[PATCH] gpio-uclass: fix gpio lookup by label
Matching anything that just happens to have the sought-for label as a prefix is wrong. For example, if the board designer has designated 10 lines for debug purposes, named "debug1" through "debug10", and we are looking up "debug1", if debug10 happens to be met first during the iteration we'd wrongly return that.
In theory, this can break existing users that could rely on this quirk, but OTOH keeping the current broken semantics can cause a lot of grief for people hitting this in the future and not understanding why they don't find the line they expect. Considering how few in-tree defconfigs currently set DM_GPIO_LOOKUP_LABEL (ignoring sandbox, only four "real" boards), let's fix it before the use becomes more widespread.
Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- drivers/gpio/gpio-uclass.c | 4 +--- 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/gpio/gpio-uclass.c b/drivers/gpio/gpio-uclass.c index 0ed32b7217..01342202fa 100644 --- a/drivers/gpio/gpio-uclass.c +++ b/drivers/gpio/gpio-uclass.c @@ -91,15 +91,13 @@ static int gpio_to_device(unsigned int gpio, struct gpio_desc *desc) static int dm_gpio_lookup_label(const char *name, struct gpio_dev_priv *uc_priv, ulong *offset) { - int len; int i;
*offset = -1; - len = strlen(name); for (i = 0; i < uc_priv->gpio_count; i++) { if (!uc_priv->name[i]) continue; - if (!strncmp(name, uc_priv->name[i], len)) { + if (!strcmp(name, uc_priv->name[i])) { *offset = i; return 0; }
On Mon, 3 Oct 2022 at 03:03, Rasmus Villemoes rasmus.villemoes@prevas.dk wrote:
It seems like we need a one-sided strncmp():
int strncmp(const char *match, const char *str, int max_len_of_str)
Eh, could you spell out what the semantics of that one would be? I can't think of anything that would differ from actual strncmp().
for (i = 0; i < m; ++i) { if (a[i] != b[i]) return a[i] - b[i]; if (!a[i]) break; } return 0;
And why would we want anything other than actual string equality here?
Oh, and now that I look at lib/string.c, both the generic strcmp() and strncmp() are broken. They correctly distinguish equality/inequality (up to the given bound), but they don't compare strings correctly, for several reasons. Sigh. Patch coming later.
Rasmus
Hi Rasmus,
On Tue, 4 Oct 2022 at 07:43, Rasmus Villemoes rasmus.villemoes@prevas.dk wrote:
Your patch is fine which is why I added the tag.
OK.
Re the one-sided strncmp(), I mean that the second string has to be at least as long as the first, but can be longer.
Hello Rasmus,
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
Hello Rasmus,
bye, Heiko
Heiko Schocher
Rasmus Villemoes
