[PATCH] imx: Add support for i.MX8MN Beacon EmbeddedWorks devkit.
Beacon EmbeddedWorks, formerly known as Logic PD, is releasing a devkit based on the i.MX8M Nano SoC consisting of baseboard + SOM. It is nearly identical to the i.MX8M Mini SOM already released.
It supports eMMC on the SOM, microSD on the baseboard, various GPIO, the PINCTRL, and UART.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index cee10f533f..f2c4429982 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -753,6 +753,7 @@ dtb-$(CONFIG_ARCH_IMX8M) += \ imx8mn-ddr4-evk.dtb \ imx8mq-evk.dtb \ imx8mm-beacon-kit.dtb \ + imx8mn-beacon-kit.dtb \ imx8mq-phanbell.dtb \ imx8mp-evk.dtb \ imx8mq-pico-pi.dtb diff --git a/arch/arm/dts/imx8mn-beacon-baseboard.dtsi b/arch/arm/dts/imx8mn-beacon-baseboard.dtsi new file mode 100644 index 0000000000..9ee2e29080 --- /dev/null +++ b/arch/arm/dts/imx8mn-beacon-baseboard.dtsi @@ -0,0 +1,220 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +/* + * Copyright 2020 Compass Electronics Group, LLC + */ + +/ { + leds { + compatible = "gpio-leds"; + + led0 { + label = "gen_led0"; + gpios = <&pca6416_1 4 GPIO_ACTIVE_HIGH>; + default-state = "none"; + }; + + led1 { + label = "gen_led1"; + gpios = <&pca6416_1 5 GPIO_ACTIVE_HIGH>; + default-state = "none"; + }; + + led2 { + label = "gen_led2"; + gpios = <&pca6416_1 6 GPIO_ACTIVE_HIGH>; + default-state = "none"; + }; + + led3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_led3>; + label = "heartbeat"; + gpios = <&gpio4 28 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + }; + + reg_usdhc2_vmmc: regulator-usdhc2 { + compatible = "regulator-fixed"; + regulator-name = "VSD_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio2 19 GPIO_ACTIVE_HIGH>; + vin-supply = <&buck4_reg>; + enable-active-high; + }; +}; + +&ecspi2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_espi2>; + cs-gpios = <&gpio5 9 0>; + status = "okay"; + + eeprom@0 { + compatible = "microchip,at25160bn", "atmel,at25"; + reg = <0>; + spi-max-frequency = <5000000>; + spi-cpha; + spi-cpol; + pagesize = <32>; + size = <2048>; + address-width = <16>; + }; +}; + +&i2c2 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; +}; + +&i2c4 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c4>; + status = "okay"; + + pca6416_0: gpio@20 { + compatible = "nxp,pcal6416"; + reg = <0x20>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pcal6414>; + gpio-controller; + #gpio-cells = <2>; + interrupt-parent = <&gpio4>; + interrupts = <27 IRQ_TYPE_LEVEL_LOW>; + }; + + pca6416_1: gpio@21 { + compatible = "nxp,pcal6416"; + reg = <0x21>; + gpio-controller; + #gpio-cells = <2>; + interrupt-parent = <&gpio4>; + interrupts = <27 IRQ_TYPE_LEVEL_LOW>; + }; +}; + +&snvs_pwrkey { + status = "okay"; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + status = "okay"; +}; + +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3>; + assigned-clocks = <&clk IMX8MN_CLK_UART3>; + assigned-clock-parents = <&clk IMX8MN_SYS_PLL1_80M>; + status = "okay"; +}; + +&usdhc2 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; + pinctrl-1 = <&pinctrl_usdhc2_100mhz>; + pinctrl-2 = <&pinctrl_usdhc2_200mhz>; + bus-width = <4>; + vmmc-supply = <®_usdhc2_vmmc>; + status = "okay"; +}; + +&iomuxc { + pinctrl_espi2: espi2grp { + fsl,pins = < + MX8MN_IOMUXC_ECSPI2_SCLK_ECSPI2_SCLK 0x82 + MX8MN_IOMUXC_ECSPI2_MOSI_ECSPI2_MOSI 0x82 + MX8MN_IOMUXC_ECSPI2_MISO_ECSPI2_MISO 0x82 + MX8MN_IOMUXC_ECSPI1_SS0_GPIO5_IO9 0x41 + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX8MN_IOMUXC_I2C2_SCL_I2C2_SCL 0x400001c3 + MX8MN_IOMUXC_I2C2_SDA_I2C2_SDA 0x400001c3 + >; + }; + + pinctrl_i2c4: i2c4grp { + fsl,pins = < + MX8MN_IOMUXC_I2C4_SCL_I2C4_SCL 0x400001c3 + MX8MN_IOMUXC_I2C4_SDA_I2C4_SDA 0x400001c3 + >; + }; + + pinctrl_led3: led3grp { + fsl,pins = < + MX8MN_IOMUXC_SAI3_RXFS_GPIO4_IO28 0x41 + >; + }; + + pinctrl_pcal6414: pcal6414-gpio { + fsl,pins = < + MX8MN_IOMUXC_SAI2_MCLK_GPIO4_IO27 0x19 + >; + }; + + pinctrl_uart2: uart2grp { + fsl,pins = < + MX8MN_IOMUXC_UART2_RXD_UART2_DCE_RX 0x140 + MX8MN_IOMUXC_UART2_TXD_UART2_DCE_TX 0x140 + >; + }; + + pinctrl_uart3: uart3grp { + fsl,pins = < + MX8MN_IOMUXC_ECSPI1_SCLK_UART3_DCE_RX 0x40 + MX8MN_IOMUXC_ECSPI1_MOSI_UART3_DCE_TX 0x40 + >; + }; + + pinctrl_usdhc2_gpio: usdhc2grpgpio { + fsl,pins = < + MX8MN_IOMUXC_SD2_CD_B_USDHC2_CD_B 0x41 + MX8MN_IOMUXC_SD2_RESET_B_GPIO2_IO19 0x41 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + MX8MN_IOMUXC_SD2_CLK_USDHC2_CLK 0x190 + MX8MN_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d0 + MX8MN_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d0 + MX8MN_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d0 + MX8MN_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d0 + MX8MN_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d0 + MX8MN_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x1d0 + >; + }; + + pinctrl_usdhc2_100mhz: usdhc2grp100mhz { + fsl,pins = < + MX8MN_IOMUXC_SD2_CLK_USDHC2_CLK 0x194 + MX8MN_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d4 + MX8MN_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d4 + MX8MN_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d4 + MX8MN_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d4 + MX8MN_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d4 + MX8MN_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x1d0 + >; + }; + + pinctrl_usdhc2_200mhz: usdhc2grp200mhz { + fsl,pins = < + MX8MN_IOMUXC_SD2_CLK_USDHC2_CLK 0x196 + MX8MN_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d6 + MX8MN_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d6 + MX8MN_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d6 + MX8MN_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d6 + MX8MN_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d6 + MX8MN_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x1d0 + >; + }; +}; diff --git a/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi b/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi new file mode 100644 index 0000000000..e496a038c5 --- /dev/null +++ b/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi @@ -0,0 +1,128 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2020 Compass Electronics Group, LLC + */ + +/ { + wdt-reboot { + compatible = "wdt-reboot"; + wdt = <&wdog1>; + u-boot,dm-spl; + }; +}; + +&{/soc@0} { + u-boot,dm-pre-reloc; + u-boot,dm-spl; +}; + +&clk { + u-boot,dm-spl; + u-boot,dm-pre-reloc; +}; + +&osc_24m { + u-boot,dm-spl; + u-boot,dm-pre-reloc; +}; + +&aips1 { + u-boot,dm-spl; + u-boot,dm-pre-reloc; +}; + +&aips2 { + u-boot,dm-spl; +}; + +&aips3 { + u-boot,dm-spl; +}; + +&fec1 { + phy-reset-gpios = <&gpio4 22 GPIO_ACTIVE_LOW>; +}; + +&gpio1 { + u-boot,dm-spl; +}; + +&gpio2 { + u-boot,dm-spl; +}; + +&gpio3 { + u-boot,dm-spl; +}; + +&gpio4 { + u-boot,dm-spl; +}; + +&gpio5 { + u-boot,dm-spl; +}; + +&iomuxc { + u-boot,dm-spl; +}; + +&pca6416_0 { + compatible = "ti,tca6416"; +}; + +&pca6416_1 { + compatible = "ti,tca6416"; +}; + +&pinctrl_i2c1 { + u-boot,dm-spl; +}; + +&pinctrl_pmic { + u-boot,dm-spl; +}; + +&pinctrl_uart2 { + u-boot,dm-spl; +}; + +&pinctrl_usdhc2_gpio { + u-boot,dm-spl; +}; + +&pinctrl_usdhc2 { + u-boot,dm-spl; +}; + +&pinctrl_usdhc3 { + u-boot,dm-spl; +}; + +&uart2 { + u-boot,dm-spl; +}; + +&usdhc1 { + u-boot,dm-spl; +}; + +&usdhc2 { + u-boot,dm-spl; +}; + +&usdhc3 { + u-boot,dm-spl; +}; + +&wdog1 { + u-boot,dm-spl; +}; + +&{/soc@0/bus@30800000/i2c@30a20000/pmic@4b} { + u-boot,dm-spl; +}; + +&{/soc@0/bus@30800000/i2c@30a20000/pmic@4b/regulators} { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/imx8mn-beacon-kit.dts b/arch/arm/dts/imx8mn-beacon-kit.dts new file mode 100644 index 0000000000..1392ce0258 --- /dev/null +++ b/arch/arm/dts/imx8mn-beacon-kit.dts @@ -0,0 +1,19 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +/* + * Copyright 2020 Compass Electronics Group, LLC + */ + +/dts-v1/; + +#include "imx8mn.dtsi" +#include "imx8mn-beacon-som.dtsi" +#include "imx8mn-beacon-baseboard.dtsi" + +/ { + model = "Beacon EmbeddedWorks i.MX8M Nano Development Kit"; + compatible = "beacon,imx8mn-beacon-kit", "fsl,imx8mn"; + + chosen { + stdout-path = &uart2; + }; +}; diff --git a/arch/arm/dts/imx8mn-beacon-som.dtsi b/arch/arm/dts/imx8mn-beacon-som.dtsi new file mode 100644 index 0000000000..6446bef998 --- /dev/null +++ b/arch/arm/dts/imx8mn-beacon-som.dtsi @@ -0,0 +1,390 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +/* + * Copyright 2020 Compass Electronics Group, LLC + */ + +/ { + usdhc1_pwrseq: usdhc1_pwrseq { + compatible = "mmc-pwrseq-simple"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc1_gpio>; + reset-gpios = <&gpio2 10 GPIO_ACTIVE_LOW>; + clocks = <&osc_32k>; + clock-names = "ext_clock"; + post-power-on-delay-ms = <80>; + }; + + memory@40000000 { + device_type = "memory"; + reg = <0x0 0x40000000 0 0x80000000>; + }; +}; + +&A53_0 { + cpu-supply = <&buck2_reg>; +}; + +&fec1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_fec1>; + phy-mode = "rgmii-id"; + phy-handle = <ðphy0>; + fsl,magic-packet; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy0: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0>; + }; + }; +}; + +&i2c1 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; + + pmic@4b { + compatible = "rohm,bd71847"; + reg = <0x4b>; + pinctrl-0 = <&pinctrl_pmic>; + interrupt-parent = <&gpio1>; + interrupts = <3 GPIO_ACTIVE_LOW>; + rohm,reset-snvs-powered; + + regulators { + buck1_reg: BUCK1 { + regulator-name = "buck1"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1300000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <1250>; + }; + + buck2_reg: BUCK2 { + regulator-name = "buck2"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1300000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <1250>; + rohm,dvs-run-voltage = <1000000>; + rohm,dvs-idle-voltage = <900000>; + }; + + buck3_reg: BUCK3 { + // BUCK5 in datasheet + regulator-name = "buck3"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1350000>; + regulator-boot-on; + regulator-always-on; + }; + + buck4_reg: BUCK4 { + // BUCK6 in datasheet + regulator-name = "buck4"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + buck5_reg: BUCK5 { + // BUCK7 in datasheet + regulator-name = "buck5"; + regulator-min-microvolt = <1605000>; + regulator-max-microvolt = <1995000>; + regulator-boot-on; + regulator-always-on; + }; + + buck6_reg: BUCK6 { + // BUCK8 in datasheet + regulator-name = "buck6"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1400000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo1_reg: LDO1 { + regulator-name = "ldo1"; + regulator-min-microvolt = <1600000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo2_reg: LDO2 { + regulator-name = "ldo2"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <900000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo3_reg: LDO3 { + regulator-name = "ldo3"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo4_reg: LDO4 { + regulator-name = "ldo4"; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo6_reg: LDO6 { + regulator-name = "ldo6"; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + }; + }; +}; + +&i2c3 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + status = "okay"; + + eeprom@50 { + compatible = "microchip, at24c64d", "atmel,24c64"; + pagesize = <32>; + read-only; /* Manufacturing EEPROM programmed at factory */ + reg = <0x50>; + }; + + rtc@51 { + compatible = "nxp,pcf85263"; + reg = <0x51>; + }; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + assigned-clocks = <&clk IMX8MN_CLK_UART1>; + assigned-clock-parents = <&clk IMX8MN_SYS_PLL1_80M>; + uart-has-rtscts; + status = "okay"; + + bluetooth { + compatible = "brcm,bcm43438-bt"; + shutdown-gpios = <&gpio2 6 GPIO_ACTIVE_HIGH>; + host-wakeup-gpios = <&gpio2 8 GPIO_ACTIVE_HIGH>; + device-wakeup-gpios = <&gpio2 7 GPIO_ACTIVE_HIGH>; + clocks = <&osc_32k>; + clock-names = "extclk"; + }; +}; + +&usdhc1 { + #address-cells = <1>; + #size-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc1>; + bus-width = <4>; + non-removable; + cap-power-off-card; + pm-ignore-notify; + keep-power-in-suspend; + mmc-pwrseq = <&usdhc1_pwrseq>; + status = "okay"; + + brcmf: bcrmf@1 { + reg = <1>; + compatible = "brcm,bcm4329-fmac"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wlan>; + interrupt-parent = <&gpio2>; + interrupts = <9 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "host-wake"; + }; +}; + +&usdhc3 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc3>; + pinctrl-1 = <&pinctrl_usdhc3_100mhz>; + pinctrl-2 = <&pinctrl_usdhc3_200mhz>; + bus-width = <8>; + non-removable; + status = "okay"; +}; + +&wdog1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wdog>; + fsl,ext-reset-output; + status = "okay"; +}; + +&iomuxc { + pinctrl_fec1: fec1grp { + fsl,pins = < + MX8MN_IOMUXC_ENET_MDC_ENET1_MDC 0x3 + MX8MN_IOMUXC_ENET_MDIO_ENET1_MDIO 0x3 + MX8MN_IOMUXC_ENET_TD3_ENET1_RGMII_TD3 0x1f + MX8MN_IOMUXC_ENET_TD2_ENET1_RGMII_TD2 0x1f + MX8MN_IOMUXC_ENET_TD1_ENET1_RGMII_TD1 0x1f + MX8MN_IOMUXC_ENET_TD0_ENET1_RGMII_TD0 0x1f + MX8MN_IOMUXC_ENET_RD3_ENET1_RGMII_RD3 0x91 + MX8MN_IOMUXC_ENET_RD2_ENET1_RGMII_RD2 0x91 + MX8MN_IOMUXC_ENET_RD1_ENET1_RGMII_RD1 0x91 + MX8MN_IOMUXC_ENET_RD0_ENET1_RGMII_RD0 0x91 + MX8MN_IOMUXC_ENET_TXC_ENET1_RGMII_TXC 0x1f + MX8MN_IOMUXC_ENET_RXC_ENET1_RGMII_RXC 0x91 + MX8MN_IOMUXC_ENET_RX_CTL_ENET1_RGMII_RX_CTL 0x91 + MX8MN_IOMUXC_ENET_TX_CTL_ENET1_RGMII_TX_CTL 0x1f + MX8MN_IOMUXC_SAI2_RXC_GPIO4_IO22 0x19 + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX8MN_IOMUXC_I2C1_SCL_I2C1_SCL 0x400001c3 + MX8MN_IOMUXC_I2C1_SDA_I2C1_SDA 0x400001c3 + >; + }; + + pinctrl_i2c3: i2c3grp { + fsl,pins = < + MX8MN_IOMUXC_I2C3_SCL_I2C3_SCL 0x400001c3 + MX8MN_IOMUXC_I2C3_SDA_I2C3_SDA 0x400001c3 + >; + }; + + pinctrl_pmic: pmicirq { + fsl,pins = < + MX8MN_IOMUXC_GPIO1_IO03_GPIO1_IO3 0x41 + >; + }; + + pinctrl_uart1: uart1grp { + fsl,pins = < + MX8MN_IOMUXC_UART1_RXD_UART1_DCE_RX 0x140 + MX8MN_IOMUXC_UART1_TXD_UART1_DCE_TX 0x140 + MX8MN_IOMUXC_UART3_RXD_UART1_DCE_CTS_B 0x140 + MX8MN_IOMUXC_UART3_TXD_UART1_DCE_RTS_B 0x140 + MX8MN_IOMUXC_SD1_DATA4_GPIO2_IO6 0x19 + MX8MN_IOMUXC_SD1_DATA5_GPIO2_IO7 0x19 + MX8MN_IOMUXC_SD1_DATA6_GPIO2_IO8 0x19 + MX8MN_IOMUXC_GPIO1_IO00_ANAMIX_REF_CLK_32K 0x141 + >; + }; + + pinctrl_usdhc1_gpio: usdhc1grpgpio { + fsl,pins = < + MX8MN_IOMUXC_SD1_RESET_B_GPIO2_IO10 0x41 + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + MX8MN_IOMUXC_SD1_CLK_USDHC1_CLK 0x190 + MX8MN_IOMUXC_SD1_CMD_USDHC1_CMD 0x1d0 + MX8MN_IOMUXC_SD1_DATA0_USDHC1_DATA0 0x1d0 + MX8MN_IOMUXC_SD1_DATA1_USDHC1_DATA1 0x1d0 + MX8MN_IOMUXC_SD1_DATA2_USDHC1_DATA2 0x1d0 + MX8MN_IOMUXC_SD1_DATA3_USDHC1_DATA3 0x1d0 + >; + }; + + pinctrl_usdhc1_100mhz: usdhc1grp100mhz { + fsl,pins = < + MX8MN_IOMUXC_SD1_CLK_USDHC1_CLK 0x194 + MX8MN_IOMUXC_SD1_CMD_USDHC1_CMD 0x1d4 + MX8MN_IOMUXC_SD1_DATA0_USDHC1_DATA0 0x1d4 + MX8MN_IOMUXC_SD1_DATA1_USDHC1_DATA1 0x1d4 + MX8MN_IOMUXC_SD1_DATA2_USDHC1_DATA2 0x1d4 + MX8MN_IOMUXC_SD1_DATA3_USDHC1_DATA3 0x1d4 + >; + }; + + pinctrl_usdhc1_200mhz: usdhc1grp200mhz { + fsl,pins = < + MX8MN_IOMUXC_SD1_CLK_USDHC1_CLK 0x196 + MX8MN_IOMUXC_SD1_CMD_USDHC1_CMD 0x1d6 + MX8MN_IOMUXC_SD1_DATA0_USDHC1_DATA0 0x1d6 + MX8MN_IOMUXC_SD1_DATA1_USDHC1_DATA1 0x1d6 + MX8MN_IOMUXC_SD1_DATA2_USDHC1_DATA2 0x1d6 + MX8MN_IOMUXC_SD1_DATA3_USDHC1_DATA3 0x1d6 + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + MX8MN_IOMUXC_NAND_WE_B_USDHC3_CLK 0x190 + MX8MN_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d0 + MX8MN_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d0 + MX8MN_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d0 + MX8MN_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d0 + MX8MN_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d0 + MX8MN_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d0 + MX8MN_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d0 + MX8MN_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d0 + MX8MN_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d0 + MX8MN_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x190 + >; + }; + + pinctrl_usdhc3_100mhz: usdhc3grp100mhz { + fsl,pins = < + MX8MN_IOMUXC_NAND_WE_B_USDHC3_CLK 0x194 + MX8MN_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d4 + MX8MN_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d4 + MX8MN_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d4 + MX8MN_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d4 + MX8MN_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d4 + MX8MN_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d4 + MX8MN_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d4 + MX8MN_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d4 + MX8MN_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d4 + MX8MN_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x194 + >; + }; + + pinctrl_usdhc3_200mhz: usdhc3grp200mhz { + fsl,pins = < + MX8MN_IOMUXC_NAND_WE_B_USDHC3_CLK 0x196 + MX8MN_IOMUXC_NAND_WP_B_USDHC3_CMD 0x1d6 + MX8MN_IOMUXC_NAND_DATA04_USDHC3_DATA0 0x1d6 + MX8MN_IOMUXC_NAND_DATA05_USDHC3_DATA1 0x1d6 + MX8MN_IOMUXC_NAND_DATA06_USDHC3_DATA2 0x1d6 + MX8MN_IOMUXC_NAND_DATA07_USDHC3_DATA3 0x1d6 + MX8MN_IOMUXC_NAND_RE_B_USDHC3_DATA4 0x1d6 + MX8MN_IOMUXC_NAND_CE2_B_USDHC3_DATA5 0x1d6 + MX8MN_IOMUXC_NAND_CE3_B_USDHC3_DATA6 0x1d6 + MX8MN_IOMUXC_NAND_CLE_USDHC3_DATA7 0x1d6 + MX8MN_IOMUXC_NAND_CE1_B_USDHC3_STROBE 0x196 + >; + }; + + pinctrl_wdog: wdoggrp { + fsl,pins = < + MX8MN_IOMUXC_GPIO1_IO02_WDOG1_WDOG_B 0xc6 + >; + }; + + pinctrl_wlan: wlangrp { + fsl,pins = < + MX8MN_IOMUXC_SD1_DATA7_GPIO2_IO9 0x111 + >; + }; +}; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index 7771fc88af..c3daa80ad8 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -67,11 +67,17 @@ config TARGET_VERDIN_IMX8MM select IMX8M_LPDDR4
config TARGET_IMX8MM_BEACON - bool "imx8mm Beacon Embedded devkit" + bool "imx8m Mini Beacon Embedded devkit" select IMX8MM select SUPPORT_SPL select IMX8M_LPDDR4
+config TARGET_IMX8MN_BEACON + bool "imx8m Nano Beacon Embedded devkit" + select IMX8MN + select SUPPORT_SPL + select IMX8M_LPDDR4 + endchoice
source "board/freescale/imx8mq_evk/Kconfig" @@ -82,5 +88,6 @@ source "board/google/imx8mq_phanbell/Kconfig" source "board/technexion/pico-imx8mq/Kconfig" source "board/toradex/verdin-imx8mm/Kconfig" source "board/beacon/imx8mm/Kconfig" +source "board/beacon/imx8mn/Kconfig"
endif diff --git a/board/beacon/imx8mn/Kconfig b/board/beacon/imx8mn/Kconfig new file mode 100644 index 0000000000..3857d1c118 --- /dev/null +++ b/board/beacon/imx8mn/Kconfig @@ -0,0 +1,14 @@ +if TARGET_IMX8MN_BEACON + +config SYS_BOARD + default "imx8mn" + +config SYS_VENDOR + default "beacon" + +config SYS_CONFIG_NAME + default "imx8mn_beacon" + +source "board/freescale/common/Kconfig" + +endif diff --git a/board/beacon/imx8mn/MAINTAINERS b/board/beacon/imx8mn/MAINTAINERS new file mode 100644 index 0000000000..e97ca48e2d --- /dev/null +++ b/board/beacon/imx8mn/MAINTAINERS @@ -0,0 +1,6 @@ +i.MX8MN Beacon Kit +M: Adam Fordaford173@gmail.com +S: Maintained +F: board/beacon/imx8mn/ +F: include/configs/imx8mn_beacon.h +F: configs/imx8mn_beacon_defconfig diff --git a/board/beacon/imx8mn/Makefile b/board/beacon/imx8mn/Makefile new file mode 100644 index 0000000000..00d540607e --- /dev/null +++ b/board/beacon/imx8mn/Makefile @@ -0,0 +1,12 @@ +# +# Copyright 2020 Compass Electronics Group, LLC +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += imx8mn_beacon.o + +ifdef CONFIG_SPL_BUILD +obj-y += spl.o +obj-y += lpddr4_timing.o +endif diff --git a/board/beacon/imx8mn/README b/board/beacon/imx8mn/README new file mode 100644 index 0000000000..52b50c9642 --- /dev/null +++ b/board/beacon/imx8mn/README @@ -0,0 +1,38 @@ +U-Boot for the Beacon EmbeddedWorks i.MX8M Nano Devkit + +Quick Start +=========== +- Build the ARM Trusted firmware binary +- Get lpddr firmware +- Build U-Boot +- Boot + +Get and Build the ARM Trusted firmware +====================================== +Note: $(srctree) is U-Boot source directory + +$ git clone https://source.codeaurora.org/external/imx/imx-atf +$ git checkout imx_5.4.24_2.1.0 +$ make PLAT=imx8mn bl31 ARCH=aarch64 CROSS_COMPILE=aarch64-linux-gnu- +$ cp build/imx8mm/release/bl31.bin $(srctree) + +Get the DDR firmware +==================== +$ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.5.bin +$ chmod +x firmware-imx-8.5.bin +$ ./firmware-imx-8.5 +$ cp firmware-imx-8.5/firmware/ddr/synopsys/lpddr4*.bin $(srctree) + +Build U-Boot +============ +$ make imx8mn_beacon_defconfig +$ make flash.bin CROSS_COMPILE=aarch64-linux-gnu- ATF_LOAD_ADDR=0x960000 + +Burn U-Boot to microSD Card +=========================== +$ sudo dd if=flash.bin of=/dev/sd[x] bs=1024 seek=32 + +Boot +==== +Set Boot switch to SD boot +S17 (1:8) 1100xxxx diff --git a/board/beacon/imx8mn/imx8mn_beacon.c b/board/beacon/imx8mn/imx8mn_beacon.c new file mode 100644 index 0000000000..5ed16fca86 --- /dev/null +++ b/board/beacon/imx8mn/imx8mn_beacon.c @@ -0,0 +1,25 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2020 Compass Electronics Group, LLC + */ + +#include <common.h> +#include <env.h> +#include <init.h> + +DECLARE_GLOBAL_DATA_PTR; + +int board_init(void) +{ + return 0; +} + +int board_mmc_get_env_dev(int devno) +{ + return devno; +} + +int board_late_init(void) +{ + return 0; +} diff --git a/board/beacon/imx8mn/lpddr4_timing.c b/board/beacon/imx8mn/lpddr4_timing.c new file mode 100644 index 0000000000..544447c498 --- /dev/null +++ b/board/beacon/imx8mn/lpddr4_timing.c @@ -0,0 +1,1431 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <linux/kernel.h> +#include <asm/arch/ddr.h> + +struct dram_cfg_param ddr_ddrc_cfg[] = { + /** Initialize DDRC registers **/ + { 0x3d400304, 0x1 }, + { 0x3d400030, 0x1 }, + { 0x3d400000, 0xa1080020 }, + { 0x3d400020, 0x202 }, + { 0x3d400024, 0x3e800 }, + { 0x3d400064, 0x3000e0 }, + { 0x3d4000d0, 0xc003061c }, + { 0x3d4000d4, 0x9e0000 }, + { 0x3d4000dc, 0xd4002d }, + { 0x3d4000e0, 0x310000 }, + { 0x3d4000e8, 0x66004d }, + { 0x3d4000ec, 0x16004d }, + { 0x3d400100, 0x1a200d22 }, + { 0x3d400104, 0x60633 }, + { 0x3d40010c, 0xc0c000 }, + { 0x3d400110, 0xf04080f }, + { 0x3d400114, 0x2040c0c }, + { 0x3d400118, 0x1010007 }, + { 0x3d40011c, 0x401 }, + { 0x3d400130, 0x20600 }, + { 0x3d400134, 0xc100002 }, + { 0x3d400138, 0xe6 }, + { 0x3d400144, 0xa00050 }, + { 0x3d400180, 0x3200018 }, + { 0x3d400184, 0x28061a8 }, + { 0x3d400188, 0x0 }, + { 0x3d400190, 0x497820a }, + { 0x3d400194, 0x80303 }, + { 0x3d4001b4, 0x170a }, + { 0x3d4001a0, 0xe0400018 }, + { 0x3d4001a4, 0xdf00e4 }, + { 0x3d4001a8, 0x80000000 }, + { 0x3d4001b0, 0x11 }, + { 0x3d4001c0, 0x1 }, + { 0x3d4001c4, 0x1 }, + { 0x3d4000f4, 0xc99 }, + { 0x3d400108, 0x70e1617 }, + { 0x3d400200, 0x1f }, + { 0x3d40020c, 0x0 }, + { 0x3d400210, 0x1f1f }, + { 0x3d400204, 0x80808 }, + { 0x3d400214, 0x7070707 }, + { 0x3d400218, 0x7070707 }, + { 0x3d400250, 0x29001701 }, + { 0x3d400254, 0x2c }, + { 0x3d40025c, 0x4000030 }, + { 0x3d400264, 0x900093e7 }, + { 0x3d40026c, 0x2005574 }, + { 0x3d400400, 0x111 }, + { 0x3d400408, 0x72ff }, + { 0x3d400494, 0x2100e07 }, + { 0x3d400498, 0x620096 }, + { 0x3d40049c, 0x1100e07 }, + { 0x3d4004a0, 0xc8012c }, + { 0x3d402020, 0x0 }, + { 0x3d402024, 0x7d00 }, + { 0x3d402050, 0x20d040 }, + { 0x3d402064, 0x6001c }, + { 0x3d4020dc, 0x840000 }, + { 0x3d4020e0, 0x310000 }, + { 0x3d4020e8, 0x66004d }, + { 0x3d4020ec, 0x16004d }, + { 0x3d402100, 0xa040105 }, + { 0x3d402104, 0x30407 }, + { 0x3d402108, 0x203060b }, + { 0x3d40210c, 0x505000 }, + { 0x3d402110, 0x2040202 }, + { 0x3d402114, 0x2030202 }, + { 0x3d402118, 0x1010004 }, + { 0x3d40211c, 0x301 }, + { 0x3d402130, 0x20300 }, + { 0x3d402134, 0xa100002 }, + { 0x3d402138, 0x1d }, + { 0x3d402144, 0x14000a }, + { 0x3d402180, 0x640004 }, + { 0x3d402190, 0x3818200 }, + { 0x3d402194, 0x80303 }, + { 0x3d4021b4, 0x100 }, + { 0x3d4020f4, 0xc99 }, + { 0x3d403020, 0x0 }, + { 0x3d403024, 0x1f40 }, + { 0x3d403050, 0x20d040 }, + { 0x3d403064, 0x30007 }, + { 0x3d4030dc, 0x840000 }, + { 0x3d4030e0, 0x310000 }, + { 0x3d4030e8, 0x66004d }, + { 0x3d4030ec, 0x16004d }, + { 0x3d403100, 0xa010102 }, + { 0x3d403104, 0x30404 }, + { 0x3d403108, 0x203060b }, + { 0x3d40310c, 0x505000 }, + { 0x3d403110, 0x2040202 }, + { 0x3d403114, 0x2030202 }, + { 0x3d403118, 0x1010004 }, + { 0x3d40311c, 0x301 }, + { 0x3d403130, 0x20300 }, + { 0x3d403134, 0xa100002 }, + { 0x3d403138, 0x8 }, + { 0x3d403144, 0x50003 }, + { 0x3d403180, 0x190004 }, + { 0x3d403190, 0x3818200 }, + { 0x3d403194, 0x80303 }, + { 0x3d4031b4, 0x100 }, + { 0x3d4030f4, 0xc99 }, + { 0x3d400028, 0x0 }, +}; + +/* PHY Initialize Configuration */ +struct dram_cfg_param ddr_ddrphy_cfg[] = { + { 0x100a0, 0x0 }, + { 0x100a1, 0x1 }, + { 0x100a2, 0x3 }, + { 0x100a3, 0x2 }, + { 0x100a4, 0x4 }, + { 0x100a5, 0x5 }, + { 0x100a6, 0x7 }, + { 0x100a7, 0x6 }, + { 0x110a0, 0x0 }, + { 0x110a1, 0x1 }, + { 0x110a2, 0x2 }, + { 0x110a3, 0x3 }, + { 0x110a4, 0x5 }, + { 0x110a5, 0x4 }, + { 0x110a6, 0x6 }, + { 0x110a7, 0x7 }, + { 0x1005f, 0x1ff }, + { 0x1015f, 0x1ff }, + { 0x1105f, 0x1ff }, + { 0x1115f, 0x1ff }, + { 0x11005f, 0x1ff }, + { 0x11015f, 0x1ff }, + { 0x11105f, 0x1ff }, + { 0x11115f, 0x1ff }, + { 0x21005f, 0x1ff }, + { 0x21015f, 0x1ff }, + { 0x21105f, 0x1ff }, + { 0x21115f, 0x1ff }, + { 0x55, 0x1ff }, + { 0x1055, 0x1ff }, + { 0x2055, 0x1ff }, + { 0x3055, 0x1ff }, + { 0x4055, 0x1ff }, + { 0x5055, 0x1ff }, + { 0x6055, 0x1ff }, + { 0x7055, 0x1ff }, + { 0x8055, 0x1ff }, + { 0x9055, 0x1ff }, + { 0x200c5, 0x19 }, + { 0x1200c5, 0x7 }, + { 0x2200c5, 0x7 }, + { 0x2002e, 0x2 }, + { 0x12002e, 0x2 }, + { 0x22002e, 0x2 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x20024, 0x1a3 }, + { 0x2003a, 0x2 }, + { 0x120024, 0x1a3 }, + { 0x2003a, 0x2 }, + { 0x220024, 0x1a3 }, + { 0x2003a, 0x2 }, + { 0x20056, 0x3 }, + { 0x120056, 0x3 }, + { 0x220056, 0x3 }, + { 0x1004d, 0xe00 }, + { 0x1014d, 0xe00 }, + { 0x1104d, 0xe00 }, + { 0x1114d, 0xe00 }, + { 0x11004d, 0xe00 }, + { 0x11014d, 0xe00 }, + { 0x11104d, 0xe00 }, + { 0x11114d, 0xe00 }, + { 0x21004d, 0xe00 }, + { 0x21014d, 0xe00 }, + { 0x21104d, 0xe00 }, + { 0x21114d, 0xe00 }, + { 0x10049, 0xeba }, + { 0x10149, 0xeba }, + { 0x11049, 0xeba }, + { 0x11149, 0xeba }, + { 0x110049, 0xeba }, + { 0x110149, 0xeba }, + { 0x111049, 0xeba }, + { 0x111149, 0xeba }, + { 0x210049, 0xeba }, + { 0x210149, 0xeba }, + { 0x211049, 0xeba }, + { 0x211149, 0xeba }, + { 0x43, 0x63 }, + { 0x1043, 0x63 }, + { 0x2043, 0x63 }, + { 0x3043, 0x63 }, + { 0x4043, 0x63 }, + { 0x5043, 0x63 }, + { 0x6043, 0x63 }, + { 0x7043, 0x63 }, + { 0x8043, 0x63 }, + { 0x9043, 0x63 }, + { 0x20018, 0x1 }, + { 0x20075, 0x4 }, + { 0x20050, 0x0 }, + { 0x20008, 0x320 }, + { 0x120008, 0x64 }, + { 0x220008, 0x19 }, + { 0x20088, 0x9 }, + { 0x200b2, 0xdc }, + { 0x10043, 0x5a1 }, + { 0x10143, 0x5a1 }, + { 0x11043, 0x5a1 }, + { 0x11143, 0x5a1 }, + { 0x1200b2, 0xdc }, + { 0x110043, 0x5a1 }, + { 0x110143, 0x5a1 }, + { 0x111043, 0x5a1 }, + { 0x111143, 0x5a1 }, + { 0x2200b2, 0xdc }, + { 0x210043, 0x5a1 }, + { 0x210143, 0x5a1 }, + { 0x211043, 0x5a1 }, + { 0x211143, 0x5a1 }, + { 0x200fa, 0x1 }, + { 0x1200fa, 0x1 }, + { 0x2200fa, 0x1 }, + { 0x20019, 0x1 }, + { 0x120019, 0x1 }, + { 0x220019, 0x1 }, + { 0x200f0, 0x660 }, + { 0x200f1, 0x0 }, + { 0x200f2, 0x4444 }, + { 0x200f3, 0x8888 }, + { 0x200f4, 0x5665 }, + { 0x200f5, 0x0 }, + { 0x200f6, 0x0 }, + { 0x200f7, 0xf000 }, + { 0x20025, 0x0 }, + { 0x2002d, 0x0 }, + { 0x12002d, 0x0 }, + { 0x22002d, 0x0 }, + { 0x2005b, 0x7529 }, + { 0x2005c, 0x0 }, + { 0x200c7, 0x21 }, + { 0x200ca, 0x24 }, + { 0x200cc, 0x1f7 }, + { 0x1200c7, 0x21 }, + { 0x1200ca, 0x24 }, + { 0x1200cc, 0x1f7 }, + { 0x2200c7, 0x21 }, + { 0x2200ca, 0x24 }, + { 0x2200cc, 0x1f7 }, + { 0x2007d, 0x212 }, + { 0x12007d, 0x212 }, + { 0x22007d, 0x212 }, + { 0x2007c, 0x61 }, + { 0x12007c, 0x61 }, + { 0x22007c, 0x61 }, + { 0x1004a, 0x500 }, + { 0x1104a, 0x500 }, + { 0x2002c, 0x0 }, +}; + +/* ddr phy trained csr */ +struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + {0x0200b2, 0x0}, + {0x1200b2, 0x0}, + {0x2200b2, 0x0}, + {0x0200cb, 0x0}, + {0x010043, 0x0}, + {0x110043, 0x0}, + {0x210043, 0x0}, + {0x010143, 0x0}, + {0x110143, 0x0}, + {0x210143, 0x0}, + {0x011043, 0x0}, + {0x111043, 0x0}, + {0x211043, 0x0}, + {0x011143, 0x0}, + {0x111143, 0x0}, + {0x211143, 0x0}, + {0x000080, 0x0}, + {0x100080, 0x0}, + {0x200080, 0x0}, + {0x001080, 0x0}, + {0x101080, 0x0}, + {0x201080, 0x0}, + {0x002080, 0x0}, + {0x102080, 0x0}, + {0x202080, 0x0}, + {0x003080, 0x0}, + {0x103080, 0x0}, + {0x203080, 0x0}, + {0x004080, 0x0}, + {0x104080, 0x0}, + {0x204080, 0x0}, + {0x005080, 0x0}, + {0x105080, 0x0}, + {0x205080, 0x0}, + {0x006080, 0x0}, + {0x106080, 0x0}, + {0x206080, 0x0}, + {0x007080, 0x0}, + {0x107080, 0x0}, + {0x207080, 0x0}, + {0x008080, 0x0}, + {0x108080, 0x0}, + {0x208080, 0x0}, + {0x009080, 0x0}, + {0x109080, 0x0}, + {0x209080, 0x0}, + {0x010080, 0x0}, + {0x110080, 0x0}, + {0x210080, 0x0}, + {0x010180, 0x0}, + {0x110180, 0x0}, + {0x210180, 0x0}, + {0x011080, 0x0}, + {0x111080, 0x0}, + {0x211080, 0x0}, + {0x011180, 0x0}, + {0x111180, 0x0}, + {0x211180, 0x0}, + {0x010081, 0x0}, + {0x110081, 0x0}, + {0x210081, 0x0}, + {0x010181, 0x0}, + {0x110181, 0x0}, + {0x210181, 0x0}, + {0x011081, 0x0}, + {0x111081, 0x0}, + {0x211081, 0x0}, + {0x011181, 0x0}, + {0x111181, 0x0}, + {0x211181, 0x0}, + {0x0100d0, 0x0}, + {0x1100d0, 0x0}, + {0x2100d0, 0x0}, + {0x0101d0, 0x0}, + {0x1101d0, 0x0}, + {0x2101d0, 0x0}, + {0x0110d0, 0x0}, + {0x1110d0, 0x0}, + {0x2110d0, 0x0}, + {0x0111d0, 0x0}, + {0x1111d0, 0x0}, + {0x2111d0, 0x0}, + {0x0100d1, 0x0}, + {0x1100d1, 0x0}, + {0x2100d1, 0x0}, + {0x0101d1, 0x0}, + {0x1101d1, 0x0}, + {0x2101d1, 0x0}, + {0x0110d1, 0x0}, + {0x1110d1, 0x0}, + {0x2110d1, 0x0}, + {0x0111d1, 0x0}, + {0x1111d1, 0x0}, + {0x2111d1, 0x0}, + {0x010068, 0x0}, + {0x010168, 0x0}, + {0x010268, 0x0}, + {0x010368, 0x0}, + {0x010468, 0x0}, + {0x010568, 0x0}, + {0x010668, 0x0}, + {0x010768, 0x0}, + {0x010868, 0x0}, + {0x011068, 0x0}, + {0x011168, 0x0}, + {0x011268, 0x0}, + {0x011368, 0x0}, + {0x011468, 0x0}, + {0x011568, 0x0}, + {0x011668, 0x0}, + {0x011768, 0x0}, + {0x011868, 0x0}, + {0x010069, 0x0}, + {0x010169, 0x0}, + {0x010269, 0x0}, + {0x010369, 0x0}, + {0x010469, 0x0}, + {0x010569, 0x0}, + {0x010669, 0x0}, + {0x010769, 0x0}, + {0x010869, 0x0}, + {0x011069, 0x0}, + {0x011169, 0x0}, + {0x011269, 0x0}, + {0x011369, 0x0}, + {0x011469, 0x0}, + {0x011569, 0x0}, + {0x011669, 0x0}, + {0x011769, 0x0}, + {0x011869, 0x0}, + {0x01008c, 0x0}, + {0x11008c, 0x0}, + {0x21008c, 0x0}, + {0x01018c, 0x0}, + {0x11018c, 0x0}, + {0x21018c, 0x0}, + {0x01108c, 0x0}, + {0x11108c, 0x0}, + {0x21108c, 0x0}, + {0x01118c, 0x0}, + {0x11118c, 0x0}, + {0x21118c, 0x0}, + {0x01008d, 0x0}, + {0x11008d, 0x0}, + {0x21008d, 0x0}, + {0x01018d, 0x0}, + {0x11018d, 0x0}, + {0x21018d, 0x0}, + {0x01108d, 0x0}, + {0x11108d, 0x0}, + {0x21108d, 0x0}, + {0x01118d, 0x0}, + {0x11118d, 0x0}, + {0x21118d, 0x0}, + {0x0100c0, 0x0}, + {0x1100c0, 0x0}, + {0x2100c0, 0x0}, + {0x0101c0, 0x0}, + {0x1101c0, 0x0}, + {0x2101c0, 0x0}, + {0x0102c0, 0x0}, + {0x1102c0, 0x0}, + {0x2102c0, 0x0}, + {0x0103c0, 0x0}, + {0x1103c0, 0x0}, + {0x2103c0, 0x0}, + {0x0104c0, 0x0}, + {0x1104c0, 0x0}, + {0x2104c0, 0x0}, + {0x0105c0, 0x0}, + {0x1105c0, 0x0}, + {0x2105c0, 0x0}, + {0x0106c0, 0x0}, + {0x1106c0, 0x0}, + {0x2106c0, 0x0}, + {0x0107c0, 0x0}, + {0x1107c0, 0x0}, + {0x2107c0, 0x0}, + {0x0108c0, 0x0}, + {0x1108c0, 0x0}, + {0x2108c0, 0x0}, + {0x0110c0, 0x0}, + {0x1110c0, 0x0}, + {0x2110c0, 0x0}, + {0x0111c0, 0x0}, + {0x1111c0, 0x0}, + {0x2111c0, 0x0}, + {0x0112c0, 0x0}, + {0x1112c0, 0x0}, + {0x2112c0, 0x0}, + {0x0113c0, 0x0}, + {0x1113c0, 0x0}, + {0x2113c0, 0x0}, + {0x0114c0, 0x0}, + {0x1114c0, 0x0}, + {0x2114c0, 0x0}, + {0x0115c0, 0x0}, + {0x1115c0, 0x0}, + {0x2115c0, 0x0}, + {0x0116c0, 0x0}, + {0x1116c0, 0x0}, + {0x2116c0, 0x0}, + {0x0117c0, 0x0}, + {0x1117c0, 0x0}, + {0x2117c0, 0x0}, + {0x0118c0, 0x0}, + {0x1118c0, 0x0}, + {0x2118c0, 0x0}, + {0x0100c1, 0x0}, + {0x1100c1, 0x0}, + {0x2100c1, 0x0}, + {0x0101c1, 0x0}, + {0x1101c1, 0x0}, + {0x2101c1, 0x0}, + {0x0102c1, 0x0}, + {0x1102c1, 0x0}, + {0x2102c1, 0x0}, + {0x0103c1, 0x0}, + {0x1103c1, 0x0}, + {0x2103c1, 0x0}, + {0x0104c1, 0x0}, + {0x1104c1, 0x0}, + {0x2104c1, 0x0}, + {0x0105c1, 0x0}, + {0x1105c1, 0x0}, + {0x2105c1, 0x0}, + {0x0106c1, 0x0}, + {0x1106c1, 0x0}, + {0x2106c1, 0x0}, + {0x0107c1, 0x0}, + {0x1107c1, 0x0}, + {0x2107c1, 0x0}, + {0x0108c1, 0x0}, + {0x1108c1, 0x0}, + {0x2108c1, 0x0}, + {0x0110c1, 0x0}, + {0x1110c1, 0x0}, + {0x2110c1, 0x0}, + {0x0111c1, 0x0}, + {0x1111c1, 0x0}, + {0x2111c1, 0x0}, + {0x0112c1, 0x0}, + {0x1112c1, 0x0}, + {0x2112c1, 0x0}, + {0x0113c1, 0x0}, + {0x1113c1, 0x0}, + {0x2113c1, 0x0}, + {0x0114c1, 0x0}, + {0x1114c1, 0x0}, + {0x2114c1, 0x0}, + {0x0115c1, 0x0}, + {0x1115c1, 0x0}, + {0x2115c1, 0x0}, + {0x0116c1, 0x0}, + {0x1116c1, 0x0}, + {0x2116c1, 0x0}, + {0x0117c1, 0x0}, + {0x1117c1, 0x0}, + {0x2117c1, 0x0}, + {0x0118c1, 0x0}, + {0x1118c1, 0x0}, + {0x2118c1, 0x0}, + {0x010020, 0x0}, + {0x110020, 0x0}, + {0x210020, 0x0}, + {0x011020, 0x0}, + {0x111020, 0x0}, + {0x211020, 0x0}, + {0x020072, 0x0}, + {0x020073, 0x0}, + {0x020074, 0x0}, + {0x0100aa, 0x0}, + {0x0110aa, 0x0}, + {0x020010, 0x0}, + {0x120010, 0x0}, + {0x220010, 0x0}, + {0x020011, 0x0}, + {0x120011, 0x0}, + {0x220011, 0x0}, + {0x0100ae, 0x0}, + {0x1100ae, 0x0}, + {0x2100ae, 0x0}, + {0x0100af, 0x0}, + {0x1100af, 0x0}, + {0x2100af, 0x0}, + {0x0110ae, 0x0}, + {0x1110ae, 0x0}, + {0x2110ae, 0x0}, + {0x0110af, 0x0}, + {0x1110af, 0x0}, + {0x2110af, 0x0}, + {0x020020, 0x0}, + {0x120020, 0x0}, + {0x220020, 0x0}, + {0x0100a0, 0x0}, + {0x0100a1, 0x0}, + {0x0100a2, 0x0}, + {0x0100a3, 0x0}, + {0x0100a4, 0x0}, + {0x0100a5, 0x0}, + {0x0100a6, 0x0}, + {0x0100a7, 0x0}, + {0x0110a0, 0x0}, + {0x0110a1, 0x0}, + {0x0110a2, 0x0}, + {0x0110a3, 0x0}, + {0x0110a4, 0x0}, + {0x0110a5, 0x0}, + {0x0110a6, 0x0}, + {0x0110a7, 0x0}, + {0x02007c, 0x0}, + {0x12007c, 0x0}, + {0x22007c, 0x0}, + {0x02007d, 0x0}, + {0x12007d, 0x0}, + {0x22007d, 0x0}, + {0x0400fd, 0x0}, + {0x0400c0, 0x0}, + {0x090201, 0x0}, + {0x190201, 0x0}, + {0x290201, 0x0}, + {0x090202, 0x0}, + {0x190202, 0x0}, + {0x290202, 0x0}, + {0x090203, 0x0}, + {0x190203, 0x0}, + {0x290203, 0x0}, + {0x090204, 0x0}, + {0x190204, 0x0}, + {0x290204, 0x0}, + {0x090205, 0x0}, + {0x190205, 0x0}, + {0x290205, 0x0}, + {0x090206, 0x0}, + {0x190206, 0x0}, + {0x290206, 0x0}, + {0x090207, 0x0}, + {0x190207, 0x0}, + {0x290207, 0x0}, + {0x090208, 0x0}, + {0x190208, 0x0}, + {0x290208, 0x0}, + {0x010062, 0x0}, + {0x010162, 0x0}, + {0x010262, 0x0}, + {0x010362, 0x0}, + {0x010462, 0x0}, + {0x010562, 0x0}, + {0x010662, 0x0}, + {0x010762, 0x0}, + {0x010862, 0x0}, + {0x011062, 0x0}, + {0x011162, 0x0}, + {0x011262, 0x0}, + {0x011362, 0x0}, + {0x011462, 0x0}, + {0x011562, 0x0}, + {0x011662, 0x0}, + {0x011762, 0x0}, + {0x011862, 0x0}, + {0x020077, 0x0}, + {0x010001, 0x0}, + {0x011001, 0x0}, + {0x010040, 0x0}, + {0x010140, 0x0}, + {0x010240, 0x0}, + {0x010340, 0x0}, + {0x010440, 0x0}, + {0x010540, 0x0}, + {0x010640, 0x0}, + {0x010740, 0x0}, + {0x010840, 0x0}, + {0x010030, 0x0}, + {0x010130, 0x0}, + {0x010230, 0x0}, + {0x010330, 0x0}, + {0x010430, 0x0}, + {0x010530, 0x0}, + {0x010630, 0x0}, + {0x010730, 0x0}, + {0x010830, 0x0}, + {0x011040, 0x0}, + {0x011140, 0x0}, + {0x011240, 0x0}, + {0x011340, 0x0}, + {0x011440, 0x0}, + {0x011540, 0x0}, + {0x011640, 0x0}, + {0x011740, 0x0}, + {0x011840, 0x0}, + {0x011030, 0x0}, + {0x011130, 0x0}, + {0x011230, 0x0}, + {0x011330, 0x0}, + {0x011430, 0x0}, + {0x011530, 0x0}, + {0x011630, 0x0}, + {0x011730, 0x0}, + {0x011830, 0x0}, +}; + +/* P0 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp0_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xc80 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x131f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400f, 0x100 }, + { 0x54012, 0x110 }, + { 0x54019, 0x2dd4 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4d66 }, + { 0x5401c, 0x4d00 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x2dd4 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4d66 }, + { 0x54022, 0x4d00 }, + { 0x54024, 0x16 }, + { 0x54032, 0xd400 }, + { 0x54033, 0x312d }, + { 0x54034, 0x6600 }, + { 0x54035, 0x4d }, + { 0x54036, 0x4d }, + { 0x54037, 0x1600 }, + { 0x54038, 0xd400 }, + { 0x54039, 0x312d }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x4d }, + { 0x5403c, 0x4d }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P1 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp1_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x101 }, + { 0x54003, 0x190 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400f, 0x100 }, + { 0x54012, 0x110 }, + { 0x54019, 0x84 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4d66 }, + { 0x5401c, 0x4d00 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x84 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4d66 }, + { 0x54022, 0x4d00 }, + { 0x54024, 0x16 }, + { 0x54032, 0x8400 }, + { 0x54033, 0x3100 }, + { 0x54034, 0x6600 }, + { 0x54035, 0x4d }, + { 0x54036, 0x4d }, + { 0x54037, 0x1600 }, + { 0x54038, 0x8400 }, + { 0x54039, 0x3100 }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x4d }, + { 0x5403c, 0x4d }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P2 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp2_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x102 }, + { 0x54003, 0x64 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400f, 0x100 }, + { 0x54012, 0x110 }, + { 0x54019, 0x84 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4d66 }, + { 0x5401c, 0x4d00 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x84 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4d66 }, + { 0x54022, 0x4d00 }, + { 0x54024, 0x16 }, + { 0x54032, 0x8400 }, + { 0x54033, 0x3100 }, + { 0x54034, 0x6600 }, + { 0x54035, 0x4d }, + { 0x54036, 0x4d }, + { 0x54037, 0x1600 }, + { 0x54038, 0x8400 }, + { 0x54039, 0x3100 }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x4d }, + { 0x5403c, 0x4d }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P0 2D message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp0_2d_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xc80 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x61 }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400d, 0x100 }, + { 0x5400f, 0x100 }, + { 0x54010, 0x1f7f }, + { 0x54012, 0x110 }, + { 0x54019, 0x2dd4 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4d66 }, + { 0x5401c, 0x4d00 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x2dd4 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4d66 }, + { 0x54022, 0x4d00 }, + { 0x54024, 0x16 }, + { 0x54032, 0xd400 }, + { 0x54033, 0x312d }, + { 0x54034, 0x6600 }, + { 0x54035, 0x4d }, + { 0x54036, 0x4d }, + { 0x54037, 0x1600 }, + { 0x54038, 0xd400 }, + { 0x54039, 0x312d }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x4d }, + { 0x5403c, 0x4d }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* DRAM PHY init engine image */ +struct dram_cfg_param ddr_phy_pie[] = { + { 0xd0000, 0x0 }, + { 0x90000, 0x10 }, + { 0x90001, 0x400 }, + { 0x90002, 0x10e }, + { 0x90003, 0x0 }, + { 0x90004, 0x0 }, + { 0x90005, 0x8 }, + { 0x90029, 0xb }, + { 0x9002a, 0x480 }, + { 0x9002b, 0x109 }, + { 0x9002c, 0x8 }, + { 0x9002d, 0x448 }, + { 0x9002e, 0x139 }, + { 0x9002f, 0x8 }, + { 0x90030, 0x478 }, + { 0x90031, 0x109 }, + { 0x90032, 0x0 }, + { 0x90033, 0xe8 }, + { 0x90034, 0x109 }, + { 0x90035, 0x2 }, + { 0x90036, 0x10 }, + { 0x90037, 0x139 }, + { 0x90038, 0xb }, + { 0x90039, 0x7c0 }, + { 0x9003a, 0x139 }, + { 0x9003b, 0x44 }, + { 0x9003c, 0x633 }, + { 0x9003d, 0x159 }, + { 0x9003e, 0x14f }, + { 0x9003f, 0x630 }, + { 0x90040, 0x159 }, + { 0x90041, 0x47 }, + { 0x90042, 0x633 }, + { 0x90043, 0x149 }, + { 0x90044, 0x4f }, + { 0x90045, 0x633 }, + { 0x90046, 0x179 }, + { 0x90047, 0x8 }, + { 0x90048, 0xe0 }, + { 0x90049, 0x109 }, + { 0x9004a, 0x0 }, + { 0x9004b, 0x7c8 }, + { 0x9004c, 0x109 }, + { 0x9004d, 0x0 }, + { 0x9004e, 0x1 }, + { 0x9004f, 0x8 }, + { 0x90050, 0x0 }, + { 0x90051, 0x45a }, + { 0x90052, 0x9 }, + { 0x90053, 0x0 }, + { 0x90054, 0x448 }, + { 0x90055, 0x109 }, + { 0x90056, 0x40 }, + { 0x90057, 0x633 }, + { 0x90058, 0x179 }, + { 0x90059, 0x1 }, + { 0x9005a, 0x618 }, + { 0x9005b, 0x109 }, + { 0x9005c, 0x40c0 }, + { 0x9005d, 0x633 }, + { 0x9005e, 0x149 }, + { 0x9005f, 0x8 }, + { 0x90060, 0x4 }, + { 0x90061, 0x48 }, + { 0x90062, 0x4040 }, + { 0x90063, 0x633 }, + { 0x90064, 0x149 }, + { 0x90065, 0x0 }, + { 0x90066, 0x4 }, + { 0x90067, 0x48 }, + { 0x90068, 0x40 }, + { 0x90069, 0x633 }, + { 0x9006a, 0x149 }, + { 0x9006b, 0x10 }, + { 0x9006c, 0x4 }, + { 0x9006d, 0x18 }, + { 0x9006e, 0x0 }, + { 0x9006f, 0x4 }, + { 0x90070, 0x78 }, + { 0x90071, 0x549 }, + { 0x90072, 0x633 }, + { 0x90073, 0x159 }, + { 0x90074, 0xd49 }, + { 0x90075, 0x633 }, + { 0x90076, 0x159 }, + { 0x90077, 0x94a }, + { 0x90078, 0x633 }, + { 0x90079, 0x159 }, + { 0x9007a, 0x441 }, + { 0x9007b, 0x633 }, + { 0x9007c, 0x149 }, + { 0x9007d, 0x42 }, + { 0x9007e, 0x633 }, + { 0x9007f, 0x149 }, + { 0x90080, 0x1 }, + { 0x90081, 0x633 }, + { 0x90082, 0x149 }, + { 0x90083, 0x0 }, + { 0x90084, 0xe0 }, + { 0x90085, 0x109 }, + { 0x90086, 0xa }, + { 0x90087, 0x10 }, + { 0x90088, 0x109 }, + { 0x90089, 0x9 }, + { 0x9008a, 0x3c0 }, + { 0x9008b, 0x149 }, + { 0x9008c, 0x9 }, + { 0x9008d, 0x3c0 }, + { 0x9008e, 0x159 }, + { 0x9008f, 0x18 }, + { 0x90090, 0x10 }, + { 0x90091, 0x109 }, + { 0x90092, 0x0 }, + { 0x90093, 0x3c0 }, + { 0x90094, 0x109 }, + { 0x90095, 0x18 }, + { 0x90096, 0x4 }, + { 0x90097, 0x48 }, + { 0x90098, 0x18 }, + { 0x90099, 0x4 }, + { 0x9009a, 0x58 }, + { 0x9009b, 0xb }, + { 0x9009c, 0x10 }, + { 0x9009d, 0x109 }, + { 0x9009e, 0x1 }, + { 0x9009f, 0x10 }, + { 0x900a0, 0x109 }, + { 0x900a1, 0x5 }, + { 0x900a2, 0x7c0 }, + { 0x900a3, 0x109 }, + { 0x40000, 0x811 }, + { 0x40020, 0x880 }, + { 0x40040, 0x0 }, + { 0x40060, 0x0 }, + { 0x40001, 0x4008 }, + { 0x40021, 0x83 }, + { 0x40041, 0x4f }, + { 0x40061, 0x0 }, + { 0x40002, 0x4040 }, + { 0x40022, 0x83 }, + { 0x40042, 0x51 }, + { 0x40062, 0x0 }, + { 0x40003, 0x811 }, + { 0x40023, 0x880 }, + { 0x40043, 0x0 }, + { 0x40063, 0x0 }, + { 0x40004, 0x720 }, + { 0x40024, 0xf }, + { 0x40044, 0x1740 }, + { 0x40064, 0x0 }, + { 0x40005, 0x16 }, + { 0x40025, 0x83 }, + { 0x40045, 0x4b }, + { 0x40065, 0x0 }, + { 0x40006, 0x716 }, + { 0x40026, 0xf }, + { 0x40046, 0x2001 }, + { 0x40066, 0x0 }, + { 0x40007, 0x716 }, + { 0x40027, 0xf }, + { 0x40047, 0x2800 }, + { 0x40067, 0x0 }, + { 0x40008, 0x716 }, + { 0x40028, 0xf }, + { 0x40048, 0xf00 }, + { 0x40068, 0x0 }, + { 0x40009, 0x720 }, + { 0x40029, 0xf }, + { 0x40049, 0x1400 }, + { 0x40069, 0x0 }, + { 0x4000a, 0xe08 }, + { 0x4002a, 0xc15 }, + { 0x4004a, 0x0 }, + { 0x4006a, 0x0 }, + { 0x4000b, 0x625 }, + { 0x4002b, 0x15 }, + { 0x4004b, 0x0 }, + { 0x4006b, 0x0 }, + { 0x4000c, 0x4028 }, + { 0x4002c, 0x80 }, + { 0x4004c, 0x0 }, + { 0x4006c, 0x0 }, + { 0x4000d, 0xe08 }, + { 0x4002d, 0xc1a }, + { 0x4004d, 0x0 }, + { 0x4006d, 0x0 }, + { 0x4000e, 0x625 }, + { 0x4002e, 0x1a }, + { 0x4004e, 0x0 }, + { 0x4006e, 0x0 }, + { 0x4000f, 0x4040 }, + { 0x4002f, 0x80 }, + { 0x4004f, 0x0 }, + { 0x4006f, 0x0 }, + { 0x40010, 0x2604 }, + { 0x40030, 0x15 }, + { 0x40050, 0x0 }, + { 0x40070, 0x0 }, + { 0x40011, 0x708 }, + { 0x40031, 0x5 }, + { 0x40051, 0x0 }, + { 0x40071, 0x2002 }, + { 0x40012, 0x8 }, + { 0x40032, 0x80 }, + { 0x40052, 0x0 }, + { 0x40072, 0x0 }, + { 0x40013, 0x2604 }, + { 0x40033, 0x1a }, + { 0x40053, 0x0 }, + { 0x40073, 0x0 }, + { 0x40014, 0x708 }, + { 0x40034, 0xa }, + { 0x40054, 0x0 }, + { 0x40074, 0x2002 }, + { 0x40015, 0x4040 }, + { 0x40035, 0x80 }, + { 0x40055, 0x0 }, + { 0x40075, 0x0 }, + { 0x40016, 0x60a }, + { 0x40036, 0x15 }, + { 0x40056, 0x1200 }, + { 0x40076, 0x0 }, + { 0x40017, 0x61a }, + { 0x40037, 0x15 }, + { 0x40057, 0x1300 }, + { 0x40077, 0x0 }, + { 0x40018, 0x60a }, + { 0x40038, 0x1a }, + { 0x40058, 0x1200 }, + { 0x40078, 0x0 }, + { 0x40019, 0x642 }, + { 0x40039, 0x1a }, + { 0x40059, 0x1300 }, + { 0x40079, 0x0 }, + { 0x4001a, 0x4808 }, + { 0x4003a, 0x880 }, + { 0x4005a, 0x0 }, + { 0x4007a, 0x0 }, + { 0x900a4, 0x0 }, + { 0x900a5, 0x790 }, + { 0x900a6, 0x11a }, + { 0x900a7, 0x8 }, + { 0x900a8, 0x7aa }, + { 0x900a9, 0x2a }, + { 0x900aa, 0x10 }, + { 0x900ab, 0x7b2 }, + { 0x900ac, 0x2a }, + { 0x900ad, 0x0 }, + { 0x900ae, 0x7c8 }, + { 0x900af, 0x109 }, + { 0x900b0, 0x10 }, + { 0x900b1, 0x10 }, + { 0x900b2, 0x109 }, + { 0x900b3, 0x10 }, + { 0x900b4, 0x2a8 }, + { 0x900b5, 0x129 }, + { 0x900b6, 0x8 }, + { 0x900b7, 0x370 }, + { 0x900b8, 0x129 }, + { 0x900b9, 0xa }, + { 0x900ba, 0x3c8 }, + { 0x900bb, 0x1a9 }, + { 0x900bc, 0xc }, + { 0x900bd, 0x408 }, + { 0x900be, 0x199 }, + { 0x900bf, 0x14 }, + { 0x900c0, 0x790 }, + { 0x900c1, 0x11a }, + { 0x900c2, 0x8 }, + { 0x900c3, 0x4 }, + { 0x900c4, 0x18 }, + { 0x900c5, 0xe }, + { 0x900c6, 0x408 }, + { 0x900c7, 0x199 }, + { 0x900c8, 0x8 }, + { 0x900c9, 0x8568 }, + { 0x900ca, 0x108 }, + { 0x900cb, 0x18 }, + { 0x900cc, 0x790 }, + { 0x900cd, 0x16a }, + { 0x900ce, 0x8 }, + { 0x900cf, 0x1d8 }, + { 0x900d0, 0x169 }, + { 0x900d1, 0x10 }, + { 0x900d2, 0x8558 }, + { 0x900d3, 0x168 }, + { 0x900d4, 0x70 }, + { 0x900d5, 0x788 }, + { 0x900d6, 0x16a }, + { 0x900d7, 0x1ff8 }, + { 0x900d8, 0x85a8 }, + { 0x900d9, 0x1e8 }, + { 0x900da, 0x50 }, + { 0x900db, 0x798 }, + { 0x900dc, 0x16a }, + { 0x900dd, 0x60 }, + { 0x900de, 0x7a0 }, + { 0x900df, 0x16a }, + { 0x900e0, 0x8 }, + { 0x900e1, 0x8310 }, + { 0x900e2, 0x168 }, + { 0x900e3, 0x8 }, + { 0x900e4, 0xa310 }, + { 0x900e5, 0x168 }, + { 0x900e6, 0xa }, + { 0x900e7, 0x408 }, + { 0x900e8, 0x169 }, + { 0x900e9, 0x6e }, + { 0x900ea, 0x0 }, + { 0x900eb, 0x68 }, + { 0x900ec, 0x0 }, + { 0x900ed, 0x408 }, + { 0x900ee, 0x169 }, + { 0x900ef, 0x0 }, + { 0x900f0, 0x8310 }, + { 0x900f1, 0x168 }, + { 0x900f2, 0x0 }, + { 0x900f3, 0xa310 }, + { 0x900f4, 0x168 }, + { 0x900f5, 0x1ff8 }, + { 0x900f6, 0x85a8 }, + { 0x900f7, 0x1e8 }, + { 0x900f8, 0x68 }, + { 0x900f9, 0x798 }, + { 0x900fa, 0x16a }, + { 0x900fb, 0x78 }, + { 0x900fc, 0x7a0 }, + { 0x900fd, 0x16a }, + { 0x900fe, 0x68 }, + { 0x900ff, 0x790 }, + { 0x90100, 0x16a }, + { 0x90101, 0x8 }, + { 0x90102, 0x8b10 }, + { 0x90103, 0x168 }, + { 0x90104, 0x8 }, + { 0x90105, 0xab10 }, + { 0x90106, 0x168 }, + { 0x90107, 0xa }, + { 0x90108, 0x408 }, + { 0x90109, 0x169 }, + { 0x9010a, 0x58 }, + { 0x9010b, 0x0 }, + { 0x9010c, 0x68 }, + { 0x9010d, 0x0 }, + { 0x9010e, 0x408 }, + { 0x9010f, 0x169 }, + { 0x90110, 0x0 }, + { 0x90111, 0x8b10 }, + { 0x90112, 0x168 }, + { 0x90113, 0x0 }, + { 0x90114, 0xab10 }, + { 0x90115, 0x168 }, + { 0x90116, 0x0 }, + { 0x90117, 0x1d8 }, + { 0x90118, 0x169 }, + { 0x90119, 0x80 }, + { 0x9011a, 0x790 }, + { 0x9011b, 0x16a }, + { 0x9011c, 0x18 }, + { 0x9011d, 0x7aa }, + { 0x9011e, 0x6a }, + { 0x9011f, 0xa }, + { 0x90120, 0x0 }, + { 0x90121, 0x1e9 }, + { 0x90122, 0x8 }, + { 0x90123, 0x8080 }, + { 0x90124, 0x108 }, + { 0x90125, 0xf }, + { 0x90126, 0x408 }, + { 0x90127, 0x169 }, + { 0x90128, 0xc }, + { 0x90129, 0x0 }, + { 0x9012a, 0x68 }, + { 0x9012b, 0x9 }, + { 0x9012c, 0x0 }, + { 0x9012d, 0x1a9 }, + { 0x9012e, 0x0 }, + { 0x9012f, 0x408 }, + { 0x90130, 0x169 }, + { 0x90131, 0x0 }, + { 0x90132, 0x8080 }, + { 0x90133, 0x108 }, + { 0x90134, 0x8 }, + { 0x90135, 0x7aa }, + { 0x90136, 0x6a }, + { 0x90137, 0x0 }, + { 0x90138, 0x8568 }, + { 0x90139, 0x108 }, + { 0x9013a, 0xb7 }, + { 0x9013b, 0x790 }, + { 0x9013c, 0x16a }, + { 0x9013d, 0x1f }, + { 0x9013e, 0x0 }, + { 0x9013f, 0x68 }, + { 0x90140, 0x8 }, + { 0x90141, 0x8558 }, + { 0x90142, 0x168 }, + { 0x90143, 0xf }, + { 0x90144, 0x408 }, + { 0x90145, 0x169 }, + { 0x90146, 0xd }, + { 0x90147, 0x0 }, + { 0x90148, 0x68 }, + { 0x90149, 0x0 }, + { 0x9014a, 0x408 }, + { 0x9014b, 0x169 }, + { 0x9014c, 0x0 }, + { 0x9014d, 0x8558 }, + { 0x9014e, 0x168 }, + { 0x9014f, 0x8 }, + { 0x90150, 0x3c8 }, + { 0x90151, 0x1a9 }, + { 0x90152, 0x3 }, + { 0x90153, 0x370 }, + { 0x90154, 0x129 }, + { 0x90155, 0x20 }, + { 0x90156, 0x2aa }, + { 0x90157, 0x9 }, + { 0x90158, 0x0 }, + { 0x90159, 0x400 }, + { 0x9015a, 0x10e }, + { 0x9015b, 0x8 }, + { 0x9015c, 0xe8 }, + { 0x9015d, 0x109 }, + { 0x9015e, 0x0 }, + { 0x9015f, 0x8140 }, + { 0x90160, 0x10c }, + { 0x90161, 0x10 }, + { 0x90162, 0x8138 }, + { 0x90163, 0x10c }, + { 0x90164, 0x8 }, + { 0x90165, 0x7c8 }, + { 0x90166, 0x101 }, + { 0x90167, 0x8 }, + { 0x90168, 0x448 }, + { 0x90169, 0x109 }, + { 0x9016a, 0xf }, + { 0x9016b, 0x7c0 }, + { 0x9016c, 0x109 }, + { 0x9016d, 0x0 }, + { 0x9016e, 0xe8 }, + { 0x9016f, 0x109 }, + { 0x90170, 0x47 }, + { 0x90171, 0x630 }, + { 0x90172, 0x109 }, + { 0x90173, 0x8 }, + { 0x90174, 0x618 }, + { 0x90175, 0x109 }, + { 0x90176, 0x8 }, + { 0x90177, 0xe0 }, + { 0x90178, 0x109 }, + { 0x90179, 0x0 }, + { 0x9017a, 0x7c8 }, + { 0x9017b, 0x109 }, + { 0x9017c, 0x8 }, + { 0x9017d, 0x8140 }, + { 0x9017e, 0x10c }, + { 0x9017f, 0x0 }, + { 0x90180, 0x1 }, + { 0x90181, 0x8 }, + { 0x90182, 0x8 }, + { 0x90183, 0x4 }, + { 0x90184, 0x8 }, + { 0x90185, 0x8 }, + { 0x90186, 0x7c8 }, + { 0x90187, 0x101 }, + { 0x90006, 0x0 }, + { 0x90007, 0x0 }, + { 0x90008, 0x8 }, + { 0x90009, 0x0 }, + { 0x9000a, 0x0 }, + { 0x9000b, 0x0 }, + { 0xd00e7, 0x400 }, + { 0x90017, 0x0 }, + { 0x9001f, 0x29 }, + { 0x90026, 0x6a }, + { 0x400d0, 0x0 }, + { 0x400d1, 0x101 }, + { 0x400d2, 0x105 }, + { 0x400d3, 0x107 }, + { 0x400d4, 0x10f }, + { 0x400d5, 0x202 }, + { 0x400d6, 0x20a }, + { 0x400d7, 0x20b }, + { 0x2003a, 0x2 }, + { 0x2000b, 0x64 }, + { 0x2000c, 0xc8 }, + { 0x2000d, 0x7d0 }, + { 0x2000e, 0x2c }, + { 0x12000b, 0xc }, + { 0x12000c, 0x19 }, + { 0x12000d, 0xfa }, + { 0x12000e, 0x10 }, + { 0x22000b, 0x3 }, + { 0x22000c, 0x6 }, + { 0x22000d, 0x3e }, + { 0x22000e, 0x10 }, + { 0x9000c, 0x0 }, + { 0x9000d, 0x173 }, + { 0x9000e, 0x60 }, + { 0x9000f, 0x6110 }, + { 0x90010, 0x2152 }, + { 0x90011, 0xdfbd }, + { 0x90012, 0x2060 }, + { 0x90013, 0x6152 }, + { 0x20010, 0x5a }, + { 0x20011, 0x3 }, + { 0x40080, 0xe0 }, + { 0x40081, 0x12 }, + { 0x40082, 0xe0 }, + { 0x40083, 0x12 }, + { 0x40084, 0xe0 }, + { 0x40085, 0x12 }, + { 0x140080, 0xe0 }, + { 0x140081, 0x12 }, + { 0x140082, 0xe0 }, + { 0x140083, 0x12 }, + { 0x140084, 0xe0 }, + { 0x140085, 0x12 }, + { 0x240080, 0xe0 }, + { 0x240081, 0x12 }, + { 0x240082, 0xe0 }, + { 0x240083, 0x12 }, + { 0x240084, 0xe0 }, + { 0x240085, 0x12 }, + { 0x400fd, 0xf }, + { 0x10011, 0x1 }, + { 0x10012, 0x1 }, + { 0x10013, 0x180 }, + { 0x10018, 0x1 }, + { 0x10002, 0x6209 }, + { 0x100b2, 0x1 }, + { 0x101b4, 0x1 }, + { 0x102b4, 0x1 }, + { 0x103b4, 0x1 }, + { 0x104b4, 0x1 }, + { 0x105b4, 0x1 }, + { 0x106b4, 0x1 }, + { 0x107b4, 0x1 }, + { 0x108b4, 0x1 }, + { 0x11011, 0x1 }, + { 0x11012, 0x1 }, + { 0x11013, 0x180 }, + { 0x11018, 0x1 }, + { 0x11002, 0x6209 }, + { 0x110b2, 0x1 }, + { 0x111b4, 0x1 }, + { 0x112b4, 0x1 }, + { 0x113b4, 0x1 }, + { 0x114b4, 0x1 }, + { 0x115b4, 0x1 }, + { 0x116b4, 0x1 }, + { 0x117b4, 0x1 }, + { 0x118b4, 0x1 }, + { 0x20089, 0x1 }, + { 0x20088, 0x19 }, + { 0xc0080, 0x2 }, + { 0xd0000, 0x1 } +}; + +struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 3200mts 1D */ + .drate = 3200, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P1 400mts 1D */ + .drate = 400, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg), + }, + { + /* P2 100mts 1D */ + .drate = 100, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp2_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp2_cfg), + }, + { + /* P0 3200mts 2D */ + .drate = 3200, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = ddr_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info dram_timing = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 3200, 400, 100, }, +}; + diff --git a/board/beacon/imx8mn/spl.c b/board/beacon/imx8mn/spl.c new file mode 100644 index 0000000000..bc907bfa30 --- /dev/null +++ b/board/beacon/imx8mn/spl.c @@ -0,0 +1,116 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <common.h> +#include <command.h> +#include <cpu_func.h> +#include <hang.h> +#include <image.h> +#include <init.h> +#include <log.h> +#include <spl.h> +#include <asm/io.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm/arch/clock.h> +#include <asm/arch/imx8mn_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/mach-imx/boot_mode.h> +#include <asm/arch/ddr.h> + +#include <dm/uclass.h> +#include <dm/device.h> +#include <dm/uclass-internal.h> +#include <dm/device-internal.h> + +DECLARE_GLOBAL_DATA_PTR; + +int spl_board_boot_device(enum boot_device boot_dev_spl) +{ + return BOOT_DEVICE_BOOTROM; +} + +void spl_dram_init(void) +{ + ddr_init(&dram_timing); +} + +void spl_board_init(void) +{ + struct udevice *dev; + int ret; + + puts("Normal Boot\n"); + + ret = uclass_get_device_by_name(UCLASS_CLK, + "clock-controller@30380000", + &dev); + if (ret < 0) + printf("Failed to find clock node. Check device tree\n"); +} + +#if CONFIG_IS_ENABLED(LOAD_FIT) +int board_fit_config_name_match(const char *name) +{ + /* Just empty function now - can't decide what to choose */ + debug("%s: %s\n", __func__, name); + + return 0; +} +#endif + +#define UART_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_FSEL1) +#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) + +static iomux_v3_cfg_t const uart_pads[] = { + IMX8MN_PAD_UART2_RXD__UART2_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + IMX8MN_PAD_UART2_TXD__UART2_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static iomux_v3_cfg_t const wdog_pads[] = { + IMX8MN_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), +}; + +int board_early_init_f(void) +{ + struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; + + imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); + + set_wdog_reset(wdog); + + imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads)); + + init_uart_clk(1); + + return 0; +} + +void board_init_f(ulong dummy) +{ + int ret; + + arch_cpu_init(); + + init_uart_clk(1); + + board_early_init_f(); + + timer_init(); + + preloader_console_init(); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + ret = spl_init(); + if (ret) { + debug("spl_init() failed: %d\n", ret); + hang(); + } + + enable_tzc380(); + + /* DDR initialization */ + spl_dram_init(); + + board_init_r(NULL, 0); +} diff --git a/configs/imx8mn_beacon_defconfig b/configs/imx8mn_beacon_defconfig new file mode 100644 index 0000000000..a6d67bbf8d --- /dev/null +++ b/configs/imx8mn_beacon_defconfig @@ -0,0 +1,105 @@ +CONFIG_ARM=y +CONFIG_ARCH_IMX8M=y +CONFIG_SYS_TEXT_BASE=0x40200000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x10000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x400000 +CONFIG_SYS_I2C_MXC_I2C1=y +CONFIG_SYS_I2C_MXC_I2C2=y +CONFIG_SYS_I2C_MXC_I2C3=y +CONFIG_DM_GPIO=y +CONFIG_SPL_TEXT_BASE=0x912000 +CONFIG_TARGET_IMX8MN_BEACON=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_SPL=y +CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x48000000 +CONFIG_DEFAULT_DEVICE_TREE="imx8mn-beacon-kit" +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/imx8m/imximage-8mn-lpddr4.cfg" +CONFIG_DEFAULT_FDT_FILE="imx8mn-beacon-kit.dtb" +CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_BOOTROM_SUPPORT=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_POWER_SUPPORT=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="u-boot=> " +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_CRC32 is not set +CONFIG_CMD_CLK=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM=y +CONFIG_SPL_CLK_COMPOSITE_CCF=y +CONFIG_CLK_COMPOSITE_CCF=y +CONFIG_SPL_CLK_IMX8MN=y +CONFIG_CLK_IMX8MN=y +CONFIG_MXC_GPIO=y +CONFIG_DM_PCA953X=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MXC=y +CONFIG_DM_MMC=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_FSL_USDHC=y +CONFIG_PHYLIB=y +CONFIG_PHY_ATHEROS=y +CONFIG_DM_ETH=y +CONFIG_PHY_GIGE=y +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_DM_PMIC=y +# CONFIG_SPL_PMIC_CHILDREN is not set +CONFIG_DM_PMIC_BD71837=y +CONFIG_DM_REGULATOR=y +CONFIG_SPL_DM_REGULATOR=y +CONFIG_DM_REGULATOR_BD71837=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_CONS_INDEX=2 +CONFIG_DM_SERIAL=y +# CONFIG_SPL_DM_SERIAL is not set +CONFIG_MXC_UART=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_SPI_MEM=y +CONFIG_NXP_FSPI=y +CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y +CONFIG_SYSRESET_PSCI=y +CONFIG_SYSRESET_WATCHDOG=y +CONFIG_DM_THERMAL=y +CONFIG_IMX_WATCHDOG=y diff --git a/include/configs/imx8mm_beacon.h b/include/configs/imx8mm_beacon.h index ce3ba74924..c09ff92b9e 100644 --- a/include/configs/imx8mm_beacon.h +++ b/include/configs/imx8mm_beacon.h @@ -61,7 +61,7 @@ "booti ${loadaddr} - ${fdt_addr}; " \ "else " \ "echo WARN: Cannot load the DT; " \ - "fi; " \ + "fi;\0" \ "netargs=setenv bootargs console=${console} " \ "root=/dev/nfs " \ "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ diff --git a/include/configs/imx8mn_beacon.h b/include/configs/imx8mn_beacon.h new file mode 100644 index 0000000000..d0ec25350e --- /dev/null +++ b/include/configs/imx8mn_beacon.h @@ -0,0 +1,145 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2018 NXP + */ + +#ifndef __IMX8MN_EVK_H +#define __IMX8MN_EVK_H + +#include <linux/sizes.h> +#include <linux/stringify.h> +#include <asm/arch/imx-regs.h> + +#ifdef CONFIG_SECURE_BOOT +#define CONFIG_CSF_SIZE SZ_8K +#endif + +#define CONFIG_SPL_MAX_SIZE (148 * 1024) +#define CONFIG_SYS_MONITOR_LEN SZ_512K +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 +#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 +#define CONFIG_SYS_UBOOT_BASE \ + (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) + +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SPL_STACK 0x95fff0 +#define CONFIG_SPL_BSS_START_ADDR 0x00950000 +#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K /* 8 KB */ +#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 +#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K /* 512 KB */ +#define CONFIG_SYS_ICACHE_OFF +#define CONFIG_SYS_DCACHE_OFF + +/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ +#define CONFIG_MALLOC_F_ADDR 0x00940000 + +/* For RAW image gives a error info not panic */ +#define CONFIG_SPL_ABORT_ON_RAW_IMAGE + +#endif + +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "script=boot.scr\0" \ + "image=Image\0" \ + "console=ttymxc1,115200\0" \ + "fdt_addr=0x43000000\0" \ + "fdt_high=0xffffffffffffffff\0" \ + "boot_fit=try\0" \ + "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "initrd_addr=0x43800000\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "mmcdev=1\0" \ + "mmcpart=1\0" \ + "finduuid=part uuid mmc ${mmcdev}:2 uuid\0" \ + "mmcautodetect=yes\0" \ + "mmcargs=setenv bootargs console=${console},${baudrate}" \ + " root=PARTUUID=${uuid} rootwait rw ${mtdparts} ${optargs}\0" \ + "loadbootscript=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run finduuid; " \ + "run mmcargs; " \ + "if run loadfdt; then " \ + "booti ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi;\0" \ + "netargs=setenv bootargs console=${console} " \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ + "netboot=echo Booting from net ...; " \ + "run netargs; " \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${loadaddr} ${image}; " \ + "if test ${boot_fit} = yes || test ${boot_fit} = try; then " \ + "bootm ${loadaddr}; " \ + "else " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "booti ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi;\0" + +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loadimage; then " \ + "run mmcboot; " \ + "else run netboot; " \ + "fi; " \ + "fi; " \ + "fi;" + +/* Link Definitions */ +#define CONFIG_LOADADDR 0x40480000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x200000 +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +#define CONFIG_ENV_OVERWRITE +#define CONFIG_SYS_MMC_ENV_DEV 0 /* USDHC2 */ +#define CONFIG_MMCROOT "/dev/mmcblk1p2" /* USDHC2 */ + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN SZ_32M + +#define CONFIG_SYS_SDRAM_BASE 0x40000000 +#define PHYS_SDRAM 0x40000000 +#define PHYS_SDRAM_SIZE 0x80000000 /* 2GB DDR */ + +#define CONFIG_MXC_UART_BASE UART2_BASE_ADDR + +/* Monitor Command Prompt */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_CBSIZE 2048 +#define CONFIG_SYS_MAXARGS 64 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) + +/* USDHC */ +#define CONFIG_SYS_FSL_USDHC_NUM 2 +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 + +/* I2C */ +#define CONFIG_SYS_I2C_SPEED 100000 + +#endif
Adam Ford
