[U-Boot] [PATCH] bootm: relocate ramdisk if CONFIG_SYS_BOOT_RAMDISK_HIGH set
In 35fc84f, bootm was refactored so plain 'bootm' and 'bootm <subcommand>' shared a common implementation. The 'bootm ramdisk' command implementation is now part of the common implementation but not invoke by plain 'bootm' since the original implementation never did ramdisk relocation. Instead, ramdisk relocation happened in image_setup_linux() which is typically called during the OS portion of 'bootm'.
On ARM, parameters to the Linux kernel can either be passed by FDT or ATAGS. When using FDT, image_setup_linux() is called which also triggers ramdisk relocation. When using ATAGS, image_setup_linux() is _not_ called because it mostly does FDT setup.
Instead of calling image_setup_linux() in both FDT and ATAGS cases, include BOOTM_STATE_RAMDISK in the requested states during a plain 'bootm' if CONFIG_SYS_BOOT_RAMDISK_HIGH is set and remove the ramdisk relocation from image_setup_linux(). This causes ramdisk relocation to happen on any system where CONFIG_SYS_BOOT_RAMDISK_HIGH regardless of the OS being booted. Also remove IMAGE_ENABLE_RAMDISK_HIGH as it was only used by the now-removed code from image_setup_linux().
Signed-off-by: Rick Altherr raltherr@google.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Joel Stanley joel@jms.id.au ---
cmd/bootm.c | 3 +++ common/image.c | 10 ---------- include/image.h | 6 ------ 3 files changed, 3 insertions(+), 16 deletions(-)
diff --git a/cmd/bootm.c b/cmd/bootm.c index 083f3d1..a7e181d 100644 --- a/cmd/bootm.c +++ b/cmd/bootm.c @@ -126,6 +126,9 @@ int do_bootm(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return do_bootm_states(cmdtp, flag, argc, argv, BOOTM_STATE_START | BOOTM_STATE_FINDOS | BOOTM_STATE_FINDOTHER | BOOTM_STATE_LOADOS | +#ifdef CONFIG_SYS_BOOT_RAMDISK_HIGH + BOOTM_STATE_RAMDISK | +#endif #if defined(CONFIG_PPC) || defined(CONFIG_MIPS) BOOTM_STATE_OS_CMDLINE | #endif diff --git a/common/image.c b/common/image.c index bd07e86..b4a6839 100644 --- a/common/image.c +++ b/common/image.c @@ -1571,10 +1571,7 @@ int image_setup_linux(bootm_headers_t *images) { ulong of_size = images->ft_len; char **of_flat_tree = &images->ft_addr; - ulong *initrd_start = &images->initrd_start; - ulong *initrd_end = &images->initrd_end; struct lmb *lmb = &images->lmb; - ulong rd_len; int ret;
if (IMAGE_ENABLE_OF_LIBFDT) @@ -1588,13 +1585,6 @@ int image_setup_linux(bootm_headers_t *images) return ret; } } - if (IMAGE_ENABLE_RAMDISK_HIGH) { - rd_len = images->rd_end - images->rd_start; - ret = boot_ramdisk_high(lmb, images->rd_start, rd_len, - initrd_start, initrd_end); - if (ret) - return ret; - }
if (IMAGE_ENABLE_OF_LIBFDT) { ret = boot_relocate_fdt(lmb, of_flat_tree, &of_size); diff --git a/include/image.h b/include/image.h index 575f592..4c39bd7 100644 --- a/include/image.h +++ b/include/image.h @@ -99,12 +99,6 @@ struct lmb;
#endif /* IMAGE_ENABLE_FIT */
-#ifdef CONFIG_SYS_BOOT_RAMDISK_HIGH -# define IMAGE_ENABLE_RAMDISK_HIGH 1 -#else -# define IMAGE_ENABLE_RAMDISK_HIGH 0 -#endif - #ifdef CONFIG_SYS_BOOT_GET_CMDLINE # define IMAGE_BOOT_GET_CMDLINE 1 #else
Reviewed-by: Cédric Le Goater clg@kaod.org
and I gave it a good test on various boards we have.
Thanks,
C.
if (ret)
return ret;
Cédric Le Goater
Rick Altherr
