[U-Boot] Pull request: nand flash
The following changes since commit a6f0c4faa4c65a7b7048b12c9d180d7e1aad1721:
Merge branch 'master' of git://git.denx.de/u-boot-avr32 (2012-09-04 09:17:27 +0200)
git://git.denx.de/u-boot-nand-flash.git master
for you to fetch changes up to 9c60e75e05dab5a0197728b6a940aaac02762936:
mxc nand: Homogenize IP revisions with Linux (2012-09-17 19:51:45 -0500)
---------------------------------------------------------------- Benoît Thébaudeau (12): mxc nand: Merge mtd and spl register definitions mxc nand: cosmectic: Light cleanup spl mxc nand: Merge duplicated code spl mxc nand: Remove duplicated code spl mxc nand: Set symmetric mode mxc nand: Access all ecc_status_result fields spl mxc nand: Fix broken boot for correctable ECC errors mtd mxc nand: Use _mxc_nand_enable_hwecc() mtd mxc nand: Fix ECC state after read_page_raw_syndrome() mtd mxc nand: Merge init functions mxc nand: Let driver detect IP revision mxc nand: Homogenize IP revisions with Linux
Joe Hershberger (4): nand: Add support for unlock.invert nand: Change ulong to loff_t and size_t nand: consolidate duplicated constants nand: Make NAND lock status compatible with Micron
Marek Vasut (1): mtd: nand: allow NAND_NO_SUBPAGE_WRITE to be set from driver
Matthieu CASTET (1): mtd: support ONFI multi lun NAND
common/cmd_nand.c | 21 ++- doc/README.nand | 2 + drivers/mtd/nand/mxc_nand.c | 335 +++++++++++------------------------------- drivers/mtd/nand/nand_base.c | 10 +- drivers/mtd/nand/nand_util.c | 26 ++-- include/configs/flea3.h | 1 - include/configs/mx35pdk.h | 1 - include/configs/tx25.h | 1 - include/fsl_nfc.h | 113 +++++++------- include/linux/mtd/nand.h | 5 +- include/nand.h | 6 +- nand_spl/nand_boot_fsl_nfc.c | 121 ++++++++------- 12 files changed, 251 insertions(+), 391 deletions(-)
Beno?t Th?baudeau (12):
[snip]
On mxc platforms this introduced: mxc_nand.c: In function 'board_nand_init': mxc_nand.c:1170:11: warning: unused variable 'tmp' [-Wunused-variable]
I've done the trivial fixup and committed that as well.
The whole request is applied, with the above note, to u-boot/master, thanks!
Scott Wood
