[U-Boot] MicroBlaze target: Where should CONFIG_SPI_FLASH_BAR be defined?
19 Nov
2015
19 Nov
'15
2:58 a.m.
Hello,
I've got a 32MByte Micron SPI Flash and I am unable to access the upper half of the part due to CONFIG_SPI_FLASH_BAR not being defined when my u-boot.elf is built. I am using the Petalinux version 2013.10 toolset to build the u-boot.elf and image.elf artifacts and am still at a loss as to where and how CONFIG_SPI_FLASH_BAR needs to be defined.
Your prompt assistance would be greatly appreciated.
Thank you, Scott Welsh
3464
Scott Welsh
