[U-Boot] [PATCH v9 2/2] console: usb: kbd: To improve TFTP booting performance
TFTP booting is slow when a USB keyboard is installed and stdin has usbkbd added. This fix is to change Ctrl-C polling for USB keyboard to every second when NET transfer is running.
Signed-off-by: Jim Lin jilin@nvidia.com --- Changes in v2: 1. Change configuration name from CONFIG_CTRLC_POLL_MS to CONFIG_CTRLC_POLL_S. 2. New code will be executed only when CONFIG_CTRLC_POLL_S is defined in configuration header file. 3. Add description in README.console. Changes in v3: 1. Move changes to common/usb_kbd.c and doc/README.usb 2. Rename config setting to CONFIG_USBKB_TESTC_PERIOD. 3. Remove slow response on USB-keyboard input when TFTP boot is not running. Changes in v4: 1. Remove changes in doc/README.usb, common/usb_kbd.c and CONFIG_USBKB_TESTC_PERIOD 2. Modify net/net.c Changes in v5: 1. Change variable name to ctrlc_t_start. 2. Use two calls of get_timer(0) to get time gap. Changes in v6: 1. In common/usb_kbd.c, check net_busy_flag to determine whether we poll USB keyboard status. 2. In include/usb.h, add external variable declaration net_busy_flag Changes in v7: 1. In common/usb_kbd.c and include/usb.h, add #ifdef CONFIG_CMD_NET. 2. In common/usb_kbd.c, modify code to get correct time gap. Changes in v8: 1. Add __maybe_unused for variable kbd_testc_tms. Changes in v9: 1. Move external variable declaration from include/usb.h to common/usb_kbd.c
common/usb_kbd.c | 15 +++++++++++++++ 1 files changed, 15 insertions(+), 0 deletions(-)
diff --git a/common/usb_kbd.c b/common/usb_kbd.c index 3174b5e..46100e6 100644 --- a/common/usb_kbd.c +++ b/common/usb_kbd.c @@ -121,6 +121,11 @@ struct usb_kbd_pdata { uint8_t flags; };
+extern int __maybe_unused net_busy_flag; + +/* The period of time between two calls of usb_kbd_testc(). */ +static unsigned long __maybe_unused kbd_testc_tms; + /* Generic keyboard event polling. */ void usb_kbd_generic_poll(void) { @@ -366,6 +371,16 @@ static int usb_kbd_testc(void) struct usb_device *usb_kbd_dev; struct usb_kbd_pdata *data;
+#ifdef CONFIG_CMD_NET + /* + * If net_busy_flag is 1, NET transfer is running, + * then we check key-pressed every second (first check may be + * less than 1 second) to improve TFTP booting performance. + */ + if (net_busy_flag && (get_timer(kbd_testc_tms) < CONFIG_SYS_HZ)) + return 0; + kbd_testc_tms = get_timer(0); +#endif dev = stdio_get_by_name(DEVNAME); usb_kbd_dev = (struct usb_device *)dev->priv; data = usb_kbd_dev->privptr;
Dear Jim Lin,
Changes in v2:
- Change configuration name from CONFIG_CTRLC_POLL_MS to
- Move changes to common/usb_kbd.c and doc/README.usb
- Rename config setting to CONFIG_USBKB_TESTC_PERIOD.
- Remove slow response on USB-keyboard input when TFTP boot is not
- Remove changes in doc/README.usb, common/usb_kbd.c and CONFIG_USBKB_TESTC_PERIOD
- Modify net/net.c
Changes in v5:
- Change variable name to ctrlc_t_start.
- Use two calls of get_timer(0) to get time gap.
Changes in v6:
- In common/usb_kbd.c, check net_busy_flag to determine whether we poll USB keyboard status.
- In include/usb.h, add external variable declaration net_busy_flag
Changes in v7:
- In common/usb_kbd.c and include/usb.h, add #ifdef CONFIG_CMD_NET.
- In common/usb_kbd.c, modify code to get correct time gap.
Changes in v8:
- Add __maybe_unused for variable kbd_testc_tms.
Changes in v9:
- Move external variable declaration from include/usb.h to
common/usb_kbd.c
Applied, thanks.
Best regards, Marek Vasut
Marek, In common/usb_kbd.c, you applied code to wrong place. You should apply my change to function usb_kbd_testc(), instead of usb_kbd_getc(). Could you help to correct it?
Thanks, Jim
-----Original Message----- From: Marek Vasut [mailto:marex@denx.de] Sent: Wednesday, August 21, 2013 12:27 PM To: Jim Lin Cc: joe.hershberger@gmail.com; u-boot@lists.denx.de; Tom Warren; swarren@wwwdotorg.org Subject: Re: [PATCH v9 2/2] console: usb: kbd: To improve TFTP booting performance
Dear Jim Lin,
Changes in v2:
- Move changes to common/usb_kbd.c and doc/README.usb 2. Rename
- Modify net/net.c
Changes in v5:
Changes in v6:
Changes in v7:
Changes in v8:
Changes in v9:
common/usb_kbd.c
Applied, thanks.
-- nvpublic
Dear Jim Lin,
I believe I applied your patches. Anyway, submit a subsequent patch against u- boot-usb/master please.
On 08/26/2013 05:31 AM, Marek Vasut wrote:
Dear Jim Lin,
Marek, did you apply the patch using "git am", "patch", or by hand-editing? Looking at the fixup patch that Jim sent, the patch context is identical in both places, so perhaps this exposed some issue with git/... - it'd be useful to understand how the problem occurred, so it can be fixed.
Dear Stephen Warren,
Dear Jim Lin,
git am ... and you're right, this is somewhat strange.
Jim Lin
Stephen Warren
