[U-Boot] [PATCH] I2C: S3C24X0: Resolve build error for VCMA9
This patch resolves the build error for I2C driver in VCMA9.
Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- drivers/i2c/s3c24x0_i2c.c | 4 +++- drivers/i2c/s3c24x0_i2c.h | 3 ++- 2 files changed, 5 insertions(+), 2 deletions(-)
diff --git a/drivers/i2c/s3c24x0_i2c.c b/drivers/i2c/s3c24x0_i2c.c index 7ec01ec..769a2ba 100644 --- a/drivers/i2c/s3c24x0_i2c.c +++ b/drivers/i2c/s3c24x0_i2c.c @@ -67,9 +67,11 @@ * variables to live in SRAM */ static unsigned int g_current_bus __attribute__((section(".data"))); +#ifdef CONFIG_OF_CONTROL +static int i2c_busses __attribute__((section(".data"))); static struct s3c24x0_i2c_bus i2c_bus[CONFIG_MAX_I2C_NUM] __attribute__((section(".data"))); -static int i2c_busses __attribute__((section(".data"))); +#endif
#if !(defined CONFIG_EXYNOS4 || defined CONFIG_EXYNOS5) static int GetI2CSDA(void) diff --git a/drivers/i2c/s3c24x0_i2c.h b/drivers/i2c/s3c24x0_i2c.h index 1243bf1..c75bcab 100644 --- a/drivers/i2c/s3c24x0_i2c.h +++ b/drivers/i2c/s3c24x0_i2c.h @@ -31,11 +31,12 @@ struct s3c24x0_i2c { u32 iiclc; };
+#ifdef CONFIG_OF_CONTROL struct s3c24x0_i2c_bus { int node; /* device tree node */ int bus_num; /* i2c bus number */ struct s3c24x0_i2c *regs; enum periph_id id; }; - +#endif #endif /* _S3C24X0_I2C_H */
what about errors?
- variables to live in SRAM
I think int is suitable more than enum. Currently periph_id is exynos specific.
Thanks. Minkyu Kang.
Minkyu Kang
Rajeshwari Shinde
