[PATCH 1/2] sunxi: add H2+ config option
Add H2+ Kconfig oiption to display proper cpu at boot time, and for other future uses, if needed, to differentiate against H3.
The patch does not change any board defconfig at this stage, so that nothing is broken.
Tested this CONFIG_MACH_SUN8I_H2_PLUS to work properly on banana pi m2 zero.
Signed-off-by: Angelo Dureghello angelo.dureghello@timesys.com --- arch/arm/cpu/armv7/sunxi/Makefile | 1 + arch/arm/cpu/armv7/sunxi/psci.c | 2 ++ arch/arm/cpu/armv7/sunxi/tzpc.c | 2 +- arch/arm/dts/Makefile | 5 +++++ arch/arm/include/asm/arch-sunxi/cpu_sun4i.h | 4 ++-- arch/arm/mach-sunxi/Kconfig | 9 +++++++++ arch/arm/mach-sunxi/board.c | 3 ++- arch/arm/mach-sunxi/cpu_info.c | 6 ++++-- arch/arm/mach-sunxi/dram_sunxi_dw.c | 4 ++-- drivers/clk/sunxi/Makefile | 1 + drivers/video/sunxi/sunxi_de2.c | 2 +- 11 files changed, 30 insertions(+), 9 deletions(-)
diff --git a/arch/arm/cpu/armv7/sunxi/Makefile b/arch/arm/cpu/armv7/sunxi/Makefile index 1d40d6a18d..5fdfe45401 100644 --- a/arch/arm/cpu/armv7/sunxi/Makefile +++ b/arch/arm/cpu/armv7/sunxi/Makefile @@ -8,6 +8,7 @@ obj-y += timer.o
obj-$(CONFIG_MACH_SUN6I) += tzpc.o +obj-$(CONFIG_MACH_SUN8I_H2_PLUS) += tzpc.o obj-$(CONFIG_MACH_SUN8I_H3) += tzpc.o
ifndef CONFIG_SPL_BUILD diff --git a/arch/arm/cpu/armv7/sunxi/psci.c b/arch/arm/cpu/armv7/sunxi/psci.c index 1ac50f558a..bcdbe888bc 100644 --- a/arch/arm/cpu/armv7/sunxi/psci.c +++ b/arch/arm/cpu/armv7/sunxi/psci.c @@ -79,6 +79,7 @@ static void __secure __mdelay(u32 ms) static void __secure clamp_release(u32 __maybe_unused *clamp) { #if defined(CONFIG_MACH_SUN6I) || defined(CONFIG_MACH_SUN7I) || \ + defined(CONFIG_MACH_SUN8I_H2_PLUS) || \ defined(CONFIG_MACH_SUN8I_H3) || \ defined(CONFIG_MACH_SUN8I_R40) u32 tmp = 0x1ff; @@ -94,6 +95,7 @@ static void __secure clamp_release(u32 __maybe_unused *clamp) static void __secure clamp_set(u32 __maybe_unused *clamp) { #if defined(CONFIG_MACH_SUN6I) || defined(CONFIG_MACH_SUN7I) || \ + defined(CONFIG_MACH_SUN8I_H2_PLUS) || \ defined(CONFIG_MACH_SUN8I_H3) || \ defined(CONFIG_MACH_SUN8I_R40) writel(0xff, clamp); diff --git a/arch/arm/cpu/armv7/sunxi/tzpc.c b/arch/arm/cpu/armv7/sunxi/tzpc.c index 0c86a21a3f..44640509ff 100644 --- a/arch/arm/cpu/armv7/sunxi/tzpc.c +++ b/arch/arm/cpu/armv7/sunxi/tzpc.c @@ -17,7 +17,7 @@ void tzpc_init(void) writel(SUN6I_TZPC_DECPORT0_RTC, &tzpc->decport0_set); #endif
-#ifdef CONFIG_MACH_SUN8I_H3 +#if defined(CONFIG_MACH_SUN8I_H2_PLUS) || defined(CONFIG_MACH_SUN8I_H3) /* Enable non-secure access to all peripherals */ writel(SUN8I_H3_TZPC_DECPORT0_ALL, &tzpc->decport0_set); writel(SUN8I_H3_TZPC_DECPORT1_ALL, &tzpc->decport1_set); diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index b8a382d153..2e58815769 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -598,6 +598,11 @@ dtb-$(CONFIG_MACH_SUN8I_A83T) += \ sun8i-a83t-bananapi-m3.dtb \ sun8i-a83t-cubietruck-plus.dtb \ sun8i-a83t-tbs-a711.dtb +dtb-$(CONFIG_MACH_SUN8I_H2_PLUS) += \ + sun8i-h2-plus-bananapi-m2-zero.dtb \ + sun8i-h2-plus-libretech-all-h3-cc.dtb \ + sun8i-h2-plus-orangepi-r1.dtb \ + sun8i-h2-plus-orangepi-zero.dtb dtb-$(CONFIG_MACH_SUN8I_H3) += \ sun8i-h2-plus-bananapi-m2-zero.dtb \ sun8i-h2-plus-libretech-all-h3-cc.dtb \ diff --git a/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h b/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h index d4c795d89c..b7a66b91e7 100644 --- a/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h +++ b/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h @@ -15,7 +15,7 @@ !defined(CONFIG_MACH_SUN8I_R40) && \ !defined(CONFIG_MACH_SUN8I_V3S) #define SUNXI_SRAM_A2_BASE 0x00040000 -#ifdef CONFIG_MACH_SUN8I_H3 +#if defined(CONFIG_MACH_SUN8I_H2_PLUS) || defined(CONFIG_MACH_SUN8I_H3) #define SUNXI_SRAM_A2_SIZE (48 * 1024) /* 16+32 kiB */ #else #define SUNXI_SRAM_A2_SIZE (80 * 1024) /* 16+64 kiB */ @@ -174,7 +174,7 @@ defined(CONFIG_MACH_SUN50I) /* module sram */ #define SUNXI_SRAM_C_BASE 0x01d00000
-#ifndef CONFIG_MACH_SUN8I_H3 +#if !defined(CONFIG_MACH_SUN8I_H2_PLUS) && !defined(CONFIG_MACH_SUN8I_H3) #define SUNXI_DE_FE0_BASE 0x01e00000 #else #define SUNXI_TVE0_BASE 0x01e00000 diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 1d4a4fdd0c..eae8a0e68b 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -288,6 +288,15 @@ config MACH_SUN8I_A83T select MMC_SUNXI_HAS_MODE_SWITCH select SUPPORT_SPL
+config MACH_SUN8I_H2_PLUS + bool "sun8i (Allwinner H2+)" + select CPU_V7A + select CPU_V7_HAS_NONSEC + select CPU_V7_HAS_VIRT + select ARCH_SUPPORT_PSCI + select MACH_SUNXI_H3_H5 + select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT + config MACH_SUN8I_H3 bool "sun8i (Allwinner H3)" select CPU_V7A diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index d9b04f75fc..adb63e93e7 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -228,7 +228,8 @@ void s_init(void) "mcr p15, 0, r0, c1, c0, 1\n" ::: "r0"); #endif -#if defined CONFIG_MACH_SUN6I || defined CONFIG_MACH_SUN8I_H3 +#if defined CONFIG_MACH_SUN6I || defined CONFIG_MACH_SUN8I_H2_PLUS || \ + defined CONFIG_MACH_SUN8I_H3 /* Enable non-secure access to some peripherals */ tzpc_init(); #endif diff --git a/arch/arm/mach-sunxi/cpu_info.c b/arch/arm/mach-sunxi/cpu_info.c index ba33ef2430..429e5ce283 100644 --- a/arch/arm/mach-sunxi/cpu_info.c +++ b/arch/arm/mach-sunxi/cpu_info.c @@ -85,6 +85,8 @@ int print_cpuinfo(void) printf("CPU: Allwinner A33 (SUN8I %04x)\n", sunxi_get_sram_id()); #elif defined CONFIG_MACH_SUN8I_A83T printf("CPU: Allwinner A83T (SUN8I %04x)\n", sunxi_get_sram_id()); +#elif defined CONFIG_MACH_SUN8I_H2_PLUS + printf("CPU: Allwinner H2+ (SUN8I %04x)\n", sunxi_get_sram_id()); #elif defined CONFIG_MACH_SUN8I_H3 printf("CPU: Allwinner H3 (SUN8I %04x)\n", sunxi_get_sram_id()); #elif defined CONFIG_MACH_SUN8I_R40 @@ -109,7 +111,7 @@ int print_cpuinfo(void) } #endif
#define SIDC_PRCTL 0x40 #define SIDC_RDKEY 0x60 @@ -143,7 +145,7 @@ int sunxi_get_sid(unsigned int *sid) { #ifdef CONFIG_AXP221_POWER return axp_get_sid(sid); -#elif defined CONFIG_MACH_SUN8I_H3 +#elif defined(CONFIG_MACH_SUN8I_H2_PLUS) || defined(CONFIG_MACH_SUN8I_H3) /* * H3 SID controller has a bug, which makes the initial value of * SUNXI_SID_BASE at boot wrong. diff --git a/arch/arm/mach-sunxi/dram_sunxi_dw.c b/arch/arm/mach-sunxi/dram_sunxi_dw.c index 9107b114df..f28c23d0c6 100644 --- a/arch/arm/mach-sunxi/dram_sunxi_dw.c +++ b/arch/arm/mach-sunxi/dram_sunxi_dw.c @@ -863,7 +863,7 @@ unsigned long sunxi_dram_init(void) } },
-#if defined(CONFIG_MACH_SUN8I_H3) +#if defined(CONFIG_MACH_SUN8I_H2_PLUS) || defined(CONFIG_MACH_SUN8I_H3) .dx_read_delays = SUN8I_H3_DX_READ_DELAYS, .dx_write_delays = SUN8I_H3_DX_WRITE_DELAYS, .ac_delays = SUN8I_H3_AC_DELAYS, @@ -890,7 +890,7 @@ unsigned long sunxi_dram_init(void) * the static functions. This saves us #ifdefs, but still keeps the binary * small. */ -#if defined(CONFIG_MACH_SUN8I_H3) +#if defined(CONFIG_MACH_SUN8I_H2_PLUS) || defined(CONFIG_MACH_SUN8I_H3) uint16_t socid = SOCID_H3; #elif defined(CONFIG_MACH_SUN8I_R40) uint16_t socid = SOCID_R40; diff --git a/drivers/clk/sunxi/Makefile b/drivers/clk/sunxi/Makefile index 4f9282a8b9..d8565b3946 100644 --- a/drivers/clk/sunxi/Makefile +++ b/drivers/clk/sunxi/Makefile @@ -16,6 +16,7 @@ obj-$(CONFIG_CLK_SUN8I_A83T) += clk_a83t.o obj-$(CONFIG_CLK_SUN8I_R40) += clk_r40.o obj-$(CONFIG_CLK_SUN8I_V3S) += clk_v3s.o obj-$(CONFIG_CLK_SUN9I_A80) += clk_a80.o +obj-$(CONFIG_CLK_SUN8I_H2_PLUS) += clk_h3.o obj-$(CONFIG_CLK_SUN8I_H3) += clk_h3.o obj-$(CONFIG_CLK_SUN50I_H6) += clk_h6.o obj-$(CONFIG_CLK_SUN50I_H616) += clk_h616.o diff --git a/drivers/video/sunxi/sunxi_de2.c b/drivers/video/sunxi/sunxi_de2.c index e02d359cd2..2af2ae4cac 100644 --- a/drivers/video/sunxi/sunxi_de2.c +++ b/drivers/video/sunxi/sunxi_de2.c @@ -84,7 +84,7 @@ static void sunxi_de2_mode_set(int mux, const struct display_timing *mode, u32 format;
/* enable clock */ -#ifdef CONFIG_MACH_SUN8I_H3 +#if defined(CONFIG_MACH_SUN8I_H2_PLUS) || defined(CONFIG_MACH_SUN8I_H3) setbits_le32(&de_clk_regs->rst_cfg, (mux == 0) ? 1 : 4); #else setbits_le32(&de_clk_regs->rst_cfg, BIT(mux));
Fix non working console on uart2, that seems releated to both Allwinner H2+ and H3.
Signed-off-by: Angelo Dureghello angelo.dureghello@timesys.com --- arch/arm/include/asm/arch-sunxi/gpio.h | 1 + arch/arm/mach-sunxi/board.c | 10 +++++++++- 2 files changed, 10 insertions(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-sunxi/gpio.h b/arch/arm/include/asm/arch-sunxi/gpio.h index 2969a530ae..21fcfd5638 100644 --- a/arch/arm/include/asm/arch-sunxi/gpio.h +++ b/arch/arm/include/asm/arch-sunxi/gpio.h @@ -150,6 +150,7 @@ enum sunxi_gpio_number { #define SUN7I_GPA_GMAC 5 #define SUN6I_GPA_SDC2 5 #define SUN6I_GPA_SDC3 4 +#define SUN8I_GPA_UART2 2 #define SUN8I_H3_GPA_UART0 2
#define SUN4I_GPB_PWM 2 diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index adb63e93e7..623da744e2 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -145,10 +145,18 @@ static int gpio_init(void) sunxi_gpio_set_cfgpin(SUNXI_GPG(3), SUN5I_GPG_UART1); sunxi_gpio_set_cfgpin(SUNXI_GPG(4), SUN5I_GPG_UART1); sunxi_gpio_set_pull(SUNXI_GPG(4), SUNXI_GPIO_PULL_UP); -#elif CONFIG_CONS_INDEX == 3 && defined(CONFIG_MACH_SUN8I) +#elif CONFIG_CONS_INDEX == 3 && defined(CONFIG_MACH_SUN8I) && \ + !defined(CONFIG_MACH_SUN8I_H2_PLUS) && \ + !defined(CONFIG_MACH_SUN8I_H3) sunxi_gpio_set_cfgpin(SUNXI_GPB(0), SUN8I_GPB_UART2); sunxi_gpio_set_cfgpin(SUNXI_GPB(1), SUN8I_GPB_UART2); sunxi_gpio_set_pull(SUNXI_GPB(1), SUNXI_GPIO_PULL_UP); +#elif CONFIG_CONS_INDEX == 3 && defined(CONFIG_MACH_SUN8I) && \ + (defined(CONFIG_MACH_SUN8I_H2_PLUS) || \ + defined(CONFIG_MACH_SUN8I_H3)) + sunxi_gpio_set_cfgpin(SUNXI_GPA(0), SUN8I_GPA_UART2); + sunxi_gpio_set_cfgpin(SUNXI_GPA(1), SUN8I_GPA_UART2); + sunxi_gpio_set_pull(SUNXI_GPA(1), SUNXI_GPIO_PULL_UP); #elif CONFIG_CONS_INDEX == 5 && defined(CONFIG_MACH_SUN8I) sunxi_gpio_set_cfgpin(SUNXI_GPL(2), SUN8I_GPL_R_UART); sunxi_gpio_set_cfgpin(SUNXI_GPL(3), SUN8I_GPL_R_UART);
On Sat, 9 Oct 2021 14:18:59 +0200 Angelo Dureghello angelo.dureghello@timesys.com wrote:
Hi Angelo,
can you please mention the H3 in the subject line, so it's more obvious that's it's only about one SoC?
- !defined(CONFIG_MACH_SUN8I_H2_PLUS) && \
- !defined(CONFIG_MACH_SUN8I_H3) sunxi_gpio_set_cfgpin(SUNXI_GPB(0), SUN8I_GPB_UART2); sunxi_gpio_set_cfgpin(SUNXI_GPB(1), SUN8I_GPB_UART2); sunxi_gpio_set_pull(SUNXI_GPB(1), SUNXI_GPIO_PULL_UP);
CONFIG_MACH_SUN8I is redundant if you use CONFIG_MACH_SUN8I_H3 below, so drop the former. And if you rearrange this section to come before the existing one above, the #elif will save you changes there. Also please drop CONFIG_MACH_SUN8I_H2_PLUS.
But the actual gist of this patch (UART2 is on portA) is indeed correct.
Cheers, Andre
- (defined(CONFIG_MACH_SUN8I_H2_PLUS) || \
- sunxi_gpio_set_cfgpin(SUNXI_GPA(0), SUN8I_GPA_UART2);
- sunxi_gpio_set_cfgpin(SUNXI_GPA(1), SUN8I_GPA_UART2);
- sunxi_gpio_set_pull(SUNXI_GPA(1), SUNXI_GPIO_PULL_UP);
Dropped CONFIG_MACH_SUN8I_H2_PLUS, reordered as suggested in the other reply, and applied to sunxi/master.
Thanks! Andre
On Sat, 9 Oct 2021 14:18:58 +0200 Angelo Dureghello angelo.dureghello@timesys.com wrote:
Hi Angelo,
But why? What does that fix except the hardcoded CPU output line? I only see a lot of churn and future issues (forgetting to add MACH_SUN8I_H2_PLUS). As far as we know the two SoCs are very close, and are almost indistinguishable by software, that's why we treat them the same. So is there a good reason for differentiating the two? If you are *really* desperate about that one "CPU: ..." line, have a look at https://linux-sunxi.org/H3#Variants and see if you can make this decision at runtime, check A31 and A31s for an example.
Cheers, Andre
- defined(CONFIG_MACH_SUN8I_H2_PLUS) || \ defined(CONFIG_MACH_SUN8I_H3) || \ defined(CONFIG_MACH_SUN8I_R40) u32 tmp = 0x1ff;
- defined(CONFIG_MACH_SUN8I_H2_PLUS) || \ defined(CONFIG_MACH_SUN8I_H3) || \ defined(CONFIG_MACH_SUN8I_R40) writel(0xff, clamp);
- sun8i-h2-plus-bananapi-m2-zero.dtb \
- sun8i-h2-plus-libretech-all-h3-cc.dtb \
- sun8i-h2-plus-orangepi-r1.dtb \
- sun8i-h2-plus-orangepi-zero.dtb
- bool "sun8i (Allwinner H2+)"
- select CPU_V7A
- select CPU_V7_HAS_NONSEC
- select CPU_V7_HAS_VIRT
- select ARCH_SUPPORT_PSCI
- select MACH_SUNXI_H3_H5
- select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT
- defined CONFIG_MACH_SUN8I_H3 /* Enable non-secure access to some peripherals */ tzpc_init();
- printf("CPU: Allwinner H2+ (SUN8I %04x)\n", sunxi_get_sram_id());
- the static functions. This saves us #ifdefs, but still keeps the binary
- small.
Hi Andre,
Hi Angelo,
This "desperate" sounds a bit ugly :) I can live without of course :) .
I faced the uart2 console not working issue (fixed in 2/2), and initially thought it was a H2+ / H3 difference, but it was not. Anyway, i finally thought that a differentiation may be useful If not, just trow the patch in the bin.
In the case you may still be interested differentiating the two just to print cpu model, or any future need, an alternative safer proposal may be something like:
config MACH_SUN8I_H2_PLUS select MACH_SUN8I_H3
Cheers, Andre
cheers, angelo
select CPU_V7A
- small.
/* enable clock */
-- Angelo Dureghello Timesys e. angelo.dureghello@timesys.com
Andre Przywara
Angelo Dureghello
