[U-Boot-Users] Why compile ERROR.
*I just want to compile the source code for the board mx1ads,which has been supported.* *And I did the follows.But errors occured*
p.s. The cross_compiler is supplied by ELDK3.1.1(arm_linux_eldk3.1.1).
*[user@Jason u-boot-1.1.3]$ make distclean* *[user@Jason u-boot-1.1.3]$ make mx1ads_config* *[user@Jason u-boot-1.1.3]$ make all *make[1]: Entering directory `/home/user/workspace/u-boot-1.1.3/tools' ln -s ../common/environment.c environment.c ln -s ../lib_generic/crc32.c crc32.c gcc -M -Wall -pedantic -idirafter ../include -DTEXT_BASE=0x08400000 -DUSE_HOSTCC environment.c img2srec.c mkimage.c crc32.c envcrc.cgen_eth_addr.c bmp_logo.c > .depend make[1]: Leaving directory `/home/user/workspace/u-boot-1.1.3/tools' make[1]: Entering directory `/home/user/workspace/u-boot-1.1.3/tools' make[1]: `.depend' is up to date. make[1]: Leaving directory `/home/user/workspace/u-boot-1.1.3/tools' make[1]: Entering directory `/home/user/workspace/u-boot-1.1.3/examples' /opt/eldk-3.1.1-arm/usr/bin/arm-linux-gcc -M -g -Os -fno-strict-aliasing -fno-common -ffixed-r8 -mshort-load-bytes -msoft-float -D__KERNEL__ -DTEXT_BASE=0x08400000 -I/home/user/workspace/u-boot-1.1.3/include -fno-builtin -ffreestanding -nostdinc -isystem /opt/eldk-3.1.1-arm/usr/bin/../lib/gcc-lib/arm-linux/3.3.3/include -pipe -DCONFIG_ARM -D__ARM__ -mapcs-32 -march=armv4 -Wall -Wstrict-prototypes hello_world.c stubs.c > .depend make[1]: Leaving directory `/home/user/workspace/u-boot-1.1.3/examples' make[1]: Entering directory `/home/user/workspace/u-boot-1.1.3/examples' make[1]: `.depend' is up to date. make[1]: Leaving directory `/home/user/workspace/u-boot-1.1.3/examples' make[1]: Entering directory `/home/user/workspace/u-boot-1.1.3/post' /opt/eldk-3.1.1-arm/usr/bin/arm-linux-gcc -M -g -Os -fno-strict-aliasing -fno-common -ffixed-r8 -mshort-load-bytes -msoft-float -D__KERNEL__ -DTEXT_BASE=0x08400000 -I/home/user/workspace/u-boot-1.1.3/include -fno-builtin -ffreestanding -nostdinc -isystem /opt/eldk-3.1.1-arm/usr/bin/../lib/gcc-lib/arm-linux/3.3.3/include -pipe -DCONFIG_ARM -D__ARM__ -mapcs-32 -march=armv4 -Wall -Wstrict-prototypes cache_8xx.S cache.c codec.c cpu.c dsp.c ether.c i2c.c memory.c post.c rtc.c spr.c sysmon.c tests.c uart.c usb.c watchdog.c > .depend make[1]: Leaving directory `/home/user/workspace/u-boot-1.1.3/post' make[1]: Entering directory `/home/user/workspace/u-boot-1.1.3/post' make[1]: `.depend' is up to date. make[1]: Leaving directory `/home/user/workspace/u-boot-1.1.3/post' make[1]: Entering directory `/home/user/workspace/u-boot-1.1.3/post/cpu' make[1]: *** No rule to make target `asm.S', needed by `.depend'. Stop. make[1]: Leaving directory `/home/user/workspace/u-boot-1.1.3/post/cpu' make: *** [depend] Error 2
*What's the matter?How to resolve?* *H..............elp!*
Tested with U-Boot-1.1.4 and top of tree: both build just fine.
Bad command: please omit the trailing '*'.
Works fine here.
Content-Type: text/html; charset=ISO-8859-1 Content-Transfer-Encoding: quoted-printable Content-Disposition: inline
And stop posting HTML here!!!
Hsia Jason
