[U-Boot-Users] [PATCH] Make MPC83xx one step closer to full relocation.
Remove a few absolute references to CFG_MONITOR_BASE for ppc/mpc83xx and use GOT relative reference. --- cpu/mpc83xx/start.S | 11 +++++++---- lib_ppc/board.c | 3 ++- 2 files changed, 9 insertions(+), 5 deletions(-)
diff --git a/cpu/mpc83xx/start.S b/cpu/mpc83xx/start.S index 1dfbf62..56fd7ec 100644 --- a/cpu/mpc83xx/start.S +++ b/cpu/mpc83xx/start.S @@ -172,8 +172,11 @@ boot_warm: /* time t 5 */ /* there and deflate the flash size back to minimal size */ /*------------------------------------------------------------*/ bl map_flash_by_law1 - lis r4, (CFG_MONITOR_BASE)@h - ori r4, r4, (CFG_MONITOR_BASE)@l + + GET_GOT /* initialize GOT access */ + lwz r4, GOT(_start) + addi r4, r4, -EXC_OFF_SYS_RESET + addi r5, r4, in_flash - _start + EXC_OFF_SYS_RESET mtlr r5 blr @@ -906,8 +909,8 @@ relocate_code: mr r10, r5 /* Save copy of Destination Address */
mr r3, r5 /* Destination Address */ - lis r4, CFG_MONITOR_BASE@h /* Source Address */ - ori r4, r4, CFG_MONITOR_BASE@l + lwz r4, GOT(_start) + addi r4, r4, -EXC_OFF_SYS_RESET lwz r5, GOT(__init_end) sub r5, r5, r4 li r6, CFG_CACHELINE_SIZE /* Cache Line Size */ diff --git a/lib_ppc/board.c b/lib_ppc/board.c index 45d1328..8a18350 100644 --- a/lib_ppc/board.c +++ b/lib_ppc/board.c @@ -117,6 +117,7 @@ DECLARE_GLOBAL_DATA_PTR; #define TOTAL_MALLOC_LEN CFG_MALLOC_LEN #endif
+extern ulong _start; extern ulong __init_end; extern ulong _end; ulong monitor_flash_len; @@ -417,7 +418,7 @@ void board_init_f (ulong bootflag) * - monitor code * - board info struct */ - len = (ulong)&_end - CFG_MONITOR_BASE; + len = (ulong)&_end - (ulong)&_start + EXC_OFF_SYS_RESET;
#ifndef CONFIG_VERY_BIG_RAM addr = CFG_SDRAM_BASE + gd->ram_size;
Joakim Tjernlund
