[U-Boot-Users] [PATCH 3/4] ARM DaVinci: Move common functions to board/davinci/common
ARM DaVinci: Move common functions to board/davinci/common.
Signed-off-by: Hugo Villeneuve hugo.villeneuve@lyrtech.com
board/davinci/common/Makefile | 53 ++++++++++++ board/davinci/common/misc.c | 126 ++++++++++++++++++++++++++++ board/davinci/common/misc.h | 32 +++++++ board/davinci/common/psc.c | 117 ++++++++++++++++++++++++++ board/davinci/common/psc.h | 28 +++++++ board/davinci/dv-evm/dv_board.c | 129 ++++-------------------------- board/davinci/schmoogie/dv_board.c | 103 ++--------------------- board/davinci/sffsdr/sffsdr.c | 158 ++++-------------------------------- board/davinci/sonata/dv_board.c | 122 +++------------------------- 9 files changed, 404 insertions(+), 464 deletions(-)
diff --git a/board/davinci/common/Makefile b/board/davinci/common/Makefile new file mode 100644 index 0000000..127bb6e --- /dev/null +++ b/board/davinci/common/Makefile @@ -0,0 +1,53 @@ +# +# (C) Copyright 2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +ifneq ($(OBJTREE),$(SRCTREE)) +$(shell mkdir -p $(obj)board/$(VENDOR)/common) +endif + +LIB = $(obj)lib$(VENDOR).a + +COBJS := psc.o misc.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### +# This is for $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/davinci/common/misc.c b/board/davinci/common/misc.c new file mode 100644 index 0000000..71a3b87 --- /dev/null +++ b/board/davinci/common/misc.c @@ -0,0 +1,126 @@ +/* + * Miscelaneous DaVinci functions. + * + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * Copyright (C) 2008 Lyrtech <www.lyrtech.com> + * Copyright (C) 2004 Texas Instruments. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <common.h> +#include <i2c.h> +#include <asm/arch/hardware.h> + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + return(0); +} + +static int dv_get_pllm_output(uint32_t pllm) +{ + return (pllm + 1) * (CFG_HZ_CLOCK / 1000000); +} + +void dv_display_clk_infos(void) +{ + printf("ARM Clock: %dMHz\n", dv_get_pllm_output(REG(PLL1_PLLM)) / 2); + printf("DDR Clock: %dMHz\n", dv_get_pllm_output(REG(PLL2_PLLM)) / + ((REG(PLL2_DIV2) & 0x1f) + 1) / 2); +} + +/* Read ethernet MAC address from EEPROM for DVEVM compatible boards. + * Returns 1 if found, 0 otherwise. + */ +int dvevm_read_mac_address(uint8_t *buf) +{ +#ifdef CFG_I2C_EEPROM_ADDR + /* Read MAC address. */ + if (i2c_read(CFG_I2C_EEPROM_ADDR, 0x7F00, CFG_I2C_EEPROM_ADDR_LEN, + (uint8_t *) &buf[0], 6)) + goto i2cerr; + + /* Check that MAC address is not null. */ + if (memcmp(buf, "\0\0\0\0\0\0", 6) == 0) + goto err; + + return 1; /* Found */ + +i2cerr: + printf("Read from EEPROM @ 0x%02x failed\n", CFG_I2C_EEPROM_ADDR); +err: +#endif /* CFG_I2C_EEPROM_ADDR */ + + return 0; +} + +/* If there is a MAC address in the environment, and if it is not identical to + * the MAC address in the ROM, then a warning is printed and the MAC address + * from the environment is used. + * + * If there is no MAC address in the environment, then it will be initialized + * (silently) from the value in the ROM. + */ +void dv_configure_mac_address(uint8_t *rom_enetaddr) +{ + int i; + u_int8_t env_enetaddr[6]; + char *tmp = getenv("ethaddr"); + char *end; + + /* Read Ethernet MAC address from the U-Boot environment. + * If it is not defined, env_enetaddr[] will be cleared. */ + for (i = 0; i < 6; i++) { + env_enetaddr[i] = tmp ? simple_strtoul(tmp, &end, 16) : 0; + if (tmp) + tmp = (*end) ? end+1 : end; + } + + /* Check if ROM and U-Boot environment MAC addresses match. */ + if (memcmp(env_enetaddr, "\0\0\0\0\0\0", 6) != 0 && + memcmp(env_enetaddr, rom_enetaddr, 6) != 0) { + printf("Warning: MAC addresses don't match:\n"); + printf(" ROM MAC address: %02X:%02X:%02X:%02X:%02X:%02X\n", + rom_enetaddr[0], rom_enetaddr[1], + rom_enetaddr[2], rom_enetaddr[3], + rom_enetaddr[4], rom_enetaddr[5]); + printf(" "ethaddr" value: %02X:%02X:%02X:%02X:%02X:%02X\n", + env_enetaddr[0], env_enetaddr[1], + env_enetaddr[2], env_enetaddr[3], + env_enetaddr[4], env_enetaddr[5]) ; + debug("### Using MAC address from environment\n"); + } + if (!tmp) { + char ethaddr[20]; + + /* There is no MAC address in the environment, so we initialize + * it from the value in the ROM. */ + sprintf(ethaddr, "%02X:%02X:%02X:%02X:%02X:%02X", + rom_enetaddr[0], rom_enetaddr[1], + rom_enetaddr[2], rom_enetaddr[3], + rom_enetaddr[4], rom_enetaddr[5]) ; + debug("### Setting environment from ROM MAC address = "%s"\n", + ethaddr); + setenv("ethaddr", ethaddr); + } +} diff --git a/board/davinci/common/misc.h b/board/davinci/common/misc.h new file mode 100644 index 0000000..4a57dbb --- /dev/null +++ b/board/davinci/common/misc.h @@ -0,0 +1,32 @@ +/* + * Copyright (C) 2008 Lyrtech <www.lyrtech.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#ifndef __MISC_H +#define __MISC_H + +extern void timer_init(void); +extern int eth_hw_init(void); + +void dv_display_clk_infos(void); +int dvevm_read_mac_address(uint8_t *buf); +void dv_configure_mac_address(uint8_t *rom_enetaddr); + +#endif /* __MISC_H */ diff --git a/board/davinci/common/psc.c b/board/davinci/common/psc.c new file mode 100644 index 0000000..00dc07c --- /dev/null +++ b/board/davinci/common/psc.c @@ -0,0 +1,117 @@ +/* + * Power and Sleep Controller (PSC) functions. + * + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * Copyright (C) 2008 Lyrtech <www.lyrtech.com> + * Copyright (C) 2004 Texas Instruments. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <common.h> +#include <asm/arch/hardware.h> + +/* + * The DM6446 includes two separate power domains: "Always On" and "DSP". The + * "Always On" power domain is always on when the chip is on. The "Always On" + * domain is powered by the VDD pins of the DM6446. The majority of the + * DM6446's modules lie within the "Always On" power domain. A separate + * domain called the "DSP" domain houses the C64x+ and VICP. The "DSP" domain + * is not always on. The "DSP" power domain is powered by the CVDDDSP pins of + * the DM6446. + */ + +/* Works on Always On power domain only (no PD argument) */ +void lpsc_on(unsigned int id) +{ + dv_reg_p mdstat, mdctl; + + if (id >= DAVINCI_LPSC_GEM) + return; /* Don't work on DSP Power Domain */ + + mdstat = REG_P(PSC_MDSTAT_BASE + (id * 4)); + mdctl = REG_P(PSC_MDCTL_BASE + (id * 4)); + + while (REG(PSC_PTSTAT) & 0x01); + + if ((*mdstat & 0x1f) == 0x03) + return; /* Already on and enabled */ + + *mdctl |= 0x03; + + /* Special treatment for some modules as for sprue14 p.7.4.2 */ + switch (id) { + case DAVINCI_LPSC_VPSSSLV: + case DAVINCI_LPSC_EMAC: + case DAVINCI_LPSC_EMAC_WRAPPER: + case DAVINCI_LPSC_MDIO: + case DAVINCI_LPSC_USB: + case DAVINCI_LPSC_ATA: + case DAVINCI_LPSC_VLYNQ: + case DAVINCI_LPSC_UHPI: + case DAVINCI_LPSC_DDR_EMIF: + case DAVINCI_LPSC_AEMIF: + case DAVINCI_LPSC_MMC_SD: + case DAVINCI_LPSC_MEMSTICK: + case DAVINCI_LPSC_McBSP: + case DAVINCI_LPSC_GPIO: + *mdctl |= 0x200; + break; + } + + REG(PSC_PTCMD) = 0x01; + + while (REG(PSC_PTSTAT) & 0x03); + while ((*mdstat & 0x1f) != 0x03); /* Probably an overkill... */ +} + +/* If DSPLINK is used, we don't want U-Boot to power on the DSP. */ +#if !defined(CFG_USE_DSPLINK) +void dsp_on(void) +{ + int i; + + if (REG(PSC_PDSTAT1) & 0x1f) + return; /* Already on */ + + REG(PSC_GBLCTL) |= 0x01; + REG(PSC_PDCTL1) |= 0x01; + REG(PSC_PDCTL1) &= ~0x100; + REG(PSC_MDCTL_BASE + (DAVINCI_LPSC_GEM * 4)) |= 0x03; + REG(PSC_MDCTL_BASE + (DAVINCI_LPSC_GEM * 4)) &= 0xfffffeff; + REG(PSC_MDCTL_BASE + (DAVINCI_LPSC_IMCOP * 4)) |= 0x03; + REG(PSC_MDCTL_BASE + (DAVINCI_LPSC_IMCOP * 4)) &= 0xfffffeff; + REG(PSC_PTCMD) = 0x02; + + for (i = 0; i < 100; i++) { + if (REG(PSC_EPCPR) & 0x02) + break; + } + + REG(PSC_CHP_SHRTSW) = 0x01; + REG(PSC_PDCTL1) |= 0x100; + REG(PSC_EPCCR) = 0x02; + + for (i = 0; i < 100; i++) { + if (!(REG(PSC_PTSTAT) & 0x02)) + break; + } + + REG(PSC_GBLCTL) &= ~0x1f; +} +#endif /* CFG_USE_DSPLINK */ diff --git a/board/davinci/common/psc.h b/board/davinci/common/psc.h new file mode 100644 index 0000000..6ab2575 --- /dev/null +++ b/board/davinci/common/psc.h @@ -0,0 +1,28 @@ +/* + * Copyright (C) 2008 Lyrtech <www.lyrtech.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#ifndef __PSC_H +#define __PSC_H + +void lpsc_on(unsigned int id); +void dsp_on(void); + +#endif /* __PSC_H */ diff --git a/board/davinci/dv-evm/dv_board.c b/board/davinci/dv-evm/dv_board.c index 834eb68..151f8a9 100644 --- a/board/davinci/dv-evm/dv_board.c +++ b/board/davinci/dv-evm/dv_board.c @@ -28,89 +28,11 @@ #include <i2c.h> #include <asm/arch/hardware.h> #include <asm/arch/emac_defs.h> +#include "../common/psc.h" +#include "../common/misc.h"
-extern void timer_init(void); -extern int eth_hw_init(void); - - -/* Works on Always On power domain only (no PD argument) */ -void lpsc_on(unsigned int id) -{ - dv_reg_p mdstat, mdctl; - - if (id >= DAVINCI_LPSC_GEM) - return; /* Don't work on DSP Power Domain */ - - mdstat = REG_P(PSC_MDSTAT_BASE + (id * 4)); - mdctl = REG_P(PSC_MDCTL_BASE + (id * 4)); - - while (REG(PSC_PTSTAT) & 0x01) {;} - - if ((*mdstat & 0x1f) == 0x03) - return; /* Already on and enabled */ - - *mdctl |= 0x03; - - /* Special treatment for some modules as for sprue14 p.7.4.2 */ - if ( (id == DAVINCI_LPSC_VPSSSLV) || - (id == DAVINCI_LPSC_EMAC) || - (id == DAVINCI_LPSC_EMAC_WRAPPER) || - (id == DAVINCI_LPSC_MDIO) || - (id == DAVINCI_LPSC_USB) || - (id == DAVINCI_LPSC_ATA) || - (id == DAVINCI_LPSC_VLYNQ) || - (id == DAVINCI_LPSC_UHPI) || - (id == DAVINCI_LPSC_DDR_EMIF) || - (id == DAVINCI_LPSC_AEMIF) || - (id == DAVINCI_LPSC_MMC_SD) || - (id == DAVINCI_LPSC_MEMSTICK) || - (id == DAVINCI_LPSC_McBSP) || - (id == DAVINCI_LPSC_GPIO) - ) - *mdctl |= 0x200; - - REG(PSC_PTCMD) = 0x01; - - while (REG(PSC_PTSTAT) & 0x03) {;} - while ((*mdstat & 0x1f) != 0x03) {;} /* Probably an overkill... */ -} - -void dsp_on(void) -{ - int i; - - if (REG(PSC_PDSTAT1) & 0x1f) - return; /* Already on */ - - REG(PSC_GBLCTL) |= 0x01; - REG(PSC_PDCTL1) |= 0x01; - REG(PSC_PDCTL1) &= ~0x100; - REG(PSC_MDCTL_BASE + (DAVINCI_LPSC_GEM * 4)) |= 0x03; - REG(PSC_MDCTL_BASE + (DAVINCI_LPSC_GEM * 4)) &= 0xfffffeff; - REG(PSC_MDCTL_BASE + (DAVINCI_LPSC_IMCOP * 4)) |= 0x03; - REG(PSC_MDCTL_BASE + (DAVINCI_LPSC_IMCOP * 4)) &= 0xfffffeff; - REG(PSC_PTCMD) = 0x02; - - for (i = 0; i < 100; i++) { - if (REG(PSC_EPCPR) & 0x02) - break; - } - - REG(PSC_CHP_SHRTSW) = 0x01; - REG(PSC_PDCTL1) |= 0x100; - REG(PSC_EPCCR) = 0x02; - - for (i = 0; i < 100; i++) { - if (!(REG(PSC_PTSTAT) & 0x02)) - break; - } - - REG(PSC_GBLCTL) &= ~0x1f; -} - - int board_init(void) { /* arch number of the board */ @@ -131,8 +53,10 @@ int board_init(void) lpsc_on(DAVINCI_LPSC_TIMER1); lpsc_on(DAVINCI_LPSC_GPIO);
+#if !defined(CFG_USE_DSPLINK) /* Powerup the DSP */ dsp_on(); +#endif /* CFG_USE_DSPLINK */
/* Bringup UART0 out of reset */ REG(UART0_PWREMU_MGMT) = 0x0000e003; @@ -157,46 +81,23 @@ int board_init(void) return(0); }
-int misc_init_r (void) +int misc_init_r(void) { - u_int8_t tmp[20], buf[10]; - int i = 0; - int clk = 0; - - clk = ((REG(PLL2_PLLM) + 1) * 27) / ((REG(PLL2_DIV2) & 0x1f) + 1); - - printf ("ARM Clock : %dMHz\n", ((REG(PLL1_PLLM) + 1) * 27 ) / 2); - printf ("DDR Clock : %dMHz\n", (clk / 2)); - - /* Set Ethernet MAC address from EEPROM */ - if (i2c_read(CFG_I2C_EEPROM_ADDR, 0x7f00, CFG_I2C_EEPROM_ADDR_LEN, buf, 6)) { - printf("\nEEPROM @ 0x%02x read FAILED!!!\n", CFG_I2C_EEPROM_ADDR); - } else { - tmp[0] = 0xff; - for (i = 0; i < 6; i++) - tmp[0] &= buf[i]; - - if ((tmp[0] != 0xff) && (getenv("ethaddr") == NULL)) { - sprintf((char *)&tmp[0], "%02x:%02x:%02x:%02x:%02x:%02x", - buf[0], buf[1], buf[2], buf[3], buf[4], buf[5]); - setenv("ethaddr", (char *)&tmp[0]); - } - } + uint8_t video_mode; + uint8_t eeprom_enetaddr[6];
- if (!eth_hw_init()) - printf("ethernet init failed!\n"); + dv_display_clk_infos();
- i2c_read (0x39, 0x00, 1, (u_int8_t *)&i, 1); + /* Read Ethernet MAC address from EEPROM if available. */ + if (dvevm_read_mac_address(eeprom_enetaddr)) + dv_configure_mac_address(eeprom_enetaddr);
- setenv ("videostd", ((i & 0x80) ? "pal" : "ntsc")); + if (!eth_hw_init()) + printf("ethernet init failed!\n");
- return(0); -} + i2c_read(0x39, 0x00, 1, &video_mode, 1);
-int dram_init(void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + setenv("videostd", ((video_mode & 0x80) ? "pal" : "ntsc"));
return(0); } diff --git a/board/davinci/schmoogie/dv_board.c b/board/davinci/schmoogie/dv_board.c index 3017546..99fd326 100644 --- a/board/davinci/schmoogie/dv_board.c +++ b/board/davinci/schmoogie/dv_board.c @@ -28,89 +28,11 @@ #include <i2c.h> #include <asm/arch/hardware.h> #include <asm/arch/emac_defs.h> +#include "../common/psc.h" +#include "../common/misc.h"
/* Bringup UART0 out of reset */ REG(UART0_PWREMU_MGMT) = 0x0000e003; @@ -157,11 +81,10 @@ int board_init(void) return(0); }
-int misc_init_r (void) +int misc_init_r(void) { u_int8_t tmp[20], buf[10]; int i = 0; - int clk = 0;
/* Set serial number from UID chip */ u_int8_t crc_tbl[256] = { @@ -199,17 +122,15 @@ int misc_init_r (void) 0xb6, 0xe8, 0x0a, 0x54, 0xd7, 0x89, 0x6b, 0x35 };
- clk = ((REG(PLL2_PLLM) + 1) * 27) / ((REG(PLL2_DIV2) & 0x1f) + 1); - - printf ("ARM Clock : %dMHz\n", ((REG(PLL1_PLLM) + 1) * 27 ) / 2); - printf ("DDR Clock : %dMHz\n", (clk / 2)); + dv_display_clk_infos();
/* Set serial number from UID chip */ if (i2c_read(CFG_UID_ADDR, 0, 1, buf, 8)) { printf("\nUID @ 0x%02x read FAILED!!!\n", CFG_UID_ADDR); forceenv("serial#", "FAILED"); } else { - if (buf[0] != 0x70) { /* Device Family Code */ + if (buf[0] != 0x70) { + /* Device Family Code */ printf("\nUID @ 0x%02x read FAILED!!!\n", CFG_UID_ADDR); forceenv("serial#", "FAILED"); } @@ -234,11 +155,3 @@ int misc_init_r (void)
return(0); } - -int dram_init(void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; - - return(0); -} diff --git a/board/davinci/sffsdr/sffsdr.c b/board/davinci/sffsdr/sffsdr.c index f41081f..f47ba0f 100644 --- a/board/davinci/sffsdr/sffsdr.c +++ b/board/davinci/sffsdr/sffsdr.c @@ -31,6 +31,8 @@ #include <i2c.h> #include <asm/arch/hardware.h> #include <asm/arch/emac_defs.h> +#include "../common/psc.h" +#include "../common/misc.h"
#define DAVINCI_A3CR (0x01E00014) /* EMIF-A CS3 config register. */ #define DAVINCI_A3CR_VAL (0x3FFFFFFD) /* EMIF-A CS3 value for FPGA. */ @@ -41,89 +43,6 @@
-extern void timer_init(void); -extern int eth_hw_init(void); - - -/* Works on Always On power domain only (no PD argument) */ -void lpsc_on(unsigned int id) -{ - dv_reg_p mdstat, mdctl; - - if (id >= DAVINCI_LPSC_GEM) - return; /* Don't work on DSP Power Domain */ - - mdstat = REG_P(PSC_MDSTAT_BASE + (id * 4)); - mdctl = REG_P(PSC_MDCTL_BASE + (id * 4)); - - while (REG(PSC_PTSTAT) & 0x01); - - if ((*mdstat & 0x1f) == 0x03) - return; /* Already on and enabled */ - - *mdctl |= 0x03; - - /* Special treatment for some modules as for sprue14 p.7.4.2 */ - switch (id) { - case DAVINCI_LPSC_VPSSSLV: - case DAVINCI_LPSC_EMAC: - case DAVINCI_LPSC_EMAC_WRAPPER: - case DAVINCI_LPSC_MDIO: - case DAVINCI_LPSC_USB: - case DAVINCI_LPSC_ATA: - case DAVINCI_LPSC_VLYNQ: - case DAVINCI_LPSC_UHPI: - case DAVINCI_LPSC_DDR_EMIF: - case DAVINCI_LPSC_AEMIF: - case DAVINCI_LPSC_MMC_SD: - case DAVINCI_LPSC_MEMSTICK: - case DAVINCI_LPSC_McBSP: - case DAVINCI_LPSC_GPIO: - *mdctl |= 0x200; - break; - } - - REG(PSC_PTCMD) = 0x01; - - while (REG(PSC_PTSTAT) & 0x03); - while ((*mdstat & 0x1f) != 0x03); /* Probably an overkill... */ -} - -#if !defined(CFG_USE_DSPLINK) -void dsp_on(void) -{ - int i; - - if (REG(PSC_PDSTAT1) & 0x1f) - return; /* Already on */ - - REG(PSC_GBLCTL) |= 0x01; - REG(PSC_PDCTL1) |= 0x01; - REG(PSC_PDCTL1) &= ~0x100; - REG(PSC_MDCTL_BASE + (DAVINCI_LPSC_GEM * 4)) |= 0x03; - REG(PSC_MDCTL_BASE + (DAVINCI_LPSC_GEM * 4)) &= 0xfffffeff; - REG(PSC_MDCTL_BASE + (DAVINCI_LPSC_IMCOP * 4)) |= 0x03; - REG(PSC_MDCTL_BASE + (DAVINCI_LPSC_IMCOP * 4)) &= 0xfffffeff; - REG(PSC_PTCMD) = 0x02; - - for (i = 0; i < 100; i++) { - if (REG(PSC_EPCPR) & 0x02) - break; - } - - REG(PSC_CHP_SHRTSW) = 0x01; - REG(PSC_PDCTL1) |= 0x100; - REG(PSC_EPCCR) = 0x02; - - for (i = 0; i < 100; i++) { - if (!(REG(PSC_PTSTAT) & 0x02)) - break; - } - - REG(PSC_GBLCTL) &= ~0x1f; -} -#endif /* CFG_USE_DSPLINK */ - int board_init(void) { /* arch number of the board */ @@ -172,8 +91,10 @@ int board_init(void) return(0); }
-/* Read ethernet MAC address from Integrity data structure inside EEPROM. */ -int read_mac_address(uint8_t *buf) +/* Read ethernet MAC address from Integrity data structure inside EEPROM. + * Returns 1 if found, 0 otherwise. + */ +static int sffsdr_read_mac_address(uint8_t *buf) { u_int32_t value, mac[2], address;
@@ -182,7 +103,7 @@ int read_mac_address(uint8_t *buf) CFG_I2C_EEPROM_ADDR_LEN, (uint8_t *) &value, 4)) goto err; if (value != INTEGRITY_CHECKWORD_VALUE) - return 1; + return 0;
/* Read SYSCFG structure offset. */ if (i2c_read(CFG_I2C_EEPROM_ADDR, INTEGRITY_SYSCFG_OFFSET, @@ -216,30 +137,23 @@ int read_mac_address(uint8_t *buf) buf[4] = mac[1] >> 24; buf[5] = mac[1] >> 16;
- return 0; + return 1; /* Found */
err: printf("Read from EEPROM @ 0x%02x failed\n", CFG_I2C_EEPROM_ADDR); - return 1; + return 0; }
/* Platform dependent initialisation. */ int misc_init_r(void) { - int i; - u_int8_t i2cbuf; - u_int8_t env_enetaddr[6], eeprom_enetaddr[6]; - char *tmp = getenv("ethaddr"); - char *end; - int clk; + uint8_t i2cbuf; + uint8_t eeprom_enetaddr[6];
/* EMIF-A CS3 configuration for FPGA. */ REG(DAVINCI_A3CR) = DAVINCI_A3CR_VAL;
- clk = ((REG(PLL2_PLLM) + 1) * 27) / ((REG(PLL2_DIV2) & 0x1f) + 1); - - printf("ARM Clock: %dMHz\n", ((REG(PLL1_PLLM) + 1) * 27) / 2); - printf("DDR Clock: %dMHz\n", (clk / 2)); + dv_display_clk_infos();
/* Configure I2C switch (PCA9543) to enable channel 0. */ i2cbuf = CFG_I2C_PCA9543_ENABLE_CH0; @@ -249,43 +163,9 @@ int misc_init_r(void) return 1; }
- /* Read Ethernet MAC address from the U-Boot environment. */ - for (i = 0; i < 6; i++) { - env_enetaddr[i] = tmp ? simple_strtoul(tmp, &end, 16) : 0; - if (tmp) - tmp = (*end) ? end+1 : end; - } - - /* Read Ethernet MAC address from EEPROM. */ - if (read_mac_address(eeprom_enetaddr) == 0) { - if (memcmp(env_enetaddr, "\0\0\0\0\0\0", 6) != 0 && - memcmp(env_enetaddr, eeprom_enetaddr, 6) != 0) { - printf("\nWarning: MAC addresses don't match:\n"); - printf("\tHW MAC address: " - "%02X:%02X:%02X:%02X:%02X:%02X\n", - eeprom_enetaddr[0], eeprom_enetaddr[1], - eeprom_enetaddr[2], eeprom_enetaddr[3], - eeprom_enetaddr[4], eeprom_enetaddr[5]); - printf("\t"ethaddr" value: " - "%02X:%02X:%02X:%02X:%02X:%02X\n", - env_enetaddr[0], env_enetaddr[1], - env_enetaddr[2], env_enetaddr[3], - env_enetaddr[4], env_enetaddr[5]) ; - debug("### Set MAC addr from environment\n"); - memcpy(eeprom_enetaddr, env_enetaddr, 6); - } - if (!tmp) { - char ethaddr[20]; - - sprintf(ethaddr, "%02X:%02X:%02X:%02X:%02X:%02X", - eeprom_enetaddr[0], eeprom_enetaddr[1], - eeprom_enetaddr[2], eeprom_enetaddr[3], - eeprom_enetaddr[4], eeprom_enetaddr[5]) ; - debug("### Set environment from HW MAC addr = "%s"\n", - ethaddr); - setenv("ethaddr", ethaddr); - } - } + /* Read Ethernet MAC address from EEPROM if available. */ + if (sffsdr_read_mac_address(eeprom_enetaddr)) + dv_configure_mac_address(eeprom_enetaddr);
if (!eth_hw_init()) printf("Ethernet init failed\n"); @@ -296,11 +176,3 @@ int misc_init_r(void)
return(0); } - -int dram_init(void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; - - return(0); -} diff --git a/board/davinci/sonata/dv_board.c b/board/davinci/sonata/dv_board.c index a6f9bc7..a6fe825 100644 --- a/board/davinci/sonata/dv_board.c +++ b/board/davinci/sonata/dv_board.c @@ -25,92 +25,13 @@ */
#include <common.h> -#include <i2c.h> #include <asm/arch/hardware.h> #include <asm/arch/emac_defs.h> +#include "../common/psc.h" +#include "../common/misc.h"
-extern void timer_init(void); -extern int eth_hw_init(void); - - -/* Works on Always On power domain only (no PD argument) */ -void lpsc_on(unsigned int id) -{ - dv_reg_p mdstat, mdctl; - - if (id >= DAVINCI_LPSC_GEM) - return; /* Don't work on DSP Power Domain */ - - mdstat = REG_P(PSC_MDSTAT_BASE + (id * 4)); - mdctl = REG_P(PSC_MDCTL_BASE + (id * 4)); - - while (REG(PSC_PTSTAT) & 0x01) {;} - - if ((*mdstat & 0x1f) == 0x03) - return; /* Already on and enabled */ - - *mdctl |= 0x03; - - /* Special treatment for some modules as for sprue14 p.7.4.2 */ - if ( (id == DAVINCI_LPSC_VPSSSLV) || - (id == DAVINCI_LPSC_EMAC) || - (id == DAVINCI_LPSC_EMAC_WRAPPER) || - (id == DAVINCI_LPSC_MDIO) || - (id == DAVINCI_LPSC_USB) || - (id == DAVINCI_LPSC_ATA) || - (id == DAVINCI_LPSC_VLYNQ) || - (id == DAVINCI_LPSC_UHPI) || - (id == DAVINCI_LPSC_DDR_EMIF) || - (id == DAVINCI_LPSC_AEMIF) || - (id == DAVINCI_LPSC_MMC_SD) || - (id == DAVINCI_LPSC_MEMSTICK) || - (id == DAVINCI_LPSC_McBSP) || - (id == DAVINCI_LPSC_GPIO) - ) - *mdctl |= 0x200; - - REG(PSC_PTCMD) = 0x01; - - while (REG(PSC_PTSTAT) & 0x03) {;} - while ((*mdstat & 0x1f) != 0x03) {;} /* Probably an overkill... */ -} - -void dsp_on(void) -{ - int i; - - if (REG(PSC_PDSTAT1) & 0x1f) - return; /* Already on */ - - REG(PSC_GBLCTL) |= 0x01; - REG(PSC_PDCTL1) |= 0x01; - REG(PSC_PDCTL1) &= ~0x100; - REG(PSC_MDCTL_BASE + (DAVINCI_LPSC_GEM * 4)) |= 0x03; - REG(PSC_MDCTL_BASE + (DAVINCI_LPSC_GEM * 4)) &= 0xfffffeff; - REG(PSC_MDCTL_BASE + (DAVINCI_LPSC_IMCOP * 4)) |= 0x03; - REG(PSC_MDCTL_BASE + (DAVINCI_LPSC_IMCOP * 4)) &= 0xfffffeff; - REG(PSC_PTCMD) = 0x02; - - for (i = 0; i < 100; i++) { - if (REG(PSC_EPCPR) & 0x02) - break; - } - - REG(PSC_CHP_SHRTSW) = 0x01; - REG(PSC_PDCTL1) |= 0x100; - REG(PSC_EPCCR) = 0x02; - - for (i = 0; i < 100; i++) { - if (!(REG(PSC_PTSTAT) & 0x02)) - break; - } - - REG(PSC_GBLCTL) &= ~0x1f; -} - - int board_init(void) { /* arch number of the board */ @@ -131,8 +52,10 @@ int board_init(void) lpsc_on(DAVINCI_LPSC_TIMER1); lpsc_on(DAVINCI_LPSC_GPIO);
/* Bringup UART0 out of reset */ REG(UART0_PWREMU_MGMT) = 0x0000e003; @@ -157,43 +80,18 @@ int board_init(void) return(0); }
-int misc_init_r (void) +int misc_init_r(void) { - u_int8_t tmp[20], buf[10]; - int i = 0; - int clk = 0; + uint8_t eeprom_enetaddr[6];
- clk = ((REG(PLL2_PLLM) + 1) * 27) / ((REG(PLL2_DIV2) & 0x1f) + 1); - - printf ("ARM Clock : %dMHz\n", ((REG(PLL1_PLLM) + 1) * 27 ) / 2); - printf ("DDR Clock : %dMHz\n", (clk / 2)); - - /* Set Ethernet MAC address from EEPROM */ - if (i2c_read(CFG_I2C_EEPROM_ADDR, 0x7f00, CFG_I2C_EEPROM_ADDR_LEN, buf, 6)) { - printf("\nEEPROM @ 0x%02x read FAILED!!!\n", CFG_I2C_EEPROM_ADDR); - } else { - tmp[0] = 0xff; - for (i = 0; i < 6; i++) - tmp[0] &= buf[i]; - - if ((tmp[0] != 0xff) && (getenv("ethaddr") == NULL)) { - sprintf((char *)&tmp[0], "%02x:%02x:%02x:%02x:%02x:%02x", - buf[0], buf[1], buf[2], buf[3], buf[4], buf[5]); - setenv("ethaddr", (char *)&tmp[0]); - } - } + /* Read Ethernet MAC address from EEPROM if available. */ + if (dvevm_read_mac_address(eeprom_enetaddr)) + dv_configure_mac_address(eeprom_enetaddr);
if (!eth_hw_init()) printf("ethernet init failed!\n");
Hugo Villeneuve
