_M5_defconfig index 6b198be6f6..37e90e1eaf 100644 --- a/configs/Mele_M5_defconfig +++ b/configs/Mele_M5_defconfig @@ -17,5 +17,6 @@ CONFIG_SCSI_AHCI=y CONFIG_ETH_DESIGNWARE=y CONFIG_SUN7I_GMAC=y CONFIG_SCSI=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Mele_M9_defconfig b/configs/Mele_M9_defconfig index af89c50ee1..94190499bf 100644 --- a/configs/Mele_M9_defconfig +++ b/configs/Mele_M9_defconfig @@ -16,5 +16,6 @@ CONFIG_AXP_DCDC1_VOLT=3300 CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_AXP_DLDO4_VOLT=3300 +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Mini-X_defconfig b/configs/Mini-X_defconfig index e32935e132..dfaa649e95 100644 --- a/configs/Mini-X_defconfig +++ b/configs/Mini-X_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Orangepi_defconfig b/configs/Orangepi_defconfig index 88e55495d5..c347e32927 100644 --- a/configs/Orangepi_defconfig +++ b/configs/Orangepi_defconfig @@ -21,5 +21,6 @@ CONFIG_ETH_DESIGNWARE=y CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y CONFIG_SCSI=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Orangepi_mini_defconfig b/configs/Orangepi_mini_defconfig index 46f27be254..7eeae25010 100644 --- a/configs/Orangepi_mini_defconfig +++ b/configs/Orangepi_mini_defconfig @@ -23,5 +23,6 @@ CONFIG_ETH_DESIGNWARE=y CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y CONFIG_SCSI=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Sinlinx_SinA31s_defconfig b/configs/Sinlinx_SinA31s_defconfig index 9744aef096..0aa02d687c 100644 --- a/configs/Sinlinx_SinA31s_defconfig +++ b/configs/Sinlinx_SinA31s_defconfig @@ -17,5 +17,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-sina31s" CONFIG_ETH_DESIGNWARE=y CONFIG_SUN7I_GMAC=y CONFIG_AXP_DLDO1_VOLT=3300 +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Sinlinx_SinA33_defconfig b/configs/Sinlinx_SinA33_defconfig index 394534b8b5..7f5aaab5fb 100644 --- a/configs/Sinlinx_SinA33_defconfig +++ b/configs/Sinlinx_SinA33_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_DFU=y # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_DFU_RAM=y CONFIG_FASTBOOT_CMD_OEM_FORMAT=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Sinovoip_BPI_M2_Plus_defconfig b/configs/Sinovoip_BPI_M2_Plus_defconfig index a325e9f806..b01aa560d2 100644 --- a/configs/Sinovoip_BPI_M2_Plus_defconfig +++ b/configs/Sinovoip_BPI_M2_Plus_defconfig @@ -13,6 +13,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-bananapi-m2-plus" # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Sinovoip_BPI_M2_defconfig b/configs/Sinovoip_BPI_M2_defconfig index 65d81a5284..fa42670355 100644 --- a/configs/Sinovoip_BPI_M2_defconfig +++ b/configs/Sinovoip_BPI_M2_defconfig @@ -16,5 +16,6 @@ CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_AXP_ALDO2_VOLT=1800 CONFIG_AXP_DLDO1_VOLT=3000 +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Sinovoip_BPI_M3_defconfig b/configs/Sinovoip_BPI_M3_defconfig index 479dd05dfb..91a3621d77 100644 --- a/configs/Sinovoip_BPI_M3_defconfig +++ b/configs/Sinovoip_BPI_M3_defconfig @@ -23,6 +23,7 @@ CONFIG_CONSOLE_MUX=y CONFIG_AXP_DCDC5_VOLT=1200 CONFIG_AXP_DLDO3_VOLT=2500 CONFIG_AXP_SW_ON=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Wexler_TAB7200_defconfig b/configs/Wexler_TAB7200_defconfig index 9a431ee4cd..d031b05f1a 100644 --- a/configs/Wexler_TAB7200_defconfig +++ b/configs/Wexler_TAB7200_defconfig @@ -17,6 +17,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Wobo_i5_defconfig b/configs/Wobo_i5_defconfig index 88ccfd406e..8ae00abcff 100644 --- a/configs/Wobo_i5_defconfig +++ b/configs/Wobo_i5_defconfig @@ -14,5 +14,6 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_AXP_ALDO3_VOLT=3300 CONFIG_AXP_ALDO4_VOLT=3300 CONFIG_CONS_INDEX=2 +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/a64-olinuxino_defconfig b/configs/a64-olinuxino_defconfig index b32df990a0..54f6a98472 100644 --- a/configs/a64-olinuxino_defconfig +++ b/configs/a64-olinuxino_defconfig @@ -10,5 +10,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-olinuxino" # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/ba10_tv_box_defconfig b/configs/ba10_tv_box_defconfig index 88199c8e78..b6776e3cb9 100644 --- a/configs/ba10_tv_box_defconfig +++ b/configs/ba10_tv_box_defconfig @@ -14,6 +14,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN4I_EMAC=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/bananapi_m1_plus_defconfig b/configs/bananapi_m1_plus_defconfig index 539ed73495..dde7b17229 100644 --- a/configs/bananapi_m1_plus_defconfig +++ b/configs/bananapi_m1_plus_defconfig @@ -19,4 +19,5 @@ CONFIG_ETH_DESIGNWARE=y CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y CONFIG_SCSI=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/bananapi_m64_defconfig b/configs/bananapi_m64_defconfig index 40c1c18aca..df0bbb4db5 100644 --- a/configs/bananapi_m64_defconfig +++ b/configs/bananapi_m64_defconfig @@ -11,6 +11,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-bananapi-m64" # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/ga10h_v1_1_defconfig b/configs/ga10h_v1_1_defconfig index 02cc9677aa..4196ad6863 100644 --- a/configs/ga10h_v1_1_defconfig +++ b/configs/ga10h_v1_1_defconfig @@ -22,6 +22,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-ga10h-v1.1" # CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_CONS_INDEX=5 +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/h8_homlet_v2_defconfig b/configs/h8_homlet_v2_defconfig index 80bdb20e8a..380949b1c2 100644 --- a/configs/h8_homlet_v2_defconfig +++ b/configs/h8_homlet_v2_defconfig @@ -15,6 +15,7 @@ CONFIG_CONSOLE_MUX=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP_DLDO4_VOLT=3300 +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/i12-tvbox_defconfig b/configs/i12-tvbox_defconfig index a3c4b0e76c..983627afbb 100644 --- a/configs/i12-tvbox_defconfig +++ b/configs/i12-tvbox_defconfig @@ -13,5 +13,6 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y CONFIG_SUN7I_GMAC=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/icnova-a20-swac_defconfig b/configs/icnova-a20-swac_defconfig index 8fca6e81ed..6d6792553e 100644 --- a/configs/icnova-a20-swac_defconfig +++ b/configs/icnova-a20-swac_defconfig @@ -20,5 +20,6 @@ CONFIG_CMD_UNZIP=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_ETH_DESIGNWARE=y CONFIG_SUN7I_GMAC=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/inet1_defconfig b/configs/inet1_defconfig index 100d075960..46f8f3c095 100644 --- a/configs/inet1_defconfig +++ b/configs/inet1_defconfig @@ -18,6 +18,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/inet_q972_defconfig b/configs/inet_q972_defconfig index b928622813..9a22499b23 100644 --- a/configs/inet_q972_defconfig +++ b/configs/inet_q972_defconfig @@ -19,6 +19,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-inet-q972" # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP_DLDO1_VOLT=3300 +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/jesurun_q5_defconfig b/configs/jesurun_q5_defconfig index 00bb745be2..c0c46a1d4e 100644 --- a/configs/jesurun_q5_defconfig +++ b/configs/jesurun_q5_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN4I_EMAC=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/libretech_all_h3_cc_h2_plus_defconfig b/configs/libretech_all_h3_cc_h2_plus_defconfig index 071be93697..ccf0b73ffd 100644 --- a/configs/libretech_all_h3_cc_h2_plus_defconfig +++ b/configs/libretech_all_h3_cc_h2_plus_defconfig @@ -12,5 +12,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-h2-plus-libretech-all-h3-cc" # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/libretech_all_h3_cc_h3_defconfig b/configs/libretech_all_h3_cc_h3_defconfig index c20ad9f3a2..159b00ea91 100644 --- a/configs/libretech_all_h3_cc_h3_defconfig +++ b/configs/libretech_all_h3_cc_h3_defconfig @@ -12,5 +12,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-libretech-all-h3-cc" # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/libretech_all_h3_cc_h5_defconfig b/configs/libretech_all_h3_cc_h5_defconfig index 5db8dfcd4f..003e2dc0f3 100644 --- a/configs/libretech_all_h3_cc_h5_defconfig +++ b/configs/libretech_all_h3_cc_h5_defconfig @@ -12,5 +12,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun50i-h5-libretech-all-h3-cc" # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/mixtile_loftq_defconfig b/configs/mixtile_loftq_defconfig index 79d984ba7b..59321b108d 100644 --- a/configs/mixtile_loftq_defconfig +++ b/configs/mixtile_loftq_defconfig @@ -16,5 +16,6 @@ CONFIG_ETH_DESIGNWARE=y CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y CONFIG_AXP_ALDO1_VOLT=3300 +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/mk802_a10s_defconfig b/configs/mk802_a10s_defconfig index 5129b49506..233925ee6e 100644 --- a/configs/mk802_a10s_defconfig +++ b/configs/mk802_a10s_defconfig @@ -13,5 +13,6 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP152_POWER=y CONFIG_CONS_INDEX=2 +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/mk802_defconfig b/configs/mk802_defconfig index 81d121fb84..454339a7cf 100644 --- a/configs/mk802_defconfig +++ b/configs/mk802_defconfig @@ -9,5 +9,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-mk802" # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUNXI_NO_PMIC=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/mk802ii_defconfig b/configs/mk802ii_defconfig index 84ae234fdc..2ce58ca64d 100644 --- a/configs/mk802ii_defconfig +++ b/configs/mk802ii_defconfig @@ -8,5 +8,6 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/nanopi_a64_defconfig b/configs/nanopi_a64_defconfig index 0a04911c81..091f395db3 100644 --- a/configs/nanopi_a64_defconfig +++ b/configs/nanopi_a64_defconfig @@ -9,5 +9,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-nanopi-a64" # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/nanopi_m1_defconfig b/configs/nanopi_m1_defconfig index e0ae3c7c60..8440bd28c9 100644 --- a/configs/nanopi_m1_defconfig +++ b/configs/nanopi_m1_defconfig @@ -10,5 +10,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-nanopi-m1" # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/nanopi_m1_plus_defconfig b/configs/nanopi_m1_plus_defconfig index ee22364760..3918b7e21e 100644 --- a/configs/nanopi_m1_plus_defconfig +++ b/configs/nanopi_m1_plus_defconfig @@ -12,5 +12,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-nanopi-m1-plus" # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/nanopi_neo2_defconfig b/configs/nanopi_neo2_defconfig index 35058186f5..100f144ed0 100644 --- a/configs/nanopi_neo2_defconfig +++ b/configs/nanopi_neo2_defconfig @@ -10,5 +10,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun50i-h5-nanopi-neo2" # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/nanopi_neo_air_defconfig b/configs/nanopi_neo_air_defconfig index f953b71f03..c2659627bc 100644 --- a/configs/nanopi_neo_air_defconfig +++ b/configs/nanopi_neo_air_defconfig @@ -12,5 +12,6 @@ CONFIG_CONSOLE_MUX=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/nanopi_neo_defconfig b/configs/nanopi_neo_defconfig index 66919e5a2b..44cd1036dd 100644 --- a/configs/nanopi_neo_defconfig +++ b/configs/nanopi_neo_defconfig @@ -13,5 +13,6 @@ CONFIG_CONSOLE_MUX=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/nanopi_neo_plus2_defconfig b/configs/nanopi_neo_plus2_defconfig index 70798a8e9f..bcaf2e5068 100644 --- a/configs/nanopi_neo_plus2_defconfig +++ b/configs/nanopi_neo_plus2_defconfig @@ -12,4 +12,5 @@ CONFIG_DEFAULT_DEVICE_TREE="sun50i-h5-nanopi-neo-plus2" # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/orangepi_2_defconfig b/configs/orangepi_2_defconfig index 577a32255b..e88615c8c6 100644 --- a/configs/orangepi_2_defconfig +++ b/configs/orangepi_2_defconfig @@ -15,5 +15,6 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y CONFIG_SY8106A_POWER=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/orangepi_lite_defconfig b/configs/orangepi_lite_defconfig index f3fd864a6d..21b05daf45 100644 --- a/configs/orangepi_lite_defconfig +++ b/configs/orangepi_lite_defconfig @@ -10,5 +10,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-lite" # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/orangepi_one_defconfig b/configs/orangepi_one_defconfig index 23f4973e5b..4c7f6027ac 100644 --- a/configs/orangepi_one_defconfig +++ b/configs/orangepi_one_defconfig @@ -11,5 +11,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-one" # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/orangepi_pc2_defconfig b/configs/orangepi_pc2_defconfig index ca1e586e89..3dabfeb300 100644 --- a/configs/orangepi_pc2_defconfig +++ b/configs/orangepi_pc2_defconfig @@ -12,6 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun50i-h5-orangepi-pc2" # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/orangepi_pc_defconfig b/configs/orangepi_pc_defconfig index 134db79e72..083e0eba9b 100644 --- a/configs/orangepi_pc_defconfig +++ b/configs/orangepi_pc_defconfig @@ -13,5 +13,6 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y CONFIG_SY8106A_POWER=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/orangepi_pc_plus_defconfig b/configs/orangepi_pc_plus_defconfig index 01c1cd7736..4068afb20e 100644 --- a/configs/orangepi_pc_plus_defconfig +++ b/configs/orangepi_pc_plus_defconfig @@ -14,5 +14,6 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y CONFIG_SY8106A_POWER=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/orangepi_plus2e_defconfig b/configs/orangepi_plus2e_defconfig index a6e61a5065..f049d3f8b9 100644 --- a/configs/orangepi_plus2e_defconfig +++ b/configs/orangepi_plus2e_defconfig @@ -15,5 +15,6 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y CONFIG_SY8106A_POWER=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/orangepi_plus_defconfig b/configs/orangepi_plus_defconfig index 8e32b0af32..4c1d609760 100644 --- a/configs/orangepi_plus_defconfig +++ b/configs/orangepi_plus_defconfig @@ -17,5 +17,6 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y CONFIG_SY8106A_POWER=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/orangepi_prime_defconfig b/configs/orangepi_prime_defconfig index 6161863258..b20835b0d7 100644 --- a/configs/orangepi_prime_defconfig +++ b/configs/orangepi_prime_defconfig @@ -10,6 +10,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun50i-h5-orangepi-prime" # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/orangepi_r1_defconfig b/configs/orangepi_r1_defconfig index 8e6ee7b2db..289f8d7650 100644 --- a/configs/orangepi_r1_defconfig +++ b/configs/orangepi_r1_defconfig @@ -12,5 +12,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-h2-plus-orangepi-r1" CONFIG_CONSOLE_MUX=y # CONFIG_CMD_FLASH is not set CONFIG_SUN8I_EMAC=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/orangepi_win_defconfig b/configs/orangepi_win_defconfig index d7211b5823..e14faacfaf 100644 --- a/configs/orangepi_win_defconfig +++ b/configs/orangepi_win_defconfig @@ -10,5 +10,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-orangepi-win" # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/orangepi_zero_defconfig b/configs/orangepi_zero_defconfig index 6afd4a3bfa..6f2a64002f 100644 --- a/configs/orangepi_zero_defconfig +++ b/configs/orangepi_zero_defconfig @@ -12,5 +12,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-h2-plus-orangepi-zero" CONFIG_CONSOLE_MUX=y # CONFIG_CMD_FLASH is not set CONFIG_SUN8I_EMAC=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/orangepi_zero_plus2_defconfig b/configs/orangepi_zero_plus2_defconfig index fdb6bb4ed9..95c3d29b85 100644 --- a/configs/orangepi_zero_plus2_defconfig +++ b/configs/orangepi_zero_plus2_defconfig @@ -12,5 +12,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun50i-h5-orangepi-zero-plus2" # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/orangepi_zero_plus_defconfig b/configs/orangepi_zero_plus_defconfig index fc656ce733..cd61b17cd4 100644 --- a/configs/orangepi_zero_plus_defconfig +++ b/configs/orangepi_zero_plus_defconfig @@ -12,5 +12,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun50i-h5-orangepi-zero-plus" # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/parrot_r16_defconfig b/configs/parrot_r16_defconfig index 553a8d6572..936f08185f 100644 --- a/configs/parrot_r16_defconfig +++ b/configs/parrot_r16_defconfig @@ -17,6 +17,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-r16-parrot" # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_CONS_INDEX=5 +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/pine64_plus_defconfig b/configs/pine64_plus_defconfig index 21ce06f370..c632d24456 100644 --- a/configs/pine64_plus_defconfig +++ b/configs/pine64_plus_defconfig @@ -12,5 +12,6 @@ CONFIG_OF_LIST="sun50i-a64-pine64 sun50i-a64-pine64-plus" CONFIG_PHY_REALTEK=y CONFIG_RTL8211E_PINE64_GIGABIT_FIX=y CONFIG_SUN8I_EMAC=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/r7-tv-dongle_defconfig b/configs/r7-tv-dongle_defconfig index 9a66ee90f9..eaf7f4816a 100644 --- a/configs/r7-tv-dongle_defconfig +++ b/configs/r7-tv-dongle_defconfig @@ -12,5 +12,6 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_AXP152_POWER=y CONFIG_CONS_INDEX=2 +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/sopine_baseboard_defconfig b/configs/sopine_baseboard_defconfig index c79c111b5d..0da899c155 100644 --- a/configs/sopine_baseboard_defconfig +++ b/configs/sopine_baseboard_defconfig @@ -16,5 +16,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-sopine-baseboard" # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/sun8i_a23_evb_defconfig b/configs/sun8i_a23_evb_defconfig index 4cb2798ce7..c32f024cd2 100644 --- a/configs/sun8i_a23_evb_defconfig +++ b/configs/sun8i_a23_evb_defconfig @@ -13,5 +13,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-evb" # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_CONS_INDEX=5 +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/sunxi_Gemei_G9_defconfig b/configs/sunxi_Gemei_G9_defconfig index d88dd4ebad..c42074c0d8 100644 --- a/configs/sunxi_Gemei_G9_defconfig +++ b/configs/sunxi_Gemei_G9_defconfig @@ -15,5 +15,6 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/tbs_a711_defconfig b/configs/tbs_a711_defconfig index 5d58f5ceb4..d7d99c4dba 100644 --- a/configs/tbs_a711_defconfig +++ b/configs/tbs_a711_defconfig @@ -18,6 +18,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-tbs-a711" # CONFIG_SPL_EFI_PARTITION is not set CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_AXP_DCDC5_VOLT=1200 +CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_FUNCTION_MASS_STORAGE=y diff --git a/drivers/usb/host/Kconfig b/drivers/usb/host/Kconfig index b4dd005651..60a152704a 100644 --- a/drivers/usb/host/Kconfig +++ b/drivers/usb/host/Kconfig @@ -191,6 +191,7 @@ config USB_EHCI_GENERIC bool "Support for generic EHCI USB controller" depends on OF_CONTROL depends on DM_USB + default ARCH_SUNXI default n ---help--- Enables support for generic EHCI controller. @@ -221,6 +222,7 @@ config USB_OHCI_GENERIC bool "Support for generic OHCI USB controller" depends on OF_CONTROL depends on DM_USB + default ARCH_SUNXI select USB_HOST ---help--- Enables support for generic OHCI controller. diff --git a/include/configs/sun4i.h b/include/configs/sun4i.h index af079a71ee..6033760583 100644 --- a/include/configs/sun4i.h +++ b/include/configs/sun4i.h @@ -11,10 +11,6 @@ * A10 specific configuration */
-#ifdef CONFIG_USB_EHCI_HCD -#define CONFIG_USB_EHCI_SUNXI -#endif - /* * Include common sunxi configuration where most the settings are */ diff --git a/include/configs/sun50i.h b/include/configs/sun50i.h index 2d73c75b8c..e050a5299f 100644 --- a/include/configs/sun50i.h +++ b/include/configs/sun50i.h @@ -10,11 +10,6 @@ * A64 specific configuration */
-#ifdef CONFIG_USB_EHCI_HCD -#define CONFIG_USB_EHCI_SUNXI -#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 -#endif - #ifndef CONFIG_MACH_SUN50I_H6 #define GICD_BASE 0x1c81000 #define GICC_BASE 0x1c82000 diff --git a/include/configs/sun5i.h b/include/configs/sun5i.h index c3692caa73..ee42af80d4 100644 --- a/include/configs/sun5i.h +++ b/include/configs/sun5i.h @@ -11,10 +11,6 @@ * High Level Configuration Options */
-#ifdef CONFIG_USB_EHCI_HCD -#define CONFIG_USB_EHCI_SUNXI -#endif - /* * Include common sunxi configuration where most the settings are */ diff --git a/include/configs/sun6i.h b/include/configs/sun6i.h index 1523684fad..1e490daac1 100644 --- a/include/configs/sun6i.h +++ b/include/configs/sun6i.h @@ -14,10 +14,6 @@ * A31 specific configuration */
-#ifdef CONFIG_USB_EHCI_HCD -#define CONFIG_USB_EHCI_SUNXI -#endif - #define CONFIG_ARMV7_SECURE_BASE SUNXI_SRAM_B_BASE #define CONFIG_ARMV7_SECURE_MAX_SIZE (64 * 1024) /* 64 KB */
diff --git a/include/configs/sun7i.h b/include/configs/sun7i.h index bb8f217b25..d2fd586672 100644 --- a/include/configs/sun7i.h +++ b/include/configs/sun7i.h @@ -12,10 +12,6 @@ * A20 specific configuration */
diff --git a/include/configs/sun8i.h b/include/configs/sun8i.h index 7dc8693b76..9b4675e4c3 100644 --- a/include/configs/sun8i.h +++ b/include/configs/sun8i.h @@ -12,10 +12,6 @@ * A23 specific configuration */
-#ifdef CONFIG_USB_EHCI_HCD -#define CONFIG_USB_EHCI_SUNXI -#endif - /* * Include common sunxi configuration where most the settings are */ diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 93690481a1..f1578d3754 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -302,7 +302,6 @@ extern int soft_i2c_gpio_scl;
#ifdef CONFIG_USB_EHCI_HCD #define CONFIG_USB_OHCI_NEW -#define CONFIG_USB_OHCI_SUNXI #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 1 #endif
Now Allwinner platform is all set to use Generic USB controller drivers, so remove the legacy sunxi drivers.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/usb/host/Makefile | 2 - drivers/usb/host/ehci-sunxi.c | 204 ----------------------------- drivers/usb/host/ohci-sunxi.c | 233 ---------------------------------- scripts/config_whitelist.txt | 2 - 4 files changed, 441 deletions(-) delete mode 100644 drivers/usb/host/ehci-sunxi.c delete mode 100644 drivers/usb/host/ohci-sunxi.c
diff --git a/drivers/usb/host/Makefile b/drivers/usb/host/Makefile index cb8c315a15..b62fdbb1d2 100644 --- a/drivers/usb/host/Makefile +++ b/drivers/usb/host/Makefile @@ -15,7 +15,6 @@ obj-$(CONFIG_USB_OHCI_DA8XX) += ohci-da8xx.o obj-$(CONFIG_USB_R8A66597_HCD) += r8a66597-hcd.o obj-$(CONFIG_USB_SL811HS) += sl811-hcd.o obj-$(CONFIG_USB_OHCI_EP93XX) += ohci-ep93xx.o -obj-$(CONFIG_USB_OHCI_SUNXI) += ohci-sunxi.o obj-$(CONFIG_USB_OHCI_LPC32XX) += ohci-lpc32xx.o obj-$(CONFIG_USB_OHCI_GENERIC) += ohci-generic.o
@@ -37,7 +36,6 @@ obj-$(CONFIG_USB_EHCI_MARVELL) += ehci-marvell.o obj-$(CONFIG_USB_EHCI_MSM) += ehci-msm.o obj-$(CONFIG_USB_EHCI_PCI) += ehci-pci.o obj-$(CONFIG_USB_EHCI_SPEAR) += ehci-spear.o -obj-$(CONFIG_USB_EHCI_SUNXI) += ehci-sunxi.o obj-$(CONFIG_USB_EHCI_TEGRA) += ehci-tegra.o obj-$(CONFIG_USB_EHCI_VCT) += ehci-vct.o obj-$(CONFIG_USB_EHCI_VF) += ehci-vf.o diff --git a/drivers/usb/host/ehci-sunxi.c b/drivers/usb/host/ehci-sunxi.c deleted file mode 100644 index 7a79931a97..0000000000 --- a/drivers/usb/host/ehci-sunxi.c +++ /dev/null @@ -1,204 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Sunxi ehci glue - * - * Copyright (C) 2015 Hans de Goede hdegoede@redhat.com - * Copyright (C) 2014 Roman Byshko rbyshko@gmail.com - * - * Based on code from - * Allwinner Technology Co., Ltd. <www.allwinnertech.com> - */ - -#include <common.h> -#include <asm/arch/clock.h> -#include <asm/io.h> -#include <dm.h> -#include "ehci.h" -#include <generic-phy.h> - -#ifdef CONFIG_SUNXI_GEN_SUN4I -#define BASE_DIST 0x8000 -#define AHB_CLK_DIST 2 -#else -#define BASE_DIST 0x1000 -#define AHB_CLK_DIST 1 -#endif - -#define SUN6I_AHB_RESET0_CFG_OFFSET 0x2c0 -#define SUN9I_AHB_RESET0_CFG_OFFSET 0x5a0 - -struct ehci_sunxi_cfg { - bool has_reset; - u32 extra_ahb_gate_mask; - u32 reset0_cfg_offset; -}; - -struct ehci_sunxi_priv { - struct ehci_ctrl ehci; - struct sunxi_ccm_reg *ccm; - u32 *reset0_cfg; - int ahb_gate_mask; /* Mask of ahb_gate0 clk gate bits for this hcd */ - struct phy phy; - const struct ehci_sunxi_cfg *cfg; -}; - -static int ehci_usb_probe(struct udevice *dev) -{ - struct usb_platdata *plat = dev_get_platdata(dev); - struct ehci_sunxi_priv *priv = dev_get_priv(dev); - struct ehci_hccr *hccr = (struct ehci_hccr *)devfdt_get_addr(dev); - struct ehci_hcor *hcor; - int extra_ahb_gate_mask = 0; - u8 reg_mask = 0; - int phys, ret; - - priv->cfg = (const struct ehci_sunxi_cfg *)dev_get_driver_data(dev); - priv->ccm = (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; - if (IS_ERR(priv->ccm)) - return PTR_ERR(priv->ccm); - - priv->reset0_cfg = (void *)priv->ccm + - priv->cfg->reset0_cfg_offset; - - phys = dev_count_phandle_with_args(dev, "phys", "#phy-cells"); - if (phys < 0) { - phys = 0; - goto no_phy; - } - - ret = generic_phy_get_by_name(dev, "usb", &priv->phy); - if (ret) { - pr_err("failed to get %s usb PHY\n", dev->name); - return ret; - } - - ret = generic_phy_init(&priv->phy); - if (ret) { - pr_err("failed to init %s USB PHY\n", dev->name); - return ret; - } - - ret = generic_phy_power_on(&priv->phy); - if (ret) { - pr_err("failed to power on %s USB PHY\n", dev->name); - return ret; - } - -no_phy: - /* - * This should go away once we've moved to the driver model for - * clocks resp. phys. - */ - reg_mask = ((uintptr_t)hccr - SUNXI_USB1_BASE) / BASE_DIST; - priv->ahb_gate_mask = 1 << AHB_GATE_OFFSET_USB_EHCI0; - extra_ahb_gate_mask = priv->cfg->extra_ahb_gate_mask; - priv->ahb_gate_mask <<= reg_mask * AHB_CLK_DIST; - extra_ahb_gate_mask <<= reg_mask * AHB_CLK_DIST; - - setbits_le32(&priv->ccm->ahb_gate0, - priv->ahb_gate_mask | extra_ahb_gate_mask); - if (priv->cfg->has_reset) - setbits_le32(priv->reset0_cfg, - priv->ahb_gate_mask | extra_ahb_gate_mask); - - hcor = (struct ehci_hcor *)((uintptr_t)hccr + - HC_LENGTH(ehci_readl(&hccr->cr_capbase))); - - return ehci_register(dev, hccr, hcor, NULL, 0, plat->init_type); -} - -static int ehci_usb_remove(struct udevice *dev) -{ - struct ehci_sunxi_priv *priv = dev_get_priv(dev); - int ret; - - if (generic_phy_valid(&priv->phy)) { - ret = generic_phy_exit(&priv->phy); - if (ret) { - pr_err("failed to exit %s USB PHY\n", dev->name); - return ret; - } - } - - ret = ehci_deregister(dev); - if (ret) - return ret; - - if (priv->cfg->has_reset) - clrbits_le32(priv->reset0_cfg, priv->ahb_gate_mask); - clrbits_le32(&priv->ccm->ahb_gate0, priv->ahb_gate_mask); - - return 0; -} - -static const struct ehci_sunxi_cfg sun4i_a10_cfg = { - .has_reset = false, -}; - -static const struct ehci_sunxi_cfg sun6i_a31_cfg = { - .has_reset = true, - .reset0_cfg_offset = SUN6I_AHB_RESET0_CFG_OFFSET, -}; - -static const struct ehci_sunxi_cfg sun8i_h3_cfg = { - .has_reset = true, - .extra_ahb_gate_mask = 1 << AHB_GATE_OFFSET_USB_OHCI0, - .reset0_cfg_offset = SUN6I_AHB_RESET0_CFG_OFFSET, -}; - -static const struct ehci_sunxi_cfg sun9i_a80_cfg = { - .has_reset = true, - .reset0_cfg_offset = SUN9I_AHB_RESET0_CFG_OFFSET, -}; - -static const struct udevice_id ehci_usb_ids[] = { - { - .compatible = "allwinner,sun4i-a10-ehci", - .data = (ulong)&sun4i_a10_cfg, - }, - { - .compatible = "allwinner,sun5i-a13-ehci", - .data = (ulong)&sun4i_a10_cfg, - }, - { - .compatible = "allwinner,sun6i-a31-ehci", - .data = (ulong)&sun6i_a31_cfg, - }, - { - .compatible = "allwinner,sun7i-a20-ehci", - .data = (ulong)&sun4i_a10_cfg, - }, - { - .compatible = "allwinner,sun8i-a23-ehci", - .data = (ulong)&sun6i_a31_cfg, - }, - { - .compatible = "allwinner,sun8i-a83t-ehci", - .data = (ulong)&sun6i_a31_cfg, - }, - { - .compatible = "allwinner,sun8i-h3-ehci", - .data = (ulong)&sun8i_h3_cfg, - }, - { - .compatible = "allwinner,sun9i-a80-ehci", - .data = (ulong)&sun9i_a80_cfg, - }, - { - .compatible = "allwinner,sun50i-a64-ehci", - .data = (ulong)&sun8i_h3_cfg, - }, - { /* sentinel */ } -}; - -U_BOOT_DRIVER(ehci_sunxi) = { - .name = "ehci_sunxi", - .id = UCLASS_USB, - .of_match = ehci_usb_ids, - .probe = ehci_usb_probe, - .remove = ehci_usb_remove, - .ops = &ehci_usb_ops, - .platdata_auto_alloc_size = sizeof(struct usb_platdata), - .priv_auto_alloc_size = sizeof(struct ehci_sunxi_priv), - .flags = DM_FLAG_ALLOC_PRIV_DMA, -}; diff --git a/drivers/usb/host/ohci-sunxi.c b/drivers/usb/host/ohci-sunxi.c deleted file mode 100644 index bb3c2475df..0000000000 --- a/drivers/usb/host/ohci-sunxi.c +++ /dev/null @@ -1,233 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Sunxi ohci glue - * - * Copyright (C) 2015 Hans de Goede hdegoede@redhat.com - * - * Based on code from - * Allwinner Technology Co., Ltd. <www.allwinnertech.com> - */ - -#include <common.h> -#include <asm/arch/clock.h> -#include <asm/io.h> -#include <dm.h> -#include <usb.h> -#include "ohci.h" -#include <generic-phy.h> - -#ifdef CONFIG_SUNXI_GEN_SUN4I -#define BASE_DIST 0x8000 -#define AHB_CLK_DIST 2 -#else -#define BASE_DIST 0x1000 -#define AHB_CLK_DIST 1 -#endif - -#define SUN6I_AHB_RESET0_CFG_OFFSET 0x2c0 -#define SUN9I_AHB_RESET0_CFG_OFFSET 0x5a0 - -struct ohci_sunxi_cfg { - bool has_reset; - u32 extra_ahb_gate_mask; - u32 extra_usb_gate_mask; - u32 reset0_cfg_offset; -}; - -struct ohci_sunxi_priv { - ohci_t ohci; - struct sunxi_ccm_reg *ccm; - u32 *reset0_cfg; - int ahb_gate_mask; /* Mask of ahb_gate0 clk gate bits for this hcd */ - int usb_gate_mask; /* Mask of usb_clk_cfg clk gate bits for this hcd */ - struct phy phy; - const struct ohci_sunxi_cfg *cfg; -}; - -static fdt_addr_t last_ohci_addr = 0; - -static int ohci_usb_probe(struct udevice *dev) -{ - struct usb_bus_priv *bus_priv = dev_get_uclass_priv(dev); - struct ohci_sunxi_priv *priv = dev_get_priv(dev); - struct ohci_regs *regs = (struct ohci_regs *)devfdt_get_addr(dev); - int extra_ahb_gate_mask = 0; - u8 reg_mask = 0; - int phys, ret; - - if ((fdt_addr_t)regs > last_ohci_addr) - last_ohci_addr = (fdt_addr_t)regs; - - priv->cfg = (const struct ohci_sunxi_cfg *)dev_get_driver_data(dev); - priv->ccm = (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; - if (IS_ERR(priv->ccm)) - return PTR_ERR(priv->ccm); - - priv->reset0_cfg = (void *)priv->ccm + - priv->cfg->reset0_cfg_offset; - - phys = dev_count_phandle_with_args(dev, "phys", "#phy-cells"); - if (phys < 0) { - phys = 0; - goto no_phy; - } - - ret = generic_phy_get_by_name(dev, "usb", &priv->phy); - if (ret) { - pr_err("failed to get %s usb PHY\n", dev->name); - return ret; - } - - ret = generic_phy_init(&priv->phy); - if (ret) { - pr_err("failed to init %s USB PHY\n", dev->name); - return ret; - } - - ret = generic_phy_power_on(&priv->phy); - if (ret) { - pr_err("failed to power on %s USB PHY\n", dev->name); - return ret; - } - -no_phy: - bus_priv->companion = true; - - /* - * This should go away once we've moved to the driver model for - * clocks resp. phys. - */ - reg_mask = ((uintptr_t)regs - (SUNXI_USB1_BASE + 0x400)) / BASE_DIST; - priv->ahb_gate_mask = 1 << AHB_GATE_OFFSET_USB_OHCI0; - extra_ahb_gate_mask = priv->cfg->extra_ahb_gate_mask; - priv->usb_gate_mask = CCM_USB_CTRL_OHCI0_CLK; - priv->ahb_gate_mask <<= reg_mask * AHB_CLK_DIST; - extra_ahb_gate_mask <<= reg_mask * AHB_CLK_DIST; - priv->usb_gate_mask <<= reg_mask; - - setbits_le32(&priv->ccm->ahb_gate0, - priv->ahb_gate_mask | extra_ahb_gate_mask); - setbits_le32(&priv->ccm->usb_clk_cfg, - priv->usb_gate_mask | priv->cfg->extra_usb_gate_mask); - if (priv->cfg->has_reset) - setbits_le32(priv->reset0_cfg, - priv->ahb_gate_mask | extra_ahb_gate_mask); - - return ohci_register(dev, regs); -} - -static int ohci_usb_remove(struct udevice *dev) -{ - struct ohci_sunxi_priv *priv = dev_get_priv(dev); - fdt_addr_t base_addr = devfdt_get_addr(dev); - int ret; - - if (generic_phy_valid(&priv->phy)) { - ret = generic_phy_exit(&priv->phy); - if (ret) { - pr_err("failed to exit %s USB PHY\n", dev->name); - return ret; - } - } - - ret = ohci_deregister(dev); - if (ret) - return ret; - - if (priv->cfg->has_reset) - clrbits_le32(priv->reset0_cfg, priv->ahb_gate_mask); - /* - * On the A64 CLK_USB_OHCI0 is the parent of CLK_USB_OHCI1, so - * we have to wait with bringing down any clock until the last - * OHCI controller is removed. - */ - if (!priv->cfg->extra_usb_gate_mask || base_addr == last_ohci_addr) { - u32 usb_gate_mask = priv->usb_gate_mask; - - usb_gate_mask |= priv->cfg->extra_usb_gate_mask; - clrbits_le32(&priv->ccm->usb_clk_cfg, usb_gate_mask); - } - - clrbits_le32(&priv->ccm->ahb_gate0, priv->ahb_gate_mask); - - return 0; -} - -static const struct ohci_sunxi_cfg sun4i_a10_cfg = { - .has_reset = false, -}; - -static const struct ohci_sunxi_cfg sun6i_a31_cfg = { - .has_reset = true, - .reset0_cfg_offset = SUN6I_AHB_RESET0_CFG_OFFSET, -}; - -static const struct ohci_sunxi_cfg sun8i_h3_cfg = { - .has_reset = true, - .extra_ahb_gate_mask = 1 << AHB_GATE_OFFSET_USB_EHCI0, - .reset0_cfg_offset = SUN6I_AHB_RESET0_CFG_OFFSET, -}; - -static const struct ohci_sunxi_cfg sun9i_a80_cfg = { - .has_reset = true, - .reset0_cfg_offset = SUN9I_AHB_RESET0_CFG_OFFSET, -}; - -static const struct ohci_sunxi_cfg sun50i_a64_cfg = { - .has_reset = true, - .extra_ahb_gate_mask = 1 << AHB_GATE_OFFSET_USB_EHCI0, - .extra_usb_gate_mask = CCM_USB_CTRL_OHCI0_CLK, - .reset0_cfg_offset = SUN6I_AHB_RESET0_CFG_OFFSET, -}; - -static const struct udevice_id ohci_usb_ids[] = { - { - .compatible = "allwinner,sun4i-a10-ohci", - .data = (ulong)&sun4i_a10_cfg, - }, - { - .compatible = "allwinner,sun5i-a13-ohci", - .data = (ulong)&sun4i_a10_cfg, - }, - { - .compatible = "allwinner,sun6i-a31-ohci", - .data = (ulong)&sun6i_a31_cfg, - }, - { - .compatible = "allwinner,sun7i-a20-ohci", - .data = (ulong)&sun4i_a10_cfg, - }, - { - .compatible = "allwinner,sun8i-a23-ohci", - .data = (ulong)&sun6i_a31_cfg, - }, - { - .compatible = "allwinner,sun8i-a83t-ohci", - .data = (ulong)&sun6i_a31_cfg, - }, - { - .compatible = "allwinner,sun8i-h3-ohci", - .data = (ulong)&sun8i_h3_cfg, - }, - { - .compatible = "allwinner,sun9i-a80-ohci", - .data = (ulong)&sun9i_a80_cfg, - }, - { - .compatible = "allwinner,sun50i-a64-ohci", - .data = (ulong)&sun50i_a64_cfg, - }, - { /* sentinel */ } -}; - -U_BOOT_DRIVER(usb_ohci) = { - .name = "ohci_sunxi", - .id = UCLASS_USB, - .of_match = ohci_usb_ids, - .probe = ohci_usb_probe, - .remove = ohci_usb_remove, - .ops = &ohci_usb_ops, - .platdata_auto_alloc_size = sizeof(struct usb_platdata), - .priv_auto_alloc_size = sizeof(struct ohci_sunxi_priv), - .flags = DM_FLAG_ALLOC_PRIV_DMA, -}; diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 0d60da3f28..4cca3d1c73 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -4611,7 +4611,6 @@ CONFIG_USB_EHCI_MX5 CONFIG_USB_EHCI_MXC CONFIG_USB_EHCI_MXS CONFIG_USB_EHCI_SPEAR -CONFIG_USB_EHCI_SUNXI CONFIG_USB_EHCI_TEGRA CONFIG_USB_EHCI_TXFIFO_THRESH CONFIG_USB_EHCI_VCT @@ -4653,7 +4652,6 @@ CONFIG_USB_OHCI CONFIG_USB_OHCI_EP93XX CONFIG_USB_OHCI_LPC32XX CONFIG_USB_OHCI_NEW -CONFIG_USB_OHCI_SUNXI CONFIG_USB_OTG CONFIG_USB_OTG_BLACKLIST_HUB CONFIG_USB_PHY_CFG_BASE
Implement AHB bus MMC clocks for all Allwinner SoC clock drivers via clock map descriptor table.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/clk/sunxi/clk_a10.c | 4 ++++ drivers/clk/sunxi/clk_a10s.c | 3 +++ drivers/clk/sunxi/clk_a23.c | 3 +++ drivers/clk/sunxi/clk_a31.c | 4 ++++ drivers/clk/sunxi/clk_a64.c | 3 +++ drivers/clk/sunxi/clk_a83t.c | 3 +++ drivers/clk/sunxi/clk_h3.c | 3 +++ drivers/clk/sunxi/clk_r40.c | 4 ++++ drivers/clk/sunxi/clk_v3s.c | 3 +++ 9 files changed, 30 insertions(+)
diff --git a/drivers/clk/sunxi/clk_a10.c b/drivers/clk/sunxi/clk_a10.c index 7492e1367a..fb11231dd1 100644 --- a/drivers/clk/sunxi/clk_a10.c +++ b/drivers/clk/sunxi/clk_a10.c @@ -18,6 +18,10 @@ static struct ccu_clk_map a10_clks[] = { [CLK_AHB_OHCI0] = { 0x060, BIT(2), NULL }, [CLK_AHB_EHCI1] = { 0x060, BIT(3), NULL }, [CLK_AHB_OHCI1] = { 0x060, BIT(4), NULL }, + [CLK_AHB_MMC0] = { 0x060, BIT(8), NULL }, + [CLK_AHB_MMC1] = { 0x060, BIT(9), NULL }, + [CLK_AHB_MMC2] = { 0x060, BIT(10), NULL }, + [CLK_AHB_MMC3] = { 0x060, BIT(11), NULL },
[CLK_USB_OHCI0] = { 0x0cc, BIT(6), NULL }, [CLK_USB_OHCI1] = { 0x0cc, BIT(7), NULL }, diff --git a/drivers/clk/sunxi/clk_a10s.c b/drivers/clk/sunxi/clk_a10s.c index 45ef10d7a5..ba5e2e323d 100644 --- a/drivers/clk/sunxi/clk_a10s.c +++ b/drivers/clk/sunxi/clk_a10s.c @@ -16,6 +16,9 @@ static struct ccu_clk_map a10s_clks[] = { [CLK_AHB_OTG] = { 0x060, BIT(0), NULL }, [CLK_AHB_EHCI] = { 0x060, BIT(1), NULL }, [CLK_AHB_OHCI] = { 0x060, BIT(2), NULL }, + [CLK_AHB_MMC0] = { 0x060, BIT(8), NULL }, + [CLK_AHB_MMC1] = { 0x060, BIT(9), NULL }, + [CLK_AHB_MMC2] = { 0x060, BIT(10), NULL },
[CLK_USB_OHCI] = { 0x0cc, BIT(6), NULL }, [CLK_USB_PHY0] = { 0x0cc, BIT(8), NULL }, diff --git a/drivers/clk/sunxi/clk_a23.c b/drivers/clk/sunxi/clk_a23.c index 424e065a66..43e6dd63bf 100644 --- a/drivers/clk/sunxi/clk_a23.c +++ b/drivers/clk/sunxi/clk_a23.c @@ -13,6 +13,9 @@ #include <dt-bindings/reset/sun8i-a23-a33-ccu.h>
static struct ccu_clk_map a23_clks[] = { + [CLK_BUS_MMC0] = { 0x060, BIT(8), NULL }, + [CLK_BUS_MMC1] = { 0x060, BIT(9), NULL }, + [CLK_BUS_MMC2] = { 0x060, BIT(10), NULL }, [CLK_BUS_OTG] = { 0x060, BIT(24), NULL }, [CLK_BUS_EHCI] = { 0x060, BIT(26), NULL }, [CLK_BUS_OHCI] = { 0x060, BIT(29), NULL }, diff --git a/drivers/clk/sunxi/clk_a31.c b/drivers/clk/sunxi/clk_a31.c index c6d82be120..f314feff69 100644 --- a/drivers/clk/sunxi/clk_a31.c +++ b/drivers/clk/sunxi/clk_a31.c @@ -13,6 +13,10 @@ #include <dt-bindings/reset/sun6i-a31-ccu.h>
static struct ccu_clk_map a31_clks[] = { + [CLK_AHB1_MMC0] = { 0x060, BIT(8), NULL }, + [CLK_AHB1_MMC1] = { 0x060, BIT(9), NULL }, + [CLK_AHB1_MMC2] = { 0x060, BIT(10), NULL }, + [CLK_AHB1_MMC3] = { 0x060, BIT(12), NULL }, [CLK_AHB1_OTG] = { 0x060, BIT(24), NULL }, [CLK_AHB1_EHCI0] = { 0x060, BIT(26), NULL }, [CLK_AHB1_EHCI1] = { 0x060, BIT(27), NULL }, diff --git a/drivers/clk/sunxi/clk_a64.c b/drivers/clk/sunxi/clk_a64.c index 890bf8ca21..0574b88f9b 100644 --- a/drivers/clk/sunxi/clk_a64.c +++ b/drivers/clk/sunxi/clk_a64.c @@ -13,6 +13,9 @@ #include <dt-bindings/reset/sun50i-a64-ccu.h>
static struct ccu_clk_map a64_clks[] = { + [CLK_BUS_MMC0] = { 0x060, BIT(8), NULL }, + [CLK_BUS_MMC1] = { 0x060, BIT(9), NULL }, + [CLK_BUS_MMC2] = { 0x060, BIT(10), NULL }, [CLK_BUS_OTG] = { 0x060, BIT(23), NULL }, [CLK_BUS_EHCI0] = { 0x060, BIT(24), NULL }, [CLK_BUS_EHCI1] = { 0x060, BIT(25), NULL }, diff --git a/drivers/clk/sunxi/clk_a83t.c b/drivers/clk/sunxi/clk_a83t.c index 58d28eb6ad..cc18975a06 100644 --- a/drivers/clk/sunxi/clk_a83t.c +++ b/drivers/clk/sunxi/clk_a83t.c @@ -13,6 +13,9 @@ #include <dt-bindings/reset/sun8i-a83t-ccu.h>
static struct ccu_clk_map a83t_clks[] = { + [CLK_BUS_MMC0] = { 0x060, BIT(8), NULL }, + [CLK_BUS_MMC1] = { 0x060, BIT(9), NULL }, + [CLK_BUS_MMC2] = { 0x060, BIT(10), NULL }, [CLK_BUS_OTG] = { 0x060, BIT(24), NULL }, [CLK_BUS_EHCI0] = { 0x060, BIT(26), NULL }, [CLK_BUS_EHCI1] = { 0x060, BIT(27), NULL }, diff --git a/drivers/clk/sunxi/clk_h3.c b/drivers/clk/sunxi/clk_h3.c index 96bf2f4fa9..505616a889 100644 --- a/drivers/clk/sunxi/clk_h3.c +++ b/drivers/clk/sunxi/clk_h3.c @@ -13,6 +13,9 @@ #include <dt-bindings/reset/sun8i-h3-ccu.h>
static struct ccu_clk_map h3_clks[] = { + [CLK_BUS_MMC0] = { 0x060, BIT(8), NULL }, + [CLK_BUS_MMC1] = { 0x060, BIT(9), NULL }, + [CLK_BUS_MMC2] = { 0x060, BIT(10), NULL }, [CLK_BUS_OTG] = { 0x060, BIT(23), NULL }, [CLK_BUS_EHCI0] = { 0x060, BIT(24), NULL }, [CLK_BUS_EHCI1] = { 0x060, BIT(25), NULL }, diff --git a/drivers/clk/sunxi/clk_r40.c b/drivers/clk/sunxi/clk_r40.c index 746d6734b2..006aa138b6 100644 --- a/drivers/clk/sunxi/clk_r40.c +++ b/drivers/clk/sunxi/clk_r40.c @@ -13,6 +13,10 @@ #include <dt-bindings/reset/sun8i-r40-ccu.h>
static struct ccu_clk_map r40_clks[] = { + [CLK_BUS_MMC0] = { 0x060, BIT(8), NULL }, + [CLK_BUS_MMC1] = { 0x060, BIT(9), NULL }, + [CLK_BUS_MMC2] = { 0x060, BIT(10), NULL }, + [CLK_BUS_MMC3] = { 0x060, BIT(11), NULL }, [CLK_BUS_OTG] = { 0x060, BIT(25), NULL }, [CLK_BUS_EHCI0] = { 0x060, BIT(26), NULL }, [CLK_BUS_EHCI1] = { 0x060, BIT(27), NULL }, diff --git a/drivers/clk/sunxi/clk_v3s.c b/drivers/clk/sunxi/clk_v3s.c index 3bd793eb40..125b847bac 100644 --- a/drivers/clk/sunxi/clk_v3s.c +++ b/drivers/clk/sunxi/clk_v3s.c @@ -13,6 +13,9 @@ #include <dt-bindings/reset/sun8i-v3s-ccu.h>
static struct ccu_clk_map v3s_clks[] = { + [CLK_BUS_MMC0] = { 0x060, BIT(8), NULL }, + [CLK_BUS_MMC1] = { 0x060, BIT(9), NULL }, + [CLK_BUS_MMC2] = { 0x060, BIT(10), NULL }, [CLK_BUS_OTG] = { 0x060, BIT(24), NULL },
Implement direct MMC clocks for all Allwinner SoC clock drivers via clock map descriptor table.
This includes adding ccu_clk_set_rate function pointer, which indeed support CLK set_rate API, so update clock handling in sunxi_mmc driver to support both no-dm and dm code.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/include/asm/arch-sunxi/ccu.h | 10 +++++ drivers/clk/sunxi/clk_a10.c | 5 +++ drivers/clk/sunxi/clk_a10s.c | 6 +++ drivers/clk/sunxi/clk_a23.c | 6 +++ drivers/clk/sunxi/clk_a31.c | 5 +++ drivers/clk/sunxi/clk_a64.c | 4 ++ drivers/clk/sunxi/clk_a83t.c | 4 ++ drivers/clk/sunxi/clk_h3.c | 4 ++ drivers/clk/sunxi/clk_r40.c | 4 ++ drivers/clk/sunxi/clk_sunxi.c | 19 +++++++++ drivers/clk/sunxi/clk_v3s.c | 4 ++ drivers/mmc/sunxi_mmc.c | 58 +++++++++++++++++---------- 12 files changed, 107 insertions(+), 22 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/ccu.h b/arch/arm/include/asm/arch-sunxi/ccu.h index bacd052ef3..4e30ab330c 100644 --- a/arch/arm/include/asm/arch-sunxi/ccu.h +++ b/arch/arm/include/asm/arch-sunxi/ccu.h @@ -60,6 +60,16 @@ struct sunxi_clk_priv {
extern struct clk_ops sunxi_clk_ops;
+/** + * mmc_clk_set_rate - mmc clock set rate + * + * @base: clock register base address + * @bit: clock bit value + * @rate: clock input rate in Hz + * @return 0, or -ve error code. + */ +int mmc_clk_set_rate(void *base, u32 bit, ulong rate); + /** * sunxi_reset_bind() - reset binding * diff --git a/drivers/clk/sunxi/clk_a10.c b/drivers/clk/sunxi/clk_a10.c index fb11231dd1..55176bc174 100644 --- a/drivers/clk/sunxi/clk_a10.c +++ b/drivers/clk/sunxi/clk_a10.c @@ -23,6 +23,11 @@ static struct ccu_clk_map a10_clks[] = { [CLK_AHB_MMC2] = { 0x060, BIT(10), NULL }, [CLK_AHB_MMC3] = { 0x060, BIT(11), NULL },
+ [CLK_MMC0] = { 0x088, BIT(31), &mmc_clk_set_rate }, + [CLK_MMC1] = { 0x08c, BIT(31), &mmc_clk_set_rate }, + [CLK_MMC2] = { 0x090, BIT(31), &mmc_clk_set_rate }, + [CLK_MMC3] = { 0x094, BIT(31), &mmc_clk_set_rate }, + [CLK_USB_OHCI0] = { 0x0cc, BIT(6), NULL }, [CLK_USB_OHCI1] = { 0x0cc, BIT(7), NULL }, [CLK_USB_PHY] = { 0x0cc, BIT(8), NULL }, diff --git a/drivers/clk/sunxi/clk_a10s.c b/drivers/clk/sunxi/clk_a10s.c index ba5e2e323d..89c4897000 100644 --- a/drivers/clk/sunxi/clk_a10s.c +++ b/drivers/clk/sunxi/clk_a10s.c @@ -20,6 +20,12 @@ static struct ccu_clk_map a10s_clks[] = { [CLK_AHB_MMC1] = { 0x060, BIT(9), NULL }, [CLK_AHB_MMC2] = { 0x060, BIT(10), NULL },
+#ifdef CONFIG_MMC + [CLK_MMC0] = { 0x088, BIT(31), &mmc_clk_set_rate }, + [CLK_MMC1] = { 0x08c, BIT(31), &mmc_clk_set_rate }, + [CLK_MMC2] = { 0x090, BIT(31), &mmc_clk_set_rate }, +#endif + [CLK_USB_OHCI] = { 0x0cc, BIT(6), NULL }, [CLK_USB_PHY0] = { 0x0cc, BIT(8), NULL }, [CLK_USB_PHY1] = { 0x0cc, BIT(9), NULL }, diff --git a/drivers/clk/sunxi/clk_a23.c b/drivers/clk/sunxi/clk_a23.c index 43e6dd63bf..911d6987c8 100644 --- a/drivers/clk/sunxi/clk_a23.c +++ b/drivers/clk/sunxi/clk_a23.c @@ -20,6 +20,12 @@ static struct ccu_clk_map a23_clks[] = { [CLK_BUS_EHCI] = { 0x060, BIT(26), NULL }, [CLK_BUS_OHCI] = { 0x060, BIT(29), NULL },
+#ifdef CONFIG_MMC + [CLK_MMC0] = { 0x088, BIT(31), &mmc_clk_set_rate }, + [CLK_MMC1] = { 0x08c, BIT(31), &mmc_clk_set_rate }, + [CLK_MMC2] = { 0x090, BIT(31), &mmc_clk_set_rate }, +#endif + [CLK_USB_PHY0] = { 0x0cc, BIT(8), NULL }, [CLK_USB_PHY1] = { 0x0cc, BIT(9), NULL }, [CLK_USB_HSIC] = { 0x0cc, BIT(10), NULL }, diff --git a/drivers/clk/sunxi/clk_a31.c b/drivers/clk/sunxi/clk_a31.c index f314feff69..3c807bde77 100644 --- a/drivers/clk/sunxi/clk_a31.c +++ b/drivers/clk/sunxi/clk_a31.c @@ -24,6 +24,11 @@ static struct ccu_clk_map a31_clks[] = { [CLK_AHB1_OHCI1] = { 0x060, BIT(30), NULL }, [CLK_AHB1_OHCI2] = { 0x060, BIT(31), NULL },
+ [CLK_MMC0] = { 0x088, BIT(31), &mmc_clk_set_rate }, + [CLK_MMC1] = { 0x08c, BIT(31), &mmc_clk_set_rate }, + [CLK_MMC2] = { 0x090, BIT(31), &mmc_clk_set_rate }, + [CLK_MMC3] = { 0x094, BIT(31), &mmc_clk_set_rate }, + [CLK_USB_PHY0] = { 0x0cc, BIT(8), NULL }, [CLK_USB_PHY1] = { 0x0cc, BIT(9), NULL }, [CLK_USB_PHY2] = { 0x0cc, BIT(10), NULL }, diff --git a/drivers/clk/sunxi/clk_a64.c b/drivers/clk/sunxi/clk_a64.c index 0574b88f9b..a3392d7e8f 100644 --- a/drivers/clk/sunxi/clk_a64.c +++ b/drivers/clk/sunxi/clk_a64.c @@ -22,6 +22,10 @@ static struct ccu_clk_map a64_clks[] = { [CLK_BUS_OHCI0] = { 0x060, BIT(28), NULL }, [CLK_BUS_OHCI1] = { 0x060, BIT(29), NULL },
+ [CLK_MMC0] = { 0x088, BIT(31), &mmc_clk_set_rate }, + [CLK_MMC1] = { 0x08c, BIT(31), &mmc_clk_set_rate }, + [CLK_MMC2] = { 0x090, BIT(31), &mmc_clk_set_rate }, + [CLK_USB_PHY0] = { 0x0cc, BIT(8), NULL }, [CLK_USB_PHY1] = { 0x0cc, BIT(9), NULL }, [CLK_USB_HSIC] = { 0x0cc, BIT(10), NULL }, diff --git a/drivers/clk/sunxi/clk_a83t.c b/drivers/clk/sunxi/clk_a83t.c index cc18975a06..a2e0ac7a26 100644 --- a/drivers/clk/sunxi/clk_a83t.c +++ b/drivers/clk/sunxi/clk_a83t.c @@ -21,6 +21,10 @@ static struct ccu_clk_map a83t_clks[] = { [CLK_BUS_EHCI1] = { 0x060, BIT(27), NULL }, [CLK_BUS_OHCI0] = { 0x060, BIT(29), NULL },
+ [CLK_MMC0] = { 0x088, BIT(31), &mmc_clk_set_rate }, + [CLK_MMC1] = { 0x08c, BIT(31), &mmc_clk_set_rate }, + [CLK_MMC2] = { 0x090, BIT(31), &mmc_clk_set_rate }, + [CLK_USB_PHY0] = { 0x0cc, BIT(8), NULL }, [CLK_USB_PHY1] = { 0x0cc, BIT(9), NULL }, [CLK_USB_HSIC] = { 0x0cc, BIT(10), NULL }, diff --git a/drivers/clk/sunxi/clk_h3.c b/drivers/clk/sunxi/clk_h3.c index 505616a889..316c20889d 100644 --- a/drivers/clk/sunxi/clk_h3.c +++ b/drivers/clk/sunxi/clk_h3.c @@ -26,6 +26,10 @@ static struct ccu_clk_map h3_clks[] = { [CLK_BUS_OHCI2] = { 0x060, BIT(30), NULL }, [CLK_BUS_OHCI3] = { 0x060, BIT(31), NULL },
+ [CLK_MMC0] = { 0x088, BIT(31), &mmc_clk_set_rate }, + [CLK_MMC1] = { 0x08c, BIT(31), &mmc_clk_set_rate }, + [CLK_MMC2] = { 0x090, BIT(31), &mmc_clk_set_rate }, + [CLK_USB_PHY0] = { 0x0cc, BIT(8), NULL }, [CLK_USB_PHY1] = { 0x0cc, BIT(9), NULL }, [CLK_USB_PHY2] = { 0x0cc, BIT(10), NULL }, diff --git a/drivers/clk/sunxi/clk_r40.c b/drivers/clk/sunxi/clk_r40.c index 006aa138b6..9273f3b7ea 100644 --- a/drivers/clk/sunxi/clk_r40.c +++ b/drivers/clk/sunxi/clk_r40.c @@ -25,6 +25,10 @@ static struct ccu_clk_map r40_clks[] = { [CLK_BUS_OHCI1] = { 0x060, BIT(30), NULL }, [CLK_BUS_OHCI2] = { 0x060, BIT(31), NULL },
[CLK_USB_PHY0] = { 0x0cc, BIT(8), NULL }, [CLK_USB_PHY1] = { 0x0cc, BIT(9), NULL }, diff --git a/drivers/clk/sunxi/clk_sunxi.c b/drivers/clk/sunxi/clk_sunxi.c index 791b1ac7f2..ca147ec9cc 100644 --- a/drivers/clk/sunxi/clk_sunxi.c +++ b/drivers/clk/sunxi/clk_sunxi.c @@ -12,6 +12,24 @@ #include <asm/arch/ccu.h> #include <linux/log2.h>
+static ulong sunxi_clk_set_rate(struct clk *clk, ulong rate) +{ + struct sunxi_clk_priv *priv = dev_get_priv(clk->dev); + struct ccu_clk_map *map = &priv->desc->clks[clk->id]; + u32 *base; + + if (!map->ccu_clk_set_rate) { + debug("%s (CLK#%ld) unhandled\n", __func__, clk->id); + return 0; + } + + debug("%s(#%ld) off#0x%x, BIT(%d)\n", __func__, + clk->id, map->off, ilog2(map->bit)); + + base = priv->base + map->off; + return map->ccu_clk_set_rate(base, map->bit, rate); +} + static int sunxi_clk_enable(struct clk *clk) { struct sunxi_clk_priv *priv = dev_get_priv(clk->dev); @@ -55,4 +73,5 @@ static int sunxi_clk_disable(struct clk *clk) struct clk_ops sunxi_clk_ops = { .enable = sunxi_clk_enable, .disable = sunxi_clk_disable, + .set_rate = sunxi_clk_set_rate, }; diff --git a/drivers/clk/sunxi/clk_v3s.c b/drivers/clk/sunxi/clk_v3s.c index 125b847bac..4af6b9abfb 100644 --- a/drivers/clk/sunxi/clk_v3s.c +++ b/drivers/clk/sunxi/clk_v3s.c @@ -18,6 +18,10 @@ static struct ccu_clk_map v3s_clks[] = { [CLK_BUS_MMC2] = { 0x060, BIT(10), NULL }, [CLK_BUS_OTG] = { 0x060, BIT(24), NULL },
+ [CLK_MMC0] = { 0x088, BIT(31), &mmc_clk_set_rate }, + [CLK_MMC1] = { 0x08c, BIT(31), &mmc_clk_set_rate }, + [CLK_MMC2] = { 0x090, BIT(31), &mmc_clk_set_rate }, + [CLK_USB_PHY0] = { 0x0cc, BIT(8), NULL }, };
diff --git a/drivers/mmc/sunxi_mmc.c b/drivers/mmc/sunxi_mmc.c index 39f15eb423..bf82014a64 100644 --- a/drivers/mmc/sunxi_mmc.c +++ b/drivers/mmc/sunxi_mmc.c @@ -13,6 +13,7 @@ #include <malloc.h> #include <mmc.h> #include <asm/io.h> +#include <asm/arch/ccu.h> #include <asm/arch/clock.h> #include <asm/arch/cpu.h> #include <asm/arch/gpio.h> @@ -34,6 +35,8 @@ struct sunxi_mmc_priv { struct mmc_config cfg; };
+bool new_mode; + #if !CONFIG_IS_ENABLED(DM_MMC) /* support 4 mmc hosts */ struct sunxi_mmc_priv mmc_host[4]; @@ -95,23 +98,19 @@ static int mmc_resource_init(int sdc_no) } #endif
-static int mmc_set_mod_clk(struct sunxi_mmc_priv *priv, unsigned int hz) +int mmc_clk_set_rate(void *base, u32 bit, ulong rate) { unsigned int pll, pll_hz, div, n, oclk_dly, sclk_dly; - bool new_mode = false; u32 val = 0;
- if (IS_ENABLED(CONFIG_MMC_SUNXI_HAS_NEW_MODE) && (priv->mmc_no == 2)) - new_mode = true; - /* * The MMC clock has an extra /2 post-divider when operating in the new * mode. */ if (new_mode) - hz = hz * 2; + rate = rate * 2;
- if (hz <= 24000000) { + if (rate <= 24000000) { pll = CCM_MMC_CTRL_OSCM24; pll_hz = 24000000; } else { @@ -127,8 +126,8 @@ static int mmc_set_mod_clk(struct sunxi_mmc_priv *priv, unsigned int hz) #endif }
- div = pll_hz / hz; - if (pll_hz % hz) + div = pll_hz / rate; + if (pll_hz % rate) div++;
n = 0; @@ -138,32 +137,31 @@ static int mmc_set_mod_clk(struct sunxi_mmc_priv *priv, unsigned int hz) }
if (n > 3) { - printf("mmc %u error cannot set clock to %u\n", priv->mmc_no, - hz); + printf("mmc error cannot set clock to %ld\n", rate); return -1; }
/* determine delays */ - if (hz <= 400000) { + if (rate <= 400000) { oclk_dly = 0; sclk_dly = 0; - } else if (hz <= 25000000) { + } else if (rate <= 25000000) { oclk_dly = 0; sclk_dly = 5; #ifdef CONFIG_MACH_SUN9I - } else if (hz <= 52000000) { + } else if (rate <= 52000000) { oclk_dly = 5; sclk_dly = 4; } else { - /* hz > 52000000 */ + /* rate > 52000000 */ oclk_dly = 2; sclk_dly = 4; #else - } else if (hz <= 52000000) { + } else if (rate <= 52000000) { oclk_dly = 3; sclk_dly = 4; } else { - /* hz > 52000000 */ + /* rate > 52000000 */ oclk_dly = 1; sclk_dly = 4; #endif @@ -172,22 +170,35 @@ static int mmc_set_mod_clk(struct sunxi_mmc_priv *priv, unsigned int hz) if (new_mode) { #ifdef CONFIG_MMC_SUNXI_HAS_NEW_MODE val = CCM_MMC_CTRL_MODE_SEL_NEW; - setbits_le32(&priv->reg->ntsr, SUNXI_MMC_NTSR_MODE_SEL_NEW); #endif } else { val = CCM_MMC_CTRL_OCLK_DLY(oclk_dly) | CCM_MMC_CTRL_SCLK_DLY(sclk_dly); }
- writel(CCM_MMC_CTRL_ENABLE| pll | CCM_MMC_CTRL_N(n) | - CCM_MMC_CTRL_M(div) | val, priv->mclkreg); + writel(bit | pll | CCM_MMC_CTRL_N(n) | + CCM_MMC_CTRL_M(div) | val, base);
- debug("mmc %u set mod-clk req %u parent %u n %u m %u rate %u\n", - priv->mmc_no, hz, pll_hz, 1u << n, div, pll_hz / (1u << n) / div); + debug("mmc set mod-clk req %ld parent %u n %u m %u rate %u\n", + rate, pll_hz, 1u << n, div, pll_hz / (1u << n) / div);
return 0; }
+static int mmc_set_mod_clk(struct sunxi_mmc_priv *priv, unsigned int hz) +{ +#if CONFIG_IS_ENABLED(DM_MMC) && CONFIG_IS_ENABLED(CLK) +#else + if (IS_ENABLED(CONFIG_MMC_SUNXI_HAS_NEW_MODE) && (priv->mmc_no == 2)) + new_mode = true; + + if (new_mode) + setbits_le32(&priv->reg->ntsr, SUNXI_MMC_NTSR_MODE_SEL_NEW); + + return mmc_clk_set_rate(priv->mclkreg, CCM_MMC_CTRL_ENABLE, hz); +#endif +} + static int mmc_update_clk(struct sunxi_mmc_priv *priv) { unsigned int cmd; @@ -599,6 +610,9 @@ static int sunxi_mmc_probe(struct udevice *dev) cfg->f_min = 400000; cfg->f_max = 52000000;
+ if (device_is_compatible(dev, "allwinner,sun8i-a83t-emmc")) + new_mode = true; + priv->reg = (void *)dev_read_addr(dev);
/* We don't have a sunxi clock driver so find the clock address here */
Implement AHB bus MMC resets for all Allwinner SoC clock drivers via reset map descriptor table.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/clk/sunxi/clk_a23.c | 3 +++ drivers/clk/sunxi/clk_a31.c | 4 ++++ drivers/clk/sunxi/clk_a64.c | 3 +++ drivers/clk/sunxi/clk_a83t.c | 3 +++ drivers/clk/sunxi/clk_h3.c | 3 +++ drivers/clk/sunxi/clk_r40.c | 4 ++++ drivers/clk/sunxi/clk_v3s.c | 3 +++ 7 files changed, 23 insertions(+)
diff --git a/drivers/clk/sunxi/clk_a23.c b/drivers/clk/sunxi/clk_a23.c index 911d6987c8..06a2e6bc79 100644 --- a/drivers/clk/sunxi/clk_a23.c +++ b/drivers/clk/sunxi/clk_a23.c @@ -38,6 +38,9 @@ static struct ccu_reset_map a23_resets[] = { [RST_USB_PHY1] = { 0x0cc, BIT(1) }, [RST_USB_HSIC] = { 0x0cc, BIT(2) },
+ [RST_BUS_MMC0] = { 0x2c0, BIT(8) }, + [RST_BUS_MMC1] = { 0x2c0, BIT(9) }, + [RST_BUS_MMC2] = { 0x2c0, BIT(10) }, [RST_BUS_OTG] = { 0x2c0, BIT(24) }, [RST_BUS_EHCI] = { 0x2c0, BIT(26) }, [RST_BUS_OHCI] = { 0x2c0, BIT(29) }, diff --git a/drivers/clk/sunxi/clk_a31.c b/drivers/clk/sunxi/clk_a31.c index 3c807bde77..15076d0e72 100644 --- a/drivers/clk/sunxi/clk_a31.c +++ b/drivers/clk/sunxi/clk_a31.c @@ -42,6 +42,10 @@ static struct ccu_reset_map a31_resets[] = { [RST_USB_PHY1] = { 0x0cc, BIT(1) }, [RST_USB_PHY2] = { 0x0cc, BIT(2) },
+ [RST_AHB1_MMC0] = { 0x2c0, BIT(8) }, + [RST_AHB1_MMC1] = { 0x2c0, BIT(9) }, + [RST_AHB1_MMC2] = { 0x2c0, BIT(10) }, + [RST_AHB1_MMC3] = { 0x2c0, BIT(11) }, [RST_AHB1_OTG] = { 0x2c0, BIT(24) }, [RST_AHB1_EHCI0] = { 0x2c0, BIT(26) }, [RST_AHB1_EHCI1] = { 0x2c0, BIT(27) }, diff --git a/drivers/clk/sunxi/clk_a64.c b/drivers/clk/sunxi/clk_a64.c index a3392d7e8f..5b652d5d7d 100644 --- a/drivers/clk/sunxi/clk_a64.c +++ b/drivers/clk/sunxi/clk_a64.c @@ -39,6 +39,9 @@ static struct ccu_reset_map a64_resets[] = { [RST_USB_PHY1] = { 0x0cc, BIT(1) }, [RST_USB_HSIC] = { 0x0cc, BIT(2) },
+ [RST_BUS_MMC0] = { 0x2c0, BIT(8) }, + [RST_BUS_MMC1] = { 0x2c0, BIT(9) }, + [RST_BUS_MMC2] = { 0x2c0, BIT(10) }, [RST_BUS_OTG] = { 0x2c0, BIT(23) }, [RST_BUS_EHCI0] = { 0x2c0, BIT(24) }, [RST_BUS_EHCI1] = { 0x2c0, BIT(25) }, diff --git a/drivers/clk/sunxi/clk_a83t.c b/drivers/clk/sunxi/clk_a83t.c index a2e0ac7a26..47b7672e7f 100644 --- a/drivers/clk/sunxi/clk_a83t.c +++ b/drivers/clk/sunxi/clk_a83t.c @@ -37,6 +37,9 @@ static struct ccu_reset_map a83t_resets[] = { [RST_USB_PHY1] = { 0x0cc, BIT(1) }, [RST_USB_HSIC] = { 0x0cc, BIT(2) },
+ [RST_BUS_MMC0] = { 0x2c0, BIT(8) }, + [RST_BUS_MMC1] = { 0x2c0, BIT(9) }, + [RST_BUS_MMC2] = { 0x2c0, BIT(10) }, [RST_BUS_OTG] = { 0x2c0, BIT(24) }, [RST_BUS_EHCI0] = { 0x2c0, BIT(26) }, [RST_BUS_EHCI1] = { 0x2c0, BIT(27) }, diff --git a/drivers/clk/sunxi/clk_h3.c b/drivers/clk/sunxi/clk_h3.c index 316c20889d..a47a9d04d5 100644 --- a/drivers/clk/sunxi/clk_h3.c +++ b/drivers/clk/sunxi/clk_h3.c @@ -46,6 +46,9 @@ static struct ccu_reset_map h3_resets[] = { [RST_USB_PHY2] = { 0x0cc, BIT(2) }, [RST_USB_PHY3] = { 0x0cc, BIT(3) },
+ [RST_BUS_MMC0] = { 0x2c0, BIT(8) }, + [RST_BUS_MMC1] = { 0x2c0, BIT(9) }, + [RST_BUS_MMC2] = { 0x2c0, BIT(10) }, [RST_BUS_OTG] = { 0x2c0, BIT(23) }, [RST_BUS_EHCI0] = { 0x2c0, BIT(24) }, [RST_BUS_EHCI1] = { 0x2c0, BIT(25) }, diff --git a/drivers/clk/sunxi/clk_r40.c b/drivers/clk/sunxi/clk_r40.c index 9273f3b7ea..24c26ad3be 100644 --- a/drivers/clk/sunxi/clk_r40.c +++ b/drivers/clk/sunxi/clk_r40.c @@ -43,6 +43,10 @@ static struct ccu_reset_map r40_resets[] = { [RST_USB_PHY1] = { 0x0cc, BIT(1) }, [RST_USB_PHY2] = { 0x0cc, BIT(2) },
+ [RST_BUS_MMC0] = { 0x2c0, BIT(8) }, + [RST_BUS_MMC1] = { 0x2c0, BIT(9) }, + [RST_BUS_MMC2] = { 0x2c0, BIT(10) }, + [RST_BUS_MMC3] = { 0x2c0, BIT(11) }, [RST_BUS_OTG] = { 0x2c0, BIT(25) }, [RST_BUS_EHCI0] = { 0x2c0, BIT(26) }, [RST_BUS_EHCI1] = { 0x2c0, BIT(27) }, diff --git a/drivers/clk/sunxi/clk_v3s.c b/drivers/clk/sunxi/clk_v3s.c index 4af6b9abfb..c49990245c 100644 --- a/drivers/clk/sunxi/clk_v3s.c +++ b/drivers/clk/sunxi/clk_v3s.c @@ -28,6 +28,9 @@ static struct ccu_clk_map v3s_clks[] = { static struct ccu_reset_map v3s_resets[] = { [RST_USB_PHY0] = { 0x0cc, BIT(0) },
+ [RST_BUS_MMC0] = { 0x2c0, BIT(8) }, + [RST_BUS_MMC1] = { 0x2c0, BIT(9) }, + [RST_BUS_MMC2] = { 0x2c0, BIT(10) }, [RST_BUS_OTG] = { 0x2c0, BIT(24) }, };
Reset is an optional for some controllers with some families of CPU's with same SoC where the common IP driver can handle to drive the entire SoC families. optional reset get by name is useful for those drivers to make common way of reset handling.
Example, In Allwinner SoC with MMC controllers has no reset for Sun4i, 5i, 7i but reset have reset.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/reset/reset-uclass.c | 17 +++++++++++++++++ include/reset.h | 25 +++++++++++++++++++++++++ 2 files changed, 42 insertions(+)
diff --git a/drivers/reset/reset-uclass.c b/drivers/reset/reset-uclass.c index 99881b8b99..3bc280be5e 100644 --- a/drivers/reset/reset-uclass.c +++ b/drivers/reset/reset-uclass.c @@ -138,6 +138,23 @@ int reset_get_by_name(struct udevice *dev, const char *name, return reset_get_by_index(dev, index, reset_ctl); }
+int reset_get_by_name_optional(struct udevice *dev, const char *name, + struct reset_ctl *reset_ctl, bool optional) +{ + int index; + + debug("%s(dev=%p, name=%s, reset_ctl=%p)\n", __func__, dev, name, + reset_ctl); + reset_ctl->dev = NULL; + + index = dev_read_stringlist_search(dev, "reset-names", name); + if (index < 0) { + printf("reset_get_by_name_optional: optional = %d, index = %d\n", optional, index); + return optional ? 0 : index; + } + + return reset_get_by_index(dev, index, reset_ctl); +} int reset_request(struct reset_ctl *reset_ctl) { struct reset_ops *ops = reset_dev_ops(reset_ctl->dev); diff --git a/include/reset.h b/include/reset.h index a7bbc1c331..a5af31f549 100644 --- a/include/reset.h +++ b/include/reset.h @@ -132,6 +132,23 @@ int reset_get_bulk(struct udevice *dev, struct reset_ctl_bulk *bulk); int reset_get_by_name(struct udevice *dev, const char *name, struct reset_ctl *reset_ctl);
+/** + * reset_get_by_name_optional - Get/request a reset signal by name optionally. + * + * This look up and requests a reset signal similar to reset_get_by_name() + * but with optional flag. + * + * @dev: The client device. + * @name: The name of the reset signal to request, within the client's + * list of reset signals. + * @reset_ctl: A pointer to a reset control struct to initialize. + * @optional: Optional flag, true if reset is optional, false if reset is + * necessary which is same as reset_get_by_name() + * @return 0 if OK, or a negative error code. + */ +int reset_get_by_name_optional(struct udevice *dev, const char *name, + struct reset_ctl *reset_ctl, bool optional); + /** * reset_request - Request a reset signal. * @@ -254,6 +271,14 @@ static inline int reset_get_by_name(struct udevice *dev, const char *name, return -ENOTSUPP; }
+static inline int reset_get_by_name_optional(struct udevice *dev, + const char *name, + struct reset_ctl *reset_ctl, + bool optional) +{ + return -ENOTSUPP; +} + static inline int reset_free(struct reset_ctl *reset_ctl) { return 0;
Add reset_valid to check whether given reset is valid or not.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- include/reset.h | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/include/reset.h b/include/reset.h index a5af31f549..70130bb886 100644 --- a/include/reset.h +++ b/include/reset.h @@ -315,4 +315,15 @@ static inline int reset_release_bulk(struct reset_ctl_bulk *bulk) } #endif
+/** + * reset_valid() - check if reset is valid + * + * @reset_ctl: the reset to check + * @return TRUE if valid, or FALSE + */ +static inline bool reset_valid(struct reset_ctl *reset_ctl) +{ + return !!reset_ctl->dev; +} + #endif
Now CLK and RESET driver for Allwinner SoC are available, so add the relevant operations on mmc sunxi driver.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/mmc/sunxi_mmc.c | 60 +++++++++++++++++++++++++++++++---------- 1 file changed, 46 insertions(+), 14 deletions(-)
diff --git a/drivers/mmc/sunxi_mmc.c b/drivers/mmc/sunxi_mmc.c index bf82014a64..3011ec9498 100644 --- a/drivers/mmc/sunxi_mmc.c +++ b/drivers/mmc/sunxi_mmc.c @@ -8,10 +8,12 @@ */
#include <common.h> +#include <clk.h> #include <dm.h> #include <errno.h> #include <malloc.h> #include <mmc.h> +#include <reset.h> #include <asm/io.h> #include <asm/arch/ccu.h> #include <asm/arch/clock.h> @@ -26,8 +28,12 @@ struct sunxi_mmc_plat { };
struct sunxi_mmc_priv { +#if CONFIG_IS_ENABLED(DM_MMC) && CONFIG_IS_ENABLED(CLK) + struct clk mmc_clk; +#else unsigned mmc_no; uint32_t *mclkreg; +#endif unsigned fatal_err; struct gpio_desc cd_gpio; /* Change Detect GPIO */ int cd_inverted; /* Inverted Card Detect */ @@ -188,6 +194,15 @@ int mmc_clk_set_rate(void *base, u32 bit, ulong rate) static int mmc_set_mod_clk(struct sunxi_mmc_priv *priv, unsigned int hz) { #if CONFIG_IS_ENABLED(DM_MMC) && CONFIG_IS_ENABLED(CLK) + int ret; + + ret = clk_set_rate(&priv->mmc_clk, hz); + if (ret) { + dev_err(dev, "failed to set rate for mmc_clk\n"); + return ret; + } + + return ret; #else if (IS_ENABLED(CONFIG_MMC_SUNXI_HAS_NEW_MODE) && (priv->mmc_no == 2)) new_mode = true; @@ -379,7 +394,7 @@ static int sunxi_mmc_send_cmd_common(struct sunxi_mmc_priv *priv, writel(data->blocks * data->blocksize, &priv->reg->bytecnt); }
- debug("mmc %d, cmd %d(0x%08x), arg 0x%08x\n", priv->mmc_no, + debug("mmc cmd %d(0x%08x), arg 0x%08x\n", cmd->cmdidx, cmdval | cmd->cmdidx, cmd->cmdarg); writel(cmd->cmdarg, &priv->reg->arg);
@@ -591,8 +606,8 @@ static int sunxi_mmc_probe(struct udevice *dev) struct sunxi_mmc_plat *plat = dev_get_platdata(dev); struct sunxi_mmc_priv *priv = dev_get_priv(dev); struct mmc_config *cfg = &plat->cfg; - struct ofnode_phandle_args args; - u32 *gate_reg; + struct clk ahb_clk; + struct reset_ctl reset; int bus_width, ret;
cfg->name = dev->name; @@ -615,20 +630,37 @@ static int sunxi_mmc_probe(struct udevice *dev)
- /* We don't have a sunxi clock driver so find the clock address here */ - ret = dev_read_phandle_with_args(dev, "clocks", "#clock-cells", 0, - 1, &args); - if (ret) + ret = clk_get_by_name(dev, "ahb", &ahb_clk); + if (ret) { + dev_err(dev, "falied to get ahb clock\n"); return ret; - priv->mclkreg = (u32 *)ofnode_get_addr(args.node); + }
- ret = dev_read_phandle_with_args(dev, "clocks", "#clock-cells", 0, - 0, &args); - if (ret) + ret = clk_get_by_name(dev, "mmc", &priv->mmc_clk); + if (ret) { + dev_err(dev, "falied to get mmc clock\n"); return ret; - gate_reg = (u32 *)ofnode_get_addr(args.node); - setbits_le32(gate_reg, 1 << args.args[0]); - priv->mmc_no = args.args[0] - 8; + } + + ret = reset_get_by_name_optional(dev, "ahb", &reset, true); + if (ret) { + dev_err(dev, "falied to get ahb reset\n"); + return ret; + } + + ret = clk_enable(&ahb_clk); + if (ret) { + dev_err(dev, "failed to enable ahb clock\n"); + return ret; + } + + if (reset_valid(&reset)) { + ret = reset_deassert(&reset); + if (ret) { + dev_err(dev, "failed to deassert ahb reset\n"); + return ret; + } + }
ret = mmc_set_mod_clk(priv, 24000000); if (ret)
Usually eMMC is default env fat device for environment, if MMC_SUNXI_SLOT_EXTRA != 1 Sunxi always probed emmc device as 1. but with DM_MMC it can be more possible to probe eMMC as device 2 since for most of the sunxi platforms eMMC is configured mmc2.
So update the fastboot mmc default device as 2 if DM_MMC and MMC_SUNXI_SLOT_EXTRA != 1 slot is 2 defined but some boards may not use all possible mmc devices or partly disabled in DT, for those update the device in board specific defconfig.
Cc: Olliver Schinagl oliver@schinagl.nl Cc: Chen-Yu Tsai wens@csie.org Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- configs/A20-OLinuXino-Lime2-eMMC_defconfig | 1 + configs/Sinlinx_SinA33_defconfig | 1 + configs/amarula_a64_relic_defconfig | 1 + drivers/fastboot/Kconfig | 3 ++- 4 files changed, 5 insertions(+), 1 deletion(-)
diff --git a/configs/A20-OLinuXino-Lime2-eMMC_defconfig b/configs/A20-OLinuXino-Lime2-eMMC_defconfig index 2851a461e8..8cedf9cf24 100644 --- a/configs/A20-OLinuXino-Lime2-eMMC_defconfig +++ b/configs/A20-OLinuXino-Lime2-eMMC_defconfig @@ -30,4 +30,5 @@ CONFIG_SCSI=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=1 CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/Sinlinx_SinA33_defconfig b/configs/Sinlinx_SinA33_defconfig index 7f5aaab5fb..80741b58f9 100644 --- a/configs/Sinlinx_SinA33_defconfig +++ b/configs/Sinlinx_SinA33_defconfig @@ -22,5 +22,6 @@ CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=1 CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y CONFIG_USB_FUNCTION_MASS_STORAGE=y diff --git a/configs/amarula_a64_relic_defconfig b/configs/amarula_a64_relic_defconfig index b72cbfabc6..caeb3f6008 100644 --- a/configs/amarula_a64_relic_defconfig +++ b/configs/amarula_a64_relic_defconfig @@ -12,4 +12,5 @@ CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-amarula-relic" # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_MUSB_GADGET=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/drivers/fastboot/Kconfig b/drivers/fastboot/Kconfig index bc25ea1d9c..4a1bfd119c 100644 --- a/drivers/fastboot/Kconfig +++ b/drivers/fastboot/Kconfig @@ -88,7 +88,8 @@ config FASTBOOT_FLASH_MMC_DEV int "Define FASTBOOT MMC FLASH default device" depends on FASTBOOT_FLASH_MMC default 0 if ARCH_SUNXI && MMC_SUNXI_SLOT_EXTRA = -1 - default 1 if ARCH_SUNXI && MMC_SUNXI_SLOT_EXTRA != -1 + default 1 if ARCH_SUNXI && !DM_MMC && MMC_SUNXI_SLOT_EXTRA != -1 + default 2 if ARCH_SUNXI && DM_MMC && MMC_SUNXI_SLOT_EXTRA != -1 help The fastboot "flash" command requires additional information regarding the non-volatile storage device. Define this to
So update the env default device as 2 if DM_MMC and MMC_SUNXI_SLOT_EXTRA != 1 but some boards may not use all possible mmc devices or partly disabled in DT, for those update the device in board specific defconfig.
Cc: Olliver Schinagl oliver@schinagl.nl Cc: Hans de Goede hdegoede@redhat.com Cc: Marcus Cooper codekipper@gmail.com Cc: Stefan Mavrodiev stefan@olimex.com Cc: Paul Kocialkowski contact@paulk.fr Cc: Chen-Yu Tsai wens@csie.org Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- configs/A20-OLinuXino-Lime2-eMMC_defconfig | 1 + configs/A20-OLinuXino_MICRO-eMMC_defconfig | 1 + configs/A20-OLinuXino_MICRO_defconfig | 1 + configs/A20-Olimex-SOM-EVB_defconfig | 1 + configs/A20-Olimex-SOM204-EVB-eMMC_defconfig | 1 + configs/Mele_M3_defconfig | 1 + configs/Orangepi_mini_defconfig | 1 + configs/Sinlinx_SinA33_defconfig | 1 + configs/Yones_Toptech_BD1078_defconfig | 1 + configs/amarula_a64_relic_defconfig | 1 + env/Kconfig | 3 ++- 11 files changed, 12 insertions(+), 1 deletion(-)
diff --git a/configs/A20-OLinuXino-Lime2-eMMC_defconfig b/configs/A20-OLinuXino-Lime2-eMMC_defconfig index 8cedf9cf24..bc5820263c 100644 --- a/configs/A20-OLinuXino-Lime2-eMMC_defconfig +++ b/configs/A20-OLinuXino-Lime2-eMMC_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 CONFIG_MMC0_CD_PIN="PH1" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_ENV_FAT_DEVICE_AND_PART="1:auto" CONFIG_USB0_VBUS_PIN="PC17" CONFIG_USB0_VBUS_DET="PH5" CONFIG_I2C1_ENABLE=y diff --git a/configs/A20-OLinuXino_MICRO-eMMC_defconfig b/configs/A20-OLinuXino_MICRO-eMMC_defconfig index f7e7cbab0a..1552960d88 100644 --- a/configs/A20-OLinuXino_MICRO-eMMC_defconfig +++ b/configs/A20-OLinuXino_MICRO-eMMC_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 CONFIG_MMC0_CD_PIN="PH1" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_ENV_FAT_DEVICE_AND_PART="1:auto" CONFIG_I2C1_ENABLE=y CONFIG_VIDEO_VGA=y CONFIG_SATAPWR="PB8" diff --git a/configs/A20-OLinuXino_MICRO_defconfig b/configs/A20-OLinuXino_MICRO_defconfig index 8dcbdc08f9..b5f1b7efe2 100644 --- a/configs/A20-OLinuXino_MICRO_defconfig +++ b/configs/A20-OLinuXino_MICRO_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_CLK=384 CONFIG_MMC0_CD_PIN="PH1" CONFIG_MMC3_CD_PIN="PH11" CONFIG_MMC_SUNXI_SLOT_EXTRA=3 +CONFIG_ENV_FAT_DEVICE_AND_PART="1:auto" CONFIG_I2C1_ENABLE=y CONFIG_VIDEO_VGA=y CONFIG_SATAPWR="PB8" diff --git a/configs/A20-Olimex-SOM-EVB_defconfig b/configs/A20-Olimex-SOM-EVB_defconfig index a06499e2d0..58f6fbad91 100644 --- a/configs/A20-Olimex-SOM-EVB_defconfig +++ b/configs/A20-Olimex-SOM-EVB_defconfig @@ -7,6 +7,7 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_MMC3_CD_PIN="PH0" CONFIG_MMC3_PINS="PH" CONFIG_MMC_SUNXI_SLOT_EXTRA=3 +CONFIG_ENV_FAT_DEVICE_AND_PART="1:auto" CONFIG_USB0_VBUS_PIN="PB9" CONFIG_USB0_VBUS_DET="PH5" CONFIG_SATAPWR="PC3" diff --git a/configs/A20-Olimex-SOM204-EVB-eMMC_defconfig b/configs/A20-Olimex-SOM204-EVB-eMMC_defconfig index 3bb8c4c7e6..ac4f841c4e 100644 --- a/configs/A20-Olimex-SOM204-EVB-eMMC_defconfig +++ b/configs/A20-Olimex-SOM204-EVB-eMMC_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 CONFIG_MMC0_CD_PIN="PH1" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_ENV_FAT_DEVICE_AND_PART="1:auto" CONFIG_USB0_VBUS_PIN="PC17" CONFIG_USB0_VBUS_DET="PH5" CONFIG_I2C1_ENABLE=y diff --git a/configs/Mele_M3_defconfig b/configs/Mele_M3_defconfig index 22497aaeb4..bc447a4a90 100644 --- a/configs/Mele_M3_defconfig +++ b/configs/Mele_M3_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 CONFIG_MMC0_CD_PIN="PH1" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_ENV_FAT_DEVICE_AND_PART="1:auto" CONFIG_VIDEO_VGA=y CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-m3" diff --git a/configs/Orangepi_mini_defconfig b/configs/Orangepi_mini_defconfig index 7eeae25010..cfab739552 100644 --- a/configs/Orangepi_mini_defconfig +++ b/configs/Orangepi_mini_defconfig @@ -7,6 +7,7 @@ CONFIG_MACPWR="PH23" CONFIG_MMC0_CD_PIN="PH10" CONFIG_MMC3_CD_PIN="PH11" CONFIG_MMC_SUNXI_SLOT_EXTRA=3 +CONFIG_ENV_FAT_DEVICE_AND_PART="1:auto" CONFIG_USB1_VBUS_PIN="PH26" CONFIG_USB2_VBUS_PIN="PH22" CONFIG_VIDEO_COMPOSITE=y diff --git a/configs/Sinlinx_SinA33_defconfig b/configs/Sinlinx_SinA33_defconfig index 80741b58f9..2d7b295188 100644 --- a/configs/Sinlinx_SinA33_defconfig +++ b/configs/Sinlinx_SinA33_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_CLK=552 CONFIG_DRAM_ZQ=15291 CONFIG_MMC0_CD_PIN="PB4" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_ENV_FAT_DEVICE_AND_PART="1:auto" CONFIG_USB0_ID_DET="PH8" CONFIG_VIDEO_LCD_MODE="x:1024,y:600,depth:18,pclk_khz:66000,le:90,ri:160,up:3,lo:127,hs:70,vs:20,sync:3,vmode:0" CONFIG_VIDEO_LCD_DCLK_PHASE=0 diff --git a/configs/Yones_Toptech_BD1078_defconfig b/configs/Yones_Toptech_BD1078_defconfig index c49cbcbc3c..cad5618d54 100644 --- a/configs/Yones_Toptech_BD1078_defconfig +++ b/configs/Yones_Toptech_BD1078_defconfig @@ -7,6 +7,7 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_MMC1_CD_PIN="PH2" CONFIG_MMC1_PINS="PH" CONFIG_MMC_SUNXI_SLOT_EXTRA=1 +CONFIG_ENV_FAT_DEVICE_AND_PART="1:auto" CONFIG_USB0_VBUS_PIN="PB9" CONFIG_USB0_VBUS_DET="AXP0-VBUS-DETECT" CONFIG_AXP_GPIO=y diff --git a/configs/amarula_a64_relic_defconfig b/configs/amarula_a64_relic_defconfig index caeb3f6008..bb5c0ff7b2 100644 --- a/configs/amarula_a64_relic_defconfig +++ b/configs/amarula_a64_relic_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN50I=y CONFIG_RESERVE_ALLWINNER_BOOT0_HEADER=y CONFIG_DRAM_ODT_EN=y CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_ENV_FAT_DEVICE_AND_PART="0:auto" # CONFIG_VIDEO_DE2 is not set CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-amarula-relic" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/env/Kconfig b/env/Kconfig index be99efb937..99577f1b2e 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -374,7 +374,8 @@ config ENV_FAT_DEVICE_AND_PART default "0:1" if TI_COMMON_CMD_OPTIONS default "0:auto" if ARCH_ZYNQMP default "0:auto" if ARCH_SUNXI && MMC_SUNXI_SLOT_EXTRA = -1 - default "1:auto" if ARCH_SUNXI && MMC_SUNXI_SLOT_EXTRA != -1 + default "1:auto" if ARCH_SUNXI && !DM_MMC && MMC_SUNXI_SLOT_EXTRA != -1 + default "2:auto" if ARCH_SUNXI && DM_MMC && MMC_SUNXI_SLOT_EXTRA != -1 default "0" if ARCH_AT91 help Define this to a string to specify the partition of the device. It can
With DM_MMC the mmc devices are probed as per dt status and eMMC can probed maximum device of 2, if all nodes like mmc0, mmc1 and mmc2 status are 'okay'.
So update mmc_bootdev to 2 and add boot order as 2, 1, 0 devices. so-that it can to boot any identified device even if the respective device status disabled or unsupported.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- board/sunxi/board.c | 2 +- include/configs/sunxi-common.h | 4 +++- 2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 857d5ff010..89012daad1 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -775,7 +775,7 @@ int misc_init_r(void) } else if (boot == BOOT_DEVICE_MMC1) { env_set("mmc_bootdev", "0"); } else if (boot == BOOT_DEVICE_MMC2) { - env_set("mmc_bootdev", "1"); + env_set("mmc_bootdev", "2"); }
setup_environment(gd->fdt_blob); diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index f1578d3754..9016c048ab 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -377,8 +377,10 @@ extern int soft_i2c_gpio_scl; #define BOOTENV_DEV_MMC_AUTO(devtypeu, devtypel, instance) \ BOOTENV_DEV_MMC(MMC, mmc, 0) \ BOOTENV_DEV_MMC(MMC, mmc, 1) \ + BOOTENV_DEV_MMC(MMC, mmc, 2) \ "bootcmd_mmc_auto=" \ - "if test ${mmc_bootdev} -eq 1; then " \ + "if test ${mmc_bootdev} -eq 2; then " \ + "run bootcmd_mmc2; " \ "run bootcmd_mmc1; " \ "run bootcmd_mmc0; " \ "elif test ${mmc_bootdev} -eq 0; then " \
Enable DM_MMC for Allwinner A20 SoC.
Tested on A20-OLinuXino-LIME2.
Cc: Stefan Mavrodiev stefan@olimex.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/mach-sunxi/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index dce81b7d53..3fc30ee268 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -191,6 +191,7 @@ config MACH_SUN7I select ARCH_SUPPORT_PSCI select CLK select DRAM_SUN4I + select DM_MMC if MMC select PHY_SUN4I_USB select SUNXI_GEN_SUN4I select SUPPORT_SPL
Added H5, A64 compatible for mmc and emmc.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/mmc/sunxi_mmc.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/mmc/sunxi_mmc.c b/drivers/mmc/sunxi_mmc.c index 3011ec9498..5191a3e3dd 100644 --- a/drivers/mmc/sunxi_mmc.c +++ b/drivers/mmc/sunxi_mmc.c @@ -697,6 +697,8 @@ static const struct udevice_id sunxi_mmc_ids[] = { { .compatible = "allwinner,sun4i-a10-mmc" }, { .compatible = "allwinner,sun5i-a13-mmc" }, { .compatible = "allwinner,sun7i-a20-mmc" }, + { .compatible = "allwinner,sun50i-a64-mmc" }, + { .compatible = "allwinner,sun50i-a64-emmc" }, { } };
Enable DM_MMC for Allwinner H3/H5 SoCs.
Tested on H3: BPI-M2+ H5: Orangepi pc2, prime, zero+2
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 3fc30ee268..e911dd0722 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -134,6 +134,7 @@ config MACH_SUNXI_H3_H5 bool select CLK select DM_I2C + select DM_MMC if MMC select PHY_SUN4I_USB select SUNXI_DE2 select SUNXI_DRAM_DW
Enable DM_MMC for Allwinner A64 SoCs.
Tested on BPI-M64, Amarula A64-Relic
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index e911dd0722..a82fa50d1b 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -285,6 +285,7 @@ config MACH_SUN50I select ARM64 select CLK select DM_I2C + select DM_MMC if MMC select PHY_SUN4I_USB select SUNXI_DE2 select SUNXI_GEN_SUN6I
Add emmc compatible for A83T SoC.
Cc: VishnuPatekar vishnupatekar0510@gmail.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/mmc/sunxi_mmc.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/mmc/sunxi_mmc.c b/drivers/mmc/sunxi_mmc.c index 5191a3e3dd..229a7b2811 100644 --- a/drivers/mmc/sunxi_mmc.c +++ b/drivers/mmc/sunxi_mmc.c @@ -697,6 +697,7 @@ static const struct udevice_id sunxi_mmc_ids[] = { { .compatible = "allwinner,sun4i-a10-mmc" }, { .compatible = "allwinner,sun5i-a13-mmc" }, { .compatible = "allwinner,sun7i-a20-mmc" }, + { .compatible = "allwinner,sun8i-a83t-emmc" }, { .compatible = "allwinner,sun50i-a64-mmc" }, { .compatible = "allwinner,sun50i-a64-emmc" }, { }
Enable DM_MMC for Allwinner A83T SoC.
Tested on BPI-M3.
Cc: VishnuPatekar vishnupatekar0510@gmail.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/mach-sunxi/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index a82fa50d1b..d28ab9879f 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -230,6 +230,7 @@ config MACH_SUN8I_A83T bool "sun8i (Allwinner A83T)" select CPU_V7A select CLK + select DM_MMC if MMC select DRAM_SUN8I_A83T select PHY_SUN4I_USB select SUNXI_GEN_SUN6I
Enable DM_MMC for Allwinner V40 SoC.
Tested on BPI-M2 Ultra, BPI-M2 Berry.
Cc: Lothar Felten lothar.felten@gmail.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/mach-sunxi/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index d28ab9879f..584d22bfaf 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -254,6 +254,7 @@ config MACH_SUN8I_R40 select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI select CLK + select DM_MMC if MMC select SUNXI_GEN_SUN6I select SUPPORT_SPL select SUNXI_DRAM_DW
Enable DM_MMC for Allwinner A13/A31 SoC.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/mach-sunxi/Kconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 584d22bfaf..9e7021c574 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -164,6 +164,7 @@ config MACH_SUN5I select CLK select ARM_CORTEX_CPU_IS_UP select DRAM_SUN4I + select DM_MMC if MMC select PHY_SUN4I_USB select SUNXI_GEN_SUN4I select SUPPORT_SPL @@ -177,6 +178,7 @@ config MACH_SUN6I select ARCH_SUPPORT_PSCI select CLK select DRAM_SUN6I + select DM_MMC if MMC select PHY_SUN4I_USB select SUN6I_P2WI select SUN6I_PRCM
Enable DM_MMC for Allwinner A23/A33/V3S SoC.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/mach-sunxi/Kconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 9e7021c574..3de595c687 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -207,6 +207,7 @@ config MACH_SUN8I_A23 select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI select CLK + select DM_MMC if MMC select DRAM_SUN8I_A23 select PHY_SUN4I_USB select SUNXI_GEN_SUN6I @@ -221,6 +222,7 @@ config MACH_SUN8I_A33 select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI select CLK + select DM_MMC if MMC select DRAM_SUN8I_A33 select PHY_SUN4I_USB select SUNXI_GEN_SUN6I @@ -269,6 +271,7 @@ config MACH_SUN8I_V3S select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI select CLK + select DM_MMC if MMC select SUNXI_GEN_SUN6I select SUNXI_DRAM_DW select SUNXI_DRAM_DW_16BIT
Implement SPI AHB and MOD clocks for all Allwinner SoC clock drivers via clock map descriptor table.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/clk/sunxi/clk_a10.c | 9 +++++++++ drivers/clk/sunxi/clk_a10s.c | 7 +++++++ drivers/clk/sunxi/clk_a31.c | 9 +++++++++ drivers/clk/sunxi/clk_a64.c | 5 +++++ drivers/clk/sunxi/clk_h3.c | 5 +++++ drivers/clk/sunxi/clk_v3s.c | 3 +++ 6 files changed, 38 insertions(+)
diff --git a/drivers/clk/sunxi/clk_a10.c b/drivers/clk/sunxi/clk_a10.c index 55176bc174..ee499c402a 100644 --- a/drivers/clk/sunxi/clk_a10.c +++ b/drivers/clk/sunxi/clk_a10.c @@ -22,12 +22,21 @@ static struct ccu_clk_map a10_clks[] = { [CLK_AHB_MMC1] = { 0x060, BIT(9), NULL }, [CLK_AHB_MMC2] = { 0x060, BIT(10), NULL }, [CLK_AHB_MMC3] = { 0x060, BIT(11), NULL }, + [CLK_AHB_SPI0] = { 0x060, BIT(20), NULL }, + [CLK_AHB_SPI1] = { 0x060, BIT(21), NULL }, + [CLK_AHB_SPI2] = { 0x060, BIT(22), NULL }, + [CLK_AHB_SPI3] = { 0x060, BIT(23), NULL },
[CLK_MMC0] = { 0x088, BIT(31), &mmc_clk_set_rate }, [CLK_MMC1] = { 0x08c, BIT(31), &mmc_clk_set_rate }, [CLK_MMC2] = { 0x090, BIT(31), &mmc_clk_set_rate }, [CLK_MMC3] = { 0x094, BIT(31), &mmc_clk_set_rate },
+ [CLK_SPI0] = { 0x0a0, BIT(31), NULL }, + [CLK_SPI1] = { 0x0a4, BIT(31), NULL }, + [CLK_SPI2] = { 0x0a8, BIT(31), NULL }, + [CLK_SPI3] = { 0x0d4, BIT(31), NULL }, + [CLK_USB_OHCI0] = { 0x0cc, BIT(6), NULL }, [CLK_USB_OHCI1] = { 0x0cc, BIT(7), NULL }, [CLK_USB_PHY] = { 0x0cc, BIT(8), NULL }, diff --git a/drivers/clk/sunxi/clk_a10s.c b/drivers/clk/sunxi/clk_a10s.c index 89c4897000..0c71e5b698 100644 --- a/drivers/clk/sunxi/clk_a10s.c +++ b/drivers/clk/sunxi/clk_a10s.c @@ -19,6 +19,9 @@ static struct ccu_clk_map a10s_clks[] = { [CLK_AHB_MMC0] = { 0x060, BIT(8), NULL }, [CLK_AHB_MMC1] = { 0x060, BIT(9), NULL }, [CLK_AHB_MMC2] = { 0x060, BIT(10), NULL }, + [CLK_AHB_SPI0] = { 0x060, BIT(20), NULL }, + [CLK_AHB_SPI1] = { 0x060, BIT(21), NULL }, + [CLK_AHB_SPI2] = { 0x060, BIT(22), NULL },
#ifdef CONFIG_MMC [CLK_MMC0] = { 0x088, BIT(31), &mmc_clk_set_rate }, @@ -26,6 +29,10 @@ static struct ccu_clk_map a10s_clks[] = { [CLK_MMC2] = { 0x090, BIT(31), &mmc_clk_set_rate }, #endif
+ [CLK_SPI0] = { 0x0a0, BIT(31), NULL }, + [CLK_SPI1] = { 0x0a4, BIT(31), NULL }, + [CLK_SPI2] = { 0x0a8, BIT(31), NULL }, + [CLK_USB_OHCI] = { 0x0cc, BIT(6), NULL }, [CLK_USB_PHY0] = { 0x0cc, BIT(8), NULL }, [CLK_USB_PHY1] = { 0x0cc, BIT(9), NULL }, diff --git a/drivers/clk/sunxi/clk_a31.c b/drivers/clk/sunxi/clk_a31.c index 15076d0e72..1fa77e1272 100644 --- a/drivers/clk/sunxi/clk_a31.c +++ b/drivers/clk/sunxi/clk_a31.c @@ -17,6 +17,10 @@ static struct ccu_clk_map a31_clks[] = { [CLK_AHB1_MMC1] = { 0x060, BIT(9), NULL }, [CLK_AHB1_MMC2] = { 0x060, BIT(10), NULL }, [CLK_AHB1_MMC3] = { 0x060, BIT(12), NULL }, + [CLK_AHB1_SPI0] = { 0x060, BIT(20), NULL }, + [CLK_AHB1_SPI1] = { 0x060, BIT(21), NULL }, + [CLK_AHB1_SPI2] = { 0x060, BIT(22), NULL }, + [CLK_AHB1_SPI3] = { 0x060, BIT(23), NULL }, [CLK_AHB1_OTG] = { 0x060, BIT(24), NULL }, [CLK_AHB1_EHCI0] = { 0x060, BIT(26), NULL }, [CLK_AHB1_EHCI1] = { 0x060, BIT(27), NULL }, @@ -29,6 +33,11 @@ static struct ccu_clk_map a31_clks[] = { [CLK_MMC2] = { 0x090, BIT(31), &mmc_clk_set_rate }, [CLK_MMC3] = { 0x094, BIT(31), &mmc_clk_set_rate },
+ [CLK_SPI0] = { 0x0a0, BIT(31), NULL }, + [CLK_SPI1] = { 0x0a4, BIT(31), NULL }, + [CLK_SPI2] = { 0x0a8, BIT(31), NULL }, + [CLK_SPI3] = { 0x0ac, BIT(31), NULL }, + [CLK_USB_PHY0] = { 0x0cc, BIT(8), NULL }, [CLK_USB_PHY1] = { 0x0cc, BIT(9), NULL }, [CLK_USB_PHY2] = { 0x0cc, BIT(10), NULL }, diff --git a/drivers/clk/sunxi/clk_a64.c b/drivers/clk/sunxi/clk_a64.c index 5b652d5d7d..07e15fb1ac 100644 --- a/drivers/clk/sunxi/clk_a64.c +++ b/drivers/clk/sunxi/clk_a64.c @@ -16,6 +16,8 @@ static struct ccu_clk_map a64_clks[] = { [CLK_BUS_MMC0] = { 0x060, BIT(8), NULL }, [CLK_BUS_MMC1] = { 0x060, BIT(9), NULL }, [CLK_BUS_MMC2] = { 0x060, BIT(10), NULL }, + [CLK_BUS_SPI0] = { 0x060, BIT(20), NULL }, + [CLK_BUS_SPI1] = { 0x060, BIT(21), NULL }, [CLK_BUS_OTG] = { 0x060, BIT(23), NULL }, [CLK_BUS_EHCI0] = { 0x060, BIT(24), NULL }, [CLK_BUS_EHCI1] = { 0x060, BIT(25), NULL }, @@ -26,6 +28,9 @@ static struct ccu_clk_map a64_clks[] = { [CLK_MMC1] = { 0x08c, BIT(31), &mmc_clk_set_rate }, [CLK_MMC2] = { 0x090, BIT(31), &mmc_clk_set_rate },
+ [CLK_SPI0] = { 0x0a0, BIT(31), NULL }, + [CLK_SPI1] = { 0x0a4, BIT(31), NULL }, + [CLK_USB_PHY0] = { 0x0cc, BIT(8), NULL }, [CLK_USB_PHY1] = { 0x0cc, BIT(9), NULL }, [CLK_USB_HSIC] = { 0x0cc, BIT(10), NULL }, diff --git a/drivers/clk/sunxi/clk_h3.c b/drivers/clk/sunxi/clk_h3.c index a47a9d04d5..47647b6688 100644 --- a/drivers/clk/sunxi/clk_h3.c +++ b/drivers/clk/sunxi/clk_h3.c @@ -16,6 +16,8 @@ static struct ccu_clk_map h3_clks[] = { [CLK_BUS_MMC0] = { 0x060, BIT(8), NULL }, [CLK_BUS_MMC1] = { 0x060, BIT(9), NULL }, [CLK_BUS_MMC2] = { 0x060, BIT(10), NULL }, + [CLK_BUS_SPI0] = { 0x060, BIT(20), NULL }, + [CLK_BUS_SPI1] = { 0x060, BIT(21), NULL }, [CLK_BUS_OTG] = { 0x060, BIT(23), NULL }, [CLK_BUS_EHCI0] = { 0x060, BIT(24), NULL }, [CLK_BUS_EHCI1] = { 0x060, BIT(25), NULL }, @@ -30,6 +32,9 @@ static struct ccu_clk_map h3_clks[] = { [CLK_MMC1] = { 0x08c, BIT(31), &mmc_clk_set_rate }, [CLK_MMC2] = { 0x090, BIT(31), &mmc_clk_set_rate },
+ [CLK_SPI0] = { 0x0a0, BIT(31), NULL }, + [CLK_SPI1] = { 0x0a4, BIT(31), NULL }, + [CLK_USB_PHY0] = { 0x0cc, BIT(8), NULL }, [CLK_USB_PHY1] = { 0x0cc, BIT(9), NULL }, [CLK_USB_PHY2] = { 0x0cc, BIT(10), NULL }, diff --git a/drivers/clk/sunxi/clk_v3s.c b/drivers/clk/sunxi/clk_v3s.c index c49990245c..2595049eba 100644 --- a/drivers/clk/sunxi/clk_v3s.c +++ b/drivers/clk/sunxi/clk_v3s.c @@ -16,12 +16,15 @@ static struct ccu_clk_map v3s_clks[] = { [CLK_BUS_MMC0] = { 0x060, BIT(8), NULL }, [CLK_BUS_MMC1] = { 0x060, BIT(9), NULL }, [CLK_BUS_MMC2] = { 0x060, BIT(10), NULL }, + [CLK_BUS_SPI0] = { 0x060, BIT(20), NULL }, [CLK_BUS_OTG] = { 0x060, BIT(24), NULL },
+ [CLK_SPI0] = { 0x0a0, BIT(31), NULL }, + [CLK_USB_PHY0] = { 0x0cc, BIT(8), NULL }, };
Implement SPI resets for all relevant Allwinner SoC clock drivers via reset map descriptor table.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/clk/sunxi/clk_a31.c | 4 ++++ drivers/clk/sunxi/clk_a64.c | 2 ++ drivers/clk/sunxi/clk_h3.c | 2 ++ drivers/clk/sunxi/clk_v3s.c | 1 + 4 files changed, 9 insertions(+)
diff --git a/drivers/clk/sunxi/clk_a31.c b/drivers/clk/sunxi/clk_a31.c index 1fa77e1272..a5c6628c63 100644 --- a/drivers/clk/sunxi/clk_a31.c +++ b/drivers/clk/sunxi/clk_a31.c @@ -55,6 +55,10 @@ static struct ccu_reset_map a31_resets[] = { [RST_AHB1_MMC1] = { 0x2c0, BIT(9) }, [RST_AHB1_MMC2] = { 0x2c0, BIT(10) }, [RST_AHB1_MMC3] = { 0x2c0, BIT(11) }, + [RST_AHB1_SPI0] = { 0x2c0, BIT(20) }, + [RST_AHB1_SPI1] = { 0x2c0, BIT(21) }, + [RST_AHB1_SPI2] = { 0x2c0, BIT(22) }, + [RST_AHB1_SPI3] = { 0x2c0, BIT(23) }, [RST_AHB1_OTG] = { 0x2c0, BIT(24) }, [RST_AHB1_EHCI0] = { 0x2c0, BIT(26) }, [RST_AHB1_EHCI1] = { 0x2c0, BIT(27) }, diff --git a/drivers/clk/sunxi/clk_a64.c b/drivers/clk/sunxi/clk_a64.c index 07e15fb1ac..e991c8d2d1 100644 --- a/drivers/clk/sunxi/clk_a64.c +++ b/drivers/clk/sunxi/clk_a64.c @@ -47,6 +47,8 @@ static struct ccu_reset_map a64_resets[] = { [RST_BUS_MMC0] = { 0x2c0, BIT(8) }, [RST_BUS_MMC1] = { 0x2c0, BIT(9) }, [RST_BUS_MMC2] = { 0x2c0, BIT(10) }, + [RST_BUS_SPI0] = { 0x2c0, BIT(20) }, + [RST_BUS_SPI1] = { 0x2c0, BIT(21) }, [RST_BUS_OTG] = { 0x2c0, BIT(23) }, [RST_BUS_EHCI0] = { 0x2c0, BIT(24) }, [RST_BUS_EHCI1] = { 0x2c0, BIT(25) }, diff --git a/drivers/clk/sunxi/clk_h3.c b/drivers/clk/sunxi/clk_h3.c index 47647b6688..1cc32a0b91 100644 --- a/drivers/clk/sunxi/clk_h3.c +++ b/drivers/clk/sunxi/clk_h3.c @@ -54,6 +54,8 @@ static struct ccu_reset_map h3_resets[] = { [RST_BUS_MMC0] = { 0x2c0, BIT(8) }, [RST_BUS_MMC1] = { 0x2c0, BIT(9) }, [RST_BUS_MMC2] = { 0x2c0, BIT(10) }, + [RST_BUS_SPI0] = { 0x2c0, BIT(20) }, + [RST_BUS_SPI1] = { 0x2c0, BIT(21) }, [RST_BUS_OTG] = { 0x2c0, BIT(23) }, [RST_BUS_EHCI0] = { 0x2c0, BIT(24) }, [RST_BUS_EHCI1] = { 0x2c0, BIT(25) }, diff --git a/drivers/clk/sunxi/clk_v3s.c b/drivers/clk/sunxi/clk_v3s.c index 2595049eba..525b6dcb39 100644 --- a/drivers/clk/sunxi/clk_v3s.c +++ b/drivers/clk/sunxi/clk_v3s.c @@ -34,6 +34,7 @@ static struct ccu_reset_map v3s_resets[] = { [RST_BUS_MMC0] = { 0x2c0, BIT(8) }, [RST_BUS_MMC1] = { 0x2c0, BIT(9) }, [RST_BUS_MMC2] = { 0x2c0, BIT(10) }, + [RST_BUS_SPI0] = { 0x2c0, BIT(20) }, [RST_BUS_OTG] = { 0x2c0, BIT(24) }, };
Add CLK support to enable AHB and MOD SPI clocks on sun4i_spi driver.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/spi/sun4i_spi.c | 40 ++++++++++++++++++++++++++++++++++------ 1 file changed, 34 insertions(+), 6 deletions(-)
diff --git a/drivers/spi/sun4i_spi.c b/drivers/spi/sun4i_spi.c index b86b5a00ad..3be80bb39f 100644 --- a/drivers/spi/sun4i_spi.c +++ b/drivers/spi/sun4i_spi.c @@ -19,6 +19,7 @@ */
#include <common.h> +#include <clk.h> #include <dm.h> #include <spi.h> #include <errno.h> @@ -238,13 +239,36 @@ static int sun4i_spi_parse_pins(struct udevice *dev) return 0; }
-static inline void sun4i_spi_enable_clock(void) +static inline int sun4i_spi_enable_clock(struct udevice *dev) { - struct sunxi_ccm_reg *const ccm = - (struct sunxi_ccm_reg *const)SUNXI_CCM_BASE; + struct clk ahb_clk, mod_clk; + int ret; + + ret = clk_get_by_name(dev, "ahb", &ahb_clk); + if (ret) { + dev_err(dev, "falied to get ahb clock\n"); + return ret; + } + + ret = clk_get_by_name(dev, "mod", &mod_clk); + if (ret) { + dev_err(dev, "falied to get mod clock\n"); + return ret; + } + + ret = clk_enable(&ahb_clk); + if (ret) { + dev_err(dev, "failed to enable ahb clock\n"); + return ret; + } + + ret = clk_enable(&mod_clk); + if (ret) { + dev_err(dev, "failed to enable mod clock\n"); + return ret; + }
- setbits_le32(&ccm->ahb_gate0, (1 << AHB_GATE_OFFSET_SPI0)); - writel((1 << 31), &ccm->spi0_clk_cfg); + return 0; }
static int sun4i_spi_ofdata_to_platdata(struct udevice *bus) @@ -267,8 +291,12 @@ static int sun4i_spi_probe(struct udevice *bus) { struct sun4i_spi_platdata *plat = dev_get_platdata(bus); struct sun4i_spi_priv *priv = dev_get_priv(bus); + int ret; + + ret = sun4i_spi_enable_clock(bus); + if (ret) + return ret;
- sun4i_spi_enable_clock(); sun4i_spi_parse_pins(bus);
priv->regs = (struct sun4i_spi_regs *)(uintptr_t)plat->base_addr;
Add Allwinner sun6i SPI driver for A31, H3/H5 an A64.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/spi/Kconfig | 6 + drivers/spi/Makefile | 1 + drivers/spi/sun6i_spi.c | 475 ++++++++++++++++++++++++++++++++++++++++ 3 files changed, 482 insertions(+) create mode 100644 drivers/spi/sun6i_spi.c
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index dcd719ff0a..671658dddc 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -179,6 +179,12 @@ config SUN4I_SPI help SPI driver for Allwinner sun4i, sun5i and sun7i SoCs
+config SUN6I_SPI + bool "Allwinner A31 SPI controller" + depends on ARCH_SUNXI + help + This enables using the SPI controller on the Allwinner A31 SoCs. + config TEGRA114_SPI bool "nVidia Tegra114 SPI driver" help diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 728e30c538..6e60091bc1 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -45,6 +45,7 @@ obj-$(CONFIG_SH_SPI) += sh_spi.o obj-$(CONFIG_SH_QSPI) += sh_qspi.o obj-$(CONFIG_STM32_QSPI) += stm32_qspi.o obj-$(CONFIG_SUN4I_SPI) += sun4i_spi.o +obj-$(CONFIG_SUN6I_SPI) += sun6i_spi.o obj-$(CONFIG_TEGRA114_SPI) += tegra114_spi.o obj-$(CONFIG_TEGRA20_SFLASH) += tegra20_sflash.o obj-$(CONFIG_TEGRA20_SLINK) += tegra20_slink.o diff --git a/drivers/spi/sun6i_spi.c b/drivers/spi/sun6i_spi.c new file mode 100644 index 0000000000..236ed86a25 --- /dev/null +++ b/drivers/spi/sun6i_spi.c @@ -0,0 +1,475 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2018 Amarula Solutions. + * Author: Jagan Teki jagan@amarulasolutions.com + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <spi.h> +#include <errno.h> +#include <fdt_support.h> +#include <reset.h> +#include <wait_bit.h> + +#include <asm/bitops.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <asm/arch/clock.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define SUN6I_FIFO_DEPTH 128 +#define SUN8I_FIFO_DEPTH 64 + +#define SUN6I_GBL_CTL_BUS_ENABLE BIT(0) +#define SUN6I_GBL_CTL_MASTER BIT(1) +#define SUN6I_GBL_CTL_TP BIT(7) +#define SUN6I_GBL_CTL_RST BIT(31) + +#define SUN6I_TFR_CTL_CPHA BIT(0) +#define SUN6I_TFR_CTL_CPOL BIT(1) +#define SUN6I_TFR_CTL_SPOL BIT(2) +#define SUN6I_TFR_CTL_CS_MASK 0x30 +#define SUN6I_TFR_CTL_CS(cs) (((cs) << 4) & SUN6I_TFR_CTL_CS_MASK) +#define SUN6I_TFR_CTL_CS_MANUAL BIT(6) +#define SUN6I_TFR_CTL_CS_LEVEL BIT(7) +#define SUN6I_TFR_CTL_DHB BIT(8) +#define SUN6I_TFR_CTL_FBS BIT(12) +#define SUN6I_TFR_CTL_XCH_MASK 0x80000000 +#define SUN6I_TFR_CTL_XCH BIT(31) + +#define SUN6I_FIFO_CTL_RF_RDY_TRIG_LEVEL_MASK 0xff +#define SUN6I_FIFO_CTL_RF_RDY_TRIG_LEVEL_BITS 0 +#define SUN6I_FIFO_CTL_RF_RST BIT(15) +#define SUN6I_FIFO_CTL_TF_ERQ_TRIG_LEVEL_MASK 0xff +#define SUN6I_FIFO_CTL_TF_ERQ_TRIG_LEVEL_BITS 16 +#define SUN6I_FIFO_CTL_TF_RST BIT(31) + +#define SUN6I_CLK_CTL_CDR2_MASK 0xff +#define SUN6I_CLK_CTL_CDR2(div) (((div) & SUN6I_CLK_CTL_CDR2_MASK) << 0) +#define SUN6I_CLK_CTL_CDR1_MASK 0xf +#define SUN6I_CLK_CTL_CDR1(div) (((div) & SUN6I_CLK_CTL_CDR1_MASK) << 8) +#define SUN6I_CLK_CTL_DRS BIT(12) + +#define SUN6I_MAX_XFER_SIZE 0xffffff +#define SUN6I_BURST_CNT(cnt) ((cnt) & SUN6I_MAX_XFER_SIZE) +#define SUN6I_XMIT_CNT(cnt) ((cnt) & SUN6I_MAX_XFER_SIZE) +#define SUN6I_BURST_CTL_CNT_STC(cnt) ((cnt) & SUN6I_MAX_XFER_SIZE) + +#define SUN6I_SPI_MAX_RATE 24000000 +#define SUN6I_SPI_MIN_RATE 3000 +#define SUN6I_SPI_DEFAULT_RATE 1000000 +#define SUN6I_SPI_TIMEOUT_US 1000000 + +/* sun6i spi register set */ +struct sun6i_spi_regs { + u32 res1; /* 0x00 */ + u32 gblctl; /* 0x04 */ + u32 tfrctl; /* 0x08 */ + u32 res2; /* 0x0c */ + u32 intctl; /* 0x10 */ + u32 intsta; /* 0x14 */ + u32 fifoctl; /* 0x18 */ + u32 fifosta; /* 0x1c */ + u32 res3; /* 0x20 */ + u32 clkctl; /* 0x24 */ + u32 res4[2]; /* 0x28 */ + u32 bc; /* 0x30 */ + u32 tc; /* 0x34 */ + u32 bctlc; /* 0x38 */ + u32 res5[113]; /* 0x3c */ + u32 txdata; /* 0x200 */ + u32 res6[63]; /* 0x204 */ + u32 rxdata; /* 0x300 */ +}; + +struct sun6i_spi_platdata { + u32 base_addr; + u32 max_hz; +}; + +struct sun6i_spi_priv { + struct sun6i_spi_regs *regs; + u32 freq; + u32 mode; + u32 fifo_depth; + + const u8 *tx_buf; + u8 *rx_buf; +}; + +static inline void sun6i_spi_drain_fifo(struct sun6i_spi_priv *priv, int len) +{ + u8 byte; + + while (len--) { + byte = readb(&priv->regs->rxdata); + *priv->rx_buf++ = byte; + } +} + +static inline void sun6i_spi_fill_fifo(struct sun6i_spi_priv *priv, int len) +{ + u8 byte; + + while (len--) { + byte = priv->tx_buf ? *priv->tx_buf++ : 0; + writeb(byte, &priv->regs->txdata); + } +} + +static void sun6i_spi_set_cs(struct udevice *bus, u8 cs, bool enable) +{ + struct sun6i_spi_priv *priv = dev_get_priv(bus); + u32 reg; + + reg = readl(&priv->regs->tfrctl); + reg &= ~SUN6I_TFR_CTL_CS_MASK; + reg |= SUN6I_TFR_CTL_CS(cs); + + if (enable) + reg &= ~SUN6I_TFR_CTL_CS_LEVEL; + else + reg |= SUN6I_TFR_CTL_CS_LEVEL; + + writel(reg, &priv->regs->tfrctl); +} + +static int sun6i_spi_parse_pins(struct udevice *dev) +{ + const void *fdt = gd->fdt_blob; + const char *pin_name; + const fdt32_t *list; + u32 phandle; + int drive, pull = 0, pin, i; + int offset; + int size; + + list = fdt_getprop(fdt, dev_of_offset(dev), "pinctrl-0", &size); + if (!list) { + printf("WARNING: sun6i_spi: cannot find pinctrl-0 node\n"); + return -EINVAL; + } + + while (size) { + phandle = fdt32_to_cpu(*list++); + size -= sizeof(*list); + + offset = fdt_node_offset_by_phandle(fdt, phandle); + if (offset < 0) + return offset; + + drive = fdt_getprop_u32_default_node(fdt, offset, 0, + "drive-strength", 0); + if (drive) { + if (drive <= 10) + drive = 0; + else if (drive <= 20) + drive = 1; + else if (drive <= 30) + drive = 2; + else + drive = 3; + } else { + drive = fdt_getprop_u32_default_node(fdt, offset, 0, + "allwinner,drive", + 0); + drive = min(drive, 3); + } + + if (fdt_get_property(fdt, offset, "bias-disable", NULL)) + pull = 0; + else if (fdt_get_property(fdt, offset, "bias-pull-up", NULL)) + pull = 1; + else if (fdt_get_property(fdt, offset, "bias-pull-down", NULL)) + pull = 2; + else + pull = fdt_getprop_u32_default_node(fdt, offset, 0, + "allwinner,pull", + 0); + pull = min(pull, 2); + + for (i = 0; ; i++) { + pin_name = fdt_stringlist_get(fdt, offset, + "pins", i, NULL); + if (!pin_name) { + pin_name = fdt_stringlist_get(fdt, offset, + "allwinner,pins", + i, NULL); + if (!pin_name) + break; + } + + pin = name_to_gpio(pin_name); + if (pin < 0) + break; + + sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SPI0); + sunxi_gpio_set_drv(pin, drive); + sunxi_gpio_set_pull(pin, pull); + } + } + return 0; +} + +static inline int sun6i_spi_enable_ccu(struct udevice *dev) +{ + struct clk ahb_clk, mod_clk; + struct reset_ctl reset; + int ret; + + ret = clk_get_by_name(dev, "ahb", &ahb_clk); + if (ret) { + dev_err(dev, "failed to get ahb clock\n"); + return ret; + } + + ret = clk_get_by_name(dev, "mod", &mod_clk); + if (ret) { + dev_err(dev, "failed to get mod clock\n"); + return ret; + } + + ret = reset_get_by_index(dev, 0, &reset); + if (ret) { + dev_err(dev, "failed to get reset\n"); + return ret; + } + + ret = clk_enable(&ahb_clk); + if (ret) { + dev_err(dev, "failed to enable ahb clock\n"); + return ret; + } + + ret = clk_enable(&mod_clk); + if (ret) { + dev_err(dev, "failed to enable mod clock\n"); + return ret; + } + + ret = reset_deassert(&reset); + if (ret) { + dev_err(dev, "failed to deassert reset\n"); + return ret; + } + + return 0; +} + +static int sun6i_spi_ofdata_to_platdata(struct udevice *bus) +{ + struct sun6i_spi_platdata *plat = dev_get_platdata(bus); + int node = dev_of_offset(bus); + + plat->base_addr = devfdt_get_addr(bus); + plat->max_hz = fdtdec_get_int(gd->fdt_blob, node, + "spi-max-frequency", + SUN6I_SPI_DEFAULT_RATE); + + if (plat->max_hz > SUN6I_SPI_MAX_RATE) + plat->max_hz = SUN6I_SPI_MAX_RATE; + + return 0; +} + +static int sun6i_spi_probe(struct udevice *bus) +{ + struct sun6i_spi_platdata *plat = dev_get_platdata(bus); + struct sun6i_spi_priv *priv = dev_get_priv(bus); + int ret; + + ret = sun6i_spi_enable_ccu(bus); + if (ret) + return ret; + + sun6i_spi_parse_pins(bus); + + priv->regs = (struct sun6i_spi_regs *)(uintptr_t)plat->base_addr; + priv->freq = plat->max_hz; + priv->fifo_depth = dev_get_driver_data(bus); + + return 0; +} + +static int sun6i_spi_claim_bus(struct udevice *dev) +{ + struct sun6i_spi_priv *priv = dev_get_priv(dev->parent); + + writel(SUN6I_GBL_CTL_BUS_ENABLE | SUN6I_GBL_CTL_MASTER | + SUN6I_GBL_CTL_TP, &priv->regs->gblctl); + writel(SUN6I_TFR_CTL_CS_MANUAL, &priv->regs->tfrctl); + + return 0; +} + +static int sun6i_spi_release_bus(struct udevice *dev) +{ + struct sun6i_spi_priv *priv = dev_get_priv(dev->parent); + u32 reg; + + reg = readl(&priv->regs->gblctl); + reg &= ~SUN6I_GBL_CTL_BUS_ENABLE; + writel(reg, &priv->regs->gblctl); + + return 0; +} + +static int sun6i_spi_xfer(struct udevice *dev, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) +{ + struct udevice *bus = dev->parent; + struct sun6i_spi_priv *priv = dev_get_priv(bus); + struct dm_spi_slave_platdata *slave_plat = dev_get_parent_platdata(dev); + + u32 len = bitlen / 8; + u32 reg; + u8 nbytes; + int ret; + + priv->tx_buf = dout; + priv->rx_buf = din; + + if (bitlen % 8) { + debug("%s: non byte-aligned SPI transfer.\n", __func__); + return -ENAVAIL; + } + + if (flags & SPI_XFER_BEGIN) + sun6i_spi_set_cs(bus, slave_plat->cs, true); + + /* Reset FIFOs */ + writel(SUN6I_FIFO_CTL_RF_RST | SUN6I_FIFO_CTL_TF_RST, + &priv->regs->fifoctl); + + while (len) { + /* Setup the transfer now... */ + nbytes = min(len, priv->fifo_depth); + + /* Setup the counters */ + writel(SUN6I_BURST_CNT(nbytes), &priv->regs->bc); + writel(SUN6I_XMIT_CNT(nbytes), &priv->regs->tc); + writel(SUN6I_BURST_CTL_CNT_STC(nbytes), &priv->regs->bctlc); + + /* Fill the TX FIFO */ + sun6i_spi_fill_fifo(priv, nbytes); + + /* Start the transfer */ + reg = readl(&priv->regs->tfrctl); + writel(reg | SUN6I_TFR_CTL_XCH, &priv->regs->tfrctl); + + /* Wait transfer to complete */ + ret = wait_for_bit_le32(&priv->regs->tfrctl, + SUN6I_TFR_CTL_XCH_MASK, false, + SUN6I_SPI_TIMEOUT_US, false); + if (ret) { + printf("ERROR: sun6i_spi: Timeout transferring data\n"); + sun6i_spi_set_cs(bus, slave_plat->cs, false); + return ret; + } + + /* Drain the RX FIFO */ + sun6i_spi_drain_fifo(priv, nbytes); + + len -= nbytes; + } + + if (flags & SPI_XFER_END) + sun6i_spi_set_cs(bus, slave_plat->cs, false); + + return 0; +} + +static int sun6i_spi_set_speed(struct udevice *dev, uint speed) +{ + struct sun6i_spi_platdata *plat = dev_get_platdata(dev); + struct sun6i_spi_priv *priv = dev_get_priv(dev); + unsigned int div; + u32 reg; + + if (speed > plat->max_hz) + speed = plat->max_hz; + + if (speed < SUN6I_SPI_MIN_RATE) + speed = SUN6I_SPI_MIN_RATE; + + /* + * Setup clock divider. + * + * We have two choices there. Either we can use the clock + * divide rate 1, which is calculated thanks to this formula: + * SPI_CLK = MOD_CLK / (2 ^ cdr) + * Or we can use CDR2, which is calculated with the formula: + * SPI_CLK = MOD_CLK / (2 * (cdr + 1)) + * Whether we use the former or the latter is set through the + * DRS bit. + * + * First try CDR2, and if we can't reach the expected + * frequency, fall back to CDR1. + */ + reg = readl(&priv->regs->clkctl); + div = SUN6I_SPI_MAX_RATE / (2 * speed); + if (div <= (SUN6I_CLK_CTL_CDR2_MASK + 1)) { + if (div > 0) + div--; + + reg |= SUN6I_CLK_CTL_CDR2(div) | SUN6I_CLK_CTL_DRS; + } else { + div = __ilog2(SUN6I_SPI_MAX_RATE) - __ilog2(speed); + reg |= SUN6I_CLK_CTL_CDR1(div); + } + + writel(reg, &priv->regs->clkctl); + priv->freq = speed; + + return 0; +} + +static int sun6i_spi_set_mode(struct udevice *dev, uint mode) +{ + struct sun6i_spi_priv *priv = dev_get_priv(dev); + u32 reg; + + reg = readl(&priv->regs->tfrctl); + reg &= ~(SUN6I_TFR_CTL_CPOL | SUN6I_TFR_CTL_CPHA); + + if (mode & SPI_CPOL) + reg |= SUN6I_TFR_CTL_CPOL; + + if (mode & SPI_CPHA) + reg |= SUN6I_TFR_CTL_CPHA; + + priv->mode = mode; + writel(reg, &priv->regs->tfrctl); + + return 0; +} + +static const struct dm_spi_ops sun6i_spi_ops = { + .claim_bus = sun6i_spi_claim_bus, + .release_bus = sun6i_spi_release_bus, + .xfer = sun6i_spi_xfer, + .set_speed = sun6i_spi_set_speed, + .set_mode = sun6i_spi_set_mode, +}; + +static const struct udevice_id sun6i_spi_ids[] = { + { .compatible = "allwinner,sun6i-a31-spi", + .data = SUN6I_FIFO_DEPTH }, + { .compatible = "allwinner,sun8i-h3-spi", + .data = SUN8I_FIFO_DEPTH }, + { } +}; + +U_BOOT_DRIVER(sun6i_spi) = { + .name = "sun6i_spi", + .id = UCLASS_SPI, + .of_match = sun6i_spi_ids, + .ops = &sun6i_spi_ops, + .ofdata_to_platdata = sun6i_spi_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct sun6i_spi_platdata), + .priv_auto_alloc_size = sizeof(struct sun6i_spi_priv), + .probe = sun6i_spi_probe, +};
Implement UART clocks for all Allwinner SoC clock drivers via clock map descriptor table.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/clk/sunxi/clk_a10.c | 9 +++++++++ drivers/clk/sunxi/clk_a10s.c | 5 +++++ drivers/clk/sunxi/clk_a23.c | 6 ++++++ drivers/clk/sunxi/clk_a31.c | 7 +++++++ drivers/clk/sunxi/clk_a64.c | 6 ++++++ drivers/clk/sunxi/clk_a83t.c | 6 ++++++ drivers/clk/sunxi/clk_h3.c | 5 +++++ drivers/clk/sunxi/clk_r40.c | 9 +++++++++ drivers/clk/sunxi/clk_v3s.c | 4 ++++ 9 files changed, 57 insertions(+)
diff --git a/drivers/clk/sunxi/clk_a10.c b/drivers/clk/sunxi/clk_a10.c index ee499c402a..d145d37217 100644 --- a/drivers/clk/sunxi/clk_a10.c +++ b/drivers/clk/sunxi/clk_a10.c @@ -27,6 +27,15 @@ static struct ccu_clk_map a10_clks[] = { [CLK_AHB_SPI2] = { 0x060, BIT(22), NULL }, [CLK_AHB_SPI3] = { 0x060, BIT(23), NULL },
+ [CLK_APB1_UART0] = { 0x06c, BIT(16), NULL }, + [CLK_APB1_UART1] = { 0x06c, BIT(17), NULL }, + [CLK_APB1_UART2] = { 0x06c, BIT(18), NULL }, + [CLK_APB1_UART3] = { 0x06c, BIT(19), NULL }, + [CLK_APB1_UART4] = { 0x06c, BIT(20), NULL }, + [CLK_APB1_UART5] = { 0x06c, BIT(21), NULL }, + [CLK_APB1_UART6] = { 0x06c, BIT(22), NULL }, + [CLK_APB1_UART7] = { 0x06c, BIT(23), NULL }, + [CLK_MMC0] = { 0x088, BIT(31), &mmc_clk_set_rate }, [CLK_MMC1] = { 0x08c, BIT(31), &mmc_clk_set_rate }, [CLK_MMC2] = { 0x090, BIT(31), &mmc_clk_set_rate }, diff --git a/drivers/clk/sunxi/clk_a10s.c b/drivers/clk/sunxi/clk_a10s.c index 0c71e5b698..d2e9af2555 100644 --- a/drivers/clk/sunxi/clk_a10s.c +++ b/drivers/clk/sunxi/clk_a10s.c @@ -23,6 +23,11 @@ static struct ccu_clk_map a10s_clks[] = { [CLK_AHB_SPI1] = { 0x060, BIT(21), NULL }, [CLK_AHB_SPI2] = { 0x060, BIT(22), NULL },
+ [CLK_APB1_UART0] = { 0x06c, BIT(16), NULL }, + [CLK_APB1_UART1] = { 0x06c, BIT(17), NULL }, + [CLK_APB1_UART2] = { 0x06c, BIT(18), NULL }, + [CLK_APB1_UART3] = { 0x06c, BIT(19), NULL }, + #ifdef CONFIG_MMC [CLK_MMC0] = { 0x088, BIT(31), &mmc_clk_set_rate }, [CLK_MMC1] = { 0x08c, BIT(31), &mmc_clk_set_rate }, diff --git a/drivers/clk/sunxi/clk_a23.c b/drivers/clk/sunxi/clk_a23.c index 06a2e6bc79..9dbc83c531 100644 --- a/drivers/clk/sunxi/clk_a23.c +++ b/drivers/clk/sunxi/clk_a23.c @@ -20,6 +20,12 @@ static struct ccu_clk_map a23_clks[] = { [CLK_BUS_EHCI] = { 0x060, BIT(26), NULL }, [CLK_BUS_OHCI] = { 0x060, BIT(29), NULL },
+ [CLK_BUS_UART0] = { 0x06c, BIT(16), NULL }, + [CLK_BUS_UART1] = { 0x06c, BIT(17), NULL }, + [CLK_BUS_UART2] = { 0x06c, BIT(18), NULL }, + [CLK_BUS_UART3] = { 0x06c, BIT(19), NULL }, + [CLK_BUS_UART4] = { 0x06c, BIT(20), NULL }, + #ifdef CONFIG_MMC [CLK_MMC0] = { 0x088, BIT(31), &mmc_clk_set_rate }, [CLK_MMC1] = { 0x08c, BIT(31), &mmc_clk_set_rate }, diff --git a/drivers/clk/sunxi/clk_a31.c b/drivers/clk/sunxi/clk_a31.c index a5c6628c63..40803a1d64 100644 --- a/drivers/clk/sunxi/clk_a31.c +++ b/drivers/clk/sunxi/clk_a31.c @@ -28,6 +28,13 @@ static struct ccu_clk_map a31_clks[] = { [CLK_AHB1_OHCI1] = { 0x060, BIT(30), NULL }, [CLK_AHB1_OHCI2] = { 0x060, BIT(31), NULL },
+ [CLK_APB2_UART0] = { 0x06c, BIT(16), NULL }, + [CLK_APB2_UART1] = { 0x06c, BIT(17), NULL }, + [CLK_APB2_UART2] = { 0x06c, BIT(18), NULL }, + [CLK_APB2_UART3] = { 0x06c, BIT(19), NULL }, + [CLK_APB2_UART4] = { 0x06c, BIT(20), NULL }, + [CLK_APB2_UART5] = { 0x06c, BIT(21), NULL }, + [CLK_MMC0] = { 0x088, BIT(31), &mmc_clk_set_rate }, [CLK_MMC1] = { 0x08c, BIT(31), &mmc_clk_set_rate }, [CLK_MMC2] = { 0x090, BIT(31), &mmc_clk_set_rate }, diff --git a/drivers/clk/sunxi/clk_a64.c b/drivers/clk/sunxi/clk_a64.c index e991c8d2d1..ae96ce7803 100644 --- a/drivers/clk/sunxi/clk_a64.c +++ b/drivers/clk/sunxi/clk_a64.c @@ -24,6 +24,12 @@ static struct ccu_clk_map a64_clks[] = { [CLK_BUS_OHCI0] = { 0x060, BIT(28), NULL }, [CLK_BUS_OHCI1] = { 0x060, BIT(29), NULL },
+ [CLK_BUS_UART0] = { 0x06c, BIT(16), NULL }, + [CLK_BUS_UART1] = { 0x06c, BIT(17), NULL }, + [CLK_BUS_UART2] = { 0x06c, BIT(18), NULL }, + [CLK_BUS_UART3] = { 0x06c, BIT(19), NULL }, + [CLK_BUS_UART4] = { 0x06c, BIT(20), NULL }, + [CLK_MMC0] = { 0x088, BIT(31), &mmc_clk_set_rate }, [CLK_MMC1] = { 0x08c, BIT(31), &mmc_clk_set_rate }, [CLK_MMC2] = { 0x090, BIT(31), &mmc_clk_set_rate }, diff --git a/drivers/clk/sunxi/clk_a83t.c b/drivers/clk/sunxi/clk_a83t.c index 47b7672e7f..5c1235fa7b 100644 --- a/drivers/clk/sunxi/clk_a83t.c +++ b/drivers/clk/sunxi/clk_a83t.c @@ -21,6 +21,12 @@ static struct ccu_clk_map a83t_clks[] = { [CLK_BUS_EHCI1] = { 0x060, BIT(27), NULL }, [CLK_BUS_OHCI0] = { 0x060, BIT(29), NULL },
+ [CLK_BUS_UART0] = { 0x06c, BIT(16), NULL }, + [CLK_BUS_UART1] = { 0x06c, BIT(17), NULL }, + [CLK_BUS_UART2] = { 0x06c, BIT(18), NULL }, + [CLK_BUS_UART3] = { 0x06c, BIT(19), NULL }, + [CLK_BUS_UART4] = { 0x06c, BIT(20), NULL }, + [CLK_MMC0] = { 0x088, BIT(31), &mmc_clk_set_rate }, [CLK_MMC1] = { 0x08c, BIT(31), &mmc_clk_set_rate }, [CLK_MMC2] = { 0x090, BIT(31), &mmc_clk_set_rate }, diff --git a/drivers/clk/sunxi/clk_h3.c b/drivers/clk/sunxi/clk_h3.c index 1cc32a0b91..3be6f4cdac 100644 --- a/drivers/clk/sunxi/clk_h3.c +++ b/drivers/clk/sunxi/clk_h3.c @@ -28,6 +28,11 @@ static struct ccu_clk_map h3_clks[] = { [CLK_BUS_OHCI2] = { 0x060, BIT(30), NULL }, [CLK_BUS_OHCI3] = { 0x060, BIT(31), NULL },
+ [CLK_BUS_UART0] = { 0x06c, BIT(16), NULL }, + [CLK_BUS_UART1] = { 0x06c, BIT(17), NULL }, + [CLK_BUS_UART2] = { 0x06c, BIT(18), NULL }, + [CLK_BUS_UART3] = { 0x06c, BIT(19), NULL }, + [CLK_MMC0] = { 0x088, BIT(31), &mmc_clk_set_rate }, [CLK_MMC1] = { 0x08c, BIT(31), &mmc_clk_set_rate }, [CLK_MMC2] = { 0x090, BIT(31), &mmc_clk_set_rate }, diff --git a/drivers/clk/sunxi/clk_r40.c b/drivers/clk/sunxi/clk_r40.c index 24c26ad3be..1e5b1d10f7 100644 --- a/drivers/clk/sunxi/clk_r40.c +++ b/drivers/clk/sunxi/clk_r40.c @@ -25,6 +25,15 @@ static struct ccu_clk_map r40_clks[] = { [CLK_BUS_OHCI1] = { 0x060, BIT(30), NULL }, [CLK_BUS_OHCI2] = { 0x060, BIT(31), NULL },
+ [CLK_BUS_UART0] = { 0x06c, BIT(16), NULL }, + [CLK_BUS_UART1] = { 0x06c, BIT(17), NULL }, + [CLK_BUS_UART2] = { 0x06c, BIT(18), NULL }, + [CLK_BUS_UART3] = { 0x06c, BIT(19), NULL }, + [CLK_BUS_UART4] = { 0x06c, BIT(20), NULL }, + [CLK_BUS_UART5] = { 0x06c, BIT(21), NULL }, + [CLK_BUS_UART6] = { 0x06c, BIT(22), NULL }, + [CLK_BUS_UART7] = { 0x06c, BIT(23), NULL }, + [CLK_MMC0] = { 0x088, BIT(31), &mmc_clk_set_rate }, [CLK_MMC1] = { 0x08c, BIT(31), &mmc_clk_set_rate }, [CLK_MMC2] = { 0x090, BIT(31), &mmc_clk_set_rate }, diff --git a/drivers/clk/sunxi/clk_v3s.c b/drivers/clk/sunxi/clk_v3s.c index 525b6dcb39..e12ab2bc65 100644 --- a/drivers/clk/sunxi/clk_v3s.c +++ b/drivers/clk/sunxi/clk_v3s.c @@ -19,6 +19,10 @@ static struct ccu_clk_map v3s_clks[] = { [CLK_BUS_SPI0] = { 0x060, BIT(20), NULL }, [CLK_BUS_OTG] = { 0x060, BIT(24), NULL },
+ [CLK_BUS_UART0] = { 0x06c, BIT(16), NULL }, + [CLK_BUS_UART1] = { 0x06c, BIT(17), NULL }, + [CLK_BUS_UART2] = { 0x06c, BIT(18), NULL }, + [CLK_MMC0] = { 0x088, BIT(31), &mmc_clk_set_rate }, [CLK_MMC1] = { 0x08c, BIT(31), &mmc_clk_set_rate }, [CLK_MMC2] = { 0x090, BIT(31), &mmc_clk_set_rate },
Implement UART resets for all relevant Allwinner SoC clock drivers via reset map descriptor table.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/clk/sunxi/clk_a23.c | 6 ++++++ drivers/clk/sunxi/clk_a31.c | 7 +++++++ drivers/clk/sunxi/clk_a64.c | 6 ++++++ drivers/clk/sunxi/clk_a83t.c | 6 ++++++ drivers/clk/sunxi/clk_h3.c | 5 +++++ drivers/clk/sunxi/clk_r40.c | 9 +++++++++ drivers/clk/sunxi/clk_v3s.c | 4 ++++ 7 files changed, 43 insertions(+)
diff --git a/drivers/clk/sunxi/clk_a23.c b/drivers/clk/sunxi/clk_a23.c index 9dbc83c531..8ce5383bb1 100644 --- a/drivers/clk/sunxi/clk_a23.c +++ b/drivers/clk/sunxi/clk_a23.c @@ -50,6 +50,12 @@ static struct ccu_reset_map a23_resets[] = { [RST_BUS_OTG] = { 0x2c0, BIT(24) }, [RST_BUS_EHCI] = { 0x2c0, BIT(26) }, [RST_BUS_OHCI] = { 0x2c0, BIT(29) }, + + [RST_BUS_UART0] = { 0x2d8, BIT(16) }, + [RST_BUS_UART1] = { 0x2d8, BIT(17) }, + [RST_BUS_UART2] = { 0x2d8, BIT(18) }, + [RST_BUS_UART3] = { 0x2d8, BIT(19) }, + [RST_BUS_UART4] = { 0x2d8, BIT(20) }, };
static const struct ccu_desc sun8i_a23_ccu_desc = { diff --git a/drivers/clk/sunxi/clk_a31.c b/drivers/clk/sunxi/clk_a31.c index 40803a1d64..288979a18f 100644 --- a/drivers/clk/sunxi/clk_a31.c +++ b/drivers/clk/sunxi/clk_a31.c @@ -72,6 +72,13 @@ static struct ccu_reset_map a31_resets[] = { [RST_AHB1_OHCI0] = { 0x2c0, BIT(29) }, [RST_AHB1_OHCI1] = { 0x2c0, BIT(30) }, [RST_AHB1_OHCI2] = { 0x2c0, BIT(31) }, + + [RST_APB2_UART0] = { 0x2d8, BIT(16) }, + [RST_APB2_UART1] = { 0x2d8, BIT(17) }, + [RST_APB2_UART2] = { 0x2d8, BIT(18) }, + [RST_APB2_UART3] = { 0x2d8, BIT(19) }, + [RST_APB2_UART4] = { 0x2d8, BIT(20) }, + [RST_APB2_UART5] = { 0x2d8, BIT(21) }, };
static const struct ccu_desc sun6i_a31_ccu_desc = { diff --git a/drivers/clk/sunxi/clk_a64.c b/drivers/clk/sunxi/clk_a64.c index ae96ce7803..26cbd69a4c 100644 --- a/drivers/clk/sunxi/clk_a64.c +++ b/drivers/clk/sunxi/clk_a64.c @@ -60,6 +60,12 @@ static struct ccu_reset_map a64_resets[] = { [RST_BUS_EHCI1] = { 0x2c0, BIT(25) }, [RST_BUS_OHCI0] = { 0x2c0, BIT(28) }, [RST_BUS_OHCI1] = { 0x2c0, BIT(29) }, + + [RST_BUS_UART0] = { 0x2d8, BIT(16) }, + [RST_BUS_UART1] = { 0x2d8, BIT(17) }, + [RST_BUS_UART2] = { 0x2d8, BIT(18) }, + [RST_BUS_UART3] = { 0x2d8, BIT(19) }, + [RST_BUS_UART4] = { 0x2d8, BIT(20) }, };
static const struct ccu_desc sun50i_a64_ccu_desc = { diff --git a/drivers/clk/sunxi/clk_a83t.c b/drivers/clk/sunxi/clk_a83t.c index 5c1235fa7b..cf9455da97 100644 --- a/drivers/clk/sunxi/clk_a83t.c +++ b/drivers/clk/sunxi/clk_a83t.c @@ -50,6 +50,12 @@ static struct ccu_reset_map a83t_resets[] = { [RST_BUS_EHCI0] = { 0x2c0, BIT(26) }, [RST_BUS_EHCI1] = { 0x2c0, BIT(27) }, [RST_BUS_OHCI0] = { 0x2c0, BIT(29) }, + + [RST_BUS_UART0] = { 0x2d8, BIT(16) }, + [RST_BUS_UART1] = { 0x2d8, BIT(17) }, + [RST_BUS_UART2] = { 0x2d8, BIT(18) }, + [RST_BUS_UART3] = { 0x2d8, BIT(19) }, + [RST_BUS_UART4] = { 0x2d8, BIT(20) }, };
static const struct ccu_desc sun8i_a83t_ccu_desc = { diff --git a/drivers/clk/sunxi/clk_h3.c b/drivers/clk/sunxi/clk_h3.c index 3be6f4cdac..c9bdb209fc 100644 --- a/drivers/clk/sunxi/clk_h3.c +++ b/drivers/clk/sunxi/clk_h3.c @@ -70,6 +70,11 @@ static struct ccu_reset_map h3_resets[] = { [RST_BUS_OHCI1] = { 0x2c0, BIT(29) }, [RST_BUS_OHCI2] = { 0x2c0, BIT(30) }, [RST_BUS_OHCI3] = { 0x2c0, BIT(31) }, + + [RST_BUS_UART0] = { 0x2d8, BIT(16) }, + [RST_BUS_UART1] = { 0x2d8, BIT(17) }, + [RST_BUS_UART2] = { 0x2d8, BIT(18) }, + [RST_BUS_UART3] = { 0x2d8, BIT(19) }, };
static const struct ccu_desc sun8i_h3_ccu_desc = { diff --git a/drivers/clk/sunxi/clk_r40.c b/drivers/clk/sunxi/clk_r40.c index 1e5b1d10f7..ee699d26ee 100644 --- a/drivers/clk/sunxi/clk_r40.c +++ b/drivers/clk/sunxi/clk_r40.c @@ -63,6 +63,15 @@ static struct ccu_reset_map r40_resets[] = { [RST_BUS_OHCI0] = { 0x2c0, BIT(29) }, [RST_BUS_OHCI1] = { 0x2c0, BIT(30) }, [RST_BUS_OHCI2] = { 0x2c0, BIT(31) }, + + [RST_BUS_UART0] = { 0x2d8, BIT(16) }, + [RST_BUS_UART1] = { 0x2d8, BIT(17) }, + [RST_BUS_UART2] = { 0x2d8, BIT(18) }, + [RST_BUS_UART3] = { 0x2d8, BIT(19) }, + [RST_BUS_UART4] = { 0x2d8, BIT(20) }, + [RST_BUS_UART5] = { 0x2d8, BIT(21) }, + [RST_BUS_UART6] = { 0x2d8, BIT(22) }, + [RST_BUS_UART7] = { 0x2d8, BIT(23) }, };
static const struct ccu_desc sun8i_r40_ccu_desc = { diff --git a/drivers/clk/sunxi/clk_v3s.c b/drivers/clk/sunxi/clk_v3s.c index e12ab2bc65..722af3a91b 100644 --- a/drivers/clk/sunxi/clk_v3s.c +++ b/drivers/clk/sunxi/clk_v3s.c @@ -40,6 +40,10 @@ static struct ccu_reset_map v3s_resets[] = { [RST_BUS_MMC2] = { 0x2c0, BIT(10) }, [RST_BUS_SPI0] = { 0x2c0, BIT(20) }, [RST_BUS_OTG] = { 0x2c0, BIT(24) }, + + [RST_BUS_UART0] = { 0x2d8, BIT(16) }, + [RST_BUS_UART1] = { 0x2d8, BIT(17) }, + [RST_BUS_UART2] = { 0x2d8, BIT(18) }, };
static const struct ccu_desc sun8i_v3s_ccu_desc = {
Jagan Teki
