[U-Boot] [PATCH] tegra20: display: Add support for flipped panels
Add support for two new panel properties, flip-vertical and flip-horizontal. If set the display controller will be setup to correctly flip the image.
Change-Id: I324b5d2b0b7ebbde7e08e5f32509cf101c057c84 Signed-off-by: Alban Bedel alban.bedel@avionic-design.de --- arch/arm/cpu/armv7/tegra20/display.c | 20 ++++++++++++++++++-- arch/arm/include/asm/arch-tegra20/display.h | 4 ++++ 2 files changed, 22 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv7/tegra20/display.c b/arch/arm/cpu/armv7/tegra20/display.c index fd77f3f..b332dd4 100644 --- a/arch/arm/cpu/armv7/tegra20/display.c +++ b/arch/arm/cpu/armv7/tegra20/display.c @@ -20,6 +20,7 @@ static void update_window(struct dc_ctlr *dc, struct disp_ctl_win *win) { unsigned h_dda, v_dda; unsigned long val; + unsigned x, y;
val = readl(&dc->cmd.disp_win_header); val |= WINDOW_A_SELECT; @@ -58,11 +59,22 @@ static void update_window(struct dc_ctlr *dc, struct disp_ctl_win *win) val = WIN_ENABLE; if (win->bpp < 24) val |= COLOR_EXPAND; + if (win->flip_h) + val |= H_DIRECTION; + if (win->flip_v) + val |= V_DIRECTION; writel(val, &dc->win.win_opt);
+ x = win->x; + if (win->flip_h) + x += (win->w - 1) * (win->bpp / 8); + y = win->y; + if (win->flip_v) + y += win->h - 1; + writel((unsigned long)win->phys_addr, &dc->winbuf.start_addr); - writel(win->x, &dc->winbuf.addr_h_offset); - writel(win->y, &dc->winbuf.addr_v_offset); + writel(x, &dc->winbuf.addr_h_offset); + writel(y, &dc->winbuf.addr_v_offset);
writel(0xff00, &dc->win.blend_nokey); writel(0xff00, &dc->win.blend_1win); @@ -204,6 +216,8 @@ int setup_window(struct disp_ctl_win *win, struct fdt_disp_config *config) win->out_y = 0; win->out_w = config->width; win->out_h = config->height; + win->flip_h = config->flip_h; + win->flip_v = config->flip_v; win->phys_addr = config->frame_buffer; win->stride = config->width * (1 << config->log2_bpp) / 8; debug("%s: depth = %d\n", __func__, config->log2_bpp); @@ -258,6 +272,8 @@ static int tegra_decode_panel(const void *blob, int node,
config->width = fdtdec_get_int(blob, node, "xres", -1); config->height = fdtdec_get_int(blob, node, "yres", -1); + config->flip_h = fdtdec_get_bool(blob, node, "flip-horizontal"); + config->flip_v = fdtdec_get_bool(blob, node, "flip-vertical"); config->pixel_clock = fdtdec_get_int(blob, node, "clock", 0); if (!config->pixel_clock || config->width == -1 || config->height == -1) { diff --git a/arch/arm/include/asm/arch-tegra20/display.h b/arch/arm/include/asm/arch-tegra20/display.h index a04c84e..05c7bd5 100644 --- a/arch/arm/include/asm/arch-tegra20/display.h +++ b/arch/arm/include/asm/arch-tegra20/display.h @@ -25,6 +25,8 @@ struct disp_ctl_win { unsigned out_y; /* Top edge of output window (row) */ unsigned out_w; /* Width of output window in pixels */ unsigned out_h; /* Height of output window in pixels */ + unsigned flip_h; /* Horizontally flip the image */ + unsigned flip_v; /* Vertically flip the image */ };
#define FDT_LCD_TIMINGS 4 @@ -53,6 +55,8 @@ struct fdt_disp_config { int width; /* width in pixels */ int height; /* height in pixels */ int bpp; /* number of bits per pixel */ + unsigned flip_h; /* Horizontally flip the image */ + unsigned flip_v; /* Vertically flip the image */
/* * log2 of number of bpp, in general, unless it bpp is 24 in which
Alban Bedel
