[U-Boot] [announce] tbot: add a testcase for checking kconfig move
Hello,
just for interests
I just added a testcase to tbot, which checks if U-Boot patch(es) do not change the resulting U-Boot binaries(currently I check u-boot.bin and spl/u-boot-spl.bin ... it should be easy to add more if needed)
see tbot testcase: [1] https://github.com/hsdenx/tbot/commit/bd20fca143e49a1575df5a5532057abbb72341...
For installing tbot please read: https://github.com/hsdenx/tbot/blob/master/doc/README.install (if you only want to use this new testcase, you do not need the steps for adding a virtual lab, nor a connection to a boards console), you can use your PC where you installed tbot (ofcourse this PC must have the ability to compile U-Boot, toolchains for supported archs must be installed, also git, parmiko must be installed))
For using [1] with tbot, you need the config file: https://github.com/hsdenx/tbot/blob/master/config/tbot_uboot_kconfig_check.c... and adapt it to your local settings. Hope the comments are helpful.
Do not hesitate to contact me, if you have problems to get tbot running.
bye, Heiko
Here a log running the testcase [1] (enable tbot to print status info to stdout: https://github.com/hsdenx/tbot/blob/master/config/tbot_uboot_kconfig_check.c... changing this line into "self.debugstatus=True"
also enabled line https://github.com/hsdenx/tbot/blob/master/src/tc/uboot/tc_uboot_check_kconf... to test for each arch only one board):
$ python2.7 src/common/tbot.py -c config/tbot_uboot_kconfig_check.cfg -t tc_uboot_check_kconfig.py -l log/tbot.log **** option cfg: config/tbot_uboot_kconfig_check.cfg log: log/tbot.log tc: tc_uboot_check_kconfig.py v 0 ('CUR WORK PATH: ', '/home/hs/data/Entwicklung/tbot') ('CFGFILE ', 'config/tbot_uboot_kconfig_check.cfg') ('LOGFILE ', '/home/hs/data/Entwicklung/tbot/log/tbot.log') get u-boot source testing board adp-ag101p 1 / 13 testing board amcore 2 / 13 testing board ap_sh4a_4a 3 / 13 testing board vct_premium 4 / 13 testing board bf527-ezkit 5 / 13 testing board axs103 6 / 13 testing board axs103 first compile failed testing board atngw100 7 / 13 testing board microblaze-generic 8 / 13 testing board 10m50 9 / 13 testing board openrisc-generic 10 / 13 testing board openrisc-generic first compile failed testing board sandbox 11 / 13 sandbox u-boot bin diff da4496233033935d13e599de0b6c72e7 != 290b8d52b847b0d01b0c48d7b77b9aef testing board gr_ep2s60 12 / 13 testing board chromebook_link 13 / 13 Boards : 13 compile err : 2 not checked : 0 U-Boot good : 10 bad 1 SPL good : 1 bad 0 ('compile err :', ['axs103', 'openrisc-generic']) ('bad :', ['sandbox']) End of TBOT: failure
It seems I have a problem to get sandbox compiling identical binaries, I must check this, also boards, which does not compile cannot checked ... but I think, its ready for usage ...
Heiko Schocher
