[U-Boot] [PATCH] Do not mux and setup SPI if disabled in the config
This allows baseboards without SPI to compile.
Signed-off-by: Clemens Gruber clemens.gruber@pqgruber.com Cc: Markus Niebel Markus.Niebel@tq-group.com Cc: Tom Rini trini@konsulko.com --- board/tqc/tqma6/tqma6.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/board/tqc/tqma6/tqma6.c b/board/tqc/tqma6/tqma6.c index 29db838..5c4d104 100644 --- a/board/tqc/tqma6/tqma6.c +++ b/board/tqc/tqma6/tqma6.c @@ -131,6 +131,8 @@ int board_mmc_init(bd_t *bis) return 0; }
+#if defined(CONFIG_MXC_SPI) + static iomux_v3_cfg_t const tqma6_ecspi1_pads[] = { /* SS1 */ NEW_PAD_CTRL(MX6_PAD_EIM_D19__GPIO3_IO19, SPI_PAD_CTRL), @@ -161,6 +163,8 @@ int board_spi_cs_gpio(unsigned bus, unsigned cs) (cs == CONFIG_SF_DEFAULT_CS)) ? TQMA6_SF_CS_GPIO : -1; }
+#endif /* defined(CONFIG_MXC_SPI) */ + static struct i2c_pads_info tqma6_i2c3_pads = { /* I2C3: on board LM75, M24C64, */ .scl = { @@ -201,7 +205,9 @@ int board_init(void) /* address of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
+#if defined(CONFIG_MXC_SPI) tqma6_iomuxc_spi(); +#endif tqma6_setup_i2c();
tqma6_bb_board_init();
(added Stefano as imx custodian)
- static iomux_v3_cfg_t const tqma6_ecspi1_pads[] = { /* SS1 */ NEW_PAD_CTRL(MX6_PAD_EIM_D19__GPIO3_IO19, SPI_PAD_CTRL),
- static struct i2c_pads_info tqma6_i2c3_pads = { /* I2C3: on board LM75, M24C64, */ .scl = {
Hmmm. This should not be necessary. Please take a look at the wru4 baseboard addition that is already in mainline. Especially this patch:
commit 34ee786e5b388625e5a0e0891ee69d4bbf34178b Author: Stefan Roese sr@denx.de Date: Thu Mar 12 13:34:30 2015 +0100
arm: mx6: tqma6: Update to optionally configure an alternative SPI setup
By making the tqma6_iomuxc_spi() weak, this patch adds the possibility to add a different function for this SPI configuration. This can be used by other baseboards, that might have a different SPI setup.
This patch will be used by the upcoming WRU-IV board support which also uses the TQMa6 SoM.
Signed-off-by: Stefan Roese sr@denx.de
This is enough in your baseboard file now:
void tqma6_iomuxc_spi(void) { /* No SPI on this baseboard */ }
Thanks, Stefan
Hi Stefan,
Thanks.
I noticed your patch but then we would still have to define CONFIG_SF_DEFAULT_BUS and CONFIG_SF_DEFAULT_CS in our board config or include the tqma6.h config, which defines too many things we do not need.
The problem is, we have different clocks and more c files, so we use a separate board directory and a separate board config without SPI defines and just use obj-y += ../../tqc/tqma6/tqma6.o in front of our object files in the Makefile.
If we don't exclude those SPI parts, we would either have to define those SPI config options (which does not make sense) or move all of our board code in one file under tqc/tqma6 which is not an option, we also define additional clocks via a separate IMX_CONFIG file.
Wouldn't it be better to always exclude this code when not using SPI instead of weakly defining the tqma6_iomuxc_spi function? Then small baseboards could be put in tqc/tqma6 and larger projects could still just link to tqma6.o and put all their stuff in a separate board directory.
arm: mx6: tqma6: Update to optionally configure an alternative SPI setup By making the tqma6_iomuxc_spi() weak, this patch adds the possibility to add a different function for this SPI configuration. This can be used by other baseboards, that might have a different SPI setup. This patch will be used by the upcoming WRU-IV board support which also uses the TQMa6 SoM. Signed-off-by: Stefan Roese <sr@denx.de>
Thanks, Stefan
Regards, Clemens
Hi Clemens,
I would have expected that all boards using these TQ SoM's include this config header.
How about this patch:
diff --git a/board/tqc/tqma6/tqma6.c b/board/tqc/tqma6/tqma6.c index 29db838..345930f 100644 --- a/board/tqc/tqma6/tqma6.c +++ b/board/tqc/tqma6/tqma6.c @@ -28,6 +28,13 @@
#include "tqma6_bb.h"
+#ifndef CONFIG_SF_DEFAULT_BUS +#define CONFIG_SF_DEFAULT_BUS 0 +#endif +#ifndef CONFIG_SF_DEFAULT_CS +#define CONFIG_SF_DEFAULT_CS 0 +#endif
Does this work for you?
Thanks, Stefan
On 5 August 2015 at 13:35, Stefan Roese sr@denx.de wrote:
Hi Clemens,
Why would need this - it's already part of spi_flash.h
thanks!
I am also wondering about commit f85764cc1f6ab01ffc60dd78de9c4de4cff2b5ce, which defines CONFIG_SPI_FLASH in the WRU4 defconfig file, even though it does not need SPI flash support, just to work around undefined reference errors regarding spi_flash_free, etc.
Couldn't those workarounds be avoided by excluding the SPI parts via ifdefs, as I did in my patch today?
thanks!
Jagan | openedev.
Thanks, Clemens
Right. But as mentioned before I really would like to avoid those ifdef's. So let me check if I can get this done in a more clean way.
Thanks, Stefan
Hi Stefan,
This should work, but wouldn't it be cleaner to just exclude the SPI parts? Why add 7 LOC when 4 LOC are enough to exclude the SPI parts? Besides that, it reduces the binary size.
Then we could also remove the empty SPI function from all board files, if SPI is not used.
Thanks, Stefan
Regards, Clemens
Hi Clemens,
The binary size should be the same (I didn't check this). The linker should remove the not referenced functions / variables.
As for the added 7 LOC, Jagans suggestion to include "spi_flash.h" should also work instead. This seems to be a nice solution for me that doesn't add any new #ifdef's to the code.
Thanks, Stefan
Clemens Gruber
Jagan Teki
Stefan Roese
