[U-Boot] [PATCH v2 01/16] km/common: remove unneeded ifdefs for I2C
All boards from this serie use i2c. There is no need to #ifdef the header.
Signed-off-by: Holger Brunck holger.brunck@keymile.com --- Changes for v2: - fix typo in commit message
board/keymile/common/common.c | 2 -- 1 files changed, 0 insertions(+), 2 deletions(-)
diff --git a/board/keymile/common/common.c b/board/keymile/common/common.c index 6f407b7..468c755 100644 --- a/board/keymile/common/common.c +++ b/board/keymile/common/common.c @@ -38,9 +38,7 @@ #include "post.h" #endif #include "common.h" -#if defined(CONFIG_HARD_I2C) || defined(CONFIG_SOFT_I2C) #include <i2c.h> -#endif
#if !defined(CONFIG_MPC83xx) static void i2c_write_start_seq(void);
EEprom_ivm_addr isn't set in our environment, so remove the usage of this.
Signed-off-by: Holger Brunck holger.brunck@keymile.com --- Changes for v2: - none
board/keymile/common/ivm.c | 8 -------- 1 files changed, 0 insertions(+), 8 deletions(-)
diff --git a/board/keymile/common/ivm.c b/board/keymile/common/ivm.c index eaa924f..7fe3b0f 100644 --- a/board/keymile/common/ivm.c +++ b/board/keymile/common/ivm.c @@ -325,14 +325,6 @@ int ivm_read_eeprom(void) } i2c_set_bus_num(dev->busid); #endif - - buf = (unsigned char *) getenv("EEprom_ivm_addr"); - if (buf != NULL) { - ret = strict_strtoul((char *)buf, 16, &dev_addr); - if (ret != 0) - return -3; - } - /* add deblocking here */ i2c_make_abort();
This define isn't set within our setup files. So we can safely remove the affected code.
board/keymile/common/ivm.c | 4 ---- 1 files changed, 0 insertions(+), 4 deletions(-)
diff --git a/board/keymile/common/ivm.c b/board/keymile/common/ivm.c index 7fe3b0f..607daa6 100644 --- a/board/keymile/common/ivm.c +++ b/board/keymile/common/ivm.c @@ -312,13 +312,9 @@ int ivm_read_eeprom(void)
#if defined(CONFIG_I2C_MUX) /* First init the Bus, select the Bus */ -#if defined(CONFIG_SYS_I2C_IVM_BUS) - dev = i2c_mux_ident_muxstring((uchar *)CONFIG_SYS_I2C_IVM_BUS); -#else buf = (unsigned char *) getenv("EEprom_ivm"); if (buf != NULL) dev = i2c_mux_ident_muxstring(buf); -#endif if (dev == NULL) { printf("Error couldnt add Bus for IVM\n"); return -1;
For kmvect1 we need a special solution and for km_arm boards we already have. So move the common code to the architectur specific file.
Signed-off-by: Karlheinz Jerg karlheinz.jerg@keymile.com Signed-off-by: Holger Brunck holger.brunck@keymile.com --- Changes for v2: - make piggy_present() static - add __iomem macro
board/keymile/common/common.c | 11 ----------- board/keymile/km82xx/km82xx.c | 8 ++++++++ board/keymile/km83xx/km83xx.c | 24 +++++++++++++++++++++++- 3 files changed, 31 insertions(+), 12 deletions(-)
diff --git a/board/keymile/common/common.c b/board/keymile/common/common.c index 468c755..ef93ed3 100644 --- a/board/keymile/common/common.c +++ b/board/keymile/common/common.c @@ -183,17 +183,6 @@ void i2c_init_board(void) } #endif
- -#if !defined(MACH_TYPE_KM_KIRKWOOD) -int ethernet_present(void) -{ - struct km_bec_fpga *base = - (struct km_bec_fpga *)CONFIG_SYS_KMBEC_FPGA_BASE; - - return in_8(&base->bprth) & PIGGY_PRESENT; -} -#endif - int board_eth_init(bd_t *bis) { if (ethernet_present()) diff --git a/board/keymile/km82xx/km82xx.c b/board/keymile/km82xx/km82xx.c index 67b69f6..defc885 100644 --- a/board/keymile/km82xx/km82xx.c +++ b/board/keymile/km82xx/km82xx.c @@ -385,6 +385,14 @@ void handle_mgcoge3un_reset(void) } #endif
+int ethernet_present(void) +{ + struct km_bec_fpga *base = + (struct km_bec_fpga *)CONFIG_SYS_KMBEC_FPGA_BASE; + + return in_8(&base->bprth) & PIGGY_PRESENT; +} + /* * Early board initalization. */ diff --git a/board/keymile/km83xx/km83xx.c b/board/keymile/km83xx/km83xx.c index 83a8753..b027173 100644 --- a/board/keymile/km83xx/km83xx.c +++ b/board/keymile/km83xx/km83xx.c @@ -133,6 +133,28 @@ const uint upma_table[] = { }; #endif
+static int piggy_present(void) +{ + struct km_bec_fpga __iomem *base = + (struct km_bec_fpga __iomem *)CONFIG_SYS_KMBEC_FPGA_BASE; + + return in_8(&base->bprth) & PIGGY_PRESENT; +} + +#if defined(CONFIG_KMVECT1) +int ethernet_present(void) +{ + /* ethernet port connected to simple switch without piggy */ + return 1; +} +#else +int ethernet_present(void) +{ + return piggy_present(); +} +#endif + + int board_early_init_r(void) { struct km_bec_fpga *base = @@ -280,7 +302,7 @@ int checkboard(void) { puts("Board: Keymile " CONFIG_KM_BOARD_NAME);
- if (ethernet_present()) + if (piggy_present()) puts(" with PIGGY."); puts("\n"); return 0;
For the the kmvect1 board we will also need a functionality to add an offset to the IVMs MAC address, because these board will have two valid ethernet ports for debugging purpose. So move the code to an own function.
Signed-off-by: Holger Brunck holger.brunck@keymile.com --- Changes for v2: - new in this serie, needed as preparation for fixes in the next patch as requested on the ML
board/keymile/common/ivm.c | 28 +++++++++++++++++----------- 1 files changed, 17 insertions(+), 11 deletions(-)
diff --git a/board/keymile/common/ivm.c b/board/keymile/common/ivm.c index 607daa6..d568fd9 100644 --- a/board/keymile/common/ivm.c +++ b/board/keymile/common/ivm.c @@ -201,6 +201,22 @@ static int ivm_check_crc(unsigned char *buf, int block) return 0; }
+static int calculate_mac_offset(unsigned char *valbuf, unsigned char *buf, + int offset) +{ + unsigned long val = (buf[4] << 16) + (buf[5] << 8) + buf[6]; + + if (offset == 0) + return 0; + + val += offset; + buf[4] = (val >> 16) & 0xff; + buf[5] = (val >> 8) & 0xff; + buf[6] = val & 0xff; + sprintf((char *)valbuf, "%pM", buf + 1); + return 0; +} + static int ivm_analyze_block2(unsigned char *buf, int len) { unsigned char valbuf[CONFIG_SYS_IVM_EEPROM_PAGE_LEN]; @@ -210,17 +226,7 @@ static int ivm_analyze_block2(unsigned char *buf, int len) sprintf((char *)valbuf, "%pM", buf + 1); ivm_set_value("IVM_MacAddress", (char *)valbuf); /* if an offset is defined, add it */ -#if defined(CONFIG_PIGGY_MAC_ADRESS_OFFSET) - if (CONFIG_PIGGY_MAC_ADRESS_OFFSET > 0) { - unsigned long val = (buf[4] << 16) + (buf[5] << 8) + buf[6]; - - val += CONFIG_PIGGY_MAC_ADRESS_OFFSET; - buf[4] = (val >> 16) & 0xff; - buf[5] = (val >> 8) & 0xff; - buf[6] = val & 0xff; - sprintf((char *)valbuf, "%pM", buf + 1); - } -#endif + calculate_mac_offset(buf, valbuf, CONFIG_PIGGY_MAC_ADRESS_OFFSET); #ifdef MACH_TYPE_KM_KIRKWOOD setenv((char *)"ethaddr", (char *)valbuf); #else
kmvect1 has a UEC2 connection to the piggy board and a UEC0 connection to the switch MV88E6122. This switch has a connection to a frontport ethernet interface. The ethernet port used for network booting is automatically selected by u-boot. If a Piggy is plugged, the Piggy port is selected (UEC2, eth1). If the Piggy isn't present, the Frontport is selected (UEC0, eth0).
The switch reset is connected to a GPIO on the PRIO3 board FPGA (GPIO28) and released at startup.
Signed-off-by: Karlheinz Jerg karlheinz.jerg@keymile.com Signed-off-by: Holger Brunck holger.brunck@keymile.com --- Changes for v2: - set eth1addr directly after reading out the inventory - make extsw_conf static - add __iomen macro
board/keymile/common/ivm.c | 8 ++++- board/keymile/km83xx/km83xx.c | 67 ++++++++++++++++++++++++++++++++++++ include/configs/km/km83xx-common.h | 8 +--- include/configs/suvd3.h | 37 ++++++++++++++++++++ 4 files changed, 113 insertions(+), 7 deletions(-)
diff --git a/board/keymile/common/ivm.c b/board/keymile/common/ivm.c index d568fd9..22d5256 100644 --- a/board/keymile/common/ivm.c +++ b/board/keymile/common/ivm.c @@ -233,7 +233,13 @@ static int ivm_analyze_block2(unsigned char *buf, int len) if (getenv("ethaddr") == NULL) setenv((char *)"ethaddr", (char *)valbuf); #endif - +#ifdef CONFIG_KMVECT1 +/* KMVECT1 has two ethernet interfaces */ + if (getenv("eth1addr") == NULL) { + calculate_mac_offset(buf, valbuf, 1); + setenv((char *)"eth1addr", (char *)valbuf); + } +#endif /* IVM_MacCount */ count = (buf[10] << 24) + (buf[11] << 16) + diff --git a/board/keymile/km83xx/km83xx.c b/board/keymile/km83xx/km83xx.c index b027173..1e8e2cc 100644 --- a/board/keymile/km83xx/km83xx.c +++ b/board/keymile/km83xx/km83xx.c @@ -215,8 +215,75 @@ int misc_init_r(void) return 0; }
+#if defined(CONFIG_KMVECT1) +#include <mv88e6352.h> +/* Marvell MV88E6122 switch configuration */ +static struct mv88e_sw_reg extsw_conf[] = { + /* port 1, FRONT_MDI, autoneg */ + { PORT(1), PORT_PHY, NO_SPEED_FOR }, + { PORT(1), PORT_CTRL, FORWARDING | EGRS_FLD_ALL }, + { PHY(1), PHY_1000_CTRL, NO_ADV }, + { PHY(1), PHY_SPEC_CTRL, AUTO_MDIX_EN }, + { PHY(1), PHY_CTRL, PHY_100_MBPS | AUTONEG_EN | AUTONEG_RST | + FULL_DUPLEX }, + /* port 2, unused */ + { PORT(2), PORT_CTRL, PORT_DIS }, + { PHY(2), PHY_CTRL, PHY_PWR_DOWN }, + { PHY(2), PHY_SPEC_CTRL, SPEC_PWR_DOWN }, + /* port 3, BP_MII (CPU), PHY mode, 100BASE */ + { PORT(3), PORT_CTRL, FORWARDING | EGRS_FLD_ALL }, + /* port 4, ESTAR to slot 11, SerDes, 1000BASE-X */ + { PORT(4), PORT_STATUS, NO_PHY_DETECT }, + { PORT(4), PORT_PHY, SPEED_1000_FOR }, + { PORT(4), PORT_CTRL, FORWARDING | EGRS_FLD_ALL }, + /* port 5, ESTAR to slot 13, SerDes, 1000BASE-X */ + { PORT(5), PORT_STATUS, NO_PHY_DETECT }, + { PORT(5), PORT_PHY, SPEED_1000_FOR }, + { PORT(5), PORT_CTRL, FORWARDING | EGRS_FLD_ALL }, + /* + * Errata Fix: 1.9V Output from Internal 1.8V Regulator, + * acc . MV-S300889-00D.pdf , clause 4.5 + */ + { PORT(5), 0x1A, 0xADB1 }, + /* port 6, unused, this port has no phy */ + { PORT(6), PORT_CTRL, PORT_DIS }, +}; +#endif + int last_stage_init(void) { +#if defined(CONFIG_KMVECT1) + struct km_bec_fpga __iomem *base = + (struct km_bec_fpga __iomem *)CONFIG_SYS_KMBEC_FPGA_BASE; + u8 tmp_reg; + + /* Release mv88e6122 from reset */ + tmp_reg = in_8(&base->res1[0]) | 0x10; /* DIRECT3 register */ + out_8(&base->res1[0], tmp_reg); /* GP28 as output */ + tmp_reg = in_8(&base->gprt3) | 0x10; /* GP28 to high */ + out_8(&base->gprt3, tmp_reg); + + /* configure MV88E6122 switch */ + char *name = "UEC2"; + + if (miiphy_set_current_dev(name)) + return 0; + + mv88e_sw_program(name, CONFIG_KM_MVEXTSW_ADDR, extsw_conf, + ARRAY_SIZE(extsw_conf)); + + mv88e_sw_reset(name, CONFIG_KM_MVEXTSW_ADDR); + + if (piggy_present()) { + setenv("ethact", "UEC2"); + setenv("netdev", "eth1"); + puts("using PIGGY for network boot\n"); + } else { + setenv("netdev", "eth0"); + puts("using frontport for network boot\n"); + } +#endif + #if defined(CONFIG_KMCOGE5NE) struct bfticu_iomap *base = (struct bfticu_iomap *)CONFIG_SYS_BFTIC3_BASE; diff --git a/include/configs/km/km83xx-common.h b/include/configs/km/km83xx-common.h index a9823d6..1e596c8 100644 --- a/include/configs/km/km83xx-common.h +++ b/include/configs/km/km83xx-common.h @@ -165,19 +165,15 @@ #define CONFIG_UEC_ETH #define CONFIG_ETHPRIME "UEC0"
+#if !defined(CONFIG_MPC8309) #define CONFIG_UEC_ETH1 /* GETH1 */ #define UEC_VERBOSE_DEBUG 1 +#endif
#ifdef CONFIG_UEC_ETH1 -#if defined(CONFIG_MPC8309) -#define CONFIG_SYS_UEC1_UCC_NUM 2 /* UCC3 */ -#define CONFIG_SYS_UEC1_RX_CLK QE_CLK_NONE /* not used in RMII Mode */ -#define CONFIG_SYS_UEC1_TX_CLK QE_CLK12 -#else #define CONFIG_SYS_UEC1_UCC_NUM 3 /* UCC4 */ #define CONFIG_SYS_UEC1_RX_CLK QE_CLK_NONE /* not used in RMII Mode */ #define CONFIG_SYS_UEC1_TX_CLK QE_CLK17 -#endif #define CONFIG_SYS_UEC1_ETH_TYPE FAST_ETH #define CONFIG_SYS_UEC1_PHY_ADDR 0 #define CONFIG_SYS_UEC1_INTERFACE_TYPE PHY_INTERFACE_MODE_RMII diff --git a/include/configs/suvd3.h b/include/configs/suvd3.h index c50832c..bbf9da5 100644 --- a/include/configs/suvd3.h +++ b/include/configs/suvd3.h @@ -110,4 +110,41 @@ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U
+/* + * QE UEC ethernet configuration + */ +#if defined(CONFIG_KMVECT1) +#define CONFIG_MV88E6352_SWITCH +#define CONFIG_KM_MVEXTSW_ADDR 0x10 + +/* ethernet port connected to simple switch 88e6122 (UEC0) */ +#define CONFIG_UEC_ETH1 +#define CONFIG_SYS_UEC1_UCC_NUM 0 /* UCC1 */ +#define CONFIG_SYS_UEC1_RX_CLK QE_CLK9 +#define CONFIG_SYS_UEC1_TX_CLK QE_CLK10 + +#define CONFIG_FIXED_PHY 0xFFFFFFFF +#define CONFIG_SYS_FIXED_PHY_ADDR 0x1E /* unused address */ +#define CONFIG_SYS_FIXED_PHY_PORT(devnum, speed, duplex) \ + {devnum, speed, duplex} +#define CONFIG_SYS_FIXED_PHY_PORTS \ + CONFIG_SYS_FIXED_PHY_PORT("UEC0", SPEED_100, DUPLEX_FULL) + +#define CONFIG_SYS_UEC1_ETH_TYPE FAST_ETH +#define CONFIG_SYS_UEC1_PHY_ADDR CONFIG_SYS_FIXED_PHY_ADDR +#define CONFIG_SYS_UEC1_INTERFACE_TYPE PHY_INTERFACE_MODE_MII +#define CONFIG_SYS_UEC1_INTERFACE_SPEED 100 + +/* ethernet port connected to piggy (UEC2) */ +#define CONFIG_HAS_ETH1 +#define CONFIG_UEC_ETH2 +#define CONFIG_SYS_UEC2_UCC_NUM 2 /* UCC3 */ +#define CONFIG_SYS_UEC2_RX_CLK QE_CLK_NONE /* not used in RMII Mode */ +#define CONFIG_SYS_UEC2_TX_CLK QE_CLK12 +#define CONFIG_SYS_UEC2_ETH_TYPE FAST_ETH +#define CONFIG_SYS_UEC2_PHY_ADDR 0 +#define CONFIG_SYS_UEC2_INTERFACE_TYPE PHY_INTERFACE_MODE_RMII +#define CONFIG_SYS_UEC2_INTERFACE_SPEED 100 +#endif /* CONFIG_KMVECT1 */ + #endif /* __CONFIG_H */
On this board we are using hard floating point, so select the correct toolchain.
include/configs/km/km8309-common.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/include/configs/km/km8309-common.h b/include/configs/km/km8309-common.h index b36e892..7bd1e92 100644 --- a/include/configs/km/km8309-common.h +++ b/include/configs/km/km8309-common.h @@ -22,7 +22,7 @@ #define CONFIG_MPC830x 1 /* MPC830x family */ #define CONFIG_MPC8309 1 /* MPC8309 CPU specific */
-#define CONFIG_KM_DEF_ARCH "arch=ppc_8xx\0" +#define CONFIG_KM_DEF_ARCH "arch=ppc_82xx\0" #define CONFIG_CMD_DIAG 1
/* include common defines/options for all 83xx Keymile boards */
Replace the hardcoded string with a variable. If CONFIG_NAND_ECC_BCH is set we use a specific name for the uImage (ecc_bch_uImage).
Signed-off-by: Andreas Huber andreas.huber@keymile.com Signed-off-by: Holger Brunck holger.brunck@keymile.com --- Changes for v2: - none
include/configs/km/keymile-common.h | 9 ++++++++- 1 files changed, 8 insertions(+), 1 deletions(-)
diff --git a/include/configs/km/keymile-common.h b/include/configs/km/keymile-common.h index f64748e..ae88759 100644 --- a/include/configs/km/keymile-common.h +++ b/include/configs/km/keymile-common.h @@ -148,6 +148,12 @@ "ubi part " CONFIG_KM_UBI_PARTITION_NAME_APP "; fi\0" #endif /* CONFIG_KM_UBI_PARTITION_NAME_APP */
+#ifdef CONFIG_NAND_ECC_BCH +#define CONFIG_KM_UIMAGE_NAME "ecc_bch_uImage\0" +#else +#define CONFIG_KM_UIMAGE_NAME "uImage\0" +#endif + /* * boottargets * - set 'subbootcmds' @@ -210,9 +216,10 @@ */ #define CONFIG_KM_DEF_ENV_FLASH_BOOT \ "cramfsaddr=" __stringify(CONFIG_KM_CRAMFS_ADDR) "\0" \ - "cramfsloadkernel=cramfsload ${load_addr_r} uImage\0" \ + "cramfsloadkernel=cramfsload ${load_addr_r} ${uimage}\0" \ "ubicopy=ubi read "__stringify(CONFIG_KM_CRAMFS_ADDR) \ " bootfs${boot_bank}\0" \ + "uimage=" CONFIG_KM_UIMAGE_NAME \ CONFIG_KM_DEV_ENV_FLASH_BOOT_UBI
Replace uImage with ${uimage}. If uimage is not set, default it to uImage.
board/keymile/scripts/develop-common.txt | 5 +++-- board/keymile/scripts/ramfs-common.txt | 5 +++-- 2 files changed, 6 insertions(+), 4 deletions(-)
diff --git a/board/keymile/scripts/develop-common.txt b/board/keymile/scripts/develop-common.txt index aa3d659..a6bb1b1 100644 --- a/board/keymile/scripts/develop-common.txt +++ b/board/keymile/scripts/develop-common.txt @@ -1,8 +1,9 @@ altbootcmd=run ${subbootcmds} bootcmd=run ${subbootcmds} -configure=km_setboardid && saveenv && reset +configure=run set_uimage; km_setboardid && saveenv && reset subbootcmds=tftpfdt tftpkernel nfsargs add_default boot nfsargs=setenv bootargs root=/dev/nfs rw nfsroot=${serverip}:${toolchain}/${arch} -tftpkernel=tftpboot ${load_addr_r} ${hostname}/uImage +tftpkernel=tftpboot ${load_addr_r} ${hostname}/${uimage} toolchain=/opt/eldk rootfssize=0 +set_uimage=printenv uimage || setenv uimage uImage diff --git a/board/keymile/scripts/ramfs-common.txt b/board/keymile/scripts/ramfs-common.txt index c1b45ab..8a8d287 100644 --- a/board/keymile/scripts/ramfs-common.txt +++ b/board/keymile/scripts/ramfs-common.txt @@ -4,8 +4,9 @@ altbootcmd=run ${subbootcmds} bootcmd=run ${subbootcmds} subbootcmds=tftpfdt tftpkernel setrootfsaddr tftpramfs flashargs add_default addpanic addramfs boot nfsargs=setenv bootargs root=/dev/nfs rw nfsroot=${serverip}:${rootpath} -configure=km_setboardid && saveenv && reset +configure=run set_uimage; km_setboardid && saveenv && reset rootfsfile=${hostname}/rootfsImage setrootfsaddr=setexpr value ${pnvramaddr} - ${rootfssize} && setenv rootfsaddr 0x${value} -tftpkernel=tftpboot ${load_addr_r} ${hostname}/uImage +tftpkernel=tftpboot ${load_addr_r} ${hostname}/${uimage} tftpramfs=tftpboot ${rootfsaddr} ${hostname}/rootfsImage +set_uimage=printenv uimage || setenv uimage uImage
If CONFIG_NAND_ECC_BCH is set we use 4-bit error corretion code instead of the 1-bit error correction code on the NAND device within this driver.
Signed-off-by: Holger Brunck holger.brunck@keymile.com Acked-by: Scott Wood scottwood@freescale.com --- Changes for v2: - add Acked-by: Scott Wood
drivers/mtd/nand/kmeter1_nand.c | 4 ++++ 1 files changed, 4 insertions(+), 0 deletions(-)
diff --git a/drivers/mtd/nand/kmeter1_nand.c b/drivers/mtd/nand/kmeter1_nand.c index e8e5b7b..f044597 100644 --- a/drivers/mtd/nand/kmeter1_nand.c +++ b/drivers/mtd/nand/kmeter1_nand.c @@ -119,7 +119,11 @@ static int kpn_nand_dev_ready(struct mtd_info *mtd)
int board_nand_init(struct nand_chip *nand) { +#if defined(CONFIG_NAND_ECC_BCH) + nand->ecc.mode = NAND_ECC_SOFT_BCH; +#else nand->ecc.mode = NAND_ECC_SOFT; +#endif
/* Reference hardware control function */ nand->cmd_ctrl = kpn_nand_hwcontrol;
Switch from 1-bit ecc to 4-bit ecc.
include/configs/km8360.h | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/include/configs/km8360.h b/include/configs/km8360.h index 7631ab6..5b191bc 100644 --- a/include/configs/km8360.h +++ b/include/configs/km8360.h @@ -25,6 +25,8 @@ #define CONFIG_KM_BOARD_NAME "kmcoge5ne" #define CONFIG_KM_DEF_NETDEV "netdev=eth1\0" #define CONFIG_CMD_NAND +#define CONFIG_NAND_ECC_BCH +#define CONFIG_BCH #define CONFIG_NAND_KMETER1 #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define NAND_MAX_CHIPS 1
If CONFIG_NAND_ECC_BCH is chosen from in the board configuration we add an ecc mode to the kernel commandline.
include/configs/km/keymile-common.h | 3 +++ 1 files changed, 3 insertions(+), 0 deletions(-)
diff --git a/include/configs/km/keymile-common.h b/include/configs/km/keymile-common.h index ae88759..796f330 100644 --- a/include/configs/km/keymile-common.h +++ b/include/configs/km/keymile-common.h @@ -150,8 +150,10 @@
#ifdef CONFIG_NAND_ECC_BCH #define CONFIG_KM_UIMAGE_NAME "ecc_bch_uImage\0" +#define CONFIG_KM_ECC_MODE " eccmode=bch" #else #define CONFIG_KM_UIMAGE_NAME "uImage\0" +#define CONFIG_KM_ECC_MODE #endif
/* @@ -190,6 +192,7 @@ ":${hostname}:${netdev}:off3" \ " console=" CONFIG_KM_CONSOLE_TTY ",${baudrate}" \ " mem=${kernelmem} init=${init}" \ + CONFIG_KM_ECC_MODE \ " phram.phram=phvar,${varaddr}," __stringify(CONFIG_KM_PHRAM)\ " " CONFIG_KM_UBI_LINUX_MTD " " \ CONFIG_KM_DEF_BOOT_ARGS_CPU \
This is a preparation for the upcoming kmopti2 board. This board has also a second fpga on board which is different to the tuxx1 target. But we want to use the same header file. So remove the config option KM_DISABLE_APP2 and simply use the board names to distinguish the features.
boards.cfg | 6 +++--- include/configs/tuxx1.h | 17 +++++++++-------- 2 files changed, 12 insertions(+), 11 deletions(-)
diff --git a/boards.cfg b/boards.cfg index e4b0d44..1c78991 100644 --- a/boards.cfg +++ b/boards.cfg @@ -700,9 +700,9 @@ SIMPC8313_SP powerpc mpc83xx simpc8313 sheldon TQM834x powerpc mpc83xx tqm834x tqc suvd3 powerpc mpc83xx km83xx keymile - suvd3:SUVD3 kmvect1 powerpc mpc83xx km83xx keymile - suvd3:KMVECT1 -tuge1 powerpc mpc83xx km83xx keymile - tuxx1:KM_DISABLE_APP2,TUGE1 -tuxx1 powerpc mpc83xx km83xx keymile -kmsupx5 powerpc mpc83xx km83xx keymile - tuxx1:KM_DISABLE_APP2,KMSUPX5 +tuge1 powerpc mpc83xx km83xx keymile - tuxx1:TUGE1 +tuxx1 powerpc mpc83xx km83xx keymile - tuxx1:TUXX1 +kmsupx5 powerpc mpc83xx km83xx keymile - tuxx1:KMSUPX5 sbc8548 powerpc mpc85xx sbc8548 - - sbc8548 sbc8548_PCI_33 powerpc mpc85xx sbc8548 - - sbc8548:PCI,33 sbc8548_PCI_33_PCIE powerpc mpc85xx sbc8548 - - sbc8548:PCI,33,PCIE diff --git a/include/configs/tuxx1.h b/include/configs/tuxx1.h index 90d2e61..3997717 100644 --- a/include/configs/tuxx1.h +++ b/include/configs/tuxx1.h @@ -11,7 +11,7 @@ * (C) Copyright 2008 * Heiko Schocher, DENX Software Engineering, hs@denx.de. * - * (C) Copyright 2010-2012 + * (C) Copyright 2010-2013 * Lukas Roggli, KEYMILE Ltd, lukas.roggli@keymile.com * Holger Brunck, Keymile GmbH, holger.bruncl@keymile.com * @@ -27,16 +27,17 @@ /* * High Level Configuration Options */ -#ifdef CONFIG_KMSUPX5 +#if defined(CONFIG_KMSUPX5) #define CONFIG_KM_BOARD_NAME "kmsupx5" #define CONFIG_HOSTNAME kmsupx5 -#elif defined CONFIG_TUGE1 +#elif defined(CONFIG_TUGE1) #define CONFIG_KM_BOARD_NAME "tuge1" #define CONFIG_HOSTNAME tuge1 -#else -#define CONFIG_TUXXX /* TUXX1 board (tuxa1/tuda1) specific */ +#elif defined(CONFIG_TUXX1) /* TUXX1 board (tuxa1/tuda1) specific */ #define CONFIG_KM_BOARD_NAME "tuxx1" #define CONFIG_HOSTNAME tuxx1 +#else +#error ("Board not supported") #endif
#define CONFIG_SYS_TEXT_BASE 0xF0000000 @@ -46,7 +47,7 @@
#define CONFIG_SYS_APP1_BASE 0xA0000000 /* PAXG */ #define CONFIG_SYS_APP1_SIZE 256 /* Megabytes */ -#ifndef CONFIG_KM_DISABLE_APP2 +#if defined(CONFIG_TUXX1) #define CONFIG_SYS_APP2_BASE 0xB0000000 /* PINC3 */ #define CONFIG_SYS_APP2_SIZE 256 /* Megabytes */ #endif @@ -81,7 +82,7 @@ OR_GPCM_TRLX_SET | \ OR_GPCM_EHTR_CLEAR | \ OR_GPCM_EAD) -#ifndef CONFIG_KM_DISABLE_APP2 +#if defined(CONFIG_TUXX1) /* * Configuration for C3 on the local bus */ @@ -125,7 +126,7 @@ BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U
-#ifdef CONFIG_KM_DISABLE_APP2 +#if defined(CONFIG_TUGE1) || defined(CONFIG_KMSUPX5) #define CONFIG_SYS_IBAT6L (0) #define CONFIG_SYS_IBAT6U (0) #define CONFIG_SYS_DBAT6L CONFIG_SYS_IBAT6L
This board is similar to TUXX1 but it has a different sized second FPGA. Therefore the configuration for the third chipselect is different.
boards.cfg | 1 + include/configs/tuxx1.h | 31 +++++++++++++++++++++++++------ 2 files changed, 26 insertions(+), 6 deletions(-)
diff --git a/boards.cfg b/boards.cfg index 1c78991..01acf19 100644 --- a/boards.cfg +++ b/boards.cfg @@ -702,6 +702,7 @@ suvd3 powerpc mpc83xx km83xx keymile kmvect1 powerpc mpc83xx km83xx keymile - suvd3:KMVECT1 tuge1 powerpc mpc83xx km83xx keymile - tuxx1:TUGE1 tuxx1 powerpc mpc83xx km83xx keymile - tuxx1:TUXX1 +kmopti2 powerpc mpc83xx km83xx keymile - tuxx1:KMOPTI2 kmsupx5 powerpc mpc83xx km83xx keymile - tuxx1:KMSUPX5 sbc8548 powerpc mpc85xx sbc8548 - - sbc8548 sbc8548_PCI_33 powerpc mpc85xx sbc8548 - - sbc8548:PCI,33 diff --git a/include/configs/tuxx1.h b/include/configs/tuxx1.h index 3997717..6caf23a 100644 --- a/include/configs/tuxx1.h +++ b/include/configs/tuxx1.h @@ -36,6 +36,9 @@ #elif defined(CONFIG_TUXX1) /* TUXX1 board (tuxa1/tuda1) specific */ #define CONFIG_KM_BOARD_NAME "tuxx1" #define CONFIG_HOSTNAME tuxx1 +#elif defined(CONFIG_KMOPTI2) +#define CONFIG_KM_BOARD_NAME "kmopti2" +#define CONFIG_HOSTNAME kmopti2 #else #error ("Board not supported") #endif @@ -47,18 +50,18 @@
#define CONFIG_SYS_APP1_BASE 0xA0000000 /* PAXG */ #define CONFIG_SYS_APP1_SIZE 256 /* Megabytes */ -#if defined(CONFIG_TUXX1) +#if defined(CONFIG_TUXX1) || defined(CONFIG_KMOPTI2) #define CONFIG_SYS_APP2_BASE 0xB0000000 /* PINC3 */ #define CONFIG_SYS_APP2_SIZE 256 /* Megabytes */ #endif
/* * Init Local Bus Memory Controller: - * - * Bank Bus Machine PortSz Size Device on TUDA1 TUXA1 TUGE1 KMSUPX4 - * ---- --- ------- ------ ----- --------------------------------------- - * 2 Local GPCM 8 bit 256MB PAXG LPXF PAXI LPXF - * 3 Local GPCM 8 bit 256MB PINC3 PINC2 unused unused + * Device on + * Bank Bus Machine PortSz Size TUDA1 TUXA1 TUGE1 KMSUPX4 KMOPTI2 + * ---- --- ------- ------ ----- --------------------------------------- + * 2 Local GPCM 8 bit 256MB PAXG LPXF PAXI LPXF PAXE + * 3 Local GPCM 8 bit 256MB PINC3 PINC2 unused unused OPI2(16 bit) * */
@@ -108,6 +111,22 @@ MxMR_WLFx_2X) #endif
+#if defined(CONFIG_KMOPTI2) +/* + * Configuration for C3 on the local bus + */ +#define CONFIG_SYS_LBLAWBAR3_PRELIM CONFIG_SYS_APP2_BASE +#define CONFIG_SYS_LBLAWAR3_PRELIM (LBLAWAR_EN | LBLAWAR_256MB) +#define CONFIG_SYS_BR3_PRELIM (CONFIG_SYS_APP2_BASE | \ + BR_PS_16 | \ + BR_MS_GPCM | \ + BR_V) +#define CONFIG_SYS_OR3_PRELIM (MEG_TO_AM(CONFIG_SYS_APP2_SIZE) | \ + OR_GPCM_SCY_4 | \ + OR_GPCM_TRLX_CLEAR | \ + OR_GPCM_EHTR_CLEAR) +#endif + /* * MMU Setup */
Remove it from the processor specific headers. This is already defined in the common header km83xx.h.
include/configs/km/km8309-common.h | 2 -- include/configs/km/km8321-common.h | 2 -- 2 files changed, 0 insertions(+), 4 deletions(-)
diff --git a/include/configs/km/km8309-common.h b/include/configs/km/km8309-common.h index 7bd1e92..7f9cffa 100644 --- a/include/configs/km/km8309-common.h +++ b/include/configs/km/km8309-common.h @@ -33,8 +33,6 @@ /* at end of uboot partition, before env */ #define CONFIG_SYS_QE_FMAN_FW_ADDR 0xF00B0000
-#define CONFIG_MISC_INIT_R - /* * System IO Config */ diff --git a/include/configs/km/km8321-common.h b/include/configs/km/km8321-common.h index 8ad6fc3..abb9081 100644 --- a/include/configs/km/km8321-common.h +++ b/include/configs/km/km8321-common.h @@ -38,8 +38,6 @@ /* include common defines/options for all 83xx Keymile boards */ #include "km83xx-common.h"
There is no need for a environment variable to configure the dtt bus.
Signed-off-by: Holger Brunck holger.brunck@keymile.com --- Changes for v2: - change commit message
board/keymile/km83xx/km83xx.c | 12 ++++-------- include/configs/km/km83xx-common.h | 1 - 2 files changed, 4 insertions(+), 9 deletions(-)
diff --git a/board/keymile/km83xx/km83xx.c b/board/keymile/km83xx/km83xx.c index 1e8e2cc..faaa39b 100644 --- a/board/keymile/km83xx/km83xx.c +++ b/board/keymile/km83xx/km83xx.c @@ -98,17 +98,13 @@ const qe_iop_conf_t qe_iop_conf_tab[] = { static int board_init_i2c_busses(void) { I2C_MUX_DEVICE *dev = NULL; - uchar *buf; + uchar *dtt_bus = (uchar *)"pca9547:70:a";
/* Set up the Bus for the DTTs */ - buf = (unsigned char *) getenv("dtt_bus"); - if (buf != NULL) - dev = i2c_mux_ident_muxstring(buf); - if (dev == NULL) { + dev = i2c_mux_ident_muxstring(dtt_bus); + if (dev == NULL) printf("Error couldn't add Bus for DTT\n"); - printf("please setup dtt_bus to where your\n"); - printf("DTT is found.\n"); - } + return 0; }
diff --git a/include/configs/km/km83xx-common.h b/include/configs/km/km83xx-common.h index 1e596c8..eb0e5b6 100644 --- a/include/configs/km/km83xx-common.h +++ b/include/configs/km/km83xx-common.h @@ -312,7 +312,6 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ CONFIG_KM_DEF_ENV \ CONFIG_KM_DEF_ARCH \ - "dtt_bus=pca9547:70:a\0" \ "EEprom_ivm=pca9547:70:9\0" \ "newenv=" \ "prot off 0xF00C0000 +0x40000 && " \
On Mon, 21 Jan 2013 14:55:13 +0100 Holger Brunck holger.brunck@keymile.com wrote:
applied 16 out of 16 patches.
Thanks,
Kim
Hi Tom,
Please pull the latest set of keymile 83xx board updates:
The following changes since commit 9a82b10c6657c5744802971036bb564ebc660291:
Merge branch 'master' of git://git.denx.de/u-boot (2013-02-15 17:46:50 -0600)
git://git.denx.de/u-boot-mpc83xx.git master
for you to fetch changes up to 411190cb16b63e39345a608b68b3d1be5168117a:
powerpc/83xx/km: drop uneeded dtt_bus environment var (2013-02-15 17:47:21 -0600)
---------------------------------------------------------------- Andreas Huber (2): km/common: introduce $uimage variable km/scripts: replace hardcoded uImage
Holger Brunck (12): km/common: remove unneeded ifdefs for I2C km/common/ivm: remove obsolete code km/common/ivm: remove CONFIG_SYS_I2C_IVM_BUS related code km/common/ivm: rework piggy mac adress offset generation powerpc/83xx: use ppc_6xx as arch variable for kmvect1 kmeter1_nand: allow uasge of NAND_ECC_SOFT_BCH powerpc/83xx: use NAND_ECC_BCH for kmcoge5ne km/common: add eccmode to kernel commandline powerpc/83xx/km: cleanup tuxx1 support powerpc/83xx/km: add support for kmopti2 board powerpc/83xx/km: remove uneeded CONFIG_MISC_INIT_R powerpc/83xx/km: drop uneeded dtt_bus environment var
Karlheinz Jerg (2): km82xx, km83xx: move ethernet_present() from common to cpu specific powerpc/83xx/km: add MV88E6122 switch support for kmvect1
board/keymile/common/common.c | 13 ---- board/keymile/common/ivm.c | 48 +++++++------- board/keymile/km82xx/km82xx.c | 8 +++ board/keymile/km83xx/km83xx.c | 103 ++++++++++++++++++++++++++++--- board/keymile/scripts/develop-common.txt | 5 +- board/keymile/scripts/ramfs-common.txt | 5 +- boards.cfg | 7 ++- drivers/mtd/nand/kmeter1_nand.c | 4 ++ include/configs/km/keymile-common.h | 12 +++- include/configs/km/km8309-common.h | 4 +- include/configs/km/km8321-common.h | 2 - include/configs/km/km83xx-common.h | 9 +-- include/configs/km8360.h | 2 + include/configs/suvd3.h | 37 +++++++++++ include/configs/tuxx1.h | 46 ++++++++++---- 15 files changed, 226 insertions(+), 79 deletions(-)
Thanks,
Kim
On Fri, Feb 15, 2013 at 05:59:44PM -0600, Kim Phillips wrote:
Hi Tom,
Holger Brunck
Kim Phillips
