[U-Boot] [PATCH 1/1] Add config option for disabling DM9000-SROM support.
Some boards do not have SROM support for the DM9000 network adapter. Instead of listing these board names in the driver code, make this option configurable from the board config file.
It also removes a build warning for the at91sam9261ek board: 'dm9000x.c:545: warning: 'read_srom_word' defined but not used'
And it repaires the trizepsiv board build which was broken around the same routines
Signed-off-by: Remy Bohmer linux@bohmer.net --- board/trizepsiv/eeprom.c | 14 +++++++------- drivers/net/dm9000x.c | 16 ++++++++-------- include/configs/at91sam9261ek.h | 1 + include/dm9000.h | 11 +++++++++++ 4 files changed, 27 insertions(+), 15 deletions(-) create mode 100644 include/dm9000.h
diff --git a/board/trizepsiv/eeprom.c b/board/trizepsiv/eeprom.c index 63f1c6c..9fa7aef 100644 --- a/board/trizepsiv/eeprom.c +++ b/board/trizepsiv/eeprom.c @@ -23,17 +23,17 @@
#include <common.h> #include <command.h> - -extern u16 read_srom_word(int); -extern void write_srom_word(int offset, u16 val); +#include <dm9000.h>
static int do_read_dm9000_eeprom ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { - int i; + unsigned int i; + u8 data[2];
for (i=0; i < 0x40; i++) { if (!(i % 0x10)) - printf("\n%08lx:", i); - printf(" %04x", read_srom_word(i)); + printf("\n%08x:", i); + dm9000_read_srom_word(i, data); + printf(" %02x%02x", data[1], data[0]); } printf ("\n"); return (0); @@ -54,7 +54,7 @@ static int do_write_dm9000_eeprom ( cmd_tbl_t *cmdtp, int flag, int argc, char * cmd_usage(cmdtp); return 1; } - write_srom_word(offset, value); + dm9000_write_srom_word(offset, value); return (0); }
diff --git a/drivers/net/dm9000x.c b/drivers/net/dm9000x.c index 8ca2bf7..934d991 100644 --- a/drivers/net/dm9000x.c +++ b/drivers/net/dm9000x.c @@ -53,7 +53,7 @@ v1.2 03/18/2003 Weilun Huang weilun_huang@davicom.com.tw: notes (i.e. double reset) - some minor code cleanups These changes are tested with DM9000{A,EP,E} together - with a 200MHz Atmel AT91SAM92161 core + with a 200MHz Atmel AT91SAM9261 core
TODO: external MII is not functional, only internal at the moment. */ @@ -62,6 +62,7 @@ TODO: external MII is not functional, only internal at the moment. #include <command.h> #include <net.h> #include <asm/io.h> +#include <dm9000.h>
#include "dm9000x.h"
@@ -113,7 +114,6 @@ void eth_halt(void); static int dm9000_probe(void); static u16 phy_read(int); static void phy_write(int, u16); -static void read_srom_word(int, u8 *); static u8 DM9000_ior(int); static void DM9000_iow(int reg, u8 value);
@@ -347,9 +347,9 @@ eth_init(bd_t * bd)
/* Set Node address */ if (!eth_getenv_enetaddr("ethaddr", enetaddr)) { -#if !defined(CONFIG_AT91SAM9261EK) +#if !defined(CONFIG_DM9000_NO_SROM_AVAIL) for (i = 0; i < 3; i++) - read_srom_word(i, enetaddr + 2 * i); + dm9000_read_srom_word(i, enetaddr + 2 * i); eth_setenv_enetaddr("ethaddr", enetaddr); #endif } @@ -541,7 +541,8 @@ eth_rx(void) /* Read a word data from SROM */ -static void read_srom_word(int offset, u8 *to) +#if !defined(CONFIG_DM9000_NO_SROM_AVAIL) +void dm9000_read_srom_word(int offset, u8 *to) { DM9000_iow(DM9000_EPAR, offset); DM9000_iow(DM9000_EPCR, 0x4); @@ -551,8 +552,7 @@ static void read_srom_word(int offset, u8 *to) to[1] = DM9000_ior(DM9000_EPDRH); }
-void -write_srom_word(int offset, u16 val) +void dm9000_write_srom_word(int offset, u16 val) { DM9000_iow(DM9000_EPAR, offset); DM9000_iow(DM9000_EPDRH, ((val >> 8) & 0xff)); @@ -561,7 +561,7 @@ write_srom_word(int offset, u16 val) udelay(8000); DM9000_iow(DM9000_EPCR, 0); } - +#endif
/* Read a byte from I/O port diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index fdaa71c..c30674f 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -137,6 +137,7 @@ #define DM9000_IO CONFIG_DM9000_BASE #define DM9000_DATA (CONFIG_DM9000_BASE + 4) #define CONFIG_DM9000_USE_16BIT 1 +#define CONFIG_DM9000_NO_SROM_AVAIL 1 #define CONFIG_NET_RETRY_COUNT 20 #define CONFIG_RESET_PHY_R 1
diff --git a/include/dm9000.h b/include/dm9000.h new file mode 100644 index 0000000..d59919b --- /dev/null +++ b/include/dm9000.h @@ -0,0 +1,11 @@ + +#ifndef __DM9000_H__ +#define __DM9000_H__ + +/****************** function prototypes **********************/ +#if !defined(CONFIG_DM9000_NO_SROM_AVAIL) +void dm9000_write_srom_word(int offset, u16 val); +void dm9000_read_srom_word(int offset, u8 *to); +#endif + +#endif /* __DM9000_H__ */
please put Stelian in Cc
CONFIG_DM9000_NO_SROM will be shorter and the same
eth_setenv_enetaddr("ethaddr", enetaddr);dm9000_read_srom_word(i, enetaddr + 2 * i);
#endif
Ben what do you think to do as usb have a dir to store all net header include/net/
@@ -0,0 +1,11 @@
Copyrigth?
Best Regards, J.
Hello,
2009/5/3 Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com:
Done!
OK
- dm9000_read_srom_word(i, enetaddr + 2 * i);
I have chosen the same location as the dm9161.h, other similar headers are there as well. If it has to be changed, I suggest making it a separate patch.
@@ -0,0 +1,11 @@
Copyrigth?
OK.
Best Regards, J.
sure
I've in mind this
include/{ => net}/at91rm9200_net.h include/{ => net}/bcm5221.h include/{ => net}/dm9161.h include/{ => net}/dp83848.h include/{ => net}/lxt971a.h include/{ => net}/mii_phy.h include/{ => net}/miiphy.h include/{ => net}/ns7520_eth.h include/{ => net}/ns9750_eth.h include/{ => net}/ppc4xx_enet.h include/{ => net}/tsec.h
or
include/{ => net}/at91rm9200_net.h include/{ => net}/ns7520_eth.h include/{ => net}/ns9750_eth.h include/{ => net}/ppc4xx_enet.h include/{ => net}/tsec.h include/{ => net/phy}/bcm5221.h include/{ => net/phy}/dm9161.h include/{ => net/phy}/dp83848.h include/{ => net/phy}/lxt971a.h include/{ => net/phy}/mii_phy.h include/{ => net/phy}/miiphy.h
and maybe include/{ => net}/netdev.h
Best Regards, J.
Hi J-C,
On Sun, May 3, 2009 at 3:21 AM, Jean-Christophe PLAGNIOL-VILLARD < plagnioj@jcrosoft.com> wrote:
sure
I've in mind this
or
Best Regards, J.
I'm not crazy about this idea - it seems like unnecessary hierarchy when efforts could be diverted elsewhere. There are very few net-related public header files (as you've shown) and browsing through them, there's a lot of duplication of 802.3-defined PHY stuff and register definitions that are really private to the drivers themselves. Ideally we would have very little in the way of device-specific public functions apart from xxx_initialize(). I'm OK with having device-specific prototypes and struct definitions in netdev.h - that's what it was created for in the first place. As long as there's no code there (including static inlines) it seems appropriate.
regards, Ben
V2: reworked comments from Jean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Remy Bohmer linux@bohmer.net --- board/trizepsiv/eeprom.c | 14 +++++++------- drivers/net/dm9000x.c | 16 ++++++++-------- include/configs/at91sam9261ek.h | 1 + include/dm9000.h | 20 ++++++++++++++++++++ 4 files changed, 36 insertions(+), 15 deletions(-) create mode 100644 include/dm9000.h
diff --git a/drivers/net/dm9000x.c b/drivers/net/dm9000x.c index 8ca2bf7..f139435 100644 --- a/drivers/net/dm9000x.c +++ b/drivers/net/dm9000x.c @@ -53,7 +53,7 @@ v1.2 03/18/2003 Weilun Huang weilun_huang@davicom.com.tw: notes (i.e. double reset) - some minor code cleanups These changes are tested with DM9000{A,EP,E} together - with a 200MHz Atmel AT91SAM92161 core + with a 200MHz Atmel AT91SAM9261 core
/* Set Node address */ if (!eth_getenv_enetaddr("ethaddr", enetaddr)) { -#if !defined(CONFIG_AT91SAM9261EK) +#if !defined(CONFIG_DM9000_NO_SROM) for (i = 0; i < 3; i++) - read_srom_word(i, enetaddr + 2 * i); + dm9000_read_srom_word(i, enetaddr + 2 * i); eth_setenv_enetaddr("ethaddr", enetaddr); #endif } @@ -541,7 +541,8 @@ eth_rx(void) /* Read a word data from SROM */ -static void read_srom_word(int offset, u8 *to) +#if !defined(CONFIG_DM9000_NO_SROM) +void dm9000_read_srom_word(int offset, u8 *to) { DM9000_iow(DM9000_EPAR, offset); DM9000_iow(DM9000_EPCR, 0x4); @@ -551,8 +552,7 @@ static void read_srom_word(int offset, u8 *to) to[1] = DM9000_ior(DM9000_EPDRH); }
/* Read a byte from I/O port diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index fdaa71c..9621b7c 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -137,6 +137,7 @@ #define DM9000_IO CONFIG_DM9000_BASE #define DM9000_DATA (CONFIG_DM9000_BASE + 4) #define CONFIG_DM9000_USE_16BIT 1 +#define CONFIG_DM9000_NO_SROM 1 #define CONFIG_NET_RETRY_COUNT 20 #define CONFIG_RESET_PHY_R 1
diff --git a/include/dm9000.h b/include/dm9000.h new file mode 100644 index 0000000..76f9bfd --- /dev/null +++ b/include/dm9000.h @@ -0,0 +1,20 @@ +/* + * NOTE: DAVICOM DM9000 ethernet driver interface + * + * Authors: Remy Bohmer linux@bohmer.net + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * as published by the Free Software Foundation; either version + * 2 of the License, or (at your option) any later version. + */ +#ifndef __DM9000_H__ +#define __DM9000_H__ + +/****************** function prototypes **********************/ +#if !defined(CONFIG_DM9000_NO_SROM) +void dm9000_write_srom_word(int offset, u16 val); +void dm9000_read_srom_word(int offset, u8 *to); +#endif + +#endif /* __DM9000_H__ */
FWIW: Signed-off-by: Stelian Pop stelian@popies.net
Thanks,
this should be below the "---" marker so that it doesnt show up in the changelog
similar comment with subject summary: no need for "1/1", the "v2" should be more in the "[PATCH v2]", and summaries do not get periods ...
there is no "e" in "repairs" ... -mike
participants (5)
Ben Warren
Mike Frysinger
Remy Bohmer
Stelian Pop
