[U-Boot] [PATCH] MAKEALL: Do a sanity check on user-supplied arguments
Add a check to make sure that the user's arguments actually find a board in boards.cfg. Previously, if a user misspelled an argument the argument would be discarded without warning. For example, running 'MAKEALL -c 85xx' with the intention of compiling all Freescale 85xx boards would instead silently discard the '-c 85xx' argument since the proper cpu name is 'mpc85xx' and then proceed to compile all PowerPC boards (MAKEALL's default).
Also fix an unrelated typo.
Signed-off-by: Peter Tyser ptyser@xes-inc.com --- MAKEALL | 8 +++++++- 1 files changed, 7 insertions(+), 1 deletions(-)
diff --git a/MAKEALL b/MAKEALL index c54c6e8..767d561 100755 --- a/MAKEALL +++ b/MAKEALL @@ -11,7 +11,7 @@ # line; without any arguments, MAKEALL defaults to building all Power # Architecture systems (i. e. same as for "MAKEALL powerpc"). # -# With the iontroduction of the board.cfg file, it has become possible +# With the introduction of the board.cfg file, it has become possible # to provide additional selections. We use standard command line # options for this: # @@ -125,6 +125,12 @@ FILTER="$1 !~ /^#/"
if [ "$SELECTED" ] ; then SELECTED=$(awk '('"$FILTER"') { print $1 }' boards.cfg) + + # Make sure some boards from boards.cfg are actually found + if [ -z "$SELECTED" ] ; then + echo "Error: No boards selected, invalid arguments" + exit 1 + fi fi
Dear Peter Tyser,
Applied, thanks.
Peter Tyser
