[U-Boot] Pull request: u-boot-uniphier
Hi Tom,
The following changes since commit 21866c34a1b4098a8868c9250daf01baf84c2397:
at91sam9rlek_mmc_defconfig: Add CONFIG_ARCH_AT91=y (2015-03-20 10:47:38 -0400)
git://git.denx.de/u-boot-uniphier.git master
for you to fetch changes up to 90e357efed06767d87c49280bc25272fdf378612:
ARM: UniPhier: remove unnecessary ifdef conditional (2015-03-24 00:16:02 +0900)
---------------------------------------------------------------- Masahiro Yamada (14): ARM: UniPhier: remove unnecessary CONFIG_SYS_SOC ARM: UniPhier: include PH1-LD4 Makefile from PH1-sLD8 ARM: UniPhier: move platform devices to SPL ARM: UniPhier: move UART pin settings to SPL ARM: UniPhier: enable CONFIG_PANIC_HANG ARM: UniPhier: enable Driver Model and UART on SPL ARM: UniPhier: use CONFIG_SPL_STACK to define SPL stack pointer ARM: UniPhier: add CONFIG_SPL_MAX_FOOTPRINT ARM: UniPhier: move init stack area just below TEXT_BASE ARM: UniPhier: add empty lowlevel_init to U-boot proper ARM: UniPhier: fix typos in comments ARM: UniPhier: optimize kicking secondary CPUs code ARM: UniPhier: disable L2 cache by lowlevel_init of U-Boot proper ARM: UniPhier: remove unnecessary ifdef conditional
arch/arm/mach-uniphier/Kconfig | 3 --- arch/arm/mach-uniphier/Makefile | 2 +- arch/arm/mach-uniphier/cache_uniphier.c | 32 ++------------------------------ arch/arm/mach-uniphier/init_page_table.S | 10 +++++++++- arch/arm/mach-uniphier/late_lowlevel_init.S | 17 +++++++++++++++++ arch/arm/mach-uniphier/lowlevel_init.S | 63 +++++++++++++++++++++++++++++++++++++++++++++++---------------- arch/arm/mach-uniphier/ph1-ld4/Makefile | 4 ++-- arch/arm/mach-uniphier/ph1-ld4/early_pinctrl.c | 27 +++++++++++++++++++++++++++ arch/arm/mach-uniphier/ph1-ld4/pinctrl.c | 18 ++---------------- arch/arm/mach-uniphier/ph1-pro4/Makefile | 4 ++-- arch/arm/mach-uniphier/ph1-pro4/early_pinctrl.c | 27 +++++++++++++++++++++++++++ arch/arm/mach-uniphier/ph1-pro4/pinctrl.c | 15 ++------------- arch/arm/mach-uniphier/ph1-sld8/Makefile | 17 +---------------- arch/arm/mach-uniphier/ph1-sld8/early_pinctrl.c | 27 +++++++++++++++++++++++++++ arch/arm/mach-uniphier/ph1-sld8/pinctrl.c | 18 ++---------------- arch/arm/mach-uniphier/smp.S | 54 ------------------------------------------------------ arch/arm/mach-uniphier/spl.c | 18 +++++++++++++++--- arch/arm/mach-uniphier/support_card.c | 11 ++++++----- configs/ph1_ld4_defconfig | 1 + configs/ph1_pro4_defconfig | 1 + configs/ph1_sld8_defconfig | 1 + include/configs/uniphier.h | 20 ++++++++------------ 22 files changed, 200 insertions(+), 190 deletions(-) create mode 100644 arch/arm/mach-uniphier/late_lowlevel_init.S create mode 100644 arch/arm/mach-uniphier/ph1-ld4/early_pinctrl.c create mode 100644 arch/arm/mach-uniphier/ph1-pro4/early_pinctrl.c create mode 100644 arch/arm/mach-uniphier/ph1-sld8/early_pinctrl.c delete mode 100644 arch/arm/mach-uniphier/smp.S
On Tue, Mar 24, 2015 at 12:22:17AM +0900, Masahiro Yamada wrote:
Hi Tom,
Masahiro Yamada
