[U-Boot] [PATCH 1/2] net: Add SMC911X driver to Kconfig
There are a variety of boards that need some cleanup in their respective include/configs file, but here is a foundation for them to begin their transisiton.
Signed-off-by: Adam Ford aford173@gmail.com --- drivers/net/Kconfig | 29 +++++++++++++++++++++++++++++ 1 file changed, 29 insertions(+)
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 5ceea44..bd2a303 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -203,6 +203,35 @@ config RTL8169 This driver supports Realtek 8169 series gigabit ethernet family of PCI/PCIe chipsets/adapters.
+config SMC911X + bool "SMSC LAN911x and LAN921x controller driver" + +if SMC911X + +config SMC911X_BASE + hex "SMC911X Base Address" + default 0 + help + Define this to hold the physical address + of the device (I/O space) + +choice + prompt "SMC911X bus width" + default SMC911X_16_BIT + +config SMC911X_32_BIT + bool "Enable 32-bit interface" + +config SMC911X_16_BIT + bool "Enable 16-bit interface" + help + Define this if data bus is 16 bits. If your processor + automatically converts one 32 bit word to two 16 bit + words you may also try CONFIG_SMC911X_32_BIT. + +endchoice +endif #SMC911X + config SUN7I_GMAC bool "Enable Allwinner GMAC Ethernet support" help
With SMC911X supported in Kconfig, let's migrate the Logic PD OMAP3 board.
Signed-off-by: Adam Ford aford173@gmail.com --- configs/omap3_logic_defconfig | 4 ++++ include/configs/omap3_logic.h | 7 ------- 2 files changed, 4 insertions(+), 7 deletions(-)
diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index 8d0a4d4..07abc55 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -40,6 +40,10 @@ CONFIG_MMC_OMAP36XX_PINS=y CONFIG_NAND=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 +CONFIG_NETDEVICES=y +CONFIG_SMC911X=y +CONFIG_SMC911X_BASE=0x08000000 +CONFIG_SMC911X_32_BIT=y CONFIG_SYS_NS16550=y CONFIG_OMAP3_SPI=y CONFIG_USB=y diff --git a/include/configs/omap3_logic.h b/include/configs/omap3_logic.h index a4a40f4..6b7a2d6 100644 --- a/include/configs/omap3_logic.h +++ b/include/configs/omap3_logic.h @@ -242,13 +242,6 @@ #define CONFIG_ENV_OFFSET SMNAND_ENV_OFFSET #define CONFIG_ENV_ADDR SMNAND_ENV_OFFSET
-/* SMSC922x Ethernet */ -#if defined(CONFIG_CMD_NET) -#define CONFIG_SMC911X -#define CONFIG_SMC911X_32_BIT -#define CONFIG_SMC911X_BASE 0x08000000 -#endif /* (CONFIG_CMD_NET) */ - /* Defines for SPL */
/* NAND: SPL falcon mode configs */
Adam Ford
