[U-Boot] [PATCH] Blackfin: initcode: mark uncommon code paths as unlikely
Putting memory into self refresh only happens when doing development, not during the normal course of things, so mark those code paths as unlikely.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- arch/blackfin/cpu/initcode.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/arch/blackfin/cpu/initcode.c b/arch/blackfin/cpu/initcode.c index fb3a101..243f4f3 100644 --- a/arch/blackfin/cpu/initcode.c +++ b/arch/blackfin/cpu/initcode.c @@ -337,13 +337,13 @@ maybe_self_refresh(ADI_BOOT_DATA *bs)
/* If external memory is enabled, put it into self refresh first. */ #if defined(EBIU_RSTCTL) - if (bfin_read_EBIU_RSTCTL() & DDR_SRESET) { + if (unlikely(bfin_read_EBIU_RSTCTL() & DDR_SRESET)) { serial_putc('b'); bfin_write_EBIU_RSTCTL(bfin_read_EBIU_RSTCTL() | SRREQ); return true; } #elif defined(EBIU_SDGCTL) - if (bfin_read_EBIU_SDBCTL() & EBE) { + if (unlikely(bfin_read_EBIU_SDBCTL() & EBE)) { serial_putc('b'); bfin_write_EBIU_SDGCTL(bfin_read_EBIU_SDGCTL() | SRFS); return true; @@ -367,7 +367,7 @@ program_clocks(ADI_BOOT_DATA *bs, bool put_into_srfs) serial_putc('b');
/* If we're entering self refresh, make sure it has happened. */ - if (put_into_srfs) + if (unlikely(put_into_srfs)) #if defined(EBIU_RSTCTL) while (!(bfin_read_EBIU_RSTCTL() & SRACK)) continue; @@ -549,7 +549,7 @@ program_memory_controller(ADI_BOOT_DATA *bs, bool put_into_srfs) serial_putc('c');
/* Now that we've reprogrammed, take things out of self refresh. */ - if (put_into_srfs) + if (unlikely(put_into_srfs)) #if defined(EBIU_RSTCTL) bfin_write_EBIU_RSTCTL(bfin_read_EBIU_RSTCTL() & ~(SRREQ)); #elif defined(EBIU_SDGCTL) @@ -604,7 +604,7 @@ check_hibernation(ADI_BOOT_DATA *bs, u16 vr_ctl, bool put_into_srfs) * * SCKELOW is unreliable on older parts (anomaly 307) */ - if (ANOMALY_05000307 || vr_ctl & 0x8000) { + if (unlikely(ANOMALY_05000307 || vr_ctl & 0x8000)) { uint32_t *hibernate_magic = 0; __builtin_bfin_ssync(); /* make sure memory controller is done */ if (hibernate_magic[0] == 0xDEADBEEF) {
Mike Frysinger
