[PATCH 0/5] riscv: sifive/fu540: Booting from SPI
This series support Boot from SPI on SiFive FU540 HiFive Unleashed board.
SPI uses a separate defconfig and it is possible to reuse existing one, but it requires runtime detection of boot mode via MSEL.
Any help? let me know.
Series depends on [1] and [2].
[1] https://patchwork.ozlabs.org/cover/1263480/ [2] https://patchwork.ozlabs.org/project/uboot/list/?series=169649
Any inputs? Jagan.
Jagan Teki (5): sifive: fu540: Add Booting from SPI env: Enable SPI flash env for SiFive FU540 sifive: fu540: Mark the default env as SPI flash sifive: fu540: Add boot flash script offset, size sifive: fu540: Enable SF distro bootcmd
.../dts/hifive-unleashed-a00-u-boot.dtsi | 12 ++++++ board/sifive/fu540/Kconfig | 1 + board/sifive/fu540/fu540.c | 3 ++ configs/sifive_fu540_spi_defconfig | 26 +++++++++++ doc/board/sifive/fu540.rst | 43 +++++++++++++++++++ env/Kconfig | 3 ++ include/configs/sifive-fu540.h | 7 ++- 7 files changed, 94 insertions(+), 1 deletion(-) create mode 100644 configs/sifive_fu540_spi_defconfig
U-Boot SPL 2020.04-rc4-g0b8ed9b8b6 (Apr 20 2020 - 18:31:50 +0530) Trying to boot from MMC1
U-Boot 2020.04-rc4-g0b8ed9b8b6 (Apr 20 2020 - 18:31:50 +0530)
CPU: rv64imafdc Model: SiFive HiFive Unleashed A00 DRAM: 8 GiB MMC: spi@10050000:mmc@0: 0 Loading Environment from SPI Flash... SF: Detected is25wp256 with page size 256 Bytes, erase size 4 KiB, total 32 MiB *** Warning - bad CRC, using default environment
In: serial@10010000 Out: serial@10010000 Err: serial@10010000 Net: eth0: ethernet@10090000 Hit any key to stop autoboot: 0
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- .../dts/hifive-unleashed-a00-u-boot.dtsi | 12 ++++++ board/sifive/fu540/fu540.c | 3 ++ configs/sifive_fu540_spi_defconfig | 26 +++++++++++ doc/board/sifive/fu540.rst | 43 +++++++++++++++++++ 4 files changed, 84 insertions(+) create mode 100644 configs/sifive_fu540_spi_defconfig
diff --git a/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi b/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi index 0162f59f60..f5a208398f 100644 --- a/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi +++ b/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi @@ -12,6 +12,10 @@ spi2 = &qspi2; };
+ config { + u-boot,spl-payload-offset = <0x105000>; /* @ 1044KB */ + }; + hfclk { u-boot,dm-spl; }; @@ -21,6 +25,14 @@ }; };
+&qspi0 { + u-boot,dm-spl; + + flash@0 { + u-boot,dm-spl; + }; +}; + &qspi2 { mmc@0 { u-boot,dm-spl; diff --git a/board/sifive/fu540/fu540.c b/board/sifive/fu540/fu540.c index 131fee8898..84dd20e29d 100644 --- a/board/sifive/fu540/fu540.c +++ b/board/sifive/fu540/fu540.c @@ -129,6 +129,9 @@ void board_boot_order(u32 *spl_boot_list) u32 boot_devices[] = { #ifdef CONFIG_SPL_MMC_SUPPORT BOOT_DEVICE_MMC1, +#endif +#ifdef CONFIG_SPL_SPI_LOAD + BOOT_DEVICE_SPI, #endif };
diff --git a/configs/sifive_fu540_spi_defconfig b/configs/sifive_fu540_spi_defconfig new file mode 100644 index 0000000000..24d0a9338e --- /dev/null +++ b/configs/sifive_fu540_spi_defconfig @@ -0,0 +1,26 @@ +CONFIG_RISCV=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_TARGET_SIFIVE_FU540=y +CONFIG_ARCH_RV64I=y +CONFIG_RISCV_SMODE=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_MISC_INIT_R=y +CONFIG_DISPLAY_CPUINFO=y +CONFIG_DISPLAY_BOARDINFO=y +CONFIG_DEFAULT_DEVICE_TREE="hifive-unleashed-a00" +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_DM_MTD=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_DM_SPI=y +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI_SUPPORT=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SPL_YMODEM_SUPPORT=y +CONFIG_SPL_CLK=y +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x3000 +CONFIG_SIFIVE_FU540_DDR=y diff --git a/doc/board/sifive/fu540.rst b/doc/board/sifive/fu540.rst index 691ef232e2..14323e0985 100644 --- a/doc/board/sifive/fu540.rst +++ b/doc/board/sifive/fu540.rst @@ -391,3 +391,46 @@ Program the SD card Change DIP switches MSEL[3:0] are set to 1011
Insert the SD card and power up the board. + +Booting from SPI +---------------- + +Use steps from "Building" section for building the U-Boot + +.. code-block:: none + + export ARCH=riscv + export CROSS_COMPILE=<riscv64 toolchain prefix> + make sifive_fu540_spi_defconfig + make + +Partition the SPI in Linux via mtdblock. (Require to boot +the board in SD boot mode by enabling MTD block in Linux) + +.. code-block:: none + + # sgdisk --clear \ + > --set-alignment=2 \ + > --new=1:40:2087 --change-name=1:loader1 --typecode=1:5B193300-FC78-40CD-8002-E86C45580B47 \ + > --new=2:2088:10279 --change-name=2:loader2 --typecode=2:2E54B353-1271-4842-806F-E436D6AF6985 \ + > --new=3:10536:65494 --change-name=3:rootfs --typecode=3:0FC63DAF-8483-4772-8E79-3D69D8477DE4 \ + > /dev/mtdblock0 + +Program the SPI (Require to boot the board in SD boot mode) +on U-Boot proper. + +.. code-block:: none + + sf erase 0x5000 0x100000 + tftpboot $kernel_addr_r u-boot-spl.bin + sf write $kernel_addr_r 0x5000 $filesize + + sf erase 0x105000 0x100000 + tftpboot $kernel_addr_r u-boot.itb + sf write $kernel_addr_r 0x105000 $filesize + +Power off the board + +Change DIP switches MSEL[3:0] are set to 0110 + +Power up the board.
Hi Jagan,
On Mon, Apr 20, 2020 at 10:05 PM Jagan Teki jagan@amarulasolutions.com wrote:
This log seems to be SD boot, not SPI boot
config {
Can we add some comments about how this is chosen?
+&qspi0 {
u-boot,dm-spl;
flash@0 {
u-boot,dm-spl;
BOOT_DEVICE_SPI,
#endif };
These config options should be ordered by "make savedefconfg"
- export ARCH=riscv
- export CROSS_COMPILE=<riscv64 toolchain prefix>
- make sifive_fu540_spi_defconfig
- make
- # sgdisk --clear \
--set-alignment=2 \ --new=1:40:2087 --change-name=1:loader1 --typecode=1:5B193300-FC78-40CD-8002-E86C45580B47 \ --new=2:2088:10279 --change-name=2:loader2 --typecode=2:2E54B353-1271-4842-806F-E436D6AF6985 \ --new=3:10536:65494 --change-name=3:rootfs --typecode=3:0FC63DAF-8483-4772-8E79-3D69D8477DE4 \ /dev/mtdblock0+Program the SPI (Require to boot the board in SD boot mode) +on U-Boot proper.
- sf erase 0x5000 0x100000
- tftpboot $kernel_addr_r u-boot-spl.bin
- sf write $kernel_addr_r 0x5000 $filesize
- sf erase 0x105000 0x100000
- tftpboot $kernel_addr_r u-boot.itb
- sf write $kernel_addr_r 0x105000 $filesize
Looks good otherwise: Reviewed-by: Bin Meng bmeng.cn@gmail.com
Regards, Bin
On Mon, Apr 20, 2020 at 7:54 PM Bin Meng bmeng.cn@gmail.com wrote:
Hi Jagan,
Wrong log added, my bad.
config {
Yes on the doc file of loader2 sector start. Yes will make it more verbose if it isn't sufficient.
+&qspi0 {
u-boot,dm-spl;
flash@0 {
u-boot,dm-spl;
BOOT_DEVICE_SPI,
#endif };
Yes, I just sent it as the first series. Hoping to reuse existing defconfig if we have any way to detect the boot mode at runtime like reading MSEL.
Jagan.
SPI flash device on HiFive Unleashed has 32MiB Size.
This patch add SPI flash environment after U-Boot proper partition with a size of 128KiB.
SPI flash partition layout(32MiB): 0 - 34 : reserved for GPT header 35 - 39 : unused 40 - 2087 : loader1 (SPL, FSBL) 2088 - 10279 : loader2 (U-Boot proper, U-Boot) 10280 - 10535 : environment 10536 - 65494 : rootfs 65528 - 65536 : distro script
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- env/Kconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/env/Kconfig b/env/Kconfig index 0d6f559b39..67c88fd40b 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -500,6 +500,7 @@ config ENV_OFFSET default 0 if ARC default 0x140000 if ARCH_AT91 default 0x260000 if ARCH_OMAP2PLUS + default 0x505000 if TARGET_SIFIVE_FU540 help Offset from the start of the device (or partition)
@@ -519,6 +520,7 @@ config ENV_SIZE default 0x2000 if ARCH_ROCKCHIP && ENV_IS_IN_SPI_FLASH default 0x8000 if ARCH_ZYNQMP || ARCH_VERSAL default 0x4000 if ARC + default 0x20000 if TARGET_SIFIVE_FU540 default 0x1f000 help Size of the environment storage area @@ -529,6 +531,7 @@ config ENV_SECT_SIZE default 0x2000 if ARCH_ROCKCHIP default 0x40000 if ARCH_ZYNQMP || ARCH_VERSAL default 0x20000 if ARCH_ZYNQ || ARCH_OMAP2PLUS || ARCH_AT91 + default 0x10000 if TARGET_SIFIVE_FU540 help Size of the sector containing the environment.
Hi Jagan,
We really should not touch the generic env/Kconfig file otherwise the generic Kconfig will soon become unmaintainable. Instead put it into either board specific Kconfig, or SoC specific Kconfig. If this should be common layout for all SiFive FU540 SoCs, we should put it under arch/riscv/cpu/fu540/Kconfig
Regards, Bin
Mark the default U-Boot environment as SPI flash since this is an on board flash device.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- board/sifive/fu540/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/board/sifive/fu540/Kconfig b/board/sifive/fu540/Kconfig index 43d01bab8d..7e49feba00 100644 --- a/board/sifive/fu540/Kconfig +++ b/board/sifive/fu540/Kconfig @@ -27,6 +27,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy def_bool y select GENERIC_RISCV select SUPPORT_SPL + select ENV_IS_IN_SPI_FLASH imply CMD_DHCP imply CMD_EXT2 imply CMD_EXT4
HiFive-Unleashed-A00 has SPI flash with 32MiB size. So, let's use the script offset at the end of 4K. This way it cannot overlap any offsets being used by software components in flash layout.
So, SF distrocmd will pick the script at desired script address and run.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- include/configs/sifive-fu540.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/configs/sifive-fu540.h b/include/configs/sifive-fu540.h index 72c841eb9b..68fda14d76 100644 --- a/include/configs/sifive-fu540.h +++ b/include/configs/sifive-fu540.h @@ -62,6 +62,8 @@ "kernel_addr_r=0x84000000\0" \ "fdt_addr_r=0x88000000\0" \ "scriptaddr=0x88100000\0" \ + "script_offset_f=0x1fff000\0" \ + "script_size_f=0x1000\0" \ "pxefile_addr_r=0x88200000\0" \ "ramdisk_addr_r=0x88300000\0" \ "type_guid_gpt_loader1=" TYPE_GUID_LOADER1 "\0" \
Enable SPI flash(SF) distro boot command in Sifive FU540.
This distro boot will read the boot script at specific location at the flash and start sourcing the same.
Included the SF device at the last of the target devices list since all the rest of the devices on the list have more possibility to boot the distribution due to the size of the SPI flash is concern.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- include/configs/sifive-fu540.h | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/include/configs/sifive-fu540.h b/include/configs/sifive-fu540.h index 68fda14d76..f21411a701 100644 --- a/include/configs/sifive-fu540.h +++ b/include/configs/sifive-fu540.h @@ -43,9 +43,11 @@ #ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 0) \ + func(SF, sf, 0) \ func(DHCP, dhcp, na)
#include <config_distro_bootcmd.h> +#include <environment/distro/sf.h>
#define TYPE_GUID_LOADER1 "5B193300-FC78-40CD-8002-E86C45580B47" #define TYPE_GUID_LOADER2 "2E54B353-1271-4842-806F-E436D6AF6985" @@ -70,7 +72,8 @@ "type_guid_gpt_loader2=" TYPE_GUID_LOADER2 "\0" \ "type_guid_gpt_system=" TYPE_GUID_SYSTEM "\0" \ "partitions=" PARTS_DEFAULT "\0" \ - BOOTENV + BOOTENV \ + BOOTENV_SF
#define CONFIG_PREBOOT \ "setenv fdt_addr ${fdtcontroladdr};" \
Hi Jagan,
Should we determine the boot order based on MSEL dynamically?
Thank you very much for get the SPI flash working and bring in additional booting from SPI flash support.
Any inputs? Jagan.
Regards, Bin
Bin Meng
Jagan Teki
