[PATCH] armv8: layerscape: enable eMMC HS400 workarounds for LX2160A/LX2162A
Enable eMMC HS400 workarounds for LX2160A/LX2162A.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 9d1ba4c771..395e5ccaad 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -224,6 +224,8 @@ config ARCH_LX2162A select SYS_FSL_EC1 select SYS_FSL_EC2 select SYS_FSL_ERRATUM_A050106 + select SYS_FSL_ERRATUM_A011334 + select SYS_FSL_ESDHC_UNRELIABLE_PULSE_DETECTION_WORKAROUND select SYS_FSL_HAS_RGMII select SYS_FSL_HAS_SEC select SYS_FSL_HAS_CCN508 @@ -254,6 +256,8 @@ config ARCH_LX2160A select SYS_FSL_EC1 select SYS_FSL_EC2 select SYS_FSL_ERRATUM_A050106 + select SYS_FSL_ERRATUM_A011334 + select SYS_FSL_ESDHC_UNRELIABLE_PULSE_DETECTION_WORKAROUND select SYS_FSL_HAS_RGMII select SYS_FSL_HAS_SEC select SYS_FSL_HAS_CCN508
Any comments. Thanks!
-----Original Message----- From: Yangbo Lu yangbo.lu@nxp.com Sent: 2021年4月27日 16:42 To: u-boot@lists.denx.de; Priyanka Jain priyanka.jain@nxp.com; Meenakshi Aggarwal meenakshi.aggarwal@nxp.com Cc: Y.b. Lu yangbo.lu@nxp.com Subject: [PATCH] armv8: layerscape: enable eMMC HS400 workarounds for LX2160A/LX2162A
- select SYS_FSL_ERRATUM_A011334
- select SYS_FSL_ESDHC_UNRELIABLE_PULSE_DETECTION_WORKAROUND select SYS_FSL_HAS_RGMII select SYS_FSL_HAS_SEC select SYS_FSL_HAS_CCN508
-- 2.25.1
May I know the status of the patch? Thanks.
-----Original Message----- From: Y.b. Lu Sent: 2021年5月14日 10:25 To: Priyanka Jain priyanka.jain@nxp.com; Meenakshi Aggarwal meenakshi.aggarwal@nxp.com Cc: u-boot@lists.denx.de Subject: RE: [PATCH] armv8: layerscape: enable eMMC HS400 workarounds for LX2160A/LX2162A
-- 2.25.1
Y.b. Lu
Yangbo Lu
